void MX_ADC3_Init(void) { ADC_MultiModeTypeDef multimode = {0}; ADC_ChannelConfTypeDef sConfig = {0}; hadc3.Instance = ADC3; hadc3.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4; hadc3.Init.Resolution = ADC_RESOLUTION_12B; hadc3.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc3.Init.GainCompensation = 0; hadc3.Init.ScanConvMode = ADC_SCAN_DISABLE; hadc3.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc3.Init.LowPowerAutoWait = DISABLE; hadc3.Init.ContinuousConvMode = ENABLE; hadc3.Init.NbrOfConversion = 1; hadc3.Init.DiscontinuousConvMode = DISABLE; hadc3.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc3.Init.DMAContinuousRequests = DISABLE; hadc3.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc3.Init.OversamplingMode = DISABLE; if (HAL_ADC_Init(&hadc3) != HAL_OK) { Error_Handler(); } /** Configure the ADC multi-mode */ multimode.Mode = ADC_MODE_INDEPENDENT; if (HAL_ADCEx_MultiModeConfigChannel(&hadc3, &multimode) != HAL_OK) { Error_Handler(); } /** Configure Regular Channel */ sConfig.Channel = ADC_CHANNEL_1; sConfig.Rank = ADC_REGULAR_RANK_1; sConfig.SamplingTime = ADC_SAMPLETIME_92CYCLES_5; sConfig.SingleDiff = ADC_SINGLE_ENDED; sConfig.OffsetNumber = ADC_OFFSET_NONE; sConfig.Offset = 0; if (HAL_ADC_ConfigChannel(&hadc3, &sConfig) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN ADC3_Init 2 */ /* USER CODE END ADC3_Init 2 */ } HAL_ADCEx_Calibration_Start(&hadc3, ADC_SINGLE_ENDED); HAL_ADC_Start(&hadc3); 仿真时,查看DR寄存器,只有在开始运行仿真时转换一次就不再转换,改成外部TIM触发也只是能转换一次,是哪里配置错误吗? |
MCU的ADC进行电压采集时,外部输入阻抗最大能到多少?
stm32g474cct6 flash地址问题
在 main 函数里读取 ADC 采样数值
HRTIM中已经设置了两路独立输出,第二路无法设置触发源,提示必须是0
记录使用Cube生成HRTIM工程时的一个bug
STM32L010F4P6的ADC多通道采集,采用扫描+DMA的方式,采集到不同通道的值会一起变化
stm32 usb hid设备能发数据给PC,但不能接收PC的数据!!!
STSPIN32G4 STM32G431VBTx CAN FIFO发送数据帧随机变远程帧
如何将电机转速度控制在0.1RPM以下?我尝试过将SPEED_UNIT改为480,电机转速度可以控制在0.125RPM,但最转到250RPM时,编码器计数好像溢出了
STM32G474 HRTIM的single-shot功能,如何使用?
可能调试模块没有做更新,你也没有啥操作。
保持现有 配置的前提下,你这样试试,先软件启动ADC,然后查询接收,再看看结果。
int main(void)
uint8_t i=0;
HAL_ADC_Start(&hadc1);
while (1)
if (HAL_ADC_PollForConversion(&hadc1, 888) != HAL_OK)
Error_Handler();
AdcResulti++] = HAL_ADC_GetValue(&hadc1);
if(i==9) i=0;
} //while(1)
} //main
