在STM32N6570-DK上部署图像分类模型卡住了,求助。
LQC_ 提问时间:2025-5-16 13:40 / 未解决
大家好,
我按照下面的教程进行部署,在最后执行python stm32ai_main.py的时候出错,窗口日志如下。谁能帮我弄清楚发生了什么?应该怎么做?
https://github.com/STMicroelectronics/stm32ai-modelzoo-services/blob/main/image_classification/deployment/README_STM32N6.md
LOAD ERROR: WindowsPath('E:/07_Stm32/stm32N657/stm32ai-modelzoo-main/stm32ai-modelzoo-services-main/stm32ai-modelzoo-services/image_classification/src/deployment_outputs/2025_05_16_13_00_27/network.h') and WindowsPath('E:/07_Stm32/stm32N657/stm32ai-modelzoo-main/stm32ai-modelzoo-services-main/stm32ai-modelzoo-services/image_classification/src/deployment_outputs/2025_05_16_13_00_27/network.h') are the same file Error executing job with overrides: [] Traceback (most recent call last): File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src\stm32ai_main.py", line 421, in <module> main() File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra\main.py", line 94, in decorated_main _run_hydra( File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 394, in _run_hydra _run_app( File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 457, in _run_app run_and_report( File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 223, in run_and_report raise ex File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 220, in run_and_report return func() File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 458, in <lambda> lambda: hydra.run( File "D:\26_anaconda3\envs\n61\lib\site-packages\clearml\binding\hydra_bind.py", line 91, in _patched_hydra_run return PatchHydra._original_hydra_run(self, config_name, task_function, overrides, *args, *kwargs) File "D:\26anaconda3\envs\n61\lib\site-packages\hydra_internal\hydra.py", line 132, in run = ret.return_value File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra\core\utils.py", line 260, in return_value raise self._return_value File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra\core\utils.py", line 186, in run_job ret.return_value = task_function(task_cfg) File "D:\26_anaconda3\envs\n61\lib\site-packages\clearml\binding\hydra_bind.py", line 230, in _patched_task_function return task_function(a_config, a_args, **a_kwargs) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src\stm32ai_main.py", line 407, in main process_mode(mode=mode, configs=cfg, train_ds=train_ds, valid_ds=valid_ds, quantization_ds=quantization_ds, File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src\stm32ai_main.py", line 302, in process_mode deploy(cfg=configs) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../deployment\deploy.py", line 90, in deploy stm32ai_deploy_stm32n6(target=board, stlink_serial_number=stlink_serial_number, stm32ai_version=stm32ai_version, c_project_path=c_project_path, File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../../common/deployment\common_deploy.py", line 469, in stm32ai_deploy_stm32n6 stmaic_local_call(session) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../../common/deployment\common_deploy.py", line 443, in stmaic_local_call stmaic.compile(session=session, options=opt, target=session._board_config) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../../common\stm32ai_local\compile.py", line 208, in cmd_compile raise Exception('Error during compilation') Exception: Error during compilation
收藏 评论2 发布时间:2025-5-16 13:40
patch1582 回答时间:2025-5-27 20:44:58
我检索了所有*.c文件,没有重复调用network.h。这个错误不知道什么原因导致
范荣华 回答时间:2025-7-4 10:32:56
你引用了 两个 network.h,删除一个文件。
