请问一下STM32F103C8T6的Hardwar NSS Output ENABLE后cs持续拉低是为什么
Legend-奇君 提问时间:2026-5-8 11:07 / 未解决
我不太清楚为什么Hardwar NSS为什么不能在发送完以后自动拉高,我尝试过通过在HAL_SPI_Transmit_DMA函数前后添加开关nss或者开关spi的指令,但是这种做法会使得spi无法启动,如果不添加将会让cs信号持续低电平,下面是我的控制代码和spi配置代码。
/ USER CODE BEGIN Header /
  • @file dma.c
  • @brief This file provides code for the configuration
  • of all the requested memory to memory DMA transfers.
  • @attention
  • Copyright (c) 2026 STMicroelectronics.
  • All rights reserved.
  • This software is licensed under terms that can be found in the LICENSE file
  • in the root directory of this software component.
  • If no LICENSE file comes with this software, it is provided AS-IS.
/ USER CODE END Header /
/ Includes ------------------------------------------------------------------/
include "dma.h"
/ USER CODE BEGIN 0 /
/ USER CODE END 0 /
/ Configure DMA /
/ USER CODE BEGIN 1 /
/ USER CODE END 1 /
  • Enable DMA controller clock
void MX_DMA_Init(void)
/ DMA controller clock enable /
__HAL_RCC_DMA1_CLK_ENABLE();
/ DMA interrupt init /
/ DMA1_Channel3_IRQn interrupt configuration /
HAL_NVIC_SetPriority(DMA1_Channel3_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA1_Channel3_IRQn);
/ USER CODE BEGIN 2 /
static uint8_t dac_tx_buf[3];
uint8_t wTransferState = TRANSFER_COMPLETE;
uint8_t i=0;
uint16_t val;
void DAC_WriteA_DMA(uint16_t data)
while(wTransferState == TRANSFER_WAIT);
dac_tx_buf[0] = DAC_CH_A;
dac_tx_buf[1] = (data >> 8) & 0xFF;
dac_tx_buf[2] = data & 0xFF;
wTransferState = TRANSFER_WAIT;
HAL_SPI_Transmit_DMA(&hspi1, dac_tx_buf, 3); }
void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi)
if(hspi == &hspi1)
void DAC_GenSawtooth_2P2KHz(void)
static uint16_t dac_val = 0;
DAC_WriteA_DMA(dac_val);
dac_val += 384;
if(dac_val >= MAX_DAC_VALUE)
dac_val = 0;
/ USER CODE END 2 /
  • @file spi.c
  • of the SPI instances.
  • @attention
include "spi.h"
/ USER CODE END 0 /
SPI_HandleTypeDef hspi1;
DMA_HandleTypeDef hdma_spi1_tx;
/ SPI1 init function /
void MX_SPI1_Init(void)
/ USER CODE BEGIN SPI1_Init 0 /
/ USER CODE END SPI1_Init 0 /
/ USER CODE BEGIN SPI1_Init 1 /
/ USER CODE END SPI1_Init 1 /
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_2EDGE;
hspi1.Init.NSS = SPI_NSS_HARD_OUTPUT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_16;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
Error_Handler(); }
/ USER CODE BEGIN SPI1_Init 2 /
/ USER CODE END SPI1_Init 2 /
void HAL_SPI_MspInit(SPI_HandleTypeDef* spiHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(spiHandle->Instance==SPI1)
/ USER CODE BEGIN SPI1_MspInit 0 /
/ USER CODE END SPI1_MspInit 0 /
/ SPI1 clock enable /
__HAL_RCC_SPI1_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**SPI1 GPIO Configuration
PA4 ------> SPI1_NSS
PA5 ------> SPI1_SCK
PA7 ------> SPI1_MOSI
GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_7;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/ SPI1 DMA Init /
/ SPI1_TX Init /
hdma_spi1_tx.Instance = DMA1_Channel3;
hdma_spi1_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
hdma_spi1_tx.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_spi1_tx.Init.MemInc = DMA_MINC_ENABLE;
hdma_spi1_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
hdma_spi1_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
hdma_spi1_tx.Init.Mode = DMA_NORMAL;
hdma_spi1_tx.Init.Priority = DMA_PRIORITY_VERY_HIGH;
if (HAL_DMA_Init(&hdma_spi1_tx) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(spiHandle,hdmatx,hdma_spi1_tx);
/ SPI1 interrupt Init /
HAL_NVIC_SetPriority(SPI1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(SPI1_IRQn); / USER CODE BEGIN SPI1_MspInit 1 /
/ USER CODE END SPI1_MspInit 1 /
void HAL_SPI_MspDeInit(SPI_HandleTypeDef* spiHandle)
/ USER CODE BEGIN SPI1_MspDeInit 0 /
/ USER CODE END SPI1_MspDeInit 0 /
/ Peripheral clock disable /
__HAL_RCC_SPI1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_7);
/ SPI1 DMA DeInit /
HAL_DMA_DeInit(spiHandle->hdmatx);
/ SPI1 interrupt Deinit /
HAL_NVIC_DisableIRQ(SPI1_IRQn); / USER CODE BEGIN SPI1_MspDeInit 1 /
/ USER CODE END SPI1_MspDeInit 1 /
/ USER CODE END 1 /
赞 收藏 评论2 发布时间:2026-5-8 11:07
butterflyspring 回答时间:2026-5-8 15:34:28
试了一下,禁止SPI工作,似乎也没有拉高。
不过这个手册上也说了,不会自动拉高的。
从应用上讲,控制从设备想拉高的话,开始通过IO口比较灵活,在开始时拉低,在完成的回调里拉高。
xmshao 回答时间:2026-5-9 15:30:02
估计stm32早期的32F系列这个地方都有这个缺陷,后来新推出的STM32G/H/U等系列的SPI都支持NSSP模式,即发完一串数据后可以自动拉高,不要再手动去拉高。
我们做选型时尽量选择新推出的系列,其实性价比更高。
