用的stm32f2xx_stdperiph_lib里的示例程序做CAN通信测试,环回模式测试OK。正常模式下,用CAN调试软件向板子发数据,始终进不了接收中断 .c文件 int main(void) { /* NVIC configuration */ NVIC_Config(); /* CAN configuration */ CAN_Config(); /* Infinite loop */ while(1) { Delay(); } } void CAN_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; /* CAN GPIOs configuration **************************************************/ /* Enable GPIO clock */ RCC_AHB1PeriphClockCmd(CAN_GPIO_CLK, ENABLE); GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_RX_SOURCE, CAN_AF_PORT); GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_TX_SOURCE, CAN_AF_PORT); /* Configure CAN RX and TX pins */ GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN | CAN_TX_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure); /* CAN configuration ********************************************************/ /* Enable CAN clock */ RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE); /* CAN register init */ CAN_DeInit(CANx); /* CAN cell init */ CAN_InitStructure.CAN_TTCM = DISABLE; CAN_InitStructure.CAN_ABOM = DISABLE; CAN_InitStructure.CAN_AWUM = DISABLE; CAN_InitStructure.CAN_NART = DISABLE; CAN_InitStructure.CAN_RFLM = DISABLE; CAN_InitStructure.CAN_TXFP = DISABLE; CAN_InitStructure.CAN_Mode = CAN_Mode_Normal; CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; /* CAN Baudrate = 1MBps (CAN clocked at 30 MHz) */ /*CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq; CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq; CAN_InitStructure.CAN_Prescaler = 2; CAN_Init(CANx, &CAN_InitStructure);*/ /* CAN filter init */ #ifdef USE_CAN1 CAN_FilterInitStructure.CAN_FilterNumber = 0; #else /* USE_CAN2 */ CAN_FilterInitStructure.CAN_FilterNumber = 14; #endif /* USE_CAN1 */ CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask; CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit; CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000; CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000; CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0; CAN_FilterInitStructure.CAN_FilterActivation = ENABLE; CAN_FilterInit(&CAN_FilterInitStructure); /* Enable FIFO 0 message pending Interrupt */ CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE); } void NVIC_Config(void) { NVIC_InitTypeDef NVIC_InitStructure; #ifdef USE_CAN1 NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn; #else /* USE_CAN2 */ NVIC_InitStructure.NVIC_IRQChannel = CAN2_RX0_IRQn; #endif /* USE_CAN1 */ NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } .h头文件 #define USE_CAN1 //#define USE_CAN2 #ifdef USE_CAN1 #define CANx CAN1 #define CAN_CLK RCC_APB1Periph_CAN1 #define CAN_RX_PIN GPIO_Pin_11 #define CAN_TX_PIN GPIO_Pin_12 #define CAN_GPIO_PORT GPIOA #define CAN_GPIO_CLK RCC_AHB1Periph_GPIOA #define CAN_AF_PORT GPIO_AF_CAN1 #define CAN_RX_SOURCE GPIO_PinSource11 #define CAN_TX_SOURCE GPIO_PinSource12 #else /*USE_CAN2*/ #define CANx CAN2 #define CAN_CLK (RCC_APB1Periph_CAN1 | RCC_APB1Periph_CAN2) #define CAN_RX_PIN GPIO_Pin_12 #define CAN_TX_PIN GPIO_Pin_13 #define CAN_GPIO_PORT GPIOB #define CAN_GPIO_CLK RCC_AHB1Periph_GPIOB #define CAN_AF_PORT GPIO_AF_CAN2 #define CAN_RX_SOURCE GPIO_PinSource12 #define CAN_TX_SOURCE GPIO_PinSource13 #endif /* USE_CAN1 */ stm32f2xx_it.c 文件中涉及的CAN接收中断程序 #ifdef USE_CAN1 void CAN1_RX0_IRQHandler(void) { CAN_Receive(CAN1, CAN_FIFO0, &RxMessage); CAN_FIFORelease(CAN2, CAN_FIFO0); } #endif /* USE_CAN1 */ #ifdef USE_CAN2 /** * @brief This function handles CAN2 RX0 request. * @param None * @retval None */ void CAN2_RX0_IRQHandler(void) { CAN_Receive(CAN2, CAN_FIFO0, &RxMessage); CAN_FIFORelease(CAN2, CAN_FIFO0); } #endif /* USE_CAN2 */ 以上,PC端通过USB-CAN-A2设备与板子连接,CAN调试工具不断发数据。用示波器测收发器的CANH及CANL脚,有脉冲波形,说明CAN口能正常接收到PC端数据。但测收发器的RX脚(RX脚连MCU引出的PA11脚,复用为CAN_RX功能)始终为高电平,没有收到有效信号。 |
STM32F207+LWIP的网络丢包问题! 【悬赏问答】
STM32F207+DP83848+RTL8019可不可以实现双网口设计
深圳市旺宝电子STM32F207开发板例程集
STM32F2 器件 -25° 上电正常 复位就挂了
STM32F229 TIMER CNT问题
哪位工程师有STM32F2xx的寄存器手册?
STM32F2xx RTC启动不了,求助!!!!
STM32F2外部按键触发中断问题
STM32F205 低功耗模式有BUG?
STM32F207 两个ADC同时采样问题
RE:STM32F205 CAN通信问题
RE:STM32F205 CAN通信问题 【悬赏问答】
