各位大侠本人最近在调试STM32F373VCT6 芯片,需要用到SPI接口,但是调试了1天都没有任何进展,我先上程序,请大家帮忙分析一下,谢谢! void SPI_Config(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIO clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE); /* Enable the SPI peripheral */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); /* SPI MOSI pin configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_PinSource9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOC, &GPIO_InitStructure); /* SPI SCK pin configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_PinSource7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); /* SPI MISO pin configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_PinSource8; GPIO_Init(GPIOC, &GPIO_InitStructure); /* SPI NSS pin configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_PinSource6; GPIO_Init(GPIOC, &GPIO_InitStructure); /* SPI pin mappings */ GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_5); GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_5); GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_5); GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_5); /* SPI configuration -------------------------------------------------------*/ SPI_Cmd(SPIx, DISABLE); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Hard; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; /* Initializes the SPI communication */ SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_Init(SPI1, &SPI_InitStructure); /* Initialize the FIFO threshold */ SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF); /* Enable the SPI peripheral */ SPI_Cmd(SPI1, ENABLE); } void SPI_Bufferwrite(unsigned char *buffer,unsigned char num) { unsigned char i; for(i=0;i |
STM32F3 硬件I2C 驱动OLED 求助!!
STM32F303使用定时器触发双ADC常规同步采样模式
哪位大哥传下STM32F334 Nucleo的工程模板给我下
STM32F334 不能串口下载
关于STM32F334的HRTIM分辨率问题
STM32F303+LCD1602程序问题,不只为什么点不亮?
STM32F334的ADC使用问题
STM32F334 HRTIM形成移相全桥波形问题
STM32F103C8T6替换STM32F301C8T6
关于STM32F3 ADC在差分模式下的采样率计算问题
回复:STM32F373VCT6 SPI接口程序问题
/*!< Configure SD_SPI pins: SCK */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //这里是端口配置
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //SCK上拉
/*!< Configure SD_SPI pins: MISO */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
/*!< Configure SD_SPI pins: MOSI */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
/*!< Configure CS_PIN pin: */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; // 用通用IO来配置--不用NSS
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
SPI配置参考:
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_Cmd(SPI1, ENABLE); /*!< SD_SPI enable */
当然是你的SPI时钟配置出问题了:首先你的端口配置有问题,参考代码如下:
SPI配置参考:
非常感谢,我回头试试,有消息了告诉你!
RE:STM32F373VCT6 SPI接口程序问题
STM32 SPI接口的简单实现
STM32的SPI接口
推荐你看下这里:
STM32 SPI接口的简单实现
STM32的SPI接口
现在SPI是可以工作了,但是为什么我非的要执行
while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE)==RESET); //ÅжÏÊÇ·ñÒѾ·¢ËÍÍê³É
SPI1->DR = byte;
以上程序后,再进行
while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE)==RESET);
buffer = SPI1->DR;
就不会出问题。
但是如果我不首先执行
SPI1->DR = byte;
程序就会一直卡死在 while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE)==RESET);这条程序。
我不知道我的表达是否清楚,能帮我解释一下吗,谢谢!
