请教一个古怪的STM32F205的串口DMA接收问题
FSL_FAE_NEO 提问时间:2013-12-19 13:03 /
几乎是按照官方例子配出来的程序.  我是想设置4个字节到缓冲区后产生接收传输完成中断. 然后一次处理4个字节,但是PC只要向STM32发送1个字节,DMA_FLAG_TCIF1马上就置位了, 缓冲区里面也没有数据,但是看USART-DR里是收到那个字符的.
下面是初始化代码,为了简化我没有中断,配置好串口后一直查询 DMA_FLAG_TCIF1 标志位.
// 初始化函数,外面会传一个BUF首地址和长度进来作为DMA接收缓冲区
void HAL_UARTDevInit (const UINT8 *p_rec_buf, UINT32 num)
    UINT8 err;
    DMA_InitTypeDef dma_init_structure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
    /* Connect PXx to USARTx_Tx*/
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_USART3);
    /* Connect PXx to USARTx_Rx*/
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_USART3);
    /* Configure USART Tx as alternate function  */
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
    /* Configure USART Rx as alternate function  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    /* USART configuration */
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_Init(USART3, &USART_InitStructure);
   // USART_ClearFlag(USART3, USART_FLAG_TC | USART_FLAG_RXNE);                   /* 清除已有的标志位, 防止使能后直接进入该中断 */
    USART_Cmd(USART3, ENABLE);
    /* 当配置DMA时初始化DMA接收通道 */
    DMA_DeInit(DMA1_Stream1);
    dma_init_structure.DMA_Channel            = DMA_Channel_4;
    dma_init_structure.DMA_PeripheralBaseAddr = (uint32_t)(USART3 + 0x04);
    dma_init_structure.DMA_Memory0BaseAddr    = (uint32_t)p_rec_buf;
    dma_init_structure.DMA_DIR                = DMA_DIR_PeripheralToMemory;
    dma_init_structure.DMA_BufferSize         = num;
    dma_init_structure.DMA_PeripheralInc      = DMA_PeripheralInc_Disable;
    dma_init_structure.DMA_MemoryInc          = DMA_MemoryInc_Enable;
    dma_init_structure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    dma_init_structure.DMA_MemoryDataSize     = DMA_MemoryDataSize_Byte;
    dma_init_structure.DMA_Mode               = DMA_Mode_Normal;
    dma_init_structure.DMA_Priority           = DMA_Priority_VeryHigh;
    dma_init_structure.DMA_FIFOMode           = DMA_FIFOMode_Disable;
    dma_init_structure.DMA_FIFOThreshold      = DMA_FIFOThreshold_Full;
    dma_init_structure.DMA_MemoryBurst        = DMA_MemoryBurst_Single;
    dma_init_structure.DMA_PeripheralBurst    = DMA_PeripheralBurst_Single;
    DMA_Init(DMA1_Stream1, &dma_init_structure);
    USART_DMACmd(USART3, USART_DMAReq_Rx, ENABLE);
    DMA_Cmd(DMA1_Stream1, ENABLE);
//测试代码
unsigned char buffer[4];
HAL_UARTDevInit(buffer, 4);
while (DMA_GetFlagStatus(DMA1_Stream1, DMA_FLAG_TCIF1) == RESET)
while(1); // 设个断点程序达到此处后停下来观察内存. 只要串口接受到1个字节就会到这里, buffer里全是0, 而USART3->DR里有我发过来的数据.   详细对比了几遍和例程 USART_TwoBoards\DataExchangeDMA.  几乎没有不同. 我禁止掉了FIFO模式, 如果启用FIFO也是一样
请高人帮忙!
赞 收藏 1 评论5 发布时间:2013-12-19 13:03
5个回答
Hiker天下 回答时间:2013-12-19 16:26:17
RE:请教一个古怪的STM32F205的串口DMA接收问题
你可以这用判断发送完成标志, 只判断DMA的发送长度是否为0就可以了。我在F10x,F4xx都是这样做的,性能很可靠。
qq1279893629 回答时间:2013-12-20 11:49:15
少了DMA中断使能。NVIC_EnableIRQ(DMA1_Channe4_IRQn);
楼主可以多找几个历程,多对比下,总会找到差别的。
wkuang 回答时间:2013-12-22 23:29:02
研究下寄存器的具体意义吧,不要只看官方历程,结合datasheet看嗲吗还是有必要的。
官方的库/例程可以参考,但是不要完全不思考,个人建议
无帝老三 回答时间:2017-3-15 13:57:17
遇到同样问题,设置接收buf128个字节
那接收到128个字节才会认为是接收完成啊
怎么第一个字节就进入接收完成中断了,楼主解决没?
gege770 回答时间:2017-4-27 09:24:18
将USART_Cmd(USART3, ENABLE);放在DMA_Cmd(DMA1_Stream1, ENABLE);后面试试
