【原创】STM32F0第一个工程,LED/串口收发中断
abner88 发布时间:2014-3-11 22:34
    之前买的STM32F0Discovery开发板一直没用,前几天才开始折腾,记录下第一个工程吧。
" Y3 ]& ^7 t$ q5 q6 w) M( K    玩过STM32F10xx,发现F0开发方式和F1很接近,F1很多代码稍作修改便可移植到F0上。
5 O; Y7 R0 `/ V( m, q    基于IAR7.1建立工程。( v6 d8 Y/ y) R
6 i# |+ [+ D' p; P
9 \: `1 Y& X7 i. W9 [# z. p, q ! T' a( W/ t; Q, e
 : O, q( g- s4 P( T
$ z4 J  x+ n0 ~2 s# t, X0 @
7 x; T1 _3 A8 p$ `4 t* d8 \、、串口初始化
- k7 X* h6 S8 R8 [: { 0 O) v8 W% H1 d; T
void Usart_Config(uint16_t Usart_BaudRate)& k/ C/ D: i% M/ p0 Z5 m% O9 @
$ F, N/ `  T, K6 G! m. L  NVIC_InitTypeDef  NVIC_InitStructure; 0 I( M+ n8 Y# {8 z! ]0 y
  GPIO_InitTypeDef  GPIO_InitStructure;
; v" V- g) o; C$ ?( o5 j* U- J  USART_InitTypeDef USART_InitStructure; ; @" ]9 H7 _) {" ]
. C- k7 N( {& T* E4 N0 G  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);   //enable clock of GPIOA
& R8 K% t, Y/ {9 S1 a" Y: \  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //enable clock of USART1
8 s# h, L. H1 U6 `9 y& i' {* I  2 P1 [: ?' |$ N9 _( ?7 p( Z
  /* Configure USART Tx as alternate function push-pull */
6 w: k5 |$ H5 \- h  GPIO_InitStructure.GPIO_Pin       =   GPIO_Pin_9 | GPIO_Pin_10;& Q. l0 P* @8 r1 |
  GPIO_InitStructure.GPIO_Mode      =   GPIO_Mode_AF;- T3 q" G  j- i$ l9 a
  GPIO_InitStructure.GPIO_Speed     =   GPIO_Speed_50MHz;
8 Z+ G2 f  @" u0 C$ I9 u& O  GPIO_InitStructure.GPIO_OType     =   GPIO_OType_PP;% X5 O' B+ N$ a% k) L
  GPIO_InitStructure.GPIO_PuPd      =   GPIO_PuPd_UP;
6 x; J- k( c# N3 P' J2 Y6 l0 p  GPIO_Init(GPIOA, &GPIO_InitStructure);  E2 u, v) b  s; r1 U$ e" m
  : H# A, P8 P/ w) ?  T* k6 e
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);//PA9 as Usart1_TX! T9 E* d! ?: ?
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);//PA10 as Usart1_RX
% c# a4 _/ z; [& p' z( P* |$ W  - Y/ |' q' S+ |. Y- e3 c6 m: U! x  f
  USART_InitStructure.USART_BaudRate          =   Usart_BaudRate;
5 t8 I0 @- y) z' x& @  USART_InitStructure.USART_WordLength        =   USART_WordLength_8b;
5 }7 W9 Q4 m9 k" e' C  USART_InitStructure.USART_StopBits          =   USART_StopBits_1;
: B# w: _1 t9 E8 ~! g2 J& A  USART_InitStructure.USART_Parity            =   USART_Parity_No;
$ A& x# s1 N4 e, @! |6 H  USART_InitStructure.USART_Mode              =   USART_Mode_Rx | USART_Mode_Tx;
3 o% y+ j' t* j1 d% d) l  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;' y- T1 I$ _6 P# g. d
  USART_Init(USART1,&USART_InitStructure);% C3 ^+ o) T9 }2 p* p( j5 ^
  ' f: Z- ~2 \) s; C3 c& H
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;& b& A, O  `$ t6 Y  a3 A$ M6 f
  NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
7 R% x+ ]' |& L( a" z' d" u2 P4 L  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
5 A- _: [" r2 c  NVIC_Init(&NVIC_InitStructure);
' e4 E/ i* ~! ~; g" P: Y0 J$ W& ]) l& Z2 D# b
#if USART_RXNE_INTERRUPT
$ j+ ?& h/ \6 U  USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);! o" ]2 m& `$ `: O3 U
#endif, Y# o! d3 C4 U9 Q( Q
% f0 ?: b" z! @/ R. M- V
  USART_Cmd(USART1, ENABLE);//enable USART1
0 k+ a& ^, U8 r# n0 l  2 `( ~, ~- m5 n: J
#if USART_TC_INTERRUPT        7 S& r, _7 ?2 w" J6 M& r
  USART_ClearFlag(USART1,USART_FLAG_TC);
; i9 J3 N6 {7 ^4 ~/ y& R  USART_ITConfig(USART1,USART_IT_TC,ENABLE);7 S$ W3 t. ?. n( \" X7 Z" i1 d
#endif
% l/ ]3 y8 Q8 j3 k; f3 K/ k8 E2 s}1 n2 Q; Q5 e+ ^  D7 R8 ]9 c4 k) Z
    在做GPIO复用功能映射的时候,第二个参数不要习惯性的写成GPIO_Pin_9,红色部分代码# Y( X) l+ w/ U  e9 @
    为方便代码裁剪,使用宏定义来控制。因为使能中断的时候会自动发送一个空闲帧,TC中断标志位会置位,所以TC中断开启的操作应当放在串口使能操作之后,并且开启TC中断之前应当清除一次TC中断标志位,否则一旦串口初始化完毕,就会进入TC中断。如上蓝色部分代码。
' h6 G/ u7 v& ]7 v; @5 Z
" \1 _$ [1 p" R+ ]- B+ `. w8 N+ @3 o , p) u& C  T% Q# u! e
) M$ S4 j: E$ D3 d; `, r、、发送字节
- O6 [  y* o/ m4 d4 J1 m 5 t# G- p; Q$ t" p+ ^
void Usart_TxByte(uint8_t dat)
7 O1 k0 P1 |4 U) t* K{
$ S5 j1 F1 }0 D$ E  USART_SendData(USART1,dat);
- H* v  x4 C. j% P, B; H3 K8 J  while (USART_GetFlagStatus(USART1, USART_FLAG_TC) != SET);//wait untill transmitt complete
7 ]2 n, M8 O' C5 _+ L. K}
  X; I; ^( N% \
5 Y7 y1 A$ k5 ~3 [
8 @, i' P; T3 O$ s' Y. {9 h2 r 1 J$ r' Y8 k" z4 R% q+ ~/ U
、、发送字符串
% u" W) F" l0 c/ \0 h  y# U  }   p0 E  ~" |, ]! b
void Usart_TxString(uint8_t *string)' k3 d- x  G9 I
# J" ?( w0 ?1 k& _  while(*string != '\0')
( O' T) s# n3 M) U: a    Usart_TxByte(*string++);
( `: F3 G! K2 E5 n2 k. Y/ e  i}
' A/ H; |6 e( j4 b
8 C% t1 b" W# Q1 i9 U( G+ F, Y
2 f0 ?0 o/ s: o: x& i! G $ y" N5 J4 n0 g# O, F
、、中断服务函数! s* N( U9 s6 F& a  D6 z
 3 e3 K2 V( F0 y' A0 \
) B9 W. |5 r- b6 y
<span style="font-size: small;">void USART1_IRQHandler(void)6 {6 e6 ]5 P$ G. i2 @1 ~
{2 R- R% B/ ]5 ~7 ^
  static uint8_t n = 0;
: H/ L+ k/ w) O
/ f4 a( }3 B' U- {) `" P  if(USART_GetFlagStatus(USART1,USART_FLAG_ORE))    //ORE interrupt
( S  i$ r# x  i( P    USART1->ICR |= 1
01--USART.rar
300.04 KB, 下载次数: 528
参与人数 1 ST金币 +8 收起 理由
奥丁泰尔 + 8
赞 收藏 评论23 发布时间:2014-3-11 22:34
23个回答
fansanderen 回答时间:2018-5-11 16:26:28
楼主你好,我用这个例程在中断一直报if(USART_GetFlagStatus(USART1,USART_FLAG_ORE))        //溢出中断
! J7 q- h; J$ M/ E0 ?  G    USART1->ICR |= 1 << 3;// USART_ReceiveData(USART1);这里一直执行,不知道能否解决?
dearfar 回答时间:2016-1-29 16:09:21
谢谢楼主,有用处
zui135-124601 回答时间:2015-1-7 11:08:12
有用,好东西.........................
沐紫 回答时间:2014-3-17 19:54:24
RE:【原创】STM32F0第一个工程,LED/串口收发中断
支持!
kakashi2010 回答时间:2014-3-19 00:53:42
谢谢楼主,看看吧。
bn777_mcu 回答时间:2014-3-19 08:10:51
看看
lillian-368088 回答时间:2014-3-19 08:57:32
谢谢楼主· ·· 看看
lillian-368088 回答时间:2014-3-19 08:57:47
谢谢楼主
abner88 回答时间:2014-3-20 09:48:26
回复:【原创】STM32F0第一个工程,LED/串口收发中断
回复第 2 楼 于2014-03-17 19:54:24发表:- E/ \, \" _% R
支持!& ^; y! T! A4 v$ m8 N5 U# w
 第一次在论坛发帖,感谢管理员支持
wangjuneric 回答时间:2014-3-20 14:44:10
学习学习
q2459451851 回答时间:2014-3-25 16:15:06
恩恩,嘿嘿
w627255898 回答时间:2014-4-19 11:59:04
谢谢
jerry9203 回答时间:2014-5-2 13:52:17
junliangdt 回答时间:2014-5-3 14:40:10
绝对支持,下了,学习
kenneth19800322 回答时间:2014-6-23 09:39:39
Thank you very much for your sharing.
自由人-379179 回答时间:2014-8-16 17:28:44
学习一下 好像 F0的串口中断和STM32F1的中断标志清除方式不一样
◆Flyzym◆ 回答时间:2014-8-17 11:51:03
谢谢楼主,看看吧。
12下一页
