情况是这样的,用STM32F105作host驱动U盘,用的STM32的MSC库,前面都没有问题 Enumeration completed > USBH_USR_UserInput OK. (我只在原库基础上加了串口中断输出调试) 一直卡在USBH_MSC_Handle 里的USBH_MSC_GETMaxLUN 里的USBH_CtlReq等,卡在(case CMD_WAIT)这了,谁知道是什么原因?如何解? 贴码如下: USBH_Status USBH_CtlReq (USB_OTG_CORE_HANDLE *pdev, USBH_HOST *phost, uint8_t *buff, uint16_t length) { USBH_Status status; status = USBH_BUSY; switch (phost->RequestState) { case CMD_SEND: /* Start a SETUP transfer */ USBH_SubmitSetupRequest(phost, buff, length); phost->RequestState = CMD_WAIT; status = USBH_BUSY; break; case CMD_WAIT: if (phost->Control.state == CTRL_COMPLETE ) { /* Commands successfully sent and Response Received */ phost->RequestState = CMD_SEND; phost->Control.state =CTRL_IDLE; status = USBH_OK; } else if (phost->Control.state == CTRL_ERROR) { /* Failure Mode */ phost->RequestState = CMD_SEND; status = USBH_FAIL; } else if (phost->Control.state == CTRL_STALLED ) { /* Commands successfully sent and Response Received */ phost->RequestState = CMD_SEND; status = USBH_NOT_SUPPORTED; } break; default: break; } return status; } |
STM3210C-EVAL USB 官方例程调试报错
STM32F103 全速 USB 大容量存储方案咨询
STM32H573ZI 全速 USB
STM32F103的USB的虚拟串口,串口助手打开的时候会收到两条数据,第一条数据是前5秒串口助手未打开时发送的,这怎么解决?
询问电源纹波对芯片的影响
STM32F2xx 是否有 UVC 相关示例工程
VL53L5CX无法使用
stm32f107裸机+HR911105A+lwIP 1.31 SYN发送失败的问题
MCU的ADC进行电压采集时,外部输入阻抗最大能到多少?
