STM32F091微控制器单片集成最高256KB的闪存和32KB的 SRAM存储器,足以实现Java堆栈,能够运行通常只有大存储容量或昂贵产品才能运行的复杂应用软件,带来令人满意的用户体验。全系列产品(包括经济型48引脚微控制器)均配备6个USART,其中3个USART能够支持智能卡、区域互联网 (LIN, Local Interconnect Network)、红外线传输 (IrDA, Infrared Data Association,IrDA)和Modbus[1]模式。
2、NucleoF303RE特性
板载stlinkV2调试下载器
芯片:
Core: ARM? Cortex?-M4 32-bit CPU with
72 MHz FPU, single-cycle multiplication and
HW division, 90 DMIPS (from CCM), DSP
instruction and MPU (memory protection unit)
? Operating conditions:
– VDD, VDDA voltage range: 2.0 V to 3.6 V
? Memories
– Up to 512 Kbytes of Flash memory
– 64 Kbytes of SRAM, with HW parity check
implemented on the first 32 Kbytes.
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x 16 PLL option
– All mappable on external interrupt vectors
– Several 5 V-tolerant
? Interconnect matrix
? 12-channel DMA controller
? Four ADCs 0.20 μs (up to 40 channels) with
selectable resolution of 12/10/8/6 bits, 0 to
3.6 V conversion range, separate analog
supply from 2.0 to 3.6 V
? Two 12-bit DAC channels with analog supply
from 2.4 to 3.6 V
? Seven ultra-fast rail-to-rail analog comparators
with analog supply from 2.0 to 3.6 V
? Four operational amplifiers that can be used in
PGA mode, all terminals accessible with analog
supply from 2.4 to 3.6 V
1、开发板的话STM32F429IDISCOVERY
The STM32F429 Discovery helps you to discover the high-performance microcontrollers of the STM32 F4 series and to develop your applications easily.
It offers everything required for beginners and experienced users to get started quickly.
Based on the STM32F429ZIT6, it includes an ST-LINK/V2 embedded debug tool, a 2.4" QVGA TFT LCD, an external SDRAM of 64 Mbits,
a gyroscope ST MEMs, a USB OTG micro-AB connector, LEDs and pushbuttons.
Key Features
STM32F429ZIT6 microcontroller featuring 2 MB of Flash memory, 256 KB of RAM in an LQFP144 package
On-board ST-LINK/V2 with selection mode switch to use the kit as a standalone
ST-LINK/V2 (with SWD connector for programming and debugging)
Board power supply: through the USB bus or from an external 3 V or 5 V supply voltage
2.4" QVGA TFT LCD
SDRAM 64 Mbits
L3GD20, ST MEMS motion sensor, 3-axis digital output gyroscope
Six LEDsD1 (red/green) for USB communicationLD2 (red) for 3.3 V power-onTwo user LEDsD3 (green), LD4 (red)Two USB OTG LEDsD5 (green) VBUS and LD6 (red) OC (over-current)
Two pushbuttons (user and reset)
USB OTG with micro-AB connector
Extension header for LQFP144 I/Os for a quick connection to the prototyping board and an easy probing
2、开发板采用STM32F429ZIT6
Features
• Core: ARM 32-bit Cortex™-M4 CPU with FPU,
Adaptive real-time accelerator (ART
Accelerator™) allowing 0-wait state execution
from Flash memory, frequency up to 180 MHz,
MPU, 225 DMIPS/1.25 DMIPS/MHz
(Dhrystone 2.1), and DSP instructions
• Memories
– Up to 2 MB of Flash memory organized into
two banks allowing read-while-write
– Up to 256+4 KB of SRAM including 64-KB
of CCM (core coupled memory) data RAM
– Flexible external memory controller with up
to 32-bit data bus: SRAM,PSRAM,SDRAM,
Compact Flash/NOR/NAND memories
• LCD parallel interface, 8080/6800 modes
• LCD-TFT controller up toSVGA resolution with dedicated Chrom-ART Accelerator™ for enhanced graphic content creation (DMA2D)
• Clock, reset and supply management
– 1.8 V to 3.6 V application supply and I/Os
– POR, PDR, PVD and BOR
– 4-to-26 MHz crystal oscillator
– Internal 16 MHz factory-trimmed RC (1%
accuracy)
– Internal 32 kHz RC with calibration
• Low power
– Sleep, Stop and Standby modes
–VBATsupply for RTC, 20×32 bit backup registers + optional 4 KB backup SRAM
• 3×12-bit, 2.4 MSPS ADC: up to 24 channels and 7.2 MSPS in tripleinterleaved mode
• 2×12-bit D/A converters
• General-purpose DMA: 16-stream DMA
controller with FIFOs and burst support
• Up to 17 timers: up to twelve 16-bit and two 32-bit timers up to 180 MHz, each with up to 4 IC/OC/PWM or pulse counter and quadrature (incremental) encoder input
• Debug mode
– SWD & JTAG interfaces
– Cortex-M4 Embedded Trace Macrocell™ brstm32f4.pdf(1.98 MB, 下载次数: 0)
【STM32F410x8 STM32F410xB】基于ARM Cortex-M4内核的32位微控制器,MCU+FPU,125DMIPS,128KB闪存、32KB RAM,9个TIM,1个ADC,9个通信外设接口和摄像头
(ARM®-Cortex®-M4 32b MCU+FPU, 125 DMIPS, 128KB Flash, 32KB RAM, 9 TIMs, 1 ADC, 9 comm. interfaces)
该产品拥有一个灵活的功率架构,模拟电路包括最高工作电压3.6V的12位1.0μs ADC和双通道12位DAC,能够最大限度地扩大动态范围,同时数字电路可在更低的电压下工作,最大限度地降低功耗。此外,微控制器的I/O引脚可单独供电,无需电平转换器(level shifter)即可直接连接一个低压配套芯片,如应用处理器。
STM32F091内置CAN2.0A/B支持功能,可用于控制汽车网络的车载信息娱乐应用及工业控制应用。此外,设计人员还可利用芯片内部集成的触控器以及SysTick定时器和实时时钟开发创新应用,其中实时时钟可提高实时处理性能,提供时间日期或日历功能。
Getting started with STM32 Nucleo board software
这个STM32F091,由于其多串口的特性,开发应用在一个数据采集终端作为协议转换器使用。
(2)芯片特性
1、RTC功能,可以使用备用电池,精准走时!
2、4路12/10/8/6位精度可选的快速ADC,多达40个通道!
3、512KB的Flash,可以支持操作系统,跑文件系统,外接SD存储,可以允许更多通道,更长时间的数据采集和存储,十分方便!
4、全速USB接口,可以将采集到的数据通过USB数据线传送到上位机。
(3)制作应用
7路压力信号同步采集器_DMA+UART
【2】板子主要特性
NUCLEO-L053R8 是ST公司推出的一款针对STM32L0系列设计的Cortex-M0+开发板,
具有 mbed 功能,
支持Arduino。
同时还提供 ST Morpho 扩展排针,可连接微控制器的所有周边外设。
1.65V~3.6V工作电压!
最低0.27微安超低功耗!
工作频率最高可达32MHz,
集成了存储器保护单元(MPU),高速嵌入存储器(64KB闪存,2KB数据EEPROM和8KB RAM),
工作温度-40 到125 ℃,
【3】做过的设计:
鱼缸水位监测、自动补水!
智能小车!
2、NucleoF303RE特性
板载stlinkV2调试下载器
芯片:
? Memories
from 2.4 to 3.6 V
3、应用
循迹智能小车
室内温湿度、危险气体监控
1使用正点原子的战舰mini开发板
2ARM 32-bit Cortex-M3 Microcontroller, 72MHz, 128kB Flash, 20kB SRAM,
PLL, Embedded Internal RC 8MHz and 32kHz, Real-Time Clock,
Nested Interrupt Controller, Power Saving Modes, JTAG and SWD,
3 Synch. 16-bit Timers with Input Capture, Output Compare and PWM,
16-bit 6-ch Advanced Timer, 2 16-bit Watchdog Timers, SysTick Timer,
2 SPI, 2 I2C, 3 USART, USB 2.0 Full Speed Interface, CAN 2.0B Active,
2 12-bit 16-ch A/D Converter, Fast I/O Ports
è¯ç宿¹ä»ç»èµæ
3.恒温箱的设计
智能电表控制设计
二、特性
1、STM32f103,在南京EK-STM32F买的,学习ARM,于因为它资源多,并且中文资料很多,学习起来也方便,上面集成了各种想要的外设。替代现有产品方便等,后来学习液晶显示购买火牛开发板。
2、stm32f103vet6
SRAM : 64kB
Flash : 512KB
FSMC : 1 Flexible Static Memory Controller for SRAM, PSRAM, NOR and NAND Flash,
PLL : 1 PLL,
RCC : Embedded Internal RC 8MHz and 32kHz,
RTC : 1 Real-Time Clock,
NVIC : 1 Nested Interrupt Controller, Power Saving Modes, JTAG and SWD,
TIM : 4 Synch. 16-bit Timers with Input Capture, Output Compare and PWM,
TIM : 2 16-bit Advanced Timer, 2 16-bit Basic Timer, 2 16-bit Watchdog Timers,
三、做过的设计
1、使用STM32F103做的使用芯片上的IIC总线。
2、使用STM32F103的AD、使用DMA采集交流电信号,节约部分工作量,电力仪表成品。
3、STM32的上面的各种外设例程。
STM32F103xC STM32F103xD STM32F103xEæ°æ®æå.pdf
2016-1-21 09:29 上传
点击文件名下载附件
下载积分: ST金币 -11.56 MB, 下载次数: 1, 下载积分: ST金币 -1
在180 MHz频率下,从Flash存储器执行时,STM32F429/439能够提供225 DMIPS/608 CoreMark性能,并且利用意法半导体的ART加速器实现了FLASH零等待状态。DSP指令和浮点运算单元扩大了产品的应用范围
使用在继电器保护中!
资料可在st官方下载,中英文结合!
资料需要上传了才能参加抽奖
2.
ALIENTEKALIENTEKALIENTEKALIENTEK ALIENTEKALIENTEK 战舰 STM32STM32 开发板 板载资源如下: 板载资源如下: 板载资源如下: 板载资源如下:
◆ CPUCPU :STM32F103ZET6 STM32F103ZET6STM32F103ZET6 STM32F103ZET6 STM32F103ZET6 STM32F103ZET6,LQFPLQFPLQFPLQFP14 4,FLASHFLASHFLASHFLASH :512 K,SRAM SRAMSRAM:64 K;
◆ 外扩 SRAMSRAMSRAMSRAM:IS62WV51216IS62WV51216 IS62WV51216 IS62WV51216,1M 字节
◆ 外扩 SPI FLASHSPI FLASHSPI FLASHSPI FLASH SPI FLASHSPI FLASHSPI FLASH :W25Q64W25Q64 W25Q64W25Q64W25Q64,8M 字节
◆ 1个电源指示灯(蓝色) 个电源指示灯(蓝色) 个电源指示灯(蓝色) 个电源指示灯(蓝色) 个电源指示灯(蓝色)
◆ 2个状态指示灯( 个状态指示灯( 个状态指示灯( 个状态指示灯( DS0DS0 :红色, :红色, DS1DS1 :绿色) :绿色)
◆ 1个红外接收头, 个红外接收头, 个红外接收头, 个红外接收头, 并配备一款小巧的红外遥控器 配备一款小巧的红外遥控器 配备一款小巧的红外遥控器 配备一款小巧的红外遥控器 配备一款小巧的红外遥控器 配备一款小巧的红外遥控器
◆ 1个 EEPROM EEPROM EEPROMEEPROM芯片, 芯片, 24C02 24C0224C02 ,容量 ,容量 256256 字节
◆ 1个重力加速度传感器芯片, 个重力加速度传感器芯片, 个重力加速度传感器芯片, 个重力加速度传感器芯片, 个重力加速度传感器芯片, 个重力加速度传感器芯片, ADXL345ADXL345ADXL345ADXL345ADXL345
◆ 1个高性能音频编解码芯片, 个高性能音频编解码芯片, 个高性能音频编解码芯片, 个高性能音频编解码芯片, 个高性能音频编解码芯片, 个高性能音频编解码芯片, VS1053VS1053 VS1053
◆ 1个 FM 立体声 收发芯片, 收发芯片, 收发芯片, RDA5820RDA5820RDA5820RDA5820RDA5820
◆ 1个 2.4G 2.4G2.4G无线模块接口( 无线模块接口( 无线模块接口( 无线模块接口( NRF24L01NRF24L01NRF24L01NRF24L01 NRF24L01 )
◆ 1路 CANCANCAN接口,采用 接口,采用 接口,采用 TJA1050TJA1050 TJA1050 芯片
◆ 1路 485 485接口,采用 接口,采用 接口,采用 SP3485SP3485SP3485SP3485 SP3485芯片
◆ 1路 RS232RS232 RS232接口,采用 接口,采用 接口,采用 SP 3232 芯片
◆ 1个 PS/2 PS/2接口,可外鼠标、键盘 接口,可外鼠标、键盘 接口,可外鼠标、键盘 接口,可外鼠标、键盘 接口,可外鼠标、键盘 接口,可外鼠标、键盘
◆ 1个游戏手柄接口,可以直插 个游戏手柄接口,可以直插 个游戏手柄接口,可以直插 个游戏手柄接口,可以直插 个游戏手柄接口,可以直插 个游戏手柄接口,可以直插 个游戏手柄接口,可以直插 FC(FC(FC(红白机)游戏手柄 红白机)游戏手柄 红白机)游戏手柄
◆ 1路数字温湿度传感器接口,支持 路数字温湿度传感器接口,支持 路数字温湿度传感器接口,支持 路数字温湿度传感器接口,支持 路数字温湿度传感器接口,支持 路数字温湿度传感器接口,支持 路数字温湿度传感器接口,支持 DS18B2DS18B2 DS18B2 DS18B20 /DHT11/DHT11/DHT11/DHT11 /DHT11等
◆ 1个标准的 个标准的 2.4/2.8 2.4/2.8 /3.5/3.5 /3.5寸 LCDLCDLCD接口,支持触摸屏 接口,支持触摸屏 接口,支持触摸屏 接口,支持触摸屏 接口,支持触摸屏
◆ 1个摄像头模块接口 个摄像头模块接口 个摄像头模块接口 个摄像头模块接口
◆ 2个 OLEDOLEDOLED 模块接口 模块接口 模块接口
◆ 1个 USBUSBUSB串口,可用于程序下载和代码调试 串口,可用于程序下载和代码调试 串口,可用于程序下载和代码调试 串口,可用于程序下载和代码调试 串口,可用于程序下载和代码调试 串口,可用于程序下载和代码调试 串口,可用于程序下载和代码调试 串口,可用于程序下载和代码调试 (USMARTUSMART USMARTUSMARTUSMART调试) 调试)
◆ 1个 USB USB USB USB SLAVE SLAVESLAVESLAVE接口,用于 接口,用于 接口,用于 US B通信
◆ 1个有源蜂鸣器 个有源蜂鸣器 个有源蜂鸣器
◆ 1个 FM 收发天线 接口,并配收发天线 接口,并配收发天线 接口,并配收发天线 接口,并配收发天线
接口,并配◆ 1个 RS232/RS485RS232/RS485 RS232/RS485 RS232/RS485RS232/RS485RS232/RS485 选择接口 选择接口 选择接口
◆ 1个 CAN/USBCAN/USBCAN/USBCAN/USBCAN/USBCAN/USBCAN/USB选择接口 选择接口 选择接口
◆ 1个串口 选择接个串口 选择接个串口 选择接个串口
选择接◆ 1个 SD 卡接口( 卡接口( 在板子背面, 在板子背面, 在板子背面, 支持 SPI/SDIOSPI/SDIOSPI/SDIOSPI/SDIOSPI/SDIO SPI/SDIOSPI/SDIO)
◆ 1个 SD 卡/网络模块选择 网络模块选择 网络模块选择 接口
◆ 1个标准的 个标准的 JTAG/SWD JTAG/SWDJTAG/SWDJTAG/SWDJTAG/SWD JTAG/SWD调试下载口 调试下载口 调试下载口
◆ 1个 VS1053VS1053 VS1053 的 IIS 输出接口 输出接口
◆ 1个 MIC/LINE IN MIC/LINE INMIC/LINE INMIC/LINE INMIC/LINE INMIC/LINE INMIC/LINE IN MIC/LINE IN选择接口 选择接口 选择接口
◆ 1个录音头( 个录音头( 个录音头( MIC/ MIC/MIC/咪头) 咪头)
◆ 1路立体声音频输出接口 路立体声音频输出接口 路立体声音频输出接口 路立体声音频输出接口 路立体声音频输出接口
◆ 1路立体声录音 立体声录音 立体声录音 输入接口 输入接口
◆ 1组多功能端口( 组多功能端口( 组多功能端口( 组多功能端口( DAC/ADC/PWM AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPAD DAC/ADC/PWM AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPAD DAC/ADC/PWM AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPAD DAC/ADC/PWM AUDIO IN/TPADDAC/ADC/PWM DAC/AUDIO IN/TPAD)
◆ 1组 5V 电源供应 电源供应 /接入口 接入口
◆ 1组 3.3V 3.3V3.3V电源供应 电源供应 电源供应 /接入口 接入口
◆ 1个参考电压设置接口 个参考电压设置接口 个参考电压设置接口 个参考电压设置接口 个参考电压设置接口
7
◆ 1个直流电源输入接口(压范围: 个直流电源输入接口(压范围: 个直流电源输入接口(压范围: 个直流电源输入接口(压范围: 个直流电源输入接口(压范围: 个直流电源输入接口(压范围: 个直流电源输入接口(压范围: 个直流电源输入接口(压范围: 6~16V)
◆ 1个启动模式选择配置接口 个启动模式选择配置接口 个启动模式选择配置接口 个启动模式选择配置接口 个启动模式选择配置接口 个启动模式选择配置接口
◆ 1个 RTCRTCRTC后备电池 座,并带后备电池 座,并带后备电池 座,并带后备电池 座,并带后备电池
座,并带◆ 1个复位 按钮,可用于个复位 按钮,可用于个复位 按钮,可用于个复位 按钮,可用于个复位 按钮,可用于个复位 按钮,可用于MCU MCU和 LCDLCDLCD
◆ 4个功能按钮,其中 个功能按钮,其中 个功能按钮,其中 个功能按钮,其中 WK_UP WK_UP WK_UP兼具唤醒功能 兼具唤醒功能 兼具唤醒功能
◆ 1个电容触摸按键 个电容触摸按键 个电容触摸按键 个电容触摸按键
◆ 1个电源 开关,控制整板的个电源 开关,控制整板的个电源 开关,控制整板的个电源 开关,控制整板的个电源 开关,控制整板的个电源 开关,控制整板的个电源
开关,控制整板的◆ 独创的一键下载功能 独创的一键下载功能 独创的一键下载功能 独创的一键下载功能
◆ 除晶振占用的 除晶振占用的 除晶振占用的 IO 口外,其余所有 口外,其余所有 口外,其余所有 口外,其余所有 口外,其余所有 IO 口全部引出 口全部引出 口全部引出
2、 说明该STM32产品型号:NUCLEO-F030R8
列举其一项或者多项特性:支持mbed\Arduino
同时附件上传一篇该型号产品的资料:
3、 基于STM32你做过哪些设计?
运动控制器的开发、传感器模块的控制IC
Key Features
2.4" QVGA TFT LCD
SDRAM 64 Mbits
Six LEDs
Features
• Memories
accuracy)
• Low power
• Debug mode
3、准备用来学习μCOS系统,然后做一些数据采集或者工业控制方面的应用
2 STM32F103 VBT6 特性 72MHz ,90DMIPS with 1.25 DMIPS/Mhz
Nested interrupt controller with 43 maskable interrupt channels
Interrupt processing with tail chaining;
ç¨æ¥æ§å¶ä¸çæµçµå¨æº
STM32F3 F4ç¼ç¨æå.pdf
2016-1-21 11:22 上传
点击文件名下载附件
下载积分: ST金币 -12.54 MB, 下载次数: 1, 下载积分: ST金币 -1
