本帖最后由 Dylan疾风闪电 于 2018-8-9 15:39 编辑 ( W+ |' B1 {9 f! f, }; P6 r
1 B: v/ }8 {; ^9 H
使用举例:配置72MHZ时钟作为系统时钟#define SystemClockMHz 72//MHZ0 u; ~, }- f: j' n* \
: j/ X0 Q- G! U! }. n aHW_SystemClockMux(USE_EXTERNAL_HSE, SystemClockMHz) ;# {: o, ]. z1 `' u
HW_SystemClockMux(USE_INTERNAL_HSI, SystemClockMHz);
" t7 E/ N) ^2 S9 o( O- O; L3 o; M6 M9 G
; a3 G1 p4 |; I3 c( }2 D2 U/ d
3 J4 l" M5 K5 p1 M9 d
B. V" ~4 Z' v, A) f代码已验证。发个帖子,便于自己移植使用。9 R) h3 {3 \+ j3 O+ N! C
; ?) s- J/ F9 F
n2 k+ n3 y5 m% W/ o- /* Const to source of high speed clock:internal or external. */7 f2 P5 n# k( m9 O' D3 j
- #define USE_EXTERNAL_HSE 0
+ W* y, E0 c7 l0 Y1 t: N" Z8 } - #define USE_INTERNAL_HSI 1
1 \: K* g3 h+ g/ h3 l - /**
6 s m e) z6 X+ U - * <b>配製系統主時鐘頻率。</b>
0 R) q$ \* V$ e* D$ c - * <p>功能:選擇時鐘源,并進行PLL倍頻。0 O. G0 Q8 ~& n- }+ P' f
- * @param osc 高速時鐘源的選擇。! q1 n6 S' A, I- y, p7 D! ?' z* H
- * @arg USE_EXTERNAL_HSE: 外部高速晶振) _7 M/ g2 P6 B4 c
- * @arg USE_INTERNAL_HSI: 內部高速晶振
i8 n. }. d5 L x2 s4 {/ k6 u - * @param maxFreq 芯片最大主频?M,查询对应的数据手册
! u$ I$ _1 u$ U, ^& v - * @return osc7 y% a3 ]& J( x# v% m) S- @
- * @version 2.0.0.0(20160407)
" c+ R/ ^: U, \) @ - * <p-2014>实现CM0与CM3兼容完成!5 G9 [( |& n$ G" g
- * <p-2016>對字符串/單詞進行變更。7 `: v" o5 G, p
- * @author Dylan% H) T, w% P6 e/ R. X+ f
' s) M5 p' T+ E% `; {1 e - uint8_t HW_SystemClockMux(uint8_t osc, uint8_t maxFreq)9 ]0 n6 [" I# W, Y, `+ x
, h# { h. s( l$ x7 |8 ]: ] - #if defined (STM32F100) || defined (STM32F101) || defined (STM32F103) p& S0 k6 M6 D& L' k5 i' s
- uint8_t errCode = 0xff;4 [% L' `4 D2 c6 i) Y3 f
- uint32_t sTimeCount, sTimeMax = 0xFFF;
* f; F, _) Y# P6 Y - #endif1 F5 [2 T9 N. d' f8 ?/ W i
6 `5 R! O$ f+ A - HW_SystemPowerON();5 V) h/ B2 v; Y: ^9 |5 v. M- x$ U
- . y1 q3 g- q8 r U, D( {9 g$ M; z( |
- switch(osc)" r7 T1 e* a+ z0 {5 O
0 x: ?$ J I/ ? - case USE_EXTERNAL_HSE:) f: ~ Z0 e5 g6 \+ p) z7 X) h! {/ x
- #if defined (STM32F100) || defined (STM32F101) || defined (STM32F103)4 F/ z/ s8 N$ O$ S, g
- RCC->CR |= 1<<16; //HSEON
, I2 A4 R* H% g; u, P$ ^ -
7 L7 s% g$ x+ r, {, c" p/ a - sTimeCount = sTimeMax;; Q" H- C0 C' F2 H+ D
- while(((RCC->CR>>17) & 0x1) == 0) //等待HSE就绪
4 K* B" m: ?& X, K2 ^4 a - {! e3 t* t6 ^& a# \2 Y. o
- if (sTimeCount--) return errCode;
* ]$ m# G3 s2 X& z' l# \& L) v N - }( F+ M z( |8 C* F. F/ ^* F
, x3 @9 ^1 X5 x/ U9 _ - RCC->CFGR |= (maxFreq/8-2)<<18; //设置PLL值倍频//HSE 8MHz5 J6 T1 R. Y- E. b
- 6 @& e( `2 {7 y
- RCC->CFGR |= 1<<16; //切换PLL输入时钟源为0->1:HSI/2(4MHz)->HSE(8MHz)' O! n g: S! w! O+ C+ a+ M
. t9 P, t) P( x7 L6 w+ U* v - //存在等待状态时,必须先开启预取缓冲区4 o: ?" p8 r7 J# L
- if (maxFreq <= 24)
1 b2 h; T: t1 F o2 {( g" @) ]2 D - FLASH->ACR |= 0x30;//000:零等待状态,当 0 < SYSCLK ≤ 24MHz
+ h+ m% O/ ~( G5 J) O L - else if (maxFreq <= 48)/ g; N( W9 P F) B3 T$ ^0 q/ R
- FLASH->ACR |= 0x31;//001:一个等待状态,当 24MHz < SYSCLK ≤ 48MHz. c+ G0 U& o2 \0 @
- else5 @0 r* G5 `7 x# U* f
- FLASH->ACR |= 0x32;//010:两个等待状态,当 48MHz < SYSCLK ≤ 72MHz; l( V2 o) g* g/ E1 ~1 \4 X
5 H2 R* r! D* J3 c, k - RCC->CR |= 1<<24; //PLLON
. l8 x5 `" Y& _9 ~7 R8 v -
j' }. U1 A% N: {, @1 ] - sTimeCount = sTimeMax;
c Q- {8 |7 l* N, Y' A - while(((RCC->CR>>25) & 0x1) == 0) //等待PLL就绪/ G( R; R) Z0 v
0 e# f$ o$ a& _6 ^5 T - if (sTimeCount--) return errCode;
. @) |$ s7 I( X) x: F- F' ~ - }
( L' ?9 T- l! y - 8 i5 J& y* @0 B& P* d- i- R# Y
- RCC->CFGR |= 0x2; //PLL作为sysClk5 b& C& T) E( w! y% X D
- 2 ^; {* g* o' m; |& U2 C+ R
% s7 E7 f/ X9 g6 r& E$ z7 G - while(((RCC->CFGR>>2) & 0x3) != 0x02) //等待sysClk就绪# S% L# {9 G' F* s- b4 \
- {( r4 d- h* J% T, \
% g* Q* @. E0 B3 S7 B' ` - }8 s) A5 L2 I1 ~6 e/ t9 U
- #elif defined (STM32F051) || defined (STM32F042) //none. l; F0 i* K" ?( j$ o, a6 o6 T
- #else5 f) q' H5 j9 U
- #warning "Make sure needn't define STM32Fxxx etc. ?"
" c! X+ Y& t+ p7 M - #endif
) d0 z" g" B/ x' d - break;
( c2 Z" t- M& v A( E - default: //case USE_INTERNAL_HSI:% |, Z7 P2 i# e+ D
- RCC->CFGR &= 0xFFFEFFFF; //HSI 8MHz/2
' g( V! u% a2 L7 {0 k6 o2 R - RCC->CFGR |= ((maxFreq>>2)-2)<<18; //设置PLL值倍频
( P- f; }, n9 k3 l - ! A% m- w# Y# E2 Z& @- j5 P
- //存在等待状态时,必须先开启预取缓冲区! B9 A" U* ^ K( f- e5 k8 {8 \9 N
- if (maxFreq <= 24) Y- o9 ~- M) O4 v; R* Y9 E; U
- FLASH->ACR |= 0x30;//000:零等待状态,当 0 < SYSCLK ≤ 24MHz/ c4 r, p6 D: |/ [# \+ x! \4 G. P
: } A, F, }- q; \7 X O# ~ - FLASH->ACR |= 0x31;//001:一个等待状态,当 24MHz < SYSCLK ≤ 48MHz6 P+ `5 m4 b" M( d% h. m6 G
- else2 n" ~' W6 I/ n C K% f- ]8 U: Z- m1 s
- FLASH->ACR |= 0x32;//010:两个等待状态,当 48MHz < SYSCLK ≤ 72MHz! F% R* P. g2 @7 t& _
- ! ]! E0 s4 P* D+ ^* ^4 B' s
# j0 k9 T. j; L' H% p' O: l8 {$ p - while(((RCC->CR>>25) & 0x1) != 1); //等待PLL就绪5 o# Z) t1 F0 |0 g7 i. E
- RCC->CFGR |= 0x2; //PLL作为sysClk4 _2 b3 B3 z" Q# n! Q& \
- while(((RCC->CFGR>>2)&0x3) != 0x02); //等待sysClk就绪$ z5 K# j$ y; Z" p$ ]
- break;
6 l0 B7 \0 C! D8 V0 |- I - }
! m1 L N( C" A -
6 o, u6 D; d$ C8 L. s0 R - return 0;, W* s7 V: }7 S# p' F1 K8 m5 c
6 \. }$ m2 ^+ K9 h$ a; x0 y
. x( W/ U# `5 p8 }; V/ p$ ~- |8 ` U8 ?- /**
6 f, g2 r% i( V5 C1 V5 a - * <b>芯片上电默认时钟配置。</b>* ]/ c( n+ ~* _6 X* u T
- * <p>功能:用来恢复时钟系统到上电默认状态。
. \ b( R7 d5 }9 B - * @version 1.1.0.0(20140228)$ {1 L; |4 I. X+ T% K8 ]
7 t, J4 J& _& M( c W% f - * @author Dylan! _" `; A9 P4 h' n) c1 U" Z m
- */) K# t: ^. z) i5 s
- void HW_SystemPowerON(void)) K4 j# k9 a: S, F9 w1 O$ \& l
- {* _ F0 `! a; o) [$ w5 m4 e* [5 J
- #if defined (STM32F051) || defined (STM32F042)
$ U5 M" ]1 y5 N" I9 c - RCC->CR |= 0x00000001;//HSION
2 }, E6 b6 u0 l1 I$ l: j P
C4 l. w' C9 H: n4 G% o- RCC->CR &= 0x0202FFFF;/* Reset HSEON, CSSON and PLLON, HSEBYP bit */
& p$ a! F7 I. K9 t. s" X' E
8 M: M* J9 i) M1 g9 I! q1 n; p- RCC->CFGR &= 0x0000000C;/* Reset SW[1:0], HPRE[3:0], PPRE[2:0], ADCPRE and MCOSEL[2:0],PLLSRC, PLLXTPRE and PLLMUL[3:0] bits */$ x; j8 y: H! O! @4 Q
5 m" p+ V9 g9 Q$ F6 ~- RCC->CFGR2 &= 0x00000000;/* Reset PREDIV1[3:0] bits *///与CFGR[17]一起用作HSE-PLL设置! n9 ]& T. J4 E7 t Q
- 3 W1 u; D& E8 x3 C, Q1 L; A6 A |
- RCC->CFGR3 &= 0x00000000;/* Reset USARTSW[1:0], I2CSW, CECSW and ADCSW bits */
- W# L* P- {1 R9 I - $ i) K3 k( B: U. N) }
- RCC->CR2 &= 0xFFFFFFFE;/* Reset HSI14 bit */4 H. |/ x6 x! ^( p0 s( C; B
- , S) d- }1 M) o5 V
- RCC->CIR = 0x00000000;/* Disable all interrupts */9 F9 m6 Z( A2 O6 R% m n# @0 q
+ B; Y/ N: S! O' ^* J" R- #elif defined (STM32F100) || defined (STM32F101) || defined (STM32F103)* {! H. G5 K3 r7 N# I! G
- RCC->CR &= 0x0000FF83;//把HSI调整到8MHz±1%==》开启HSI==》等待就绪' m7 m. w) V! t& b. k$ P
- / X/ _+ @, z% c1 c
- RCC->CFGR = 0x00000400;//限制APB1时钟是HCLK_Div2
1 X% h Z; x9 J2 o8 I! D( ]/ H$ h
7 T' E2 I* l9 i- RCC->CIR = 0x00BF0000;//清除所有的RCC中断标志
9 I& F8 L4 G0 k. }
9 w e2 }9 [8 e3 x. `2 A3 W- //配置向量表5 U2 h0 s, n9 k u9 Q
- #ifdef VECT_TAB_RAM
/ n( H' O T. Y$ Q0 P* f - /* Set the Vector Table base location at 0x20000000 */
0 r2 E/ U) A2 a& ] - NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);& R# w$ Y ]8 B6 ]" ^4 d! j1 ^
- #else /* VECT_TAB_FLASH */
2 ]# X9 o3 @: Z/ ` - /* Set the Vector Table base location at 0x08000000 */( O4 o& k) g4 Q P
- NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- q! C9 Z+ X' G2 i- z6 U' [ - #endif
$ Y! d. Q- b. ~9 Y6 P+ [6 T9 E+ R - #else
5 Y- ]# |" f# u% {7 V9 L; k - #warning "Make sure needn't define STM32F051 etc. ?"
+ T; r' u& I$ O5 p H/ g - #endif0 w' a/ ~" J; \! G+ k8 D
复制代码 0 Q% B) s# F" R7 O
% X" y* D0 T% T7 H |
