我需要将F103的代码移植到F334上面,发现不能生成PWM,大佬们帮我看一下我哪里没有配置正确 谢谢 void TIM1_PWM_Init(u16 arr,u16 psc) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; //TIM_InternalClockConfig(TIM1); RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);// RCC_AHBPeriphResetCmd(RCC_AHBPeriph_GPIOA , ENABLE); //使能GPIO外设时钟使能 //设置该引脚为复用输出功能,输出TIM1 CH1的PWM脉冲波形 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TIM_CH1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_11);//PA10复用 TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值 80K TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值 不分频 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式 TIM_TimeBaseStructure.TIM_RepetitionCounter=0xf0; TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能 TIM_OCInitStructure.TIM_Pulse = 0; //设置待装入捕获比较寄存器的脉冲值 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高 TIM_OC1Init(TIM1, &TIM_OCInitStructure); //根据TIM_OCInitStruct中指定的参数初始化外设TIMx TIM_CtrlPWMOutputs(TIM1,ENABLE); //MOE 主输出使能 TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //CH1预装载使能 TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的预装载寄存器 TIM_Cmd(TIM1, ENABLE); //使能TIM1 } int main(void) { u16 led0pwmval=50; u8 dir=1; TIM1_PWM_Init(899,100);//不分频。PWM频率=72000/(899+1)=80Khz TIM_SetCompare1(TIM1,led0pwmval); while(1) { Delay_ms(10); //delay_ms(10); if(dir)led0pwmval++; else led0pwmval--; if(led0pwmval>50)dir=0; if(led0pwmval==0)dir=1; TIM_SetCompare1(TIM1,led0pwmval); } } |
STM32F3 硬件I2C 驱动OLED 求助!!
STM32F303使用定时器触发双ADC常规同步采样模式
哪位大哥传下STM32F334 Nucleo的工程模板给我下
STM32F334 不能串口下载
关于STM32F334的HRTIM分辨率问题
STM32F303+LCD1602程序问题,不只为什么点不亮?
STM32F334的ADC使用问题
STM32F334 HRTIM形成移相全桥波形问题
STM32F103C8T6替换STM32F301C8T6
关于STM32F3 ADC在差分模式下的采样率计算问题
我用的PA8输出,TIM1_CH1通道,不知道这个要不要引脚复用(感觉不需要)复用和不复用都试过了 都不行
HRTIM_OutputCfgTypeDef HRTIM_TIM_OutputStructure;//配置输出特性,高低电平等
HRTIM_BaseInitTypeDef HRTIM_BaseInitStructure;//配置基本参数,这部分和普通定时器一样
HRTIM_TimerInitTypeDef HRTIM_TimerInitStructure; //配置不同模式
HRTIM_TimerCfgTypeDef HRTIM_TimerWaveStructure;//配置波形参数,错误等
HRTIM_CompareCfgTypeDef HRTIM_CompareStructure;//配置比较寄存器
用以上几个部分就能产生最简单的PWM波形
声明有人测试了还是有问题,不过每个人情况不同,最好还是在官网查正确步骤
TIM1_PWM_Init(100,899);//PWM频率=72000/(899+1)=80Khz
