lsm6dsl功耗问题
wfagly_dtt 提问时间:2021-12-13 13:47 / 已解决
lsm6dsl在应用手册显示,高性能模式的功耗是0.6mA,但我在实际使用过程中,功耗达到2mA。
在3.3V电压下,一以下是我的配置
 * @brief  Initialize the LSM6DSL sensor
 * @param  pObj the device pObj
 * @retval 0 in case of success, an error code otherwise
int32_t LSM6DSL_Init(void)
  /* Enable register address automatically incremented during a multiple byte
  access with a serial interface. Enable IF_INC */
  if (lsm6dsl_auto_increment_set(PROPERTY_ENABLE) != LSM6DSL_OK)
    return LSM6DSL_ERROR;
  /* Enable BDU */
  if (lsm6dsl_block_data_update_set(PROPERTY_ENABLE) != LSM6DSL_OK)
  /* FIFO mode selection. LSM6DSL_STREAM_MODE*/
  if (lsm6dsl_fifo_mode_set(LSM6DSL_BYPASS_MODE) != LSM6DSL_OK)
  /* Full scale selection. */
  if (lsm6dsl_xl_full_scale_set(LSM6DSL_2g) != LSM6DSL_OK)
  /* Full scale selection. LSM6DSL_2000dps*/
  if (lsm6dsl_gy_full_scale_set(LSM6DSL_2000dps) != LSM6DSL_OK)
  /* Output data rate selection - LSM6DSL_GY_ODR_104Hz */
  if (lsm6dsl_gy_data_rate_set(LSM6DSL_GY_ODR_104Hz) != LSM6DSL_OK)
  /* Output data rate selection - LSM6DSL_XL_ODR_104Hz */
  if (lsm6dsl_xl_data_rate_set(LSM6DSL_XL_ODR_104Hz) != LSM6DSL_OK)
  return LSM6DSL_OK;
发现一但配置频率,对加速度计没有影响,但是磁力计配置之后,功耗直线上升,这是什么原因呢?
收藏 评论2 发布时间:2021-12-13 13:47
wfagly_dtt 回答时间:2021-12-13 15:59:48
在关闭该传感器或者注释掉频率配置也会少2mA功耗。
  /* Output data rate selection - power down. */
//  if (lsm6dsl_gy_data_rate_set(LSM6DSL_GY_ODR_52Hz) != LSM6DSL_OK)
//    return LSM6DSL_ERROR;
//  /* Output data rate selection - power down. LSM6DSL_XL_ODR_104Hz */
//  if (lsm6dsl_xl_data_rate_set(LSM6DSL_XL_ODR_52Hz) != LSM6DSL_OK)
st_yujie2510 回答时间:2021-12-15 17:15:45
您硬件连接了中断管脚吗?开了中断功能吗?如果有的话,建议关闭中断功能或是断开中断连接看看
