01. TIM概述2 j: ?6 x1 ]/ f* X( j
stm32f4xx_tim.h和stm32f4xx_tim.c文件中9 ]0 U; K8 Y/ g9 V+ v
* d7 Y8 j% q) W; L( V02. 相关类型
, V% c9 Z- ~" p) m5 d9 W Q* `3 iTIM_TimeBaseInitTypeDef
9 H+ w9 Y2 T; W7 ^' w1 D
' S& D! Q4 M/ E m4 v; O- r- /** ' F$ u- t g6 X# {0 t" i& s8 }0 P. x
- * @brief TIM Time Base Init structure definition
5 P- m8 O3 Z" `# E: ? - * @note This structure is used with all TIMx except for TIM6 and TIM7. 9 V9 G. c0 i) a) R! {! u4 ?
- */0 q" v7 q6 d& F) R
- ; b" W, T8 f. u# p9 P) @( @; t
- typedef struct! ^2 J6 }3 _4 i9 b- b# K
- {" X! o9 @$ n k2 C5 D: h& V; H4 ]# p
- uint16_t TIM_Prescaler; /*!< Specifies the prescaler value used to divide the TIM clock.. q S( x0 O |* p
- This parameter can be a number between 0x0000 and 0xFFFF */
+ Q7 V2 n, S* v" Y - % P& y6 V& O8 Z
- uint16_t TIM_CounterMode; /*!< Specifies the counter mode.; c, ~2 B, Q% Q5 ~- n; s
- This parameter can be a value of @ref TIM_Counter_Mode */
b# u7 Y. `; l( f1 t5 m4 G - ; `; H. J& t' r& Y: V
- uint32_t TIM_Period; /*!< Specifies the period value to be loaded into the active
' e! @ F4 a; K/ C+ Z4 G5 M s - Auto-Reload Register at the next update event.
- y! j* ]$ }1 v( U* O4 p - This parameter must be a number between 0x0000 and 0xFFFF. */
: l3 t- E7 {0 ^' u
) b0 {. V6 s$ c J- j- uint16_t TIM_ClockDivision; /*!< Specifies the clock division.
& i! W a. H J. i: x6 b - This parameter can be a value of @ref TIM_Clock_Division_CKD */+ j# K9 g* R7 P$ P: s- K
; k. z/ x1 v D5 h' J8 s7 \- uint8_t TIM_RepetitionCounter; /*!< Specifies the repetition counter value. Each time the RCR downcounter
4 V( L6 Y. k* `1 W9 ?* c! f - reaches zero, an update event is generated and counting restarts& g# i- k& D1 j
- from the RCR value (N).
( f7 z; h# e/ ~ - This means in PWM mode that (N+1) corresponds to:0 ?% B# f! z V6 Y* o
- - the number of PWM periods in edge-aligned mode; `% x3 E; G+ W! H
- - the number of half PWM period in center-aligned mode+ ^8 v) }/ e* ~, h4 Y0 t" o
- This parameter must be a number between 0x00 and 0xFF.
( v" g. s& f" c% Z9 C2 Y( s- q - @note This parameter is valid only for TIM1 and TIM8. */
8 p) f9 C% a0 Q7 g- Q - } TIM_TimeBaseInitTypeDef;
5 o" r b6 [( G5 V; b
$ P3 X; Y( {2 `+ @' B' CTIM_OCInitTypeDef
V% j8 t2 m3 t- x5 |
3 M8 [' |" {" Q: f- /** " y+ ]/ x6 G' |9 V
- * @brief TIM Output Compare Init structure definition
" ]7 r5 T7 f7 _! s- |2 w% u; |/ C - */5 W Q2 H$ u! l- f0 C1 P( c2 y
- 0 m1 K$ H( s, k
- typedef struct
; _; p% b4 Y( Q# C- V - {
. o- Q$ [ B) Z - uint16_t TIM_OCMode; /*!< Specifies the TIM mode.
' D+ L7 a" z. f2 `0 u1 S ~ - This parameter can be a value of @ref TIM_Output_Compare_and_PWM_modes */6 {6 y1 W5 b' \5 Q1 X, H+ D4 e6 k
6 s, I- E. s2 T: S- uint16_t TIM_OutputState; /*!< Specifies the TIM Output Compare state./ n2 V7 B& e/ G( H I4 A: [ v" J
- This parameter can be a value of @ref TIM_Output_Compare_State */
. _$ i0 \5 g# T( m* N9 p2 v! `) h" q) r
5 O' p# \7 h) I" m/ H- uint16_t TIM_OutputNState; /*!< Specifies the TIM complementary Output Compare state.
' n& |5 h) z7 x8 E - This parameter can be a value of @ref TIM_Output_Compare_N_State& ?1 e# f; b+ ~
! N& r1 m/ H' C# r K - ! q8 e$ S& _6 X* U. P+ t [" p
- uint32_t TIM_Pulse; /*!< Specifies the pulse value to be loaded into the Capture Compare Register.
0 U: Q9 Y) q: a8 e+ e( h4 y0 G - This parameter can be a number between 0x0000 and 0xFFFF */: q" I v7 Z( n; Y2 i1 Y7 L
$ }# Y' O1 s- P9 O$ Y/ |! ?- uint16_t TIM_OCPolarity; /*!< Specifies the output polarity.$ u7 l$ M* t6 D2 s: s; d
- This parameter can be a value of @ref TIM_Output_Compare_Polarity */
0 X6 h+ F* T6 B4 K! ?- q
) p7 V% ~8 ?# ~: J1 T( J- uint16_t TIM_OCNPolarity; /*!< Specifies the complementary output polarity.: R+ C8 b6 {* l) Q
- This parameter can be a value of @ref TIM_Output_Compare_N_Polarity
; v7 H7 n# {6 N, g7 x - @note This parameter is valid only for TIM1 and TIM8. */
, o" J* r S3 G; {$ {3 K - + {$ g/ G: C X+ Y/ Z: g
- uint16_t TIM_OCIdleState; /*!< Specifies the TIM Output Compare pin state during Idle state.
t" \) h( D% ]/ _* ?# k - This parameter can be a value of @ref TIM_Output_Compare_Idle_State
4 b- c( G/ Y" B5 X2 R7 r$ G$ H - @note This parameter is valid only for TIM1 and TIM8. */, L: y/ f* J9 J' }3 j
b( w: B. R! H+ \% V/ \ E% }- uint16_t TIM_OCNIdleState; /*!< Specifies the TIM Output Compare pin state during Idle state.' L( w9 | x, J, ]7 S
- This parameter can be a value of @ref TIM_Output_Compare_N_Idle_State
* F# ?5 }; e; Q - @note This parameter is valid only for TIM1 and TIM8. */; \1 J) i. n5 F+ x. }' v
- } TIM_OCInitTypeDef;
2 Y: s) x) y& ?
! n8 ^8 ]! n/ I+ ETIM_ICInitTypeDef/ ^9 v% y6 `! g( w# s5 ?1 @
; J {2 Y |* m0 A$ j. P0 G. N- /** 8 T% ^" I- \& m# o; i9 G* [
- * @brief TIM Input Capture Init structure definition
( b3 d+ H3 V3 [* s) T% e+ D: k a - */
. Q. ]/ o) D6 x' D1 p4 ~, p- \
0 G- m1 z2 l; U' o% `" c- typedef struct
+ K2 F1 ]! K4 A; z& i! _ - {# h. k9 I v' e( b3 \- y
% ^. d# I S: K+ }- uint16_t TIM_Channel; /*!< Specifies the TIM channel.9 @" |2 u. H) v! l4 p/ V( k
- This parameter can be a value of @ref TIM_Channel */
* A$ \6 S8 X: _ - 6 O) K# n' X( i
- uint16_t TIM_ICPolarity; /*!< Specifies the active edge of the input signal.7 {7 I" @& m$ Y" G6 J
- This parameter can be a value of @ref TIM_Input_Capture_Polarity */
* }8 y. i( Y. g5 d0 G3 L1 o
2 }2 e( k8 f9 p1 p. a i- uint16_t TIM_ICSelection; /*!< Specifies the input. r0 B5 b+ @9 A+ d; Y X# h a$ w
- This parameter can be a value of @ref TIM_Input_Capture_Selection */
9 z% q: l& A" ~ v4 Q: d4 H, `/ L; A - - Y$ t+ b3 |2 d1 ^0 o
- uint16_t TIM_ICPrescaler; /*!< Specifies the Input Capture Prescaler.
) }& q, U& _1 K4 c* Q3 a# s - This parameter can be a value of @ref TIM_Input_Capture_Prescaler */
0 ]' t W+ _2 v, A( q! K - 5 V& x$ A9 n+ Z6 z; h/ |2 F' K
- uint16_t TIM_ICFilter; /*!< Specifies the input capture filter.5 u* A% i1 y' K% g) X5 c
- This parameter can be a number between 0x0 and 0xF */
% A8 ]! h/ m, E6 Q) N5 j, M - } TIM_ICInitTypeDef;
/ s; u7 l: }( k8 z; k3 ]2 g
复制代码 9 s! B, h% D8 D4 s, ?0 L+ [2 W
TIM_BDTRInitTypeDef' g3 \- r( _# |5 o3 z% ^8 z5 U
, ], Q: _7 B9 p
$ X# i% }& F' t4 h) _# R - * @brief BDTR structure definition ' h8 ]$ F* m" H# G
- * @note This structure is used only with TIM1 and TIM8.
0 Q. r& ?/ v) i ?8 }0 s4 @ - */
8 N0 a2 C1 U1 O - : f. g0 l3 T, H4 t5 p/ q
- typedef struct
M7 ~" D5 B( S4 e) B2 c0 a1 M- I - {
" H/ S0 s/ ~ z6 N# Y - % d0 F9 m/ A+ r
- uint16_t TIM_OSSRState; /*!< Specifies the Off-State selection used in Run mode.& h: j; } F$ O( i5 m/ t
- This parameter can be a value of @ref TIM_OSSR_Off_State_Selection_for_Run_mode_state */
, b1 c2 s, s8 @( ~. U4 G3 ]; k
( }4 r& [; }4 z' w% C7 [- uint16_t TIM_OSSIState; /*!< Specifies the Off-State used in Idle state.
) q: b v# I& t$ K. r' K - This parameter can be a value of @ref TIM_OSSI_Off_State_Selection_for_Idle_mode_state */
+ } q5 F7 ? r% e - + @( o8 e; r! z2 I8 v
- uint16_t TIM_LOCKLevel; /*!< Specifies the LOCK level parameters.% X* |0 d: @( i" e7 Y+ V; r
- This parameter can be a value of @ref TIM_Lock_level */
( g& t- W4 u4 ~! Y# T$ R - & y5 w% ~8 Y" {! c. |- ]
- uint16_t TIM_DeadTime; /*!< Specifies the delay time between the switching-off and the
0 U$ b. |4 \6 x - switching-on of the outputs.& w6 i/ h `% ?: u" M
- This parameter can be a number between 0x00 and 0xFF */0 H4 o/ I/ {+ C; U6 x
5 v4 Z$ ^% k6 w# \- uint16_t TIM_Break; /*!< Specifies whether the TIM Break input is enabled or not.
- y8 v/ s0 T: D) b - This parameter can be a value of @ref TIM_Break_Input_enable_disable */
0 \. l: R0 X% _1 B
' ~0 B% K- Y" n& u8 y. ~- uint16_t TIM_BreakPolarity; /*!< Specifies the TIM Break Input pin polarity.
1 D3 w- k% d6 B: U7 U/ L4 j - This parameter can be a value of @ref TIM_Break_Polarity */
+ d- v9 Z: c; |' I8 h& p
& r5 E* ]2 I5 y0 ~- b- uint16_t TIM_AutomaticOutput; /*!< Specifies whether the TIM Automatic Output feature is enabled or not. 0 n, V" Q* ~+ ]* ^: G4 ?! [) e2 }6 F
- This parameter can be a value of @ref TIM_AOE_Bit_Set_Reset */
* d. M ]0 W" d/ i1 b3 F - } TIM_BDTRInitTypeDef;
8 |% y. b0 p8 r2 X
复制代码 3 R% J, I, l% a/ m' W3 [
TIM% N0 G0 t, r6 M
- J" D5 L1 K. K& o8 c% M a- o
1 U2 u) H( R* j7 n8 U& Q- /** @defgroup TIM_Exported_constants
- ^6 B4 L. [* R$ X5 b( l - * @{
0 E$ i- O" P) H8 O/ _ - */
+ N2 U1 m. e2 u4 g; A - 2 }8 A3 L/ q, W
- #define IS_TIM_ALL_PERIPH(PERIPH) (((PERIPH) == TIM1) || \3 Q# Z) u/ N" C: M0 }& i& ]% Z& L v
- ((PERIPH) == TIM2) || \
# y% l" [ ^; N5 L9 L" B4 S - ((PERIPH) == TIM3) || \
" ]! M9 E- c3 F( z8 L! p) C1 J - ((PERIPH) == TIM4) || \
5 N$ x8 m/ r1 @, n. K2 A7 m - ((PERIPH) == TIM5) || \
Q* h, j# D! A - ((PERIPH) == TIM6) || \( A# i* R9 S$ y2 Q6 h: k5 q
- ((PERIPH) == TIM7) || \( t, b4 D! {# S8 h9 G- @# t7 w
- ((PERIPH) == TIM8) || \
& i6 I7 N1 C9 z- ~* w' V8 ?6 m* b - ((PERIPH) == TIM9) || \3 \+ E0 A* o t* ~9 G- W
- ((PERIPH) == TIM10) || \
1 ?0 J' a! m J9 O - ((PERIPH) == TIM11) || \
E- I4 C- `4 B% o8 a - ((PERIPH) == TIM12) || \/ Y" ]& z; [, T- A5 G* r+ W, C
- (((PERIPH) == TIM13) || \- }- {; ]: H" w. S G% a- C/ ?' T
- ((PERIPH) == TIM14))), t- @6 z4 I9 c P+ N
- /* LIST1: TIM1, TIM2, TIM3, TIM4, TIM5, TIM8, TIM9, TIM10, TIM11, TIM12, TIM13 and TIM14 */
) ?7 o8 T, n9 q9 j" r - #define IS_TIM_LIST1_PERIPH(PERIPH) (((PERIPH) == TIM1) || \8 O5 r: k5 _9 o$ e5 w# A& [ d
- ((PERIPH) == TIM2) || \3 g4 E5 k+ x7 R1 k0 y* Z
- ((PERIPH) == TIM3) || \$ X8 ~% ~/ s8 R$ g. q( b e, g- K
- ((PERIPH) == TIM4) || \% D* k) u+ o& h% e
3 D2 w: b. t" j* X - ((PERIPH) == TIM8) || \& T- w3 ?6 i: V! o6 p6 S
- ((PERIPH) == TIM9) || \5 Y: ]+ X6 n! Z* d5 e8 ]
+ u2 Z3 e; t! [5 a - ((PERIPH) == TIM11) || \
& J% f& O8 \4 \5 \2 q. F - ((PERIPH) == TIM12) || \
0 h6 {: O! Z& o - ((PERIPH) == TIM13) || \7 [+ K6 a% L) z+ k+ M. A# U+ w# ` H
- X d& [, Q6 {% e$ i9 R @
} L1 W0 T; C% p$ i- /* LIST2: TIM1, TIM2, TIM3, TIM4, TIM5, TIM8, TIM9 and TIM12 */' S b& U* ? [5 _; ]# K) w8 w6 w
- #define IS_TIM_LIST2_PERIPH(PERIPH) (((PERIPH) == TIM1) || \
. a4 |& x5 K. ]) S6 S! g) A. T - ((PERIPH) == TIM2) || \% T) i# M9 D; F8 `, K8 ]
, F. E- X' x5 e - ((PERIPH) == TIM4) || \
% Y% n0 h' D- d1 Y - ((PERIPH) == TIM5) || \) x# U% \7 U8 {3 \; b" h* z V
! x$ x: _( w4 @; w# ^ - ((PERIPH) == TIM9) || \' r8 c0 ?% I3 \3 F/ h
- ((PERIPH) == TIM12))6 I. n" S7 V" D1 a' |/ [
- /* LIST3: TIM1, TIM2, TIM3, TIM4, TIM5 and TIM8 */
. }/ T' v, j9 @% F - #define IS_TIM_LIST3_PERIPH(PERIPH) (((PERIPH) == TIM1) || \
6 T" p" L5 p( o# [ - ((PERIPH) == TIM2) || \
/ ]+ Y" u# v% q8 P0 Y/ b# z - ((PERIPH) == TIM3) || \
. c# [: C3 u1 h/ l- H# \/ t - ((PERIPH) == TIM4) || \) O6 W6 l* u/ j6 y3 z1 r" p \
0 i4 u: | Y+ U% F - ((PERIPH) == TIM8))
: i* |: _2 V1 }) C) q8 w - /* LIST4: TIM1 and TIM8 */2 ]! c/ f, C- Y* u1 m
- #define IS_TIM_LIST4_PERIPH(PERIPH) (((PERIPH) == TIM1) || \1 G" u' p& H$ U" { ~
) w9 N6 Z! b( f: {8 ?. w1 ]3 I - /* LIST5: TIM1, TIM2, TIM3, TIM4, TIM5, TIM6, TIM7 and TIM8 */
! ~1 h. {; O, H1 W3 F* G5 V5 j - #define IS_TIM_LIST5_PERIPH(PERIPH) (((PERIPH) == TIM1) || \
0 F' K) h8 ~4 X% O - ((PERIPH) == TIM2) || \) X- X5 G; s+ u. Z" A5 J9 J
- ((PERIPH) == TIM3) || \( ?0 K4 V) x* h! ^2 ~& A8 R
- ((PERIPH) == TIM4) || \; p$ O+ Q! v F4 X" W9 y8 V
- ((PERIPH) == TIM5) || \/ @& K& z3 q- H$ H( ~5 G
$ v$ D' C: q3 r& m8 w - ((PERIPH) == TIM7) || \, C5 B: q0 N4 ]1 q
- ((PERIPH) == TIM8))5 `- ^% L# p( q
- /* LIST6: TIM2, TIM5 and TIM11 */
) g2 A- r8 w8 d' Q. N. @6 R" y- Y - #define IS_TIM_LIST6_PERIPH(TIMx)(((TIMx) == TIM2) || \; M3 Q7 F/ L* ]9 ~' d
- ((TIMx) == TIM5) || \
( c/ i5 N- |8 D' A - ((TIMx) == TIM11))
( W' i c, i+ w( J8 k
复制代码 ! m) p2 R; H' M; f! t
TIM_Output_Compare_and_PWM_modes* S5 \3 P# _6 c1 b
* y z7 K6 g* O! u K- /** @defgroup TIM_Output_Compare_and_PWM_modes 6 k& C- ^6 o3 S7 x/ {
- * @{, L/ l/ M! p: U' |* @4 M* n; C
) p6 q) r5 j4 k9 B2 s" N$ K - 4 u8 ], x. O k
- #define TIM_OCMode_Timing ((uint16_t)0x0000)/ v% ~& ^; D: r
- #define TIM_OCMode_Active ((uint16_t)0x0010)4 l0 `* F* S/ R( L7 N
- #define TIM_OCMode_Inactive ((uint16_t)0x0020)+ n+ x/ ~9 X8 r2 @' a
- #define TIM_OCMode_Toggle ((uint16_t)0x0030)8 I$ q9 w6 Z" g# C& _* u( L
- #define TIM_OCMode_PWM1 ((uint16_t)0x0060)
: s! Z- s$ }! z; u7 N# u- s - #define TIM_OCMode_PWM2 ((uint16_t)0x0070)
; M) O( t5 b8 G8 v g0 G0 u - #define IS_TIM_OC_MODE(MODE) (((MODE) == TIM_OCMode_Timing) || \2 @" r" l! Y3 `) ^" h
- ((MODE) == TIM_OCMode_Active) || \0 `8 g5 |; C: \8 B
- ((MODE) == TIM_OCMode_Inactive) || \7 C. ~% A6 x4 L) V
- ((MODE) == TIM_OCMode_Toggle)|| \9 F- y9 \* n0 ` l& Z) _
- ((MODE) == TIM_OCMode_PWM1) || \
7 l8 I, L2 `' H2 l - ((MODE) == TIM_OCMode_PWM2))
: j) @* M3 _' M; Y$ X - #define IS_TIM_OCM(MODE) (((MODE) == TIM_OCMode_Timing) || \5 U3 X( ?! X8 F2 r$ l! J
$ M R, J7 V r# K, y - ((MODE) == TIM_OCMode_Inactive) || \
/ F1 ]( t y1 ^- b8 R - ((MODE) == TIM_OCMode_Toggle)|| \
1 W6 b* f0 k& q3 p - ((MODE) == TIM_OCMode_PWM1) || \0 {; H0 R1 Q8 C* z4 w# C! ^. E
- ((MODE) == TIM_OCMode_PWM2) || \
' E Y4 D( @1 ]0 B7 x: b2 N+ K# g - ((MODE) == TIM_ForcedAction_Active) || \
! e2 s$ @. D0 L: G, l - ((MODE) == TIM_ForcedAction_InActive))
! ^9 t: A# c* Q) `: a- z
复制代码 5 x |+ g! s1 f8 V i3 v
TIM_One_Pulse_Mode
/ d- u1 A4 |; {3 M( E }
2 e* C: a, ]* Y8 B+ H% B( o. Z- /** @defgroup TIM_One_Pulse_Mode
# ^+ J" _, V4 x5 K5 _5 U$ | - * @{" x( x8 W- i3 c
$ A9 a7 n9 b, z$ E# i5 w
: ~1 J T7 q9 i$ |- #define TIM_OPMode_Single ((uint16_t)0x0008)' z. D' W: k9 l( _" F Y7 l
- #define TIM_OPMode_Repetitive ((uint16_t)0x0000)
$ ?0 N* W" t+ u+ s - #define IS_TIM_OPM_MODE(MODE) (((MODE) == TIM_OPMode_Single) || \
) `, W& Z7 r6 D - ((MODE) == TIM_OPMode_Repetitive))
复制代码 , z) u7 o) S% v' l' a
TIM_Channel! K8 r0 Z% e$ W% q( |
! i q; b/ O D2 e
- /** @defgroup TIM_Channel $ p5 w* `7 J& c3 Y
- * @{* x9 F" {2 M( N. d8 h" P
- */) A6 e3 M6 K2 a, d
- 4 J$ r* f& K5 L" B
- #define TIM_Channel_1 ((uint16_t)0x0000)2 T; o3 m' g9 q% Z. e t7 z+ x1 ]
- #define TIM_Channel_2 ((uint16_t)0x0004)/ r0 \( F( m* r/ ?& f
- #define TIM_Channel_3 ((uint16_t)0x0008)
* O. A9 f6 P C: p5 s6 s - #define TIM_Channel_4 ((uint16_t)0x000C)
3 M8 h: c+ H3 O5 a- P
8 g+ X- E2 _, A3 ?$ U, A8 @- #define IS_TIM_CHANNEL(CHANNEL) (((CHANNEL) == TIM_Channel_1) || \. ?# J. j% D, w" m" x
- ((CHANNEL) == TIM_Channel_2) || \
$ y- Q: e5 ^/ _# \0 ] - ((CHANNEL) == TIM_Channel_3) || \
" p% Z) e. p( z# j - ((CHANNEL) == TIM_Channel_4))
8 a$ x+ ~% X. j
( r8 [% C) w1 ]+ C$ b \- #define IS_TIM_PWMI_CHANNEL(CHANNEL) (((CHANNEL) == TIM_Channel_1) || \( C! u6 a% f; q9 X- [! C
- ((CHANNEL) == TIM_Channel_2))
2 D- z' @* A& o( m+ { - #define IS_TIM_COMPLEMENTARY_CHANNEL(CHANNEL) (((CHANNEL) == TIM_Channel_1) || \- p; E) c" [) B0 Z
- ((CHANNEL) == TIM_Channel_2) || \- w+ K! g& V( X5 r" B" e3 e
- ((CHANNEL) == TIM_Channel_3))
$ V& }" }! ?# k7 [" o! t3 y8 s$ l: l
复制代码 % v9 R! _* l( g+ v+ I( Z- x
, [: c) z( v: [6 z" G1 r! S2 h" }1 G) r$ H' O* z
- /** @defgroup TIM_Clock_Division_CKD
* l& o7 {0 {3 L; P - * @{
# ^2 d m: p- J d9 @" C0 y - */" w3 V% q& I1 w+ H5 j
: r* V3 Z. v; K" {3 d6 P- #define TIM_CKD_DIV1 ((uint16_t)0x0000)
8 w8 ]; g$ g8 p4 N- }! e - #define TIM_CKD_DIV2 ((uint16_t)0x0100)
* U8 G6 E& z0 l( T. |! x - #define TIM_CKD_DIV4 ((uint16_t)0x0200)
/ p1 k7 P. J% D2 A6 _) B/ w0 A& e; J - #define IS_TIM_CKD_DIV(DIV) (((DIV) == TIM_CKD_DIV1) || \6 r$ `/ ?! T7 N6 i; l& I
- ((DIV) == TIM_CKD_DIV2) || \
! n J! k. `( o. H2 } - ((DIV) == TIM_CKD_DIV4))
# s3 i! H m9 H+ n3 O
复制代码 & D% d/ [1 w% c: u! D
TIM_Counter_Mode
# C* g% U4 _: W3 f- `) D2 p9 u& G. x9 O4 Q3 g8 y- G
- /** @defgroup TIM_Counter_Mode
5 K. Q4 q9 J S- B: T - * @{
6 l8 q* H4 D. e5 W* y - */$ G: B1 f, p/ f+ }7 O
- ( }3 P, `6 H8 ~# W- L' @+ p
- #define TIM_CounterMode_Up ((uint16_t)0x0000)1 q: I( `, {6 [! @4 P- i/ P5 B
- #define TIM_CounterMode_Down ((uint16_t)0x0010) m1 ^ e, K* i" A1 F
- #define TIM_CounterMode_CenterAligned1 ((uint16_t)0x0020)
t Y; B9 @' `" p+ S* {# F - #define TIM_CounterMode_CenterAligned2 ((uint16_t)0x0040)
) f& w9 p- o, k% j - #define TIM_CounterMode_CenterAligned3 ((uint16_t)0x0060)( L1 l" L" _, m; y
- #define IS_TIM_COUNTER_MODE(MODE) (((MODE) == TIM_CounterMode_Up) || \- L2 r. L4 Q3 [; K) ]
- ((MODE) == TIM_CounterMode_Down) || \
& M0 t, F# }& G: z% y" j - ((MODE) == TIM_CounterMode_CenterAligned1) || \
2 `. i2 z* s$ A1 e - ((MODE) == TIM_CounterMode_CenterAligned2) || \4 w% s6 j, {3 s3 t
- ((MODE) == TIM_CounterMode_CenterAligned3))
复制代码 % ~- k. q& R- E* C
TIM_Output_Compare_Polarity, \5 D; f9 i% e" W
0 X3 L* i/ N6 N5 R- /** @defgroup TIM_Output_Compare_Polarity + z9 E2 ^8 G% h2 e: ^2 D# I
4 E5 e- H* A" {% T% ^9 X - */
2 G' a- w- N0 a$ n" n' s - # X7 c7 c5 Q2 S- o; ^
- #define TIM_OCPolarity_High ((uint16_t)0x0000)
% m0 s+ o, f6 Y$ N - #define TIM_OCPolarity_Low ((uint16_t)0x0002)5 W/ c, g( L6 n) |
- #define IS_TIM_OC_POLARITY(POLARITY) (((POLARITY) == TIM_OCPolarity_High) || \9 F" N, {/ [/ u
- ((POLARITY) == TIM_OCPolarity_Low))
# Q: u- y' ]- M( STIM_Output_Compare_N_Polarity9 w2 e5 o; x% [4 A8 u: @% ? U
% t' w- w( C3 G. C: b1 p' E* T P- /** @defgroup TIM_Output_Compare_N_Polarity " k# y" B6 M7 }' a! r
4 i( b; o/ e& c; K - */2 z* M( C( I7 g% Z; P! J" C
- , k% r2 k* W/ m- g1 i1 r
- #define TIM_OCNPolarity_High ((uint16_t)0x0000)1 w- G& B# _" t; W S1 _# F. R
- #define TIM_OCNPolarity_Low ((uint16_t)0x0008), Z4 o) L5 p5 Y |$ y- V
- #define IS_TIM_OCN_POLARITY(POLARITY) (((POLARITY) == TIM_OCNPolarity_High) || \
" O2 a( d9 \: j4 @1 z$ N( ^# V% U - ((POLARITY) == TIM_OCNPolarity_Low))
$ r3 e: @' r; u" a( C' t6 r d
复制代码 : z. Z/ R' D- O" G
( Z. r( N8 J3 a; K! h/ x; b, w$ d
' `! t: u2 C% W8 V6 D- /** @defgroup TIM_Output_Compare_State % X# m9 R5 V/ \& G1 e; D2 d
- * @{1 K6 }4 M# S" n( j" i4 l) y- y
. {- J! t$ I4 }$ Q1 X5 K' [ - 7 \% C7 p1 y3 U
- #define TIM_OutputState_Disable ((uint16_t)0x0000)
. c Z0 M' [, g. `4 }/ V, T0 d - #define TIM_OutputState_Enable ((uint16_t)0x0001)) ~- Z7 f9 l0 F7 B! H* \; G; T
- #define IS_TIM_OUTPUT_STATE(STATE) (((STATE) == TIM_OutputState_Disable) || \1 W) F) v; g8 l$ w& h. H7 s5 u
- ((STATE) == TIM_OutputState_Enable))4 B7 N% h i9 V$ J* q/ ?! c9 B
复制代码 $ i# k! f4 h3 e8 |; P0 [( F" W. A' R
TIM_Output_Compare_N_State- /** @defgroup TIM_Output_Compare_N_State5 g, T! B; \+ v; B3 D
- * @{4 l% }- v, v; l/ K
- S% J6 J$ q+ @# q9 v `. s5 U
$ f' c6 v' p& P% T0 t2 k- #define TIM_OutputNState_Disable ((uint16_t)0x0000): h6 O3 e9 {. g/ f9 ]& h' N
- #define TIM_OutputNState_Enable ((uint16_t)0x0004)
- l3 S( t& l; v; Q$ N; A% P0 w - #define IS_TIM_OUTPUTN_STATE(STATE) (((STATE) == TIM_OutputNState_Disable) || \
; L, i" h5 h. R$ ?; E3 V( _ - ((STATE) == TIM_OutputNState_Enable))
复制代码 , C) ?0 F) V5 n7 N1 T `7 s; f
TIM_Capture_Compare_State
- D4 R' k5 P5 D* ^7 f
6 v; C1 z4 A9 _& F* n& O- /** @defgroup TIM_Capture_Compare_State
6 q- e: g) c% Q! c% Z9 y8 G - * @{
! f A& t1 ?& H/ G3 D - */. ^& |6 `6 `5 w" \" Z
+ K; S6 h2 ~- B' q$ g* L$ o1 }- #define TIM_CCx_Enable ((uint16_t)0x0001)
0 n9 N: ~: Y4 D - #define TIM_CCx_Disable ((uint16_t)0x0000)8 s, \6 c: A& {
- #define IS_TIM_CCX(CCX) (((CCX) == TIM_CCx_Enable) || \
7 R7 ]/ Z3 `: d - ((CCX) == TIM_CCx_Disable))
复制代码 $ z7 h4 f1 u9 M) l" T1 k5 a- [
TIM_Capture_Compare_N_State
3 O1 h- P6 f1 c, V. M) G& `: m# n3 q4 h9 D4 E; s; ]1 C3 L
- /** @defgroup TIM_Capture_Compare_N_State& A5 _1 A ?1 j& p8 s* W+ v
+ k, ~2 p) C/ | - */1 ^( m+ a6 o$ k0 o, _1 x
7 ]% U$ c. b5 w n- #define TIM_CCxN_Enable ((uint16_t)0x0004) y# H$ j/ @3 t" a, u$ Z
- #define TIM_CCxN_Disable ((uint16_t)0x0000)
/ j! H4 c: R- o - #define IS_TIM_CCXN(CCXN) (((CCXN) == TIM_CCxN_Enable) || \
6 |' g. N. a9 ` - ((CCXN) == TIM_CCxN_Disable))
7 p2 d! B! s4 g2 F, I6 FTIM_Break_Input_enable_disable1 k9 `& Y0 p' b; A
8 h8 D& E2 V. g$ V2 h- [- /** @defgroup TIM_Break_Input_enable_disable " ?/ O( c& d. |' f+ V( v
& _8 ]" w& s! j5 s: t' X* [ - */% \3 W9 f( N+ d' c) |
5 L' X8 v+ }* M+ l! H1 Y% Z5 ]- #define TIM_Break_Enable ((uint16_t)0x1000)5 q' I6 y/ a+ ?; s/ L
- #define TIM_Break_Disable ((uint16_t)0x0000)% l& N5 c& N( W- J: @
- #define IS_TIM_BREAK_STATE(STATE) (((STATE) == TIM_Break_Enable) || \
3 ~2 M6 `: ?/ U0 A2 C - ((STATE) == TIM_Break_Disable))
复制代码 ( Q1 o _7 j# d5 ]) m
TIM_Break_Polarity6 X8 q) W6 h) M/ N. X/ Z% W
; s+ A2 W8 z' O3 C# K( i
- /** @defgroup TIM_Break_Polarity ; n* q; L5 y, e T7 U! {$ W- O
- * @{2 v4 R6 |/ Q) s* T7 ^. K9 G
& |, C2 g& o' T2 \3 J - ( t) j( w' m/ ?% I- W7 U. U
- #define TIM_BreakPolarity_Low ((uint16_t)0x0000)2 G' r8 Q$ e W/ v7 s5 i' m! W
- #define TIM_BreakPolarity_High ((uint16_t)0x2000)9 J9 k) `9 ?- @4 X* F/ A5 E' _
- #define IS_TIM_BREAK_POLARITY(POLARITY) (((POLARITY) == TIM_BreakPolarity_Low) || \) l: a- ~, o3 j0 T; T
- ((POLARITY) == TIM_BreakPolarity_High))
复制代码 ) E0 J/ L* ~2 \
TIM_AOE_Bit_Set_Reset+ l2 x$ {6 S; u( X$ H
$ i. s$ {: Y4 V( p c+ _- ' Q6 ?! |' G' z9 j5 }+ U
- /** @defgroup TIM_AOE_Bit_Set_Reset ' _% w& [1 f) d7 U% G* g# j" H
- * @{: M( Q; e. d1 G( k7 ^* J8 l- V; O
- */7 y Y9 B7 V* x1 L7 m( M
5 R: K% E7 T6 V0 k1 _+ q; e; }/ K# Y- #define TIM_AutomaticOutput_Enable ((uint16_t)0x4000)
! ^ A* o! ]. A - #define TIM_AutomaticOutput_Disable ((uint16_t)0x0000)
% z7 K, {! v1 W- V" x; V& G8 Y3 y1 H, e - #define IS_TIM_AUTOMATIC_OUTPUT_STATE(STATE) (((STATE) == TIM_AutomaticOutput_Enable) || \# {- s! P' M, C* F
- ((STATE) == TIM_AutomaticOutput_Disable))
复制代码 1 [! J8 `& S1 r4 v
TIM_Lock_level
: y! `9 X$ N. M' ]* H5 H }
9 ^7 Y3 u6 ?( B. ^& _- /** @defgroup TIM_Lock_level
+ ]8 r3 T6 \" y$ A) _ - * @{$ K3 U* {9 f0 o, [
1 O Y3 v$ V: R! A0 j& I" I - 4 c+ J! {. u( W6 p7 M A$ ~1 Z
- #define TIM_LOCKLevel_OFF ((uint16_t)0x0000)
# l0 A% }4 L2 L3 j2 a! p1 S& H - #define TIM_LOCKLevel_1 ((uint16_t)0x0100)
, R5 n7 L; e/ C* R- ^' j - #define TIM_LOCKLevel_2 ((uint16_t)0x0200)
2 r: [3 n4 x# \. G! Z - #define TIM_LOCKLevel_3 ((uint16_t)0x0300)6 a/ h; v$ u5 k D
- #define IS_TIM_LOCK_LEVEL(LEVEL) (((LEVEL) == TIM_LOCKLevel_OFF) || \" {3 N: b. z$ F% L" Z% X
- ((LEVEL) == TIM_LOCKLevel_1) || \
$ P8 g! A; K4 \4 ?1 M - ((LEVEL) == TIM_LOCKLevel_2) || \
) |4 w0 ?/ k3 W8 U7 @. I# @$ t# A - ((LEVEL) == TIM_LOCKLevel_3))
0 D& d, d( ]! PTIM_OSSI_Off_State_Selection_for_Idle_mode_state
4 O+ ^7 s% \' O1 H4 C* o' v
# d$ ^+ W: D9 u: ~
2 E( S. I, C' H; O- /** @defgroup TIM_OSSI_Off_State_Selection_for_Idle_mode_state
: r$ Y# q0 m* Y+ ^1 F4 X: w - * @{
, Q4 L! `) p6 A7 H - */8 M( `: x. |3 A' u, \# |
- 4 W& R. `! y2 p2 `
- #define TIM_OSSIState_Enable ((uint16_t)0x0400)
' P8 ~8 z: ~* ` _1 o7 e" i; r4 ]. ~$ S - #define TIM_OSSIState_Disable ((uint16_t)0x0000)
# {- B5 S; w; ` - #define IS_TIM_OSSI_STATE(STATE) (((STATE) == TIM_OSSIState_Enable) || \
+ A$ S, q1 a: A J - ((STATE) == TIM_OSSIState_Disable))
复制代码 ) l8 x6 O t! d/ v+ ~% o/ u0 c
' O# U- n2 m4 {2 Z0 R) j2 h
' |; n, x1 m O3 H- S( i2 N- /** @defgroup TIM_OSSR_Off_State_Selection_for_Run_mode_state
) e. Q, R" F4 P2 H, u* F5 I f1 a - * @{1 l8 O [# @2 N0 z( I
, Y3 h$ a% ?- l/ H- E/ G! g - ! D. H& [% ~6 ^
- #define TIM_OSSRState_Enable ((uint16_t)0x0800)! A8 Y: a% [( |: U8 t1 {% Q ^+ ~! u
- #define TIM_OSSRState_Disable ((uint16_t)0x0000)- i0 H( p5 R5 g7 G
- #define IS_TIM_OSSR_STATE(STATE) (((STATE) == TIM_OSSRState_Enable) || \
) n& K) \ f* S0 B! ? - ((STATE) == TIM_OSSRState_Disable))9 e" E% D3 l5 x- V& J- K7 {# X; H/ g
复制代码 $ G% c, n! u4 U
8 w" P4 R. v$ T- w/ P! ?5 m8 ?/ H
+ ~/ h+ f( g4 |- /** @defgroup TIM_Output_Compare_Idle_State 2 s$ g& {3 u |' T$ h9 e& S5 T% G
- * @{5 X, G+ A, ?$ ~- l& x1 f l
- */9 v0 I" U9 ]6 q6 l- `/ T- y6 l
- 0 D, q: @& Q1 o) W c
- #define TIM_OCIdleState_Set ((uint16_t)0x0100)
6 ^, _& K7 u/ d - #define TIM_OCIdleState_Reset ((uint16_t)0x0000)# Y+ e! u, X& n% m& R
- #define IS_TIM_OCIDLE_STATE(STATE) (((STATE) == TIM_OCIdleState_Set) || \
6 I! T) Z$ j( b) ^" U/ y( R3 ^8 [* M - ((STATE) == TIM_OCIdleState_Reset))
/ j4 k" ^( H2 z- ]- E6 K) X( P4 vTIM_Output_Compare_N_Idle_State+ S3 Y- j' \4 D' U( K. N0 y
& W1 D I" }2 x8 s% O- /** @defgroup TIM_Output_Compare_N_Idle_State
$ v1 i6 w# j; ~8 p, C; a, Q0 D - * @{; J7 w" j, F8 O2 G
}2 x" d7 |( T; j - * J' ]' [3 b+ Y" E7 Q2 @
- #define TIM_OCNIdleState_Set ((uint16_t)0x0200)
+ e$ ?3 R9 t1 a% Q9 J8 H - #define TIM_OCNIdleState_Reset ((uint16_t)0x0000)* B: n: ?$ Y W
- #define IS_TIM_OCNIDLE_STATE(STATE) (((STATE) == TIM_OCNIdleState_Set) || \
* ^% m1 A+ q3 D+ u* |, b - ((STATE) == TIM_OCNIdleState_Reset))
! {. l# _5 w1 ]TIM_Input_Capture_Polarity" k4 H5 E1 ^5 ?& i& n- Q
8 Z7 W. s7 n) G: M$ k9 Z u- /** @defgroup TIM_Input_Capture_Polarity
A) [4 Y) N3 { a" T% ]. ] - * @{
% _; A* a0 s1 q# h - */
5 M" z0 C& B, L6 U - ) E* j! _: W% _8 w/ z0 M4 d
- #define TIM_ICPolarity_Rising ((uint16_t)0x0000)) l# Q( n! q( I S/ y6 ^
- #define TIM_ICPolarity_Falling ((uint16_t)0x0002)
$ a9 ~. m: j/ w$ u1 ` - #define TIM_ICPolarity_BothEdge ((uint16_t)0x000A)
1 R1 M! W1 s0 Q# i+ N* z - #define IS_TIM_IC_POLARITY(POLARITY) (((POLARITY) == TIM_ICPolarity_Rising) || \* j1 y6 ]1 D' H* R
- ((POLARITY) == TIM_ICPolarity_Falling)|| \
8 z7 u3 t; O! n - ((POLARITY) == TIM_ICPolarity_BothEdge))
复制代码 4 n, q9 O/ g9 ^; ]! G- U# d: n
TIM_Input_Capture_Selection- /** @defgroup TIM_Input_Capture_Selection 1 R5 T6 W( E |8 q9 Y0 l
6 ?" g. X, S9 w4 N - */
^% x+ [, M% \# b7 ?0 k* F. o5 G
8 D% x/ m" @& L O) {; T# k- #define TIM_ICSelection_DirectTI ((uint16_t)0x0001) /*!< TIM Input 1, 2, 3 or 4 is selected to be ( A& |! V. t1 r' S8 |# u
- connected to IC1, IC2, IC3 or IC4, respectively */. C- P! t. _7 {) e7 a& U! ~9 P
- #define TIM_ICSelection_IndirectTI ((uint16_t)0x0002) /*!< TIM Input 1, 2, 3 or 4 is selected to be
; s2 p% f7 T4 {+ ?5 k - connected to IC2, IC1, IC4 or IC3, respectively. */
* i4 r) A3 Q5 p+ b1 D0 ` - #define TIM_ICSelection_TRC ((uint16_t)0x0003) /*!< TIM Input 1, 2, 3 or 4 is selected to be connected to TRC. */
4 g* o9 V' r s6 m2 n+ u# j - #define IS_TIM_IC_SELECTION(SELECTION) (((SELECTION) == TIM_ICSelection_DirectTI) || \8 S3 {' x7 V9 w$ J, Z
- ((SELECTION) == TIM_ICSelection_IndirectTI) || \: N% `) Z) U q' l
- ((SELECTION) == TIM_ICSelection_TRC))
复制代码 8 N. _. R0 ~% R5 S. r+ u3 L# s p
TIM_Input_Capture_Prescaler4 s( Q# P7 Q! ?0 `
7 q. W, m b+ i" C5 U
- /** @defgroup TIM_Input_Capture_Prescaler # M+ } g5 i% [8 {4 N: k: K
7 f- @' Q. J9 @5 F" [ - */
- j- i9 _" G; A - 3 S3 J. j2 ~, Q7 o
- #define TIM_ICPSC_DIV1 ((uint16_t)0x0000) /*!< Capture performed each time an edge is detected on the capture input. */
0 x8 {- ~2 g& x6 S/ \ - #define TIM_ICPSC_DIV2 ((uint16_t)0x0004) /*!< Capture performed once every 2 events. *// ~7 @7 D1 i% R3 e2 f7 r/ T# n
- #define TIM_ICPSC_DIV4 ((uint16_t)0x0008) /*!< Capture performed once every 4 events. */
# Y& m) `+ Y& {+ f% X - #define TIM_ICPSC_DIV8 ((uint16_t)0x000C) /*!< Capture performed once every 8 events. */4 \* B5 Q, b# v; ?
- #define IS_TIM_IC_PRESCALER(PRESCALER) (((PRESCALER) == TIM_ICPSC_DIV1) || \
0 F0 D' }5 z! R. z) a7 O - ((PRESCALER) == TIM_ICPSC_DIV2) || \* T+ V# S+ M7 |9 S
- ((PRESCALER) == TIM_ICPSC_DIV4) || \
% r' G8 y* p5 { - ((PRESCALER) == TIM_ICPSC_DIV8))2 n V& [$ B9 S: H7 \
) w) H, l+ I% R* P) K* pTIM_interrupt_sources3 Z( s. o8 A/ |: c
7 t! `* t- _ ]% {8 s0 Z) ]" F) N
- /** @defgroup TIM_interrupt_sources + w& b# M" }( ~$ {* V
- * @{6 c4 ^1 v) J. @0 a! _) a# o
7 {, \( o& [4 B
, M. K# A& v; W7 L. Q- #define TIM_IT_Update ((uint16_t)0x0001)0 `9 V" d" G, w
- #define TIM_IT_CC1 ((uint16_t)0x0002)
* `# m# B$ I& B* H* O - #define TIM_IT_CC2 ((uint16_t)0x0004)3 { Y" N& d- ^8 J" c9 _: y
- #define TIM_IT_CC3 ((uint16_t)0x0008)
0 v8 R6 R p# K1 q5 m8 v - #define TIM_IT_CC4 ((uint16_t)0x0010)
. l' R# u5 Q' I+ o$ Y; i- j6 a - #define TIM_IT_COM ((uint16_t)0x0020)
6 V% k( L9 Q8 ?9 |: B( s0 [ - #define TIM_IT_Trigger ((uint16_t)0x0040); f9 N- Q% z6 L3 _3 F
- #define TIM_IT_Break ((uint16_t)0x0080)
' s- ^7 g9 F8 w3 b. R - #define IS_TIM_IT(IT) ((((IT) & (uint16_t)0xFF00) == 0x0000) && ((IT) != 0x0000))6 C% a! b3 V2 h8 J0 u( o6 \+ G; {# Q
- 0 Y4 i" J" i! u; n
- #define IS_TIM_GET_IT(IT) (((IT) == TIM_IT_Update) || \
+ O8 L; x0 e) A - ((IT) == TIM_IT_CC1) || \: ~ a8 }! P3 g- R" j! v% s
- ((IT) == TIM_IT_CC2) || \
& _! e/ p& B/ c0 k5 f" S4 ]3 Y! k - ((IT) == TIM_IT_CC3) || \; ?( v& z$ s: Z& v$ l5 k0 M8 |& d6 ^
- ((IT) == TIM_IT_CC4) || \
$ V5 \4 d/ ?/ V! C- c) I - ((IT) == TIM_IT_COM) || \
% T0 V) S6 @; p7 w - ((IT) == TIM_IT_Trigger) || \4 r6 a5 c. X5 v% l
- ((IT) == TIM_IT_Break))
复制代码 # X$ s2 y8 l8 y+ |5 W
TIM_DMA_Base_address
( H+ L+ k" e$ U1 B+ ?' {" }5 l1 q0 `. `. m( t! }& q
- /** @defgroup TIM_DMA_Base_address 9 x$ G1 H# L) ` X
- * @{% G* I! p! ~( W2 @4 x
- */) S3 H. k- E) S9 r- {2 b: l
- , V8 r2 {1 G; q- P; r
- #define TIM_DMABase_CR1 ((uint16_t)0x0000)5 ?9 Z; w& A8 M0 j: b. k3 v% p; B
- #define TIM_DMABase_CR2 ((uint16_t)0x0001)
5 q! s( G1 M! h6 t0 A6 g8 G2 f - #define TIM_DMABase_SMCR ((uint16_t)0x0002)* A. i. Y" y, T7 g, T* `
- #define TIM_DMABase_DIER ((uint16_t)0x0003)# H$ \& C) C) k; x+ G$ |2 Q0 C
- #define TIM_DMABase_SR ((uint16_t)0x0004)
* y6 q2 X& O1 p8 K - #define TIM_DMABase_EGR ((uint16_t)0x0005)0 E" d8 h7 k; d, Q6 w) r7 @
- #define TIM_DMABase_CCMR1 ((uint16_t)0x0006)0 x$ w. H. T( i: [0 g5 i- \
- #define TIM_DMABase_CCMR2 ((uint16_t)0x0007)% G) N% x) a2 U% j4 M
- #define TIM_DMABase_CCER ((uint16_t)0x0008)
* G1 Z' V+ s9 B8 i! u2 ]% n - #define TIM_DMABase_CNT ((uint16_t)0x0009)
) P5 A+ M, v& z. C - #define TIM_DMABase_PSC ((uint16_t)0x000A)' o, S' I- a# ]2 u" U6 f r. C
- #define TIM_DMABase_ARR ((uint16_t)0x000B)* Z" \0 U9 i( u; m2 r/ E
- #define TIM_DMABase_RCR ((uint16_t)0x000C)7 ]' Z0 m* b0 O# b6 n; P
- #define TIM_DMABase_CCR1 ((uint16_t)0x000D)
( z0 f0 Y6 ^7 } - #define TIM_DMABase_CCR2 ((uint16_t)0x000E)/ E7 ^% ~) d' l$ D
- #define TIM_DMABase_CCR3 ((uint16_t)0x000F): ~4 W ^: U: S5 D, |
- #define TIM_DMABase_CCR4 ((uint16_t)0x0010)
$ g8 ]* [4 ~4 j, f s Y - #define TIM_DMABase_BDTR ((uint16_t)0x0011)% G- ?& Q5 u6 c- V/ K7 }
- #define TIM_DMABase_DCR ((uint16_t)0x0012)
% c' j. d! F6 k! u4 Y3 O - #define TIM_DMABase_OR ((uint16_t)0x0013)
2 }2 Q; N9 b8 R: q" W3 | - #define IS_TIM_DMA_BASE(BASE) (((BASE) == TIM_DMABase_CR1) || \7 F n% E3 \$ r$ M' J
- ((BASE) == TIM_DMABase_CR2) || \$ p/ `( A4 f- `. {0 _
- ((BASE) == TIM_DMABase_SMCR) || \
/ \; z" {$ ?7 n) u G - ((BASE) == TIM_DMABase_DIER) || \
+ c& A- r' M9 ?- k& l$ M2 O8 u9 @ - ((BASE) == TIM_DMABase_SR) || \& Y; [7 |& \9 W
- ((BASE) == TIM_DMABase_EGR) || \
: D+ N' e8 Z* m+ N$ v5 ^ - ((BASE) == TIM_DMABase_CCMR1) || \/ M5 ^8 m. F2 t& x, U$ _
- ((BASE) == TIM_DMABase_CCMR2) || \* F2 J/ `; X3 `3 r* ~3 X& S' U. ]+ Z
- ((BASE) == TIM_DMABase_CCER) || \
( { S6 f8 J3 t1 }6 Q- W# V - ((BASE) == TIM_DMABase_CNT) || \
p b( W) B& q; Q8 t3 N - ((BASE) == TIM_DMABase_PSC) || \( M' E4 o2 D5 B2 [9 m o5 D
- ((BASE) == TIM_DMABase_ARR) || \
) H* Q2 g; Q0 X - ((BASE) == TIM_DMABase_RCR) || \4 ?8 H6 h7 \- K" A: J
- ((BASE) == TIM_DMABase_CCR1) || \
9 b6 D u4 W7 S# i S* \- N2 Z2 U4 ~9 z - ((BASE) == TIM_DMABase_CCR2) || \) f$ P0 |6 Y3 W1 |% w
- ((BASE) == TIM_DMABase_CCR3) || \
% ~% ?$ O$ k$ f( U4 @ - ((BASE) == TIM_DMABase_CCR4) || \7 S- K, w# k# O, w2 S1 f
- ((BASE) == TIM_DMABase_BDTR) || \
" M' w" z# n: D - ((BASE) == TIM_DMABase_DCR) || \
6 B* L* e" @9 L! ]: O5 g - ((BASE) == TIM_DMABase_OR))
5 I: s) B N7 YTIM_DMA_Burst_Length; V; s/ `& d" [( @
8 W$ I" C; a3 c- ]' h/ `
- /** @defgroup TIM_DMA_Burst_Length
, H2 t: _, O1 L0 ]" E# X9 A - * @{
: ]' U) H7 n2 e3 N' L* `9 k* _/ O/ r% D - */' h9 q% O4 V0 E& m0 R: r; S+ c7 |% m
/ h* c, M: o7 V% B3 a' o# [+ |3 v- #define TIM_DMABurstLength_1Transfer ((uint16_t)0x0000)2 z! f) v7 U8 x. ~$ f( x, i
- #define TIM_DMABurstLength_2Transfers ((uint16_t)0x0100) F* a t* g$ q5 y) k
- #define TIM_DMABurstLength_3Transfers ((uint16_t)0x0200)
/ Z* |% y) c5 ~" j0 p - #define TIM_DMABurstLength_4Transfers ((uint16_t)0x0300)
2 k& q4 ?8 U0 T1 }( n7 x - #define TIM_DMABurstLength_5Transfers ((uint16_t)0x0400); F' v- \) D+ v: l9 g p( k7 _0 Y
- #define TIM_DMABurstLength_6Transfers ((uint16_t)0x0500)) [0 S6 \" k, p% j0 ?8 ?- ?0 w8 ^7 \
- #define TIM_DMABurstLength_7Transfers ((uint16_t)0x0600)
2 Y8 c, \3 L! N) v% B# H' x$ j - #define TIM_DMABurstLength_8Transfers ((uint16_t)0x0700)7 X+ N/ _6 \; m$ v j5 Q
- #define TIM_DMABurstLength_9Transfers ((uint16_t)0x0800)
7 Y- K4 q- R e+ K/ q$ v+ M- l9 G - #define TIM_DMABurstLength_10Transfers ((uint16_t)0x0900)
1 S) g1 D! t3 W8 D: _ - #define TIM_DMABurstLength_11Transfers ((uint16_t)0x0A00)* d1 f0 ~1 K' w$ K0 Z- v& X) W
- #define TIM_DMABurstLength_12Transfers ((uint16_t)0x0B00) c: q5 V$ w8 q) s% |& Z8 U- b
- #define TIM_DMABurstLength_13Transfers ((uint16_t)0x0C00)
c# Q% k' I7 p9 v' j - #define TIM_DMABurstLength_14Transfers ((uint16_t)0x0D00). D! H: B; ?/ t7 z! @$ x# N( d3 m
- #define TIM_DMABurstLength_15Transfers ((uint16_t)0x0E00)# v' M6 ~$ Z- ^) z0 A' H% p
- #define TIM_DMABurstLength_16Transfers ((uint16_t)0x0F00)
! r" h( ?, |7 Z# r; c* o- }( s+ }# R - #define TIM_DMABurstLength_17Transfers ((uint16_t)0x1000)
' y" f1 l3 b7 z! {1 \) a- k - #define TIM_DMABurstLength_18Transfers ((uint16_t)0x1100)
$ v6 j1 Y' { c& h9 x3 l/ \* s - #define IS_TIM_DMA_LENGTH(LENGTH) (((LENGTH) == TIM_DMABurstLength_1Transfer) || \
/ W5 r+ ^" A# `" X0 c8 Q9 n! G6 P - ((LENGTH) == TIM_DMABurstLength_2Transfers) || \2 Y5 l* R; e6 b. l( N0 j+ B
- ((LENGTH) == TIM_DMABurstLength_3Transfers) || \6 X0 s) ^ @( @. A- c; Y$ N
- ((LENGTH) == TIM_DMABurstLength_4Transfers) || \' k+ n3 Y: S5 Y7 ~! V& n4 H. U: v
- ((LENGTH) == TIM_DMABurstLength_5Transfers) || \
( p4 q) P$ K% [6 y$ z9 t3 @ - ((LENGTH) == TIM_DMABurstLength_6Transfers) || \8 f* e" C: H/ D' J
- ((LENGTH) == TIM_DMABurstLength_7Transfers) || \ F7 S, E. z; A5 v* ?+ |4 I) ]2 y
- ((LENGTH) == TIM_DMABurstLength_8Transfers) || \0 q# I. J1 r( q7 n/ v/ j# H
- ((LENGTH) == TIM_DMABurstLength_9Transfers) || \
0 F. v' r7 f: `: ` - ((LENGTH) == TIM_DMABurstLength_10Transfers) || \
# |& l1 x; D# i' ]5 i - ((LENGTH) == TIM_DMABurstLength_11Transfers) || \
5 }% z, l- S4 L- z, g - ((LENGTH) == TIM_DMABurstLength_12Transfers) || \9 I- Z! i# f7 E/ O" b; w s0 d: y
- ((LENGTH) == TIM_DMABurstLength_13Transfers) || \
6 I" ?, O& ]8 S! ?7 l- L+ `9 f - ((LENGTH) == TIM_DMABurstLength_14Transfers) || \
+ R' v W" ], f5 g* g5 E3 N - ((LENGTH) == TIM_DMABurstLength_15Transfers) || \
/ B. c, c7 U8 C7 p+ P8 ~* F - ((LENGTH) == TIM_DMABurstLength_16Transfers) || \
. |! ]$ D5 l! s: B - ((LENGTH) == TIM_DMABurstLength_17Transfers) || \8 } k5 l9 ^# Z
- ((LENGTH) == TIM_DMABurstLength_18Transfers))( }! G C. g, Z( u
复制代码 1 A" }! w3 e* }/ q4 J
TIM_DMA_sources
; D/ N5 x( l+ `" Z
4 o9 V/ v% W o$ H- /** @defgroup TIM_DMA_sources 2 [# g F; u) m$ t
* F1 _% a! l( V1 {8 d, \ - */6 l9 F' }" w P3 {, a& g' X/ ?
' t8 s( o- q( |% R4 x+ H- #define TIM_DMA_Update ((uint16_t)0x0100)
; S" Y6 S& I- q' S6 O - #define TIM_DMA_CC1 ((uint16_t)0x0200)
+ W) ]6 X7 G5 ~% O" } - #define TIM_DMA_CC2 ((uint16_t)0x0400) \) N' p, _3 _: u
- #define TIM_DMA_CC3 ((uint16_t)0x0800)
2 R, W6 F1 d9 \" ?& T - #define TIM_DMA_CC4 ((uint16_t)0x1000); m9 b x# o" G8 h5 J' i
- #define TIM_DMA_COM ((uint16_t)0x2000)4 v6 u2 E) s$ S, F6 s$ z
- #define TIM_DMA_Trigger ((uint16_t)0x4000)5 m& \" J1 n* e! b8 U K$ r
- #define IS_TIM_DMA_SOURCE(SOURCE) ((((SOURCE) & (uint16_t)0x80FF) == 0x0000) && ((SOURCE) != 0x0000))
) G' M0 ]: q9 d7 Q6 g# j6 wTIM_External_Trigger_Prescaler
% ?" w+ `9 T2 n2 e& z4 D' C4 ^1 m6 U8 d# J3 @9 M! H
- /** @defgroup TIM_External_Trigger_Prescaler 7 Y* {; g& Y; E0 a
- * @{7 L, p4 w* j" A1 _- p7 n4 @' r( H
- */4 b1 U; ^: N |$ }' r7 r& g7 D2 X1 w
- " \; g- X& B2 d8 k2 q7 `
- #define TIM_ExtTRGPSC_OFF ((uint16_t)0x0000)
7 T/ K+ J0 T" Z+ w2 U9 Q# J( ?# d - #define TIM_ExtTRGPSC_DIV2 ((uint16_t)0x1000). t5 F9 D R: @. D
- #define TIM_ExtTRGPSC_DIV4 ((uint16_t)0x2000); O G6 @) \% w9 q% e
- #define TIM_ExtTRGPSC_DIV8 ((uint16_t)0x3000), S6 t0 A9 m! h, ^# y* t
- #define IS_TIM_EXT_PRESCALER(PRESCALER) (((PRESCALER) == TIM_ExtTRGPSC_OFF) || \3 {7 g) k5 t! g x
- ((PRESCALER) == TIM_ExtTRGPSC_DIV2) || \
1 F; H, j- e( e9 I O4 Z3 V2 [ - ((PRESCALER) == TIM_ExtTRGPSC_DIV4) || \. T; N% K, u5 S% F% r- H
- ((PRESCALER) == TIM_ExtTRGPSC_DIV8))
复制代码 7 e, d; a3 c1 M0 |- S
TIM_Internal_Trigger_Selection) V4 L+ X& C3 Z$ I6 l3 K8 [
* c5 t* k5 _ {. o( Z+ |- /** @defgroup TIM_Internal_Trigger_Selection & n* ]2 w, Q, F' H9 ^! P
- * @{4 Z' A) d* a' O0 a; l
- */: E" ^4 T" U6 s: ?& m, `
- 9 o9 r, F" P* o5 `# U+ \" f
- #define TIM_TS_ITR0 ((uint16_t)0x0000)- ]4 U% y! t# z) ]
- #define TIM_TS_ITR1 ((uint16_t)0x0010)
9 X1 t; z) y, ?! r, L' Y; A/ m - #define TIM_TS_ITR2 ((uint16_t)0x0020)
6 U/ Z) V0 K' C - #define TIM_TS_ITR3 ((uint16_t)0x0030)
# x J/ q. ~8 I! w - #define TIM_TS_TI1F_ED ((uint16_t)0x0040)
" G4 g1 B0 C' g ^5 s# Z7 X - #define TIM_TS_TI1FP1 ((uint16_t)0x0050)2 s5 |* g2 u# R5 G
- #define TIM_TS_TI2FP2 ((uint16_t)0x0060)
# [. U& K L4 U. T( k5 |7 G - #define TIM_TS_ETRF ((uint16_t)0x0070)
1 ^( q3 [) U, ? - #define IS_TIM_TRIGGER_SELECTION(SELECTION) (((SELECTION) == TIM_TS_ITR0) || \; ?4 @' J4 S* B+ s
- ((SELECTION) == TIM_TS_ITR1) || \4 \ V& z% D1 h- G2 z7 O! U6 y
- ((SELECTION) == TIM_TS_ITR2) || \
4 }; x) {% C/ f! d - ((SELECTION) == TIM_TS_ITR3) || \5 l# o' \0 [$ w4 f# z8 J
- ((SELECTION) == TIM_TS_TI1F_ED) || \1 t/ G4 @. n% a$ Z' p1 p# d
- ((SELECTION) == TIM_TS_TI1FP1) || \* h7 H. U9 X" S" W1 _$ c
- ((SELECTION) == TIM_TS_TI2FP2) || \) z$ Z9 j" ?# M4 i
- ((SELECTION) == TIM_TS_ETRF)): r( e# K7 @ I
- #define IS_TIM_INTERNAL_TRIGGER_SELECTION(SELECTION) (((SELECTION) == TIM_TS_ITR0) || \
$ G: W. b0 @* `. Y3 J. H9 J1 j - ((SELECTION) == TIM_TS_ITR1) || \
m7 F; M' T1 o7 @' R! f0 p - ((SELECTION) == TIM_TS_ITR2) || \
) t) ^% t* D( h# \4 h - ((SELECTION) == TIM_TS_ITR3))! N6 O/ G0 m( e' c+ A2 Q
. p$ Q& r/ B, f. s! L- a7 Y: yTIM_TIx_External_Clock_Source
% o. p* C# M- h+ m' U2 L' J8 e9 s @* t
/ P* d3 S& U7 L; `: G- /** @defgroup TIM_TIx_External_Clock_Source / `4 y1 N# e. `5 ~$ y
- * @{$ f& J8 s- h5 [' f1 w0 t% B8 j
$ c% Z- Q: G3 {7 u' M* ` - 8 |! D) i; u* o* @8 \5 c
- #define TIM_TIxExternalCLK1Source_TI1 ((uint16_t)0x0050)/ d* q( j( _$ S; Q0 x' I! a
- #define TIM_TIxExternalCLK1Source_TI2 ((uint16_t)0x0060)+ _" I1 ^6 `1 k* }
- #define TIM_TIxExternalCLK1Source_TI1ED ((uint16_t)0x0040)
# ]! Z4 _9 E) \* GTIM_External_Trigger_Polarity
6 h J1 q/ o6 m6 y$ L* U- d6 @+ T7 d) I
- /** @defgroup TIM_External_Trigger_Polarity
4 f4 {- e5 ]+ V - * @{
) i. V4 a$ T" v% r6 y' n2 x - */ 9 Z; n. U& v2 l7 ^% F' V
- #define TIM_ExtTRGPolarity_Inverted ((uint16_t)0x8000)* \( y J7 Z( g& Y
- #define TIM_ExtTRGPolarity_NonInverted ((uint16_t)0x0000)
6 d& |4 M: D+ [/ M `- c( P% Y' } - #define IS_TIM_EXT_POLARITY(POLARITY) (((POLARITY) == TIM_ExtTRGPolarity_Inverted) || \3 |, X2 [" n( H% N# Z% f/ r
- ((POLARITY) == TIM_ExtTRGPolarity_NonInverted))
$ W2 q' B4 ~, s+ O& O% QTIM_Prescaler_Reload_Mode! P7 N: l( q, d2 }
2 D2 e4 I0 i1 L) a! {
- /** @defgroup TIM_Prescaler_Reload_Mode
" r# Y% |/ j: z0 y1 H' o; ^3 Z - * @{8 o+ E: d# l0 {: H0 f6 Z
- */ W1 O+ p# O3 z% {( f) X' h: M; v
- : i2 g" `5 T7 M, V" i
- #define TIM_PSCReloadMode_Update ((uint16_t)0x0000)1 w9 j: X. |% a; P0 I8 d5 o. H
- #define TIM_PSCReloadMode_Immediate ((uint16_t)0x0001) N" E& r: Y! Y" O
- #define IS_TIM_PRESCALER_RELOAD(RELOAD) (((RELOAD) == TIM_PSCReloadMode_Update) || \: \. F. F0 f+ Y. i5 I
- ((RELOAD) == TIM_PSCReloadMode_Immediate))
M" b+ K. t7 B8 gTIM_Forced_Action# H* I$ f( |3 w, B( W
7 i3 L, q& Z0 ]
- /** @defgroup TIM_Forced_Action
. C! ?5 G: C6 t3 s8 P - * @{( g+ Q" ]! {8 g2 j0 R
% n2 C0 r' _9 @1 N
' l5 |% k/ E4 K. S1 [0 g- #define TIM_ForcedAction_Active ((uint16_t)0x0050)
3 [5 t9 T5 w1 G# G& W4 w5 h - #define TIM_ForcedAction_InActive ((uint16_t)0x0040)
6 ]3 @$ c k7 ^! S0 S W9 S x3 t9 l - #define IS_TIM_FORCED_ACTION(ACTION) (((ACTION) == TIM_ForcedAction_Active) || \- P+ y" J9 n8 c! |9 ?
- ((ACTION) == TIM_ForcedAction_InActive))
复制代码 & a2 G4 c j$ Y x) m% g
TIM_Encoder_Mode' V% k/ l* H2 J* ^
: B! I- `+ H7 Q
- /** @defgroup TIM_Encoder_Mode
0 \' M- Q8 o _8 \ - * @{& S% d. f% q" Z3 V/ F1 w7 j
' c9 w4 g9 P2 `
* z3 Q* B1 D$ o- #define TIM_EncoderMode_TI1 ((uint16_t)0x0001)' b- w2 @2 g& t* X
- #define TIM_EncoderMode_TI2 ((uint16_t)0x0002)
/ T, C0 ~6 I4 A# \ - #define TIM_EncoderMode_TI12 ((uint16_t)0x0003)8 W2 m1 }1 w, A5 L8 P
- #define IS_TIM_ENCODER_MODE(MODE) (((MODE) == TIM_EncoderMode_TI1) || \% @! X! `/ W8 f
- ((MODE) == TIM_EncoderMode_TI2) || \) l) j( c4 d% f9 N. E. x
- ((MODE) == TIM_EncoderMode_TI12))
复制代码 , I8 f" D, d" l, ]
TIM_Event_Source
! L, B( }6 u# c+ e& a+ ]) g7 T4 a4 }& B
- /** @defgroup TIM_Event_Source 2 ^1 W8 G5 r" ]0 s% u
- * @{5 r, K0 |4 X" i) }6 Q5 A3 _
) m1 [8 q' l1 z
s( s! {& t" u6 c3 T- #define TIM_EventSource_Update ((uint16_t)0x0001)
9 Q) R& J- n0 q: ?( @ ~ - #define TIM_EventSource_CC1 ((uint16_t)0x0002)
( n! w( }& v9 U! b8 i+ J7 i+ r - #define TIM_EventSource_CC2 ((uint16_t)0x0004)- V. u: V% Y/ K- f5 X
- #define TIM_EventSource_CC3 ((uint16_t)0x0008)4 U% V6 Y2 M8 i& A; B; d
- #define TIM_EventSource_CC4 ((uint16_t)0x0010)
# U5 |! C1 a4 O" M N* d - #define TIM_EventSource_COM ((uint16_t)0x0020)1 ?: b* O/ n! J6 m% i. q1 w. l# x
- #define TIM_EventSource_Trigger ((uint16_t)0x0040)- P! Q/ I& S! E( X, Z6 G
- #define TIM_EventSource_Break ((uint16_t)0x0080)
- V7 T: H _7 a: g) F - #define IS_TIM_EVENT_SOURCE(SOURCE) ((((SOURCE) & (uint16_t)0xFF00) == 0x0000) && ((SOURCE) != 0x0000))
0 i* W4 q4 V0 f! |/ _TIM_Update_Source @+ z, N1 [1 ~
; I) b% ]$ [; t: J, a% @3 \9 C' ?
- /** @defgroup TIM_Update_Source 0 ]' b. B5 w0 O7 o+ P
- * @{4 Q- |% P. H4 w# P0 k# l" a4 x
+ N( C* j* A6 U! U. j' [
* Q% o4 U3 p. X4 [ \, ~5 N% r- #define TIM_UpdateSource_Global ((uint16_t)0x0000) /*!< Source of update is the counter overflow/underflow( k+ o* j# Z2 \5 T: C
- or the setting of UG bit, or an update generation: z7 g3 a+ v8 i& M8 P$ J. d. L1 ~
- through the slave mode controller. */
9 @2 {% A$ g# j) R - #define TIM_UpdateSource_Regular ((uint16_t)0x0001) /*!< Source of update is counter overflow/underflow. */# X' |7 o8 C3 g4 ]; n
- #define IS_TIM_UPDATE_SOURCE(SOURCE) (((SOURCE) == TIM_UpdateSource_Global) || \2 k: N! _$ j0 A$ a
- ((SOURCE) == TIM_UpdateSource_Regular))
复制代码 ! r4 D" C% \9 g, x' v# c" t8 n6 y
TIM_Output_Compare_Preload_State
' y4 m1 N% C# V7 } g. ^& x3 K, M1 n5 _% X: A: Z, f- E% L& `
- /** @defgroup TIM_Output_Compare_Preload_State
3 ~3 Q( W2 k( V# }5 o6 N - * @{
( v% u3 P9 ], `7 X, ~" n+ _ - */, ~/ Z, H. d) ?5 A M$ B
$ o$ \) f- t/ N( m( y. u4 v- #define TIM_OCPreload_Enable ((uint16_t)0x0008)' g" B4 e3 x4 o+ I1 ^8 s: ~1 F9 S9 H. {3 L
- #define TIM_OCPreload_Disable ((uint16_t)0x0000)" m2 e3 U0 W4 [
- #define IS_TIM_OCPRELOAD_STATE(STATE) (((STATE) == TIM_OCPreload_Enable) || \ Y: S! F. m1 [5 p5 M& W0 h8 W
- ((STATE) == TIM_OCPreload_Disable))
复制代码 ; h( b7 \( `# L S) u& O
TIM_Output_Compare_Fast_State- /** @defgroup TIM_Output_Compare_Fast_State : D; H5 o2 ^2 `! T
- * @{1 Z- P7 y3 R; c
1 f, I& c2 U9 ?8 m& O; [% X- z1 h
/ [% M2 L. P8 \5 N+ z+ k- #define TIM_OCFast_Enable ((uint16_t)0x0004)0 S9 A0 W1 ]: v P
- #define TIM_OCFast_Disable ((uint16_t)0x0000)
, `9 r) ] a0 D/ G6 c: H - #define IS_TIM_OCFAST_STATE(STATE) (((STATE) == TIM_OCFast_Enable) || \
! y: G* |5 I9 A2 @* r) l9 g- m( X - ((STATE) == TIM_OCFast_Disable))
复制代码 - J9 R7 m7 K0 {* A: l* w
TIM_Output_Compare_Clear_State- /** @defgroup TIM_Output_Compare_Clear_State ; ~3 e t1 Y9 r6 f
! s+ g9 w- U: r2 ^/ `+ y - */
' G1 Z) S4 Z$ l8 z/ d8 [% |
1 U' B' w/ J3 ^7 G- #define TIM_OCClear_Enable ((uint16_t)0x0080)
- Q E+ C: @& u" K" N* y# f9 Z% q* u - #define TIM_OCClear_Disable ((uint16_t)0x0000)
, n8 f7 |9 y4 e% Y/ a @' {+ Y - #define IS_TIM_OCCLEAR_STATE(STATE) (((STATE) == TIM_OCClear_Enable) || \8 j* b- R3 h4 X( \3 i* v2 x
- ((STATE) == TIM_OCClear_Disable))
复制代码 8 F% _" h4 q3 m$ m/ J/ P- j- |+ d3 d
TIM_Trigger_Output_Source
0 s3 X' ]9 o1 q
$ a& g: i1 _' @* s$ U- /** @defgroup TIM_Trigger_Output_Source ; X3 B; z2 M0 P
- * @{' G* H2 v' `0 ?$ I
; E/ u6 ~; \# v$ {& E$ f - n- W% C* t7 L' Y* Z8 g
- #define TIM_TRGOSource_Reset ((uint16_t)0x0000)( C+ \) t6 T* @' J( s ^' e% d
- #define TIM_TRGOSource_Enable ((uint16_t)0x0010): \. }6 v$ [0 @8 w0 @0 M7 b9 a
- #define TIM_TRGOSource_Update ((uint16_t)0x0020)
3 l/ b2 D8 c( D# r. I9 L - #define TIM_TRGOSource_OC1 ((uint16_t)0x0030); X: F; q1 d6 R# p
- #define TIM_TRGOSource_OC1Ref ((uint16_t)0x0040)
- e. |' Q& t) q( M - #define TIM_TRGOSource_OC2Ref ((uint16_t)0x0050)
9 B' q1 r- Y4 K1 t3 E& `7 q - #define TIM_TRGOSource_OC3Ref ((uint16_t)0x0060)2 O/ K3 F( X$ t4 t/ l& J
- #define TIM_TRGOSource_OC4Ref ((uint16_t)0x0070): [/ O0 h F# |5 v
- #define IS_TIM_TRGO_SOURCE(SOURCE) (((SOURCE) == TIM_TRGOSource_Reset) || \+ S, B( [0 E/ E: s) n
- ((SOURCE) == TIM_TRGOSource_Enable) || \
$ e- L( v9 M# J - ((SOURCE) == TIM_TRGOSource_Update) || \
: {5 S; @! s+ F+ G - ((SOURCE) == TIM_TRGOSource_OC1) || \
! \0 `3 W0 w2 g - ((SOURCE) == TIM_TRGOSource_OC1Ref) || \+ m! P8 k5 E5 u) W
- ((SOURCE) == TIM_TRGOSource_OC2Ref) || \
: I: I3 g1 P" ?, A+ i4 V - ((SOURCE) == TIM_TRGOSource_OC3Ref) || \
0 I, o& H0 e# p2 D6 J* f - ((SOURCE) == TIM_TRGOSource_OC4Ref))
% q8 h% W3 v! J1 [2 Z% l/ g: |TIM_Slave_Mode- Q3 |" C* A1 u) v" G
- l6 v) ^- h& v0 y& G" m
- /** @defgroup TIM_Slave_Mode
/ k5 ~* A8 h. F/ j& {- | - * @{
# f t7 ]0 \! r1 K; n - */$ J, E2 ]/ g9 n( P
* f8 Z. X9 {$ q0 J- #define TIM_SlaveMode_Reset ((uint16_t)0x0004)
0 y$ h5 `" {5 W6 }( _2 R3 i - #define TIM_SlaveMode_Gated ((uint16_t)0x0005), X1 T9 }" Y8 l" b* g
- #define TIM_SlaveMode_Trigger ((uint16_t)0x0006)7 [0 D9 |6 K3 c* d
- #define TIM_SlaveMode_External1 ((uint16_t)0x0007); f7 t5 a3 s5 \. J5 d" W# L1 ]
- #define IS_TIM_SLAVE_MODE(MODE) (((MODE) == TIM_SlaveMode_Reset) || \
7 |7 O& }' Q- t' @2 O( R, {6 W - ((MODE) == TIM_SlaveMode_Gated) || \
3 J+ P& U1 l1 ~2 J B - ((MODE) == TIM_SlaveMode_Trigger) || \9 k7 T! H# I9 E% ~9 T3 z" v' r. e
- ((MODE) == TIM_SlaveMode_External1))
6 F7 G1 X- _" u. L+ ~
( l8 {7 J( K7 K$ n& {TIM_Master_Slave_Mode- /** @defgroup TIM_Master_Slave_Mode % A+ L2 ~4 L+ L* _7 T$ O6 x2 w
- ?% o. I( ]2 v* c7 z& R - */" q9 w% K! S4 q! l
- * }8 d+ |! ~$ N6 |
- #define TIM_MasterSlaveMode_Enable ((uint16_t)0x0080)
! D2 z6 ]: {3 C% O8 R - #define TIM_MasterSlaveMode_Disable ((uint16_t)0x0000)
8 O( M3 _8 E& s9 k7 M/ d) V$ r - #define IS_TIM_MSM_STATE(STATE) (((STATE) == TIM_MasterSlaveMode_Enable) || \- @% e' |6 ?/ `% c V+ v7 }; v
- ((STATE) == TIM_MasterSlaveMode_Disable)) p. m8 ]" D# [0 `4 ]3 L$ j
% P6 \) x9 O: W0 N# \2 e; Z% aTIM_Remap
% b, v- b4 T0 K" n' o2 g4 \6 h% n; [8 J! a m, A
- /** @defgroup TIM_Remap
. H: R$ Q3 C0 l* y - * @{
1 ?, s8 Y# G: E2 Y& F9 S+ } - */3 E$ ]+ I3 }7 N; i
( M3 \4 {4 b. j- #define TIM2_TIM8_TRGO ((uint16_t)0x0000)+ a1 c. l& x0 i) a6 m5 Y
- #define TIM2_ETH_PTP ((uint16_t)0x0400)/ u2 \# k( }0 X- o9 _& }! _
- #define TIM2_USBFS_SOF ((uint16_t)0x0800)
; z9 N" y6 \6 L9 c3 c. y - #define TIM2_USBHS_SOF ((uint16_t)0x0C00)
% X9 G( R: w2 N# ?) ^7 S f3 ] - 7 i# H* V$ j8 t6 N" `: C
- #define TIM5_GPIO ((uint16_t)0x0000)
9 q/ t1 R: |7 A) u: P; w5 U# ` - #define TIM5_LSI ((uint16_t)0x0040)
6 I" X! ^9 S& a1 \; B - #define TIM5_LSE ((uint16_t)0x0080) v7 E6 `# y5 ^6 A2 `
- #define TIM5_RTC ((uint16_t)0x00C0)5 T3 Q+ A2 t. n3 ?( `; O4 z. a
- - P% d. W; x6 I8 ]7 y. ]
- #define TIM11_GPIO ((uint16_t)0x0000)- _7 }1 O7 z, v2 V5 r4 w p
- #define TIM11_HSE ((uint16_t)0x0002)
$ Q9 Z. w- E# z. O3 s3 w# [0 T3 m - . W: G! l9 D5 \ ^: O0 e6 a" t; c
- #define IS_TIM_REMAP(TIM_REMAP) (((TIM_REMAP) == TIM2_TIM8_TRGO)||\
: s6 \& Y% a; g; G1 F - ((TIM_REMAP) == TIM2_ETH_PTP)||\
`9 h8 t/ H8 s" N - ((TIM_REMAP) == TIM2_USBFS_SOF)||\% h- L- R$ k# j2 v, d+ o& b0 m' \
- ((TIM_REMAP) == TIM2_USBHS_SOF)||\
* V0 j" F1 S7 m- k% m - ((TIM_REMAP) == TIM5_GPIO)||\
9 C M0 Q, g R$ J - ((TIM_REMAP) == TIM5_LSI)||\
7 \9 [3 _8 M$ M1 g- Y) i - ((TIM_REMAP) == TIM5_LSE)||\
0 K- i1 j7 k6 v, ~ - ((TIM_REMAP) == TIM5_RTC)||\
: m# K1 j- J! F - ((TIM_REMAP) == TIM11_GPIO)||\
# l& u6 L+ }3 `6 B0 P' n, L P: b - ((TIM_REMAP) == TIM11_HSE))
& F- C4 X/ g% ?6 t4 a* m
复制代码 * @' N% o, [5 w7 T2 d: _
TIM_Flags
; G& h `6 ]( y& p Y6 ?
5 I+ I F& Q- u1 b) b' ]* r. j- /** @defgroup TIM_Flags 9 i4 \) M! z6 V8 d2 I; V9 e
$ r! F0 n1 S' |, Q/ c - */4 o" N5 a( i8 y
- 7 \2 b' s% Z3 J) S5 d
- #define TIM_FLAG_Update ((uint16_t)0x0001)
; g$ v; |) }# s, H& n - #define TIM_FLAG_CC1 ((uint16_t)0x0002)
; b$ O, K" ~+ j$ u& ~( j+ \1 ~7 B - #define TIM_FLAG_CC2 ((uint16_t)0x0004)
" `5 F1 [: B7 T7 w9 J& ~ - #define TIM_FLAG_CC3 ((uint16_t)0x0008)
% i' J8 q2 f& O$ L8 N' V - #define TIM_FLAG_CC4 ((uint16_t)0x0010)2 @3 r6 Q, N" H4 o, A
- #define TIM_FLAG_COM ((uint16_t)0x0020)1 ~- D, n4 J S% m( [" u; X& [( V9 i
- #define TIM_FLAG_Trigger ((uint16_t)0x0040)
* N7 y. u; ~( q: z5 g2 W+ k - #define TIM_FLAG_Break ((uint16_t)0x0080)
9 _- E) {! N7 y! C, A( k6 I! g/ w - #define TIM_FLAG_CC1OF ((uint16_t)0x0200)5 |. M# l+ ~, J
- #define TIM_FLAG_CC2OF ((uint16_t)0x0400); o2 l) Q' n8 C5 G; s
- #define TIM_FLAG_CC3OF ((uint16_t)0x0800)
. u# d+ Y' C7 v% Z - #define TIM_FLAG_CC4OF ((uint16_t)0x1000)
9 `& l( j$ a$ n0 [0 L. [( `9 @. J - #define IS_TIM_GET_FLAG(FLAG) (((FLAG) == TIM_FLAG_Update) || \
- Z8 G. ~& Y6 Z* r! S5 F0 \+ { - ((FLAG) == TIM_FLAG_CC1) || \
$ I9 \6 i5 B! }, X - ((FLAG) == TIM_FLAG_CC2) || \
4 P+ e8 L4 n6 @ - ((FLAG) == TIM_FLAG_CC3) || \' H5 ~. ~5 F/ y. Q! J, A0 i
- ((FLAG) == TIM_FLAG_CC4) || \6 B0 _" X+ }; L( t
- ((FLAG) == TIM_FLAG_COM) || \
) g) b9 j/ f- h# k. Q - ((FLAG) == TIM_FLAG_Trigger) || \
( {% t+ a- n5 R* C5 B! n2 L: V( f- u - ((FLAG) == TIM_FLAG_Break) || \
3 E8 {* p" G( }" M+ }7 S - ((FLAG) == TIM_FLAG_CC1OF) || \$ \* V2 T. n$ P5 q" H0 [
- ((FLAG) == TIM_FLAG_CC2OF) || \, Y" a3 c2 E ]" c; R. H
- ((FLAG) == TIM_FLAG_CC3OF) || \/ J+ [9 F/ e! B+ k) n
- ((FLAG) == TIM_FLAG_CC4OF))
复制代码 + w! l9 ~: q9 H5 e. g0 l3 D
其它
1 s; u% e ~/ A3 f% t2 c- u
3 o+ C+ C: ]; H! a2 b6 S8 Y3 x- /** @defgroup TIM_Input_Capture_Filer_Value
0 {! l( G: u, u. t" [ - * @{8 t, G& W& H" V; ` V, Q% ]
# ^) a6 p2 O4 e* x/ n3 O2 N. { - # L3 @# @( O, x& q& _3 w9 {, N. w
- #define IS_TIM_IC_FILTER(ICFILTER) ((ICFILTER) <= 0xF)
$ \! E m1 p# I& M* q4 r D - /**
7 A% S) s' O& d$ S {; C - * @}
9 V% X6 X$ V/ M7 Q$ Q - */
1 g7 i+ y: {7 u; _
" y9 e, ^' j$ V& w- /** @defgroup TIM_External_Trigger_Filter
$ T4 V0 k" c- P4 P7 h+ k - * @{
6 w; b2 e$ ]8 S& [% H - */
5 F0 B/ X) h, \8 Z) D( _) k - ' b' i) _. O- X# b
- #define IS_TIM_EXT_FILTER(EXTFILTER) ((EXTFILTER) <= 0xF)/ q; t# R( V. a P! @ e" Z
3 h9 u; J) v* P - * @}
. d7 D$ C$ A$ K- e& r' E2 a - */
+ @9 J4 @6 j5 K ^: B1 t% x
r# K5 f; h; k6 {& l- /** @defgroup TIM_Legacy
6 M: g; b9 P! H C6 t4 `, R - * @{
4 m1 r1 [ j8 X- i - */
' t" h" s2 ~! w9 y: X - ; r$ z! v- j' y! c! s' Z5 A
- #define TIM_DMABurstLength_1Byte TIM_DMABurstLength_1Transfer8 M4 @2 d8 P k( j4 J- p
- #define TIM_DMABurstLength_2Bytes TIM_DMABurstLength_2Transfers# g( s" P* Z$ u
- #define TIM_DMABurstLength_3Bytes TIM_DMABurstLength_3Transfers
! [! i, ^- D; V7 b$ Z7 I - #define TIM_DMABurstLength_4Bytes TIM_DMABurstLength_4Transfers( T9 \/ b+ E8 X
- #define TIM_DMABurstLength_5Bytes TIM_DMABurstLength_5Transfers
/ j' b. A' `0 o4 }- S5 [ - #define TIM_DMABurstLength_6Bytes TIM_DMABurstLength_6Transfers
+ v$ Z5 W; c1 F p& {. \ - #define TIM_DMABurstLength_7Bytes TIM_DMABurstLength_7Transfers
7 m( ?& S( L; E9 B+ j1 Q - #define TIM_DMABurstLength_8Bytes TIM_DMABurstLength_8Transfers' G' A$ E3 k8 i4 O8 X7 E
- #define TIM_DMABurstLength_9Bytes TIM_DMABurstLength_9Transfers
' ?! I8 K1 w$ k) R" ~/ O - #define TIM_DMABurstLength_10Bytes TIM_DMABurstLength_10Transfers
; Z( r& z3 K* L" v0 j - #define TIM_DMABurstLength_11Bytes TIM_DMABurstLength_11Transfers
0 h. c% S7 K1 z# Q8 R! ~ - #define TIM_DMABurstLength_12Bytes TIM_DMABurstLength_12Transfers( B+ H0 I) w* N% ~5 h$ U! N4 c7 d8 M
- #define TIM_DMABurstLength_13Bytes TIM_DMABurstLength_13Transfers
/ [6 P/ S+ i0 \6 @3 X0 H - #define TIM_DMABurstLength_14Bytes TIM_DMABurstLength_14Transfers# n+ \& |( K' t1 `
- #define TIM_DMABurstLength_15Bytes TIM_DMABurstLength_15Transfers
6 X3 l: T& T4 Y3 A3 Z. t* W5 A- O - #define TIM_DMABurstLength_16Bytes TIM_DMABurstLength_16Transfers$ |( T- _; z, F4 J. r; v0 X! {
- #define TIM_DMABurstLength_17Bytes TIM_DMABurstLength_17Transfers" q# I( J8 o! M7 V: _; d
- #define TIM_DMABurstLength_18Bytes TIM_DMABurstLength_18Transfers
+ J1 l" I0 ?( u0 j& q( _03. 相关函数9 _6 X9 ^& l* E0 U
- /* TimeBase management ********************************************************/# N x- I6 R: V3 w; z
- void TIM_DeInit(TIM_TypeDef* TIMx);/ e* P- E9 R F3 w0 Z
- void TIM_TimeBaseInit(TIM_TypeDef* TIMx, TIM_TimeBaseInitTypeDef* TIM_TimeBaseInitStruct);7 X# j4 C/ W) @: Q
- void TIM_TimeBaseStructInit(TIM_TimeBaseInitTypeDef* TIM_TimeBaseInitStruct);$ n+ r3 k/ q9 s( n" [
- void TIM_PrescalerConfig(TIM_TypeDef* TIMx, uint16_t Prescaler, uint16_t TIM_PSCReloadMode);/ V$ c0 L+ Q Y+ }9 E
- void TIM_CounterModeConfig(TIM_TypeDef* TIMx, uint16_t TIM_CounterMode);
- J! q( _$ e/ B, `7 h - void TIM_SetCounter(TIM_TypeDef* TIMx, uint32_t Counter);
% \3 S0 F. s) `2 G- O - void TIM_SetAutoreload(TIM_TypeDef* TIMx, uint32_t Autoreload);- p: q' r# `; ~& u
- uint32_t TIM_GetCounter(TIM_TypeDef* TIMx);7 N' D! i* G# _4 A6 q7 R) |1 ^3 t
- uint16_t TIM_GetPrescaler(TIM_TypeDef* TIMx);# t: E* F7 a7 U" {& u
- void TIM_UpdateDisableConfig(TIM_TypeDef* TIMx, FunctionalState NewState);8 p! N# y% ]8 M2 |0 R& P5 {1 R* U
- void TIM_UpdateRequestConfig(TIM_TypeDef* TIMx, uint16_t TIM_UpdateSource);% s2 P, O4 d7 Q. J
- void TIM_ARRPreloadConfig(TIM_TypeDef* TIMx, FunctionalState NewState);
5 x* {* T2 L# ~2 z0 Z7 L- ?+ M$ w/ P - void TIM_SelectOnePulseMode(TIM_TypeDef* TIMx, uint16_t TIM_OPMode);/ i: t; C8 U% W3 U6 Y6 F* l
- void TIM_SetClockDivision(TIM_TypeDef* TIMx, uint16_t TIM_CKD);" _6 y' E8 E9 K: ]7 ^) z# u7 _
- void TIM_Cmd(TIM_TypeDef* TIMx, FunctionalState NewState);- w6 a U+ Z$ H
- ! D2 q: X3 U8 x. B
- /* Output Compare management **************************************************/3 k; T. R9 \' k9 J/ O* M
- void TIM_OC1Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
- h9 W6 n, ^. g2 V - void TIM_OC2Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);( \; ~. Z/ }& Z7 J! o) h* Y V
- void TIM_OC3Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
+ M+ n2 g9 H) |1 d+ s - void TIM_OC4Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
3 ^ w: k2 q$ w - void TIM_OCStructInit(TIM_OCInitTypeDef* TIM_OCInitStruct);* Z. S) C: o8 \0 s! b
- void TIM_SelectOCxM(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_OCMode);6 Y8 T6 t6 j1 A$ ~, Q8 C) k
- void TIM_SetCompare1(TIM_TypeDef* TIMx, uint32_t Compare1);/ T$ ~) a! R* [9 P T" ?- E3 n; v( P
- void TIM_SetCompare2(TIM_TypeDef* TIMx, uint32_t Compare2);
& ?9 k R/ {- }2 V, n6 j - void TIM_SetCompare3(TIM_TypeDef* TIMx, uint32_t Compare3);) _4 E5 k7 [: e0 l. a
- void TIM_SetCompare4(TIM_TypeDef* TIMx, uint32_t Compare4);
1 v, z; W0 R+ g, Z - void TIM_ForcedOC1Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);2 u- e: I, M' L2 C; i0 D& c. ^
- void TIM_ForcedOC2Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
( B' r% P; L' f6 c6 E - void TIM_ForcedOC3Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
! N# Q) x, H% M8 H5 { - void TIM_ForcedOC4Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);; M" P P& s! j( D0 ?- A5 g% P3 H; E
- void TIM_OC1PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);; x: _& T0 N; c u; C2 R; k
- void TIM_OC2PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);
* P8 |3 g: L% l4 K4 z - void TIM_OC3PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);* K- U7 w4 D# Y' Y
- void TIM_OC4PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);; a8 p: j q1 g7 K0 u- L2 p
- void TIM_OC1FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);& H4 S& O8 t+ F. z+ I% r
- void TIM_OC2FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);& X0 Q7 u! }% |4 T& [
- void TIM_OC3FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);
, i- L5 U* |5 C9 d - void TIM_OC4FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);% g& X7 C$ }1 } b. o+ R2 K' f
- void TIM_ClearOC1Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);+ K! x6 Z- q0 V4 E
- void TIM_ClearOC2Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
& Z" _' _& ]" h - void TIM_ClearOC3Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
, ?! n1 d/ i1 C+ j2 @ - void TIM_ClearOC4Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);% \/ `1 F0 } p
- void TIM_OC1PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);
, P# @4 ?6 }4 K1 Z3 { - void TIM_OC1NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);
5 {8 P, w. o y- z - void TIM_OC2PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);0 E4 a, k+ C3 x9 I8 m& n& z
- void TIM_OC2NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);
# W5 J: A. e" a6 D' U$ N - void TIM_OC3PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);
6 I/ W, }# j9 u6 N - void TIM_OC3NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);: T$ d7 I. p1 L' l' O: ^6 u
- void TIM_OC4PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);7 {( h7 c7 |* `( \
- void TIM_CCxCmd(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_CCx);
& z; J9 B. V' ^5 m% w1 o* i" | - void TIM_CCxNCmd(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_CCxN);
3 l( J, B4 _) W8 u
0 n# b7 A: }" b: m- Q! Z- /* Input Capture management ***************************************************/4 N% c" c9 w; F% _2 n& Y- S, M9 _
- void TIM_ICInit(TIM_TypeDef* TIMx, TIM_ICInitTypeDef* TIM_ICInitStruct);# {9 e0 t" t; s2 J' b6 `: e
- void TIM_ICStructInit(TIM_ICInitTypeDef* TIM_ICInitStruct);5 ?. U- O2 w; r
- void TIM_PWMIConfig(TIM_TypeDef* TIMx, TIM_ICInitTypeDef* TIM_ICInitStruct);
! K) W, i0 h' b0 q- A - uint32_t TIM_GetCapture1(TIM_TypeDef* TIMx);
7 _3 d- ~1 ~: w; d: o M - uint32_t TIM_GetCapture2(TIM_TypeDef* TIMx);! n6 \; K# p ~/ d/ m! W/ k
- uint32_t TIM_GetCapture3(TIM_TypeDef* TIMx);
, P/ s! j# `1 o* \; @ - uint32_t TIM_GetCapture4(TIM_TypeDef* TIMx);+ J$ V8 a% |- T5 ^
- void TIM_SetIC1Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);7 W! K- b7 i- P
- void TIM_SetIC2Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);
$ W2 y9 v/ |0 c- ], V - void TIM_SetIC3Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);
8 x4 d7 N; I* u- b& Q* L' y - void TIM_SetIC4Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);1 f$ O$ b( @7 p+ z
- 0 c5 l% e; a+ c1 P+ v6 u
- /* Advanced-control timers (TIM1 and TIM8) specific features ******************/) m1 m7 I& o2 u V1 c0 ]8 S3 o
- void TIM_BDTRConfig(TIM_TypeDef* TIMx, TIM_BDTRInitTypeDef *TIM_BDTRInitStruct);
8 f8 X+ }. [' z - void TIM_BDTRStructInit(TIM_BDTRInitTypeDef* TIM_BDTRInitStruct);
1 R) i) g( H$ g1 C - void TIM_CtrlPWMOutputs(TIM_TypeDef* TIMx, FunctionalState NewState);
: @& m) L) D# @* p0 u. M - void TIM_SelectCOM(TIM_TypeDef* TIMx, FunctionalState NewState);
0 O9 U' q+ Z& k - void TIM_CCPreloadControl(TIM_TypeDef* TIMx, FunctionalState NewState);
6 E- B1 [% M7 R C - : h/ M# J7 R& U) p4 y: F* n# x* b
- /* Interrupts, DMA and flags management ***************************************/) Z2 E4 e8 X2 j: U
- void TIM_ITConfig(TIM_TypeDef* TIMx, uint16_t TIM_IT, FunctionalState NewState);6 ~8 _( ?" M6 S" s: G& T7 v3 z: T
- void TIM_GenerateEvent(TIM_TypeDef* TIMx, uint16_t TIM_EventSource);
4 M' n l( W* O8 D- I - FlagStatus TIM_GetFlagStatus(TIM_TypeDef* TIMx, uint16_t TIM_FLAG);4 o$ n! o! X$ @* x+ P# J
- void TIM_ClearFlag(TIM_TypeDef* TIMx, uint16_t TIM_FLAG);
k b9 v+ S4 [; g3 e3 H - ITStatus TIM_GetITStatus(TIM_TypeDef* TIMx, uint16_t TIM_IT);) ?+ d! N3 c+ q( a+ {
- void TIM_ClearITPendingBit(TIM_TypeDef* TIMx, uint16_t TIM_IT);
; \7 R9 Q6 [0 W% Q - void TIM_DMAConfig(TIM_TypeDef* TIMx, uint16_t TIM_DMABase, uint16_t TIM_DMABurstLength);
C, y1 g4 ]0 Y8 \* R& d5 \+ K - void TIM_DMACmd(TIM_TypeDef* TIMx, uint16_t TIM_DMASource, FunctionalState NewState);1 J4 s8 D3 V- N% u3 d
- void TIM_SelectCCDMA(TIM_TypeDef* TIMx, FunctionalState NewState);# y g" k; A- Y- |) E
- W7 ^7 y7 q, J! D: v2 l
- /* Clocks management **********************************************************/' g4 V: G1 {" ]2 |7 I, y. Y6 K0 h
- void TIM_InternalClockConfig(TIM_TypeDef* TIMx);/ o2 x+ [+ L# L# E: y% x
- void TIM_ITRxExternalClockConfig(TIM_TypeDef* TIMx, uint16_t TIM_InputTriggerSource);2 P# ]- q2 }# W
- void TIM_TIxExternalClockConfig(TIM_TypeDef* TIMx, uint16_t TIM_TIxExternalCLKSource,4 i0 e9 n" R( D
- uint16_t TIM_ICPolarity, uint16_t ICFilter);$ N) f* i! q* q+ i
- void TIM_ETRClockMode1Config(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, uint16_t TIM_ExtTRGPolarity,
- L3 P: T G1 U t/ o u- B - uint16_t ExtTRGFilter);
* w) V( H9 Q$ c6 p$ E$ p% r - void TIM_ETRClockMode2Config(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, - }# l2 v1 _* ]8 H7 a. Z
- uint16_t TIM_ExtTRGPolarity, uint16_t ExtTRGFilter);, j9 E( {3 r4 J8 _% k) n
- % D" C& J6 S8 {. C# T2 G* ^
- /* Synchronization management *************************************************/
. Y) a! W/ V% ?( z9 H - void TIM_SelectInputTrigger(TIM_TypeDef* TIMx, uint16_t TIM_InputTriggerSource);
6 H; Y/ t5 [" R, y - void TIM_SelectOutputTrigger(TIM_TypeDef* TIMx, uint16_t TIM_TRGOSource);
+ v9 |1 j+ j2 A/ D. f9 r8 p - void TIM_SelectSlaveMode(TIM_TypeDef* TIMx, uint16_t TIM_SlaveMode);
% N6 t! `; k, e- S& o - void TIM_SelectMasterSlaveMode(TIM_TypeDef* TIMx, uint16_t TIM_MasterSlaveMode); S- ?! s) N3 }. d4 v2 j) p
- void TIM_ETRConfig(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, uint16_t TIM_ExtTRGPolarity,. w1 ~5 ~& d- K
- uint16_t ExtTRGFilter);" |3 y/ b2 O# B2 {! H6 k
- : u7 j/ S- e& ^+ ~ @% q& v1 \' G. [
- /* Specific interface management **********************************************/ 2 [! n6 j1 p0 J, t! a7 k
- void TIM_EncoderInterfaceConfig(TIM_TypeDef* TIMx, uint16_t TIM_EncoderMode,
! I' O6 d4 l c: `" L9 l3 N - uint16_t TIM_IC1Polarity, uint16_t TIM_IC2Polarity);
$ I8 ? `/ |* h. t; }# f - void TIM_SelectHallSensor(TIM_TypeDef* TIMx, FunctionalState NewState);
( _+ l+ v! C% G* _, m# b
9 b1 n) F; L6 {! a9 z- /* Specific remapping management **********************************************/+ E- l4 q: M/ c) P* f# E+ s4 ~& T
- void TIM_RemapConfig(TIM_TypeDef* TIMx, uint16_t TIM_Remap); Y* G% k& b6 j$ J9 Q' s
复制代码 2 W) E; e! v0 j. ^: T
04. 结构体封装3 [+ @% Z8 p" I; T1 [: d' _' |
- /** ( t* O1 g8 K7 r( M
- * @brief TIM
$ D6 j' ]2 p( y& F0 t* I; H4 A& g - */
2 f% F) y4 _ T9 z$ K
8 f" k, l, {/ |0 _2 N7 I( n/ p- typedef struct# d# _2 J- g; [. S1 `
- {7 X' ]9 u! d$ d p0 O& |' w
- __IO uint16_t CR1; /*!< TIM control register 1, Address offset: 0x00 */+ Q3 M0 A; b% E: K/ H4 H+ i
- uint16_t RESERVED0; /*!< Reserved, 0x02 */' C* Z9 [4 @7 G q
- __IO uint16_t CR2; /*!< TIM control register 2, Address offset: 0x04 */0 ?& Q; k! ?! k- X, d) [
- uint16_t RESERVED1; /*!< Reserved, 0x06 */5 G' V8 \" ~0 J* F6 C
- __IO uint16_t SMCR; /*!< TIM slave mode control register, Address offset: 0x08 */
- u3 \+ Q* x1 L: |$ S! r; f - uint16_t RESERVED2; /*!< Reserved, 0x0A */) m" I; [( D" \3 p+ }
- __IO uint16_t DIER; /*!< TIM DMA/interrupt enable register, Address offset: 0x0C */
g2 D% D/ C, d% } - uint16_t RESERVED3; /*!< Reserved, 0x0E */
V4 R; F" ~/ f$ m - __IO uint16_t SR; /*!< TIM status register, Address offset: 0x10 */' |, P7 F8 R4 }
- uint16_t RESERVED4; /*!< Reserved, 0x12 */
" z$ n# P! k. m5 F2 Z( H - __IO uint16_t EGR; /*!< TIM event generation register, Address offset: 0x14 */3 r" E/ k& r! c+ u
- uint16_t RESERVED5; /*!< Reserved, 0x16 */5 @7 a3 h9 ~* o0 ^) j# c
- __IO uint16_t CCMR1; /*!< TIM capture/compare mode register 1, Address offset: 0x18 */
1 m6 o' ^5 G# g" P0 e$ S - uint16_t RESERVED6; /*!< Reserved, 0x1A */
) y! A% B- ?- J% j - __IO uint16_t CCMR2; /*!< TIM capture/compare mode register 2, Address offset: 0x1C */' H& S' v' V7 H" L( o, [; \$ R
- uint16_t RESERVED7; /*!< Reserved, 0x1E */
8 _! p2 m) O9 d6 s+ U$ ?, ~7 m - __IO uint16_t CCER; /*!< TIM capture/compare enable register, Address offset: 0x20 */# W& V7 T# R$ |/ ^+ F$ u
- uint16_t RESERVED8; /*!< Reserved, 0x22 */9 }7 J. G. g2 N
- __IO uint32_t CNT; /*!< TIM counter register, Address offset: 0x24 */
9 C! J* S* Z5 [( D4 ?6 e; u - __IO uint16_t PSC; /*!< TIM prescaler, Address offset: 0x28 */' x! \' u, b: }
- uint16_t RESERVED9; /*!< Reserved, 0x2A */( Z' O5 D+ ~! r: d
- __IO uint32_t ARR; /*!< TIM auto-reload register, Address offset: 0x2C */8 c0 o5 J! L. S4 F) R2 X7 A; L
- __IO uint16_t RCR; /*!< TIM repetition counter register, Address offset: 0x30 */
1 F/ ^$ K3 N5 x7 a - uint16_t RESERVED10; /*!< Reserved, 0x32 *// A4 }3 t- ^2 E: o
- __IO uint32_t CCR1; /*!< TIM capture/compare register 1, Address offset: 0x34 */4 ]- }4 P0 Q* w/ n/ R
- __IO uint32_t CCR2; /*!< TIM capture/compare register 2, Address offset: 0x38 */% A& ]! C: \% i0 m6 {1 A. L. w
- __IO uint32_t CCR3; /*!< TIM capture/compare register 3, Address offset: 0x3C */8 e' i2 c) ~0 Q
- __IO uint32_t CCR4; /*!< TIM capture/compare register 4, Address offset: 0x40 */
8 \5 p# O$ s. Q# [ - __IO uint16_t BDTR; /*!< TIM break and dead-time register, Address offset: 0x44 */- `, {) ]4 r& ?
- uint16_t RESERVED11; /*!< Reserved, 0x46 */
) V; H' H/ [! f3 U0 ^* T& g. r U - __IO uint16_t DCR; /*!< TIM DMA control register, Address offset: 0x48 */$ M# n: C/ R3 f4 e6 w
- uint16_t RESERVED12; /*!< Reserved, 0x4A */
) x/ T; Z. _! u+ D" F' s - __IO uint16_t DMAR; /*!< TIM DMA address for full transfer, Address offset: 0x4C */
6 {4 B9 V! K# T k6 O" e) `( ? - uint16_t RESERVED13; /*!< Reserved, 0x4E */
% o- E+ n+ s5 n5 [. C - __IO uint16_t OR; /*!< TIM option register, Address offset: 0x50 */
; t. O& x+ |: L - uint16_t RESERVED14; /*!< Reserved, 0x52 */
9 o U& P' y# t: [& e) U - } TIM_TypeDef;
* l# f/ M4 W. L! h d
4 ^9 S1 j9 _! q g5 X% i% ~' p
" q9 h/ @: ~7 n5 a |
