01. 概述
R6 E# f" v; H6 v中断相关代码主要分布在固件库的 stm32f4xx_exti.h 和 stm32f4xx_exti.c 文件中。
4 w% M u/ ~" Z: P
$ J. N* q5 ^9 j& N% i02. 相关类型
: o& ^" {1 F, G' n1 [EXTI模式枚举
; K! N' e, P, j( h2 j: ~- a+ m6 n; e0 ?9 I% j) o" F) y3 ]& ]
7 I7 |: y% H3 V7 l# Y
EXTI触发枚举' `/ v) P- q e* s. G7 K# Z
6 C. i: q( G: L7 M. f6 ]! o) a% t5 `; Z
0 @) F+ B+ h6 r" s# X* ~ - * @brief EXTI Trigger enumeration
, ?' N, z. |' t3 P/ [ - */
, V9 \6 O+ c& q$ k
3 Z% c7 ?/ A8 c6 H- typedef enum
: x- q7 e- C; J6 x# v- `! ~ - {
. h8 |" I! D/ p# V- E ~ - EXTI_Trigger_Rising = 0x08, //上升沿
6 P$ o% B8 ~" F! Y% n6 Y, K - EXTI_Trigger_Falling = 0x0C, //下降沿, J4 x/ o3 z/ z( J( |) D
- EXTI_Trigger_Rising_Falling = 0x10 //边沿触发) u" ^5 g* v7 e+ V, E5 W1 Y
- }EXTITrigger_TypeDef;/ ?& X2 l& Q, ^2 [
2 O$ Q# m4 `/ r' D- #define IS_EXTI_TRIGGER(TRIGGER) (((TRIGGER) == EXTI_Trigger_Rising) || \1 D+ Z$ `8 ~; O7 K; _" Z- K6 |. [ v
- ((TRIGGER) == EXTI_Trigger_Falling) || \
9 k- \5 R9 l+ E1 e+ I) a - ((TRIGGER) == EXTI_Trigger_Rising_Falling))$ _+ q0 D" k. n4 w6 G: w+ |: S! K
$ P+ X) C& ?7 I2 W1 GEXTI初始化结构体
* i* b- v+ T8 z- f) m5 h, @3 s9 Y: g- q" w7 V0 ?3 z
- /** 4 l& q6 {3 F2 P0 @
- * @brief EXTI Init Structure definition $ z( u9 O- v" f2 v
+ q, v$ @3 S( A/ O# \
4 K- T! L& e: |' X& D3 i) d3 k- typedef struct
4 z0 A' n5 A% D1 k7 ~( w$ y - {
0 \/ H# S4 N# L - uint32_t EXTI_Line; /*!< Specifies the EXTI lines to be enabled or disabled.
: r9 _8 G0 t3 A. W - This parameter can be any combination value of @ref EXTI_Lines */
9 m. b2 R; H+ J$ d( y$ r
7 [: |7 E5 J% l" ^( P* @: ?* M- EXTIMode_TypeDef EXTI_Mode; /*!< Specifies the mode for the EXTI lines.
+ O: w; b$ g" q. n - This parameter can be a value of @ref EXTIMode_TypeDef */
& p. n) R( m/ G: |3 ~
@0 \+ ^4 Q( \- G8 [- H- EXTITrigger_TypeDef EXTI_Trigger; /*!< Specifies the trigger signal active edge for the EXTI lines.
/ d% K1 B% x, E! M - This parameter can be a value of @ref EXTITrigger_TypeDef */
6 m/ h" f3 J a9 h, p$ k5 i - 8 J: t. @ z8 o2 K; \
- FunctionalState EXTI_LineCmd; /*!< Specifies the new state of the selected EXTI lines.7 V: r/ _$ {8 {4 S+ p2 l
- This parameter can be set either to ENABLE or DISABLE */
2 S1 u; k- o# E9 v' h9 [. W7 U - }EXTI_InitTypeDef;: p2 y9 d/ J% X
8 y$ z' }' a" h) U7 n+ U8 [# c外部中断线
- p, M Q9 w4 o2 A- S/ o/ t# @3 l: u3 y7 K1 I
- /** @defgroup EXTI_Lines
& r3 A2 d! g' w1 U" i - * @{$ o+ X8 S' s# ]3 ]3 `" Q# ~$ N4 |% u
- */# X& ?3 e5 k+ w, S; X- Q
- - z, y0 @+ P9 `. k( i( C7 _
- #define EXTI_Line0 ((uint32_t)0x00001) /*!< External interrupt line 0 */
- Q! D/ x$ E) e4 h+ H4 z! p - #define EXTI_Line1 ((uint32_t)0x00002) /*!< External interrupt line 1 */& D' }; w* _! d* J9 c7 y# j
- #define EXTI_Line2 ((uint32_t)0x00004) /*!< External interrupt line 2 */, A* W* _+ I2 k; @1 [ ~6 r
- #define EXTI_Line3 ((uint32_t)0x00008) /*!< External interrupt line 3 *// U6 k& [% u' b# x" d8 j
- #define EXTI_Line4 ((uint32_t)0x00010) /*!< External interrupt line 4 */5 D4 f& l0 p: O+ [& w1 g9 y
- #define EXTI_Line5 ((uint32_t)0x00020) /*!< External interrupt line 5 */
7 W4 ~. \, U+ K+ R, b4 |. v/ i5 a - #define EXTI_Line6 ((uint32_t)0x00040) /*!< External interrupt line 6 */
8 [) A/ D& r7 t; ]+ b2 Y# } - #define EXTI_Line7 ((uint32_t)0x00080) /*!< External interrupt line 7 */0 Q: I% s& m! y% n- f1 O
- #define EXTI_Line8 ((uint32_t)0x00100) /*!< External interrupt line 8 */
5 r. O$ d% v w. Z6 a" c# I - #define EXTI_Line9 ((uint32_t)0x00200) /*!< External interrupt line 9 */
- [8 C2 I2 F: `, o1 u T3 [" O - #define EXTI_Line10 ((uint32_t)0x00400) /*!< External interrupt line 10 */
; E' u1 S8 N. X) k - #define EXTI_Line11 ((uint32_t)0x00800) /*!< External interrupt line 11 */
|' E/ T+ Q: c- [ - #define EXTI_Line12 ((uint32_t)0x01000) /*!< External interrupt line 12 */
) ~! V3 R% _8 t - #define EXTI_Line13 ((uint32_t)0x02000) /*!< External interrupt line 13 */
' I8 e1 ?7 r6 q - #define EXTI_Line14 ((uint32_t)0x04000) /*!< External interrupt line 14 */
, X: @" X, I6 f- P+ U - #define EXTI_Line15 ((uint32_t)0x08000) /*!< External interrupt line 15 */
7 d! b X" G7 O9 J. R - #define EXTI_Line16 ((uint32_t)0x10000) /*!< External interrupt line 16 Connected to the
0 a. d5 e0 `, c4 F - PVD Output */; t3 W; C. I$ c- L: P
- #define EXTI_Line17 ((uint32_t)0x20000) /*!< External interrupt line 17 Connected to the; x5 Y% B6 _! J2 c
- RTC Alarm event */
2 h/ c6 s0 K# m2 l. l$ ? - #define EXTI_Line18 ((uint32_t)0x40000) /*!< External interrupt line 18 Connected to the
7 @7 ]6 i9 m. P1 @6 ? - USB OTG FS Wakeup from suspend event */
. L2 D; G0 N4 R5 L2 [' [# B - #define EXTI_Line19 ((uint32_t)0x80000) /*!< External interrupt line 19 Connected to the
7 k! F2 N' E0 n4 Q$ ? - Ethernet Wakeup event */+ A& K. B( w' j1 p5 P% h
- #define EXTI_Line20 ((uint32_t)0x00100000) /*!< External interrupt line 20 Connected to the
$ G3 {5 r& l! ~6 R" ] - USB OTG HS (configured in FS) Wakeup event */4 V/ R+ ^1 G# ^( _6 W- j# E) ]
- #define EXTI_Line21 ((uint32_t)0x00200000) /*!< External interrupt line 21 Connected to the ( D% c. z% N6 p1 M% x
- RTC Tamper and Time Stamp events */ ; S* n: Z8 {6 P: N7 y9 z0 t
- #define EXTI_Line22 ((uint32_t)0x00400000) /*!< External interrupt line 22 Connected to the' b0 R# x6 s1 K3 p4 [
- RTC Wakeup event */# W0 a, S. |/ ]
- #define EXTI_Line23 ((uint32_t)0x00800000) /*!< External interrupt line 23 Connected to the ' e, B* v7 ` V
- LPTIM Wakeup event */$ j2 z% |% h; J) a' h
) }! ?: s& {: U
0 C7 e. o3 ?* i( V6 K. a1 x) w- #define IS_EXTI_LINE(LINE) ((((LINE) & (uint32_t)0xFF800000) == 0x00) && ((LINE) != (uint16_t)0x00))
0 P& c, Q* m$ N- ^2 a
+ q. k9 {& @$ R9 w$ k7 t- #define IS_GET_EXTI_LINE(LINE) (((LINE) == EXTI_Line0) || ((LINE) == EXTI_Line1) || \
4 q* k: v8 o+ S4 F) _5 M - ((LINE) == EXTI_Line2) || ((LINE) == EXTI_Line3) || \
( }5 K. N! z; d. P0 J W& Y5 v - ((LINE) == EXTI_Line4) || ((LINE) == EXTI_Line5) || \
9 u) H4 S, o. O; \ [; a - ((LINE) == EXTI_Line6) || ((LINE) == EXTI_Line7) || \
" x; ~& G* F# D1 U& j) x" Q( U$ D - ((LINE) == EXTI_Line8) || ((LINE) == EXTI_Line9) || \+ E, }5 I" y/ y2 t0 L' \; Y6 X
- ((LINE) == EXTI_Line10) || ((LINE) == EXTI_Line11) || \
7 q8 e& C) q5 I% T - ((LINE) == EXTI_Line12) || ((LINE) == EXTI_Line13) || \
$ q3 E c* Y6 `' V* B O+ i6 s* d - ((LINE) == EXTI_Line14) || ((LINE) == EXTI_Line15) || \
+ v9 X, H5 W' b" T/ N* k& f - ((LINE) == EXTI_Line16) || ((LINE) == EXTI_Line17) || \
, M& N2 N2 I2 t* v6 Y3 [ - ((LINE) == EXTI_Line18) || ((LINE) == EXTI_Line19) || \
1 d" P7 L4 m$ B* t - ((LINE) == EXTI_Line20) || ((LINE) == EXTI_Line21) ||\" q1 A& c4 ~( ?- i! I+ a$ Q" r
- ((LINE) == EXTI_Line22) || ((LINE) == EXTI_Line23))
复制代码 5 q! \0 J' B8 C5 F2 ^
03. 相关函数$ @' y. T+ v9 A! e$ {0 C
5 W5 U: g4 O3 y9 N) o- ^3 ~- /* Exported macro ------------------------------------------------------------*/
7 i0 {) z/ j) r2 y# [+ ~" J - /* Exported functions --------------------------------------------------------*// {" W5 ]8 H- ?3 W0 X( p6 I
- ! q( W, y) F$ `0 W
- /* Function used to set the EXTI configuration to the default reset state *****/
5 o& P+ z2 ?( P! e2 M - void EXTI_DeInit(void);
+ F' @$ f& C& L9 }7 d2 @ - 0 X: {/ q3 C2 ~" {) e5 H* _
- /* Initialization and Configuration functions *********************************/
% `6 W' U9 \3 u8 u8 Q - void EXTI_Init(EXTI_InitTypeDef* EXTI_InitStruct);
5 ]& ^" h1 |; d - void EXTI_StructInit(EXTI_InitTypeDef* EXTI_InitStruct);! `2 D8 E V4 W. S
- void EXTI_GenerateSWInterrupt(uint32_t EXTI_Line);
5 x' e' H3 {: ^ - c; p+ c. L1 s3 _% k6 _
- /* Interrupts and flags management functions **********************************/# f7 m! ]6 d% e/ w
- FlagStatus EXTI_GetFlagStatus(uint32_t EXTI_Line);) N$ @ `, ^% v& r5 H+ P
- void EXTI_ClearFlag(uint32_t EXTI_Line);
, Q2 c+ j2 N2 v2 W4 w - ITStatus EXTI_GetITStatus(uint32_t EXTI_Line);, g2 t8 l! `! y' o9 h8 S
- void EXTI_ClearITPendingBit(uint32_t EXTI_Line);
! ?" ^) ?' o3 u& r
, r q% q3 L% M6 n
- [& r, B1 u2 |. w
( i. J& j! R% V/ \: A6 w |
