【经验分享】STM32 GPIO相关函数和类型
STMCU小助手 发布时间:2022-4-3 15:00
01. GPIO固件库概述& u4 K9 X& Y/ @8 G5 C& |
stm32f4xx_gpio.h GPIO相关函数和类型的声明% ?, ?7 @7 y$ i3 }4 M/ S
+ ^7 o( a" \% S- }stm32f4xx_gpio.c GPIO相关函数具体实现。3 ~8 E+ u6 n6 y  r( X" ~
+ k- y% s' x( @02. GPIO相关类型7 h: D$ b' g+ [- Z' W# L. V
GPIO相关的类型几乎都在stm32f4xx_gpio.h文件中。
5 I3 W4 c: X2 d9 }% I. d) F7 M" z
GPIO的模式  I1 K: O3 z% i( z4 l
8 l4 Y- l& ~4 Y/ n( E% H6 ^- |5 X! U
  1. /** 1 Z2 r) o$ R( E
  2.   * @brief  GPIO Configuration Mode enumeration 1 w% n2 S' H* y3 E$ z+ O; y
  3.   */
    % J* O5 G2 o3 E0 Z8 e; `% G
  4. typedef enum
    + U- U9 C2 o3 R7 `
  5. {
    5 @3 Q6 H5 \  R7 c7 K  M% y
  6.   GPIO_Mode_IN   = 0x00, /*!< GPIO Input Mode */
    8 T9 ~2 K0 l5 U& x# t
  7.   GPIO_Mode_OUT  = 0x01, /*!< GPIO Output Mode */( O& Q. @. f( ?6 E4 Z9 d( w4 V
  8.   GPIO_Mode_AF   = 0x02, /*!< GPIO Alternate function Mode */
    9 a' ]8 ?" G, w
  9.   GPIO_Mode_AN   = 0x03  /*!< GPIO Analog Mode */3 J( |6 c* h. m) a
  10. }GPIOMode_TypeDef;& `6 w4 ~0 ]- E1 L; K5 o
  11. #define IS_GPIO_MODE(MODE) (((MODE) == GPIO_Mode_IN)  || ((MODE) == GPIO_Mode_OUT) || \
    0 w7 f) h8 b' \- f: _) B
  12.                             ((MODE) == GPIO_Mode_AF)|| ((MODE) == GPIO_Mode_AN))
% f8 v+ Z: j: ?# Z( F, xGPIO输出类型
* C8 W* F8 S7 \/ t3 f
/ t" O& i3 K- Z
  1. /**
    8 W# k$ ]4 x: g5 T! p* w( }
  2.   * @brief  GPIO Output type enumeration
    9 s$ H0 t; C% u, ~$ n, V% U
  3.   */  5 |9 P: ]5 Z! b3 I9 ]/ K
  4. typedef enum( R, i8 U& ^* R8 S8 I6 z4 w
  5. { / ~2 z  |5 Q* u+ V# g( n' B5 g
  6.   GPIO_OType_PP = 0x00,
    7 A! C4 b0 W1 R5 |
  7.   GPIO_OType_OD = 0x01
    * e* x1 J; V# H4 D
  8. }GPIOOType_TypeDef;- g, B/ A; z- S0 N/ \: L+ \, L
  9. #define IS_GPIO_OTYPE(OTYPE) (((OTYPE) == GPIO_OType_PP) || ((OTYPE) == GPIO_OType_OD))
    : R) {! Z. T) }
( n8 g. R' j# b  a- e3 X8 G3 J
GPIO输出速度) o1 T( J5 x$ o
: I( ]8 n0 Q9 p* {3 J
  1. /** : r0 U& t3 g1 m' b6 i: u, [+ W" ^3 G! k
  2.   * @brief  GPIO Output Maximum frequency enumeration 3 x) r( W6 O9 P: o8 R
  3.   */
    ; H0 f: Q, @( Z4 D6 B+ [2 ~
  4. typedef enum
    % Z: K" w  t6 |; E1 Y
  5. {
    5 f0 w4 A: D& z( ^: J# g, l2 O
  6.   GPIO_Low_Speed     = 0x00, /*!< Low speed    */) t$ N4 B. L8 r7 w/ O& f) E$ `
  7.   GPIO_Medium_Speed  = 0x01, /*!< Medium speed */5 A; Z! n/ ~6 X( v  M- \
  8.   GPIO_Fast_Speed    = 0x02, /*!< Fast speed   */) i% @( }% D* x6 D- {/ A( d! [
  9.   GPIO_High_Speed    = 0x03  /*!< High speed   */
    9 k  ~% ]4 r& [2 q, l- k6 ^
  10. }GPIOSpeed_TypeDef;' x/ l- t$ Y# c9 N' M
  11. 7 J6 r7 M4 D; v2 I( L! m
  12. /* Add legacy definition */* Z/ h9 s( S' @6 F
  13. #define  GPIO_Speed_2MHz    GPIO_Low_Speed    : t' N, \5 E3 G" q3 C
  14. #define  GPIO_Speed_25MHz   GPIO_Medium_Speed 1 w$ R& [" L# }/ Y8 s* c: ^
  15. #define  GPIO_Speed_50MHz   GPIO_Fast_Speed
    1 d" N0 L- M; q6 t* K: N/ d
  16. #define  GPIO_Speed_100MHz  GPIO_High_Speed
    . m" p% |( g! M7 _; u, Y
  17. ! n  b9 D$ r& Q+ w
  18. #define IS_GPIO_SPEED(SPEED) (((SPEED) == GPIO_Low_Speed) || ((SPEED) == GPIO_Medium_Speed) || \
    ! L6 F' {6 i' ]3 K3 Q$ Z% F
  19.                               ((SPEED) == GPIO_Fast_Speed)||  ((SPEED) == GPIO_High_Speed))
4 n# w* i  \' \# GGPIO上下拉/ b8 m; P* n3 F# L+ n2 R- @
/ _9 j  x6 w. B: B8 K: P
  1. /**
    + U: p3 Q+ i+ \3 X3 C
  2.   * @brief  GPIO Configuration PullUp PullDown enumeration
    1 |2 z4 I$ Z0 T4 t7 i$ G7 L
  3.   */
    % ?- v+ j+ T( o+ p, P; b1 A! R
  4. typedef enum- }3 @* R3 j% E
  5. {
    1 g8 g% e" J- b2 L
  6.   GPIO_PuPd_NOPULL = 0x00,
    9 ]2 N" q+ k) @! W
  7.   GPIO_PuPd_UP     = 0x01," `% ~5 g4 a( G+ O8 M& [
  8.   GPIO_PuPd_DOWN   = 0x020 z( q3 o: m1 ?& n2 _# v
  9. }GPIOPuPd_TypeDef;: k- T5 k* T% J0 @
  10. #define IS_GPIO_PUPD(PUPD) (((PUPD) == GPIO_PuPd_NOPULL) || ((PUPD) == GPIO_PuPd_UP) || \
    2 t, g* x: D8 D4 |/ A
  11.                             ((PUPD) == GPIO_PuPd_DOWN))
( G# J( ^  x) _. ]4 E: c7 M; y5 h) e
GPIO置位和复位
. o7 d  b5 q- O* h- a) m& j
1 ~! I& k1 D2 N% I1 _# E
  1. /** ; D3 b4 A  n+ }+ L* N
  2.   * @brief  GPIO Bit SET and Bit RESET enumeration
    0 T4 f. u" N' y
  3.   */
    $ v* q3 _% S% w6 d! w
  4. typedef enum) u+ f& \  L1 e2 W/ u7 S- u
  5. { 6 `/ ]6 U2 h8 l9 [  ~
  6.   Bit_RESET = 0,
    + @" L- V, w  [3 y( }* f$ O
  7.   Bit_SET- Z6 y! F% a$ J5 n, i
  8. }BitAction;" ?+ ~) N1 g% D! t
  9. #define IS_GPIO_BIT_ACTION(ACTION) (((ACTION) == Bit_RESET) || ((ACTION) == Bit_SET))
; _5 S, h2 z6 q' EGPIO初始化结构体类型声明
3 f$ X2 z5 C: R; m; f- x" P1 N
& E6 @; j, M* }+ [5 p! w  A& T
  1. /**   o" z. |  K5 w# `/ k* d
  2.   * @brief   GPIO Init structure definition
    - F( M9 N( j/ R
  3.   */
    3 i" m7 y) F* @( t: r& J7 o
  4. typedef struct1 c  F1 y/ n0 U# O' c' g# }
  5. {
    " S% y! |. {0 ^$ U
  6.   uint32_t GPIO_Pin;              /*!< Specifies the GPIO pins to be configured.
    3 a+ C/ s4 r- {2 }3 x# Y6 {' `; Y3 o
  7.                                        This parameter can be any value of @ref GPIO_pins_define */1 X3 n9 }3 h  L. L6 u# r7 c  r& K
  8. : }2 `3 z. Z3 A1 ^7 `
  9.   GPIOMode_TypeDef GPIO_Mode;     /*!< Specifies the operating mode for the selected pins.0 M/ Z  D$ U4 |# n$ q) A, {
  10.                                        This parameter can be a value of @ref GPIOMode_TypeDef */  x' S6 _7 J2 F
  11. : d6 \- e' ?. H! h1 t
  12.   GPIOSpeed_TypeDef GPIO_Speed;   /*!< Specifies the speed for the selected pins.
    + a+ [! n+ h" o
  13.                                        This parameter can be a value of @ref GPIOSpeed_TypeDef */
    7 S  C! T9 Y7 u8 D3 Q
  14.   {0 Y* c  R+ ~! l- F
  15.   GPIOOType_TypeDef GPIO_OType;   /*!< Specifies the operating output type for the selected pins.& W. l: i! k& h/ B- s
  16.                                        This parameter can be a value of @ref GPIOOType_TypeDef */
    6 R* K" s7 M' n  G' W" y
  17. 8 E* L; b2 c5 s) s; D0 J& C
  18.   GPIOPuPd_TypeDef GPIO_PuPd;     /*!< Specifies the operating Pull-up/Pull down for the selected pins.
    ; C7 }$ D8 x. `4 J- f1 A
  19.                                        This parameter can be a value of @ref GPIOPuPd_TypeDef */
    3 ]$ F; y" S' t1 h( ]
  20. }GPIO_InitTypeDef;# y3 Q! x& N+ m# x5 x. G
2 E% `! i4 M: [( ^# j% _03. GPIO相关宏
, Y% a1 ?: D2 z4 E) p判断是否为合法的GPIO外设- L! J+ Q( t, v5 z- h5 \  V
6 M# {. d' h2 V
  1. #define IS_GPIO_ALL_PERIPH(PERIPH) (((PERIPH) == GPIOA) || \$ q7 D, m# X5 Z$ `2 C
  2.                                     ((PERIPH) == GPIOB) || \
    ' w) M" ~6 ]2 L1 l
  3.                                     ((PERIPH) == GPIOC) || \& k5 d# c( o6 U6 `1 c
  4.                                     ((PERIPH) == GPIOD) || \0 H! Q2 A" Q% b8 Y) [, T
  5.                                     ((PERIPH) == GPIOE) || \
    1 S8 @) K1 F& C, |5 o
  6.                                     ((PERIPH) == GPIOF) || \. A! Z, ]% @4 M2 P% ^6 O
  7.                                     ((PERIPH) == GPIOG) || \
    ' ]* Q9 i. q& w/ ?' \
  8.                                     ((PERIPH) == GPIOH) || \: L! k( r/ b( R1 p- V% n% |- c0 _! T
  9.                                     ((PERIPH) == GPIOI) || \
    : u* G+ H4 u( I9 T, V) B8 O; |
  10.                                     ((PERIPH) == GPIOJ) || \
    + v; E& n" k$ J0 O
  11.                                     ((PERIPH) == GPIOK))
( Q: g; G( N$ \% m& i& pGPIO合法的引脚" [1 g- Z5 K) b# F
$ f9 K' w% F# e+ m2 ?
  1. /** @defgroup GPIO_pins_define * o" [% S4 C+ s. X
  2.   * @{
    & y4 H$ V+ v. v) A% z! L. q
  3.   */
    - d: ~. B* c$ O# h" @
  4. #define GPIO_Pin_0                 ((uint16_t)0x0001)  /* Pin 0 selected */2 c% A" T# S0 V& u, a- K4 D) ^1 I
  5. #define GPIO_Pin_1                 ((uint16_t)0x0002)  /* Pin 1 selected */. }+ R6 m2 z+ N. N0 D# O% ]
  6. #define GPIO_Pin_2                 ((uint16_t)0x0004)  /* Pin 2 selected */( r% R: _- x% I' V
  7. #define GPIO_Pin_3                 ((uint16_t)0x0008)  /* Pin 3 selected */
    ; k  J# b, N# o# r1 h8 S7 ?" p0 d
  8. #define GPIO_Pin_4                 ((uint16_t)0x0010)  /* Pin 4 selected */
    8 r6 E! Z, a5 Y& c, d, m7 ]
  9. #define GPIO_Pin_5                 ((uint16_t)0x0020)  /* Pin 5 selected */
    5 ~3 ?- K% H$ ~
  10. #define GPIO_Pin_6                 ((uint16_t)0x0040)  /* Pin 6 selected */
    4 q! ~( q/ h7 v
  11. #define GPIO_Pin_7                 ((uint16_t)0x0080)  /* Pin 7 selected *// i1 a$ O( R! {7 f2 A& Z/ f
  12. #define GPIO_Pin_8                 ((uint16_t)0x0100)  /* Pin 8 selected */
    ) q- E0 }/ ^0 g6 J/ v. h$ F) ?
  13. #define GPIO_Pin_9                 ((uint16_t)0x0200)  /* Pin 9 selected */
    " ]1 h! m9 w! H) |2 p& Y" w
  14. #define GPIO_Pin_10                ((uint16_t)0x0400)  /* Pin 10 selected */
    ! M  I3 Z$ }0 a- D4 i% L5 p
  15. #define GPIO_Pin_11                ((uint16_t)0x0800)  /* Pin 11 selected */4 o( i# K4 v6 m- C' A
  16. #define GPIO_Pin_12                ((uint16_t)0x1000)  /* Pin 12 selected */
    $ r# [9 y; H* n7 g
  17. #define GPIO_Pin_13                ((uint16_t)0x2000)  /* Pin 13 selected */! }5 N! L) r1 h
  18. #define GPIO_Pin_14                ((uint16_t)0x4000)  /* Pin 14 selected */! o9 I1 A8 v/ t$ @- l  b
  19. #define GPIO_Pin_15                ((uint16_t)0x8000)  /* Pin 15 selected */1 o7 w% A9 w6 U! J) v& |
  20. #define GPIO_Pin_All               ((uint16_t)0xFFFF)  /* All pins selected */
    8 K2 ?, s5 f! L: ]  Y; U: n* j8 G
  21. * C0 g" N' ^3 M
  22. #define GPIO_PIN_MASK              ((uint32_t)0x0000FFFF) /* PIN mask for assert test */" c  T* r: B! m/ R- V8 I+ q
  23. #define IS_GPIO_PIN(PIN)           (((PIN) & GPIO_PIN_MASK ) != (uint32_t)0x00)
    ( y0 N0 M" m$ j* B
  24. #define IS_GET_GPIO_PIN(PIN) (((PIN) == GPIO_Pin_0) || \
    * j+ l/ b7 A0 ?
  25.                               ((PIN) == GPIO_Pin_1) || \9 ?  S+ C# x3 a# l; G" O
  26.                               ((PIN) == GPIO_Pin_2) || \  m7 e% |$ w  s( o8 r  b: L
  27.                               ((PIN) == GPIO_Pin_3) || \3 f# }* T! J  k! k& X* q9 T, Y0 o) H
  28.                               ((PIN) == GPIO_Pin_4) || \6 X; ?, H& a/ o/ T+ a6 E
  29.                               ((PIN) == GPIO_Pin_5) || \
    ! O0 |3 O9 N4 N( m
  30.                               ((PIN) == GPIO_Pin_6) || \
    % z7 Y# t# v4 y
  31.                               ((PIN) == GPIO_Pin_7) || \! ^# I! v6 `( ?- @
  32.                               ((PIN) == GPIO_Pin_8) || \
    . j! t$ z6 u( ]' h) y
  33.                               ((PIN) == GPIO_Pin_9) || \. d. H4 i  P1 p6 l: R
  34.                               ((PIN) == GPIO_Pin_10) || \
    1 O3 ]. d8 N$ |6 b8 z
  35.                               ((PIN) == GPIO_Pin_11) || \
    3 m$ @5 ?* c" G- K: Y
  36.                               ((PIN) == GPIO_Pin_12) || \
    - q2 d6 ]1 \' @5 h* w4 S( n6 M4 {! E
  37.                               ((PIN) == GPIO_Pin_13) || \
    8 E0 \* }9 u: _7 {
  38.                               ((PIN) == GPIO_Pin_14) || \
    & a+ m5 g7 H, n3 ^8 @8 g( T
  39.                               ((PIN) == GPIO_Pin_15))
! `' b& @# S. f/ n0 {+ H! OGPIO合法的引脚源6 H$ v5 P# [3 Q6 L5 [1 ^0 n
6 v6 f3 O2 S- ?+ S
  1. ' z# h2 m, c# x9 v
  2. /** @defgroup GPIO_Pin_sources
      X  G7 l" l3 p3 b. f" ?, C. k* V
  3.   * @{7 {. o( J. v6 o/ w% j5 X  V
  4.   */
    & o4 l& ~! {) ?% w* I# ^) R
  5. #define GPIO_PinSource0            ((uint8_t)0x00)( x: J! g0 o) f( q
  6. #define GPIO_PinSource1            ((uint8_t)0x01)# p5 f6 l, E1 N; S' C9 t, F
  7. #define GPIO_PinSource2            ((uint8_t)0x02)( B! Y1 `8 v. _) z* M
  8. #define GPIO_PinSource3            ((uint8_t)0x03)
    * ~* c+ R7 P1 ^" n) n* R, c: a  G
  9. #define GPIO_PinSource4            ((uint8_t)0x04)
    . d$ w( X! o2 u
  10. #define GPIO_PinSource5            ((uint8_t)0x05)$ J3 u$ u+ l  I) n  \6 I
  11. #define GPIO_PinSource6            ((uint8_t)0x06)8 ?8 c( _) L0 V- e
  12. #define GPIO_PinSource7            ((uint8_t)0x07)
    . ?$ E& ]! A) w% N1 k6 M
  13. #define GPIO_PinSource8            ((uint8_t)0x08)/ c  A1 K/ M* O% g% f4 x8 s" a1 a
  14. #define GPIO_PinSource9            ((uint8_t)0x09)+ S5 H/ n7 M; _; u% V  P1 j. a
  15. #define GPIO_PinSource10           ((uint8_t)0x0A)
    % u2 s& B7 _: c; A" j
  16. #define GPIO_PinSource11           ((uint8_t)0x0B)' m$ J3 J( J; B4 ]
  17. #define GPIO_PinSource12           ((uint8_t)0x0C)
    0 ^7 R6 z) ]: I4 i! U7 i0 ?
  18. #define GPIO_PinSource13           ((uint8_t)0x0D)* U- c* J8 d$ o5 B0 T& [$ F7 {% b
  19. #define GPIO_PinSource14           ((uint8_t)0x0E)( W. k' q' m& ]" V( P9 c
  20. #define GPIO_PinSource15           ((uint8_t)0x0F)
    6 \) @- ?% q8 i  \7 @
  21. 4 ]$ e9 k9 K8 [& m$ y; l0 v
  22. #define IS_GPIO_PIN_SOURCE(PINSOURCE) (((PINSOURCE) == GPIO_PinSource0) || \
    7 k% E' }# ]# s' d* X* E
  23.                                        ((PINSOURCE) == GPIO_PinSource1) || \
    9 I+ |7 X$ q) {, N* F% J
  24.                                        ((PINSOURCE) == GPIO_PinSource2) || \4 J; K9 R; |5 M4 V
  25.                                        ((PINSOURCE) == GPIO_PinSource3) || \
    # U. @6 I9 ~0 T- A8 h; E! I
  26.                                        ((PINSOURCE) == GPIO_PinSource4) || \" S7 n. V6 `- S
  27.                                        ((PINSOURCE) == GPIO_PinSource5) || \1 O  r: U3 c& I, E8 S+ G
  28.                                        ((PINSOURCE) == GPIO_PinSource6) || \
    0 r7 L- l1 L( M0 [
  29.                                        ((PINSOURCE) == GPIO_PinSource7) || \
    ) ]. b* _2 W% S0 e$ Y; U
  30.                                        ((PINSOURCE) == GPIO_PinSource8) || \
    . g1 K% C$ A' g& P& x+ V
  31.                                        ((PINSOURCE) == GPIO_PinSource9) || \1 R6 ~+ p# N/ S6 @; j' e
  32.                                        ((PINSOURCE) == GPIO_PinSource10) || \7 A* r  ^! s8 Q0 L& H* T/ w. K
  33.                                        ((PINSOURCE) == GPIO_PinSource11) || \  [" G; r: D. H. B! B
  34.                                        ((PINSOURCE) == GPIO_PinSource12) || \0 s" x, e, [# `/ e) G/ b! O
  35.                                        ((PINSOURCE) == GPIO_PinSource13) || \
    / J! d0 V5 f, I6 {) i
  36.                                        ((PINSOURCE) == GPIO_PinSource14) || \
    # m8 P' Q5 w3 [
  37.                                        ((PINSOURCE) == GPIO_PinSource15))
+ Z( p2 y& K+ J8 N  k# G# B
04. GPIO相关函数
) U9 \: U6 |6 m+ S
  1. /*  Function used to set the GPIO configuration to the default reset state ****// b4 f: n2 H3 x  s" ~; Y+ c, X4 z2 v
  2. //配置GPIO为默认状态
    6 R4 E! \7 s5 r3 B) a" o5 y
  3. void GPIO_DeInit(GPIO_TypeDef* GPIOx);
    ) K- M. ^" s9 [  O0 n
  4. 4 {' X: q6 ~* [3 |( ~9 Y6 O; ?4 A
  5. /* Initialization and Configuration functions *********************************/
    * G$ Y1 I( c) N' T+ t
  6. //GPIO初始化1 e* n0 c7 d* _* n; x; V9 @4 F
  7. void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct);  Q! g) F5 h% q, ~' {& [/ U& h
  8. //GPIO结构体初始化: P: V3 l  ^7 b' m: F3 ]% c6 S( K
  9. void GPIO_StructInit(GPIO_InitTypeDef* GPIO_InitStruct);
    , ^: D9 M1 Z1 Z6 N' A- \! [5 H4 G
  10. //GPIO锁配置
    4 ]+ t9 t+ E4 d- {6 y6 }
  11. void GPIO_PinLockConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);
    " @3 G( L  ?) s0 z1 h. S' h
  12. / U" \/ I* v; b) U- G
  13. /* GPIO Read and Write functions **********************************************/
    # F7 N) O1 e8 ~( J1 z. G  z
  14. //GPIO读写函数+ z: T2 j5 c5 L- t+ k' B6 q) S$ W
  15. uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);; J4 w, `& k; T
  16. uint16_t GPIO_ReadInputData(GPIO_TypeDef* GPIOx);
    ' b6 K7 C3 v1 s1 `* u
  17. uint8_t GPIO_ReadOutputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);
    . ?7 m7 k; E1 `1 X
  18. uint16_t GPIO_ReadOutputData(GPIO_TypeDef* GPIOx);" m4 `' q3 q/ F* k; n- s/ Z
  19. void GPIO_SetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);
    $ m  t1 ~9 v4 Y* V
  20. void GPIO_ResetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);" g/ V( m& G; f% Y9 w& T
  21. void GPIO_WriteBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, BitAction BitVal);
    6 n+ ?7 t1 \+ w' U. M7 w
  22. void GPIO_Write(GPIO_TypeDef* GPIOx, uint16_t PortVal);
    8 \6 {" F1 q9 B2 \
  23. void GPIO_ToggleBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);
    # R2 f7 {' R% w, ^8 y  I
  24. 5 q- _( o5 {& }- O4 L9 P8 D% I, X5 |
  25. /* GPIO Alternate functions configuration function ****************************/; a: ^1 W2 d% O7 I% u4 B8 r
  26. void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF);
0 i" N" x/ ^# l05. GPIO其它相关
. H8 @0 Q  L% |/ }: x7 m: k' s! rstm32f4xx.h文件中3 {, ~; p8 E3 v' W
6 U" _# P) G" H3 ?通用GPIO结构体封装0 V  w! p+ I$ K
6 b! R7 S0 n* G
  1. typedef struct2 ~5 q5 l5 |6 E3 t( \) Y0 J% Z0 z
  2. {+ b$ W4 u( I% V& G. P3 f
  3.   __IO uint32_t MODER;    /*!< GPIO port mode register,               Address offset: 0x00      */
    . l4 p1 y  ^5 ^; f, R( U: }+ ]$ s5 J9 |
  4.   __IO uint32_t OTYPER;   /*!< GPIO port output type register,        Address offset: 0x04      */
    4 |3 G. @* v7 g, _+ n# V5 N. x' z
  5.   __IO uint32_t OSPEEDR;  /*!< GPIO port output speed register,       Address offset: 0x08      */: E" E! I/ H+ Y4 s$ c& e: p+ f
  6.   __IO uint32_t PUPDR;    /*!< GPIO port pull-up/pull-down register,  Address offset: 0x0C      */1 M& y( U1 e0 `0 Z" l( {) W" u2 r
  7.   __IO uint32_t IDR;      /*!< GPIO port input data register,         Address offset: 0x10      */' u9 `& u+ `* ?! @! |* E5 z- \9 d
  8.   __IO uint32_t ODR;      /*!< GPIO port output data register,        Address offset: 0x14      */' X$ d+ ?6 E* J+ r8 |( o3 D) J/ o
  9.   __IO uint16_t BSRRL;    /*!< GPIO port bit set/reset low register,  Address offset: 0x18      */  `# |/ E8 e! r% E* Y
  10.   __IO uint16_t BSRRH;    /*!< GPIO port bit set/reset high register, Address offset: 0x1A      */+ `! [+ P/ @9 Z8 \' {' P7 o
  11.   __IO uint32_t LCKR;     /*!< GPIO port configuration lock register, Address offset: 0x1C      */$ D' B  S! q: L. m! @5 i& K, D
  12.   __IO uint32_t AFR[2];   /*!< GPIO alternate function registers,     Address offset: 0x20-0x24 */" C% ]; M/ y. D* T; {6 w2 ^2 b
  13. } GPIO_TypeDef;
& H0 }: Z  Q5 \! a+ `6 V& sGPIO基地址- ]& F7 L( Q- A& ^* c; b* h4 a
. G9 @" _" I' `% h& [
  1. /*!< AHB1 peripherals */
    9 d1 N1 l6 @9 G, ], l# G- U
  2. #define GPIOA_BASE            (AHB1PERIPH_BASE + 0x0000)- v4 H/ j" b/ H8 O6 S7 A; O3 e
  3. #define GPIOB_BASE            (AHB1PERIPH_BASE + 0x0400)' K' Z" @0 ~: X7 w1 u- U5 z
  4. #define GPIOC_BASE            (AHB1PERIPH_BASE + 0x0800)
    " p4 o& @, l; {' {/ _2 d6 J
  5. #define GPIOD_BASE            (AHB1PERIPH_BASE + 0x0C00)
    ' _, L2 C0 b5 n3 W; C
  6. #define GPIOE_BASE            (AHB1PERIPH_BASE + 0x1000)/ f$ {# i  c2 V: K; J9 _9 ]
  7. #define GPIOF_BASE            (AHB1PERIPH_BASE + 0x1400)( k" `6 l/ f3 W) @2 `9 R' e
  8. #define GPIOG_BASE            (AHB1PERIPH_BASE + 0x1800)
      o* l% z  w/ {) J# {) N7 F
  9. #define GPIOH_BASE            (AHB1PERIPH_BASE + 0x1C00)
    2 I9 B; ~+ x0 D- b
  10. #define GPIOI_BASE            (AHB1PERIPH_BASE + 0x2000)% X! r: q; v7 r- h9 ~; M
  11. #define GPIOJ_BASE            (AHB1PERIPH_BASE + 0x2400)
    9 {, ~1 m! d8 ^
  12. #define GPIOK_BASE            (AHB1PERIPH_BASE + 0x2800)
    ; v* o1 N9 {  _5 \- I. u% z
+ f4 h- O3 [/ u1 y  L+ @
GPIO起始地址# q$ L5 [+ ?6 O+ [8 w/ k  Q& E- R
3 L. N- ^4 g( Q, J' O/ b" s1 e; o8 {
  1. #define GPIOA               ((GPIO_TypeDef *) GPIOA_BASE)  b1 f, Z0 v: G% G8 F2 l: M
  2. #define GPIOB               ((GPIO_TypeDef *) GPIOB_BASE)8 b5 u9 o+ n, h" V4 u
  3. #define GPIOC               ((GPIO_TypeDef *) GPIOC_BASE)
    : |% u( G& J) O! c0 i- m: T" B# j
  4. #define GPIOD               ((GPIO_TypeDef *) GPIOD_BASE)
    ! Z+ ~2 n2 U5 p1 F2 [) G7 Y6 b3 O8 Y
  5. #define GPIOE               ((GPIO_TypeDef *) GPIOE_BASE)/ P& r# m# \/ g3 L4 u
  6. #define GPIOF               ((GPIO_TypeDef *) GPIOF_BASE)
    1 E. s5 [8 u! ^9 j: F  ?& m
  7. #define GPIOG               ((GPIO_TypeDef *) GPIOG_BASE)2 K. q4 u) H- M1 }2 _
  8. #define GPIOH               ((GPIO_TypeDef *) GPIOH_BASE)5 O! o7 t; M0 |( U9 M2 w: a
  9. #define GPIOI               ((GPIO_TypeDef *) GPIOI_BASE)
    7 \8 f) G5 j, t5 s8 b, Y
  10. #define GPIOJ               ((GPIO_TypeDef *) GPIOJ_BASE)2 e! x/ N& R1 H5 L% a
  11. #define GPIOK               ((GPIO_TypeDef *) GPIOK_BASE)
) o( j3 E  ]* t8 t7 s, Z
GPIO寄存器相关位
, d8 b7 ]4 A, B; Q5 y1 y9 b) O8 b+ Y7 p; @7 Y! C7 _
  1. /******************************************************************************/
    0 ?" p3 M/ t! p7 f) G+ d2 @! ?2 Z! y
  2. /*        *// z( U# E* J0 t0 J2 u2 |
  3. /*                            General Purpose I/O                             */7 [, z- `% n/ r# n
  4. /*        */% a( D, e! a8 w
  5. /******************************************************************************/' L! m& e0 h& A7 b  o) l
  6. /******************  Bits definition for GPIO_MODER register  *****************/0 r0 S: s9 S8 Y" R/ d! q
  7. #define GPIO_MODER_MODER0                    ((uint32_t)0x00000003)
    % g2 u7 K4 s) y2 z' V
  8. #define GPIO_MODER_MODER0_0                  ((uint32_t)0x00000001)9 e. M& A. Z4 b/ T; e; l
  9. #define GPIO_MODER_MODER0_1                  ((uint32_t)0x00000002)# U; R3 z" _2 o7 K
  10. 0 P8 M7 K% Z  q0 Y* e/ K+ U
  11. #define GPIO_MODER_MODER1                    ((uint32_t)0x0000000C)
    & e' d) z, _* K( m/ J0 S- c9 y4 N
  12. #define GPIO_MODER_MODER1_0                  ((uint32_t)0x00000004)% F+ N, Z* b- l. S6 `' d+ |/ `; e
  13. #define GPIO_MODER_MODER1_1                  ((uint32_t)0x00000008)+ C' n9 L8 X% f, r( ~
  14. 2 ?4 @* \  l9 t2 i8 q
  15. #define GPIO_MODER_MODER2                    ((uint32_t)0x00000030)
    ( x9 }. ?0 T9 W) `
  16. #define GPIO_MODER_MODER2_0                  ((uint32_t)0x00000010)
    5 i0 E- a6 l0 q' \
  17. #define GPIO_MODER_MODER2_1                  ((uint32_t)0x00000020)
    " x0 l1 O4 U: H" ~' k5 V  J4 H5 t2 E# |
  18. " g% d8 ]% S) K- M- B
  19. #define GPIO_MODER_MODER3                    ((uint32_t)0x000000C0)/ `6 Y& a# a' _+ D3 ]7 w
  20. #define GPIO_MODER_MODER3_0                  ((uint32_t)0x00000040)
    9 F0 y4 o# p; }2 C6 d
  21. #define GPIO_MODER_MODER3_1                  ((uint32_t)0x00000080)
    . I1 a, m4 A. ^0 M* y9 P# ~
  22. / K' Q8 F+ u0 w$ h8 ]" `
  23. #define GPIO_MODER_MODER4                    ((uint32_t)0x00000300)
    . ?/ |# {* V& a8 X6 K7 s  c# {+ {8 E
  24. #define GPIO_MODER_MODER4_0                  ((uint32_t)0x00000100)
    & D+ A& @9 X& f( B
  25. #define GPIO_MODER_MODER4_1                  ((uint32_t)0x00000200)8 x1 B8 W$ N0 d0 ]8 o
  26. ) r; Q4 }4 Q# X0 B$ v- X! Z' t( s
  27. #define GPIO_MODER_MODER5                    ((uint32_t)0x00000C00)
    ) W% `; L9 v) M, L+ m- G
  28. #define GPIO_MODER_MODER5_0                  ((uint32_t)0x00000400)
    $ B! j9 ]! m5 k1 ~7 ~
  29. #define GPIO_MODER_MODER5_1                  ((uint32_t)0x00000800)' D% r, D) a! u0 j' z( O) Y
  30. 7 S* L4 N9 g9 \  h1 E  ^
  31. #define GPIO_MODER_MODER6                    ((uint32_t)0x00003000)" i; Q. j: j1 F& W  C, g5 D3 t1 p
  32. #define GPIO_MODER_MODER6_0                  ((uint32_t)0x00001000), `- Q5 k0 K! ?
  33. #define GPIO_MODER_MODER6_1                  ((uint32_t)0x00002000)
    ) N7 |0 N' V9 w4 L! G
  34. 5 {8 x' r" _( r7 h6 ?2 H
  35. #define GPIO_MODER_MODER7                    ((uint32_t)0x0000C000)
    4 J- y; H% G4 t& Q
  36. #define GPIO_MODER_MODER7_0                  ((uint32_t)0x00004000)
    . p4 N5 `+ T$ d* K: p+ `
  37. #define GPIO_MODER_MODER7_1                  ((uint32_t)0x00008000)
    . i9 K/ t. t, v! [8 L% Q) M
  38. . a/ E/ z( i+ W& z! C0 i+ r  ]7 I- x
  39. #define GPIO_MODER_MODER8                    ((uint32_t)0x00030000)/ f3 y5 j+ q. O0 P9 A* u4 [8 o
  40. #define GPIO_MODER_MODER8_0                  ((uint32_t)0x00010000)
    9 @7 ^2 c/ s5 k
  41. #define GPIO_MODER_MODER8_1                  ((uint32_t)0x00020000)
      k* D2 A  N- l
  42. . w+ w% ]7 F: F+ I2 i7 W  D
  43. #define GPIO_MODER_MODER9                    ((uint32_t)0x000C0000)
    1 j. v, @* J8 ?. l$ A
  44. #define GPIO_MODER_MODER9_0                  ((uint32_t)0x00040000)
    * x8 z$ o. u. S( L
  45. #define GPIO_MODER_MODER9_1                  ((uint32_t)0x00080000)' ?5 F$ K( Y4 V/ Q, e2 D( T' n- _
  46. ' h! @) t  @9 }
  47. #define GPIO_MODER_MODER10                   ((uint32_t)0x00300000)
    . W+ x$ R/ C( c
  48. #define GPIO_MODER_MODER10_0                 ((uint32_t)0x00100000)
    5 H+ l1 u- z+ b- x4 N6 w
  49. #define GPIO_MODER_MODER10_1                 ((uint32_t)0x00200000)
    # q# M. ]! {, s+ X8 r  P7 w, f
  50. - N# @$ g" e/ n2 S2 h( g
  51. #define GPIO_MODER_MODER11                   ((uint32_t)0x00C00000)
    * T( U: L! t$ A- l
  52. #define GPIO_MODER_MODER11_0                 ((uint32_t)0x00400000)
    % I# z/ ]8 E: p
  53. #define GPIO_MODER_MODER11_1                 ((uint32_t)0x00800000)  c# J4 @9 Z$ v, L& ^
  54. ! e+ \3 F, ^; E. U# x
  55. #define GPIO_MODER_MODER12                   ((uint32_t)0x03000000)" O$ C" Y$ J4 t/ o+ ~# ^
  56. #define GPIO_MODER_MODER12_0                 ((uint32_t)0x01000000)
    * [, C: I2 Y! x6 f
  57. #define GPIO_MODER_MODER12_1                 ((uint32_t)0x02000000)
    " h0 h- U  o9 C4 n  F" M3 ~
  58. $ c/ X9 @$ q. W
  59. #define GPIO_MODER_MODER13                   ((uint32_t)0x0C000000)" M; a" P. W- u9 V3 O& P9 J
  60. #define GPIO_MODER_MODER13_0                 ((uint32_t)0x04000000)$ L4 v$ l4 b$ t$ U- J. \
  61. #define GPIO_MODER_MODER13_1                 ((uint32_t)0x08000000)6 A4 t$ N/ C) f4 }6 d
  62. + c2 b; H7 {$ y$ X0 u1 L
  63. #define GPIO_MODER_MODER14                   ((uint32_t)0x30000000)# a" q3 N" m6 v6 x4 \
  64. #define GPIO_MODER_MODER14_0                 ((uint32_t)0x10000000)
    4 }! U9 r# M+ X( r! H
  65. #define GPIO_MODER_MODER14_1                 ((uint32_t)0x20000000)
    5 i% Y8 D4 r5 S+ ?  P; x! q
  66. & N8 w- I0 h9 w- E, O! c9 D
  67. #define GPIO_MODER_MODER15                   ((uint32_t)0xC0000000)5 s( i8 E/ a- F) f. P
  68. #define GPIO_MODER_MODER15_0                 ((uint32_t)0x40000000)0 O: b0 d  \) F2 |
  69. #define GPIO_MODER_MODER15_1                 ((uint32_t)0x80000000)' y5 e. F! ]/ g2 I/ f( i1 Z
  70. * |' d! M0 P+ O5 b6 |; L7 {
  71. /******************  Bits definition for GPIO_OTYPER register  ****************/
    1 K* `( S! @- t. y0 ]/ p
  72. #define GPIO_OTYPER_OT_0                     ((uint32_t)0x00000001)  F0 K  W6 l6 v3 D
  73. #define GPIO_OTYPER_OT_1                     ((uint32_t)0x00000002)
    3 E* ]2 ^# k' S% U7 c
  74. #define GPIO_OTYPER_OT_2                     ((uint32_t)0x00000004)
    ) b* w: ?3 p4 Z2 Z
  75. #define GPIO_OTYPER_OT_3                     ((uint32_t)0x00000008)
    ; d$ m3 O) Q( O2 o) r( y8 ]
  76. #define GPIO_OTYPER_OT_4                     ((uint32_t)0x00000010)4 n$ i; H' P* o) e0 d1 ]0 @
  77. #define GPIO_OTYPER_OT_5                     ((uint32_t)0x00000020)
    ) I' B( d& X+ @8 n& l2 p' W! \
  78. #define GPIO_OTYPER_OT_6                     ((uint32_t)0x00000040); k1 y. _" x+ z+ @& u/ g
  79. #define GPIO_OTYPER_OT_7                     ((uint32_t)0x00000080)
    % E8 ~: j( Z6 c( N. r0 r' y$ w# i
  80. #define GPIO_OTYPER_OT_8                     ((uint32_t)0x00000100)
    ) g* f& N& d/ K6 d9 H
  81. #define GPIO_OTYPER_OT_9                     ((uint32_t)0x00000200); D, K2 t: \3 m  ^
  82. #define GPIO_OTYPER_OT_10                    ((uint32_t)0x00000400)
    6 s7 T8 _1 ^/ _
  83. #define GPIO_OTYPER_OT_11                    ((uint32_t)0x00000800)
    1 \3 L: e5 {1 G# R' G8 i: c
  84. #define GPIO_OTYPER_OT_12                    ((uint32_t)0x00001000); ^& `* q# o3 G
  85. #define GPIO_OTYPER_OT_13                    ((uint32_t)0x00002000)
    . Y/ ~4 w% o1 x7 z# k* Y8 P, Y
  86. #define GPIO_OTYPER_OT_14                    ((uint32_t)0x00004000)
    7 u3 k* K7 |, r8 U. _8 I" x
  87. #define GPIO_OTYPER_OT_15                    ((uint32_t)0x00008000)+ N! X( B; d5 P7 q* w, U- S
  88. * O. N+ G7 @, I! T) p0 Z1 b
  89. /******************  Bits definition for GPIO_OSPEEDR register  ***************/! N3 }$ {; z7 p% j( Y: B6 ~2 N( b
  90. #define GPIO_OSPEEDER_OSPEEDR0               ((uint32_t)0x00000003)
    " ~1 k) e! w) w( E* c2 Z; e
  91. #define GPIO_OSPEEDER_OSPEEDR0_0             ((uint32_t)0x00000001)+ m/ J# R9 a# z( u
  92. #define GPIO_OSPEEDER_OSPEEDR0_1             ((uint32_t)0x00000002)% f( O. M. y% A% N
  93. ) ]$ I) [$ Y' D- f6 Z+ b
  94. #define GPIO_OSPEEDER_OSPEEDR1               ((uint32_t)0x0000000C)
    2 X/ p! O: X* A9 Y6 b  M
  95. #define GPIO_OSPEEDER_OSPEEDR1_0             ((uint32_t)0x00000004)
    4 k3 A- v# `0 P6 q. n
  96. #define GPIO_OSPEEDER_OSPEEDR1_1             ((uint32_t)0x00000008)
    6 X3 `8 S4 x- l
  97. 1 z  p" }7 x& a& N) X" H/ e2 o
  98. #define GPIO_OSPEEDER_OSPEEDR2               ((uint32_t)0x00000030)' Q  V" C6 @, O# `  d3 \
  99. #define GPIO_OSPEEDER_OSPEEDR2_0             ((uint32_t)0x00000010)
    ) x- `, y# ~9 ~0 f! N. [3 W- Y( {
  100. #define GPIO_OSPEEDER_OSPEEDR2_1             ((uint32_t)0x00000020)& \& z$ Y- U/ l; y* B
  101. 5 T5 }6 y+ n4 g7 q+ C* ?
  102. #define GPIO_OSPEEDER_OSPEEDR3               ((uint32_t)0x000000C0)
    5 r$ F+ B9 |9 }/ V0 s
  103. #define GPIO_OSPEEDER_OSPEEDR3_0             ((uint32_t)0x00000040); e7 V% A9 c8 h$ c! V- o; d) Q2 a
  104. #define GPIO_OSPEEDER_OSPEEDR3_1             ((uint32_t)0x00000080)5 n$ y8 y6 t8 q) }/ d) T% O. B
  105. ) o4 o+ |' J' V8 ^* [. I3 L0 t; @
  106. #define GPIO_OSPEEDER_OSPEEDR4               ((uint32_t)0x00000300)* y2 q% q1 Q3 Z2 h1 M
  107. #define GPIO_OSPEEDER_OSPEEDR4_0             ((uint32_t)0x00000100)3 T& C7 m0 I4 i) Q* C; w
  108. #define GPIO_OSPEEDER_OSPEEDR4_1             ((uint32_t)0x00000200)
    ; T7 Q  ]& @) @8 [+ N6 i9 W7 \
  109. : ?  T- s5 s$ U( \, n7 ?* M% o
  110. #define GPIO_OSPEEDER_OSPEEDR5               ((uint32_t)0x00000C00)
    - [) l6 B* Y+ m8 r, t6 P; o
  111. #define GPIO_OSPEEDER_OSPEEDR5_0             ((uint32_t)0x00000400)2 G3 ~. S4 G5 V( L' t" S+ z& D
  112. #define GPIO_OSPEEDER_OSPEEDR5_1             ((uint32_t)0x00000800)) H: X/ t$ J3 I6 Q7 N/ n
  113. + j: O+ w9 ?- @/ ~% m1 L2 C
  114. #define GPIO_OSPEEDER_OSPEEDR6               ((uint32_t)0x00003000), g8 }) ~: W2 V: ]% O" v
  115. #define GPIO_OSPEEDER_OSPEEDR6_0             ((uint32_t)0x00001000)
    % x- d) u% N. F
  116. #define GPIO_OSPEEDER_OSPEEDR6_1             ((uint32_t)0x00002000). m: ?5 q: J$ O: c+ x
  117. : ?6 v5 w  Q2 x9 P+ x+ s
  118. #define GPIO_OSPEEDER_OSPEEDR7               ((uint32_t)0x0000C000)) W" x- Z- `7 ~) h/ [( @
  119. #define GPIO_OSPEEDER_OSPEEDR7_0             ((uint32_t)0x00004000)
    9 H: e% r6 o; [- s# O
  120. #define GPIO_OSPEEDER_OSPEEDR7_1             ((uint32_t)0x00008000)2 _' p$ k+ U! u8 g1 f
  121. 4 L" }( P1 t* M7 h) ~  V2 D
  122. #define GPIO_OSPEEDER_OSPEEDR8               ((uint32_t)0x00030000)
    3 M( D6 C. ~  K" G
  123. #define GPIO_OSPEEDER_OSPEEDR8_0             ((uint32_t)0x00010000). m" u7 ~& x1 f) H
  124. #define GPIO_OSPEEDER_OSPEEDR8_1             ((uint32_t)0x00020000)) W6 ~' b& q8 t' I1 ?& V4 Z1 S
  125.   ], ~- e) y% ~! `
  126. #define GPIO_OSPEEDER_OSPEEDR9               ((uint32_t)0x000C0000)
    3 n2 J/ Y' Z6 R: g
  127. #define GPIO_OSPEEDER_OSPEEDR9_0             ((uint32_t)0x00040000)0 \# z9 u/ B' s6 b0 E
  128. #define GPIO_OSPEEDER_OSPEEDR9_1             ((uint32_t)0x00080000)% f7 f2 o  k1 k  |/ b
  129. " _, v, r# j" U) P! {7 z& Z
  130. #define GPIO_OSPEEDER_OSPEEDR10              ((uint32_t)0x00300000)6 ?1 m2 U' a0 g" K% Q) Q$ Q
  131. #define GPIO_OSPEEDER_OSPEEDR10_0            ((uint32_t)0x00100000)
    . k! C' \4 e' z) o) o
  132. #define GPIO_OSPEEDER_OSPEEDR10_1            ((uint32_t)0x00200000)
    0 k6 l* }$ F( T6 b; [4 W
  133. 4 i7 s& K% w0 R/ a$ m1 ?
  134. #define GPIO_OSPEEDER_OSPEEDR11              ((uint32_t)0x00C00000)
    ) q( ]" s, d+ m6 E3 q# |* `6 W
  135. #define GPIO_OSPEEDER_OSPEEDR11_0            ((uint32_t)0x00400000)
    2 Z& r7 B2 b5 O# @0 `% Y$ G/ l
  136. #define GPIO_OSPEEDER_OSPEEDR11_1            ((uint32_t)0x00800000)+ i  M9 M- O7 w+ Z
  137. , I1 G3 K' M/ U4 @" r  u
  138. #define GPIO_OSPEEDER_OSPEEDR12              ((uint32_t)0x03000000)  f' f  W( u7 z
  139. #define GPIO_OSPEEDER_OSPEEDR12_0            ((uint32_t)0x01000000)
    + c( z1 f+ D, K
  140. #define GPIO_OSPEEDER_OSPEEDR12_1            ((uint32_t)0x02000000)
    ) D/ i# u9 q" I, f; a  b& {
  141. $ Y1 Z# M( k* |# m% z
  142. #define GPIO_OSPEEDER_OSPEEDR13              ((uint32_t)0x0C000000)+ C2 y' w  [1 T4 m8 {, ?
  143. #define GPIO_OSPEEDER_OSPEEDR13_0            ((uint32_t)0x04000000)
    1 l! W5 |4 u# `: M  N
  144. #define GPIO_OSPEEDER_OSPEEDR13_1            ((uint32_t)0x08000000)
    7 O  N  w& m" ^5 Q; A9 J: @; h
  145. 0 c4 F% A# P; C, T: e9 u; s
  146. #define GPIO_OSPEEDER_OSPEEDR14              ((uint32_t)0x30000000)2 Z7 i8 \6 ?& Y. p% _
  147. #define GPIO_OSPEEDER_OSPEEDR14_0            ((uint32_t)0x10000000)
      y+ d7 y$ Q) e+ a8 _9 r4 o
  148. #define GPIO_OSPEEDER_OSPEEDR14_1            ((uint32_t)0x20000000)3 l4 I' k( C  D1 F& S; T7 r, F
  149. ' w& t, P& B! g4 R! X* u- x& Y! g
  150. #define GPIO_OSPEEDER_OSPEEDR15              ((uint32_t)0xC0000000)
    9 E# \# B5 c7 M8 ]! X
  151. #define GPIO_OSPEEDER_OSPEEDR15_0            ((uint32_t)0x40000000)9 v, ^  r5 ^2 x0 a$ K& R7 ^0 j
  152. #define GPIO_OSPEEDER_OSPEEDR15_1            ((uint32_t)0x80000000)
    1 E: h0 `" r; L; L. v* R! |
  153. , `* v9 R1 r, h3 P
  154. /******************  Bits definition for GPIO_PUPDR register  *****************/( y6 a% K. c" I
  155. #define GPIO_PUPDR_PUPDR0                    ((uint32_t)0x00000003), Y  d" J. v1 f2 @% |3 V
  156. #define GPIO_PUPDR_PUPDR0_0                  ((uint32_t)0x00000001)6 x& C8 X% v, E6 |7 s) p- v4 Z
  157. #define GPIO_PUPDR_PUPDR0_1                  ((uint32_t)0x00000002)& a; z% x$ s! u- F
  158. , A  I8 V9 R5 Z; y2 a" F2 V
  159. #define GPIO_PUPDR_PUPDR1                    ((uint32_t)0x0000000C); o9 Y9 O1 Y0 J$ ]) c
  160. #define GPIO_PUPDR_PUPDR1_0                  ((uint32_t)0x00000004)
    6 w& O$ v  G- F7 P! d
  161. #define GPIO_PUPDR_PUPDR1_1                  ((uint32_t)0x00000008)
    ! {" c/ D4 }/ [. a, o
  162. ' u( A5 y0 I8 |
  163. #define GPIO_PUPDR_PUPDR2                    ((uint32_t)0x00000030)
    ) U0 u- b5 X  s
  164. #define GPIO_PUPDR_PUPDR2_0                  ((uint32_t)0x00000010)
    ! M* v, J! D" o$ G9 s* S4 Q+ S
  165. #define GPIO_PUPDR_PUPDR2_1                  ((uint32_t)0x00000020)
    / f5 i2 t5 A6 }! c3 s, y. O* c
  166. , j* h6 O% n5 I0 W2 _: [
  167. #define GPIO_PUPDR_PUPDR3                    ((uint32_t)0x000000C0)
    ! Y9 z! N" P8 U& A7 R8 v2 D( o$ ~2 B
  168. #define GPIO_PUPDR_PUPDR3_0                  ((uint32_t)0x00000040)
      ]3 {5 y. W( l( w& g; T" ~
  169. #define GPIO_PUPDR_PUPDR3_1                  ((uint32_t)0x00000080); w( g5 N7 t5 `
  170. 2 A; m* _1 A# l# f4 M; y. v6 A
  171. #define GPIO_PUPDR_PUPDR4                    ((uint32_t)0x00000300)2 |$ i# i/ }0 J4 T5 q: a* W
  172. #define GPIO_PUPDR_PUPDR4_0                  ((uint32_t)0x00000100); \3 o2 g' t; P
  173. #define GPIO_PUPDR_PUPDR4_1                  ((uint32_t)0x00000200)
      X2 ?8 x* P& M. k, S+ m) E# K
  174. " U6 n' r" @, _9 O7 }
  175. #define GPIO_PUPDR_PUPDR5                    ((uint32_t)0x00000C00)
    - o/ f& k3 `6 ?; Y6 n1 I/ t  V
  176. #define GPIO_PUPDR_PUPDR5_0                  ((uint32_t)0x00000400)2 e' O1 ^5 _$ g) V. i8 g
  177. #define GPIO_PUPDR_PUPDR5_1                  ((uint32_t)0x00000800)
    , k: H% t" @' o
  178. 9 ~0 [" u% O& {% @, @
  179. #define GPIO_PUPDR_PUPDR6                    ((uint32_t)0x00003000)
    / ~. [  C$ p, y" v/ r* h
  180. #define GPIO_PUPDR_PUPDR6_0                  ((uint32_t)0x00001000)
    ( h  D5 Q7 T; _3 }; ~/ Z
  181. #define GPIO_PUPDR_PUPDR6_1                  ((uint32_t)0x00002000)' y/ y0 x$ ~0 s- g0 ]9 k
  182. 8 J! C$ ~! h! ?7 L7 W; K
  183. #define GPIO_PUPDR_PUPDR7                    ((uint32_t)0x0000C000). ]# y; F  F& T& T  f
  184. #define GPIO_PUPDR_PUPDR7_0                  ((uint32_t)0x00004000)) C; V  t- f2 k- a+ T1 U/ h
  185. #define GPIO_PUPDR_PUPDR7_1                  ((uint32_t)0x00008000)
    . ~* m4 E! N& ~7 {( s
  186. ' O1 |- ]  v. V- A2 c$ X+ G0 H' w
  187. #define GPIO_PUPDR_PUPDR8                    ((uint32_t)0x00030000)+ d+ C7 Q8 d4 ?
  188. #define GPIO_PUPDR_PUPDR8_0                  ((uint32_t)0x00010000)+ u! A3 h! K3 `; \. o# x
  189. #define GPIO_PUPDR_PUPDR8_1                  ((uint32_t)0x00020000)
    $ }" o, w9 i3 B3 N  T0 H" o. i
  190. " w0 }+ L9 \" i4 o! A& c& V
  191. #define GPIO_PUPDR_PUPDR9                    ((uint32_t)0x000C0000)
    9 A0 U9 t* {0 D# J5 V0 ^7 ^' F/ J
  192. #define GPIO_PUPDR_PUPDR9_0                  ((uint32_t)0x00040000)) d& r% V, E" i. W3 D- x
  193. #define GPIO_PUPDR_PUPDR9_1                  ((uint32_t)0x00080000)
    # |: X2 o6 }$ q, g" a6 P' x
  194. 1 ^% N6 _) A1 s* \
  195. #define GPIO_PUPDR_PUPDR10                   ((uint32_t)0x00300000)
    ) ?; @. z; c. }, A
  196. #define GPIO_PUPDR_PUPDR10_0                 ((uint32_t)0x00100000)
    : s, G7 S$ N/ h* u0 m1 k
  197. #define GPIO_PUPDR_PUPDR10_1                 ((uint32_t)0x00200000)
    3 N) k! h$ N& [5 n# E1 `2 N
  198. + l: p/ m- V" f) R
  199. #define GPIO_PUPDR_PUPDR11                   ((uint32_t)0x00C00000): i7 J- t# Q- d' E
  200. #define GPIO_PUPDR_PUPDR11_0                 ((uint32_t)0x00400000)6 f7 K; x/ n8 n1 d6 V
  201. #define GPIO_PUPDR_PUPDR11_1                 ((uint32_t)0x00800000)8 |( M8 w7 H' r6 ~: S
  202. 3 u7 E* s& N) F$ s
  203. #define GPIO_PUPDR_PUPDR12                   ((uint32_t)0x03000000)
    8 Q/ C4 t% f, X  r% t, [8 ?- d
  204. #define GPIO_PUPDR_PUPDR12_0                 ((uint32_t)0x01000000)
    8 A* R6 M# m% Y
  205. #define GPIO_PUPDR_PUPDR12_1                 ((uint32_t)0x02000000)4 s. \( J5 u' L" T" C" l
  206. ; |: |% I2 i& [# f2 E8 b8 C
  207. #define GPIO_PUPDR_PUPDR13                   ((uint32_t)0x0C000000)" J6 X9 k" j. ?) f% a* D6 S
  208. #define GPIO_PUPDR_PUPDR13_0                 ((uint32_t)0x04000000)' Y; @3 r8 d  j+ {6 `# W/ D9 R& S
  209. #define GPIO_PUPDR_PUPDR13_1                 ((uint32_t)0x08000000)
    9 l8 ]$ H* P5 A
  210. , c5 q2 i# s5 f
  211. #define GPIO_PUPDR_PUPDR14                   ((uint32_t)0x30000000)3 M' ]" U! ^) p5 v
  212. #define GPIO_PUPDR_PUPDR14_0                 ((uint32_t)0x10000000)9 C  k- |6 ?5 P7 u
  213. #define GPIO_PUPDR_PUPDR14_1                 ((uint32_t)0x20000000)0 O6 L$ f; P; K8 \8 _' E
  214. ) p4 l! j& m8 H! g9 ]% [! k& u
  215. #define GPIO_PUPDR_PUPDR15                   ((uint32_t)0xC0000000)
    ; Q  B: b, R. C- x' x9 h, ^* p9 D; `
  216. #define GPIO_PUPDR_PUPDR15_0                 ((uint32_t)0x40000000)
    2 r: k- H" `# k
  217. #define GPIO_PUPDR_PUPDR15_1                 ((uint32_t)0x80000000): r2 M5 G2 o8 ?( `
  218. 0 L2 ?$ [3 Y% _& K% L
  219. /******************  Bits definition for GPIO_IDR register  *******************/
    + D( _8 M! E" E5 k
  220. #define GPIO_IDR_IDR_0                       ((uint32_t)0x00000001)
    4 I" d/ d6 h& d
  221. #define GPIO_IDR_IDR_1                       ((uint32_t)0x00000002)
    7 {& F) J% A9 @* Z  A( }
  222. #define GPIO_IDR_IDR_2                       ((uint32_t)0x00000004); }! V8 X) A+ X1 m- r" e  |
  223. #define GPIO_IDR_IDR_3                       ((uint32_t)0x00000008)& N+ C, A8 W! n
  224. #define GPIO_IDR_IDR_4                       ((uint32_t)0x00000010)% n$ _7 c3 l. Q3 J, z
  225. #define GPIO_IDR_IDR_5                       ((uint32_t)0x00000020)# n5 f2 Q4 J# v9 r9 b
  226. #define GPIO_IDR_IDR_6                       ((uint32_t)0x00000040)
    / R# d5 p5 G% z# E
  227. #define GPIO_IDR_IDR_7                       ((uint32_t)0x00000080)
    & n/ r( A) g. M! E1 Y
  228. #define GPIO_IDR_IDR_8                       ((uint32_t)0x00000100)* {, y9 u. n. i$ v. ?
  229. #define GPIO_IDR_IDR_9                       ((uint32_t)0x00000200)) n/ I# `! P" p1 O$ \& Q
  230. #define GPIO_IDR_IDR_10                      ((uint32_t)0x00000400)
    4 E& |: H+ c% r8 l( a/ D! L
  231. #define GPIO_IDR_IDR_11                      ((uint32_t)0x00000800)
    2 v( R# {( t- Q4 g" Q( F1 I& |
  232. #define GPIO_IDR_IDR_12                      ((uint32_t)0x00001000)
    0 Q" C% r9 G( g7 x7 u& Y
  233. #define GPIO_IDR_IDR_13                      ((uint32_t)0x00002000); X1 A" {! W3 r8 S0 g5 p0 Y0 `
  234. #define GPIO_IDR_IDR_14                      ((uint32_t)0x00004000)6 B+ R. p& r# b7 W- B9 W
  235. #define GPIO_IDR_IDR_15                      ((uint32_t)0x00008000)
    ( ~9 q4 r/ d) F6 V+ `
  236. /* Old GPIO_IDR register bits definition, maintained for legacy purpose */
    , c9 t& O  z0 _& A4 d8 i* X
  237. #define GPIO_OTYPER_IDR_0                    GPIO_IDR_IDR_0
    0 b6 }4 [. R1 X6 P+ J" `
  238. #define GPIO_OTYPER_IDR_1                    GPIO_IDR_IDR_1
    " ?! r# j7 w3 j/ A* n/ a
  239. #define GPIO_OTYPER_IDR_2                    GPIO_IDR_IDR_2
    8 \5 A: i, S: K* s4 I, U
  240. #define GPIO_OTYPER_IDR_3                    GPIO_IDR_IDR_3. e: C. ]4 G* p4 [+ e
  241. #define GPIO_OTYPER_IDR_4                    GPIO_IDR_IDR_4
    $ x9 V2 s9 a/ Y$ q
  242. #define GPIO_OTYPER_IDR_5                    GPIO_IDR_IDR_5
    2 p4 h4 d0 _  @( Z! r' w' L
  243. #define GPIO_OTYPER_IDR_6                    GPIO_IDR_IDR_6' T' {  Z% ?2 z9 O
  244. #define GPIO_OTYPER_IDR_7                    GPIO_IDR_IDR_7
    ; R! n% i' \+ t! l, S
  245. #define GPIO_OTYPER_IDR_8                    GPIO_IDR_IDR_8
    : ?4 q" M$ _0 ~5 `- V
  246. #define GPIO_OTYPER_IDR_9                    GPIO_IDR_IDR_9
    1 f) n. S) o$ r0 R) y! L6 r0 \
  247. #define GPIO_OTYPER_IDR_10                   GPIO_IDR_IDR_10
    7 F! i! d- O" c/ Y, }. Y! Z
  248. #define GPIO_OTYPER_IDR_11                   GPIO_IDR_IDR_114 F$ {0 K9 y5 G; X$ i9 G" Z/ i
  249. #define GPIO_OTYPER_IDR_12                   GPIO_IDR_IDR_12
    # p4 M; h6 u: s! E$ [0 N
  250. #define GPIO_OTYPER_IDR_13                   GPIO_IDR_IDR_13% g& g  G' F$ ~( S$ Z3 K
  251. #define GPIO_OTYPER_IDR_14                   GPIO_IDR_IDR_14
    ( X# Y; C, G; f
  252. #define GPIO_OTYPER_IDR_15                   GPIO_IDR_IDR_15- j1 C$ [6 h- \& b* B
  253. 5 C5 h6 B) p1 Y3 m+ Q8 o& ^/ \1 D
  254. /******************  Bits definition for GPIO_ODR register  *******************/
    % G5 r2 E! Q) |, V9 x
  255. #define GPIO_ODR_ODR_0                       ((uint32_t)0x00000001)
    ; \3 u6 B  \7 Y/ W8 E
  256. #define GPIO_ODR_ODR_1                       ((uint32_t)0x00000002)( ]; v7 \+ m+ v5 N4 m
  257. #define GPIO_ODR_ODR_2                       ((uint32_t)0x00000004)
    / u2 Q5 y/ o4 n
  258. #define GPIO_ODR_ODR_3                       ((uint32_t)0x00000008)
    & F/ p% a, g1 g
  259. #define GPIO_ODR_ODR_4                       ((uint32_t)0x00000010)7 T3 s* g1 T8 ^, D) @( T
  260. #define GPIO_ODR_ODR_5                       ((uint32_t)0x00000020)
    . h( e3 W" f. ?7 ?" Y- j7 G
  261. #define GPIO_ODR_ODR_6                       ((uint32_t)0x00000040)
    + z9 B) f2 q) O  }% I! i
  262. #define GPIO_ODR_ODR_7                       ((uint32_t)0x00000080)
    8 e0 l/ j1 x8 ?% U
  263. #define GPIO_ODR_ODR_8                       ((uint32_t)0x00000100)* B/ Z4 w$ J& R; e8 R. Y
  264. #define GPIO_ODR_ODR_9                       ((uint32_t)0x00000200)
    ( e- R- ]8 ~" T5 m
  265. #define GPIO_ODR_ODR_10                      ((uint32_t)0x00000400)2 j  V' Q" N; [7 @- S: e2 b7 J- G
  266. #define GPIO_ODR_ODR_11                      ((uint32_t)0x00000800)) J: Q# S! ^, H
  267. #define GPIO_ODR_ODR_12                      ((uint32_t)0x00001000)
    6 q7 I6 b; H3 R5 {5 K; s% N! M$ ]
  268. #define GPIO_ODR_ODR_13                      ((uint32_t)0x00002000)
    ! t2 i, c. i# R- S
  269. #define GPIO_ODR_ODR_14                      ((uint32_t)0x00004000)
    " a) ?& }& D# r
  270. #define GPIO_ODR_ODR_15                      ((uint32_t)0x00008000)) P* L+ x) ~7 Y  _! q( ]
  271. /* Old GPIO_ODR register bits definition, maintained for legacy purpose */- Z- M  I" _* A& ]
  272. #define GPIO_OTYPER_ODR_0                    GPIO_ODR_ODR_0
    * o* l& y0 A3 E) ^8 J
  273. #define GPIO_OTYPER_ODR_1                    GPIO_ODR_ODR_1$ G5 H) @  m8 g" H
  274. #define GPIO_OTYPER_ODR_2                    GPIO_ODR_ODR_2
    % R* G% e2 b# ~: l+ G! x8 r
  275. #define GPIO_OTYPER_ODR_3                    GPIO_ODR_ODR_3  F. D  M, v; P0 W3 B
  276. #define GPIO_OTYPER_ODR_4                    GPIO_ODR_ODR_4) |7 m) m( ^* \. b# I# B5 P. S& a/ |
  277. #define GPIO_OTYPER_ODR_5                    GPIO_ODR_ODR_59 l  \- T- e, [, @# n* J
  278. #define GPIO_OTYPER_ODR_6                    GPIO_ODR_ODR_6% A/ P  d% j" ^  y% b
  279. #define GPIO_OTYPER_ODR_7                    GPIO_ODR_ODR_7
    7 q; x  E; O  y$ j6 u4 D% ]
  280. #define GPIO_OTYPER_ODR_8                    GPIO_ODR_ODR_8# ~& w. ]6 S& x+ h6 k
  281. #define GPIO_OTYPER_ODR_9                    GPIO_ODR_ODR_9- b! U; d( I/ O$ t! T7 a
  282. #define GPIO_OTYPER_ODR_10                   GPIO_ODR_ODR_10' U8 G7 p, X- D' e" e. {2 u" ~5 q
  283. #define GPIO_OTYPER_ODR_11                   GPIO_ODR_ODR_11
    % q" K8 x* h$ ?1 j/ G, d
  284. #define GPIO_OTYPER_ODR_12                   GPIO_ODR_ODR_12% y7 l  Z# l( W) E1 S
  285. #define GPIO_OTYPER_ODR_13                   GPIO_ODR_ODR_13
    6 O, C7 ^* f( }2 E4 P2 o
  286. #define GPIO_OTYPER_ODR_14                   GPIO_ODR_ODR_14# e- ~5 C. l* l" i) r( ^7 ?+ O
  287. #define GPIO_OTYPER_ODR_15                   GPIO_ODR_ODR_15
    . f8 c6 a1 _' b8 ^" P
  288. 1 E* [/ y9 d$ l- L' r$ Y0 U
  289. /******************  Bits definition for GPIO_BSRR register  ******************/4 {9 C" {1 b6 T# X/ ^& r
  290. #define GPIO_BSRR_BS_0                       ((uint32_t)0x00000001)
    " f& y7 A" e9 O: F1 ^
  291. #define GPIO_BSRR_BS_1                       ((uint32_t)0x00000002)) z: ?& d5 v5 {, h& k+ d5 j
  292. #define GPIO_BSRR_BS_2                       ((uint32_t)0x00000004)
    # t, k" d9 Q8 T0 a/ V1 w
  293. #define GPIO_BSRR_BS_3                       ((uint32_t)0x00000008)  j( `6 s+ D/ N$ @  X& M; O$ g
  294. #define GPIO_BSRR_BS_4                       ((uint32_t)0x00000010)
    ) k3 r) W  ?  }! G) |9 Y- V
  295. #define GPIO_BSRR_BS_5                       ((uint32_t)0x00000020)/ s4 U; f4 B) L% o  T! M# k6 |
  296. #define GPIO_BSRR_BS_6                       ((uint32_t)0x00000040)
    3 u9 J: u/ J( \+ V# A9 q
  297. #define GPIO_BSRR_BS_7                       ((uint32_t)0x00000080)3 x, o2 R: k: L8 X1 X8 j9 F4 y
  298. #define GPIO_BSRR_BS_8                       ((uint32_t)0x00000100)' H4 F8 u, p( L% i7 M, P4 q& p
  299. #define GPIO_BSRR_BS_9                       ((uint32_t)0x00000200)* J, E$ P6 |+ Y5 ~. v$ }  ]
  300. #define GPIO_BSRR_BS_10                      ((uint32_t)0x00000400)
      [/ P0 Z  i+ u9 ]+ P7 S
  301. #define GPIO_BSRR_BS_11                      ((uint32_t)0x00000800)8 D( F/ B8 I* E( m- W
  302. #define GPIO_BSRR_BS_12                      ((uint32_t)0x00001000)
    " |+ u5 C0 B% h% i9 F
  303. #define GPIO_BSRR_BS_13                      ((uint32_t)0x00002000)6 \& W1 @  u3 {4 Q, w
  304. #define GPIO_BSRR_BS_14                      ((uint32_t)0x00004000)0 ^* [2 ~5 G4 u: K5 v# ]7 l
  305. #define GPIO_BSRR_BS_15                      ((uint32_t)0x00008000)# P' E" A( ?& [4 B; W5 W
  306. #define GPIO_BSRR_BR_0                       ((uint32_t)0x00010000)% `2 v, f7 G6 M  i
  307. #define GPIO_BSRR_BR_1                       ((uint32_t)0x00020000)* Y) i+ e2 r) F1 ~
  308. #define GPIO_BSRR_BR_2                       ((uint32_t)0x00040000)0 B$ e; k: ?7 o1 R3 {( R
  309. #define GPIO_BSRR_BR_3                       ((uint32_t)0x00080000)
    " U) I1 O% j5 ^7 D" \+ O% N4 X
  310. #define GPIO_BSRR_BR_4                       ((uint32_t)0x00100000)
    3 p6 T2 @6 {9 W3 a, A6 q9 }4 B, u$ W% V
  311. #define GPIO_BSRR_BR_5                       ((uint32_t)0x00200000)7 s: C" K; G5 R7 g" p/ c5 i
  312. #define GPIO_BSRR_BR_6                       ((uint32_t)0x00400000)% L, N6 U" c- ~! l: g
  313. #define GPIO_BSRR_BR_7                       ((uint32_t)0x00800000), ^5 _+ v( w; p1 I
  314. #define GPIO_BSRR_BR_8                       ((uint32_t)0x01000000)% x& L0 A: w3 O5 t- s: c, Q8 M
  315. #define GPIO_BSRR_BR_9                       ((uint32_t)0x02000000)
    1 n3 A% o, w) J4 V8 x4 l" F
  316. #define GPIO_BSRR_BR_10                      ((uint32_t)0x04000000)8 }. q, A8 T# H% W
  317. #define GPIO_BSRR_BR_11                      ((uint32_t)0x08000000)" w9 o( ]+ P! G( r, r, E
  318. #define GPIO_BSRR_BR_12                      ((uint32_t)0x10000000)
    5 }8 J) L0 Q' \5 G9 _/ ^2 c' i- S
  319. #define GPIO_BSRR_BR_13                      ((uint32_t)0x20000000)8 s! T+ D, A/ ^+ ]! c& z3 X9 j
  320. #define GPIO_BSRR_BR_14                      ((uint32_t)0x40000000)
    9 l$ |5 ~* a, `$ i  a+ H% ~
  321. #define GPIO_BSRR_BR_15                      ((uint32_t)0x80000000)
+ K* B1 y0 @7 K3 k4 JGPIO全部挂载AHB1总线上
9 r8 B4 m8 r5 |( M2 y
3 e; [# Z* ?5 {* Y0 U9 p
  1. $ [0 i# ~0 @6 `9 ]& B
  2. /********************  Bit definition for RCC_AHB1ENR register  ***************/
    $ U% Z" w/ C6 K# I' b
  3. #define  RCC_AHB1ENR_GPIOAEN                 ((uint32_t)0x00000001)) |# s5 Z! W# |' h% n9 ?, A/ U
  4. #define  RCC_AHB1ENR_GPIOBEN                 ((uint32_t)0x00000002)
    : C5 {+ g5 L" b. R  w4 T1 [, I
  5. #define  RCC_AHB1ENR_GPIOCEN                 ((uint32_t)0x00000004)2 O( h( }* u' T- I) f
  6. #define  RCC_AHB1ENR_GPIODEN                 ((uint32_t)0x00000008)
    ( ?( W$ y% z) t- I" R
  7. #define  RCC_AHB1ENR_GPIOEEN                 ((uint32_t)0x00000010)3 t+ D: y) T2 }. Y  S) @
  8. #define  RCC_AHB1ENR_GPIOFEN                 ((uint32_t)0x00000020)
    % ~6 c) @7 o  }
  9. #define  RCC_AHB1ENR_GPIOGEN                 ((uint32_t)0x00000040)7 ~" j8 y7 G6 q
  10. #define  RCC_AHB1ENR_GPIOHEN                 ((uint32_t)0x00000080)
    7 X& k' D3 i* ]% e1 o# }, T1 o, N
  11. #define  RCC_AHB1ENR_GPIOIEN                 ((uint32_t)0x00000100)2 U3 E' `& M* _$ R
  12. #define  RCC_AHB1ENR_GPIOJEN                 ((uint32_t)0x00000200)+ ]) X  X$ y1 f
  13. #define  RCC_AHB1ENR_GPIOKEN                 ((uint32_t)0x00000400)
4 }8 H! B4 U1 {3 x5 Y0 u6 U
赞 收藏 评论0 发布时间:2022-4-3 15:00
