头文件
5 t# ]5 O0 c& i- #ifndef SD2405_H__$ S# ~: _' [) A- w, p
- #define SD2405_H__
1 u, O) _% Z3 }( L7 r G
, q! R2 h, P7 S. ~- #include "main.h"9 c1 r( C& [- w* @6 t' t) z& a0 g. w; C
- #include "delay.h"
: j: e! y) u, X7 ~2 v# d; H! F
( P, p# S% {; f) f- ' i) i" Q8 e& Z4 z# `9 q
- #define IIC_SCL PBout(13), T+ h" W* F2 q
- #define IIC_SDA PBout(14)
# O ]# D/ v- O' N; x - #define READ_SDA PBin(14)
9 }3 |( n# S- N# r+ i3 {4 k
; h N7 d) x% v+ |) `& R( S6 {7 s- /// SD2405寄存器地址定义 ///
, g4 x+ A: Z8 u1 d3 A p+ ^7 @ - #define SD2405_ADDR_YEAR 6
1 g ]# {3 e) s* K. z# B. J' u - #define SD2405_ADDR_MONTH 5
* X: k$ C+ E' i% f3 {, g - #define SD2405_ADDR_DAY 4; p" ?% |7 F& N: P# e: \7 W
- #define SD2405_ADDR_WEEK 3- c+ A7 m% z- [& b
- #define SD2405_ADDR_HOUR 2
( ?% _# |5 ]% E* p+ P6 W, H) y - #define SD2405_ADDR_MINUTE 1
' x5 V, F; K" W, e! R- ]$ _ - #define SD2405_ADDR_SECOND 0) S. C. u8 ]% f2 k" L
6 j# I4 D+ q; z, |' Y- #define SD2405_ADDR_CTR1 0X0F
& s5 g7 b2 N7 [7 n2 h* k$ A# [; g - #define SD2405_ADDR_CTR2 0X10
* Y. K* q" N J% U' i0 R7 u' I - #define SD2405_ADDR_CTR3 0X11' D; u! ]' m$ t: ]6 w& @: X
- * T" w9 h* R7 q3 B
+ ?( A- T& m& ~- #define UChar2BCD(chr) ((((chr) / 10) << 4) | ((chr) % 10)) ~! E" T6 d* _1 ?* e
- #define BCD2UChar(bcd) ((((bcd) >> 4) * 10) + ((bcd) & 0X0F))! }* i" E2 D/ G4 W5 P
) y5 @( K+ f6 ]& h: p( C- ; s! A) P+ p$ j$ R6 [" v
- #pragma pack(1)
4 e9 v0 m5 n5 f4 y: b - typedef struct
8 A% w8 g6 v, w& v - {
3 `9 g0 B/ J, t+ V; i# M+ [6 m - uint16_t year;: W* H3 F5 Z, |& ?- \9 F( q8 }
- uint8_t month;% a% H4 w5 Y+ R1 e" G2 K
- uint8_t day;, l1 V6 b; o8 x0 J& ^9 i: _
- uint8_t hour;
# @3 d7 ?# r. }/ t& Q! v - uint8_t minute;7 v8 b5 d! ^- d- p+ A7 w9 L. \% I' W+ j9 |
- uint8_t second;( E/ B: f! i/ }9 x8 g& }0 h$ |; W4 e
- uint8_t week;
; B4 q; \ C* b9 ] - }SD2405_DateTypedef;
% H5 X) i0 \- S- X/ J# | - #pragma pack(); K4 n; h+ W( q+ ]1 {2 G
) k. L( c* e$ b- void SD2405_Init(void);9 _2 Z1 L1 Z- D7 e7 U5 q+ B
- void SD2405_Write_Time(SD2405_DateTypedef* date);
) B! z' x K* l; ?/ T" A - SD2405_DateTypedef* SD2405_Read_Time(void);
% |) n; q) d8 U" ^ [. D; _7 ? - : g) j6 U, i$ u! a" F }
- #endif
复制代码 5 Z( Q+ w" U7 T* T' e- h/ S: [
源文件* z1 ]5 i9 g4 B3 M2 T/ y- l
- #include "sd2405.h"4 E7 I. b7 P9 `6 Z0 o; C/ R
- #include <string.h>9 U8 a7 A6 a& a/ C J' v `9 P: C
5 v/ X4 ~$ m& h3 H5 b9 p- void IIC_Init(void)4 D: K* n6 j8 _/ A% H# a
- {( J. u/ p' y4 L0 r" q8 Q7 b- M
- /* 此处添加你的IIC引脚初始化IO的代码,我是直接使用STM32CubeMX生成的 */$ D0 U) h2 N- l7 k# y
- IIC_SCL = 1;6 z C. Y. ^" w' K$ B5 v* T
- IIC_SDA = 1;
- X& ]+ u. Z4 H& j: ~! @# h - }
8 y4 v; S% P! P" Y - 7 C- z9 b) ~' i
- /// 设置IIC的SDA引脚为输出5 k3 i0 O8 p8 P" i% d1 `- |
- void SDA_SET_OUT(void)
r4 _; v( @/ o* ?. ] - {$ x6 \) `( Q. N% y0 x
- GPIO_InitTypeDef GPIO_InitStruct = {0};
. p3 t r( E7 ?' D/ o) l7 a - GPIO_InitStruct.Pin = IIC_SCL_Pin | IIC_SDA_Pin;
4 R9 {2 S. `8 V* B - GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;" W" n+ Q/ ?6 `! t! e) x) v7 ?" Q
- GPIO_InitStruct.Pull = GPIO_NOPULL;! Z" Y( H# K. H+ C% _( G
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
# A$ b7 t7 B1 W% L$ ^/ ^0 `- F - HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
9 n# }9 F0 E" ` n9 p) Q- k9 T - }, V4 f. B1 h8 A2 S6 t0 z1 Q, V; Z y
9 E! a& t, j7 D+ g& x- /// 设置IIC的SDA引脚为输入1 C( Y* |" d0 d. i
- void SDA_SET_IN(void)
1 M. B5 S; b9 @ - {/ c8 d. L& E; C5 y0 v' ^. J% M$ F6 {
- GPIO_InitTypeDef GPIO_InitStruct = {0};: B2 k- A2 r) ~. C; V) J. K, q
- GPIO_InitStruct.Pin = IIC_SDA_Pin;
* W* f0 {; i: z) S5 G2 t - GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;/ p+ q, T0 L7 M: g2 S! g
- GPIO_InitStruct.Pull = GPIO_NOPULL;# h6 @5 B; d9 X T, \9 ?5 b8 L. x' E6 Z
# ^$ J9 l% M2 {! q% z0 ~ - }
3 ]# C) N/ j% l0 b* \
7 I+ u* X% }. J8 i1 g2 Z5 u8 _$ N- void IIC_Start(void). ]! B7 q3 J# u
- {! f% g: H ^4 P6 _/ T/ |/ v
- SDA_SET_OUT();
: n/ J& b. [" d2 c1 k0 \ - IIC_SDA = 1;% W+ Z+ I. P% l F# o( E
- IIC_SCL = 1;
; w4 Q) y; }7 K6 L: U% d1 q - delay_us(5);
/ U8 |( N' n$ t- |* y: C7 p2 t/ @ - IIC_SDA = 0; //START:when CLK is high,DATA change form high to low r$ a* T" ?5 `- |, z* \
- delay_us(6);9 ?) Y% \4 w8 o3 \0 `
- IIC_SCL = 0;; m5 v" I. J8 J
) B r' ~, r E! U
3 p ~9 a; h8 x- X- [8 x- void IIC_Stop(void)
+ E3 Z$ T7 p+ r5 ^ - {
, g% H# b5 e1 C3 H# }/ V - SDA_SET_OUT();
9 @+ [* Q( y% I" K. j9 @ - IIC_SCL = 0;2 ]$ s# Q: l) G5 q0 @1 W: `
- IIC_SDA = 0; //STOP:when CLK is high DATA change form low to high, k4 l8 l& A4 T# I/ l* ?3 [: a8 G0 j
- IIC_SCL = 1;
% _9 M) c3 f/ F, G: H( u - delay_us(6);
# Z% v8 ?9 Z* @$ H* c - IIC_SDA = 1;
" K; x3 ]: l H, A8 i - delay_us(6);
1 \; {9 E, B+ f. @2 K& x - }8 O$ L8 x, ?. }# z* l' D( n
- # R! g! n2 e. X7 M; K- ?+ F
- uint8_t IIC_Wait_Ack(void)
, p+ S; C* U" F- x4 g - {' N5 J% ^2 }# u+ E/ T
- uint8_t tempTime = 0;* ~, R7 m, P$ {3 e$ X
- IIC_SDA = 1;
/ _. }" ~6 l' q0 h9 F1 ] - delay_us(1);
; u* L: B3 d# q' S" y - SDA_SET_IN();+ J* |* |& z' }
- IIC_SCL = 1;8 U* w, G4 k9 ~) r+ B0 s
- delay_us(1);
' V* e" `( ]7 H - while (READ_SDA)
c5 U Z* [7 Q2 x8 a" F( o - {
6 U* ?2 F* |8 s - tempTime++;% U/ Y* d% X2 Y0 t* ]; P! a
- if (tempTime > 250). O/ e9 B2 X7 ]3 @/ V [
0 k/ _7 e& C- c( h: B# o - IIC_Stop();
& D0 w- m* [5 m - return 1;
) B( I: u3 u" B9 ^# J. O7 K - }
7 o3 W4 y' u3 a- I+ R, I - }5 \& ^2 V4 D/ h2 q1 \
- IIC_SCL = 0;2 \# K# X$ i( y2 q8 a! M; q7 L$ w* u
- return 0;5 r" }2 i. {6 F" y) ]* T( u+ F+ d1 Q
& g6 c& ?; {3 j5 K6 s! r& k - 4 ~- e6 ~! D. x' N) E
- void IIC_Ack(void)1 v; k0 }+ _/ g. [/ i. |' Y- t* @
- {( b S, B) ~; s J
- IIC_SCL = 0;
7 D/ f( n3 @' ^4 A) Z- i - SDA_SET_OUT();
. Y. k, t! O& ]1 m# Y- u - IIC_SDA = 0;$ H8 f/ @6 c/ O
- delay_us(2);
( [4 p. E- i' Q: _8 j* q. l; R - IIC_SCL = 1;1 p" q' V/ s% v# z% l; r% Y
- delay_us(5);
4 w& x b Y. |2 @- @& U/ j - IIC_SCL = 0;& E2 R8 c8 t8 V/ c6 F+ J$ _9 G
# E; g- D0 p* }! Z W
! b1 g! W2 ?6 X( v9 `2 ^+ c- void IIC_NAck(void)- B9 ?5 n0 V; D! e( ?7 \
- {, d0 i1 e1 g* v$ j- u0 I9 f* w
- IIC_SCL = 0;* q8 V6 e0 x1 Q% Q9 g
- SDA_SET_OUT();( a, h" i- z: Z: Y9 V |2 v
- IIC_SDA = 1;4 Y5 o& l; f1 k4 r
- delay_us(2);9 d" l b3 I1 x' |- Z
- IIC_SCL = 1;4 V5 [! [* f2 U! Z3 B
- delay_us(5);& r" [0 s3 z2 ^5 G+ A- }
- IIC_SCL = 0;/ b) S; q' U4 A- h
9 z; ~7 u b: w6 h - ' K0 u7 S- ^9 g! A9 i" G& r' O
- void IIC_Send_Byte(uint8_t txd)+ G$ J: k, i: [3 U2 E+ V3 {
- {3 g, R; b: A9 l# O9 U
- uint8_t t;, o3 |& k0 A" g% t4 F, q* I- u% }2 `
- SDA_SET_OUT();+ @1 w* l4 {7 k! I6 i
- IIC_SCL = 0;% L% M. {/ @, O P
- for (t = 0; t < 8; t++)
* U- x7 w$ e* u$ `# R6 x+ @ - {
9 {& Z& T+ q ^. } - if ((txd & 0x80) > 0) //0x80 1000 00004 \$ p% G, q& J' B; l# p2 [
- IIC_SDA = 1;
: x4 ~9 c' H3 D7 V$ ~0 e- p - else& z1 H# T% E6 k. }0 l
- IIC_SDA = 0;
( P i, W( ^: z4 |; g9 H2 @1 Z - txd <<= 1;
; K) O. Z0 I B: `, C9 [1 \, m - delay_us(2);; N$ m, y) B' e+ s4 e- g/ L
- IIC_SCL = 1;
& L: h) z; l3 s2 k, Q" W6 V - delay_us(2);; z) e3 Z9 `6 I$ B# |* X
- IIC_SCL = 0;; ]8 o1 ?8 C( g! ?
- delay_us(2);
. ]8 @; A9 p; G - }
6 R2 ]7 z% D5 q' G6 Y4 A w - }
3 M! c/ C1 c! z- S) v - 5 P- y l& g3 N' k0 n9 `& b% `
- uint8_t IIC_Read_Byte(uint8_t ack)
1 E' _+ U) X) n( e0 \& h- L" g - {
" ^7 A. Y8 w, d2 Y$ H% T& [% G - uint8_t i, receive = 0;
1 c* o. x+ y; W" E - SDA_SET_IN();
8 h+ I) }( S# D; F - for (i = 0; i < 8; i++ )" O. T" w9 t5 q) u' [! O- U& O
- {- E1 B' ?: O, u! z7 {1 b" e
- IIC_SCL = 0;" l& t9 ^% e( ]+ c
- delay_us(2);
7 m; l, M$ z K* n7 W& I3 j/ d" ^ - IIC_SCL = 1;
, w5 |) X. N4 g0 A - receive <<= 1;0 E R, [. B& w( h
- if (READ_SDA)receive++;' V% }7 Y- F) M. s$ s9 g7 a9 N
- delay_us(1);
2 C* \# s: Z- T* _ - }( f0 S3 h! @+ [2 ^
- if (!ack)8 S. M" o' Y; i3 \
- IIC_NAck();6 m# k2 {2 I# |7 o9 H$ c
- else6 S; e' t2 \4 u0 E
- IIC_Ack();) n) z8 j+ ]$ x( X
- return receive;: `" l6 N7 \- R3 R S8 X/ G6 x
- }" p/ e* L4 F- p. a# T9 ~, x5 Y
# G! B$ N! T6 {0 i3 v- void SD2405_Init(void)0 d- I0 E" x; F5 l. {5 T8 z
- {$ c! X, ] U6 u; t' {, @" W
- IIC_Init();
) e5 b2 ^2 z5 m: y9 c, s& s - }
0 z& [. ]; [9 S. g0 |
1 K- {6 B. R7 C. l/ f- void SD2405_WriteOneByte(uint8_t WriteAddr, uint8_t Data)3 H( ^5 D O; V( L* {6 B
- {( ~. ~0 _. e+ w, Y
- IIC_Start();6 E2 l, V& h* k
- IIC_Send_Byte(0x64);: c/ C7 @# D3 X/ O+ _4 W A
- IIC_Wait_Ack();+ I: \9 n' ]7 {) }6 n0 w6 N
- IIC_Send_Byte(WriteAddr);
- P$ `- f* D4 K) @: t - IIC_Wait_Ack();
) K* Z( j& a+ L7 b6 ] - IIC_Send_Byte(Data);7 C% T: ?8 z% g
- IIC_Wait_Ack();
0 _/ r- o2 z' E) e - IIC_Stop();
3 y& ]* U* h" ~ - delay_ms(10);
: @3 O: S' Y8 h( v. [ - }' W s1 D$ g0 k0 u8 w
. ?2 b+ K, ^2 D( J& ]- uint8_t SD2405_ReadOneByte(uint8_t ReadAddr)* I6 i4 ^+ p$ h1 l- G
\" p; F/ O* q% l0 k2 t- Q - uint8_t temp;
* k' Y3 W* U9 G2 u$ l: Z - IIC_Start();
Y% T6 S3 U4 \6 S J6 }( s2 { - IIC_Send_Byte(0x64); j# b% c. X/ O% {* ~% {. q& f
- IIC_Wait_Ack();" T6 ?+ V0 L: A
- IIC_Send_Byte(ReadAddr);1 d/ t a, E- p7 c
- IIC_Wait_Ack();
) G# n0 y& o( G - IIC_Start();0 M. w( ?) i8 u: O. ]7 q( j
- IIC_Send_Byte(0x65);
: Y( V- b% w- C9 n' l( R - IIC_Wait_Ack();
9 G' |! A+ K1 b2 q3 [+ [2 j - temp = IIC_Read_Byte(0);
0 u5 |* M+ W2 s& X( m' \ - IIC_Stop();1 Y( i4 e( e3 ^+ G9 B
- return temp;8 m7 K" C, Q! Z3 Y/ I5 @3 O
- }3 c; ?, \3 i8 M, D0 y$ g# V- V
- H/ w+ I3 \$ z/ K8 k+ ~6 d- /// 使能写* O b% z2 k8 I
- void Write_On(void)
, S- D5 V" J6 A% n8 X. o - {
! X* k! S. _" ]. U/ }! f - SD2405_WriteOneByte(SD2405_ADDR_CTR1, 0x84);
6 r! ]+ D4 g5 b3 Y3 J d J - SD2405_WriteOneByte(SD2405_ADDR_CTR2, 0x80);
4 h2 \4 \- b* {8 S - }
( B. U1 o4 P+ X' T% x$ i
6 x' b, r/ D: j3 |3 i- /// 禁止写
7 X+ {7 W( `: ` - void Write_Off(void)
% X' c2 c. B2 L; N, Z9 M - {$ K _* d9 T9 z
- SD2405_WriteOneByte(SD2405_ADDR_CTR1, 0x00);
0 x4 b8 ?6 O3 y# Y5 \ - SD2405_WriteOneByte(SD2405_ADDR_CTR2, 0x52);
( y- ?- R3 v2 R- F: |2 o' s2 h- S, C - }% r8 k, V2 i- l
- + z5 L6 J: w7 {6 I& J3 `' Z+ ^
- /// 写入时间
# U/ j+ C) S. ]& Q, P - void SD2405_Write_Time(SD2405_DateTypedef* date)
) x9 [, A2 Z$ E+ t L' M; x - {
: ?6 j) S- v0 j! J - Write_On();# h/ F9 D& V' J2 Y( r
- SD2405_WriteOneByte(SD2405_ADDR_YEAR, UChar2BCD(date->year - 2000));
* Y$ B* s# A- [' v - SD2405_WriteOneByte(SD2405_ADDR_MONTH, UChar2BCD(date->month));
% v. y0 h4 y6 |+ a" q5 t. `9 J - SD2405_WriteOneByte(SD2405_ADDR_DAY, UChar2BCD(date->day));
4 N- _: ]7 R7 }5 L0 ? - SD2405_WriteOneByte(SD2405_ADDR_HOUR, UChar2BCD(date->hour) | 0X80); /* 24小时制 */2 L9 L; Y2 _; q+ n4 L/ j- @. r
- SD2405_WriteOneByte(SD2405_ADDR_MINUTE, UChar2BCD(date->minute));
; x: y. m5 y( X B/ d" H - SD2405_WriteOneByte(SD2405_ADDR_SECOND, UChar2BCD(date->second));
5 d# w+ K. H" Q1 ~* V - SD2405_WriteOneByte(SD2405_ADDR_WEEK, UChar2BCD(date->week));0 h4 Z' [2 F8 q" s# w# c
- Write_Off();
, d/ H0 A6 f3 U - }
E4 D. }1 l0 d2 R/ j1 \ - 1 g+ I) @+ ~* Q# F
- /// 读取时间' ^/ i' W. g; p7 d9 ]+ B, m
4 W2 X$ p$ A3 J2 t& A - {, c! h5 q! ?5 ~. E6 E: T
- static SD2405_DateTypedef time;
9 |/ Y+ @2 [7 T$ a ~ - memset(&time, 0X00, sizeof(SD2405_DateTypedef));% e8 P) @& h/ J$ A
- time.year = SD2405_ReadOneByte(SD2405_ADDR_YEAR);! _) h& J; V5 ?0 M' I1 H
- time.month = SD2405_ReadOneByte(SD2405_ADDR_MONTH);
3 b6 L( g: w; b" l - time.day = SD2405_ReadOneByte(SD2405_ADDR_DAY);
0 V+ g( I; n3 s9 I3 I& l# s0 ] - time.hour = SD2405_ReadOneByte(SD2405_ADDR_HOUR);- y q3 r& B; ]1 `) b/ i- X, y
- time.minute = SD2405_ReadOneByte(SD2405_ADDR_MINUTE);2 p3 Q v7 a+ Y* f, I( X! }
- time.second = SD2405_ReadOneByte(SD2405_ADDR_SECOND);9 z% Q; T. z' y# s7 @
- time.week = SD2405_ReadOneByte(SD2405_ADDR_WEEK);2 \4 e+ v/ l; e1 f: b
- time.year = BCD2UChar(time.year) + 2000;8 L: Z0 G% }" W& O6 V' G2 w1 X
- time.month = BCD2UChar(time.month);
# J ]" W9 K* p - time.day = BCD2UChar(time.day);
! q' n- a- `& K - time.hour = BCD2UChar(time.hour & 0X7F);( ^: w( U& N0 l5 ], t
- time.second = BCD2UChar(time.second);# I: ?+ R& S* e
- time.minute = BCD2UChar(time.minute);
' C+ M) W' G' @% T- o/ Y- E - time.week = BCD2UChar(time.week);) ?9 H" ?* ^. `$ A( s9 f
- return &time;4 S9 m @! P z4 l
- }' t5 s# V" k: p0 h @4 U
- * n# G( f3 C% Y& E- N5 Q
复制代码 $ F9 @. X) _4 R1 B" i( H" _
+ K4 t+ ~0 F1 D0 l* X5 Q
% A5 ^6 c; q& p
