发布时间:2022-4-15 10:00
问题表现( k) A3 ^3 T4 P9 u5 n8 a+ w4 e 在MCU系统负载较重、串口收发数据频率很高、多个中断存在(如同时有定时器更新中断、外部中断、DMA中断、串口接收中断)的情况下,容易出现串口溢出错误(ORE)。该错误的主要显现形式是:程序莫名卡死在串口中断之中(单片机失去响应)。 解决方法9 [4 @2 c, M" E2 X ORE标志位在USART_SR寄存器,当我们打开串口接收中断时,同时也就打开了ORE中断,串口的overload错误会导致程序反复进入串口中断服务程序。在中断服务程序中增加处理overload的处理,顺序执行对USART_SR和USART_DR寄存器的读操作可以复位ORE位,以防止程序反复进入串口中断服务程序。示例代码如下: 在STM32中断函数增加USART_IT_ORE等异常中断的处理,执行USART_GetFlagStatus(USART1, USART_FLAG_ORE),会对USART_SR进行了一次读操作,然后再执行USART_ReceiveByte(USART1),会对USART_DR进行一次读操作,从而复位了ORE位。* R- ?& Q4 j$ g- s0 R$ h. h( p : _; o6 A9 i( C /** * @brief Checks whether the specified USART flag is set or not. * @param USARTx: Select the USART or the UART peripheral. * This parameter can be one of the following values: * USART1, USART2, USART3, UART4 or UART5./ [' C4 t! J5 w9 o' r. ? * @param USART_FLAG: specifies the flag to check. * This parameter can be one of the following values: * @arg USART_FLAG_CTS: CTS Change flag (not available for UART4 and UART5) * @arg USART_FLAG_LBD: LIN Break detection flag. s+ `7 A) \; [+ t4 v0 Z, J; P9 _ * @arg USART_FLAG_TXE: Transmit data register empty flag" G, l; @' s0 Y) X) c * @arg USART_FLAG_TC: Transmission Complete flag8 U. e3 g# @9 {1 x" y5 c4 R- `- P * @arg USART_FLAG_RXNE: Receive data register not empty flag * @arg USART_FLAG_IDLE: Idle Line detection flag * @arg USART_FLAG_ORE: OverRun Error flag * @arg USART_FLAG_NE: Noise Error flag * @arg USART_FLAG_FE: Framing Error flag * @arg USART_FLAG_PE: Parity Error flag * @retval The new state of USART_FLAG (SET or RESET). */: k6 }0 o0 G/ T6 v: H$ _ FlagStatus USART_GetFlagStatus(USART_TypeDef* USARTx, uint16_t USART_FLAG)$ H$ U5 X8 U8 K/ E {; g0 g3 Z# L# `5 ] FlagStatus bitstatus = RESET;- a& k. T: s" ?2 e- E- Z) E$ z0 d /* Check the parameters */ assert_param(IS_USART_ALL_PERIPH(USARTx)); assert_param(IS_USART_FLAG(USART_FLAG));+ ^4 T6 ?- j, V1 r( D* }% y /* The CTS flag is not available for UART4 and UART5 */ if (USART_FLAG == USART_FLAG_CTS) { assert_param(IS_USART_123_PERIPH(USARTx));$ {# |$ g2 R$ H7 B1 [ } if ((USARTx->SR & USART_FLAG) != (uint16_t)RESET) { bitstatus = SET;2 x5 ?- A5 u2 a } else {4 P+ q6 O. R/ Y; G$ p6 ~& `( I bitstatus = RESET; }. e5 J! a! o( n# |9 J5 S+ n1 ^8 l return bitstatus; } ' S5 \. h5 {* J$ s & H4 _: {, ~, J! h/ e6 @/ C+ b! a /*** w& @/ N' d) c0 T * @brief Returns the most recent received data by the USARTx peripheral.4 r. w0 Y$ P+ @% }9 P * @param USARTx: Select the USART or the UART peripheral. * This parameter can be one of the following values: * USART1, USART2, USART3, UART4 or UART5. * @retval The received data. */- u1 r/ W( i# Y, l1 S" Y! N uint16_t USART_ReceiveByte(USART_TypeDef* USARTx). s& z9 M% {* w* Z {" |' z& P1 z3 M/ E6 a6 @ /* Check the parameters */ h) }5 T* E, s$ u assert_param(IS_USART_ALL_PERIPH(USARTx));) I2 S0 N! E* M* w2 x4 s /* Receive Data */! b. _" i3 s6 D+ A% a O! |3 n return (uint16_t)(USARTx->DR & (uint16_t)0x01FF);2 S* k3 W8 n* ~, s7 @% C }! q" d5 K4 u1 d1 I/ {3 s$ z# t k" N( x6 C0 U& b; T1 ^+ |* z+ k' Y 1 h; g0 a3 V8 m2 s5 q, F $ J8 k! f y: |9 {: C void USART1_IRQHandler(void) {7 G) H' B9 H7 ?3 O4 g6 [: K5 ^( n; C /*** L. E8 D* }, H6 Q5 Y3 \5 ] * 如果使能串口接收中断,那么ORE为1时也会产生中断。 * 在应用中对ORE标志进行处理,当判断发生ORE中断的时候,8 L! Z; v5 V8 i * 我们再读一次USART_DR的值,9 m2 |: B- h! E. A8 f * 这样如果没有新的Overrun 溢出事件发生的时候,ORE会被清除, * 然后程序就不会因为ORE未被清除而一直不断的进入串口中断/ M. i) E8 }2 [5 { ]+ f4 I */% o* O7 `, G6 l% P 3 t6 E# }; K, m) I: n //没有使能USART_IT_ERR中断时,ORE中断只能使用USART_GetFlagStatus(USART1, USART_FLAG_ORE)读到 if(USART_GetFlagStatus(USART1, USART_FLAG_ORE) != RESET). U, I$ H" \& k/ g" o3 s) a {8 F7 k* j/ T. h8 |% y, p+ @0 M- C //(void)USARTx->SR;& h4 Z( t/ }4 ?- W9 z; b //(vois)USARTx->DR; //先读SR再读DR寄存器6 X9 r8 e7 w1 q( c l ! q1 U& p! O% \. F- K4 ?9 F* n& | USART_ReceiveByte(USART1);7 h F& D2 A) A , O$ B3 _- ?3 K+ v: t7 y //USART_ClearFlag(USART1, USART_FLAG_ORE); } 1 o7 _5 c* z4 {8 ] r //处理接收到的数据(示例为FIFO缓冲队列)9 H; y5 _: G9 q& p Y if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)% K) w7 } W9 K+ a2 a9 k { USART_ClearITPendingBit(USART1, USART_IT_RXNE);: m& E; h9 G" ] _! L% d *USART_RevPointer[0][0] = (u8) USART_ReceiveByte(USART1); USART_RevPointer[0][0]++;6 Y; E; O. A( J, ~& [3 J3 o$ o USART_RevCount[0]++; if (USART_RevPointer[0][0] >= USART_RevBuffer[0] + USART_BufferSize[0]) USART_RevPointer[0][0] = USART_RevBuffer[0];) {( |& T7 S" ~1 z3 Q# t! c0 w }, [ b$ b8 q% Y# Y } 4 V, a3 m; w+ ?% x# N& U1 O 3 o$ L/ { \4 f f) ` |
想找个ST芯片
技术手册stm32f1xx中的一个小问题
实战经验 | Keil工程使用NEAI库的异常问题
STM32几种流行开发环境的优缺点
好用软件推荐-TouchGFX Designer
