一、TM1616原理图+ @" ` o/ b+ O6 V# i% a
! U h) j2 n% x8 [- n
$ p, w) S0 ~4 W: a! i6 \; |. r8 |3 w+ v) M. |. C8 a" y
二、驱动程序+ y) c) P& c. b7 n$ k c
, s9 `% i3 D$ C9 t$ y
- #include "led.h"; ?. l2 a, R9 ~' Q
- ) q0 b; o. m+ y7 e+ X u- \& k
- $ S' Y+ |& n# Z! m1 y
- void led_init(void)
{; ]( p6 g8 O4 G( C v+ w9 I6 k - {9 O1 O6 D: x% Y
- GPIO_InitTypeDef GPIO_InitStructure;) _3 W7 o9 _/ T
/ @: k! ]+ u! x- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE, ENABLE);
- {" z- T5 R1 j# W+ [. K
9 T0 N0 M. ], K, L1 Z3 z! U1 R' c% B- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
3 e0 }# B* n4 @$ k' M - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;% g2 ?* c5 y8 ~& o1 j0 d
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
. n# f1 q4 I9 X - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;4 w" f' f% ]) K2 \6 q
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
' K& g5 p ~0 [( H9 x! L; Y' V% ? - GPIO_Init(GPIOC, &GPIO_InitStructure);
$ q# Z. e# F" F% x5 ?% h* W& V0 g3 o0 T -
$ f9 d% c4 K3 Z2 g# G) U$ i x - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;2 O, T# G! A8 d; z0 Z# F8 n9 ~
- GPIO_Init(GPIOD, &GPIO_InitStructure);: Z4 C/ B+ j3 a$ F0 a- p, M) P
- ; z+ L/ R) c* @
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;( t. U0 l% k2 c) X( w
- GPIO_Init(GPIOE, &GPIO_InitStructure);0 y! W M4 O: q- V, o# n
7 ?) t! L( [, X7 |! O- GPIO_SetBits(GPIOC,GPIO_Pin_0);
. T" _& u5 @/ X4 w; q - GPIO_SetBits(GPIOD,GPIO_Pin_13);2 `* b# j# m$ J: u/ ^
- GPIO_SetBits(GPIOE,GPIO_Pin_6);
5 u* H& @* ?$ U+ {, @# ? - }
7 j& g9 j& \% t - & r) C/ S# n# n. W3 _4 i; T$ s! F
- void led_delay(u8 i)$ a4 V4 V. V1 V- j/ X( ]" U
% f N' U3 K$ G. l9 ` D" f3 m - while(i>0)- ^$ @; [1 u; {, j9 M
- i--;6 A7 E3 k: Y1 E8 c4 \% w' i
- }. G' E; G. k& j; A) H8 N
- 1 Y5 o/ S) J1 D* `3 z
- void led_write_data(u8 data)
. j) B3 g4 ^5 J' y0 e+ C' @ - {
) k4 _9 U7 `7 P- q0 `+ U. z' l - u8 i;0 G0 P2 f8 a0 I
- for(i=0;i<8;i++)
2 }! V m+ G( H/ S/ } - {
, _' o3 g- y, i# x, B9 W5 B: s: k/ p - led_clk=0;' t7 v0 N3 |) B5 R
- if(data&0x01)0 u+ P, [9 u' Y8 G9 t* ?" T, ?
- led_dio=1;
# ]. m F S9 \, \/ h - else
) C8 ]( v# @8 m! N% C! Y - led_dio=0;1 M/ n/ r4 R$ U0 m1 Y$ G
- data>>=1;) N! ~& ]/ C" |5 H% G2 G& \- l2 u1 @
- led_delay(2);, b# R: y$ W' N7 s4 S7 N9 |3 t
- led_clk=1;) Y; Q; K C9 N9 `# i a- X& r
- }, g9 U6 G) k, Q/ J7 b5 J; d% S
' |2 u7 D* s; G: s2 s$ J9 C( u - B+ y, f4 ]% }/ V4 _6 X
- void led_show_data(u8 *showData)
5 C! s, `( j$ \# ~ Y& b - {+ o- f! `1 o' {9 n" M; w# G" m
- led_stb=0;" q& s0 Q( J' a
- led_delay(2);/ q" I) L& e: l8 w; Y3 J$ j j, h6 P1 m
- led_write_data(0x00); //设置数据命令
# Y* g0 B8 i% _6 r3 O! B - led_stb=1;- l/ h8 g3 U( i4 ^! R
- led_delay(2);; u4 L6 h7 L' {& P" Y
- led_stb=0;
9 l) R" V( u7 M9 z$ S - led_delay(2);2 Q% i2 i. F' R5 t2 Y3 p
- led_write_data(0x40); //设置数据命令
2 N, k0 H- F) ?* R4 f; y4 C - led_stb=1;7 f) ?' _5 w. i$ x6 u b+ [! P9 O" r6 t
- led_delay(2);
& n& F. \! r) ?9 [ - led_stb=0;. b2 s6 \( }: u$ r( q
- led_delay(2);7 D9 |# z3 H0 o& }
- led_write_data(0xc0); //设置显示地址
; K G |+ A. V- s. V* B! H0 k1 U -
: i# \; h: G Q+ J - & A: X1 Y* m6 e3 g
- led_write_data(showData[0]); //设置显示数据1 }' \" R( {4 R1 _
- led_write_data(0X00); //设置显示数据
" K) `1 m; o% l( O! d1 C; n. \ - led_write_data(showData[1]); //设置显示数据! ^: ?, Z" Q' {3 p
; o9 R8 p" M; Y; I5 B - led_write_data(showData[2]); //设置显示数据( M1 m! N( b# [
0 D; a: d, ?3 O' ]7 H1 k - led_write_data(showData[3]); //设置显示数据
7 l! f) o/ \7 m$ Y& { -
5 w7 [- v- Q ?& a - led_stb=1;
+ U9 M& H1 z- [ - led_delay(2);" M. \# Q$ e* `* f8 G
- led_stb=0;
! X4 F+ I0 h2 o* z3 w. C - led_delay(2);
3 |" b# E, b% a) Y. U, v7 v - led_write_data(LED_ON|LED_BRIGHTNESS_3); //设置显示控制命令; _- J$ f7 J# k0 h
- led_stb=1;
9 n4 R Y$ G n - led_delay(2);2 R/ e0 D% s# E
- } o% P( P4 a! f
- ' K0 s( D& p) b' k( o7 v, a
- 5 D( V+ u2 }, a) P6 }4 T
3 E2 k/ w. c" I* }
复制代码 : E- m+ t4 D0 u. ^& S
