【经验分享】STM32 中断相关函数和类型
STMCU小助手 发布时间:2022-6-13 10:12
01. 概述6 [- _6 e& a1 O  ]$ j; p2 d9 ~! ~
中断相关代码主要分布在固件库的 stm32f4xx_exti.h 和 stm32f4xx_exti.c 文件中。6 _- U, F7 L* |) q
4 u7 x0 _' S! j7 H$ @0 c2 r02. 相关类型$ l+ A4 w/ U3 v. c5 f
EXTI模式枚举
  1. /**
    : ?2 Y; N2 t9 N1 x" r
  2.   * @brief  EXTI mode enumeration
    . O$ p; w# ~2 A" P/ T, C
  3.   */
    $ a, }; o( h/ a0 q2 i
  4. * Y( ~4 I. v/ l( `4 {0 H8 x% w
  5. typedef enum* q8 ]# |& K; J3 v
  6. {
    3 v  k( Y- s8 B0 I- P! b  \7 X
  7.   EXTI_Mode_Interrupt = 0x00,5 a# o1 ?; j5 {  R- B+ w( I
  8.   EXTI_Mode_Event = 0x048 ]& i( L- {& U* R% d
  9. }EXTIMode_TypeDef;& D$ c3 I& z2 h3 O3 ^, e
  10. / |/ B) i& [( ^/ T' ~- |0 J
  11. #define IS_EXTI_MODE(MODE) (((MODE) == EXTI_Mode_Interrupt) || ((MODE) == EXTI_Mode_Event))2 M& j- F, E, z% f) C
& U9 d  I: ^. P
* L2 B3 t+ e+ V1 M. E0 D1 \EXTI触发枚举& ?; M1 W4 f3 I
  1. /** ; ~6 y" f* [# K
  2.   * @brief  EXTI Trigger enumeration
    1 h: R% f! Q9 G8 N* D$ q3 W! a2 b
  3.   */
    , N% t) `1 B2 U; J# v
  4. / z4 s, q2 J5 F
  5. typedef enum
    + ~8 T6 g) \0 H. |/ Q
  6. {
    0 q$ Q1 B6 j1 d" c  L& l: g5 |
  7.   EXTI_Trigger_Rising = 0x08, //上升沿
    8 ]* N5 l/ c1 |; L& X- L: A
  8.   EXTI_Trigger_Falling = 0x0C,  //下降沿
    7 k$ n: H, J9 E3 f8 O, I/ B5 z* W- [
  9.   EXTI_Trigger_Rising_Falling = 0x10 //边沿触发7 b  }7 N- o8 g! m
  10. }EXTITrigger_TypeDef;9 _$ v) P, }2 v1 o9 ^. m: g
  11. 7 U( p" {' |1 W
  12. #define IS_EXTI_TRIGGER(TRIGGER) (((TRIGGER) == EXTI_Trigger_Rising) || \
    ; k' M$ k: Z+ k) b% R2 J
  13.                                   ((TRIGGER) == EXTI_Trigger_Falling) || \
    , v1 S; I# Y1 {: ~9 s& w+ ?
  14.                                   ((TRIGGER) == EXTI_Trigger_Rising_Falling))
    & G. ^1 c0 e; q2 I  c8 w
+ S" X6 o5 t: Z. q! l; U4 G9 jEXTI初始化结构体5 X* Y0 I% y2 F9 c
  1. /**
    : ~5 O( z" R. o) I3 ~* M: z  j# R
  2.   * @brief  EXTI Init Structure definition  / B  W" l/ _6 B# y  }5 i8 R& f
  3.   */
    ( P+ Y" |* g9 T' X) Y
  4. 7 ^+ z0 F5 [8 w" h0 K
  5. typedef struct/ m9 K5 \; K3 O* A+ J8 Q4 G) R
  6. {, C' W; J$ T- N7 U
  7.   uint32_t EXTI_Line;               /*!< Specifies the EXTI lines to be enabled or disabled.4 S4 i, y9 L# q$ L! x* N& N. U
  8.                                          This parameter can be any combination value of @ref EXTI_Lines */
    ; @$ b3 `: p4 I+ f9 R
  9.
    7 B8 B+ F. U0 J4 g% [9 w5 U1 }6 f) N
  10.   EXTIMode_TypeDef EXTI_Mode;       /*!< Specifies the mode for the EXTI lines.: e0 s" B" S1 A
  11.                                          This parameter can be a value of @ref EXTIMode_TypeDef */
    . N8 K9 S8 R2 f. U; F; C  C" J( I
  12. 5 t' c. l; W6 F5 h6 Q+ y6 o/ X
  13.   EXTITrigger_TypeDef EXTI_Trigger; /*!< Specifies the trigger signal active edge for the EXTI lines." W0 z* M! T; E: q% l% D
  14.                                          This parameter can be a value of @ref EXTITrigger_TypeDef */
    1 d" ~: Y$ x( B& G* H
  15. 2 Q$ y! o4 n/ Z7 o9 V& P
  16.   FunctionalState EXTI_LineCmd;     /*!< Specifies the new state of the selected EXTI lines.; u) c. t3 {% J5 u5 S
  17.                                          This parameter can be set either to ENABLE or DISABLE */ # Z* U( W1 g& `) ]( \( t; A" w
  18. }EXTI_InitTypeDef;
    3 O1 k; [3 P. H# d
6 O; L1 ?( i0 D6 q! R  P
外部中断线
4 g4 Z; J- Z- R
  1. /** @defgroup EXTI_Lines ; }) Z4 L4 h7 O7 s  W
  2.   * @{
    ) y0 {* p1 s. d
  3.   */& b& }) H* ?2 ]7 ~. F, \; t! r
  4. 6 D" j6 Z" G% I
  5. #define EXTI_Line0       ((uint32_t)0x00001)     /*!< External interrupt line 0 */
    9 l* q: m+ l" l
  6. #define EXTI_Line1       ((uint32_t)0x00002)     /*!< External interrupt line 1 */: J! d6 V- M* R, J: |6 R- g! e
  7. #define EXTI_Line2       ((uint32_t)0x00004)     /*!< External interrupt line 2 */1 g/ {, t* h9 S& |( D- `7 @
  8. #define EXTI_Line3       ((uint32_t)0x00008)     /*!< External interrupt line 3 */
    7 |: L+ F; U* n% G
  9. #define EXTI_Line4       ((uint32_t)0x00010)     /*!< External interrupt line 4 */$ i' F# h9 C. {, j  Q2 Y, P5 H
  10. #define EXTI_Line5       ((uint32_t)0x00020)     /*!< External interrupt line 5 */8 ^! L3 s, k6 N( J% S" k6 `1 W( l
  11. #define EXTI_Line6       ((uint32_t)0x00040)     /*!< External interrupt line 6 */# x" Z8 i( h; X9 A' R
  12. #define EXTI_Line7       ((uint32_t)0x00080)     /*!< External interrupt line 7 */
    - J5 r$ p3 Q% Q; T$ `
  13. #define EXTI_Line8       ((uint32_t)0x00100)     /*!< External interrupt line 8 */
    : i: r) Z& `- m/ D0 A
  14. #define EXTI_Line9       ((uint32_t)0x00200)     /*!< External interrupt line 9 */
    $ J0 L* p: w, S/ R; H% q6 S
  15. #define EXTI_Line10      ((uint32_t)0x00400)     /*!< External interrupt line 10 */2 E& [: A) b0 }. K! F  s1 e1 P( m, ^
  16. #define EXTI_Line11      ((uint32_t)0x00800)     /*!< External interrupt line 11 */1 y  `2 Y4 U5 ~7 f  m
  17. #define EXTI_Line12      ((uint32_t)0x01000)     /*!< External interrupt line 12 */1 R) i7 R2 N1 Z6 `# D" H9 ^
  18. #define EXTI_Line13      ((uint32_t)0x02000)     /*!< External interrupt line 13 */
    # V6 Z6 S  b+ o' g! }! B4 e9 ]
  19. #define EXTI_Line14      ((uint32_t)0x04000)     /*!< External interrupt line 14 */$ s; O+ V/ ]* A1 x- d
  20. #define EXTI_Line15      ((uint32_t)0x08000)     /*!< External interrupt line 15 */  i7 n  [+ d3 m, B0 ]% O
  21. #define EXTI_Line16      ((uint32_t)0x10000)     /*!< External interrupt line 16 Connected to the
    ( d% Q& m  z% r, [
  22. PVD Output */
    ) e2 s" u6 d9 s9 X/ O$ a9 b+ _
  23. #define EXTI_Line17      ((uint32_t)0x20000)     /*!< External interrupt line 17 Connected to the6 A  L* q, y( N4 `* M' D
  24. RTC Alarm event */* y* c& D6 l: a. f! U. v, v
  25. #define EXTI_Line18      ((uint32_t)0x40000)     /*!< External interrupt line 18 Connected to the- C; e5 O5 l" N! }6 |+ E  X
  26. USB OTG FS Wakeup from suspend event */                                    * w- e5 u% l1 [/ v- C$ B4 ^8 V
  27. #define EXTI_Line19      ((uint32_t)0x80000)     /*!< External interrupt line 19 Connected to the
    , R1 F/ G9 p) Z
  28. Ethernet Wakeup event */
    + h: f4 ^2 g/ b1 n: y7 i
  29. #define EXTI_Line20      ((uint32_t)0x00100000)  /*!< External interrupt line 20 Connected to the
    $ `3 C: k0 {& V# w2 M1 `
  30. USB OTG HS (configured in FS) Wakeup event  */
    ( e& r- K: D. b9 @* o5 }
  31. #define EXTI_Line21      ((uint32_t)0x00200000)  /*!< External interrupt line 21 Connected to the
    ; z7 a8 C+ S7 m3 o
  32. RTC Tamper and Time Stamp events */                                               ! E0 v: q% \: c. b4 [
  33. #define EXTI_Line22      ((uint32_t)0x00400000)  /*!< External interrupt line 22 Connected to the
    ) ~5 b9 X) ^( d7 J! U, X* @
  34. RTC Wakeup event */
    , @& R% i7 k8 o6 ?! f: B
  35. #define EXTI_Line23      ((uint32_t)0x00800000)  /*!< External interrupt line 23 Connected to the
    1 @# j2 m0 x+ Q6 Q3 J: V5 G
  36. LPTIM Wakeup event */' P3 }3 K3 W" n
  37. ! S" t" y9 h4 ~& K- ^3 A3 R: t9 S
  38.                                           , V  P3 n8 h1 \8 |( r
  39. #define IS_EXTI_LINE(LINE) ((((LINE) & (uint32_t)0xFF800000) == 0x00) && ((LINE) != (uint16_t)0x00))
    / a6 P, x0 q0 a( }2 K0 F
  40. 7 O% |$ q& \* }, ]( _' y& z8 e
  41. #define IS_GET_EXTI_LINE(LINE) (((LINE) == EXTI_Line0) || ((LINE) == EXTI_Line1) || \
    ( _( o/ j, g$ _2 y2 c, {2 B  e1 B
  42.                                 ((LINE) == EXTI_Line2) || ((LINE) == EXTI_Line3) || \
    & }5 |7 s0 \% f' @: e; _, M# f5 t9 L
  43.                                 ((LINE) == EXTI_Line4) || ((LINE) == EXTI_Line5) || \
    + {3 j7 i1 ]$ \1 v( U( c
  44.                                 ((LINE) == EXTI_Line6) || ((LINE) == EXTI_Line7) || \& W! I7 S" {: [0 J; ?% x
  45.                                 ((LINE) == EXTI_Line8) || ((LINE) == EXTI_Line9) || \
    8 E* e2 R. k  X1 U' a8 G
  46.                                 ((LINE) == EXTI_Line10) || ((LINE) == EXTI_Line11) || \
    % |' x" S2 u* M. s6 b* Z/ j2 K- y5 v
  47.                                 ((LINE) == EXTI_Line12) || ((LINE) == EXTI_Line13) || \3 X0 z' U/ G; G. A$ y' t/ n$ {
  48.                                 ((LINE) == EXTI_Line14) || ((LINE) == EXTI_Line15) || \
    . a2 `/ @: `# Z+ e
  49.                                 ((LINE) == EXTI_Line16) || ((LINE) == EXTI_Line17) || \
    # f4 {& u" X3 }, a$ }
  50.                                 ((LINE) == EXTI_Line18) || ((LINE) == EXTI_Line19) || \
    8 ^. H- R6 J5 J. q& u2 ~6 V# C
  51.                                 ((LINE) == EXTI_Line20) || ((LINE) == EXTI_Line21) ||\( U1 R% d# |/ |" L) r  R
  52.                                 ((LINE) == EXTI_Line22) || ((LINE) == EXTI_Line23))
    $ c' O/ m# Q* s$ ?# f
  53.
    ) p6 C+ Z. W# ^! r- ]
" v! F- ?) G2 v9 d
03. 相关函数
) G3 o! f: P/ I) e6 q% l$ F& O
  1. /* Exported macro ------------------------------------------------------------*/$ j. T7 p: Z& {0 J8 q+ M* x
  2. /* Exported functions --------------------------------------------------------*/. s  q4 _2 F9 [; m! P
  3. . z- s& r6 q, j" Z( O( R
  4. /*  Function used to set the EXTI configuration to the default reset state *****/: i; E( \3 z+ M% E2 z. j' U/ A
  5. void EXTI_DeInit(void);3 J' O# ?" Q1 l) f
  6. % ~: `% Q: s6 q( [' N
  7. /* Initialization and Configuration functions *********************************/
    8 S# ]# T3 i+ Y2 ?- k
  8. void EXTI_Init(EXTI_InitTypeDef* EXTI_InitStruct);/ J1 q: i2 x: y7 u& c; U9 _7 u: \
  9. void EXTI_StructInit(EXTI_InitTypeDef* EXTI_InitStruct);
    3 H, a. f) Y- s' ^) D
  10. void EXTI_GenerateSWInterrupt(uint32_t EXTI_Line);* x4 d2 v$ C+ Z) {6 r/ s
  11. * ~+ O" O- h6 R' \" N
  12. /* Interrupts and flags management functions **********************************/8 q  d. l# P* l6 C: [
  13. FlagStatus EXTI_GetFlagStatus(uint32_t EXTI_Line);
    7 o5 o5 v1 S2 L* A8 w( G0 C/ K$ F- Y5 N
  14. void EXTI_ClearFlag(uint32_t EXTI_Line);0 R" _  _& O, @" {0 h" B
  15. ITStatus EXTI_GetITStatus(uint32_t EXTI_Line);( E6 e* X  |+ s3 P7 v
  16. void EXTI_ClearITPendingBit(uint32_t EXTI_Line);# n3 V6 A4 N; ?9 W3 ]
% Q- [$ j/ |# O- n
: y" ]! o7 E+ g9 y& ?
) n; Y1 ?( G: n2 U
" z8 _  n/ D9 i. R; h) I& Q# n
赞 收藏 评论0 发布时间:2022-6-13 10:12
