01. TIM概述9 C" v; H( ^# Q6 c' B4 w: x
stm32f4xx_tim.h和stm32f4xx_tim.c文件中) o2 T4 q/ z; W7 S1 J4 W# w
* c1 m- ~' ]( U$ Y6 p" d02. 相关类型& f5 e+ _. ?! j, T. o
TIM_TimeBaseInitTypeDef
! K( |7 L" ? V6 {" l, |$ L5 k
0 z( N# A P/ o% A. m$ u0 c- /**
3 s: C0 \1 A! H$ _+ I( ~ - * @brief TIM Time Base Init structure definition
6 }* t3 Q+ A1 \% w' i" a2 d - * @note This structure is used with all TIMx except for TIM6 and TIM7. W' I4 D$ y z. u
- */6 d% Z/ S$ f# |* u
: _, F+ X7 w2 s- typedef struct G6 {1 N+ g6 M) K1 W) o
+ L0 L5 E) Q, P. l+ j5 }2 T- { - uint16_t TIM_Prescaler; /*!< Specifies the prescaler value used to divide the TIM clock.
1 j* p& @5 P1 g5 Z& J6 t - This parameter can be a number between 0x0000 and 0xFFFF */( I4 f% i, C7 X3 C$ o
) z3 O/ T% ]+ d! J- uint16_t TIM_CounterMode; /*!< Specifies the counter mode.1 h7 l' r% _& d( m8 t
- This parameter can be a value of @ref TIM_Counter_Mode */
/ J' ~6 r5 |, C4 A2 t+ y - # ^/ }' Y: X. v9 W
- uint32_t TIM_Period; /*!< Specifies the period value to be loaded into the active! G [* g' M! R7 G: A' f! g; w# k( I" o
- Auto-Reload Register at the next update event.
' ~% b, x4 F/ R. b T - This parameter must be a number between 0x0000 and 0xFFFF. */ - ~& H" z" l5 x1 }
- k q# J2 M; s9 _+ u- uint16_t TIM_ClockDivision; /*!< Specifies the clock division.& \2 t k/ M4 M1 B
- This parameter can be a value of @ref TIM_Clock_Division_CKD */9 l! P# T- ]% W" U# B, g% j9 z3 R$ P2 H
- 0 P6 r* b& _1 [+ P% Y
- uint8_t TIM_RepetitionCounter; /*!< Specifies the repetition counter value. Each time the RCR downcounter
" ~5 Z# E% S& F7 ]: S3 O - reaches zero, an update event is generated and counting restarts
. f( ^0 w; N/ q: [3 H! [5 j - from the RCR value (N).& ~ U8 e9 X5 Y. C9 J X
- This means in PWM mode that (N+1) corresponds to:
& k1 p( q1 ]7 V% { - - the number of PWM periods in edge-aligned mode& e/ A$ C, k: F7 g% \$ `" \5 f/ M* b3 r
- - the number of half PWM period in center-aligned mode: ]+ \2 i2 j: n$ t8 @0 f" y
- This parameter must be a number between 0x00 and 0xFF. # O# x5 \/ @; v* o
- @note This parameter is valid only for TIM1 and TIM8. */2 `! @; b# T4 S2 N
- } TIM_TimeBaseInitTypeDef;
+ w" W4 i! F! _" p! x: j6 sTIM_OCInitTypeDef
$ @4 W; ? L6 ]: P3 O& ^
+ W" q- \ W3 W) W# v9 E- /** ! p/ _' F' t0 B1 o$ c* i
- * @brief TIM Output Compare Init structure definition " ` I3 ^# Y; P8 Q8 r( ~
6 F/ [+ A3 p) F+ M# j! X
. a) c, K X9 e- typedef struct
+ S/ D3 E3 l; i% v( C/ N - {" O0 x, D* \' u+ m
- uint16_t TIM_OCMode; /*!< Specifies the TIM mode.4 c, F. i' I X$ D# V3 R
- This parameter can be a value of @ref TIM_Output_Compare_and_PWM_modes */
% _( o+ e) a' K+ e - ! |; D7 q# T/ \, Y
- uint16_t TIM_OutputState; /*!< Specifies the TIM Output Compare state.
, F+ H6 `9 L! s* j% J6 ? - This parameter can be a value of @ref TIM_Output_Compare_State */1 n# j$ L) N$ _% W& _ {
: O) u# w3 u' s& ^- uint16_t TIM_OutputNState; /*!< Specifies the TIM complementary Output Compare state.: t4 J' W: N# H2 T* n
- This parameter can be a value of @ref TIM_Output_Compare_N_State8 B) r" h; s% P3 y5 Z* E
- @note This parameter is valid only for TIM1 and TIM8. */3 G9 j) E2 N- [$ T$ s s, t. y' {% r
& f- m2 S5 i1 O6 ^7 a: i# ~ E- uint32_t TIM_Pulse; /*!< Specifies the pulse value to be loaded into the Capture Compare Register.
5 V! m$ D* _+ Y6 E# W1 } - This parameter can be a number between 0x0000 and 0xFFFF */8 A+ J7 {& C" j! X; t* \
- ! c/ {* g6 W5 K' j' y
- uint16_t TIM_OCPolarity; /*!< Specifies the output polarity., A, h1 A7 r4 k* L% s2 t4 k# u
- This parameter can be a value of @ref TIM_Output_Compare_Polarity */: A5 X1 j! _; U, k( W
" r. N( w; ^$ K9 u R0 D' C3 R- uint16_t TIM_OCNPolarity; /*!< Specifies the complementary output polarity.
! {8 g! L- U; `4 m) l$ Z& X8 h - This parameter can be a value of @ref TIM_Output_Compare_N_Polarity
, \ ~& o7 r2 T - @note This parameter is valid only for TIM1 and TIM8. */& j3 R0 | L' b
' D& v& T6 [' Z1 i. [: {8 d$ x- uint16_t TIM_OCIdleState; /*!< Specifies the TIM Output Compare pin state during Idle state.$ R1 u8 H+ L3 o- G5 E
- This parameter can be a value of @ref TIM_Output_Compare_Idle_State
: Q2 r" F2 x3 H5 N9 h: m - @note This parameter is valid only for TIM1 and TIM8. */& N4 \0 ^! [. D4 ]' k J9 A! W
$ G$ R/ M# y' H- h- uint16_t TIM_OCNIdleState; /*!< Specifies the TIM Output Compare pin state during Idle state. M2 q: V J3 u3 o3 `; f7 M
- This parameter can be a value of @ref TIM_Output_Compare_N_Idle_State
) p; q7 a0 Q$ D- U* e/ f- l& c - @note This parameter is valid only for TIM1 and TIM8. */6 A- k& H1 N0 h/ U4 O! j# c
- } TIM_OCInitTypeDef;
, c y s1 z4 d% STIM_ICInitTypeDef! o7 T6 N. m( k! A
8 x! B# n0 B5 J) [
- /** ) \* |8 D1 Z, |. X Q. U
- * @brief TIM Input Capture Init structure definition " K v$ _4 a; H1 E; M* ]
; R8 P( Y- f F) g5 O3 ?0 D
; E4 u! v' A3 ^3 j- typedef struct0 W8 ^! l2 J- @
- { E1 g" [5 s- Y0 D) x- c$ u& `. D; A
- % V, N0 a( u9 c
- uint16_t TIM_Channel; /*!< Specifies the TIM channel.# S# H& Q( E3 \# H9 a
- This parameter can be a value of @ref TIM_Channel */
* r; E5 q8 H5 [) D! {+ w - * X) m7 ~/ M9 i5 u o3 j* _
- uint16_t TIM_ICPolarity; /*!< Specifies the active edge of the input signal.
3 k" ?4 f8 R8 G - This parameter can be a value of @ref TIM_Input_Capture_Polarity */
& Z/ x. W3 b# ^' }
B$ D" K" \( d% C- uint16_t TIM_ICSelection; /*!< Specifies the input.
; l/ ^7 q% n& M0 S& i# e( s - This parameter can be a value of @ref TIM_Input_Capture_Selection */- w I1 p4 F j+ \& s
/ ? |1 ]& @" F2 y8 X- uint16_t TIM_ICPrescaler; /*!< Specifies the Input Capture Prescaler.. I# A |6 T$ Y+ r! A
- This parameter can be a value of @ref TIM_Input_Capture_Prescaler */! m+ W* N! `/ t
- ' {* Q! V' O( E" z! y/ d
- uint16_t TIM_ICFilter; /*!< Specifies the input capture filter.
- s, U9 w0 v: \3 q6 U. C - This parameter can be a number between 0x0 and 0xF */1 l+ m) f1 H0 ?/ g2 r
- } TIM_ICInitTypeDef;
复制代码 2 b) I( m2 U, S( p% [
TIM_BDTRInitTypeDef
- I) {! w7 G. w- j& R
% h- x% H# ^9 z0 Q1 ?% w6 z' T8 ^0 S# }- /**
8 \* k& j! @* x/ J# x, L" K - * @brief BDTR structure definition
$ l# U9 n' X( E' C* P: D - * @note This structure is used only with TIM1 and TIM8.
4 c1 H2 Y! |7 ^' z3 A - */
& A7 h/ q0 B+ Z: U2 v - # ?+ l: |- p# ?0 x
- typedef struct
6 K1 w: m0 W* j. `, E - {
$ y" j/ n6 [( x# W* X1 p - 6 g0 a' b* E9 B
- uint16_t TIM_OSSRState; /*!< Specifies the Off-State selection used in Run mode.
# @7 O A% U4 [2 n - This parameter can be a value of @ref TIM_OSSR_Off_State_Selection_for_Run_mode_state */% R) a+ B! t/ y5 {
" z5 o x! Z8 D, ^3 n- uint16_t TIM_OSSIState; /*!< Specifies the Off-State used in Idle state.
/ Q0 S0 ^) ?' V5 ?7 E% N% s( Z - This parameter can be a value of @ref TIM_OSSI_Off_State_Selection_for_Idle_mode_state */* E) B' C9 W! ~" k
- ) w+ {; g, K- ?+ D
- uint16_t TIM_LOCKLevel; /*!< Specifies the LOCK level parameters.
' F% C8 d: g( ^. W0 H - This parameter can be a value of @ref TIM_Lock_level */
+ z* V" Y1 i) Q% g- V - - v5 G2 ]* _% {1 @! x7 v
- uint16_t TIM_DeadTime; /*!< Specifies the delay time between the switching-off and the
" k9 T$ i. e% M" b2 ~ - switching-on of the outputs./ W) x* I- C! E* w. O' l
- This parameter can be a number between 0x00 and 0xFF */2 l9 k8 |0 P6 S$ `% P) Q, h
- , W& m6 f& M' v9 t( u
- uint16_t TIM_Break; /*!< Specifies whether the TIM Break input is enabled or not.
+ k B7 U1 l: A, i; Q - This parameter can be a value of @ref TIM_Break_Input_enable_disable */
9 R, z; H" {2 k* q
$ ~2 R/ T4 C( p) C- uint16_t TIM_BreakPolarity; /*!< Specifies the TIM Break Input pin polarity.
5 j) D# J* `, i9 H - This parameter can be a value of @ref TIM_Break_Polarity */
& ]1 T( M9 ]6 ^, g$ J. u0 b - " |$ N% w5 o2 u, [8 L# J$ H
- uint16_t TIM_AutomaticOutput; /*!< Specifies whether the TIM Automatic Output feature is enabled or not.
! L4 P) D( o& o, S9 C - This parameter can be a value of @ref TIM_AOE_Bit_Set_Reset */
f9 M5 `2 U$ g+ e4 ~: Z - } TIM_BDTRInitTypeDef;
复制代码 ; j( V7 ~, e: c+ o) M% o
TIM
% W2 a8 x/ H+ H+ i1 a. d- f
7 v' R1 W8 k, [6 P% h2 D! ~- /** @defgroup TIM_Exported_constants
/ ?' l1 Z8 i N. y0 ]/ b: f - * @{
6 O7 I# X1 t% \) j- r$ R - */
$ f, q+ d+ m3 j - ! g# D& o9 r* x5 Q9 l
- #define IS_TIM_ALL_PERIPH(PERIPH) (((PERIPH) == TIM1) || \
) ~5 C7 r: e% D3 b - ((PERIPH) == TIM2) || \7 {) U( r- l# u6 Y6 s0 t2 E* {) M
- ((PERIPH) == TIM3) || \
7 u9 B8 k4 P2 K5 J& \4 L/ X% X - ((PERIPH) == TIM4) || \" \) @+ L6 F5 ^8 r( g* h8 P% e
- ((PERIPH) == TIM5) || \
6 C1 R* B/ |( i, p3 y+ Y; e3 Z - ((PERIPH) == TIM6) || \
! r7 Q/ G! M* }( L- f7 }8 J; N1 _ - ((PERIPH) == TIM7) || \
1 v4 r+ D4 v& T$ ~ - ((PERIPH) == TIM8) || \
* H6 L" F: k" O6 O8 Q8 W* ]1 ^ - ((PERIPH) == TIM9) || \6 m7 J) i/ H& A3 k9 ^1 n8 Z' L; S& D
- ((PERIPH) == TIM10) || \
+ S" \+ D% Y$ ], b- D. K7 U% H - ((PERIPH) == TIM11) || \9 F3 Y: B( y1 @
- ((PERIPH) == TIM12) || \
7 z& E, j- E: T& r - (((PERIPH) == TIM13) || \4 b5 H8 U' b- y6 S; C5 D
- ((PERIPH) == TIM14)))
2 P# l8 d, `1 g3 s" A- ^ - /* LIST1: TIM1, TIM2, TIM3, TIM4, TIM5, TIM8, TIM9, TIM10, TIM11, TIM12, TIM13 and TIM14 */
6 g& n3 k- `9 f2 _ G - #define IS_TIM_LIST1_PERIPH(PERIPH) (((PERIPH) == TIM1) || \1 f# n6 H! X* ~* X( }
0 K/ {, b* M# D1 H9 p7 | - ((PERIPH) == TIM3) || \: d) b& o! A7 ]5 p
% l) c0 l/ t* R, A$ c - ((PERIPH) == TIM5) || \5 `; y" h. `( A$ ~5 l/ C* t7 t' W6 X
0 G. m- b8 I3 F# ~* H2 ^3 c - ((PERIPH) == TIM9) || \
+ ?6 [7 S/ a& {' I6 I5 T) W - ((PERIPH) == TIM10) || \. u+ M* Z$ Q( q
- ((PERIPH) == TIM11) || \3 \- J6 c7 A9 O, Q/ P5 r* \
- ((PERIPH) == TIM12) || \+ ]3 c. O8 _; ~, s6 M# V/ O2 o* Z
- ((PERIPH) == TIM13) || \4 A2 b% l8 k1 H5 K/ y7 b- X2 O& e
3 G; e, G G* D( S. Q - & V8 M% l0 _+ }/ w9 _- [( T+ I
- /* LIST2: TIM1, TIM2, TIM3, TIM4, TIM5, TIM8, TIM9 and TIM12 */7 E2 i9 r9 _. ^; [( |2 [9 @0 c
- #define IS_TIM_LIST2_PERIPH(PERIPH) (((PERIPH) == TIM1) || \. k+ x! \$ s) ?: D
- ((PERIPH) == TIM2) || \& q- D: _1 V' `( s2 s
" ?8 [) _( y$ d2 J4 T - ((PERIPH) == TIM4) || \; t( e& Q2 L& D3 m8 y6 w
/ K8 z3 d8 y, u3 M - ((PERIPH) == TIM8) || \7 p# M1 U' n4 g/ ~9 p- i' y5 |
- ((PERIPH) == TIM9) || \# [' X. Y2 ~. |/ F
- ((PERIPH) == TIM12))2 B) X+ W5 f$ |6 ?, D1 C, ?
- /* LIST3: TIM1, TIM2, TIM3, TIM4, TIM5 and TIM8 */
0 o2 ~! y% A F: E$ D9 Q+ }0 G - #define IS_TIM_LIST3_PERIPH(PERIPH) (((PERIPH) == TIM1) || \
% T& r& D! \! a5 s. c - ((PERIPH) == TIM2) || \
9 [- j, Y9 e& U6 k. z; R# @2 c - ((PERIPH) == TIM3) || \
+ g" g9 [! s& E - ((PERIPH) == TIM4) || \* v( Y9 m% O' |2 o" J
- ((PERIPH) == TIM5) || \- ?4 b, K$ ?& k8 i# S' A5 Y
- ((PERIPH) == TIM8))
( q/ U" T0 y# |3 H& \5 `& e3 _! V - /* LIST4: TIM1 and TIM8 */6 C, y. G) ]# K5 I0 y1 o
- #define IS_TIM_LIST4_PERIPH(PERIPH) (((PERIPH) == TIM1) || \
8 u3 F. i# G6 c! w - ((PERIPH) == TIM8))' r/ Q- W/ G( ^
- /* LIST5: TIM1, TIM2, TIM3, TIM4, TIM5, TIM6, TIM7 and TIM8 */' b1 v, M+ N2 L# ~7 e
- #define IS_TIM_LIST5_PERIPH(PERIPH) (((PERIPH) == TIM1) || \
* y3 Z+ N' I3 U7 g0 [5 C; _1 w - ((PERIPH) == TIM2) || \/ `- U- L, Q' \9 P$ |
4 `) U( L6 D0 y+ z9 h% Q - ((PERIPH) == TIM4) || \
7 r1 R/ B* q1 F- c+ V" x& \ - ((PERIPH) == TIM5) || \
" u8 N1 I y4 Y' v( g% P i - ((PERIPH) == TIM6) || \
# v8 D; t% L8 Y# b - ((PERIPH) == TIM7) || \
+ c- M K* z! ^$ O' i* o" O - ((PERIPH) == TIM8))
4 f3 ~; Y! d! l" ?& t1 w - /* LIST6: TIM2, TIM5 and TIM11 */ ' @# d9 c% [$ f# `5 x2 d( U
- #define IS_TIM_LIST6_PERIPH(TIMx)(((TIMx) == TIM2) || \
- J9 k2 ^( e: X) Q" H) R6 w" ^; @ - ((TIMx) == TIM5) || \$ ^3 \/ ~4 X2 Y. X( V i7 z# F2 e
- ((TIMx) == TIM11))
复制代码 % W, d0 ~- R' a* A9 ?9 S' f, `% y1 z
2 A% }# X+ ?. }$ k& U+ {) P
1 l% X$ ~; z5 }) R" [% y- O- /** @defgroup TIM_Output_Compare_and_PWM_modes
' w/ \2 {7 F4 D5 i1 `8 w, e7 s6 K - * @{
* Y( h# H3 |& `2 B9 r4 ~ - */8 ]3 s9 x' y' f/ l& u- Q+ w# q( b1 F
- 4 n1 b5 t& A9 n7 v
- #define TIM_OCMode_Timing ((uint16_t)0x0000)
! ^( A4 u3 K1 C; f3 e - #define TIM_OCMode_Active ((uint16_t)0x0010)
4 R V9 K' S+ {" u3 H) e/ k' D2 ?) \ - #define TIM_OCMode_Inactive ((uint16_t)0x0020)8 K1 {0 v# V$ `+ n0 Z' j: m
- #define TIM_OCMode_Toggle ((uint16_t)0x0030)
% H9 }) g* W, A% u/ H" Z - #define TIM_OCMode_PWM1 ((uint16_t)0x0060)# k1 _. ^8 @ ~6 X1 ?/ {
- #define TIM_OCMode_PWM2 ((uint16_t)0x0070)) Y- t6 r" @3 v% x" K
- #define IS_TIM_OC_MODE(MODE) (((MODE) == TIM_OCMode_Timing) || \: P+ r* @7 g$ C6 \' W% X3 @0 n
- ((MODE) == TIM_OCMode_Active) || \
7 q4 ?" s# z/ z' f5 \8 @+ \3 ^/ K - ((MODE) == TIM_OCMode_Inactive) || \1 v( b& b0 h1 }9 Y% c0 {( j
- ((MODE) == TIM_OCMode_Toggle)|| \
1 `) U4 b' ^0 b ?4 C" [& A - ((MODE) == TIM_OCMode_PWM1) || \9 ^. z! _* B1 ] W1 o
- ((MODE) == TIM_OCMode_PWM2))* O: o5 g. e5 m! A7 B! {5 \2 T' `4 T
- #define IS_TIM_OCM(MODE) (((MODE) == TIM_OCMode_Timing) || \
1 P7 m' @" ?0 d9 ~( b4 W" ? - ((MODE) == TIM_OCMode_Active) || \/ J4 [( Z. d7 g1 P& w+ Y8 H
, g1 |' X% F' W) J& K - ((MODE) == TIM_OCMode_Toggle)|| \* d& F1 W0 ]& t/ i2 w0 p
) d7 O% D) m" [& v# B4 a1 Y9 |5 d9 [ - ((MODE) == TIM_OCMode_PWM2) || \# D; t1 a. I1 A% z: r4 L- I2 }
- ((MODE) == TIM_ForcedAction_Active) || \
: y8 P4 [# f- v% b- { - ((MODE) == TIM_ForcedAction_InActive))
( T- K8 v3 i$ r9 \TIM_One_Pulse_Mode) W3 V0 W& C; G- w7 S3 ]
% O5 v9 ^# M' M7 Z( [) }- c- /** @defgroup TIM_One_Pulse_Mode
& ?1 Q1 @ E1 \! ~2 A - * @{
2 n$ X8 b0 h2 q. i8 Q# i - */
0 B2 j) t% t, m5 k1 h! U
3 L+ b6 J% H1 m: e2 L9 w) L- #define TIM_OPMode_Single ((uint16_t)0x0008)
& e, ]' I/ I" m4 q - #define TIM_OPMode_Repetitive ((uint16_t)0x0000)
7 c, v1 c2 ~& h) o, c1 O - #define IS_TIM_OPM_MODE(MODE) (((MODE) == TIM_OPMode_Single) || \
1 e" J* Q6 P7 Q; M) p& [ - ((MODE) == TIM_OPMode_Repetitive))
( t2 E0 \% e# U" E2 g! R. |TIM_Channel/ t0 j! j: f5 x2 D3 T9 B" ]
1 w% J0 S, I6 u" `- /** @defgroup TIM_Channel + c5 W Z7 q) y7 u ^! U, {5 X
; [5 A) T% l6 f - */9 t1 K/ h7 e! c) Y* |; z* G
! n! R7 h' ^0 m& i) Z- #define TIM_Channel_1 ((uint16_t)0x0000)
8 u! x" u3 A( p - #define TIM_Channel_2 ((uint16_t)0x0004)$ O+ a( `: E& H. Z `& g6 M
- #define TIM_Channel_3 ((uint16_t)0x0008)/ ]$ O! n7 \. i ~9 s
- #define TIM_Channel_4 ((uint16_t)0x000C)
7 } Z3 b9 D/ X% u - . Y* f8 f& ^; @4 F% K* U! |2 N
- #define IS_TIM_CHANNEL(CHANNEL) (((CHANNEL) == TIM_Channel_1) || \) E' R& ?( Z8 o O! T! R8 E
- ((CHANNEL) == TIM_Channel_2) || \
% |- I9 b" F, _ - ((CHANNEL) == TIM_Channel_3) || \
2 G; o% N. N* r - ((CHANNEL) == TIM_Channel_4))
0 F! x, g; b3 V1 T% |) }% {) d+ n
6 C# w- q, N6 {5 g& R- #define IS_TIM_PWMI_CHANNEL(CHANNEL) (((CHANNEL) == TIM_Channel_1) || \2 q) K$ B( O6 [
- ((CHANNEL) == TIM_Channel_2))' s# Q' c% E$ x$ ?1 N ^! S9 a
- #define IS_TIM_COMPLEMENTARY_CHANNEL(CHANNEL) (((CHANNEL) == TIM_Channel_1) || \) q- z7 w/ w. W4 ?$ y- r! ^
( R5 G' f! d, w2 d/ _2 G# R5 N - ((CHANNEL) == TIM_Channel_3))
; z) C" z! Y" R2 w# E+ i
- I2 v) C6 y4 bTIM_Clock_Division_CKD
" t4 E) m' p* E' U8 `0 H* ~1 g% D" u, z& S' S
- /** @defgroup TIM_Clock_Division_CKD ( ?/ U9 U% _9 i) ]& B# {
+ w0 s$ S2 a; O% f0 F3 `. [ - */ n& M, ^& {- z7 I$ ~
7 H5 t- J, F t! v' l- S0 F- #define TIM_CKD_DIV1 ((uint16_t)0x0000)
- \& K3 ~9 q% i4 W0 Y: J, ^$ I - #define TIM_CKD_DIV2 ((uint16_t)0x0100)
0 r1 A; ^9 o6 B5 Z9 s Y- _3 E7 X - #define TIM_CKD_DIV4 ((uint16_t)0x0200)
9 K, Q8 }! F' H, @ - #define IS_TIM_CKD_DIV(DIV) (((DIV) == TIM_CKD_DIV1) || \: H3 r" o! q) i. l: w4 \+ v
- ((DIV) == TIM_CKD_DIV2) || \0 w3 m7 p, V, Z, c
- ((DIV) == TIM_CKD_DIV4))
4 M; l% `* D& f# A k2 N& B) pTIM_Counter_Mode7 ~- d1 T7 s5 f1 s+ u/ O+ g
0 j$ P6 ?4 c; n8 d1 N8 J. ]
- /** @defgroup TIM_Counter_Mode
) w7 r$ g6 v+ A K7 h, } - * @{
1 z9 s9 Z s! @$ G6 Z - */
( J6 }% ]! Z* {' K
E- D7 p6 [8 p% f, |. w- #define TIM_CounterMode_Up ((uint16_t)0x0000)
$ T2 z& A3 ^+ d# c6 U - #define TIM_CounterMode_Down ((uint16_t)0x0010)
* ?7 h% A; l# S& C X5 P( L - #define TIM_CounterMode_CenterAligned1 ((uint16_t)0x0020)1 ]) W; j, y- n
- #define TIM_CounterMode_CenterAligned2 ((uint16_t)0x0040)" F8 |- l0 r6 `* N1 u ]
- #define TIM_CounterMode_CenterAligned3 ((uint16_t)0x0060)
) [+ `$ u7 E" Y3 G, N% B/ | - #define IS_TIM_COUNTER_MODE(MODE) (((MODE) == TIM_CounterMode_Up) || \+ j# B7 T6 @" p0 V8 `
- ((MODE) == TIM_CounterMode_Down) || \2 j& b' c! ~$ R- b {
- ((MODE) == TIM_CounterMode_CenterAligned1) || \4 c7 a; U/ r$ @7 G+ z0 H
- ((MODE) == TIM_CounterMode_CenterAligned2) || \1 @ r5 D: b) t( s6 y9 U& v
- ((MODE) == TIM_CounterMode_CenterAligned3))
+ e5 o' t1 P. y: v# L% BTIM_Output_Compare_Polarity8 O r3 A# m! P) v! t
" F2 u: A. Y% a) Q3 ]- /** @defgroup TIM_Output_Compare_Polarity
4 @; X' j: E* r( u5 o& i - * @{
1 \3 E4 j. L* D @) U+ s - */+ k4 ~. B; o3 }, V: @, t- [$ E/ a
* w4 U, n- d; f! Z, X- #define TIM_OCPolarity_High ((uint16_t)0x0000)# x/ }8 h" `0 B) i+ M: {" t; W# L5 Q
- #define TIM_OCPolarity_Low ((uint16_t)0x0002)$ f8 T D2 ?( |
- #define IS_TIM_OC_POLARITY(POLARITY) (((POLARITY) == TIM_OCPolarity_High) || \
* U1 K( C4 A/ a" x P2 ~* Q' h - ((POLARITY) == TIM_OCPolarity_Low))
复制代码 - _3 N$ L; `/ P q
TIM_Output_Compare_N_Polarity- /** @defgroup TIM_Output_Compare_N_Polarity
- U1 p' }: V; Y6 a. @7 D6 F - * @{
- |4 z5 B) S/ n - */4 ~& v7 W! `$ }) N& p; _, Y% k
0 X1 M! e: d# Q- #define TIM_OCNPolarity_High ((uint16_t)0x0000)% N# p) L7 u, e/ c7 V0 y ?
- #define TIM_OCNPolarity_Low ((uint16_t)0x0008)/ V* ~+ z, x8 h2 [3 |
- #define IS_TIM_OCN_POLARITY(POLARITY) (((POLARITY) == TIM_OCNPolarity_High) || \
" S/ _5 k) C6 f; O( i, n+ | - ((POLARITY) == TIM_OCNPolarity_Low))
复制代码 + U7 o3 A3 L/ ~1 o
. U+ C: ~7 h* E* u$ H: K5 `
4 l0 i& J8 e8 T C- /** @defgroup TIM_Output_Compare_State - f4 Q4 Z/ c8 g$ Y8 \; A O* P
& J" [( I& G& @ H' u - */: s1 {/ i' p3 d
- 1 ?3 P# U/ \' Y, u
- #define TIM_OutputState_Disable ((uint16_t)0x0000)
( t: k0 F" F) G! ` - #define TIM_OutputState_Enable ((uint16_t)0x0001)7 C: M: y3 F! o( z2 Z4 _0 ?8 f; r
- #define IS_TIM_OUTPUT_STATE(STATE) (((STATE) == TIM_OutputState_Disable) || \
2 f1 \- C& `# s' U# Z- R/ p/ [ - ((STATE) == TIM_OutputState_Enable))
# ~3 C$ U8 _& ] s. iTIM_Output_Compare_N_State
1 s- ^0 h; ?' q: }) }& t: p/ k" H/ e
- /** @defgroup TIM_Output_Compare_N_State
0 O6 R/ [) W( V% o9 m - * @{
2 Q f1 W! M2 o4 ? - */
/ e4 d! K0 [5 L$ r! p- | - % n$ c0 N: s1 E% K6 `3 u
- #define TIM_OutputNState_Disable ((uint16_t)0x0000)" c' U3 S% d5 y. z; X
- #define TIM_OutputNState_Enable ((uint16_t)0x0004)2 H6 y( Z) n+ N/ a9 q7 J
- #define IS_TIM_OUTPUTN_STATE(STATE) (((STATE) == TIM_OutputNState_Disable) || \$ x7 n Y- h& v' q
- ((STATE) == TIM_OutputNState_Enable))
7 \, x# }) d1 I. C+ x/ X- {( d1 OTIM_Capture_Compare_State) p6 R3 g9 K; V9 \
% }. r0 ]/ U2 n& @) }4 H
- /** @defgroup TIM_Capture_Compare_State: h/ [3 F9 G% @8 C5 x2 o8 N
( v9 T. {/ _6 @- [- P - */
' y0 |8 W3 {# ^0 J, z
\+ D" ]5 f( v/ f& b- #define TIM_CCx_Enable ((uint16_t)0x0001)0 ~, ?, h* w/ S
- #define TIM_CCx_Disable ((uint16_t)0x0000)6 A' b) E/ Q5 `- K/ }: f
- #define IS_TIM_CCX(CCX) (((CCX) == TIM_CCx_Enable) || \
$ G# @) ]- a5 b/ B& j - ((CCX) == TIM_CCx_Disable))
) c" y* w3 F) C8 o% gTIM_Capture_Compare_N_State
; {! c7 s; q, V- ?4 ?. R
- U8 ]1 E: ~& M! b8 ~& |- /** @defgroup TIM_Capture_Compare_N_State( s6 W7 {7 k5 X# c
- * @{2 t' W; x1 z, V8 }1 g' K
- */) [0 f; e9 G" z9 a
- 9 H7 y$ Z* s @, h, w
- #define TIM_CCxN_Enable ((uint16_t)0x0004)
. ^( V% |; \; @6 X" N2 H - #define TIM_CCxN_Disable ((uint16_t)0x0000)8 h8 E3 [' b% K& ?* ]/ M8 R' R k
- #define IS_TIM_CCXN(CCXN) (((CCXN) == TIM_CCxN_Enable) || \5 c) k$ t4 O! B4 K' M9 T/ T
- ((CCXN) == TIM_CCxN_Disable))
复制代码 , E3 y& X# u4 a6 B( U1 H
TIM_Break_Input_enable_disable+ Z |! ^& r* A! I
0 c% d( j8 S. @
- /** @defgroup TIM_Break_Input_enable_disable
/ |1 i+ A z1 V! ]5 q4 K" N. o - * @{
. r/ Q/ h ]' Z9 C: t - */; N; J7 E. z- M! Y
# b7 X( D0 e9 c+ `. x9 @+ H- #define TIM_Break_Enable ((uint16_t)0x1000)2 Y7 c6 Y! X0 g" U# ]
- #define TIM_Break_Disable ((uint16_t)0x0000)
' l( h% @- U! H, _; E2 b9 { - #define IS_TIM_BREAK_STATE(STATE) (((STATE) == TIM_Break_Enable) || \3 x( j7 {% g8 ^3 x
- ((STATE) == TIM_Break_Disable))
复制代码 6 E0 M' V) b' b4 I( b8 N" l, T
TIM_Break_Polarity
$ B+ y, P; {- V2 J2 j9 c: Q% H3 G5 Q" y& s. L
- /** @defgroup TIM_Break_Polarity 6 d0 R& X$ @, u Y6 `3 G
- v7 C7 I/ k, `* J - */
) b: N- c) _8 w: x, _( _ - 1 D! Q3 L3 H2 c& O; v
- #define TIM_BreakPolarity_Low ((uint16_t)0x0000); z: m. O- k- ]( v8 s v8 m$ i. k. Z
- #define TIM_BreakPolarity_High ((uint16_t)0x2000)' x3 G; A" r9 y: b" m( H
- #define IS_TIM_BREAK_POLARITY(POLARITY) (((POLARITY) == TIM_BreakPolarity_Low) || \
! W$ y5 O& O1 r5 x6 ` - ((POLARITY) == TIM_BreakPolarity_High))
& L- g8 W1 C* zTIM_AOE_Bit_Set_Reset
s! v# E( w: T, F- /** @defgroup TIM_AOE_Bit_Set_Reset 3 \# k- i" o; e2 P
" _" } y4 s6 F i - */
2 l! k. V2 I3 Z- J& f5 _3 t3 L
- V2 D9 V% ? n6 n# H9 I' }4 i1 j- #define TIM_AutomaticOutput_Enable ((uint16_t)0x4000)
& w/ V$ W" F7 O# q, ] - #define TIM_AutomaticOutput_Disable ((uint16_t)0x0000)
" R6 \8 r4 Y" i( ?! i - #define IS_TIM_AUTOMATIC_OUTPUT_STATE(STATE) (((STATE) == TIM_AutomaticOutput_Enable) || \
/ e! Q w8 E5 o# [8 _; i - ((STATE) == TIM_AutomaticOutput_Disable))
+ k7 f- y/ ?6 ]4 Q8 ?4 k2 @TIM_Lock_level
5 a0 K3 E0 Q/ G5 {1 W
& {8 q/ Y1 t3 ?9 ?% ?$ J% l- /** @defgroup TIM_Lock_level
3 }: Y2 H8 [0 j( p. w - * @{0 B1 H' O' {$ f
/ c/ K8 c6 |. K1 X& O* X - : T+ ~% Y3 x7 q# h y! G
- #define TIM_LOCKLevel_OFF ((uint16_t)0x0000)' L5 U) b X N% C7 S. e0 K
- #define TIM_LOCKLevel_1 ((uint16_t)0x0100)
2 P+ O9 l! n+ s - #define TIM_LOCKLevel_2 ((uint16_t)0x0200)
3 A. Z% \2 M, L! @! P; O! A - #define TIM_LOCKLevel_3 ((uint16_t)0x0300)' ~9 Y: U- E; P; F7 S
- #define IS_TIM_LOCK_LEVEL(LEVEL) (((LEVEL) == TIM_LOCKLevel_OFF) || \' Y L4 A8 A7 i) C; b7 Y
- ((LEVEL) == TIM_LOCKLevel_1) || \
: b3 B: Y y- d - ((LEVEL) == TIM_LOCKLevel_2) || \( B3 ?1 H. t. s4 L4 |
- ((LEVEL) == TIM_LOCKLevel_3))
% }3 W4 m. o6 u/ n2 BTIM_OSSI_Off_State_Selection_for_Idle_mode_state- /** @defgroup TIM_OSSI_Off_State_Selection_for_Idle_mode_state + G8 f% ]: k" w$ ~) p2 Z
4 G8 c9 K7 N, q: l G% [8 ? - */
4 a, J2 W+ i( h) p1 |3 a$ N( }
9 ]5 V# [6 j9 D* r4 F1 ~$ Q- #define TIM_OSSIState_Enable ((uint16_t)0x0400)# Y. q! w/ k( j, O
- #define TIM_OSSIState_Disable ((uint16_t)0x0000)2 V4 k: I! o& |& P1 [- B
- #define IS_TIM_OSSI_STATE(STATE) (((STATE) == TIM_OSSIState_Enable) || \
1 S, v0 T8 T* [6 I5 z) X8 L - ((STATE) == TIM_OSSIState_Disable))
复制代码 6 [- ]3 K+ R3 m7 d) g; b8 J4 p2 T
/ V: I7 S( h4 Y: I% _$ b w9 u5 |6 o! O4 I# v# y
- /** @defgroup TIM_OSSR_Off_State_Selection_for_Run_mode_state
; G2 {8 G: ~2 \, v6 U3 t# g- @ - * @{
) s. [: h# j8 \! I+ t2 O: r; B5 |6 j - */- q d2 _9 w6 ] Q5 [
- 9 n8 ?; r! ^- B; j
- #define TIM_OSSRState_Enable ((uint16_t)0x0800); x$ t9 X' ~/ E2 W, b$ h
- #define TIM_OSSRState_Disable ((uint16_t)0x0000)
$ {8 X0 [# {2 [9 d - #define IS_TIM_OSSR_STATE(STATE) (((STATE) == TIM_OSSRState_Enable) || \" o5 i# [6 g7 j6 Y( h
- ((STATE) == TIM_OSSRState_Disable))
2 z ?5 C3 G! `0 ?$ t) V5 fTIM_Output_Compare_Idle_State) n, r! n# f7 }
* M* n# W' ?8 y" |" [! F% P- /** @defgroup TIM_Output_Compare_Idle_State 7 D% g$ M3 ~$ H9 p( `
; J1 Q6 s; Z3 `4 L' \7 A! f) ` - */% r8 W7 Z* m* ], l1 B5 o
- % J p2 o! j$ E s7 V+ @; W
- #define TIM_OCIdleState_Set ((uint16_t)0x0100)3 j J, s! {' }4 J/ Z- v: O) u( m( x
- #define TIM_OCIdleState_Reset ((uint16_t)0x0000), }* N0 | F+ {3 }) i
- #define IS_TIM_OCIDLE_STATE(STATE) (((STATE) == TIM_OCIdleState_Set) || \3 |6 ?% a7 J% _3 `" @+ v
- ((STATE) == TIM_OCIdleState_Reset))
复制代码 8 ~1 u. P* z5 P5 j2 F+ [. Y
TIM_Output_Compare_N_Idle_State. g# }5 q) e* u) B3 a! n
$ i3 X/ [1 t( f+ t% _$ q
- /** @defgroup TIM_Output_Compare_N_Idle_State
! M3 E* P3 [+ F6 D - * @{' u- I2 ~$ `2 W' _% j B$ w; H
8 }5 C' M; l" A - G4 \1 Y; t _% S" Z; `
- #define TIM_OCNIdleState_Set ((uint16_t)0x0200)- U, J0 Y& _( _: q+ ^ D. t, \6 f
- #define TIM_OCNIdleState_Reset ((uint16_t)0x0000)6 T( I( |9 V" Z$ V8 y
- #define IS_TIM_OCNIDLE_STATE(STATE) (((STATE) == TIM_OCNIdleState_Set) || \' o4 }/ C$ \$ K7 `, Y3 r0 {: ]* t4 x
- ((STATE) == TIM_OCNIdleState_Reset))
复制代码 2 z2 J" D% Y6 \
TIM_Input_Capture_Polarity. x3 D9 _( k( V0 v
L4 Y/ R7 @; w7 K8 f- /** @defgroup TIM_Input_Capture_Polarity
: W3 }7 k1 l- h0 B( Q - * @{
+ ?1 V4 { v B3 ?' P, } - */1 u: l' p8 ~- Q6 c9 {
$ J" g( s! c* K0 p6 ^" H: h- #define TIM_ICPolarity_Rising ((uint16_t)0x0000)& ?# ?! C" B3 I* o
- #define TIM_ICPolarity_Falling ((uint16_t)0x0002)
& {2 Y& {( F7 y - #define TIM_ICPolarity_BothEdge ((uint16_t)0x000A)
+ |; x6 W) Y# z - #define IS_TIM_IC_POLARITY(POLARITY) (((POLARITY) == TIM_ICPolarity_Rising) || \
2 z. ]5 Y, ?0 p& l1 S# [ - ((POLARITY) == TIM_ICPolarity_Falling)|| \
1 }: Z; \) L( f, t - ((POLARITY) == TIM_ICPolarity_BothEdge))
1 T _, {: E5 I$ Y* I$ ]! |4 M* vTIM_Input_Capture_Selection
( x4 k8 F" c; X* j; a
; D! j/ f& H* f% L7 U1 {0 ~- /** @defgroup TIM_Input_Capture_Selection , p% \( X' ~& T0 q
- * @{0 N W/ D) Z9 E0 s- Z" J$ ]
- */& N- R+ w, i( |: i+ ]
0 ~: b7 A$ N2 T5 \/ e8 J- #define TIM_ICSelection_DirectTI ((uint16_t)0x0001) /*!< TIM Input 1, 2, 3 or 4 is selected to be # l( c V; D2 ~1 n! O [- o- z
- connected to IC1, IC2, IC3 or IC4, respectively */
* W5 Z) W# |: |! l! e" x - #define TIM_ICSelection_IndirectTI ((uint16_t)0x0002) /*!< TIM Input 1, 2, 3 or 4 is selected to be- n a) k" x* G! w5 ]
- connected to IC2, IC1, IC4 or IC3, respectively. */
, q( L r( |$ j - #define TIM_ICSelection_TRC ((uint16_t)0x0003) /*!< TIM Input 1, 2, 3 or 4 is selected to be connected to TRC. */
/ C0 U& D/ c2 P* x: y) n - #define IS_TIM_IC_SELECTION(SELECTION) (((SELECTION) == TIM_ICSelection_DirectTI) || \3 |4 J$ S6 p6 D2 C6 ]
- ((SELECTION) == TIM_ICSelection_IndirectTI) || \% S/ H; L6 j0 W3 K+ R/ G
- ((SELECTION) == TIM_ICSelection_TRC))
复制代码 ! \( n# T8 ^! \$ x. c8 J# s2 T
TIM_Input_Capture_Prescaler& u* t8 M) |. d9 L; R% {, N
" a \& X1 s$ ~* d5 m
- /** @defgroup TIM_Input_Capture_Prescaler
8 U8 H" s0 k1 Y0 t3 ^+ N - * @{
) ?; C7 z7 i& i5 j - */
' U# S( }& I& c
) N, p0 ~, D# K* T- w7 ], p B- #define TIM_ICPSC_DIV1 ((uint16_t)0x0000) /*!< Capture performed each time an edge is detected on the capture input. */
7 [1 f3 X! @2 k( K% V - #define TIM_ICPSC_DIV2 ((uint16_t)0x0004) /*!< Capture performed once every 2 events. */: o3 d5 J: x! i: L3 M. ?9 r
- #define TIM_ICPSC_DIV4 ((uint16_t)0x0008) /*!< Capture performed once every 4 events. */
, c7 X# n4 T* R( |, ?+ l) B7 { - #define TIM_ICPSC_DIV8 ((uint16_t)0x000C) /*!< Capture performed once every 8 events. */
! k9 a$ p4 Y) x/ x& d - #define IS_TIM_IC_PRESCALER(PRESCALER) (((PRESCALER) == TIM_ICPSC_DIV1) || \1 U$ b: y, y. n# y6 U$ @
- ((PRESCALER) == TIM_ICPSC_DIV2) || \: A. H+ _) T- n1 L$ z4 C/ @! I
- ((PRESCALER) == TIM_ICPSC_DIV4) || \
$ [# |3 ]7 w/ J" {, R - ((PRESCALER) == TIM_ICPSC_DIV8))
! q1 \9 w' B; s
. J, a! K1 j3 DTIM_interrupt_sources
+ ^+ X8 z& b* r9 D; i$ I. P4 H! m+ d# i4 c8 u: G0 w
- /** @defgroup TIM_interrupt_sources ; T8 \) ~+ S3 G9 x( }8 t `* a
' `4 z( U9 m/ R. r( M e$ A* y - */
; ~+ e4 J p, D
9 M$ ^; j& X8 O a% q- #define TIM_IT_Update ((uint16_t)0x0001)
8 G+ R2 B! h; q! M. F - #define TIM_IT_CC1 ((uint16_t)0x0002)( B( }7 a! a3 ^5 l! F" g
- #define TIM_IT_CC2 ((uint16_t)0x0004)
" G$ Q( f) ~9 [. m V - #define TIM_IT_CC3 ((uint16_t)0x0008)
& Y) b2 N. R2 b4 m; \6 S. ^ - #define TIM_IT_CC4 ((uint16_t)0x0010), b& c2 z1 G @5 Q4 R g
- #define TIM_IT_COM ((uint16_t)0x0020)8 C' V5 w( T. d3 o" \" h3 @& p
- #define TIM_IT_Trigger ((uint16_t)0x0040)
$ Q" g ]9 z* U$ i5 S9 x - #define TIM_IT_Break ((uint16_t)0x0080)
, C7 [7 p4 K% Q- m- l! M - #define IS_TIM_IT(IT) ((((IT) & (uint16_t)0xFF00) == 0x0000) && ((IT) != 0x0000))
. s7 G8 n+ q9 c# R$ a5 O3 u - - {8 S3 ?* a8 c9 C' I
- #define IS_TIM_GET_IT(IT) (((IT) == TIM_IT_Update) || \' [0 ~/ W* I/ l% x+ x2 D f& P
- ((IT) == TIM_IT_CC1) || \
7 ~2 ^8 s5 B, H& M - ((IT) == TIM_IT_CC2) || \
: D) y* M) c( e! a& E - ((IT) == TIM_IT_CC3) || \
, N% n7 `" _0 q: q1 e - ((IT) == TIM_IT_CC4) || \
& a, [/ C0 Q5 b+ L' F- B - ((IT) == TIM_IT_COM) || \6 g6 q' V7 L, V
- ((IT) == TIM_IT_Trigger) || \
) S6 H( Q5 g9 Z' k - ((IT) == TIM_IT_Break))
. v, I6 M8 Y: M/ @( V% W) G/ p' [
复制代码 4 e |2 R$ l u: b L& a* a
TIM_DMA_Base_address( s* a; Q" R& U+ e
+ \: W( a% `* S2 J7 ]
- /** @defgroup TIM_DMA_Base_address
% J: L, \% c) y/ R) ^( c* P8 q6 P - * @{# t9 f9 y9 ~4 g/ E6 f* b
- */4 N& Z* ?3 J+ A9 T9 x. @
- : z7 j$ [5 J# u5 M6 K5 P4 m" g
- #define TIM_DMABase_CR1 ((uint16_t)0x0000)" m2 k# J: P7 }; }% Y1 P8 V( q) y; a
- #define TIM_DMABase_CR2 ((uint16_t)0x0001)
& U: u ]! X9 ^8 U c$ Q. X8 W - #define TIM_DMABase_SMCR ((uint16_t)0x0002)* I7 z& X& z3 k
- #define TIM_DMABase_DIER ((uint16_t)0x0003)
8 @; S3 m+ s) c6 ^. ]) }0 a1 n! m - #define TIM_DMABase_SR ((uint16_t)0x0004)2 D( W( n7 p. Y+ R9 K6 a
- #define TIM_DMABase_EGR ((uint16_t)0x0005)
/ Z6 _- M% J5 R% s( ~8 {, } - #define TIM_DMABase_CCMR1 ((uint16_t)0x0006)* E: P) T5 X' ~( u8 n
- #define TIM_DMABase_CCMR2 ((uint16_t)0x0007), u2 \; a$ |$ D4 P, V9 v. D% n4 {
- #define TIM_DMABase_CCER ((uint16_t)0x0008)
. a( y9 L6 A& ]! V( o - #define TIM_DMABase_CNT ((uint16_t)0x0009)% Q; g2 L5 L) q5 `' H
- #define TIM_DMABase_PSC ((uint16_t)0x000A)
7 p4 @5 N' d0 k; N0 ^- M: H - #define TIM_DMABase_ARR ((uint16_t)0x000B)
- m3 ?9 C/ H* L6 a# z1 a7 e& { - #define TIM_DMABase_RCR ((uint16_t)0x000C)1 z4 M4 a# J2 I6 P
- #define TIM_DMABase_CCR1 ((uint16_t)0x000D)
7 [. R% l8 f! ^4 _9 L - #define TIM_DMABase_CCR2 ((uint16_t)0x000E)
" Y- Z l: g. w5 b4 {7 l4 _ - #define TIM_DMABase_CCR3 ((uint16_t)0x000F)) m! q$ a- @. k
- #define TIM_DMABase_CCR4 ((uint16_t)0x0010)$ I( u; C# @* m' b! Q* N7 w! }# Z
- #define TIM_DMABase_BDTR ((uint16_t)0x0011)
* \% W) X& @ V8 A9 ^; t - #define TIM_DMABase_DCR ((uint16_t)0x0012)
3 K2 B1 [+ G+ U! W - #define TIM_DMABase_OR ((uint16_t)0x0013)# |* Q2 Y% p" c& p5 t, U* W7 h
- #define IS_TIM_DMA_BASE(BASE) (((BASE) == TIM_DMABase_CR1) || \
5 f2 J" [5 m& z6 |- r - ((BASE) == TIM_DMABase_CR2) || \7 g# K; N- J2 \6 [6 v
- ((BASE) == TIM_DMABase_SMCR) || \
/ w4 G. _& u% y; s' _ - ((BASE) == TIM_DMABase_DIER) || \& S* D1 s3 ]3 L' F' C. u
- ((BASE) == TIM_DMABase_SR) || \
* O9 s# g6 X' {) \" u) L - ((BASE) == TIM_DMABase_EGR) || \
4 v% q% g$ {: h - ((BASE) == TIM_DMABase_CCMR1) || \
: G) M$ |1 U/ ?# e4 u - ((BASE) == TIM_DMABase_CCMR2) || \! d% M- j7 i( }
- ((BASE) == TIM_DMABase_CCER) || \& F, h% {0 Y8 a9 @9 r. R
- ((BASE) == TIM_DMABase_CNT) || \2 E" D. t5 d! f9 [8 F: [, O
- ((BASE) == TIM_DMABase_PSC) || \& m. }3 _- d6 _' m
- ((BASE) == TIM_DMABase_ARR) || \
$ i/ `, b/ M8 e9 ^0 w7 t& d! G - ((BASE) == TIM_DMABase_RCR) || \" m* i! x6 w X5 A; A6 e) J
- ((BASE) == TIM_DMABase_CCR1) || \
, h1 Y9 o& q, i) a1 W( e4 |1 [ - ((BASE) == TIM_DMABase_CCR2) || \" `& D2 f, M9 ?8 E S( g6 d% z3 }
- ((BASE) == TIM_DMABase_CCR3) || \7 w8 N; H0 C+ l+ m, g' e
- ((BASE) == TIM_DMABase_CCR4) || \
5 Y, r$ f& \8 S, F3 c% | - ((BASE) == TIM_DMABase_BDTR) || \) e% W2 M1 }* `8 S, k- L
- ((BASE) == TIM_DMABase_DCR) || \4 |3 X4 F. Z1 \/ @: r j+ W7 V
- ((BASE) == TIM_DMABase_OR))
# x: x; K0 u+ ZTIM_DMA_Burst_Length' U2 K& R4 d3 ` g6 K7 Z2 j* {
" w( P5 x# A+ D& e$ o- /** @defgroup TIM_DMA_Burst_Length
6 `7 z5 R% Y7 k4 ~2 d+ Y - * @{$ l3 V# q; e1 u# r; S; }
- */1 Y5 a) t3 J) ]; ~( Z
- c9 c8 w- t) C8 `: I& N/ _& F
- #define TIM_DMABurstLength_1Transfer ((uint16_t)0x0000)
2 O, F1 }5 W% A0 v - #define TIM_DMABurstLength_2Transfers ((uint16_t)0x0100)
6 q, u1 `( c& U/ r4 _- a - #define TIM_DMABurstLength_3Transfers ((uint16_t)0x0200)
3 L$ U( K$ z8 T8 S - #define TIM_DMABurstLength_4Transfers ((uint16_t)0x0300)
0 i1 }! ^8 B3 ]+ F( Z B% X - #define TIM_DMABurstLength_5Transfers ((uint16_t)0x0400). n7 ]- K6 w3 e( y. N4 n
- #define TIM_DMABurstLength_6Transfers ((uint16_t)0x0500)& l. b# d! F3 U* O3 _+ ^
- #define TIM_DMABurstLength_7Transfers ((uint16_t)0x0600)1 _( L' B) E/ m# X/ t: `- }
- #define TIM_DMABurstLength_8Transfers ((uint16_t)0x0700)
& c) e) ]" [% u; E6 \. E6 p, f, l - #define TIM_DMABurstLength_9Transfers ((uint16_t)0x0800)/ h3 b) n3 I L
- #define TIM_DMABurstLength_10Transfers ((uint16_t)0x0900)
2 q; ]+ @& k6 O+ w' j$ f; f+ p - #define TIM_DMABurstLength_11Transfers ((uint16_t)0x0A00)/ B0 I3 A: O) |; L$ {
- #define TIM_DMABurstLength_12Transfers ((uint16_t)0x0B00), f+ S" E0 k* c, Q, a2 t/ [
- #define TIM_DMABurstLength_13Transfers ((uint16_t)0x0C00); f+ h h( G* z6 }6 P) }
- #define TIM_DMABurstLength_14Transfers ((uint16_t)0x0D00)! \! _/ a& ^7 ~
- #define TIM_DMABurstLength_15Transfers ((uint16_t)0x0E00)
/ F2 [- M8 U: R5 I - #define TIM_DMABurstLength_16Transfers ((uint16_t)0x0F00)
3 K8 g9 Q* H: i, B' V# o) o( u - #define TIM_DMABurstLength_17Transfers ((uint16_t)0x1000)
& S( R$ `4 \2 y: |! D, q% R - #define TIM_DMABurstLength_18Transfers ((uint16_t)0x1100)
7 y4 F2 x/ ~4 q1 C. Z( m" g - #define IS_TIM_DMA_LENGTH(LENGTH) (((LENGTH) == TIM_DMABurstLength_1Transfer) || \
o$ S4 m' B. M- J - ((LENGTH) == TIM_DMABurstLength_2Transfers) || \
: u( H, g& k% X8 f/ ~ - ((LENGTH) == TIM_DMABurstLength_3Transfers) || \$ \3 Q* d' B8 ~8 n
- ((LENGTH) == TIM_DMABurstLength_4Transfers) || \
& \& U, t. Z( ?( R7 c/ W! R - ((LENGTH) == TIM_DMABurstLength_5Transfers) || \: K6 E' _/ g, t0 V# x! J0 L
- ((LENGTH) == TIM_DMABurstLength_6Transfers) || \3 n, Z% E6 {4 R3 g: W7 t$ O
- ((LENGTH) == TIM_DMABurstLength_7Transfers) || \4 p' c- A) X4 d& C' L4 b- T
- ((LENGTH) == TIM_DMABurstLength_8Transfers) || \# u$ U, } ^/ \- L6 _ _
- ((LENGTH) == TIM_DMABurstLength_9Transfers) || \
6 U" f% R8 D1 ?# b4 ` - ((LENGTH) == TIM_DMABurstLength_10Transfers) || \
1 d$ k% ]- G. Z - ((LENGTH) == TIM_DMABurstLength_11Transfers) || \
+ S+ T. [; `: W: m! [9 I2 N - ((LENGTH) == TIM_DMABurstLength_12Transfers) || \5 v' u2 g7 O/ c6 ~! n
- ((LENGTH) == TIM_DMABurstLength_13Transfers) || \( V5 V" `. e4 p" s2 }7 P
- ((LENGTH) == TIM_DMABurstLength_14Transfers) || \
0 d' ?7 H1 h/ l - ((LENGTH) == TIM_DMABurstLength_15Transfers) || \0 O9 a2 ~) l% k) b5 U
- ((LENGTH) == TIM_DMABurstLength_16Transfers) || \+ v T0 ?+ m# R+ r0 t2 E
- ((LENGTH) == TIM_DMABurstLength_17Transfers) || \
N% B1 ], B6 y* a9 O - ((LENGTH) == TIM_DMABurstLength_18Transfers))
2 ]3 o! I9 I3 q, q) l' m: x; mTIM_DMA_sources% h# ]& {, J ^0 E) b( F
# z* u% M( B L& W
- /** @defgroup TIM_DMA_sources
8 @" P, e* B3 r - * @{. y) q$ z' ? Q% ^
* R8 o6 u4 |- j, I% N8 ^! k
( Q( C+ A- c/ O( s3 `- #define TIM_DMA_Update ((uint16_t)0x0100)
2 b' F1 P/ D4 X0 N4 b3 Q/ ^3 ~ - #define TIM_DMA_CC1 ((uint16_t)0x0200)
# S# D5 j7 B( l' k, J - #define TIM_DMA_CC2 ((uint16_t)0x0400)
, j- k O( D# b9 _5 J) p - #define TIM_DMA_CC3 ((uint16_t)0x0800)
" l( ^1 V/ r" j0 _1 H! N$ m; \ - #define TIM_DMA_CC4 ((uint16_t)0x1000)
. P1 `# i' h# M q3 F - #define TIM_DMA_COM ((uint16_t)0x2000)5 l7 M9 ?% B% l0 q+ y/ C# h* v
- #define TIM_DMA_Trigger ((uint16_t)0x4000)
+ a) r( i% D9 A9 s, z9 |" l - #define IS_TIM_DMA_SOURCE(SOURCE) ((((SOURCE) & (uint16_t)0x80FF) == 0x0000) && ((SOURCE) != 0x0000))
复制代码 , D3 T! V; e W: B; C+ Q/ i7 Q
TIM_External_Trigger_Prescaler
I9 Z5 x3 Z# Q5 Q- |1 r& s* }9 h4 I3 [8 l6 c% R' j4 ?
- /** @defgroup TIM_External_Trigger_Prescaler
8 z7 ?0 H. t' u/ K8 B) E4 l - * @{ T6 Y0 s3 p8 p6 Y/ ]. w+ b
- */# r, N/ X5 Z# I& k2 a" ^( W
" O* d% R# w* i9 S* V0 K/ ? X- #define TIM_ExtTRGPSC_OFF ((uint16_t)0x0000)) f# ?& T+ ?# ], U4 d9 M* [
- #define TIM_ExtTRGPSC_DIV2 ((uint16_t)0x1000)7 Y# P, j* h" B& J5 A5 v- r
- #define TIM_ExtTRGPSC_DIV4 ((uint16_t)0x2000)7 p5 |. M. L" B$ F3 F
- #define TIM_ExtTRGPSC_DIV8 ((uint16_t)0x3000)$ _: B8 G& f7 B n
- #define IS_TIM_EXT_PRESCALER(PRESCALER) (((PRESCALER) == TIM_ExtTRGPSC_OFF) || \( V( g' y6 V/ M& b$ K2 W1 U
- ((PRESCALER) == TIM_ExtTRGPSC_DIV2) || \2 X5 b4 t5 o2 p# d% J
- ((PRESCALER) == TIM_ExtTRGPSC_DIV4) || \
3 z7 \! M; `2 E- Y+ s - ((PRESCALER) == TIM_ExtTRGPSC_DIV8))
复制代码 ! @3 l. r# d. G/ r
TIM_Internal_Trigger_Selection2 b& I8 `! h8 }3 `8 g. a0 E
; h; H! f2 i4 V- {# c- /** @defgroup TIM_Internal_Trigger_Selection
1 q& }% s) g( {& t" D* H" o' V - * @{" S: F% q6 M9 S% o, ?
- */, R5 Y3 v6 K" v% Q: e
1 {3 g5 J- z w- #define TIM_TS_ITR0 ((uint16_t)0x0000)
8 H1 `, d7 u$ c- g3 u) n$ d - #define TIM_TS_ITR1 ((uint16_t)0x0010) s8 s' {' F, z2 \
- #define TIM_TS_ITR2 ((uint16_t)0x0020)
3 w2 _( F' s' b: \4 t - #define TIM_TS_ITR3 ((uint16_t)0x0030)
+ K# C, m% }/ Q' Y - #define TIM_TS_TI1F_ED ((uint16_t)0x0040)2 Z6 X, F2 M S: p& G) F
- #define TIM_TS_TI1FP1 ((uint16_t)0x0050)
9 N% ^6 L1 T2 q - #define TIM_TS_TI2FP2 ((uint16_t)0x0060)! Z; H1 T& |3 E% R
- #define TIM_TS_ETRF ((uint16_t)0x0070)
; k+ o, J* O) o - #define IS_TIM_TRIGGER_SELECTION(SELECTION) (((SELECTION) == TIM_TS_ITR0) || \9 I8 s8 k, P" K
- ((SELECTION) == TIM_TS_ITR1) || \( G' X+ k4 n& o; Z' A5 `% i+ j
- ((SELECTION) == TIM_TS_ITR2) || \
) K* a1 }$ p5 u6 T3 j - ((SELECTION) == TIM_TS_ITR3) || \3 {; S' Q; x& n e( J
- ((SELECTION) == TIM_TS_TI1F_ED) || \. A8 m3 e7 y1 K3 F2 ]
- ((SELECTION) == TIM_TS_TI1FP1) || \! B8 Z4 f+ h) S. n
- ((SELECTION) == TIM_TS_TI2FP2) || \
* q' l$ [' w: w. F, d - ((SELECTION) == TIM_TS_ETRF))
* z, m2 k+ x2 ^& D - #define IS_TIM_INTERNAL_TRIGGER_SELECTION(SELECTION) (((SELECTION) == TIM_TS_ITR0) || \
8 [. a, k& |6 m9 H - ((SELECTION) == TIM_TS_ITR1) || \
$ [; E; u! }0 x8 g7 i m+ w - ((SELECTION) == TIM_TS_ITR2) || \
9 S& q8 a) c4 j9 K+ @, e9 j# z& Q; d5 ^ - ((SELECTION) == TIM_TS_ITR3))
复制代码 % u5 B, @1 [% b4 T- I' \
TIM_TIx_External_Clock_Source! V6 q/ s+ D% ~! i
, @- `( y$ X9 V0 c- /** @defgroup TIM_TIx_External_Clock_Source
9 r7 Q; q4 Y4 p! c3 p. ^' w - * @{/ e# ]" G5 r9 E3 h; F2 M: a" A. `
- */0 M) Q Q$ U( s, |5 l* l
- . S. D. l" I& [2 i) g
- #define TIM_TIxExternalCLK1Source_TI1 ((uint16_t)0x0050)
( Q1 t& c# c1 L& y' i - #define TIM_TIxExternalCLK1Source_TI2 ((uint16_t)0x0060)* K C7 R2 `1 N9 [7 v3 L2 \
- #define TIM_TIxExternalCLK1Source_TI1ED ((uint16_t)0x0040)1 A5 C7 G0 t8 H8 I- @
- r Y) _3 a6 ?& k4 aTIM_External_Trigger_Polarity
. V2 q7 ^* ]3 J+ w) d
# p6 I, W2 O7 ~ @: @- /** @defgroup TIM_External_Trigger_Polarity
# _8 q9 L3 _8 v4 H - * @{
) U( j$ N) Q* d - */ 4 E, ?5 y G: p1 b$ h6 I( g5 A1 k; `
- #define TIM_ExtTRGPolarity_Inverted ((uint16_t)0x8000)" Q1 U7 ?. G& [( K N* s: X4 p
- #define TIM_ExtTRGPolarity_NonInverted ((uint16_t)0x0000)
: H# X) n2 g, Z; ~9 b - #define IS_TIM_EXT_POLARITY(POLARITY) (((POLARITY) == TIM_ExtTRGPolarity_Inverted) || \
& y( T+ g" R; T6 `6 K9 H6 r - ((POLARITY) == TIM_ExtTRGPolarity_NonInverted))
# E _) \3 {; K/ X! ~TIM_Prescaler_Reload_Mode
( K/ x5 ] U+ R: n) D3 I; H1 A, @0 N6 ~( Q# _
- /** @defgroup TIM_Prescaler_Reload_Mode 4 D: W( ?3 R/ N/ e5 B0 m
7 c) b' }7 g$ J7 ~* c9 m- {; Z - */
" m$ k8 }2 Z# g. M, z7 b4 T9 l - 9 h' h3 R* W- ^
- #define TIM_PSCReloadMode_Update ((uint16_t)0x0000)
* G6 K+ `7 p" T* e9 s7 [& k - #define TIM_PSCReloadMode_Immediate ((uint16_t)0x0001)
+ J* t6 H. `( u+ u D: K# P4 l - #define IS_TIM_PRESCALER_RELOAD(RELOAD) (((RELOAD) == TIM_PSCReloadMode_Update) || \
2 {7 r H5 @: @& B6 c- i) ^ - ((RELOAD) == TIM_PSCReloadMode_Immediate))
9 V$ T' P; u1 q7 F5 w3 T( P4 STIM_Forced_Action% r% c$ i( k% b1 H! e7 S
# n, s9 ^/ p* R8 I
- /** @defgroup TIM_Forced_Action
( J1 R) _+ k) ?7 ^7 ]' H - * @{# n9 ?/ [6 u" v: ]# }
3 f' ~4 p5 u4 H5 `! J - 6 W) g6 j& W1 p4 A
- #define TIM_ForcedAction_Active ((uint16_t)0x0050)2 ^. d7 h+ y1 M
- #define TIM_ForcedAction_InActive ((uint16_t)0x0040)
( V5 F8 R3 U$ [0 q - #define IS_TIM_FORCED_ACTION(ACTION) (((ACTION) == TIM_ForcedAction_Active) || \- s+ X1 F/ I. e% x% q0 _4 U
- ((ACTION) == TIM_ForcedAction_InActive))
' ~ Q5 {2 U( h& y: B$ u; ]: v) n" cTIM_Encoder_Mode
' E/ L% V5 Y7 l
( P" Z% Y" ^) b; ^" j% S7 }- /** @defgroup TIM_Encoder_Mode / t+ m, K* z, A: T6 P
- * @{" M/ F W) |8 G3 k1 h
* L+ j7 L0 X7 F4 s% D' D8 l
x$ P1 s5 W# v4 n- #define TIM_EncoderMode_TI1 ((uint16_t)0x0001); I; T4 M# n2 w" ~+ j- h
- #define TIM_EncoderMode_TI2 ((uint16_t)0x0002)
7 }7 o. R n5 \0 T% R7 W - #define TIM_EncoderMode_TI12 ((uint16_t)0x0003)
% l; g' z0 ^- E0 N$ i" T# G - #define IS_TIM_ENCODER_MODE(MODE) (((MODE) == TIM_EncoderMode_TI1) || \
. c# ^( V0 u5 D" O, y; K - ((MODE) == TIM_EncoderMode_TI2) || \( s9 y8 L% F/ Z1 Q( W0 c
- ((MODE) == TIM_EncoderMode_TI12))
" Q5 ?- x7 B% ?& rTIM_Event_Source U. Z' n9 e* o
, \9 g8 K2 p& F% \; N, d- /** @defgroup TIM_Event_Source
) z1 C" A8 A# q$ N7 H( s' [: V" b - * @{' {; H* K( a3 W2 B
( u( S/ @- N% p2 f" ^# k
; T7 P$ d( `# P. o- #define TIM_EventSource_Update ((uint16_t)0x0001)
* X* J0 B: [1 T0 N- A& {: }' ?$ a8 i - #define TIM_EventSource_CC1 ((uint16_t)0x0002)8 ]5 ]5 Q" W6 H7 I: A r
- #define TIM_EventSource_CC2 ((uint16_t)0x0004)9 s! G2 `' ]: T9 c" M' }6 Q0 z
- #define TIM_EventSource_CC3 ((uint16_t)0x0008)
9 v! f* X2 U( S( b; n6 L9 H - #define TIM_EventSource_CC4 ((uint16_t)0x0010)" m. l1 G0 e' Y
- #define TIM_EventSource_COM ((uint16_t)0x0020)
) _/ ~5 K9 b& R. [9 ~ - #define TIM_EventSource_Trigger ((uint16_t)0x0040)
|4 ~- `% F; K2 l - #define TIM_EventSource_Break ((uint16_t)0x0080)
- I' G! r! A$ u - #define IS_TIM_EVENT_SOURCE(SOURCE) ((((SOURCE) & (uint16_t)0xFF00) == 0x0000) && ((SOURCE) != 0x0000))
1 n4 m2 S( U1 g- U5 @9 E; aTIM_Update_Source- K$ \, O: ?/ k* Z( W0 Q
m6 ]: P% H8 w% R7 z1 U- /** @defgroup TIM_Update_Source 4 \9 y, m) [+ b( ~) l0 q
- * @{4 @* x1 x' `! g$ i
- */7 Z& h# K" Z: N4 k( J7 Y
/ I% L' G- a+ D) Q# r W! `$ r- #define TIM_UpdateSource_Global ((uint16_t)0x0000) /*!< Source of update is the counter overflow/underflow7 K3 {- Z* p& H Y* n4 V7 E
- or the setting of UG bit, or an update generation
& F: e1 D8 W" o( ^$ k - through the slave mode controller. */2 M+ B5 G5 W0 d$ y. i6 \
- #define TIM_UpdateSource_Regular ((uint16_t)0x0001) /*!< Source of update is counter overflow/underflow. */
1 R( e6 }8 W' z* k - #define IS_TIM_UPDATE_SOURCE(SOURCE) (((SOURCE) == TIM_UpdateSource_Global) || \9 k9 x/ z' n# T8 n, l( }# ]+ k
- ((SOURCE) == TIM_UpdateSource_Regular))
复制代码 % @3 {: \. M5 ?9 K* P0 ~1 p3 B, h2 J
TIM_Output_Compare_Preload_State# B7 F# U5 T* X
, C) g- H6 s: `
- /** @defgroup TIM_Output_Compare_Preload_State
2 J. v# J& E- n. N9 t o" e - * @{9 I$ X% U" z9 ^. T& t P" X8 R
- */5 N/ y( }. G% z
- 5 @7 I1 Z' M% |- K
- #define TIM_OCPreload_Enable ((uint16_t)0x0008)- {- o9 e/ v& p' Y
- #define TIM_OCPreload_Disable ((uint16_t)0x0000)$ j5 _: I% U0 k! U* H
- #define IS_TIM_OCPRELOAD_STATE(STATE) (((STATE) == TIM_OCPreload_Enable) || \0 x+ [: X# {/ `3 o( i
- ((STATE) == TIM_OCPreload_Disable))
复制代码 2 L, b( x; [9 s y. h+ q& e1 ^
TIM_Output_Compare_Fast_State
' ?+ [" ^( I7 q* {- i1 Q
* G6 }. B5 J" R, y/ w: b6 P5 v8 R$ I# P- /** @defgroup TIM_Output_Compare_Fast_State
3 ?# B& x o, S) I% Q5 M7 ^ - * @{
1 k8 b, T" }' C* `/ E/ W( [ - */, X/ {5 U. ~) `; E
- . ~% f; _" R9 a
- #define TIM_OCFast_Enable ((uint16_t)0x0004)4 Q5 @+ F6 `0 T6 A* l, N" _- b6 G2 ?
- #define TIM_OCFast_Disable ((uint16_t)0x0000)
, J9 d8 N8 H8 C1 S2 w) P7 p0 u2 B - #define IS_TIM_OCFAST_STATE(STATE) (((STATE) == TIM_OCFast_Enable) || \
! n) T+ n; j2 O' O* p) } - ((STATE) == TIM_OCFast_Disable))
复制代码 , P# ^3 _' d2 E- O- ]% g) E" V
TIM_Output_Compare_Clear_State5 s$ ]. k) k/ } f
7 p! I2 _( d- G I: ?: @
- /** @defgroup TIM_Output_Compare_Clear_State
. `% G4 A$ s0 T9 V, k - * @{
; v* _# n; A# S2 J8 S+ |. _4 j - */
6 U/ Y8 w) y- [+ M) t8 C
* k" ]# O S6 l4 f- #define TIM_OCClear_Enable ((uint16_t)0x0080)7 b( Z! x: L$ H1 q+ q: {
- #define TIM_OCClear_Disable ((uint16_t)0x0000); {- d+ N* I, C8 y4 r7 E
- #define IS_TIM_OCCLEAR_STATE(STATE) (((STATE) == TIM_OCClear_Enable) || \ ]4 x# `' O7 [; |3 k
- ((STATE) == TIM_OCClear_Disable))
复制代码 , k9 W0 k/ A3 ]2 t
TIM_Trigger_Output_Source
3 y7 X* [0 [2 x/ K* E
" V7 N" D" V k9 f0 o- /** @defgroup TIM_Trigger_Output_Source
& f9 h( q T" Z" L" |- v; O S+ @ - * @{
3 u" d; N! O# ?4 x4 Y( G - */( T" [/ g6 Z V6 t: R; O A
- & l" {# B6 w0 Q. F t
- #define TIM_TRGOSource_Reset ((uint16_t)0x0000)& R' o& ?. P! c8 q
- #define TIM_TRGOSource_Enable ((uint16_t)0x0010)- E& w+ \4 V( b
- #define TIM_TRGOSource_Update ((uint16_t)0x0020): I- r/ [( D; X. \8 }5 M/ f
- #define TIM_TRGOSource_OC1 ((uint16_t)0x0030)$ P' i. {$ ]$ C T0 x
- #define TIM_TRGOSource_OC1Ref ((uint16_t)0x0040)' S0 b+ N6 u V
- #define TIM_TRGOSource_OC2Ref ((uint16_t)0x0050)
' C i3 p+ s+ h+ M" O - #define TIM_TRGOSource_OC3Ref ((uint16_t)0x0060)
5 @3 B* v7 e K4 g% P" l# u - #define TIM_TRGOSource_OC4Ref ((uint16_t)0x0070)9 r) s2 P, h3 S* D% _
- #define IS_TIM_TRGO_SOURCE(SOURCE) (((SOURCE) == TIM_TRGOSource_Reset) || \! F, H" R- y/ e
- ((SOURCE) == TIM_TRGOSource_Enable) || \
: d8 F" _$ b$ U: [ - ((SOURCE) == TIM_TRGOSource_Update) || \ O6 c- |" x) W6 L0 u8 J
- ((SOURCE) == TIM_TRGOSource_OC1) || \
2 J8 c p; W0 ?5 R: K - ((SOURCE) == TIM_TRGOSource_OC1Ref) || \
5 H( C7 l( F( X7 V6 a* t2 o$ U& k - ((SOURCE) == TIM_TRGOSource_OC2Ref) || \
) x" R9 v( A; \! Z - ((SOURCE) == TIM_TRGOSource_OC3Ref) || \* B) c+ u2 ~- H" l& L6 k9 S
- ((SOURCE) == TIM_TRGOSource_OC4Ref))
复制代码 2 z Y9 w% m/ O/ }/ W7 l0 k
TIM_Slave_Mode: X7 p* U1 {( V1 q4 s8 Y& p
4 p5 D% G1 a" b8 y4 D- /** @defgroup TIM_Slave_Mode
7 ~# ~9 r& V3 C - * @{
7 Y4 _* I% c$ l [ - */
3 c/ i. n( g/ E- P
7 B9 _; f4 K- B1 K/ N% d- #define TIM_SlaveMode_Reset ((uint16_t)0x0004)9 k; \4 p( f4 P" l# B- w
- #define TIM_SlaveMode_Gated ((uint16_t)0x0005)
7 x1 b$ d- S) X5 q - #define TIM_SlaveMode_Trigger ((uint16_t)0x0006)
5 ?0 j4 H3 q0 Y6 T5 W8 d# R - #define TIM_SlaveMode_External1 ((uint16_t)0x0007)
6 h6 I0 n, c, O( r, i - #define IS_TIM_SLAVE_MODE(MODE) (((MODE) == TIM_SlaveMode_Reset) || \
* S& Z$ o. b7 A) ^ m - ((MODE) == TIM_SlaveMode_Gated) || \6 i/ J" O; ~5 R, d- T2 g& v" Z6 b
- ((MODE) == TIM_SlaveMode_Trigger) || \: `! W. S2 a; `' z5 _3 U9 F; p/ h
- ((MODE) == TIM_SlaveMode_External1))
0 J( v4 K$ f* \. A, y$ _. JTIM_Master_Slave_Mode
1 Y8 g9 j7 X+ h1 V& c5 {1 M, I! X
; o, [/ @& s% L2 D/ t1 ]6 k- /** @defgroup TIM_Master_Slave_Mode
5 }! t0 o% {9 @ - * @{4 f# g- d3 _& F& v2 W4 o
% Z. j. T$ i! H) G8 c2 f4 N# M$ I
8 l9 H& F: \- G9 c9 i6 _- #define TIM_MasterSlaveMode_Enable ((uint16_t)0x0080)
& Y0 L! R$ A# m; z - #define TIM_MasterSlaveMode_Disable ((uint16_t)0x0000) G1 H3 o4 R, ?! j* D+ L
- #define IS_TIM_MSM_STATE(STATE) (((STATE) == TIM_MasterSlaveMode_Enable) || \) l: j# Y4 o7 r8 r
- ((STATE) == TIM_MasterSlaveMode_Disable))
/ B% G4 p: P7 o+ Z+ |. ETIM_Remap
' c _# G, M4 S Z* e* j& ~/ f
9 G5 t. d# \; Y8 g/ L0 G- /** @defgroup TIM_Remap 8 y, a+ {& @1 H) v( W
- * @{5 M1 L/ g' b$ E) }+ V1 g+ U: v0 d
- */8 d' A) C* J& F
; f2 I; c* p! _! V- #define TIM2_TIM8_TRGO ((uint16_t)0x0000)3 C) I: O: O$ W
- #define TIM2_ETH_PTP ((uint16_t)0x0400)
6 c4 L' ^2 T$ Y$ X1 V4 P7 C - #define TIM2_USBFS_SOF ((uint16_t)0x0800)- Q6 b3 L3 g% d z, ^0 a4 z
- #define TIM2_USBHS_SOF ((uint16_t)0x0C00)* V# P! H. b; U
- ( |4 g/ e& ^% `5 R: e
- #define TIM5_GPIO ((uint16_t)0x0000); ^9 c A2 N0 W. {. x
- #define TIM5_LSI ((uint16_t)0x0040)! s" K6 k1 B; I% E8 v9 T, O+ P0 e+ c! u
- #define TIM5_LSE ((uint16_t)0x0080)5 J0 j' t- Z9 k$ z r
- #define TIM5_RTC ((uint16_t)0x00C0)- R5 g1 }6 N. G, s/ G4 X% V
5 X" L! ~0 F& N# x& Z- #define TIM11_GPIO ((uint16_t)0x0000)
4 P0 X4 z( p) J- T - #define TIM11_HSE ((uint16_t)0x0002)
9 L- E- Q X7 Z$ l1 @0 v
, v2 H0 g. T$ D/ v b7 H; I- #define IS_TIM_REMAP(TIM_REMAP) (((TIM_REMAP) == TIM2_TIM8_TRGO)||\
$ ~( J! d4 ] t: s& B: V/ V. A - ((TIM_REMAP) == TIM2_ETH_PTP)||\
# m9 n; C m& V% B! t; N( L, r - ((TIM_REMAP) == TIM2_USBFS_SOF)||\
/ M3 W! B6 j% g; _% g4 N. C# e - ((TIM_REMAP) == TIM2_USBHS_SOF)||\
6 E8 p( ^& ^; G3 v - ((TIM_REMAP) == TIM5_GPIO)||\7 `) y+ O1 Y% k; T, _
- ((TIM_REMAP) == TIM5_LSI)||\
5 P6 k, d9 U, Y( A0 y% o - ((TIM_REMAP) == TIM5_LSE)||\
. b, I( J* |5 M- {) c - ((TIM_REMAP) == TIM5_RTC)||\
1 C1 g" \& @ ]( [ - ((TIM_REMAP) == TIM11_GPIO)||\8 ]1 Y# M, z; ?# q) a* C
- ((TIM_REMAP) == TIM11_HSE))
复制代码 2 V$ R! ]7 O, P- \
TIM_Flags
7 y. L0 P) t }0 K# I9 b0 x+ W+ k% z7 ]- W* J
- /** @defgroup TIM_Flags
6 v% Y- g; s# v9 P - * @{
3 ^7 O/ X8 d( D - */1 f* L" }0 P5 f6 J& o( S
- 6 Y, @. P) V/ o$ i1 g* r+ N3 O
- #define TIM_FLAG_Update ((uint16_t)0x0001)6 }' j6 l# e$ W# X' \% a- f' c
- #define TIM_FLAG_CC1 ((uint16_t)0x0002)
1 B6 `% E/ w" M* }+ R! X$ N - #define TIM_FLAG_CC2 ((uint16_t)0x0004)% `/ q4 q2 |" r% ~2 _$ A
- #define TIM_FLAG_CC3 ((uint16_t)0x0008). T- B( d0 F G8 F$ _
- #define TIM_FLAG_CC4 ((uint16_t)0x0010)/ K' G% f* R; F: b; R, J5 p2 [
- #define TIM_FLAG_COM ((uint16_t)0x0020)
' D8 |( U& B7 u- q! \7 D7 Q% ^ - #define TIM_FLAG_Trigger ((uint16_t)0x0040). s6 M" O W. j7 _
- #define TIM_FLAG_Break ((uint16_t)0x0080)
! }0 ^- h. |) Z - #define TIM_FLAG_CC1OF ((uint16_t)0x0200)
" g& H" D( [. [! s& ]% R6 f - #define TIM_FLAG_CC2OF ((uint16_t)0x0400)
7 z& c0 d* L1 p: N) a - #define TIM_FLAG_CC3OF ((uint16_t)0x0800)
% a# i5 H6 P" u6 {0 G - #define TIM_FLAG_CC4OF ((uint16_t)0x1000)
% w" }% f2 w" M$ R P# @! ]8 n - #define IS_TIM_GET_FLAG(FLAG) (((FLAG) == TIM_FLAG_Update) || \. R! h$ ?8 ^( i1 T# E
- ((FLAG) == TIM_FLAG_CC1) || \
& r' [6 S# {) n0 ~+ W - ((FLAG) == TIM_FLAG_CC2) || \9 i1 Y" a5 F1 M$ P I
- ((FLAG) == TIM_FLAG_CC3) || \! s5 o. J1 L! j B9 }
- ((FLAG) == TIM_FLAG_CC4) || \
& g* W$ L/ i4 u3 L - ((FLAG) == TIM_FLAG_COM) || \
1 `8 o6 f( ~6 C' m, u" E - ((FLAG) == TIM_FLAG_Trigger) || \% x! @# N% N7 d' Z. l: E( ~/ J
- ((FLAG) == TIM_FLAG_Break) || \ w& ^! k9 M( |. _0 y' p3 e
- ((FLAG) == TIM_FLAG_CC1OF) || \
, S4 k2 Q9 { F" \6 V - ((FLAG) == TIM_FLAG_CC2OF) || \* O, L; G) G1 I1 _5 x( o9 u" C v( e
- ((FLAG) == TIM_FLAG_CC3OF) || \9 ]& N8 h& l. i* Q5 V f; l7 }1 }( z- }" B
- ((FLAG) == TIM_FLAG_CC4OF))
- Z! v% z; Z# m$ J3 \9 W其它/ Q7 [* P8 [7 Z& y+ i
$ R# s! O: T) _7 ` d
- /** @defgroup TIM_Input_Capture_Filer_Value
/ j! O; Y2 t9 o, C' D0 q3 x - * @{ C6 T2 o1 d4 _! `# R7 c
; o2 {1 K- p" m! ]) t6 V
7 r9 Z) U9 q6 ?: a! ], c1 k7 |- #define IS_TIM_IC_FILTER(ICFILTER) ((ICFILTER) <= 0xF) % u' q' W$ p! K( u- M8 W
- /**% r3 C; G: z: o$ D3 ^( X
" G% l2 M5 z& t7 C7 |$ ~7 M/ Q. l - */
7 V: Z: v: h9 U% J - 8 h" C- c0 Z. Q- G/ [
- /** @defgroup TIM_External_Trigger_Filter & E: X2 }+ b }
7 `$ ?; p! v$ h* T( |1 o7 j - */
+ E1 A$ ^2 B; e7 G - 4 t: P3 r/ W/ t6 X, k
- #define IS_TIM_EXT_FILTER(EXTFILTER) ((EXTFILTER) <= 0xF)& z" Q% [" B- i6 }
- j( B# }5 z H - * @}
6 U8 W8 F2 f0 ?9 J& c - */ & K U; a5 ^% b$ L/ [+ S. v( M* W
- , z6 e0 v# r& N
- /** @defgroup TIM_Legacy 2 d1 S; r) u5 j. i: I
- * @{) g/ _& P5 Q4 a0 n# \6 {
: k5 j9 X: ]( y3 m, L- a4 a
: k- N" C3 |) l: _$ H- #define TIM_DMABurstLength_1Byte TIM_DMABurstLength_1Transfer* h1 D( v$ ^' x+ ^( i% g
- #define TIM_DMABurstLength_2Bytes TIM_DMABurstLength_2Transfers
7 E) E D4 A7 V2 |8 ^ - #define TIM_DMABurstLength_3Bytes TIM_DMABurstLength_3Transfers
5 n; v/ y; X: n - #define TIM_DMABurstLength_4Bytes TIM_DMABurstLength_4Transfers
m7 |3 T" P' | - #define TIM_DMABurstLength_5Bytes TIM_DMABurstLength_5Transfers
" [9 U1 X9 d1 r - #define TIM_DMABurstLength_6Bytes TIM_DMABurstLength_6Transfers3 |3 s2 D, ?2 }9 M7 K! }
- #define TIM_DMABurstLength_7Bytes TIM_DMABurstLength_7Transfers% @: ^9 U9 N3 B' M4 j/ b
- #define TIM_DMABurstLength_8Bytes TIM_DMABurstLength_8Transfers+ G6 R! _- k( [8 ]
- #define TIM_DMABurstLength_9Bytes TIM_DMABurstLength_9Transfers" Q' S% n" g5 b/ q
- #define TIM_DMABurstLength_10Bytes TIM_DMABurstLength_10Transfers
4 j0 n; E# C- h' g( d - #define TIM_DMABurstLength_11Bytes TIM_DMABurstLength_11Transfers4 r! U% C$ ^6 j; B
- #define TIM_DMABurstLength_12Bytes TIM_DMABurstLength_12Transfers8 U! c1 J& j2 ?
- #define TIM_DMABurstLength_13Bytes TIM_DMABurstLength_13Transfers7 G! d& z q7 j2 v: r
- #define TIM_DMABurstLength_14Bytes TIM_DMABurstLength_14Transfers
2 v& ]7 |3 F, i% @+ S' b2 w - #define TIM_DMABurstLength_15Bytes TIM_DMABurstLength_15Transfers# F3 _8 l, A) a% i$ U
- #define TIM_DMABurstLength_16Bytes TIM_DMABurstLength_16Transfers
" r0 s: k$ g: C a6 F2 X - #define TIM_DMABurstLength_17Bytes TIM_DMABurstLength_17Transfers; v% M F3 W: P N5 k
- #define TIM_DMABurstLength_18Bytes TIM_DMABurstLength_18Transfers
5 A% z' {( S/ Q2 Q03. 相关函数
7 I' @# }$ y; f" P- /* TimeBase management ********************************************************/
; A5 d/ ]+ Q# ~5 W - void TIM_DeInit(TIM_TypeDef* TIMx);
/ x4 b% o! l/ W3 D& k7 ?" r+ r - void TIM_TimeBaseInit(TIM_TypeDef* TIMx, TIM_TimeBaseInitTypeDef* TIM_TimeBaseInitStruct);
; I" O n+ J! _5 O1 T' P2 i0 S - void TIM_TimeBaseStructInit(TIM_TimeBaseInitTypeDef* TIM_TimeBaseInitStruct);5 _' M" ^. q3 V/ A, Y
- void TIM_PrescalerConfig(TIM_TypeDef* TIMx, uint16_t Prescaler, uint16_t TIM_PSCReloadMode);
; Y; G* `4 `/ P0 ? - void TIM_CounterModeConfig(TIM_TypeDef* TIMx, uint16_t TIM_CounterMode);
6 c+ L5 a% b5 a' S - void TIM_SetCounter(TIM_TypeDef* TIMx, uint32_t Counter);! f0 j. x# A5 A3 U* I, G
- void TIM_SetAutoreload(TIM_TypeDef* TIMx, uint32_t Autoreload);; s0 `; _" q- _/ b* e( f
- uint32_t TIM_GetCounter(TIM_TypeDef* TIMx); G2 I1 V. `6 i
- uint16_t TIM_GetPrescaler(TIM_TypeDef* TIMx);
7 X+ t' a, T- g% f y3 p - void TIM_UpdateDisableConfig(TIM_TypeDef* TIMx, FunctionalState NewState);. V% v6 W2 ]8 K* u, h
- void TIM_UpdateRequestConfig(TIM_TypeDef* TIMx, uint16_t TIM_UpdateSource);+ M$ P# e% b$ O. ?. [( B
- void TIM_ARRPreloadConfig(TIM_TypeDef* TIMx, FunctionalState NewState);' D5 b" O$ C$ a
- void TIM_SelectOnePulseMode(TIM_TypeDef* TIMx, uint16_t TIM_OPMode);
7 v* @% @- c+ F7 u7 | - void TIM_SetClockDivision(TIM_TypeDef* TIMx, uint16_t TIM_CKD);0 u& x: C/ ~+ d- A- D9 L' P
- void TIM_Cmd(TIM_TypeDef* TIMx, FunctionalState NewState);
2 S" D T1 e* L( \% D1 m. ^$ R - ' d# t0 p) L" g' j2 m0 g" h
- /* Output Compare management **************************************************/3 X( V! V' \" P9 T d0 X+ Y
- void TIM_OC1Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
) D x3 I# p0 ?& J$ {/ ~ - void TIM_OC2Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
7 ^& n+ u7 Q% h9 G - void TIM_OC3Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);
Y, s* D9 j5 ?5 i - void TIM_OC4Init(TIM_TypeDef* TIMx, TIM_OCInitTypeDef* TIM_OCInitStruct);! C0 e( j/ e9 [+ _
- void TIM_OCStructInit(TIM_OCInitTypeDef* TIM_OCInitStruct);
7 A7 J4 L/ T/ [0 A% | - void TIM_SelectOCxM(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_OCMode);
4 i9 ?" S% x* y0 c$ n - void TIM_SetCompare1(TIM_TypeDef* TIMx, uint32_t Compare1);
" N E6 e. `" `6 }9 A- W4 U0 ` - void TIM_SetCompare2(TIM_TypeDef* TIMx, uint32_t Compare2);
" C, o7 P( U* e* Z: p$ u, y - void TIM_SetCompare3(TIM_TypeDef* TIMx, uint32_t Compare3);8 Q4 z; [9 C7 s( ^8 `
- void TIM_SetCompare4(TIM_TypeDef* TIMx, uint32_t Compare4); n* p% X( U6 v0 o; N+ n$ \/ f+ s
- void TIM_ForcedOC1Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
. v J3 U, i: d" n8 {; S - void TIM_ForcedOC2Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
% Q- X" x4 L4 Y - void TIM_ForcedOC3Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);
9 B9 j0 X# {, r+ g) c - void TIM_ForcedOC4Config(TIM_TypeDef* TIMx, uint16_t TIM_ForcedAction);- y& D( y/ O! r! U) K+ M
- void TIM_OC1PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);/ u# e ~& Z7 ?6 r0 u) ^: P5 N
- void TIM_OC2PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);
* i# n: N6 v! n3 U- k. D+ U2 U - void TIM_OC3PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload);+ s# E$ a) k5 Q! `
- void TIM_OC4PreloadConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPreload); o9 M% L- m9 N- Q- Z
- void TIM_OC1FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);8 Z: m! z% L, R. w0 |) a
- void TIM_OC2FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);! f+ b9 @$ r) _& w2 p3 }8 B
- void TIM_OC3FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);$ g! r2 k! I; {! v7 L. }
- void TIM_OC4FastConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCFast);# c( `7 h( K9 |7 B
- void TIM_ClearOC1Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
$ G h" J" u0 } - void TIM_ClearOC2Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
! d4 M M" O, k9 m* u j2 i - void TIM_ClearOC3Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);
$ |! c# F: U- n3 G# [- A - void TIM_ClearOC4Ref(TIM_TypeDef* TIMx, uint16_t TIM_OCClear);) a. H3 B8 c: k5 [0 p- k! y
- void TIM_OC1PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);: H1 a, Y1 }% K* F, r
- void TIM_OC1NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);; j! m% z7 m; D: q2 x
- void TIM_OC2PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);( `* M3 ]) b( M$ ?
- void TIM_OC2NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);& K& d+ w3 P: [/ f- m
- void TIM_OC3PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity);6 j; }2 }& E3 J* l
- void TIM_OC3NPolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCNPolarity);. Q- H5 O5 p) u8 s
- void TIM_OC4PolarityConfig(TIM_TypeDef* TIMx, uint16_t TIM_OCPolarity); D- j6 \- d- h2 O% m1 F) k2 x
- void TIM_CCxCmd(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_CCx);
% J& T5 y' {# n5 T - void TIM_CCxNCmd(TIM_TypeDef* TIMx, uint16_t TIM_Channel, uint16_t TIM_CCxN);
# ~# Y+ @: j) v/ W
1 S; b8 Y; Y5 O+ _; S2 P- /* Input Capture management ***************************************************/
8 \" t8 l" D8 K" j" a) } - void TIM_ICInit(TIM_TypeDef* TIMx, TIM_ICInitTypeDef* TIM_ICInitStruct); E5 p" ?- h' k, S8 Z2 I) x
- void TIM_ICStructInit(TIM_ICInitTypeDef* TIM_ICInitStruct);
6 g/ B( C. ^2 O% O5 V# F - void TIM_PWMIConfig(TIM_TypeDef* TIMx, TIM_ICInitTypeDef* TIM_ICInitStruct); {9 R+ ^% v! h; I( o: J% ?' e
- uint32_t TIM_GetCapture1(TIM_TypeDef* TIMx); Y! X* E& _9 C6 J1 {( u/ H6 p2 J
- uint32_t TIM_GetCapture2(TIM_TypeDef* TIMx);
* i/ n( i3 I' m+ `4 h - uint32_t TIM_GetCapture3(TIM_TypeDef* TIMx);7 v6 B. W7 d G: k" M& Y
- uint32_t TIM_GetCapture4(TIM_TypeDef* TIMx);& G5 p( }2 C# o. R9 L" J6 t) B) ~
- void TIM_SetIC1Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);
5 e) w! `1 D6 L$ J" [3 y* A1 a$ l - void TIM_SetIC2Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC); w: F4 c3 b+ r, \# `
- void TIM_SetIC3Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);& q' L% m0 P* o6 M2 a
- void TIM_SetIC4Prescaler(TIM_TypeDef* TIMx, uint16_t TIM_ICPSC);, O' |: t9 P8 D( T @+ @8 G
- 1 m8 s& J- X [
- /* Advanced-control timers (TIM1 and TIM8) specific features ******************/3 d* ~& ?; w \' N, f: x' W0 y
- void TIM_BDTRConfig(TIM_TypeDef* TIMx, TIM_BDTRInitTypeDef *TIM_BDTRInitStruct);+ W/ u9 Y; j" q# i/ O
- void TIM_BDTRStructInit(TIM_BDTRInitTypeDef* TIM_BDTRInitStruct);
T) N. |* k2 [7 o8 f+ M- A2 }4 P - void TIM_CtrlPWMOutputs(TIM_TypeDef* TIMx, FunctionalState NewState);
# f; B2 O8 H& x/ b - void TIM_SelectCOM(TIM_TypeDef* TIMx, FunctionalState NewState);7 b1 Y) l' u: C6 y3 k
- void TIM_CCPreloadControl(TIM_TypeDef* TIMx, FunctionalState NewState);5 }9 {7 [$ _" d* @6 K# G
' N: n+ I, f% ~# E2 [6 y' z2 d" S- Z- /* Interrupts, DMA and flags management ***************************************/" |# `$ j6 @; }$ z9 a
- void TIM_ITConfig(TIM_TypeDef* TIMx, uint16_t TIM_IT, FunctionalState NewState);9 h$ [; { R# A: I9 d
- void TIM_GenerateEvent(TIM_TypeDef* TIMx, uint16_t TIM_EventSource);
# t0 w- s! U# w) [) z - FlagStatus TIM_GetFlagStatus(TIM_TypeDef* TIMx, uint16_t TIM_FLAG);, f7 |+ ]) ?4 Z6 q8 r6 y( F
- void TIM_ClearFlag(TIM_TypeDef* TIMx, uint16_t TIM_FLAG);
: A8 m1 m9 Q4 J/ }# P - ITStatus TIM_GetITStatus(TIM_TypeDef* TIMx, uint16_t TIM_IT);
- M3 W. O) M6 w) x0 B' y0 B" T - void TIM_ClearITPendingBit(TIM_TypeDef* TIMx, uint16_t TIM_IT);9 i9 N2 u" s$ y
- void TIM_DMAConfig(TIM_TypeDef* TIMx, uint16_t TIM_DMABase, uint16_t TIM_DMABurstLength);; c* p: _+ u9 x R" C, }
- void TIM_DMACmd(TIM_TypeDef* TIMx, uint16_t TIM_DMASource, FunctionalState NewState); S! q4 E7 o/ `+ J: `5 f. p
- void TIM_SelectCCDMA(TIM_TypeDef* TIMx, FunctionalState NewState);4 K9 x3 [( q, w0 J# ?
- 8 Z8 }: e; G. n8 o
- /* Clocks management **********************************************************/9 u0 e% T7 d$ {( ^3 h5 X1 F0 t0 q
- void TIM_InternalClockConfig(TIM_TypeDef* TIMx);
. ?3 Q$ [! p, V$ Z, D - void TIM_ITRxExternalClockConfig(TIM_TypeDef* TIMx, uint16_t TIM_InputTriggerSource);
* `( x* T7 z$ {: S# }) b6 ] - void TIM_TIxExternalClockConfig(TIM_TypeDef* TIMx, uint16_t TIM_TIxExternalCLKSource," [. G2 ^/ f5 L& \8 ?
- uint16_t TIM_ICPolarity, uint16_t ICFilter);
0 s9 g6 r4 |3 t* l# w - void TIM_ETRClockMode1Config(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, uint16_t TIM_ExtTRGPolarity,
) _1 x& ^# s* {; i! ?$ O - uint16_t ExtTRGFilter);) [) E9 ]" `( F# `* a
- void TIM_ETRClockMode2Config(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler,
7 ~9 Q( k* w0 I# l - uint16_t TIM_ExtTRGPolarity, uint16_t ExtTRGFilter);2 w! y* z& a# n3 ?2 u# T1 ]( a) S2 X
+ `/ \+ I# P! l4 p- /* Synchronization management *************************************************/* S( W9 @ ]& s8 U
- void TIM_SelectInputTrigger(TIM_TypeDef* TIMx, uint16_t TIM_InputTriggerSource);
! \0 C3 b4 T& r9 _4 t) } - void TIM_SelectOutputTrigger(TIM_TypeDef* TIMx, uint16_t TIM_TRGOSource);
: Y/ q, @! @3 x: z2 T3 L- ? - void TIM_SelectSlaveMode(TIM_TypeDef* TIMx, uint16_t TIM_SlaveMode);
! F' `1 k0 S2 h( @ - void TIM_SelectMasterSlaveMode(TIM_TypeDef* TIMx, uint16_t TIM_MasterSlaveMode);
' v, B! j# j! K) {4 L* D - void TIM_ETRConfig(TIM_TypeDef* TIMx, uint16_t TIM_ExtTRGPrescaler, uint16_t TIM_ExtTRGPolarity,
; p+ L( \0 S& n: [- D( c) d( t$ L - uint16_t ExtTRGFilter);
; |. e, c7 N# o/ m
: r4 A+ W4 K. C$ N4 j- /* Specific interface management **********************************************/ 0 R, t! G& G0 A% D
- void TIM_EncoderInterfaceConfig(TIM_TypeDef* TIMx, uint16_t TIM_EncoderMode,9 `9 I$ M$ V5 {+ P. Q$ i
- uint16_t TIM_IC1Polarity, uint16_t TIM_IC2Polarity);
' o& G8 V- ~( \. D9 t' p9 ?9 ~3 m9 s$ d - void TIM_SelectHallSensor(TIM_TypeDef* TIMx, FunctionalState NewState);
* A! ~2 |0 |. ]! C: d2 q - * {1 s. Z! F( Q% P& I2 q
- /* Specific remapping management **********************************************/( t& B I) h4 c( O- o
- void TIM_RemapConfig(TIM_TypeDef* TIMx, uint16_t TIM_Remap);
复制代码 / @1 Q A" I/ |# ~
04. 结构体封装9 o; B$ L- H: m& M6 f) _* J' w* o
2 p( D. G. R- g6 K( N - * @brief TIM' p0 ?' x. w. c
; Q4 o/ M# v( ^& \3 X/ \1 ~ - $ ^, J% G( U5 F8 \; t
- typedef struct
7 B3 e. Q8 C: a/ t# `" }7 y - {7 H Q+ Y8 X( C
- __IO uint16_t CR1; /*!< TIM control register 1, Address offset: 0x00 */
" P! t, X" z+ t. V - uint16_t RESERVED0; /*!< Reserved, 0x02 */! a( `4 G1 y) g6 f2 ?. ~, H, m3 g
- __IO uint16_t CR2; /*!< TIM control register 2, Address offset: 0x04 */
) ?7 @0 a/ F! c( k - uint16_t RESERVED1; /*!< Reserved, 0x06 */
; z4 q" a v* I7 ?& P; O - __IO uint16_t SMCR; /*!< TIM slave mode control register, Address offset: 0x08 */
4 R% P, p9 z) @) c% { - uint16_t RESERVED2; /*!< Reserved, 0x0A */
3 H# E; e- u5 U6 \2 k - __IO uint16_t DIER; /*!< TIM DMA/interrupt enable register, Address offset: 0x0C */9 e+ W8 y: r9 e* S
- uint16_t RESERVED3; /*!< Reserved, 0x0E */4 s+ h, ^3 U a5 ^2 L2 u
- __IO uint16_t SR; /*!< TIM status register, Address offset: 0x10 */( o1 I+ A d0 m1 R1 k5 b* \
- uint16_t RESERVED4; /*!< Reserved, 0x12 */
+ F6 [2 C4 H7 G! t% }9 f3 `2 t - __IO uint16_t EGR; /*!< TIM event generation register, Address offset: 0x14 */7 b- }: P1 o- g' t
- uint16_t RESERVED5; /*!< Reserved, 0x16 */7 @8 ]% I, O; {
- __IO uint16_t CCMR1; /*!< TIM capture/compare mode register 1, Address offset: 0x18 */
( h; i9 q. f8 Z$ p2 K" Y" N$ Y - uint16_t RESERVED6; /*!< Reserved, 0x1A */. a- `% v' c: N2 q2 H
- __IO uint16_t CCMR2; /*!< TIM capture/compare mode register 2, Address offset: 0x1C */, O# d8 P& h* u# B% ?7 E
- uint16_t RESERVED7; /*!< Reserved, 0x1E */! f/ X1 L/ @7 \' D2 K0 v" f
- __IO uint16_t CCER; /*!< TIM capture/compare enable register, Address offset: 0x20 */$ I7 g7 Y1 ]0 {
- uint16_t RESERVED8; /*!< Reserved, 0x22 */" _2 P* l$ I! k! \
- __IO uint32_t CNT; /*!< TIM counter register, Address offset: 0x24 */
, ? O$ r" e% J - __IO uint16_t PSC; /*!< TIM prescaler, Address offset: 0x28 */
: _( r+ x }! n1 F - uint16_t RESERVED9; /*!< Reserved, 0x2A */
2 |0 g& i2 n0 H$ C7 ?$ b - __IO uint32_t ARR; /*!< TIM auto-reload register, Address offset: 0x2C */
; Z0 ], k5 W1 d& W7 X - __IO uint16_t RCR; /*!< TIM repetition counter register, Address offset: 0x30 */
3 M/ c, z6 a( ~1 f# h @ - uint16_t RESERVED10; /*!< Reserved, 0x32 */3 Q4 j' s/ n7 o2 a2 D
- __IO uint32_t CCR1; /*!< TIM capture/compare register 1, Address offset: 0x34 */7 m: s8 N# d# Y' p. V
- __IO uint32_t CCR2; /*!< TIM capture/compare register 2, Address offset: 0x38 */" m: D0 l {6 B! j
- __IO uint32_t CCR3; /*!< TIM capture/compare register 3, Address offset: 0x3C */
9 N; e9 m. G; X - __IO uint32_t CCR4; /*!< TIM capture/compare register 4, Address offset: 0x40 */
' J) z L) l) g4 ^3 u3 a - __IO uint16_t BDTR; /*!< TIM break and dead-time register, Address offset: 0x44 */
' l! X( m* A$ F' ?7 q' T. s - uint16_t RESERVED11; /*!< Reserved, 0x46 */
* a8 P5 F. O: q4 O; ~$ W' U7 | - __IO uint16_t DCR; /*!< TIM DMA control register, Address offset: 0x48 */( ~+ A0 m, O2 P. S( u" c- D
- uint16_t RESERVED12; /*!< Reserved, 0x4A */
9 D0 h S! [$ } - __IO uint16_t DMAR; /*!< TIM DMA address for full transfer, Address offset: 0x4C */
* f: N* ]& I+ s1 V$ Q- a# x2 Z - uint16_t RESERVED13; /*!< Reserved, 0x4E */
; {% _ S+ O+ c* r- J - __IO uint16_t OR; /*!< TIM option register, Address offset: 0x50 */
2 j% t9 R: S( A" L - uint16_t RESERVED14; /*!< Reserved, 0x52 */
' ` t, D( {1 c7 m - } TIM_TypeDef;
复制代码 ! i4 k, n4 |* V5 z2 c5 `
% a2 l& n3 p# [: [1 Y! B, W
# g5 C7 j: v# ?4 ] |
