01. ADC概述
: L% F; z: P6 ] q" h. B) r7 }STM32F4xx 系列一般都有 3 个 ADC,这些 ADC 可以独立使用,也可以使用双重/三重模式(提高采样率)。STM32F4 的 ADC 是 12 位逐次逼近型的模拟数字转换器。它有 19 个通道,可测量 16 个外部源、2 个内部源和 Vbat 通道的信号。这些通道的 A/D 转换可以单次、连续、扫描或间断模式执行。ADC 的结果可以左对齐或右对齐方式存储在 16 位数据寄存器中。 模拟看门狗特性允许应用程序检测输入电压是否超出用户定义的高/低阀值。
0 r* P9 \6 E' {$ \" Y% `# ?7 |9 g- A# k
相关文件为 stm32f4xx_adc.h和 stm32f4xx_adc.c。, L. ^5 j. O9 G) d$ ~
7 n6 F/ e" P5 u4 F! {
02. 相关类型% S% T5 v U" X
- /** , e9 R/ R# _, W
- * @brief ADC Init structure definition 3 l& Q0 v, a6 g D
- */ 3 ]0 a4 b& x5 n* |, @* h' d
- typedef struct1 _; {0 d6 P; g
- {/ T3 z) a5 t0 E5 ]( o
- uint32_t ADC_Resolution; /*!< Configures the ADC resolution dual mode.
& m: q' G; Y/ y3 c& C4 K+ i - This parameter can be a value of @ref ADC_resolution */
7 X7 w3 \( `+ P! y% R8 ]- y# f0 w# \ - FunctionalState ADC_ScanConvMode; /*!< Specifies whether the conversion 9 a2 o( z( k6 V+ g2 M* W
- is performed in Scan (multichannels)
* ^- A* S B) K$ J$ W' k; R - or Single (one channel) mode.8 ?9 E2 P3 v- V! a1 `1 Y
- This parameter can be set to ENABLE or DISABLE */ 6 s2 |0 c: g) S0 E# `1 ~0 b5 Q- j
- FunctionalState ADC_ContinuousConvMode; /*!< Specifies whether the conversion , H9 P* F( {8 `' v3 D
- is performed in Continuous or Single mode.
8 {0 r& g1 G' t: I/ Y$ `8 }* a% L - This parameter can be set to ENABLE or DISABLE. */9 G1 r ?0 P2 o5 k
- uint32_t ADC_ExternalTrigConvEdge; /*!< Select the external trigger edge and
: r0 n b9 G* @- o8 _ T5 F5 p9 _ - enable the trigger of a regular group. $ q. M' l" [5 Z5 t+ ?
- This parameter can be a value of - k8 c' T6 Q% ~! v/ F/ Q
- @ref ADC_external_trigger_edge_for_regular_channels_conversion */3 g7 ] H; u5 N l8 @
- uint32_t ADC_ExternalTrigConv; /*!< Select the external event used to trigger 0 k4 ?. Y7 t, U/ ], t) F
- the start of conversion of a regular group.6 O+ @6 Q/ E! ^: n$ X- B( l
. ]! v% r1 |9 j3 Z1 Q" m4 Y - @ref ADC_extrenal_trigger_sources_for_regular_channels_conversion */1 i6 d5 }/ U2 ?0 D
- uint32_t ADC_DataAlign; /*!< Specifies whether the ADC data alignment9 s& |4 l8 q$ t: j5 @2 x
- is left or right. This parameter can be
7 H* B% S U; [* Y - a value of @ref ADC_data_align */
}# N* ]+ k ?8 ]; _3 |" A0 U - uint8_t ADC_NbrOfConversion; /*!< Specifies the number of ADC conversions8 B) T( x- L9 Z- o, K S% k7 @
- that will be done using the sequencer for
* v5 j+ M* ~+ R - regular channel group.
# h- Q9 @2 x- |' ~ - This parameter must range from 1 to 16. */
( T+ t2 ^# ^, q/ u9 P5 ^9 S - }ADC_InitTypeDef;
7 g+ S2 E4 W- Q- k- K4 G - 1 {" v# f) N! H) v% S2 p9 J
- /** ' b' \6 w0 @2 `& J, g7 J
- * @brief ADC Common Init structure definition
. B5 g& \& a) [; a ~ - */ / W7 `/ n) h1 F$ w3 [6 y5 W
- typedef struct
( W* V( G) F% ^9 {9 t - {6 Q+ L5 F& ?7 p
- uint32_t ADC_Mode; /*!< Configures the ADC to operate in ; K4 L v" N! Y5 o# X1 f/ x9 B! [
- independent or multi mode.
! X x- _6 t. q m* p( i" i& K: r% b - This parameter can be a value of @ref ADC_Common_mode */
1 J+ y: S' E: F( ^; _7 Z - uint32_t ADC_Prescaler; /*!< Select the frequency of the clock
+ h+ u* ^$ ^: i) R; ]) ~, p - to the ADC. The clock is common for all the ADCs.- r3 C2 E9 \: W0 K7 H% c
- This parameter can be a value of @ref ADC_Prescaler */' n" p2 i" \4 Y$ j5 T! }) ]. B7 h c
- uint32_t ADC_DMAAccessMode; /*!< Configures the Direct memory access , z' ^( {( ?; u
- mode for multi ADC mode.
; U/ {; T1 @( Q% b. A( ` - This parameter can be a value of + | L5 S8 g. F" R
- @ref ADC_Direct_memory_access_mode_for_multi_mode */0 q/ l2 h0 o0 ?7 ?# b2 Y% M
- uint32_t ADC_TwoSamplingDelay; /*!< Configures the Delay between 2 sampling phases.
2 l& X* t4 }+ ]+ L' [4 P9 l! ] - This parameter can be a value of 6 K5 \7 {2 @5 [5 X6 |
- @ref ADC_delay_between_2_sampling_phases */2 z4 T) f; A! {, e6 V9 v
- 8 a2 h( c* W: x1 {* ?% h
- }ADC_CommonInitTypeDef; s2 t! d& y0 d) i1 s1 ^, m3 ^$ c
- h1 x1 ]6 O4 b+ C+ c% [
@6 h6 o% M" v0 M4 @- /* Exported constants --------------------------------------------------------*/
& d' x, C, Y: g2 j0 n- O$ p' p
3 N" L: ~4 \' @) u# o4 U- /** @defgroup ADC_Exported_Constants
& m; C o$ _) {0 X - * @{
+ S$ p Z9 j) Z - */ D' r! I% q, B2 U; J2 C
- #define IS_ADC_ALL_PERIPH(PERIPH) (((PERIPH) == ADC1) || \
) a8 Y: ^6 y) r. X - ((PERIPH) == ADC2) || \2 A8 y5 M2 g5 I# P
- ((PERIPH) == ADC3)) 4 [0 q$ }1 z5 z. k
+ O7 t' z; {6 N' p9 k4 w% @4 ~- /** @defgroup ADC_Common_mode
% ]( d$ O7 X* Z8 ` - * @{0 x9 J1 ]5 @/ ]* i% R& O% G
( O: ~$ L& h* C, K# C* l - #define ADC_Mode_Independent ((uint32_t)0x00000000)
% v* C! Z& S# o% `! n* z - #define ADC_DualMode_RegSimult_InjecSimult ((uint32_t)0x00000001)+ w |8 G4 a/ l |
- #define ADC_DualMode_RegSimult_AlterTrig ((uint32_t)0x00000002)5 F+ k9 {$ l P# D0 F
- #define ADC_DualMode_InjecSimult ((uint32_t)0x00000005) u! Y7 [6 J& c* j
- #define ADC_DualMode_RegSimult ((uint32_t)0x00000006)7 W* G, e4 ]0 Z9 t; _ M
- #define ADC_DualMode_Interl ((uint32_t)0x00000007): G. D5 v/ h- m3 e
- #define ADC_DualMode_AlterTrig ((uint32_t)0x00000009)
$ x) |8 y* H) V6 a) u8 v0 _ - #define ADC_TripleMode_RegSimult_InjecSimult ((uint32_t)0x00000011)
: k5 `; h4 G6 {# i! V8 w2 u5 U% \% O - #define ADC_TripleMode_RegSimult_AlterTrig ((uint32_t)0x00000012)
/ o+ o5 }) \: L. c - #define ADC_TripleMode_InjecSimult ((uint32_t)0x00000015)& K4 r) q# Y/ Z ]" e3 Z7 b
- #define ADC_TripleMode_RegSimult ((uint32_t)0x00000016)
+ [9 u* H' a6 j3 A+ T) b - #define ADC_TripleMode_Interl ((uint32_t)0x00000017)- ` M3 v' ~4 R% B; `1 M! G- B
- #define ADC_TripleMode_AlterTrig ((uint32_t)0x00000019)+ C" F. \! s9 B- f. j0 M7 X
- #define IS_ADC_MODE(MODE) (((MODE) == ADC_Mode_Independent) || \; S/ p e5 h' h2 K
- ((MODE) == ADC_DualMode_RegSimult_InjecSimult) || \- f4 y8 K' o9 N K% S" j3 h
- ((MODE) == ADC_DualMode_RegSimult_AlterTrig) || \
6 _0 l# O0 F& R - ((MODE) == ADC_DualMode_InjecSimult) || \
+ ^7 {) D# j. e' D - ((MODE) == ADC_DualMode_RegSimult) || \
7 [0 b1 |, O; ]& Y n - ((MODE) == ADC_DualMode_Interl) || \
8 ]$ J" t4 R1 v6 s3 F8 c - ((MODE) == ADC_DualMode_AlterTrig) || \" A d) k. L" O+ K
- ((MODE) == ADC_TripleMode_RegSimult_InjecSimult) || \+ d0 U# o$ ^. o6 ]1 c# d
- ((MODE) == ADC_TripleMode_RegSimult_AlterTrig) || \
. R- C3 D' U$ b$ O$ D - ((MODE) == ADC_TripleMode_InjecSimult) || \2 | `. z% W$ k! `7 J: j, N
- ((MODE) == ADC_TripleMode_RegSimult) || \
+ N1 J9 ?# B: {* z% Y9 o4 W - ((MODE) == ADC_TripleMode_Interl) || \, u0 T. Q0 f* I# e4 j
- ((MODE) == ADC_TripleMode_AlterTrig))
2 ?: ^7 \) z$ S" y4 x; Q" o - /**
) z$ g# D' @$ {9 p - * @}
: U. H6 D" M7 a - */ % t' ?; t* z! p2 |& U* V
" J1 z4 Y+ \4 q5 E7 w: q# Z' V
* w$ T9 a/ d' A( u/ S- /** @defgroup ADC_Prescaler
% v9 @3 d) I. C: b7 C2 P - * @{# s3 _, x V2 M
- */ 2 a/ f7 P" [. U0 B4 q
- #define ADC_Prescaler_Div2 ((uint32_t)0x00000000). B5 r7 l, s5 A5 q" E
- #define ADC_Prescaler_Div4 ((uint32_t)0x00010000)
# p0 I+ d( Y1 I* ]) r* i: m - #define ADC_Prescaler_Div6 ((uint32_t)0x00020000)) Q/ V7 x% o8 n) J: A8 ^% e, y
- #define ADC_Prescaler_Div8 ((uint32_t)0x00030000)
. [8 U# t, W: a3 U - #define IS_ADC_PRESCALER(PRESCALER) (((PRESCALER) == ADC_Prescaler_Div2) || \
% |( K" h& v5 F9 x7 \ - ((PRESCALER) == ADC_Prescaler_Div4) || \3 z6 v" ?$ K. h5 y$ x
- ((PRESCALER) == ADC_Prescaler_Div6) || \) O! ?1 T5 H5 K4 u7 g- E
- ((PRESCALER) == ADC_Prescaler_Div8))% i& i" F& C. J( h+ C; b. K
8 A' Q# A- K& B; }. L - * @}' Y7 x* i+ V8 r7 Q q9 R4 ?1 M
- */ ! B- Z/ C% @ B1 v6 }; D9 H
- % d4 m+ z% U& p! i5 i1 Z v2 P
- 0 r& C# B4 V; R c) _" D3 R" Z+ m
- /** @defgroup ADC_Direct_memory_access_mode_for_multi_mode
+ {: j3 f/ \ i - * @{
$ B" f/ g5 V% B& [, ~8 o' q# ~8 ^ - */ % O$ j+ a5 d- _( R3 b
- #define ADC_DMAAccessMode_Disabled ((uint32_t)0x00000000) /* DMA mode disabled */! m7 l$ O" b$ f! D5 F
- #define ADC_DMAAccessMode_1 ((uint32_t)0x00004000) /* DMA mode 1 enabled (2 / 3 half-words one by one - 1 then 2 then 3)*/
" j M8 ^2 T% e, o - #define ADC_DMAAccessMode_2 ((uint32_t)0x00008000) /* DMA mode 2 enabled (2 / 3 half-words by pairs - 2&1 then 1&3 then 3&2)*/
- V6 w0 ^4 f" t; x* Z - #define ADC_DMAAccessMode_3 ((uint32_t)0x0000C000) /* DMA mode 3 enabled (2 / 3 bytes by pairs - 2&1 then 1&3 then 3&2) */8 o h6 `# [+ D. B5 _( x, k. c# r/ p2 P
- #define IS_ADC_DMA_ACCESS_MODE(MODE) (((MODE) == ADC_DMAAccessMode_Disabled) || \+ R6 ~- g/ w0 a5 }0 h/ J1 ~- o
- ((MODE) == ADC_DMAAccessMode_1) || \
/ r3 N3 {3 E# T9 u/ q& ~5 L - ((MODE) == ADC_DMAAccessMode_2) || \1 ^# k5 I& K1 U/ b
- ((MODE) == ADC_DMAAccessMode_3))- p) j) O7 [( {1 O& }. _8 F
0 @& z: v3 U$ J, @" T4 L, b- /**
3 S9 X3 M, Z, U2 ?0 f9 v2 I& A - * @}
+ S+ I F! f/ r4 e/ n2 H& k& J - */
' u0 ~$ P. G( B) V9 j - + |; }" G. p2 }# z
- 0 h; M" K6 c: H+ C
- /** @defgroup ADC_delay_between_2_sampling_phases
' f; v0 i3 T- }6 l - * @{' w7 |6 e7 W) j) X/ b
- */ ; Z! \, E- d& o: a5 l; g7 r" z# l
- #define ADC_TwoSamplingDelay_5Cycles ((uint32_t)0x00000000)
^+ S2 J. ?0 S - #define ADC_TwoSamplingDelay_6Cycles ((uint32_t)0x00000100)
& U7 G0 t v& s. ]+ N2 t( d7 d+ n - #define ADC_TwoSamplingDelay_7Cycles ((uint32_t)0x00000200)
# A$ Y% S% ~' r+ m' O - #define ADC_TwoSamplingDelay_8Cycles ((uint32_t)0x00000300)! R. Z1 C* R6 q) D0 _3 a
- #define ADC_TwoSamplingDelay_9Cycles ((uint32_t)0x00000400)
, I; w: \4 L# J7 A: ` - #define ADC_TwoSamplingDelay_10Cycles ((uint32_t)0x00000500)
% a# Z! W# p7 n1 `1 A& b- y - #define ADC_TwoSamplingDelay_11Cycles ((uint32_t)0x00000600)) l3 o; ^+ m, R9 z# @) k
- #define ADC_TwoSamplingDelay_12Cycles ((uint32_t)0x00000700)
% R0 S8 ?( n- {6 b" V3 W+ x- @ - #define ADC_TwoSamplingDelay_13Cycles ((uint32_t)0x00000800)
7 }) C: C7 o) f& D Y9 |; q - #define ADC_TwoSamplingDelay_14Cycles ((uint32_t)0x00000900)9 S6 M( e& v( `1 Y u
- #define ADC_TwoSamplingDelay_15Cycles ((uint32_t)0x00000A00). E- @' t! s7 M2 b9 ~5 D4 ~2 Z
- #define ADC_TwoSamplingDelay_16Cycles ((uint32_t)0x00000B00)9 o4 U ^4 [0 y; e
- #define ADC_TwoSamplingDelay_17Cycles ((uint32_t)0x00000C00): Q( i4 p% V; a# O7 G0 y0 e
- #define ADC_TwoSamplingDelay_18Cycles ((uint32_t)0x00000D00)- v' w' e" W& Z& p' [8 y
- #define ADC_TwoSamplingDelay_19Cycles ((uint32_t)0x00000E00)4 m& L; e+ Z L/ Q3 A1 E* q
- #define ADC_TwoSamplingDelay_20Cycles ((uint32_t)0x00000F00)
9 V6 z: u+ [9 E: Y5 C" Y! ^* ? - #define IS_ADC_SAMPLING_DELAY(DELAY) (((DELAY) == ADC_TwoSamplingDelay_5Cycles) || \
0 v. l( H0 c$ Y. O0 g - ((DELAY) == ADC_TwoSamplingDelay_6Cycles) || \
0 o" ~3 W/ T h( b R9 `5 d2 R - ((DELAY) == ADC_TwoSamplingDelay_7Cycles) || \
; F% t, y3 G" [* _9 u. a - ((DELAY) == ADC_TwoSamplingDelay_8Cycles) || \
6 ]+ Z! @( O2 q S" u - ((DELAY) == ADC_TwoSamplingDelay_9Cycles) || \
% H: v- y6 e1 ~ - ((DELAY) == ADC_TwoSamplingDelay_10Cycles) || \
3 ]5 l8 v+ ^, ?. e$ o1 J. g - ((DELAY) == ADC_TwoSamplingDelay_11Cycles) || \' ^. P" W( Y0 `
- ((DELAY) == ADC_TwoSamplingDelay_12Cycles) || \' L$ T/ R% N6 a5 ~
- ((DELAY) == ADC_TwoSamplingDelay_13Cycles) || \" {% s, Y: h) I8 X
- ((DELAY) == ADC_TwoSamplingDelay_14Cycles) || \+ m5 v6 U& J i1 N4 u
- ((DELAY) == ADC_TwoSamplingDelay_15Cycles) || \' M# I+ `/ ?: o7 n. h) `8 v
- ((DELAY) == ADC_TwoSamplingDelay_16Cycles) || \5 Q4 W' p1 s+ r1 r: Y8 g
- ((DELAY) == ADC_TwoSamplingDelay_17Cycles) || \1 }- S4 D+ M1 u; A% k5 P; A
- ((DELAY) == ADC_TwoSamplingDelay_18Cycles) || \
$ L8 R6 Q) k7 M L9 t& K- N - ((DELAY) == ADC_TwoSamplingDelay_19Cycles) || \
* N: L" @. n) H; S3 `# y' r$ t( A; \ - ((DELAY) == ADC_TwoSamplingDelay_20Cycles))
) M( l( q$ v0 s) }
, f" S d" U$ n1 b- /** Y4 {4 R: Z' s7 Z" r" s6 u0 j1 I
5 S1 z) b9 n' d, R0 w. w1 N! @4 {4 ? - */
8 z9 r, r8 e/ k. h5 S
9 i$ P* _2 \3 P% ~
/ P- y8 x# Z+ Z! ^- /** @defgroup ADC_resolution 6 ~2 Y4 [0 q; f7 B4 {& h
! z+ u" ?0 Q* ~5 g6 p7 S6 D - */ + O! `6 t4 h) e. d4 g
- #define ADC_Resolution_12b ((uint32_t)0x00000000)+ F9 ]% D/ o- O$ T! x/ Z* Z
- #define ADC_Resolution_10b ((uint32_t)0x01000000)! H3 n% ^+ S- |) N2 g6 v) d
- #define ADC_Resolution_8b ((uint32_t)0x02000000)
9 b" \. P* w6 ^: h, r# n - #define ADC_Resolution_6b ((uint32_t)0x03000000)7 J8 _" l/ T) T% J1 k( D% D
- #define IS_ADC_RESOLUTION(RESOLUTION) (((RESOLUTION) == ADC_Resolution_12b) || \
0 K, R$ _6 ?$ J, P4 ~; K - ((RESOLUTION) == ADC_Resolution_10b) || \+ \ G( V3 u" v( n
- ((RESOLUTION) == ADC_Resolution_8b) || \
3 [' [4 J- q1 {3 _7 \ S5 C0 s6 c4 J2 D - ((RESOLUTION) == ADC_Resolution_6b))2 v) ^# ^9 a+ L5 f( Z1 D
- d3 X0 O ? [" q4 M' g" `- /**1 k- b& B* Q% P( W' t
- * @}5 I! H; x% A) k
' s+ `+ I) i" _/ p, N* |
' N( g1 ^' T8 g) o- 7 ?0 _. ~" n7 A5 p2 v
- /** @defgroup ADC_external_trigger_edge_for_regular_channels_conversion / ]+ j; u8 Q; \. i# i5 M
. M0 }; b4 D& _+ n V" E" m0 O( w - */
+ V& ~6 |! `$ x! f( y - #define ADC_ExternalTrigConvEdge_None ((uint32_t)0x00000000): V9 X/ F8 z9 ~' h& Z/ | H
- #define ADC_ExternalTrigConvEdge_Rising ((uint32_t)0x10000000)) n+ ~3 b, T3 u% q* [
- #define ADC_ExternalTrigConvEdge_Falling ((uint32_t)0x20000000) s# x( @ }" q% \4 K3 K% T/ ?
- #define ADC_ExternalTrigConvEdge_RisingFalling ((uint32_t)0x30000000)- O1 w; w2 Z: X- X* G
- #define IS_ADC_EXT_TRIG_EDGE(EDGE) (((EDGE) == ADC_ExternalTrigConvEdge_None) || \
- U! @/ O& W R9 Y - ((EDGE) == ADC_ExternalTrigConvEdge_Rising) || \, X. R7 [; p5 n9 R2 A
- ((EDGE) == ADC_ExternalTrigConvEdge_Falling) || \
3 r D1 r. N4 r/ A. P8 M1 E% I+ A/ m - ((EDGE) == ADC_ExternalTrigConvEdge_RisingFalling))$ j& \2 q8 \1 y6 V# }/ V" D& ~
' e' p- v" X5 k7 ]& u- g - * @}$ ?% x. L4 a' v- r( ^# w
. e0 |5 H* N8 s! d2 {$ N I - - H8 b" Y; j! y2 D$ I
: K) S; y# ?8 \, h5 a- /** @defgroup ADC_extrenal_trigger_sources_for_regular_channels_conversion 1 P' R) X# C2 l
- * @{( F! [6 X0 o9 K, P, g' r
- */ 7 f, S' o& P: K" V7 i# ~9 Z, v
- #define ADC_ExternalTrigConv_T1_CC1 ((uint32_t)0x00000000)
, P/ t* s/ N( u# y. J" ~. @; k9 O! A - #define ADC_ExternalTrigConv_T1_CC2 ((uint32_t)0x01000000)+ E4 q" }& d4 ]- ~+ ?1 Z- |' b, B
- #define ADC_ExternalTrigConv_T1_CC3 ((uint32_t)0x02000000)
8 }! [7 @( O& S& l - #define ADC_ExternalTrigConv_T2_CC2 ((uint32_t)0x03000000): Q+ R& _/ R/ [4 h, `
- #define ADC_ExternalTrigConv_T2_CC3 ((uint32_t)0x04000000)+ e2 x$ \! Q/ y( C. f
- #define ADC_ExternalTrigConv_T2_CC4 ((uint32_t)0x05000000)
/ i* h5 h7 k; Q" |# L - #define ADC_ExternalTrigConv_T2_TRGO ((uint32_t)0x06000000)
! k7 Q9 ]- [: U9 {& e7 W' H - #define ADC_ExternalTrigConv_T3_CC1 ((uint32_t)0x07000000)& i$ D1 _2 e# h! z6 _& j3 H
- #define ADC_ExternalTrigConv_T3_TRGO ((uint32_t)0x08000000)
( D- z, q3 l, L. r1 l1 f - #define ADC_ExternalTrigConv_T4_CC4 ((uint32_t)0x09000000)/ w: A5 F) [ c- |( E! M
- #define ADC_ExternalTrigConv_T5_CC1 ((uint32_t)0x0A000000)
: x7 C+ |7 V* V% } - #define ADC_ExternalTrigConv_T5_CC2 ((uint32_t)0x0B000000)# B1 @7 u0 X, p7 N0 b& r
- #define ADC_ExternalTrigConv_T5_CC3 ((uint32_t)0x0C000000)# Y o6 Z& ^! @& z: J* L. y
- #define ADC_ExternalTrigConv_T8_CC1 ((uint32_t)0x0D000000)
# M) o0 G: z4 ^, I- X' L. D - #define ADC_ExternalTrigConv_T8_TRGO ((uint32_t)0x0E000000)
a9 i( s5 [( [9 M" J3 T - #define ADC_ExternalTrigConv_Ext_IT11 ((uint32_t)0x0F000000), t T; Q, f7 D3 j$ u
- #define IS_ADC_EXT_TRIG(REGTRIG) (((REGTRIG) == ADC_ExternalTrigConv_T1_CC1) || \! Q1 _. J, K8 Y+ c' h. h
- ((REGTRIG) == ADC_ExternalTrigConv_T1_CC2) || \
6 N+ k2 w6 U, D5 j9 W/ f - ((REGTRIG) == ADC_ExternalTrigConv_T1_CC3) || \, Y) G* {6 c+ b9 O4 o
- ((REGTRIG) == ADC_ExternalTrigConv_T2_CC2) || \; h0 ~& J; |0 |, b, _+ G
- ((REGTRIG) == ADC_ExternalTrigConv_T2_CC3) || \0 _; U$ I5 | R
- ((REGTRIG) == ADC_ExternalTrigConv_T2_CC4) || \* B& b3 Y y9 ^. j/ m4 y
- ((REGTRIG) == ADC_ExternalTrigConv_T2_TRGO) || \
1 ^. `& }1 T! W2 L0 A( C6 d - ((REGTRIG) == ADC_ExternalTrigConv_T3_CC1) || \
% z9 o* \/ e- s. }, k) ` - ((REGTRIG) == ADC_ExternalTrigConv_T3_TRGO) || \' B& S: U2 @+ p) e5 P
- ((REGTRIG) == ADC_ExternalTrigConv_T4_CC4) || \$ I4 b2 N& w9 d, L4 z, L" ]! K! |
- ((REGTRIG) == ADC_ExternalTrigConv_T5_CC1) || \
: U: _6 t! R C+ ` - ((REGTRIG) == ADC_ExternalTrigConv_T5_CC2) || \
5 c# o9 V2 B$ f! O9 j7 S - ((REGTRIG) == ADC_ExternalTrigConv_T5_CC3) || \
: w* e$ g# M/ `0 m - ((REGTRIG) == ADC_ExternalTrigConv_T8_CC1) || \
9 o U- I; `7 ?$ H3 [, S' V5 E - ((REGTRIG) == ADC_ExternalTrigConv_T8_TRGO) || \
+ E n$ [' Y! p( f& p4 D1 W" { - ((REGTRIG) == ADC_ExternalTrigConv_Ext_IT11))
/ o3 `8 Y# |; P9 Y; A, L - /**" @+ b7 a5 z# o6 d. `# }: F: @
- * @}- a+ T3 F% l m6 m
7 _6 I" k5 t) z& T0 ^' t - * z: _7 p- _) B4 H) I
- % a c1 Y7 p' @' R
- /** @defgroup ADC_data_align 3 i9 |: J6 F) {# |. ^) k
( ?( q0 d( |! l& s9 k4 { - */
# M/ @! s2 t5 q4 v6 w1 a - #define ADC_DataAlign_Right ((uint32_t)0x00000000)
: M- \5 e' A7 t7 z, T% q - #define ADC_DataAlign_Left ((uint32_t)0x00000800)
& L( v* Y% n* F4 F - #define IS_ADC_DATA_ALIGN(ALIGN) (((ALIGN) == ADC_DataAlign_Right) || \
" e; w6 ]- A* {2 b - ((ALIGN) == ADC_DataAlign_Left))
- ?0 s4 W8 p Z( U% L+ E, _ - /**
) ?/ B! L) ?+ V; b' R9 @ - * @}8 l! u) I, @, x! K m5 P
0 g( i1 f+ F: D - : E7 k! T8 f" s. N' C
' O9 g% i6 ]7 i; x( U3 q$ c' n- /** @defgroup ADC_channels
" A5 {' o7 L% T8 X% E - * @{
" m' e" I# `. K* q - */ , y4 I; Q: k4 p& S4 C( V% U
- #define ADC_Channel_0 ((uint8_t)0x00)6 q5 x2 L6 g# v
- #define ADC_Channel_1 ((uint8_t)0x01)% k: L% ?6 N; U; q/ V
- #define ADC_Channel_2 ((uint8_t)0x02)
0 v0 ~' ?" r2 d C; a: x9 n - #define ADC_Channel_3 ((uint8_t)0x03)) o( Y5 p c6 s5 K2 N& F5 I* @
- #define ADC_Channel_4 ((uint8_t)0x04)
* U, }& a% H4 C! r - #define ADC_Channel_5 ((uint8_t)0x05)) V! z6 a. |2 l6 Z7 j% y
- #define ADC_Channel_6 ((uint8_t)0x06) w7 B+ C7 A5 f; z
- #define ADC_Channel_7 ((uint8_t)0x07)- x' v1 i* m3 K) ]/ [' [+ p! w- Q
- #define ADC_Channel_8 ((uint8_t)0x08)
: x" |7 s2 W" o1 H - #define ADC_Channel_9 ((uint8_t)0x09)
5 s! r9 a) q0 m" @; f4 y4 p+ H& W - #define ADC_Channel_10 ((uint8_t)0x0A)7 R; W# i# K/ x+ r5 {
- #define ADC_Channel_11 ((uint8_t)0x0B)* @4 c- I8 D3 k+ b) s1 ?
- #define ADC_Channel_12 ((uint8_t)0x0C)
! ]3 @0 o3 h$ w/ ?$ ?* v$ W - #define ADC_Channel_13 ((uint8_t)0x0D)5 |4 A; o. W1 p; J Q2 I
- #define ADC_Channel_14 ((uint8_t)0x0E)
3 d: M- E+ e* b9 |/ O) p4 y/ X8 @& { - #define ADC_Channel_15 ((uint8_t)0x0F)0 K# i& c+ J& B; i* i. F
- #define ADC_Channel_16 ((uint8_t)0x10), u3 M- T, o; c. a Q
- #define ADC_Channel_17 ((uint8_t)0x11)
% t2 z9 ~8 y6 y, T& `3 s - #define ADC_Channel_18 ((uint8_t)0x12)
6 I: L) O3 p9 U# Y8 | - 3 R+ o B" d/ \" A
- #if defined (STM32F40_41xxx) || defined(STM32F412xG) || defined(STM32F413_423xx)
9 V) `% Z% H: o' E/ M8 Y, G - #define ADC_Channel_TempSensor ((uint8_t)ADC_Channel_16)! f3 I2 b" S0 p- M6 a+ i
- #endif /* STM32F40_41xxx || STM32F412xG || STM32F413_423xx */
8 S/ C' Z9 Y7 \, k
: T. q9 a0 F, U. Y- #if defined (STM32F427_437xx) || defined (STM32F429_439xx) || defined (STM32F401xx) || defined (STM32F410xx) || defined (STM32F411xE)
5 v0 U2 S$ _0 N5 A - #define ADC_Channel_TempSensor ((uint8_t)ADC_Channel_18)2 B3 Y7 `% w' t
- #endif /* STM32F427_437xx || STM32F429_439xx || STM32F401xx || STM32F410xx || STM32F411xE */3 T+ j) N% [; L
- $ l' w" u' |2 D* ?5 J% F. [; i( _; F& f
- #define ADC_Channel_Vrefint ((uint8_t)ADC_Channel_17)) F$ h( z$ `2 ^6 I7 I) T4 y$ Y; X
- #define ADC_Channel_Vbat ((uint8_t)ADC_Channel_18)4 ~+ o* J6 B' z3 C+ s: k' B
Y0 ]9 }3 T: g% R; O5 `- #define IS_ADC_CHANNEL(CHANNEL) (((CHANNEL) == ADC_Channel_0) || \' C, H# f6 V3 d( S$ l
- ((CHANNEL) == ADC_Channel_1) || \/ C; C' f3 K$ ?
- ((CHANNEL) == ADC_Channel_2) || \, D. w, p2 M! d N" B* x) |: E( e
- ((CHANNEL) == ADC_Channel_3) || \, i# d. _; u1 F L+ {7 V' e5 J
- ((CHANNEL) == ADC_Channel_4) || \
, U! I i1 r6 _% Z2 t9 K8 s5 Y7 W7 X - ((CHANNEL) == ADC_Channel_5) || \
; l5 M6 Q( W6 x9 P& V6 O - ((CHANNEL) == ADC_Channel_6) || \$ M0 x( s; x1 A* f) k. V
- ((CHANNEL) == ADC_Channel_7) || \
- W9 f& R, H% E. L. i4 t - ((CHANNEL) == ADC_Channel_8) || \- \; i$ P# v) m3 u& ^# J. F" m4 W
- ((CHANNEL) == ADC_Channel_9) || \; d$ o( E1 T4 [" B0 N' o
- ((CHANNEL) == ADC_Channel_10) || \
/ {' s; { q1 d5 T - ((CHANNEL) == ADC_Channel_11) || \) J- L7 r9 G+ j, b+ d! C3 y
- ((CHANNEL) == ADC_Channel_12) || \/ |( R: `. `. G
- ((CHANNEL) == ADC_Channel_13) || \# T# ^! d( R& U. ^4 m
- ((CHANNEL) == ADC_Channel_14) || \! O! _2 X4 O9 C0 N. y4 \
- ((CHANNEL) == ADC_Channel_15) || \
" a5 |4 f/ `5 U: L& M: R - ((CHANNEL) == ADC_Channel_16) || \
5 q J$ T# S3 ]* P - ((CHANNEL) == ADC_Channel_17) || \/ {5 i# O7 g- w% y2 Y
- ((CHANNEL) == ADC_Channel_18))
9 T4 r5 U9 n9 m& |( Y1 ^0 n - /**
5 C# ^0 I+ a" J2 S+ w6 |3 P/ r - * @}
& k/ E; A* t6 Q) T' ]2 b; f) ]% {$ R( z - */
3 Q* Y! W; P$ I6 N+ M$ o7 e
p1 c, \- l i0 _+ I8 K- 5 t$ p' |, A! m' {' T. b. W: S
- /** @defgroup ADC_sampling_times
! x2 I4 f: f: A H- F) J' C - * @{6 H( ^7 Z# d. I$ x5 e
0 z, q. D5 g! n - #define ADC_SampleTime_3Cycles ((uint8_t)0x00)
$ v8 Q T; F# v, b$ b( u - #define ADC_SampleTime_15Cycles ((uint8_t)0x01)
3 p# X! ~6 }) ?, r - #define ADC_SampleTime_28Cycles ((uint8_t)0x02)
) }7 M) L. q8 \+ i3 v: N. u8 w! [ - #define ADC_SampleTime_56Cycles ((uint8_t)0x03)) | ?7 i v5 J2 D( Y/ k
- #define ADC_SampleTime_84Cycles ((uint8_t)0x04)7 v) m3 s. z9 o) c" W
- #define ADC_SampleTime_112Cycles ((uint8_t)0x05)
% ~* R0 M8 W( f3 E" ~0 j4 s - #define ADC_SampleTime_144Cycles ((uint8_t)0x06)& y3 K6 w8 R4 E/ _. C
- #define ADC_SampleTime_480Cycles ((uint8_t)0x07)
9 s" {0 {* m. N9 C( j% f, e0 w - #define IS_ADC_SAMPLE_TIME(TIME) (((TIME) == ADC_SampleTime_3Cycles) || \
8 n T" A+ I1 O9 W8 F5 S3 d - ((TIME) == ADC_SampleTime_15Cycles) || \
2 U" T5 u$ X4 {6 r% t - ((TIME) == ADC_SampleTime_28Cycles) || \
# X' B/ r: o# d" M - ((TIME) == ADC_SampleTime_56Cycles) || \& b1 r- ~# }. f
- ((TIME) == ADC_SampleTime_84Cycles) || \
- A, u% {9 o9 g! Y$ a - ((TIME) == ADC_SampleTime_112Cycles) || \ ~0 z. v2 d9 S$ V6 u. k
- ((TIME) == ADC_SampleTime_144Cycles) || \/ V1 A% e7 ]' b3 c) y, [. V
- ((TIME) == ADC_SampleTime_480Cycles))
2 L( {2 J: _& ]7 g- y& l - /**6 W! Y1 D4 p' s% b _" Y$ p: J: x
6 f, P& s7 ?/ a: P9 Y - */
: R4 D! L$ Z5 _# U3 e
! [$ b3 F, r: k- |1 `5 }- 8 l! T* V/ [5 L% U$ w. |
- /** @defgroup ADC_external_trigger_edge_for_injected_channels_conversion
; E- E1 [0 u7 s5 U - * @{/ x$ q' }0 o: w D3 ?! f2 ^
- */ & P8 H, a4 j& \$ ?
- #define ADC_ExternalTrigInjecConvEdge_None ((uint32_t)0x00000000)' P7 k' L$ O5 p: C- |9 p/ ?
- #define ADC_ExternalTrigInjecConvEdge_Rising ((uint32_t)0x00100000)- i% u: F$ P7 w0 H" d0 g
- #define ADC_ExternalTrigInjecConvEdge_Falling ((uint32_t)0x00200000)
* D4 D8 c* C! d/ L, Q/ I& X - #define ADC_ExternalTrigInjecConvEdge_RisingFalling ((uint32_t)0x00300000)
$ e8 p4 j# l) d1 h$ C9 q" D - #define IS_ADC_EXT_INJEC_TRIG_EDGE(EDGE) (((EDGE) == ADC_ExternalTrigInjecConvEdge_None) || \: ~4 O: c3 C1 L2 g! }0 n" {
- ((EDGE) == ADC_ExternalTrigInjecConvEdge_Rising) || \8 ~. L% b+ K- c) Y# Z
- ((EDGE) == ADC_ExternalTrigInjecConvEdge_Falling) || \
" }* Y: V% |6 K$ p - ((EDGE) == ADC_ExternalTrigInjecConvEdge_RisingFalling))/ B" P- [% J' x4 |: E5 f
- 8 i5 l3 Y# K" n+ T
- /**4 S0 R5 \0 B* @
- * @}6 e7 w- O: j3 t
2 u' x" A/ N1 n1 `& ] - ) W; D8 G" n- @4 z& v3 G7 h, z
- 3 T, g/ _. T2 d% t; W
- /** @defgroup ADC_extrenal_trigger_sources_for_injected_channels_conversion , K4 {2 x0 n$ F) F2 {; t; L V" L
- * @{+ _& c$ C5 H' C9 _ F
- */ 1 l3 ]5 [. e4 s/ q2 ? x
- #define ADC_ExternalTrigInjecConv_T1_CC4 ((uint32_t)0x00000000)
' \+ E; ]) m2 \# }1 }, X - #define ADC_ExternalTrigInjecConv_T1_TRGO ((uint32_t)0x00010000)9 I% k7 b1 k6 R! i" k
- #define ADC_ExternalTrigInjecConv_T2_CC1 ((uint32_t)0x00020000)( i9 F! ?9 Q- T g8 y4 V
- #define ADC_ExternalTrigInjecConv_T2_TRGO ((uint32_t)0x00030000)
# x; D- K2 Q3 [; ~ - #define ADC_ExternalTrigInjecConv_T3_CC2 ((uint32_t)0x00040000)! V* h4 Y2 |5 b0 \
- #define ADC_ExternalTrigInjecConv_T3_CC4 ((uint32_t)0x00050000)+ p4 e# F z( P' q3 x5 v; S
- #define ADC_ExternalTrigInjecConv_T4_CC1 ((uint32_t)0x00060000)! y' o0 I( R9 A8 K2 B
- #define ADC_ExternalTrigInjecConv_T4_CC2 ((uint32_t)0x00070000)9 ?4 }3 `* `7 c
- #define ADC_ExternalTrigInjecConv_T4_CC3 ((uint32_t)0x00080000)
# X, M3 q \" e5 S; Z, m5 q* w! {& r - #define ADC_ExternalTrigInjecConv_T4_TRGO ((uint32_t)0x00090000)) u2 [4 n( J8 g, R
- #define ADC_ExternalTrigInjecConv_T5_CC4 ((uint32_t)0x000A0000)
9 l1 q7 J; }; G! A7 a7 h - #define ADC_ExternalTrigInjecConv_T5_TRGO ((uint32_t)0x000B0000)* Q% p' A, Q) F! Q2 R* T
- #define ADC_ExternalTrigInjecConv_T8_CC2 ((uint32_t)0x000C0000)9 G, w9 f" `3 V4 N y. T, b: X5 \( x
- #define ADC_ExternalTrigInjecConv_T8_CC3 ((uint32_t)0x000D0000)
& X$ |. R/ D5 `; m - #define ADC_ExternalTrigInjecConv_T8_CC4 ((uint32_t)0x000E0000)
' u, F& j1 ~+ y3 a) } - #define ADC_ExternalTrigInjecConv_Ext_IT15 ((uint32_t)0x000F0000)
8 ^4 O _2 z$ L% q1 h - #define IS_ADC_EXT_INJEC_TRIG(INJTRIG) (((INJTRIG) == ADC_ExternalTrigInjecConv_T1_CC4) || \
% \0 J6 b$ X7 v$ ^- }" L2 e& p - ((INJTRIG) == ADC_ExternalTrigInjecConv_T1_TRGO) || \% T, g/ L; U* J" u
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T2_CC1) || \
c! `. r* X: Z5 {/ m - ((INJTRIG) == ADC_ExternalTrigInjecConv_T2_TRGO) || \/ S* P, ?3 a# d- z
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T3_CC2) || \0 P H" t7 Z, b" f) Y3 F$ ?
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T3_CC4) || \/ ~8 w* T6 A/ \: {) ~. ?' p
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_CC1) || \% |: p5 J. k2 w- Q
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_CC2) || \3 S: ^9 L: x* ^+ `! z
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_CC3) || \
* P8 b9 z: y- `; r1 }" c - ((INJTRIG) == ADC_ExternalTrigInjecConv_T4_TRGO) || \7 v3 r7 W- |) o5 ]$ i) x7 d- W
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T5_CC4) || \; R' b( q: q7 F& y! y! j2 e7 D
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T5_TRGO) || \' [; E' y0 {9 B1 a9 |# v# k& g! ]
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T8_CC2) || \, k9 k1 [+ E1 c
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T8_CC3) || \+ d1 i# p% p9 A' y
- ((INJTRIG) == ADC_ExternalTrigInjecConv_T8_CC4) || \
* i8 z) G: ~3 s% x: T - ((INJTRIG) == ADC_ExternalTrigInjecConv_Ext_IT15))
, n7 h# ?2 \9 H. ]0 \ - /**' a7 p; T3 S/ s* v/ J% ?# l
" z& H% {9 [3 B7 v - */
: A0 F3 H3 N# g" }" r( h
- [( D9 u6 X | a6 G- 0 |9 N4 H7 e0 ~& s0 _" ` @
- /** @defgroup ADC_injected_channel_selection
9 X' p* ]$ ~7 [! E. q# ` - * @{
+ x4 A, V' W" {! E - */
- ~- {0 L3 `* J( [% y r - #define ADC_InjectedChannel_1 ((uint8_t)0x14)
6 }2 N" B- I, L- ^0 f7 f: V T - #define ADC_InjectedChannel_2 ((uint8_t)0x18)2 Q" e" K1 }% B# h
- #define ADC_InjectedChannel_3 ((uint8_t)0x1C)6 y$ j: ` I" `1 R u* ^" v& |) k
- #define ADC_InjectedChannel_4 ((uint8_t)0x20)
; c) ^* |/ s) ?* F, F - #define IS_ADC_INJECTED_CHANNEL(CHANNEL) (((CHANNEL) == ADC_InjectedChannel_1) || \4 n6 [" |3 W/ o& V [9 j8 a
- ((CHANNEL) == ADC_InjectedChannel_2) || \
8 i$ C1 g0 h I/ M - ((CHANNEL) == ADC_InjectedChannel_3) || \) M4 `9 z j) T0 F% B: X0 p) \
- ((CHANNEL) == ADC_InjectedChannel_4))
7 @+ m( }# j/ \! h) M" y. t c - /**( i+ S4 B9 A, `' p j. k% A6 I
' X" Q6 @1 o# K9 P - */
$ U! T$ M- J4 U - " D6 R1 g- ^4 L0 U' O% A
- ; c, j* X* |! ^. p! J, R
- /** @defgroup ADC_analog_watchdog_selection 6 Y- X* M: f( |$ d9 S1 |9 _3 x. V
2 I7 B. ?, \0 t. C0 J- c n - */ - X& U; P4 m4 L5 w. {
- #define ADC_AnalogWatchdog_SingleRegEnable ((uint32_t)0x00800200)
5 A; @- a- H. @+ I1 C' s/ Z - #define ADC_AnalogWatchdog_SingleInjecEnable ((uint32_t)0x00400200)" q) a7 j8 I8 f
- #define ADC_AnalogWatchdog_SingleRegOrInjecEnable ((uint32_t)0x00C00200)( q) l. O& P* k* S" Q7 s1 t
- #define ADC_AnalogWatchdog_AllRegEnable ((uint32_t)0x00800000)) a6 z- c) |& I# G; `
- #define ADC_AnalogWatchdog_AllInjecEnable ((uint32_t)0x00400000)* p9 K& P. P, ~; Q: c5 ?
- #define ADC_AnalogWatchdog_AllRegAllInjecEnable ((uint32_t)0x00C00000)3 M9 K1 U5 I1 I7 H! E# m7 j' x, p+ V
- #define ADC_AnalogWatchdog_None ((uint32_t)0x00000000)
* H3 e0 k: s# K; F/ a: [6 i5 w - #define IS_ADC_ANALOG_WATCHDOG(WATCHDOG) (((WATCHDOG) == ADC_AnalogWatchdog_SingleRegEnable) || \6 _" x Q# O8 x- _6 W9 h6 L. ~) p% o* n
- ((WATCHDOG) == ADC_AnalogWatchdog_SingleInjecEnable) || \ y2 e6 [2 F6 O% w# X- v7 o
- ((WATCHDOG) == ADC_AnalogWatchdog_SingleRegOrInjecEnable) || \7 }% ~% ?- G( s2 W
- ((WATCHDOG) == ADC_AnalogWatchdog_AllRegEnable) || \
. w, Y6 E, }9 @* R/ {) W7 D$ J - ((WATCHDOG) == ADC_AnalogWatchdog_AllInjecEnable) || \$ }$ z, f8 i |1 F6 v8 A# x9 ?$ y6 e
- ((WATCHDOG) == ADC_AnalogWatchdog_AllRegAllInjecEnable) || \2 D6 g$ s/ @5 N, O J W2 k
- ((WATCHDOG) == ADC_AnalogWatchdog_None))& v0 V" `3 N5 y5 c& s
0 a2 \; y4 `. r2 M- |; n - * @}( ^- w% W& R: U/ E. _& j6 j
9 ]& B" z1 @# h - 9 a- r+ c; @8 r g5 A
+ E+ |5 Z1 {" p4 F- N2 r- /** @defgroup ADC_interrupts_definition
; I+ ?3 g3 D! q# M; D; L - * @{8 \4 ?, |$ _, _% ]) W6 e) @4 K
- */ & j6 f" Y# {7 W# I6 g
- #define ADC_IT_EOC ((uint16_t)0x0205) 1 a8 e; G' K6 q3 ~! r
- #define ADC_IT_AWD ((uint16_t)0x0106) . A- \ c# D ]+ k, w5 s( k
- #define ADC_IT_JEOC ((uint16_t)0x0407)
; h. r- D( T" q - #define ADC_IT_OVR ((uint16_t)0x201A)
4 s0 O) @, L* L# v - #define IS_ADC_IT(IT) (((IT) == ADC_IT_EOC) || ((IT) == ADC_IT_AWD) || \9 Q$ p7 F& F+ P0 ` ~
- ((IT) == ADC_IT_JEOC)|| ((IT) == ADC_IT_OVR))
& ?9 F- C& {* o - /**
( m3 i2 _* m6 n# N1 T3 I; T0 e) ~/ W - * @}
' j* n) t+ ^2 P9 O* @ - */
! x& c- e4 [& Q5 n. {0 u
/ a ]6 X3 y; ~% t
8 j: z% i0 H$ y( r7 B2 u# g- /** @defgroup ADC_flags_definition
( y9 B1 ?4 a; l. s2 D0 _; Q" Q - * @{
2 Q1 Z @9 Q- B3 c1 o! P - */ 2 F8 h/ l' m: T! W9 V4 f/ a
- #define ADC_FLAG_AWD ((uint8_t)0x01)
1 m" c5 p; f! J1 N2 A - #define ADC_FLAG_EOC ((uint8_t)0x02)
) K. j! j# U- M2 A: [ - #define ADC_FLAG_JEOC ((uint8_t)0x04); Q; i7 F1 R6 `1 S9 n
- #define ADC_FLAG_JSTRT ((uint8_t)0x08)7 E2 n3 I5 Y. n# Q: M
- #define ADC_FLAG_STRT ((uint8_t)0x10)
" V4 c$ T# v- P4 `0 ~1 ~ - #define ADC_FLAG_OVR ((uint8_t)0x20)
& X* o" m# H# A. ], Y ` - , h3 Y# c# E4 M
- #define IS_ADC_CLEAR_FLAG(FLAG) ((((FLAG) & (uint8_t)0xC0) == 0x00) && ((FLAG) != 0x00))
; T- N8 r" j5 J8 J% Y! L9 \% i! f - #define IS_ADC_GET_FLAG(FLAG) (((FLAG) == ADC_FLAG_AWD) || \
1 U! N1 `- F2 C3 z& W$ f - ((FLAG) == ADC_FLAG_EOC) || \
, Z' b/ U& d. U- A - ((FLAG) == ADC_FLAG_JEOC) || \) G* {* U% Y6 @2 z$ H4 | T, c; H
- ((FLAG)== ADC_FLAG_JSTRT) || \
+ X+ h0 `0 {) n8 }5 z - ((FLAG) == ADC_FLAG_STRT) || \
5 l1 _+ |7 @5 I6 W$ S - ((FLAG)== ADC_FLAG_OVR))
. [) n! l, g* Y% f - /**- R1 k4 Q1 y8 G0 _% t5 U R* f
& t. Q" Q# _- b1 x/ E# A - */
: P. z2 H4 u! t' e% v9 o! \7 F
: `6 B+ Z( F' m( n. h1 r& Y- ! l# r* O8 Q2 l: Y5 P* t
- /** @defgroup ADC_thresholds
( l& W' m5 U6 @5 k% E - * @{9 a; r# S0 B5 n7 P- K2 r6 A
# S' y; f: [4 ]% h2 _ - #define IS_ADC_THRESHOLD(THRESHOLD) ((THRESHOLD) <= 0xFFF)
9 Q$ z% y: J! |2 X- N4 e; V - /**
o( S% E4 T, K/ W4 P! M& v - * @}
4 p% L. T c1 o6 ` - */
( E: w6 K8 V$ E; N( y' z! i
$ z' e; H) r% s9 k9 a7 E
3 l; l! E: t z! O/ g" T8 \4 h- /** @defgroup ADC_injected_offset
7 v( d0 l: {/ V - * @{) t: K% K; h% E6 P
- */ # F$ y; z( w0 K! x2 C7 X' P+ S
- #define IS_ADC_OFFSET(OFFSET) ((OFFSET) <= 0xFFF)3 x& ]! v2 a* b3 Q/ T- Z0 w h2 L
0 z7 N* _. H0 j% T - * @}
2 f4 S8 T v# |3 u% q; Z - */ + P: i. c3 g# z I
' A; Q3 ~0 {. x' Y5 ~. B- 1 `& g: |& A5 T+ p
- /** @defgroup ADC_injected_length * ~" H! a {/ _: d7 ]8 B
% t& P {+ l6 m1 o! Y - */ ; R& U- ~) [1 m& H- p5 u
- #define IS_ADC_INJECTED_LENGTH(LENGTH) (((LENGTH) >= 0x1) && ((LENGTH) <= 0x4))# R! V" G+ U4 e* W5 |
7 ~. ~. \: w" q! u! R Y - * @}5 L1 C5 v: D" a/ N5 `8 X, a2 K' b
; j5 \ m2 y- E4 l5 a - & _ x- D' i! q* Y! W6 t6 n
' P# ]1 u5 h2 f- \, }( o! y. ^. ?- /** @defgroup ADC_injected_rank
8 u! q% i+ z3 v) E. H - * @{
7 B1 C: ~0 n4 x/ L0 Y - */
" d. l4 A9 G( x" P0 s5 ] - #define IS_ADC_INJECTED_RANK(RANK) (((RANK) >= 0x1) && ((RANK) <= 0x4))' g2 S- N! T( Z" M$ ~
/ B8 G. K P5 A- k, F - * @}. C! c' m2 G2 }& o) F4 N( b
- */ ; ~/ |6 Q0 F8 f! N) h$ }" c
: p U) b2 {" q4 t3 Q9 s- * W0 L( t' D( l. s; n
- /** @defgroup ADC_regular_length
$ X: P( V3 D3 G) M' i# t8 N - * @{# ~' R6 V1 {- E J" s5 R+ P2 ?
- */ . `0 \& M7 J. V" Y4 C
- #define IS_ADC_REGULAR_LENGTH(LENGTH) (((LENGTH) >= 0x1) && ((LENGTH) <= 0x10))4 ~, @# B$ e5 S7 m2 G
. n0 q- V1 v1 V - * @} B+ _2 d2 X. Y9 ^: X3 K( v0 L3 \
( H( V% G, d7 H& o
- b! |, k3 S0 h# N" j" y- ) Q: Q1 e" k! l- O$ h- B1 R: H
- /** @defgroup ADC_regular_rank 7 g; H$ X# c9 l; Q$ K
8 p! A9 p& e. B, g - */ , c W4 c4 P. B4 o9 ?% J% E
- #define IS_ADC_REGULAR_RANK(RANK) (((RANK) >= 0x1) && ((RANK) <= 0x10))0 }& u0 K& N# i$ [; D& z7 ?, e' S
- /**9 [* z) V/ D$ m8 w8 P
- * @}1 l( p! K0 s; T: }/ E3 g2 W
4 C- F" |) w$ h, R, C - 6 Y/ `/ @/ g- e! d9 o, c
- ! }: g1 j. H, J! i* S. j
- /** @defgroup ADC_regular_discontinuous_mode_number , V$ }% Z& J) w( u" l* T! {
- * @{( W: q4 e' {& M' Q5 [/ } W
- */ % b5 M8 t" ~7 ]3 L6 \4 I5 l4 E$ e
- #define IS_ADC_REGULAR_DISC_NUMBER(NUMBER) (((NUMBER) >= 0x1) && ((NUMBER) <= 0x8)), i) ~3 ^2 C7 b2 `
$ z# ]: J2 B: i5 K# r - * @}
9 @! g4 i" C b - */
8 [( ]8 q& b( i% ~03. 相关函数3 |5 Z! G% G/ p' m9 V/ D
- /* Function used to set the ADC configuration to the default reset state *****/ 4 t0 B- b: |2 {2 b6 s
- void ADC_DeInit(void);( E6 x7 f* ]% D' t4 v* n
- 2 O- y6 z1 W8 Q
- /* Initialization and Configuration functions *********************************// s9 E# E$ J; S4 n3 H/ y: Q) C
- void ADC_Init(ADC_TypeDef* ADCx, ADC_InitTypeDef* ADC_InitStruct);6 Y* `3 T: r6 S
- void ADC_StructInit(ADC_InitTypeDef* ADC_InitStruct);8 H, E. c4 O) s& F% Q
- void ADC_CommonInit(ADC_CommonInitTypeDef* ADC_CommonInitStruct);- f8 `" f; \+ T1 ^3 P7 Z) ~' e
- void ADC_CommonStructInit(ADC_CommonInitTypeDef* ADC_CommonInitStruct);
. T8 w" E o l5 b I* T) E. A - void ADC_Cmd(ADC_TypeDef* ADCx, FunctionalState NewState);8 b7 Y- d. j" @' W
' ?0 E9 f; C9 {' ^- Q) X4 V5 F- /* Analog Watchdog configuration functions ************************************/
* `2 b: p7 ?! h" K) E8 U( | - void ADC_AnalogWatchdogCmd(ADC_TypeDef* ADCx, uint32_t ADC_AnalogWatchdog);* b, t- p0 _% P) ~; s
- void ADC_AnalogWatchdogThresholdsConfig(ADC_TypeDef* ADCx, uint16_t HighThreshold,uint16_t LowThreshold);
y5 k+ g3 {4 Q" l - void ADC_AnalogWatchdogSingleChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel);
# Q7 g4 N7 j! [# F( V - ) S3 G. k- L$ x0 @" w1 |
- /* Temperature Sensor, Vrefint and VBAT management functions ******************/$ z9 C. r9 Q- p$ g2 X! B
- void ADC_TempSensorVrefintCmd(FunctionalState NewState);4 Y) q, r9 S# P7 [
- void ADC_VBATCmd(FunctionalState NewState);+ p( T7 o( Z' L7 p$ j- Z
- - N5 {" |7 U; N& M3 S% x
- /* Regular Channels Configuration functions ***********************************/
. X! i) E0 W8 q4 i% S+ i7 B- g - void ADC_RegularChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime);
| s) w0 [& O# z; p - void ADC_SoftwareStartConv(ADC_TypeDef* ADCx);5 R) w, p2 F0 O0 j6 A1 [! W# @
- FlagStatus ADC_GetSoftwareStartConvStatus(ADC_TypeDef* ADCx);& t1 E- I- g0 @ D6 A( W
- void ADC_EOCOnEachRegularChannelCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
+ ~& A! T( S$ ]+ C. L - void ADC_ContinuousModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);( W3 l; H0 Q* I8 c2 ^2 T9 w
- void ADC_DiscModeChannelCountConfig(ADC_TypeDef* ADCx, uint8_t Number);
2 k9 @5 j* w* g. }3 | - void ADC_DiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);
9 u" q# k6 T; b9 ^ - uint16_t ADC_GetConversionValue(ADC_TypeDef* ADCx);1 n- S! v) ?( F
- uint32_t ADC_GetMultiModeConversionValue(void);7 c4 W6 ? H- M2 X
- % F4 e' K4 J9 @) y
- /* Regular Channels DMA Configuration functions *******************************/
8 w7 K9 \/ V2 j - void ADC_DMACmd(ADC_TypeDef* ADCx, FunctionalState NewState);- U! k( E9 J1 r$ }: R1 A: m$ l
- void ADC_DMARequestAfterLastTransferCmd(ADC_TypeDef* ADCx, FunctionalState NewState);+ }9 a* d7 U0 S" m+ Q
- void ADC_MultiModeDMARequestAfterLastTransferCmd(FunctionalState NewState);. u) c+ b( B9 K8 t7 w' R i
- + n7 _! Q& B& E" L( t5 Y
- /* Injected channels Configuration functions **********************************/
: S( G# A3 V$ [6 W, d' f/ M - void ADC_InjectedChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime);
4 u; c7 M# T1 c3 a5 X+ {3 V5 { - void ADC_InjectedSequencerLengthConfig(ADC_TypeDef* ADCx, uint8_t Length);0 d0 t9 E% s" J/ d
- void ADC_SetInjectedOffset(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel, uint16_t Offset);
+ k6 B9 k! S$ }( P1 D0 p4 X0 D - void ADC_ExternalTrigInjectedConvConfig(ADC_TypeDef* ADCx, uint32_t ADC_ExternalTrigInjecConv);4 G4 h4 G" t$ R$ ^! f: S
- void ADC_ExternalTrigInjectedConvEdgeConfig(ADC_TypeDef* ADCx, uint32_t ADC_ExternalTrigInjecConvEdge);
0 K( E7 q! V8 f0 L" _7 a0 e! R+ N - void ADC_SoftwareStartInjectedConv(ADC_TypeDef* ADCx);
0 ~ T& a" }/ {5 _' Y/ P - FlagStatus ADC_GetSoftwareStartInjectedConvCmdStatus(ADC_TypeDef* ADCx);" {7 t+ p. q: I# W; ^
- void ADC_AutoInjectedConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState);- w; l) u3 k6 p* t& p' q, [+ D
- void ADC_InjectedDiscModeCmd(ADC_TypeDef* ADCx, FunctionalState NewState);0 i% V. [9 i3 w7 Y( r" J; |+ k" I
- uint16_t ADC_GetInjectedConversionValue(ADC_TypeDef* ADCx, uint8_t ADC_InjectedChannel); Q( K1 D7 t: H8 @: F9 U
- # p4 m4 z& K K
- /* Interrupts and flags management functions **********************************/, D) x- B# ^# W# C( |
- void ADC_ITConfig(ADC_TypeDef* ADCx, uint16_t ADC_IT, FunctionalState NewState);
: V* O" B$ N" S. S5 n* ~; h+ r - FlagStatus ADC_GetFlagStatus(ADC_TypeDef* ADCx, uint8_t ADC_FLAG);( j* ~- O$ l9 k: k) F
- void ADC_ClearFlag(ADC_TypeDef* ADCx, uint8_t ADC_FLAG);" ^( q, E' [. C3 U
- ITStatus ADC_GetITStatus(ADC_TypeDef* ADCx, uint16_t ADC_IT);
$ G! M n) s0 L H F" r - void ADC_ClearITPendingBit(ADC_TypeDef* ADCx, uint16_t ADC_IT);
复制代码 ! ]; O1 l; y* ]- D% K( ]! [) [+ }
04. 结构体封装7 j5 \% U5 B( [$ b9 y
1 x4 Y- A3 H, G8 x! @& B( q - * @brief Analog to Digital Converter
; X2 z" O8 [* q7 V- j0 M5 M - */8 O8 ]* T. [/ u8 D
- + C% W8 m9 F; B/ X- `: z; q5 {
- typedef struct M1 \* i; e' }; S# y
- {5 D$ G4 a* m& D( \
- __IO uint32_t SR; /*!< ADC status register, Address offset: 0x00 */4 E+ E. w# W4 k' c2 F
- __IO uint32_t CR1; /*!< ADC control register 1, Address offset: 0x04 */ $ s; l8 }% f2 K8 W$ Q
- __IO uint32_t CR2; /*!< ADC control register 2, Address offset: 0x08 */; c3 ~6 ?- v# q' }- c$ v
- __IO uint32_t SMPR1; /*!< ADC sample time register 1, Address offset: 0x0C */
5 {8 F! Z# M& x% p/ u* B- v& ] - __IO uint32_t SMPR2; /*!< ADC sample time register 2, Address offset: 0x10 */' O) n2 a+ \" l& U- B( u
- __IO uint32_t JOFR1; /*!< ADC injected channel data offset register 1, Address offset: 0x14 */
6 t5 j! m: e! v6 e! h. E" H0 n - __IO uint32_t JOFR2; /*!< ADC injected channel data offset register 2, Address offset: 0x18 */
+ D6 M. t3 Z0 l1 b' e4 a - __IO uint32_t JOFR3; /*!< ADC injected channel data offset register 3, Address offset: 0x1C */
6 |: M3 `1 N S, f - __IO uint32_t JOFR4; /*!< ADC injected channel data offset register 4, Address offset: 0x20 */( {, E, g, m; O0 t* d% q
- __IO uint32_t HTR; /*!< ADC watchdog higher threshold register, Address offset: 0x24 */- {0 ?, t" L7 E/ q. M
- __IO uint32_t LTR; /*!< ADC watchdog lower threshold register, Address offset: 0x28 */- I- `4 a3 G" y1 x( K- ^( v$ k5 C
- __IO uint32_t SQR1; /*!< ADC regular sequence register 1, Address offset: 0x2C */
$ O/ v6 q3 X: K - __IO uint32_t SQR2; /*!< ADC regular sequence register 2, Address offset: 0x30 */
+ ^6 A6 } C! }& c6 }9 q' K" Z9 v% r - __IO uint32_t SQR3; /*!< ADC regular sequence register 3, Address offset: 0x34 */
* ?; _0 m! X% Y, s. I - __IO uint32_t JSQR; /*!< ADC injected sequence register, Address offset: 0x38 */" Z) Q9 h5 T1 c3 b
- __IO uint32_t JDR1; /*!< ADC injected data register 1, Address offset: 0x3C */
4 Y7 O2 W$ U' V6 o" v - __IO uint32_t JDR2; /*!< ADC injected data register 2, Address offset: 0x40 */
: P/ d, H# ?+ N9 `. h - __IO uint32_t JDR3; /*!< ADC injected data register 3, Address offset: 0x44 */( A7 C. m( F, t; q: T' K' z
- __IO uint32_t JDR4; /*!< ADC injected data register 4, Address offset: 0x48 */8 q: o2 P) K* v8 x T
- __IO uint32_t DR; /*!< ADC regular data register, Address offset: 0x4C */
0 t% X5 B9 d+ |, A- a; Y0 y/ u1 ? - } ADC_TypeDef;
8 |% ~$ ]8 l* Q+ {6 m. z# u - + f4 M6 a A5 P) R1 _9 ] ^
6 z9 ?9 O+ I3 X( w2 i" N4 d: T |
