STM32L0系列& `3 z* c6 X4 C+ `
测试基于L053
" L& F# R. m. ^6 [9 u, C
' A- {6 X2 o5 G* D初始化
. |, j% B& l$ v% c. N- void MX_RTC_Init(void)
2 G" ?5 z) Z, F- j0 v# I5 W4 { - {5 [8 E+ `1 s# C
- LL_RTC_InitTypeDef RTC_InitStruct = {0};6 |8 }0 ]$ Z* _$ @7 |, Z8 w8 q
- 1 b. \8 r5 o/ E# |; N9 J
- /* Peripheral clock enable */
# D: ^' y- m2 q# ?' v - LL_RCC_EnableRTC();
% U) {: ^+ p% G; ?: q1 |9 p P
& W. A; H" k. L* Y" }. C- /* RTC interrupt Init */
. `. b" D- P' o - NVIC_SetPriority(RTC_IRQn, 0);
: L9 q/ _! p) M& v' D - NVIC_EnableIRQ(RTC_IRQn);
" S$ U6 }: d8 ^- W3 l% M1 }) b - ) r1 |7 l6 \) ~5 [8 F
- /** Initialize RTC and set the Time and Date% c5 K! N' t" X3 F1 w8 c
0 n; S" P8 w/ h/ `4 Q$ _" d - RTC_InitStruct.HourFormat = LL_RTC_HOURFORMAT_24HOUR;6 L/ }% h9 P9 v7 V
- RTC_InitStruct.AsynchPrescaler = 127;
' d; V4 g. m9 d# k- m$ j" l! H7 b# s - RTC_InitStruct.SynchPrescaler = 255;; B0 m7 p8 [( B6 u+ f7 {, n+ \. M
- LL_RTC_Init(RTC, &RTC_InitStruct);
( a! x& ]6 G0 Q0 J, h1 _' d - /** Initialize RTC and set the Time and Date
6 E! L5 V2 J) ^- A$ |3 W - */$ `9 V. B. ?6 a0 y: ^2 ]) _
- /** Enable the WakeUp0 n/ i$ P5 n6 l% n
% k6 q. u/ [& m+ L# h2 f3 A7 l - LL_RTC_DisableWriteProtection(RTC);; d' o$ Q2 ^- X3 {9 Q
- LL_RTC_WAKEUP_SetClock(RTC, LL_RTC_WAKEUPCLOCK_CKSPRE);
9 @' t4 ^; K; D& t) f4 c; S _ - LL_EXTI_EnableIT_0_31(LL_EXTI_LINE_20);/ M i8 s0 }0 G& W. |+ V2 k
- LL_EXTI_EnableRisingTrig_0_31(LL_EXTI_LINE_20);
* n& b* r* h- N% P y7 d2 l6 }: l9 n - LL_RTC_WAKEUP_Enable(RTC);
6 o8 N+ E) `9 W+ x( n0 r, H( s - LL_RTC_EnableWriteProtection(RTC);
/ J: H* V, Y/ b y% T - }
复制代码 3 A) W6 a" S0 S$ c* e( C
中断回调
" d! w3 v, }0 \9 V. L( z- void RTC_IRQHandler(void)
, N- J5 _: U3 I0 Q3 O$ j( J - {7 G" ^( ~$ ~# U$ ]9 O4 j$ Z
- /* USER CODE BEGIN RTC_IRQn 0 */+ c2 ^% ?2 y2 \% R8 n
- HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin);. u/ }1 d+ F% C
- /* USER CODE END RTC_IRQn 0 */
$ W8 {2 O5 G6 n+ N; |) S# M - 2 v! J0 L5 } B6 v" \8 r2 B& d
- /* USER CODE BEGIN RTC_IRQn 1 */- h3 }, }/ o) r0 Y( k: M1 w
- LL_RTC_ClearFlag_WUT(RTC);//清除秒中断事件9 y' ~4 [9 G& |" \6 i/ c: i
- LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_20);//清除中断线标志位. s# p3 f% w) N! B/ @& C
- /* USER CODE END RTC_IRQn 1 */
4 D3 m6 O+ N( H% [) N' H - }
复制代码 h7 z! p$ p+ Y {: H
话外篇
& [# `8 Z& @5 e+ ]- e. n维护老项目的时候调试半天,就是不能触发RTC秒钟断,最终经过查找,发现是HAL的MSP Init被删掉了。。。2 R! ?6 v( ]* J0 K: p
在stm32l0xx_hal_msp.c中添加如下代码,RTC功能实现:
" O0 {2 H2 J& d6 X' l a/ u- {& \; H, b4 I
- void HAL_MspInit(void)
$ P# U) D5 M& }* X9 n - {+ j+ _1 d4 |5 V, ] Y
- /* USER CODE BEGIN MspInit 0 */) v- h6 v7 c: V2 U
- 7 o& }- T3 i- B9 k/ e0 k
- /* USER CODE END MspInit 0 */
7 ]4 ~9 H; Z" o- L
* |4 ^( Z! B. p0 }# P6 W- __HAL_RCC_SYSCFG_CLK_ENABLE();
/ J2 B4 }( I2 C - __HAL_RCC_PWR_CLK_ENABLE();) n8 A' h) }# J( d3 u; k" P
* m9 G0 o1 g0 t% t: `& @" d* _- /* System interrupt init*/- k( F4 h5 O* g
$ }! e: D( ~0 V" j5 `- /* USER CODE BEGIN MspInit 1 */) X* M" u1 D: K) Y, `: {' a, n
4 p$ j8 J7 f2 a- /* USER CODE END MspInit 1 */
4 M& e; O9 Y N" E; ~2 L0 x o' e6 i - }
1 _2 r0 w3 R* C. ] F% ?————————————————
! b8 f; q, K. {1 N版权声明:Logan Li
- Y" E C% I0 X0 {$ k# J3 A6 x% L& e6 i _
