实验内容:跑马灯、蜂鸣器和按键输入+ ~7 r* X* l$ {1 H
* O& |9 t' Y6 A6 F特点:不涉及寄存器操作、位操作相关代码,适合初学库函数操作的朋友7 S0 z( y# m+ y1 I, A! K. F
原理图:
1 ^$ x8 y5 y, j( c: v9 N6 w1)如图所示,跑马灯,PB5接LED0,PE5接LED1;
5 ]3 L0 M9 U. y) d: y5 m$ e3 @% O. o$ U% F3 B i' O( v$ m
( I3 V/ E: e1 S9 ?1 d$ Q2 b7 v# \
9 U, s2 i, S4 Z9 {3 q2)如图所示,蜂鸣器,PB8接BEEP(蜂鸣器);
) h, o/ d2 n! |2 `3 x; k& h7 q! W+ J! b" ~
; U" [4 X, D( y
" Q& g1 f" S" m5 d b3)如图所示,PE4接KEY0,PE3接KEY1,PE2接KEY2,PA0接WK_UP;
+ P3 s5 {7 p* _7 X9 ^% G! x/ ~2 l
5 ]- T1 H; z0 I$ v6 F% a
9 F+ u3 K9 {1 j3 J9 ?- X
+ @9 j" }, E* G3 P! c, I) v工作原理不细讲,一定要看清外设与哪个GPIO管脚对接。/ w8 g/ i2 Y- E: D# g
$ e& Q( X4 j3 P0 g# S* ?+ K6 t涉及四个GPIO库函数:( U" w: _3 q1 X# N
0 g2 Z% {. M0 U; W3 l
- 1)void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct); //初始化作用& l2 q5 {7 M5 ` e+ |
- 2)void GPIO_SetBits(GPIO_TypeDef* GPIOx,uint16_t GPIO_Pin); //设置输出电平为高9 p1 D, Q$ T) R# U: }5 R
- 3)void GPIO_ResetBits(GPIO_TypeDef* GPIOx,uint16_t GPIO_Pin); //设置输出电平为低3 P7 {* b: M9 I9 d' t }
- 4)uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef*GPIOx, uint16_t GPIO_Pin); //读取某个GPIO端口的输入电平
复制代码 ! Q4 q2 \$ F8 G9 I2 d! c
在stm32f10x_gpio.h文件中,有如下代码,需要牢记:
2 h$ @ n y+ d9 {0 z7 T% R# z E
2 o' @- F! P! J* V* @- typedef enum2 S0 a; B' }8 z0 H; v
- { GPIO_Mode_AIN = 0x0, //模拟输入//2 W9 y- p- C+ Z5 J! s3 [
- GPIO_Mode_IN_FLOATING = 0x04, //输入浮空//
7 \ U% }1 ?- u. P: O' G/ \ - GPIO_Mode_IPD = 0x28, //输入下拉//. g! p) x$ b4 m( X: u( M
- GPIO_Mode_IPU = 0x48, //输入上拉//
, f' w y0 ^0 W6 S3 S - GPIO_Mode_Out_OD = 0x14, //开漏输出//9 t T6 J" X' O0 w5 p6 F
- GPIO_Mode_Out_PP = 0x10, //推挽输出//0 u8 y9 }$ [3 E3 X: Q+ z
- GPIO_Mode_AF_OD = 0x1C, //复用开漏输出//
* Q i$ @+ m3 R9 L* w6 D. V* C5 y - GPIO_Mode_AF_PP = 0x18 //复用推挽输出//9 {" V3 a& c6 B3 d) }" [( m
- }GPIOMode_TypeDef;
* A* B+ Z/ f/ ~$ V这八种模式对应的地址是如何修改寄存器的,我暂时还不了解,有兴趣的可以仔细解读stm32f10x_gpio.c文件中的void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct)函数。& m5 R: Q% \" L7 D% P
, {* @8 u+ }! a5 V/ B7 F/ ^) I实验步骤:! l5 W3 d9 L* c3 t: u
1) 新建工程模板;
* }! U7 t. U5 l- ?+ Y8 j4 Z2) 新建HARDWARE空文件夹(与USER文件夹并列);
% N; w, k! u8 P6 V4 \7 B( h/ k' h3) 在MDK软件中,新建led.c,beep.c和key.c三个.c文件以及对应的led.h,beep.h和key.h头文件,均保存在HARDWARE文件夹中;5 M# ~+ w3 s- T k% [" f( S! M
4) led.h头文件代码如下:
0 X+ u8 ?' i, r) F9 ]4 B- q$ V3 V* ]( \5 H' g9 Y! d* ^6 d
- #ifndef __LED_H
/ t# N8 h( `4 M - #define __LED_H) j- m) Y9 O9 N" f6 i' D
- void LED_Init(void);
# l! l0 h O- ^9 W9 i* Z$ f) P$ D - #endif
复制代码 / ~3 `& e" k4 x$ I8 s4 O
5)beep.c头文件代码如下:
; `% N7 B9 b" Q0 V6 |1 @, W: m. B4 H3 l( O: |
- #ifndef __BEEP_H
3 s- X0 ?, O( S5 u, w! Q. d - #define __BEEP_H
% q$ N) i4 {! Q0 n - void BEEP_Init(void);: Z) G6 E+ H$ e1 B. K
- #endif
2 Q a6 q5 v, l7 P/ d- S: q/ |( x6)key.h头文件代码如下:1 l+ |1 Q3 {1 M) o* i
9 p, A+ c- B% \
- #ifndef __KEY_H1 b2 y' V; W$ t# a/ y' J
- #define __KEY_H) Y# a$ D# q5 x% u" c- h2 m) R
- #include "stm32f10x.h"7 b5 o8 E% c2 b" p3 w' }# U. P4 T$ W/ p
- void KEY_Init(void);: A& Z' M- c, _ k v# W
- u8 KEY_Scan(u8);
" J( U3 F% q1 z4 p( H6 Y2 q - #endif
复制代码 E% ]/ x0 O: p3 j
7)led.c文件代码如下:
, b- n9 w2 C% O+ ~2 i: C, Y" _* h' {: H1 Y) Y: W
- #include "led.h": _. y* D7 r! t) q) e# w8 l
- #include "stm32f10x.h"' v( f& ?" ^6 o7 ?3 | n$ Y
- void LED_Init(void)! t8 }' |7 @& l$ d# X- Z7 m
* v; `0 |* h8 f' ^ - GPIO_InitTypeDef GPIO_InitStructure;
1 i# M5 [; E5 \) ^% c - RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能PB端口时钟
: h a" s3 p9 m# g - RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE); //使能PE端口时钟
5 ^9 b7 l& z- B1 y - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //LED0-->PB.5 端口配置
# T8 E g. b6 q8 g - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
* N# F! F" [* s0 m# N - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz
" k% Y0 d) U# o9 | - GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB.57 s/ s6 U5 B2 x5 B* `2 p' l
- GPIO_SetBits(GPIOB,GPIO_Pin_5); //PB.5 输出高,LED0灭
5 o: u, g: O" X8 ? - GPIO_Init(GPIOE, &GPIO_InitStructure); //根据设定参数初始化GPIOE.5/ a. o: u% m9 E8 S5 t6 ~$ f& ~1 ?* R
- GPIO_SetBits(GPIOE,GPIO_Pin_5); //PE.5 输出高,LED1灭
3 j1 u5 b- x$ c1 ~ - }
复制代码 T) D l2 Z w8 a6 c
8)beep.c文件代码如下:
N: X7 b+ v; \5 A1 g
4 M# n3 y6 p; q" [5 c- #include "stm32f10x.h"
5 ~+ i% n3 v2 T* X( z! v$ z - #include "beep.h"
! q7 _! S4 X& L n5 D% ? - void BEEP_Init(void)2 c2 z( K9 P* y+ p- v
5 k- U* {6 H* h- ]% n - GPIO_InitTypeDef GPIO_InitStructure; : K! v7 C4 L+ [( R2 m% A2 g$ ]. c
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能PB端口时钟 0 C3 z8 V% C1 ]* L
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //蜂鸣器-->PB.8 端口配置 `% z" X: `- G$ k' y
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出3 D$ a; v, ~& c" x; }5 s; H
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz: ^4 F( M0 |: X6 F7 t( W
- GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB.8* ?& Z1 }. ]' _4 K
- GPIO_ResetBits(GPIOB,GPIO_Pin_8); //PB.8 输出低,蜂鸣器不叫 ' Y' g4 m% U1 W# t( v. ?: [
7 V# M+ z2 V4 A0 k, ~& R# t$ W9)key.c文件代码如下:
# q" \ e; u5 Y) a, @) p4 L% a- H% ]) B) A- N3 t" }
- #include "stm32f10x.h"; c6 ], D# O7 ]- U# ~
- #include "key.h"5 O" ^* n% d! E! p2 |
- #include "delay.h"
% a! u4 n4 c+ W# v! T/ h& d! K* ~ - void KEY_Init(void) //IO初始化 l% A' @( G9 ~( W
5 |& p3 v/ T* D2 b - GPIO_InitTypeDef GPIO_InitStructure;
5 z7 _! ^" s8 @1 T - RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOE,ENABLE); //使能PA,PE端口时钟
+ W- |5 P5 {+ p6 \, b$ }7 B - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4; //KEY0-KEY2
- v b h/ D" O: r! n$ t& ^ - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //设置成上拉输入
" H* I9 p3 ]8 k% S - GPIO_Init(GPIOE, &GPIO_InitStructure); //初始化GPIOE2,3,44 n5 ^0 d* y, h; I [, X
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;& X% q/ q' C9 }3 H* J% X
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PA0设置成输入,默认下拉
2 _: J( Q' |+ f8 G1 Q; Y" j) | - GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化GPIOA.0! ~! |- V/ \8 \9 a
# R( y2 p0 {! y5 q. u5 D0 P; U7 u( o4 i - u8 KEY_Scan(u8 mode)
6 Z L, m* c! K s - { + z! D: `$ O# U% B
- static u8 key_up=1;//按键按松开标志
4 q% F9 l: L B - if(mode)key_up=1; //支持连按
5 ?9 h! t X* x1 Z - if(key_up&&(GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_4)==0||GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_3)==0||GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_2)==0||GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1))
& S5 O# R( b& N9 H+ Q" G - {
7 i* J: [: ]$ _1 { - delay_ms(10);//去抖动 3 p( t7 o4 b/ j! A- H' X
- key_up=0;1 f; P9 O9 I: i" h% x! X, N6 E$ g
- if(GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_4)==0)return 1;1 [" ]2 m/ b6 W* Y3 b! L. }
- else if(GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_3)==0)return 2;
! @( @( p' D, x - else if(GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_2)==0)return 3;" i: [. m! C5 o0 @5 ~6 k
- else if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1)return 4;2 H: q5 o% e9 | {$ {) r' r
- }else if(GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_4)==1&&GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_3)==1&&GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_2)==1&&GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==0)key_up=1;
6 {8 e' s/ E. j' W- E) `, O$ d - return 0;// 无按键按下( b7 j4 I; I' X+ ~) @9 z$ T$ b
复制代码 3 D+ @$ Y7 C. p6 Y0 ^, A9 l
10) 在MDK软件中,右键Target1,单击Manage Project Items…,在Project Items界面、Groups一栏,新建HARDWARE,并将led.c,beep.c和key.c三个.c文件添加进来;
' \7 ]9 `% h" A, e% T11)在MDK软件中,单击魔术棒,在C/C++选项里,单击Include Paths右边的…,添加led.h,beep.h和key.h三个头文件的目录(即HARDWARE);( f k8 Q- {6 u" c" ]
12)新建main.c主函数,代码如下:; R9 j1 o* @' g& F
, }6 s" c$ g0 d3 J s a
- #include "stm32f10x.h"1 z2 w5 ` r; p# x3 o+ l$ d8 a
# n/ t0 }1 n( } - #include "led.h"; M! L( ?$ {) e4 E: l4 Z" ]: D
- #include "beep.h": L+ L) I. J$ F' e/ a
- #include "key.h"3 a" e0 _' E# j4 I6 U
- int main(void)
, I9 W7 o) U5 S4 n% \* Z" L - {
/ I7 A z$ Z, S: o" g) C% Z6 L - vu8 key=0;
' o L s) r# L0 Z - delay_init();
; q- G8 D: q5 G" _ - LED_Init();6 n6 B4 u* [# B. c' `2 [. l
- BEEP_Init();
' s5 y9 }8 O; V. d - KEY_Init(); % l3 m4 e1 ]$ {1 F' X9 W+ @ Z
- while(1)! F6 |6 k) N4 G W9 Q' U
- {3 C. L) o7 ~% B
- key=KEY_Scan(1);+ A4 o" d0 ]1 g1 O1 [( }; E, z
- if(key)7 X3 ]% d6 `. Z! j+ l6 @; \4 e
& b) y3 @1 n4 n5 S+ r# j! \ - switch(key)2 H) P- @5 n+ f& [& }2 [" b1 D
- { ) ~6 n; P) P5 @
- case 4:
; i, X+ I! R1 b Y6 F( x9 M' O - GPIO_SetBits(GPIOB,GPIO_Pin_8); //控制蜂鸣器叫 $ U9 u( m- G! F; x: ?3 H
- break;
; x2 i7 G4 p0 a' H - case 3:
|1 g0 h4 Z [7 E - GPIO_ResetBits(GPIOB,GPIO_Pin_5); //控制LED0亮
* H/ u% L1 u! J, q+ Q% C# O) m) q - break; ( j8 _0 s7 v: d2 X: h( X0 G: i
- case 2: 8 A& W) f0 @ { [9 e
- GPIO_ResetBits(GPIOE,GPIO_Pin_5); //控制LED1亮
' j# V; w4 v# L6 z. I5 m7 Q- u - break;0 a; E* U% |. Q0 R: @2 c/ r
- case 1:
( P7 I' l$ P2 l) b: `/ P - GPIO_ResetBits(GPIOB,GPIO_Pin_5); //控制LED0亮 $ K# t6 D; m: `
% {8 |" z1 v x: k P, ^5 i5 { - break;
& Y1 R, H$ m6 G - }
) n/ }$ e ^3 R, d - delay_ms(1000); //延迟1000ms
6 Y g. S" j$ B. N) ?: Q - GPIO_ResetBits(GPIOB,GPIO_Pin_8); //控制蜂鸣器不叫
+ h- o. R7 w9 e: c0 [1 j7 {) ? - GPIO_SetBits(GPIOB,GPIO_Pin_5); //控制LED0灭
" O3 E, s+ x) m: U7 b - GPIO_SetBits(GPIOE,GPIO_Pin_5); //控制LED1灭
3 j- f: }5 H$ Q - }. r/ }4 G/ R3 c. r8 c- G- o. Y
9 {5 W* i- n0 C. O7 v - }
$ X/ P5 X7 F; f+ ~4 f: W13)完成后即可运行看效果。
2 i$ q; k9 |( o4 x4 V2 ^————————————————1 B. ?" D9 v0 D3 G) W6 t* F( W
版权声明:天亮继续睡
( @$ r% R* F8 y% ~+ N7 a+ f7 o8 A! G, e# B2 t% d5 D" K
' f0 j! t% C4 G" A# u |
