STM32的时钟配置
STMCU小助手 发布时间:2022-12-26 16:00
5个时钟源
! ]2 w% }1 H3 B9 |. x, k: @( K3 ~5 XHSI,HSE,LSI,LSE,PLL1 ]7 q4 y8 p' Q+ i2 O
/ k& y1 f8 ~' ^6 E+ h2 a
HSE为高速外部时钟,频率范围4~16 MHz/ p/ ?, Z, T8 K0 ^
( _+ F. K2 t7 H8 B5 c' iPLL的时钟源可以为:! p. N! Q( N/ w! M1 S, W8 M' Z
HSE/2/ w  I" s5 I3 j  ~" b8 h
HSE; l4 V9 ]# U$ Z, ]# r8 a
HSI/2) P. S$ l% D. e4 Y2 \0 ~. Z
倍频系数为2~16倍: O2 E* M  c/ C. C1 s- u+ t5 H1 v
: z7 U* g3 ~# aSTM32可以选择一个时钟信号输出到MCO脚,即PA8上,可以选择位PLL输出的二分频,HSI,HSE或系统时钟: c# {7 L! ?( s+ V7 N
: q' i. B7 e+ o! {注意:任何一个外设之前,都必须使能其对应的时钟
- [& @: a3 x/ ]" E- `
! {% K4 m1 T" {( x% T2 O, p
  1. /**
    ! K; g  M4 {- |" \4 l' u* N
  2.   * @brief Reset and Clock Control
    3 ]+ m9 l* I: C8 U) S
  3.   */' C0 w/ T9 E) I# \' L
  4. 5 L/ N, C* J4 b" {* q
  5. typedef struct( U$ O$ H8 ]5 A# m
  6. {
    + T1 D7 m7 k4 D) L
  7.   __IO uint32_t CR;( z) N' A! S5 g8 a3 X
  8.   __IO uint32_t CFGR;7 p1 F' c% B3 Z7 e
  9.   __IO uint32_t CIR;, }  C5 E3 E7 k. E7 `" N( S
  10.   __IO uint32_t APB2RSTR;  I6 \/ `) p, N3 O/ ]
  11.   __IO uint32_t APB1RSTR;( K1 W8 [9 ^0 B
  12.   __IO uint32_t AHBENR;! j1 m7 H! ~' p; L# z' j
  13.   __IO uint32_t APB2ENR;
      k/ e- t. t! p5 Y# ]
  14.   __IO uint32_t APB1ENR;) e* I1 e/ X0 K, S& t5 W# X7 `
  15.   __IO uint32_t BDCR;' }4 P3 v* D* {. a9 }. o
  16.   __IO uint32_t CSR;
    , e) P" u2 d9 \' c: N2 s" \
  17. 6 u! Z6 O% C) _8 Z
  18. #ifdef STM32F10X_CL  . u6 y% P9 o1 k/ y' M
  19.   __IO uint32_t AHBRSTR;
    : w% `) N/ h& o8 [, Z: S: I- h
  20.   __IO uint32_t CFGR2;
    - p' L2 Z+ Q( l
  21. #endif /* STM32F10X_CL */ + u: p# l9 j8 S) G
  22. 6 ~5 ?! B* E: N' x  \* U3 E
  23. #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)   0 B  a$ I5 r! f0 L7 B) o1 f8 [) G
  24.   uint32_t RESERVED0;6 _# _5 m& D; n" [6 Y0 P' e' Y! n
  25.   __IO uint32_t CFGR2;: y8 Y% L2 n6 F) u. w4 C& o4 p
  26. #endif /* STM32F10X_LD_VL || STM32F10X_MD_VL || STM32F10X_HD_VL */   e2 T2 Q- @" A8 g3 Z* r$ e; I: b
  27. } RCC_TypeDef;
0 B; o4 l* T% ?1 ~/ R4 N
4eb1912c6807466494f84994497d5690.png : |" c# Q' n0 g$ D" O9 v
! Y) H$ v" R' X  q' I" ?' x  M$ d/ f" x; G& y4 z
如何查看SystemInit函数3 N4 f/ @# Y4 z) h# d+ x% `- @
& z2 L8 {1 Q2 c: y4 `
! b$ \  h( L6 I+ E+ w* ^" y9 B  Y8 r, E! P' [5 u% ]8 [
可以看到这里有SystemInit函数的声明
8 O9 r: i) ~$ d0 ~1 Z0 V- n, u' Y
42e5a44911b84250a91e5c28a9ece63f.png 8 ]4 E; H/ d+ x
+ o3 n8 X2 i. D+ Y1 y  @+ T
打开这个文件,可以看到SystemInit函数的定义  ]* F: n) g1 w9 F0 Q( N
8 V: T2 M1 w' I
  1. 6 {( e( B/ G: R; G9 U
  2. /**; s& |$ n. j  n3 ]
  3.   * @brief  Setup the microcontroller system
    : s" b5 S4 C: \7 p- i8 N  v
  4.   *         Initialize the Embedded Flash Interface, the PLL and update the 8 l" [; ^2 f- k- Z( i- C# j2 U
  5.   *         SystemCoreClock variable.
    " E$ w6 b0 M3 D2 Z9 c
  6.   * @note   This function should be used only after reset.& e  l1 {2 H) m. _
  7.   * @param  None
    , ^3 Y& X! O) D! g- C; N
  8.   * @retval None
    $ w8 `$ p& N% b3 c' D; P7 b
  9.   */6 v" Q% A( C8 U- P
  10. void SystemInit (void)' [# L- g4 {9 A8 _1 @6 A, f+ |9 @
  11. {
    8 \6 G9 u+ w" {; }
  12.   /* Reset the RCC clock configuration to the default reset state(for debug purpose) *// g2 }. ]2 l, D
  13.   /* Set HSION bit *// C# F+ _' d" k4 S6 f) G
  14.   RCC->CR |= (uint32_t)0x00000001;
    1 C/ s' p3 T6 Z( l
  15. - e: @) N$ h* J3 j1 @5 M
  16.   /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
    5 M0 h- v" n) J* B, M4 z% M) K) ]
  17. #ifndef STM32F10X_CL+ P( F, a. G1 B! N
  18.   RCC->CFGR &= (uint32_t)0xF8FF0000;8 H9 H2 v$ u3 L5 y
  19. #else. B2 r% ~( h# @
  20.   RCC->CFGR &= (uint32_t)0xF0FF0000;
    + v/ W' `& k+ a/ ^+ n8 e, a% s
  21. #endif /* STM32F10X_CL */   ' I& S" {9 s. V6 a+ K9 O
  22.   , D, a1 ^. u1 Q9 S2 S
  23.   /* Reset HSEON, CSSON and PLLON bits */  ~9 \( [+ _' G2 W" l' y% E
  24.   RCC->CR &= (uint32_t)0xFEF6FFFF;8 [& o$ W- x+ @0 f5 u3 f. M
  25. : O' u0 j" L" V
  26.   /* Reset HSEBYP bit */' C/ o" C# S* H, U2 T' R
  27.   RCC->CR &= (uint32_t)0xFFFBFFFF;
    2 z8 l7 w7 s8 Y' D
  28. 2 K/ t7 ^: @: K# @
  29.   /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */8 l  g" T1 a# @& m% w" j5 N) _: t
  30.   RCC->CFGR &= (uint32_t)0xFF80FFFF;
    : K+ [0 [$ q( h7 B; p
  31. 2 \2 H6 ^7 V' D' S% n
  32. #ifdef STM32F10X_CL
    7 z7 h  v* K% v  G& \# N
  33.   /* Reset PLL2ON and PLL3ON bits */
    ( Q0 w7 k# C: k4 e  T6 ?& Y
  34.   RCC->CR &= (uint32_t)0xEBFFFFFF;! `8 u( X7 F: M, ?
  35. . G5 Z7 w$ _, u1 J8 h$ |
  36.   /* Disable all interrupts and clear pending bits  */
    " W+ U/ _3 y  A* S0 P& A/ I
  37.   RCC->CIR = 0x00FF0000;
    ; v2 G5 j! k& c7 D4 F6 n
  38. 5 U5 H+ r9 B8 g5 N9 [. q
  39.   /* Reset CFGR2 register */& H: f9 i& G$ u4 n% x1 I2 x7 {$ H( e5 i
  40.   RCC->CFGR2 = 0x00000000;
    3 n8 P5 o# T" d, A" q3 x" A
  41. #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
      e' t# G+ \$ E& L" t
  42.   /* Disable all interrupts and clear pending bits  */
      R& Y( I! ]0 H
  43.   RCC->CIR = 0x009F0000;# D! b7 a2 ~1 \% |
  44. 4 F7 y" _1 N1 z% x& g0 w
  45.   /* Reset CFGR2 register */! L/ [$ i3 A1 N
  46.   RCC->CFGR2 = 0x00000000;
    + M' s) C' D+ z0 j* `0 ]2 K7 f2 ?) Q
  47. #else
    5 a- g4 o" D/ E% v1 p$ L7 q; G
  48.   /* Disable all interrupts and clear pending bits  */
    8 l/ h, z' |$ s% l* J- l
  49.   RCC->CIR = 0x009F0000;
    . ?6 `, F' S5 Q. F" S& i
  50. #endif /* STM32F10X_CL */
    " E  z/ V# a* D* C: V9 }6 C$ {5 X
  51.
    + F: |- Z3 @6 w3 `: s5 ]2 V
  52. #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
    7 @( b7 c7 M3 Q# g2 E- A
  53.   #ifdef DATA_IN_ExtSRAM/ n8 w( G1 }5 j" q6 T
  54.     SystemInit_ExtMemCtl(); . N0 C9 I7 y: K0 x* A- O2 T* a0 {
  55.   #endif /* DATA_IN_ExtSRAM */
    % l7 L/ D( T8 l2 ^! \* h4 [
  56. #endif " q. j) z5 A: ]% S$ b
  57. % W" A& W5 k9 h( t/ _7 B
  58.   /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */  c$ \- k- s! X8 M" l5 `1 E( v
  59.   /* Configure the Flash Latency cycles and enable prefetch buffer */
    6 x% s+ r. ]) H2 P, r! B4 g4 x
  60.   SetSysClock();- S8 ?& V- X6 D4 s
  61. + ?, e. ^  M" N. ?8 {
  62. #ifdef VECT_TAB_SRAM0 f. Z1 _, G: C; q. z
  63.   SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */
    ! [& `$ A+ k% X/ i! v6 a+ M
  64. #else$ j2 u" D# {1 x9 p
  65.   SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */- N& j  D6 Q* b. M4 C9 V
  66. #endif
    : _: b, l# I; ^5 O/ |) P' P
  67. }
  z; B- D; c! b5 n- p8 H
如下图所示' y2 |0 U3 O  L5 M+ i
0 E4 M3 Z" t& ~) i
ac87cb992fb74286b66d1ff2201a78ed.png " m" d  E7 x1 v0 w8 ]3 @+ p
; Z$ B* C; _- |2 f7 z* @2 P
函数解析
  1. /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
    7 v* |9 y/ ~! n0 |
  2.   /* Set HSION bit */' w# ?) U. U# k* I- M1 L% \: Y
  3.   RCC->CR |= (uint32_t)0x00000001;
2 o8 y0 ~! r3 V2 w$ `+ m& _
3 ]" [* k$ f' P0 B
首先把CR寄存器的最低位置1
- y0 a. z; }& [: m2 N4 n, E
- D8 l. h3 i- C0 T5 `0 d6 H, m  @% aSet HSION Bit 相对于打开HSION,相对于把内部的8 MHz晶振打开8 W6 n8 q% h5 N+ Z- v
* X: G% i9 E. P9 s9 X- _( I+ W3 [7 U/ `/ U
' l8 s# e8 [; U# F. w6 M1 j6 F$ E0 H5 L- d+ T
也就是这个
$ q" }2 k0 z# F) w3 Q( o0 w& X8 n3 S! \7 w* E% j& W, @
ee533c979e8a4dbdb4b8796192f65865.png 2 ]4 @- u) s+ x$ A4 z
" B2 \" E3 o' C2 j
  1. /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */0 F6 j1 ~: y, |4 H) A6 d
  2. #ifndef STM32F10X_CL( P4 H/ d0 z8 A* C: G& s
  3.   RCC->CFGR &= (uint32_t)0xF8FF0000;
    2 R* N# D% p9 Y1 e# d  d9 Y- ^) Z% e
  4. #else
    % i$ P, z, Z& N- a# z  R) T
  5.   RCC->CFGR &= (uint32_t)0xF0FF0000;2 _: d8 V/ O1 u2 Q* h, w' [
  6. #endif /* STM32F10X_CL */
$ h- z  ^5 p+ t* N  D$ H5 g( A& J; B
" M* s/ ~6 k1 O+ F. N) {
以上代码主要是看你所用的芯片是大容量还是小容量,可以在魔术棒-C/C++里的宏处查看,例如,大容量为:% y# o9 @0 m& @1 z/ B- C7 q/ ~
9 ~  O# ~+ {4 ]* m2 R7 x
STM32F10X_HD" h7 c. }  I8 |( E! C% d' `3 c  S( F
( H( u- d5 V6 a9 ~. j
因此,这里相对于是根据所用的芯片容量选择RCC->CFGR寄存器的初始状态+ P( u0 S, w# l. ~1 j2 J, \
  1.   /* Reset HSEON, CSSON and PLLON bits */4 o5 i; F3 R8 T4 n
  2.   RCC->CR &= (uint32_t)0xFEF6FFFF;
  l% p( C8 m4 }
+ ]/ _" K7 X5 W  Z
把HSEON,CSSON和PLLON对应的位清0
# B, u' x  `8 _7 K1 O) B+ `
  1.   /* Reset HSEBYP bit */4 q. F, `0 ]+ J( F+ k* z
  2.   RCC->CR &= (uint32_t)0xFFFBFFFF;
& f( J0 u1 g* o$ Q
a1a0a1b0b9a84a239d08e77c71be1ca6.png 8 V+ G; C& h7 a( J7 E( w
4 g( N0 t: y9 \0 v 把HSEBYP对应的位清0
1 m7 `3 ^4 b2 M/ B6 F7 K  g
  1.   /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */7 V6 i' W2 ]0 `5 d! j; \( ^
  2.   RCC->CFGR &= (uint32_t)0xFF80FFFF;
. h9 `* i2 ]: ]" i+ l7 }, { f1c4cf14cbc349588f99791a0ed7d527.png
6 R0 ~; g3 A2 H+ c  |, o* g
9 Q2 v( V2 b9 Q' }+ Z( s类似
) Z8 f& L$ e; O, t
+ A: \% p6 a/ }* |" o- v  W! Q% n6 K接下来是一个条件编译
( H# p1 n/ `$ }
  1.   i& y. O! _. y+ G
    + p( c8 ~& T% |$ K; [: b$ A
    7 ?: O- g$ Z' C2 \0 L
    0 N/ ~6 o  d  l3 D1 S' d8 e
  5. ) H# j, F! z' ^0 z
    ; J: H0 J! a, y; i! f5 U: w7 A9 }1 {
    " F/ F5 e. V6 `+ M" i. N9 _! Q
  8. 4 c& o( x9 h: f! U! ]! [1 ]( E
  9.   /* Reset CFGR2 register */! Q/ l' ?- E1 u1 p' u. ]
  10.   RCC->CFGR2 = 0x00000000;" T/ u9 C5 S7 _6 x6 L$ O, j- ~5 t/ ^% E
  11. #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)3 J5 W: e( ?8 G" E
  12.   /* Disable all interrupts and clear pending bits  */( z% G+ R) c6 H& `3 h
  13.   RCC->CIR = 0x009F0000;# I  B5 `/ U" ~: P) B! a
  14. + w' w# k6 O- ~1 `
  15.   /* Reset CFGR2 register */# ?$ C7 A9 C9 j
  16.   RCC->CFGR2 = 0x00000000;
    # d. O  R! G" y4 e4 `, w  c
  17. #else
    9 R" Y" `- h2 q, q8 n9 o. S0 `' B- R
  18.   /* Disable all interrupts and clear pending bits  */  a# \1 T  p, Y
  19.   RCC->CIR = 0x009F0000;
      ?" ?; f. ~& U  L: Y7 X
  20. #endif /* STM32F10X_CL */
7 g. E. p8 J) a( q& l
7 k% {5 S. N: G6 L
: T) p) P# u& C% A/ h' p0 z
2 R* f& Z. E& M! d执行的是这一段:
0 |1 c" S* X; A# l0 t& S- j" l' _$ q& g, O; {8 o- Y7 Y% m+ L
9728413aabb84591aaa599c40b458a18.png , t; B) B$ R: Z1 i
* v5 O/ g0 X4 Y% c5 K 也就是关闭所有的中断,并清除所有的标志位. {# T9 ~# g# ~! e
( [, b3 {: x' ?, a" U9 m4 ]
接下来调用了一个非常重要的函数- o8 P) r4 p' u
  1.   /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
    # s& \. u. x5 G3 q( F' S
  2.   /* Configure the Flash Latency cycles and enable prefetch buffer */# p/ W# f9 n) Z' m
  3.   SetSysClock();
* f3 |; K' c- j4 t: B
226ba74ad07f41b1a553eaab04c4fef9.png % A8 A7 B$ Y, ?* j6 f0 y
' U* C: i% s; i& b! X% c1 ~看一下这个函数的实现:
: ~. G9 x$ A+ \+ h! ]( l. h' G
  1. /**1 t  ~0 o& \; L. h9 P6 R
  2.   * @brief  Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.% C% \* ~, G2 H, L9 |
  3.   * @param  None
    2 b# S7 o# G( X: P5 w
  4.   * @retval None
    0 e+ s7 g( j9 L4 f! H6 B
  5.   */
    6 A. [' r! z1 N
  6. static void SetSysClock(void)5 D1 _! b* l  @  [7 w
  7. {
    $ r2 ^( p; J1 o4 B: x, O! g, Z
  8. #ifdef SYSCLK_FREQ_HSE) Y( g- r9 W' Y! V- e# h' _8 R' @
  9.   SetSysClockToHSE();
    ) k$ x/ Y# X+ l" j% L
  10. #elif defined SYSCLK_FREQ_24MHz9 j# [1 J1 [- {' ]* f3 j8 _
  11.   SetSysClockTo24();
    5 ?# B( B+ F; I, q0 v& Z. B1 |
  12. #elif defined SYSCLK_FREQ_36MHz1 X5 f4 s1 m: `7 l$ Z9 B5 s2 y( d; A
  13.   SetSysClockTo36();
    ' D- q9 ]9 v" S1 u4 m; f
  14. #elif defined SYSCLK_FREQ_48MHz
    ' M$ R3 ], K0 S+ S3 ?
  15.   SetSysClockTo48();
    3 ?7 z2 c. r+ ]% A6 @. i5 y
  16. #elif defined SYSCLK_FREQ_56MHz! a% \. N* f7 Q0 L+ H
  17.   SetSysClockTo56();
    , h% W2 l. z" d9 R7 t$ z
  18. #elif defined SYSCLK_FREQ_72MHz
    $ m) C2 W8 @1 J7 ?
  19.   SetSysClockTo72();  n" Z& |! g( N
  20. #endif
/ ]0 b6 q* B* e6 O( T6 {0 f! Q 4f08b87b29cb495487f3740faa54c379.png # z4 u! }8 V5 V/ B6 Y5 S1 s4 l* G
" W3 g0 a7 a( w& I3 p! T2 S
这个函数主要是看看这些标志符有没有被定义,这个定义我们是设置在下面这个文件中,我们进去看一下:
" ?3 Z* i4 e7 F2 H3 S' H" J; S6 f4 c( o+ y8 v$ @) r+ E/ L
system_stm32f10x.c
- a  D/ P+ @: S9 s
  1. #if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL). P+ @& ?& R  \7 [. o' [$ q6 e) X. H0 L
  2. /* #define SYSCLK_FREQ_HSE    HSE_VALUE */
    , J1 w/ `5 _# @+ Y- Y, ~  ~
  3. #define SYSCLK_FREQ_24MHz  24000000
    $ _8 {1 L' y* k, S, X- g* C
  4. #else
    # D" t" ]1 p8 I4 G' ~$ k2 z
  5. /* #define SYSCLK_FREQ_HSE    HSE_VALUE */6 z* n6 z4 g  p5 }
  6. /* #define SYSCLK_FREQ_24MHz  24000000 */
    . A4 j3 s' {) C* f
  7. /* #define SYSCLK_FREQ_36MHz  36000000 */- H& M  e( ]/ g; Z: Y/ ~
  8. /* #define SYSCLK_FREQ_48MHz  48000000 */
    , K6 R0 ^/ n- ^: L5 C
  9. /* #define SYSCLK_FREQ_56MHz  56000000 */
    5 y$ N/ j5 z5 }# E# T4 x
  10. #define SYSCLK_FREQ_72MHz  72000000
    1 c1 M. I* o- a* F
  11. #endif
7 G# l! V2 q) H! M# p e6c88e2122454290a9fd2a05c68a6410.png % [1 a* M4 f, M' S4 Q2 u6 E1 G# A
6 ?) l+ ]6 Q4 b* s3 ?
SetSysClock函数通过判断宏定义标志符来判断要调用哪个函数
  d9 T3 {" |8 J4 k4 K+ F! l5 V) D+ O* Z. I# V! F: ^8 s0 N% W
例如,我们在宏定义中定义了SYSCLK_FREQ_72MHz,那么SetSysClock函数就会调用SetSysClockTo72函数
. k" E7 T2 f$ H5 W, w: x. u! K# }8 I3 n: U, `& s2 s
) J$ W& B: B& d  W# P7 p( e5 ~+ {
SetSysClockTo72函数的实现
  1. /**  B! B2 j8 n& N2 ?5 ^, E8 I! A
  2.   * @brief  Sets System clock frequency to 72MHz and configure HCLK, PCLK2 " H* Z2 @$ o; S. k
  3.   *          and PCLK1 prescalers.
    9 z8 v0 [: m% {" X3 h: P) N
  4.   * @note   This function should be used only after reset.
    ! N1 Z! v5 G% u3 y# B
  5.   * @param  None( {. J. c( v( ]% k% k
  6.   * @retval None( F& K5 ]5 m" w
  7.   */: u& C: I7 g6 m
  8. static void SetSysClockTo72(void)
    ( u# F: R- c1 N% c5 K5 @; _
  9. {0 }; w6 x: [8 o
  10.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;1 ?+ O7 m5 V: e0 ]
  11.
    & ^7 W2 K! u" x; h; x4 T3 R4 [
  12.   /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
    * K% N+ W& y7 f0 }% {: \+ _
  13.   /* Enable HSE */
    4 M, \$ \* t+ W' ?; W8 \
  14.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
    . T, \; f8 x. s, t! u$ e  \, g, E% m
  15. + l% c' P7 B5 O3 z! _& d
  16.   /* Wait till HSE is ready and if Time out is reached exit */: j( `) e2 A( v% h& C
  17.   do
    8 ]" n8 M9 S+ H  F# h* M$ A
  18.   {
    ; T# E5 j* e3 L- Q" E
  19.     HSEStatus = RCC->CR & RCC_CR_HSERDY;  \' \6 y: C8 x! j) w
  20.     StartUpCounter++;
    8 {. R  h9 O: `' {! V0 N
  21.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));: j, Q# s, R: e1 v+ N
  22. # e* A+ I  t8 }- D! I
  23.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)' i- ?! L7 F& Z
  24.   {7 s; G6 t, h; s: e# |% `! |- d
  25.     HSEStatus = (uint32_t)0x01;
    : d; W" i% J" x3 x; v  k' l- O$ C
  26.   }
    7 H/ }+ S3 X! v+ |+ I
  27.   else! z8 G! L- G2 u2 i8 T1 b( J0 w/ ^! g
  28.   {
    ! |" J! K. ?9 x: B5 u+ a
  29.     HSEStatus = (uint32_t)0x00;
    - t! L6 x( l3 y
  30.   }
    * J5 j1 x, m# S3 ?2 U
  31. . O! j3 o% T  C" n
  32.   if (HSEStatus == (uint32_t)0x01). x( B( C* ]  x* {- R3 h  {/ b
  33.   {. t% Z7 L/ l* u0 g+ L
  34.     /* Enable Prefetch Buffer */* y0 v9 L4 d. G  F. u
  35.     FLASH->ACR |= FLASH_ACR_PRFTBE;/ M5 w4 Z! b& Y5 r  h' E& k
  36. . c$ K- l* {% g( Z  z5 h6 v$ N' W
  37.     /* Flash 2 wait state */
      W  g) I$ a+ a8 u! _/ B# a
  38.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);" s) P1 O% e5 r& v
  39.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;    3 a3 z. ^; n# o4 {
  40. 7 I5 n  {8 \" t
  41. ; z- n% M. [* u4 j1 @0 t% ~, B
  42.     /* HCLK = SYSCLK */
    , y9 d# d6 g0 ~& K
  43.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;4 ]% o% }" M& e) p4 A
  44.       ' _, ^7 r1 H- q/ `, b5 T
  45.     /* PCLK2 = HCLK */) |2 o  n+ `+ z$ U! E
  46.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    " f8 c6 ?% c# X% M
  47.     6 Q5 T, Y; U% z. q# W" N
  48.     /* PCLK1 = HCLK */. X) A+ r" g$ d
  49.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;$ x# K' g, X9 M2 D* o* i
  50. # v4 \4 P/ T$ r$ j) @0 o2 j1 A+ w
  51. #ifdef STM32F10X_CL
    3 [5 j* m9 q! R: j: A) S
  52.     /* Configure PLLs ------------------------------------------------------*/
    ( _) l8 t5 r6 y
  53.     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz *// ?8 V, Z. L4 `9 k8 g' b; T' X
  54.     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
    / l: N3 h7 B5 v
  55.         # t0 J' o' F6 Y% a- @. U
  56.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
    0 z* D  J$ ^9 K
  57.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
    $ y: M" |  f( Z- M9 k7 F* d
  58.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
    0 v, \" T( @; G) I" {
  59.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
      R3 K8 T4 F  `5 d; R
  60.
    0 m8 Q" k! m# A) G) m
  61.     /* Enable PLL2 */
    : p1 L% L; g& u
  62.     RCC->CR |= RCC_CR_PLL2ON;
    5 w! S3 M' o0 {1 z+ p/ m
  63.     /* Wait till PLL2 is ready *// i7 @3 p8 V' O8 R# h7 O. X' F
  64.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)# T. q- k9 l  ]0 c
  65.     {0 l' s; y1 |4 e$ j  w
  66.     }( B% l5 j9 T' \( t! `' o/ K
  67.     , r. l  j# [* _. ^6 N- R2 x, c
  68.    1 N* ]) M# e$ f& W6 R( o' {9 Z/ N5 w
  69.     /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */ 7 A# z' S0 V' V' @& |5 x9 a
  70.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);* j/ ~2 @  d; J. @( F
  71.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
    ' ]6 F5 u8 {: D0 k# i8 r, E
  72.                             RCC_CFGR_PLLMULL9);
    2 O. N! k$ ?0 H1 s. W) y. o
  73. #else
    ; B5 D1 S. n& [( R) m
  74.     /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */1 ^- m, n" @- Z8 b5 C: P& \+ R7 C% T* x: E
  75.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
    6 k  H- s8 g* {& a
  76.                                         RCC_CFGR_PLLMULL));
    $ l6 a; ?) M+ p) j
  77.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
    " n$ k1 p/ i; Y% @, e/ T2 A
  78. #endif /* STM32F10X_CL */
    ' l! W3 d! e0 w6 Z
  79. 4 `( Z1 a% Q% N0 ~
  80.     /* Enable PLL */
    , x5 J- f, w  p: t3 T1 p
  81.     RCC->CR |= RCC_CR_PLLON;
    6 `- e5 w- r- I' s; R2 L
  82. 2 f; o8 U' F. N9 v! e& j
  83.     /* Wait till PLL is ready */
    7 g6 {9 Q. c# I3 Y8 M/ U  x
  84.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
    . |& k3 A+ K% @, T- |8 u: `
  85.     {0 C; ]  O  ^0 I+ e0 J
  86.     }& ?1 A. l( s1 d. j4 x. L
  87.     6 [0 g8 [; \  P$ w) z
  88.     /* Select PLL as system clock source */
    8 r( `( x% F) T7 M! C
  89.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));& y. {* n% b( I+ w0 m
  90.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    & B& l; }) ~3 w; M& z7 T
  91. / e' r$ [4 `$ r/ V/ r0 C9 E+ [
  92.     /* Wait till PLL is used as system clock source */
    % i1 h$ X8 [0 g4 W
  93.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
    1 Q0 R. I) f! a
  94.     {
    + Q3 u/ P$ H! o* F
  95.     }
    # t/ R. A9 w+ g$ [
  96.   }. N! H+ b) J2 x* Y6 L! p/ }6 [
  97.   else
    & p3 C9 `7 p* _
  98.   { /* If HSE fails to start-up, the application will have wrong clock $ M# R; ^! ]; C0 T% N% R
  99.          configuration. User can add here some code to deal with this error */
    # ?+ F; G; V" c* n& q3 I) R# j
  100.   }
    ' Z+ ?/ e. w3 r# q& e% n
  101. }
, ?6 n6 u: t  @. W/ y0 B9 q4 s
1 f3 G8 N- E0 s! f2 Y- N1 w2 x
* m# @! x& r4 x( }
首先,通过配置CR寄存器打开HSE,即外部高速时钟使能4 a1 a6 c9 ^0 a5 Y
" b. V, H# ?; d1 X# R1 x) [( j- k% A
5 H1 p1 L- W5 j( X: s
  o$ X2 _) w$ ]
7939f1e6003e468289215b7a7a8ad707.png 9 ^. o: z: E3 A1 H4 {0 x
7 j, O5 j: V  R. ~
b98eb7647bd3471cbee5a322a61839a4.png 1 s3 L) x# B/ j0 t. j) O
( `  T* f' \6 X, w 接下来等待HSE的稳定,方法是查看CR寄存器的HSERDY位* g9 O' n6 W/ }8 z. A, s
9 f& f3 y* d% {3 U
) h8 ~- t+ u2 g. U1 n5 w
0 L( V! J2 n& C2 n5 |0 g  T5 ~ abbcce406d434efb919e429e0423a3aa.png 2 K2 z; j2 N. h6 n7 z
- H; O! x2 u/ N 若就绪,则HSEStatus = 1: |! Q7 d" j! `6 q# X1 N( {
接下来,当HSEStatus = 1时执行如下操作" N! c& w4 u/ d9 S2 U. E9 R+ `
  1.   if (HSEStatus == (uint32_t)0x01)$ a% }# }3 r: H& `' `" q: _
  2.   {5 c0 s% M( C4 }0 J
  3.     /* Enable Prefetch Buffer */$ Y% r( U$ p, U8 B# [
  4.     FLASH->ACR |= FLASH_ACR_PRFTBE;
    ( e7 ^% Z* j7 W
  5. 4 M$ L- J8 C& d! i, o/ ]- ?
  6.     /* Flash 2 wait state */
    & h5 P0 Y0 S1 H
  7.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);# J8 \* c& S$ R) L9 u0 [5 p
  8.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;    , T' n  M) f& d8 F. r
  9. 9 y  H# r& n0 L. g
  10. 6 w" u0 b) w  Z& [3 t$ _  B
  11.     /* HCLK = SYSCLK */
    7 y+ o/ C; s) K, [  K/ v
  12.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    6 w" o# o9 ^& h7 l+ L
  13.       $ x- b9 a9 H& h5 k/ A7 w
  14.     /* PCLK2 = HCLK */0 A0 E4 M3 {+ H7 p
  15.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    , v" G5 k4 ?+ l/ z  S
  16.
    % k% O+ e8 D% l8 V
  17.     /* PCLK1 = HCLK */
    3 b5 _; f1 h9 o+ P( k3 h
  18.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
    + T: _2 C: i' u) d1 k, x
  19. 9 K3 h  o5 z3 N
  20. #ifdef STM32F10X_CL
    7 r1 V5 u; k7 S
  21.     /* Configure PLLs ------------------------------------------------------*/
    ( U* N  Y% K- v0 _
  22.     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */6 X* z6 C3 `* {9 ?( `
  23.     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
    , v& _! r8 [2 B7 D
  24.
    * `, b9 m' s% M& k
  25.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |' J  @. o- k+ N& k- j6 _
  26.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
    . }. o* I- v* k0 E
  27.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |5 r! U, o& C# A7 L# m
  28.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
    ! r' M' @3 r5 r7 N
  29.
    ! P1 n3 V6 E6 `, R3 c6 s
  30.     /* Enable PLL2 */
    / M" U" |9 u2 N0 |
  31.     RCC->CR |= RCC_CR_PLL2ON;6 f  D: Q; i/ ^) ]
  32.     /* Wait till PLL2 is ready */
    . X" P; ?3 i% g) T. s) D
  33.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)7 y4 M! i+ O5 d5 t+ ]9 w, e
  34.     {
    9 k: a% I# g3 F
  35.     }
    + ^2 ^. v! P7 {
  36.     , p8 ~0 Y9 b3 O9 ]% ?. r; t
  37.    ; l. O2 |# l6 M3 B  g8 U. r
  38.     /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */ 2 v3 e1 S- i/ U
  39.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);9 I  d4 U" }  ~3 l' d  h6 |+ X
  40.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 | 2 S! ?- T# J& F5 d4 f
  41.                             RCC_CFGR_PLLMULL9);
    7 K% ^" x3 V! l5 y/ k
  42. #else    4 r, j/ k% s- w0 H4 d! D* N
  43.     /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
      n1 E$ _9 T5 \5 _, |: O
  44.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
    + p$ \5 q6 [: v
  45.                                         RCC_CFGR_PLLMULL));
    ; G. O: y6 s* b7 n* T  ^; ~4 ^0 ]' }
  46.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);  O$ e+ |" N) E
  47. #endif /* STM32F10X_CL */
    * a& S6 u$ b4 n5 Q
  48.   }" j1 i% u- M- e" V+ w+ L# M
  49.     /* Enable PLL */$ C( q) U7 |3 ?0 Z9 m, }
  50.     RCC->CR |= RCC_CR_PLLON;
    1 U, }( a2 V$ g' A7 z4 G
  51. % L* \) L- ?4 O* t
  52.     /* Wait till PLL is ready */
    ; h9 M; w5 K8 ^* _4 ]
  53.     while((RCC->CR & RCC_CR_PLLRDY) == 0)  e6 o8 Q5 r4 b. ]3 c
  54.     {  ?9 ^* C0 U0 T5 n" |
  55.     }
    + B  I- s; X9 ]! F/ V' h
  56.
    5 i$ O" h& o" C$ E7 _
  57.     /* Select PLL as system clock source */$ `+ G( }- c* @% c! W
  58.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    5 V5 w) [6 P) `! v" ]7 \
  59.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    & X  J. N" @- @/ u
  60. ; r( a4 U: B, K+ P
  61.     /* Wait till PLL is used as system clock source */# P2 ]# D+ R, m* A& R) t
  62.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
    , h( L; |' l- y1 B! \' X& e- `7 o7 C
  63.     {( n2 W- r$ d# i) g. ^% b4 w* O
  64.     }
    # `7 A/ n$ U: ?2 _
  65.   }
    ' Q& Y8 F+ b8 Z) d( S
  66.   else
    1 o* Q0 q  ]5 ?( E
  67.   { /* If HSE fails to start-up, the application will have wrong clock
    $ I& [. A+ _, B1 o
  68.          configuration. User can add here some code to deal with this error */" M& e8 i5 G( n/ u! M  c
  69.   }
- o0 A6 P3 K. b% c9 a
由CPU的速度是远远快于FLASH的速度的,因此需要对FLASH控制器进行配置
: b# [3 Y/ ^! Z. k0 l& P( M" x( U! i5 F- W$ i
; o4 n: ^  j8 A! B; n  Y; @. F" b3 M$ N$ h' s$ k0 v2 T
通过CFGR寄存器设置AHB Prescale 设为1,泽恩HCLK就等于SYSCLK
  J3 o6 `4 x! p+ c( c/ |
# z5 p2 m9 E& l6 @3 c6 X- V! m
22843ba4c8e14c819ec8d98bf7b4fd73.png 8 F( L( b' {7 Z6 V* `5 L3 g& o5 D
' F3 q5 a8 g: K, F
1175c083c0374cc6b113316734d67417.png 1 D# S& x/ |) s$ k; j
8 T) V8 t3 z' s# }& y
& w! Q( v5 _" Y; M% w% `7 k6 d % Y" r8 G0 A/ o, @* u( ^- J
7f8a3be7a71342e8a1ae92fb02ff5334.png % m. r: o& P' F: K# H* j* B
  x" ^, y0 s/ ~
% M1 X6 r( |; ~* _8 P
+ F0 d7 ]  }; i; ]( y
* z5 @9 o& t( |  M$ M7 V2 R* m* r1 \9 o  W* E
24331fedc033422aa2b1b3ad2e64419e.png % O# ^2 G& Z9 P- Z+ g* S9 k: ?
( ]4 G7 M- J/ |% l5 S
+ ]' H, F$ G# Q0 H; c% l/ I
本质上是将APB2的Prescale设置为1; C7 u4 p( |, Z/ i2 e
/ u$ t  s3 B; g5 ]$ q. b. ?
, ~$ T( v4 c6 A8 M
: X- q  N3 T9 G% q7 I
( d+ M# P1 w8 Y  `% |2 Y9 u  N, I, c2 m: j0 b2 e* _
8 o( Z+ m6 \( j. d3 ^& k7 l2 f$ I
3 b/ C( w5 B) c8 D* u 6b711a96f798468c9564b645e6d5a3e2.png
$ B% |1 p! T5 x8 C; T9 y% _
, B9 K& ^8 L1 \0 |* ]8 @* }
经过以上配置:
, U7 y; m: i& `' j9 Z$ k) T0 GHCLK = SYSCLK; I! \% F; y4 v5 q6 @. Y3 {
PCLK2  = SYSCLK, J  I9 a$ Y' y. {& t, `; R( y
PCLK1 = SYSCLK
& x$ J" X# L% m+ L3 t* x- D/ q! ~3 W3 M2 S% _
8 P! r- j# y  k2 d 4d76f244c7304777a5e924a7ef0ba986.png , n# {4 W8 m$ `9 v: g3 }# v
' s) a0 q& b+ Z; I) a8 y4 _
此处条件编译) r4 P3 T9 A" f3 Z4 _* [8 j$ T: u
8 Y* x8 B& `+ l8 r" L( t/ ]
执行的是这段/ }! R" t7 V* y& [
- N. t4 U" b" ~. b4 r+ F) Z
5 \5 A0 H8 g9 @
5 B, H' x: h4 }2 U" I
  1. CC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    * n* o! i! e$ E7 }% e+ P
  2.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLMULL6);
- n- G- O* K4 E# K/ y, o" D
将HSE作为时钟源,倍频系数为9,即将HSE直接作为时钟源,倍频9后的PLLCLK作为系统时钟,后面的预分频都是72 MHz
2 c6 J/ e. e6 x
7 E$ b! f4 a! }( X
4c4e538a4eda4470bca3f30158cfce5a.png : x  G3 Y' x! Y7 O: O3 A7 l1 G0 G" h
0 T6 H, }2 _1 @* r7 J
84c504ec27bf4f539652567e9ddefa77.png 1 F% i7 k1 W9 U; b, c
/ p& H' t  ~' ]+ _6 `2 c
4 G+ T. A2 M0 O* X% q+ L6 W0 r  K' j* r
6c424b43db464bbc9e6fcf568d5d3409.png + [( O" w/ J( h  A$ T
% ?# m. C* ^! u6 V) ]# _  E 等待PLL就绪
6 D( ]: n2 {# F7 E3 I
1 d/ y4 C) t; }5 ~+ E
( a' `* R* s, J6 T/ R' v8 ` 1 J, t+ V# j/ H% M1 z0 B/ s9 Y9 P
b7ffbf05369a4f3a8d3a43b257822054.png   J9 m6 E" _8 F1 Z) p( h
% g. M' Q' x, vPLL作为系统时钟,并等待其稳定
4 ^0 a! S  M+ ~6 P* a9 b
  e3 Z/ }( M0 J/ J3 F; j
8 C# E" o& O9 R$ u5 _1 c+ G# u# r' {2 [! ]
调用SystemInit函数的地方. B, C5 J. d, A. ^: s- q$ Q
6 u- R: n* i6 _) C$ ?  Z& X1 ^
3 s9 N1 T2 o1 K! E
3 v4 g! ~# Q( R" T% Z: qstartup_stm32f10x_hd.s
# g3 K3 T; t. L! }这里定义先执行SystemInit函数,再执行main函数
" ~9 I( d5 v2 R0 @6 a2 S% G* E  U& N/ f9 w9 p
4614dab15bf8423c824d4377246ac5a7.png + k* H0 h. c9 g5 `
" ?+ n7 w' P. y, d0 C8 E( Y9 }————————————————# V& v4 b% T# x% j
版权声明:CodeForCoffee7 [! I1 K4 V2 P; `  B* ^
9 i- B, B( m' f4 i% T! L1 A& I
% n# Q' W; }4 B, {$ O  d  r! H- y/ k" X$ [" [+ |' q& g
( ?- j' D% R0 Z2 n+ j$ A
4 I2 ?! \: A# A0 B
赞 收藏 评论0 发布时间:2022-12-26 16:00
