本文通过一个小的设计来进行讲解,将STM32内部存储的一个数组中的数据,通过DMA操作复制到第二个数组里,并用USART1串口将第二个数组中的数据输出到电脑端,进行检查,看是否复制成功。! g, M m& _/ b
* g1 J; K) C+ V) l: B3 }7 g首先总结全文,,使用STM32进行DMA操作的主要过程如下:! u$ m C; m, b- F
1,初始化GPIO
! U2 k& s, I' Z$ U# S, O2,初始化串口: c+ e" R1 U- L6 i& z
3,初始化DMA
6 a3 [9 a' o! ?4,编写主函数; X1 N3 p# X& B8 ?7 V
) E# Y5 _' a _7 S1 B f
下面介绍详细步骤:1 ?- f: u. Y# f, B9 W: e! Q
( a- D+ d$ p: L5 W1,初始化GPIO
) E5 ^. L7 U7 w& X, _% p0 {' x- void IO_Init()) d/ b5 f$ o, y9 |+ V7 W
- {' H8 I& N( |, ]( W5 U
- GPIO_InitTypeDef Uart_A; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
4 A6 \, U% J8 z) B3 A" u0 k# E - Uart_A.GPIO_Pin = GPIO_Pin_9;
; ]6 W3 p5 |. I; L$ u - Uart_A.GPIO_Speed = GPIO_Speed_50MHz;
& R9 m5 \ {4 q3 N - Uart_A.GPIO_Mode = GPIO_Mode_AF_PP;$ j$ |4 E4 n9 Y% N! q7 h6 X9 {$ u
- GPIO_Init(GPIOA,&Uart_A);
! P. Q. X& u0 D3 R" k7 @$ H& x - 7 H- i" E' O! d& [+ l/ z
- Uart_A.GPIO_Pin = GPIO_Pin_10;
: G9 x2 A) R3 u; } - Uart_A.GPIO_Speed = GPIO_Speed_50MHz;$ E' S5 F, f& n0 V6 e8 W
- Uart_A.GPIO_Mode = GPIO_Mode_IN_FLOATING; //page 1108 M/ \- G7 X2 R
9 S A$ Q; A3 Q3 o) k7 M& L0 B: H -
2 J* F5 t% \, q+ z0 f2 B - }
, `, H9 J5 `: ?& j" ^9 A O: g2,初始化USART1
; `) U$ ?9 f7 @/ i. g- void Usart1_Init()
2 F' O- A9 }* D; y0 f - {
9 w6 P$ R! t; C. x& F$ m7 S9 g& _% m; T - USART_InitTypeDef Uart;# y) [8 @2 R1 i5 ]/ J
& k7 k; S- k6 S ]' f - RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);1 F5 r: o$ ^ h- S$ y
- Uart.USART_BaudRate = 115200;
0 p3 U; f5 S; A1 v - Uart.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
" ~3 Y+ N8 Y- B. n4 _8 s" @7 u8 j - Uart.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;0 X; n3 o8 l, ^/ A4 M3 ^' {* W6 `
- Uart.USART_Parity = USART_Parity_No;' N2 |1 q% t/ J. z. L
- Uart.USART_StopBits = USART_StopBits_1;
: v' l0 }: d3 _" R% ^. y( w6 t5 d - Uart.USART_WordLength = USART_WordLength_8b;
4 P% o3 p& ]5 L4 q. T - USART_Init(USART1,&Uart);, d4 L5 X- g- L
- 9 P! x. @/ q& G7 N
- USART_Cmd(USART1,ENABLE);
( b: n9 d2 I" B! i/ F- M% p - USART_ClearFlag(USART1,USART_FLAG_TC); //page 5403 A" | P: p& a
复制代码 2 u$ g) A( E: m$ g E
! ~8 r# I2 V: n) G& ~$ t* T
3,初始化DMA# W9 R0 Q$ Y; H
库函数中DMA的结构体如下:. }3 O0 k2 e! P) O6 L
- typedef struct% y/ m3 O, n$ R9 B( N/ @4 O9 f$ M
* \( ]9 t# ]& H9 z - uint32_t DMA_PeripheralBaseAddr; /*!< Specifies the peripheral base address for DMAy Channelx. */& O; Q2 @" o* L; n2 R
- ) Y- `5 Y3 i6 b0 K, G( {
- uint32_t DMA_MemoryBaseAddr; /*!< Specifies the memory base address for DMAy Channelx. */
5 o4 V$ v" }# a& j5 V% j - 6 z8 B" a; b* G& a
- uint32_t DMA_DIR; /*!< Specifies if the peripheral is the source or destination.4 e1 m$ e: L! _, d- L0 y% ]9 ?) I/ O
- This parameter can be a value of @ref DMA_data_transfer_direction */
- D8 V6 @' y" @ - 7 v+ g1 i. n0 M* V# ], M3 y) Y. y
- uint32_t DMA_BufferSize; /*!< Specifies the buffer size, in data unit, of the specified Channel.
$ k: @* ~$ t) M ] - The data unit is equal to the configuration set in DMA_PeripheralDataSize
6 i. G! {! x2 X5 `( X* G2 G, F& G - or DMA_MemoryDataSize members depending in the transfer direction. */
+ M* V \. o G; I3 f) S -
4 b2 e2 y" k6 Y) e, b( I* @# s) | - uint32_t DMA_PeripheralInc; /*!< Specifies whether the Peripheral address register is incremented or not.
1 U% O! B5 n, O; u; ^5 E - This parameter can be a value of @ref DMA_peripheral_incremented_mode */
m. X: Q, \" s8 t - ; a. ~) y6 D% q4 Z2 t1 v" H4 I1 m
- uint32_t DMA_MemoryInc; /*!< Specifies whether the memory address register is incremented or not.5 S9 j; d5 @% ~% `; l5 s! D' @ N
- This parameter can be a value of @ref DMA_memory_incremented_mode *// {2 ]2 u, U& K8 h/ k1 |; Y
- 9 x5 d4 x l( F2 i5 z8 m! ^* ~
- uint32_t DMA_PeripheralDataSize; /*!< Specifies the Peripheral data width.
+ q3 W5 I/ L9 v/ N9 Z" d2 Y5 ] - This parameter can be a value of @ref DMA_peripheral_data_size */' J: b2 t w7 ?
9 S+ }) g3 f: N- m - uint32_t DMA_MemoryDataSize; /*!< Specifies the Memory data width.
9 k' u' ^' J7 ?; |6 L - This parameter can be a value of @ref DMA_memory_data_size */
$ {0 X8 {4 f. o( C/ o5 n - ; f C5 j% i" o: O C
- uint32_t DMA_Mode; /*!< Specifies the operation mode of the DMAy Channelx.) _ W3 _3 Z! {% z0 |
- This parameter can be a value of @ref DMA_circular_normal_mode.( R# J/ _! j" \% [7 L' w+ l, _
- @note: The circular buffer mode cannot be used if the memory-to-memory) H" ^1 j' B! p2 a
- data transfer is configured on the selected Channel */' D& a9 b+ p3 x: S1 M8 o2 q7 r
- : o, z2 L" z$ v+ F3 |, C1 f* {; P1 h
- uint32_t DMA_Priority; /*!< Specifies the software priority for the DMAy Channelx.
& _- s5 L$ E" g - This parameter can be a value of @ref DMA_priority_level */
8 s4 A) b- ^# F' f5 s - & L* c) V" B1 [ i* e; }: q
- uint32_t DMA_M2M; /*!< Specifies if the DMAy Channelx will be used in memory-to-memory transfer.( ^8 Q: X; Y) X8 F. J
- This parameter can be a value of @ref DMA_memory_to_memory */
4 v9 n$ [7 W& [ _ - }DMA_InitTypeDef;
复制代码 ) p) ~, H# r; R3 ~! c
这个是定义DMA的传输方向,DMA传输总共有三个方向,外设到内存,内存到外设,内存到内存(关于外设和内存可以这样简单理解,相当于一条路的两头)
# @2 y& t5 n! l8 X& w
! B/ X8 K4 _, J库函数中有两个定义:
0 | N/ P# A5 u4 u- #define DMA_DIR_PeripheralDST ((uint32_t)0x00000010)
* T, w+ p3 {2 @" _% k - #define DMA_DIR_PeripheralSRC ((uint32_t)0x00000000)
复制代码 8 M* D0 S5 Q% V
以DST结尾的那个,表示,以外设为目的地,以SRC结尾的那个,表示,以外设为起始点。; E, k& X- p0 e3 G6 N
uint32_t DMA_PeripheralBaseAddr;这个是用来定义外设地址的4 I2 V% E; ~7 t7 F
uint32_t DMA_MemoryBaseAddr;这个是用来定义内存地址的$ i3 }' i" D/ f8 U/ ?
uint32_t DMA_BufferSize;这个是指DMA通道的DMA 缓存的大小,这是为了照顾,两边的速率不一致。
. |% Q) A# D, s/ M* x7 z2 U* Tuint32_t DMA_PeripheralInc;这个是用来定义外设地址是否要自增
6 f' D/ F; K! f% Duint32_t DMA_MemoryInc; 这个是用来定义内存地址是否要自增
) Z ]2 u1 \) s2 k5 R! juint32_t DMA_PeripheralDataSize;用来制定外设的数据宽度
, Z$ l# B& N1 T4 ?' f0 Z; N8 l5 _uint32_t DMA_MemoryDataSize;
- E( |2 }' \" d; U! U, C# B+ m' H0 T" ~
这个是用来制定内存的数据宽度,当外设和存储器之间传数据时,两边的数据宽度应该设置为一样大小' r9 [4 Y( r! I3 C' \' j( @
0 t9 A2 o4 y* H: G* n/ nuint32_t DMA_Mode;
( e* w; X! V* P* S
& y0 S" X! a. J) c% e这个是用来指定DMA的工作模式,有一次传输和循环传输模式,两种。
% }) p: A9 M( G7 m$ z$ i3 L3 _6 M) _& B1 T3 k$ }2 X
uint32_t DMA_Priority;9 q2 }. i* \+ A
+ W% |. ~% T( @- G4 p1 @这个是用来指定DMA的优先级,有非常高,高,中,低四种。3 [. }" D: z& Z
8 q' a1 I1 M+ X Z, `" V
uint32_t DMA_M2M; 这个是用来设置是否进行 内存到内存传输
9 }# C' U( C- R. g4 `( j3 T9 d$ c& f7 @4 U5 |% @# j
初始化函数如下:* ?, u; v8 r" a4 j7 F6 d" X0 G: a
- void Dma_Init()
' ]# E7 {7 m4 D$ x4 c @ - {4 U1 _. V, {, M6 B2 `
- DMA_InitTypeDef dma;
- p7 Y% S# c! Y- E% ~: D! h - RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);//老规矩,先开心脏
4 I. \$ J2 w* G) m2 D7 j( Y/ [+ i( O S - dma.DMA_MemoryBaseAddr = (u32)zimu;内存地址5 }+ J' P* x: R4 M& ]
- dma.DMA_PeripheralBaseAddr = (u32)zimu_1;外设地址
, l3 o/ O! ~7 i - dma.DMA_DIR = DMA_DIR_PeripheralDST;外设为目的地,即zimu_1数组为目的地9 J- H9 o/ Y0 C9 z
3 c! a ^# [* P/ M. \/ x, Q* W - dma.DMA_BufferSize = 26;缓冲区大小 G* w/ `2 f4 n" L, H, w( i# S
- dma.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte;数据宽度
. u$ z6 G7 R* p# ` - dma.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;同上/ y" r1 A8 N% w6 I/ b; a0 p
- ( W4 m4 z* r9 l4 E' Z" m
- dma.DMA_MemoryInc = DMA_MemoryInc_Enabl;内存地址自增+ I$ _. @: ^( ~. M" J
- dma.DMA_PeripheralInc = DMA_PeripheralInc_Enable;外设地址自增
& n. `0 W# E& J& G -
) Q0 o; t* U6 Q! b. ]& N# P& H6 i - dma.DMA_Mode = DMA_Mode_Normal;单次模式5 \0 ~7 ?7 K9 A
- dma.DMA_Priority = DMA_Priority_High;优先级为高- Q }, G& K1 D4 o7 p
- dma.DMA_M2M = DMA_M2M_Enable;设置为内存到内存传输
4 {! f1 h% P3 x -
8 e: ^, Q# Z$ J3 C8 @+ k! A5 T6 Q - DMA_Init(DMA1_Channel6,&dma);寄存器初始化3 E6 X3 r ?5 h: |3 m. S5 g
- DMA_Cmd(DMA1_Channel6,ENABLE);DMA使能
}4 O4 k' y, i# k: X, c - }
. f N! }' P# U1 P2 Z- I7 a3 C4,编写主函数
8 w9 A* D3 N j$ ?- int main()8 n0 F$ M! Z9 L* c: `
3 C: u* ?5 g5 C/ ?1 Y* _; \' H - void printf_string(char* a);' f' T9 l* L0 G5 S, ^* B0 R0 Z
- IO_Init();GPIO初始化+ W! P g {. x+ N& B4 D
- Usart1_Init();USART1初始化
" W( V0 V U' J* | - Dma_Init();DMA初始化( k5 X% l, S' W! G! ?9 o& ?! g- o
- while(DMA_GetFlagStatus(DMA1_FLAG_TC6) == RESET){}//等待DMA操作完成,在参考手册的149页可以仔细看这个寄存器3 ~6 ~3 h% r; S( {1 L( @8 C5 K
+ b0 I7 _; `0 O- v3 g4 M - while(1){, b4 B, v8 u' O. I4 T* O8 x3 l
- if(USART_GetFlagStatus(USART1,USART_FLAG_TXE))判断是否能用串口输出
& ]! M- o" b0 r# ^& ] - {8 v% b0 s8 }& h
- printf_string(zimu_1);输出zimu_1数组
b1 e% u+ b; q% j8 L3 b7 U - delay(3000);延时7 r1 w' U4 J* |' O- O5 i- z
2 r( E' Q$ K8 y1 y - }
8 k! E5 o$ e3 F1 G0 ?0 Q( Q) { - }3 i8 \0 ~# e* [4 M& T
- void printf_string(char* a)3 d& H6 y' N& Y) D) y7 h
- {+ [( @0 {% \! w7 L8 \% {5 F8 {
- while(*a != '\0')直到数组末尾! t+ n4 j7 `% m! w
- m8 }1 \2 U; c% h: v& K t3 h - USART1->DR = *a;赋值给USART的数据寄存器 B; D# ]! n& \# g7 S$ G
- while(!USART_GetFlagStatus(USART1,USART_FLAG_TC));等待发送成功
_4 t* f! H$ r. H: G) z' r6 R: A# m - a++;地址加一
' Y6 Z7 b5 \3 a. B* ` - }
! o- e3 H- Z$ q) N* ~ - }
~& [- c0 i3 X. v9 h0 X/ Y4 g* l2 E5 c l& S2 ^$ Q! O V4 i0 E) M
本文到此结束,因博主水平有限,如有错误,敬请指出,不胜感激!
6 r& o0 `* v" N/ A3 j$ ]& _( T8 z! ?2 A+ {8 D! A7 @- I
3 ], f1 h: L* Y) p9 k3 a5 }亲测,可运行。详细代码如下:) n2 a' |1 a$ F+ e. x6 l+ e( q
- #include<stm32f10x.h>- {' F$ v0 }2 J: z# ]+ C" b; f
- #define uint unsigned int
; e% T" h% ` i+ {$ Z - #define uchar unsigned char+ J+ p( S6 q- ~% u6 ]- c4 c: N
j7 f: I* [4 y. |! T - char zimu[]={'a','b','c','d','e','f','g','h','i','j','k','l','m','n','o','p','q','r','s','t','u','v','w','x','y','z'};
: ^( I2 C: w2 [! u% q( ~& u. J - char zimu_1[32]={'.'};! ?5 h" C2 k% w' P8 e: N _8 c
- void delay(uint n)
" c; w* m' q$ |* s3 g - {
! n8 E' t; B$ Z+ J, a2 |/ l/ p& Z - int i,j;
) {' Y% u$ E7 h+ w/ v/ w - for(i=0;i<n;i++)
* v& D; ?- K* b - for(j=0;j<8500;j++);
5 i7 J. ?+ l: i5 W! e) i) U - }
0 _1 C, ]3 W# y - 5 |' V3 J" \$ j3 ? w8 `. M
- void IO_Init()/ C. M( c$ o9 b! I9 \6 F2 s/ H
- {; P1 r# S2 \% o6 P, z5 X- Z
- GPIO_InitTypeDef Uart_A;7 k: H9 M! A% W1 ? U6 c
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);$ X5 ?9 F% R5 i# r. q; X! ^% n; G
$ A- }2 x8 ~! v+ r - Uart_A.GPIO_Pin = GPIO_Pin_9;4 c3 A- V& J+ M6 L d& Y2 z4 O
- Uart_A.GPIO_Speed = GPIO_Speed_50MHz;9 \" e1 d/ ]: G: n2 K
- Uart_A.GPIO_Mode = GPIO_Mode_AF_PP;/ I% S7 c: a- o/ W- D
+ U$ P+ J4 Y/ E- y2 b( | -
9 A: v; h3 F5 X: d - Uart_A.GPIO_Pin = GPIO_Pin_10;6 q3 |5 a! n( W z; S N: ~9 j# t/ o
- Uart_A.GPIO_Speed = GPIO_Speed_50MHz;/ l# b9 V2 V. K( H6 f/ n( K; C
5 D& e; _; h8 Z1 V/ `$ h - GPIO_Init(GPIOA,&Uart_A);1 l! v! a/ {7 s$ t, _1 e
! I0 r! N* j# m- n' p2 I - }
8 U4 R: h+ {, d- ], _* {) M4 J - void Usart1_Init()$ O0 T6 g2 Z& ?& W t8 |! b' I- I
- {" i0 w2 ]0 m# n; F
; f5 |, w; L; a/ a2 y3 U -
" |! f0 d( x$ `" t+ X - RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
L" D! I9 @& l: I$ z ] - Uart.USART_BaudRate = 115200;
! M- R* p2 k* l! Q; r. b9 j1 b - Uart.USART_HardwareFlowControl = USART_HardwareFlowControl_None;# e! S+ O' _' p( E/ _
- Uart.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;8 B8 B+ t- g( W, \" f
- Uart.USART_Parity = USART_Parity_No;! l2 A# P4 I8 w) ]
- Uart.USART_StopBits = USART_StopBits_1;( M ]& f8 W2 b: d% N5 d0 J9 `( r0 `
- Uart.USART_WordLength = USART_WordLength_8b;* J/ @8 S. N( b7 H% I; q9 r6 s8 L
- USART_Init(USART1,&Uart);" k6 r3 L! d3 W5 K
+ T: i ^' m" r! v - USART_Cmd(USART1,ENABLE);3 E% J( G @- U# o8 N; n& ]
- USART_ClearFlag(USART1,USART_FLAG_TC); //page 540 U+ K& I# H! Q: M/ x1 R3 Y/ W9 {
2 B2 I( _# R7 t; f) v1 D1 |3 L -
: t: m' O( ~# L! u6 O9 s8 f5 Y - void Dma_Init()1 E9 O: V k: T+ D v6 O& D! `5 H
% f9 [; f# ^* H' U) u - DMA_InitTypeDef dma;0 x. v' N ?: R
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);9 u" D' Y2 q6 w# g' f
- dma.DMA_MemoryBaseAddr = (u32)zimu;1 B. X' I' }; D1 |3 U2 R3 Y. E- n
9 V5 j, D# ?4 b/ Z& w6 | - dma.DMA_DIR = DMA_DIR_PeripheralDST;
. A4 P- {6 P6 W! J$ F( t- B' e% b: | -
7 z: Y* ~: V0 X* b# O# x$ m/ w - dma.DMA_BufferSize = 26;5 f; ]* ?/ m. R8 R$ n# j& N- B
: s. E8 C& { x; L/ g$ O3 c - dma.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;7 Q" @4 f ^7 u/ W
- ) r8 b* t$ O2 {4 Y% C
- dma.DMA_MemoryInc = DMA_MemoryInc_Enable;
9 @" e* e" [1 A3 N* l; _; ~4 w - dma.DMA_PeripheralInc = DMA_PeripheralInc_Enable;
4 F0 O+ I- I" v+ M -
0 v' p" Y; L) Y. Z$ L* [2 ] - dma.DMA_Mode = DMA_Mode_Normal;
$ @0 y* h% t4 h/ ]5 p3 Z. I - dma.DMA_Priority = DMA_Priority_High;* h" }' \/ x3 p v% I- f% n8 ^) _
- dma.DMA_M2M = DMA_M2M_Enable;/ V, J1 ]2 B% n9 \2 k) c
- ! s7 ?6 U4 d; }
- DMA_Init(DMA1_Channel6,&dma);( Q2 k' e" L" M, H
- DMA_Cmd(DMA1_Channel6,ENABLE);& d) i: i4 r' R1 F; A4 w
- }1 ?, b; x8 K, ^3 Z8 o: Z
- int main()1 ]3 H/ H# n: K! _" z' d
: O& v% z" J7 D8 k5 M8 T+ j - void printf_string(char* a);
5 K N. H/ t' I6 Q( o- |4 U - IO_Init();, L9 o( @5 H( V3 Y7 U" j5 |2 W
- Usart1_Init();
. P+ R' N, R" ~6 r* v - Dma_Init();+ Z( B X5 o/ K1 j
- % t( O% W: ^! n2 y0 a( h
- GPIOC->BSRR = GPIO_Pin_13;
! `5 E" R' Z7 n+ M1 L -
+ h) B" G7 `7 N - while(DMA_GetFlagStatus(DMA1_FLAG_TC6) == RESET){}
9 I( v" j" B6 B -
1 N, |' M& t. g9 V1 f C+ l - while(1){
) A, n9 u( s4 w- f - if(USART_GetFlagStatus(USART1,USART_FLAG_TXE))8 G- C6 R3 V/ R
4 b# v1 b4 w+ ~3 a: [ - printf_string(zimu_1);
( k0 k; ]/ t {( w2 ~ - delay(3000);
q! R+ y; G$ ^- ]. H- u# y5 i - }
+ U( m# e) {! n' m% H) R - }: U' n* q- I% N t9 Z2 H
- }! @+ t- D1 K7 d
- void printf_string(char* a)4 ~3 L, H1 a/ x" S% c- E3 B
0 u/ F ?# P8 w- Z% v- c - //USART1->CR1 &= ~USART_CR1_TXEIE;6 S' i3 P ^8 X5 E4 O0 \7 D- i
- USART1->CR1 |= USART_CR1_TXEIE;) M- X8 @& Z" v7 y
- while(*a != '\0')
5 @4 V7 C, _8 J* ^8 t+ `# o - {
) j8 {( V) \' i# j' t { - USART1->DR = *a;
8 B! W- @; Q* K7 q! q - while(!USART_GetFlagStatus(USART1,USART_FLAG_TC));8 G( K( X8 w* J3 X
- a++;
4 P) e, v+ V+ }4 ?) A1 y# g2 z - }
' I, b" a, m8 b' t - }
+ a* ^5 ^$ c1 b) l, `, |————————————————+ U* C$ ?7 N+ Q
版权声明:家安
1 A9 _$ ?8 M9 n! T9 x, h
8 G2 _: \ \& u: i# k3 y& r, t
8 p7 p4 H+ O9 C8 Y& m) \6 e |
