Adc初始化后用HAL_ADCEx_Calibration_Start函数进行校准,一直返回失败,为什么?
Sancia 提问时间:2023-3-29 23:07 / 未解决
使用的板子为NUCLEO-U575ZI-Q。
下面是初始化的代,请各位大佬解惑,困惑很久。
ADC_HandleTypeDef hadc1;
void HAL_ADC_MspInit(ADC_HandleTypeDef *hadc)
    GPIO_InitTypeDef GPIO_InitStruct = {0};
    RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
    if (hadc->Instance == ADC1)
        PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADCDAC;
        PeriphClkInit.AdcDacClockSelection = RCC_ADCDACCLKSOURCE_HSI;
        if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
            // Error_Handler();
        /* Peripheral clock enable */
        __HAL_RCC_ADC12_CLK_ENABLE();
        __HAL_RCC_GPIOA_CLK_ENABLE();
        /**ADC1 GPIO Configuration
        PA4     ------> ADC1_IN9
        GPIO_InitStruct.Pin = GPIO_PIN_4;
        GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
        GPIO_InitStruct.Pull = GPIO_NOPULL;
        HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
static void MX_ADC1_Init(void)
    ADC_ChannelConfTypeDef sConfig = {0};
    hadc1.Instance = ADC1;
    hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV8;
    hadc1.Init.Resolution = ADC_RESOLUTION_12B;
    hadc1.Init.GainCompensation = 0;
    hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
    hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
    hadc1.Init.LowPowerAutoWait = DISABLE;
    hadc1.Init.ContinuousConvMode = DISABLE;
    hadc1.Init.NbrOfConversion = 1;
    hadc1.Init.DiscontinuousConvMode = DISABLE;
    hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
    hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
    hadc1.Init.DMAContinuousRequests = DISABLE;
    hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
    hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
    hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
    hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
    hadc1.Init.OversamplingMode = DISABLE;
    if (HAL_ADC_Init(&hadc1) != HAL_OK)
        Error_Handler();
    sConfig.Channel = ADC_CHANNEL_9;
    sConfig.Rank = ADC_REGULAR_RANK_1;
    sConfig.SamplingTime = ADC_SAMPLETIME_391CYCLES_5;
    sConfig.SingleDiff = ADC_SINGLE_ENDED;
    sConfig.OffsetNumber = ADC_OFFSET_NONE;
    sConfig.Offset = 0;
    if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
        Error_Handler();
    if (HAL_ADCEx_Calibration_Start(&hadc1, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED) != HAL_OK)
        Error_Handler();
赞 收藏 评论2 发布时间:2023-3-29 23:07
xmshao 回答时间:2023-3-30 09:47:37
校准返回错误跟你ADC配置没多少关系,重点检查下你的硬件,尤其电源 vdd,vdda,以及电源特殊脚
比如VCAP,PDR_ON这些,具体参考芯片管脚布局,ADC外设的时钟。
另外,校准要放在启动ADC之前操作。
wangjinglu 回答时间:2023-12-15 10:50:08
我也遇到这个问题了请问你最后怎么解决的
