为了呈现 STM32H563ZI 接近MPU的性能,本次测试使用freeRTOS系统进行PWM和GPIO的测试。首先,需要安装STM32Cube的STM32H5的freeRTOS系统模块,新建项目时选择“ACCESS TO EXAMPLE SELECTOR”项目,选择开发板NUCLEO-H563ZI,选择FreeRTOS_Semaphore_LowPower项目。项目默认打开了PWR管理,还有三个LED外设。我们的评测是使用一个低功耗定时器 LPTIM4 作为信号源来控制 GPIO 的输出。- /* USER CODE BEGIN Header */
9 h) U2 e; J3 { ^ - /**; [% `! Q2 A5 g6 A& o1 D1 n! ^
- ******************************************************************************* C, t5 o# t$ r0 e& R, j
- * File Name : app_freertos.c
+ r; U. }/ l# s" N - * Description : Code for freertos applications
' `4 i. k9 `8 K - ******************************************************************************
3 w* \: Q$ _: s: D( }9 { - * @attention *7 ?+ N# {8 Q8 b- A! L
- * Copyright (c) 2023 STMicroelectronics.
' l# P$ C4 L+ L6 P9 x. W - * All rights reserved.
[6 T5 P5 y" r - *! e0 L0 S0 x& N" e9 y/ p9 I
- * This software is licensed under terms that can be found in the LICENSE file1 R* T5 J+ S: s% A
- * in the root directory of this software component.% R1 I: {# D9 w8 f4 H3 r
- * If no LICENSE file comes with this software, it is provided AS-IS.
6 s9 k. y7 Q6 y, Z/ ~% q7 g( X/ E1 ? - *
4 w3 I9 }& e/ i - ******************************************************************************
% \2 [. Z; r/ b# j0 v - */, I; [ d! e3 x( K0 q+ G% b
- /* USER CODE END Header */
( W( o; C* v. Z) j7 G+ E1 o6 G) j - /* Includes ------------------------------------------------------------------*/
3 B6 H& k7 {0 C: b0 t+ v5 r - #include "FreeRTOS.h"
$ C* ~7 v! o3 P$ }3 a# c ? - #include "task.h"
6 Z. S2 K7 j1 H% M9 k - #include "main.h"5 m# u" w& g$ l+ ~0 L* |3 N4 e
- #include "cmsis_os2.h"
* f' c/ q+ @: X4 {3 I - /* Private includes ----------------------------------------------------------*/
4 ~9 ?" {0 n- h# ^. G% I - /* USER CODE BEGIN Includes */. p9 k- n+ e% S0 b& |/ A
- /* USER CODE END Includes */$ \5 R4 a* l0 {; L; U/ |
- /* Private typedef -----------------------------------------------------------*/6 v. _- }$ d; ?* I
- /* USER CODE BEGIN PTD */# L& O9 y- R8 M. F- H) N; H
- /* USER CODE END PTD */, q8 {2 n. ^9 e5 I
- /* Private define ------------------------------------------------------------*/( \$ k0 I+ h) L, g- p
- /* USER CODE BEGIN PD */
. p+ W& g% k, g" C% [: B9 z2 I - #define DEFAULT_TIMEOUT (1000)' e7 ?" y: ` w1 T6 ]0 q
- /* USER CODE END PD */
& Q2 }4 r% [! [, B8 O; U5 @" [ - /* Private macro -------------------------------------------------------------*/
( z7 ]! J. b" ], |# L" g1 S - /* USER CODE BEGIN PM */, m; r Y F2 f
- /* USER CODE END PM */3 x& y$ u1 V8 U- u
- /* Private variables ---------------------------------------------------------*/
/ n) v, E5 S' j9 a0 r3 s) ~ - /* USER CODE BEGIN Variables */
0 `$ S$ _9 }# u4 `4 B- A9 x7 m - extern LPTIM_HandleTypeDef hlptim4;
( z& c) m3 G- Z* E- o7 ~/ Y& l - /* USER CODE END Variables */5 E, [0 V3 V& B) J' [
- /* Definitions for MainThread */; w4 k( a3 K; t& _/ i
- osThreadId_t MainThreadHandle;, k7 T/ u, B5 C/ l1 N* J" D1 ^' R
- const osThreadAttr_t MainThread_attributes = {
. Q9 ^- R2 f. D& b$ r - .name = "MainThread",2 m. f7 v1 @9 a4 x
- .priority = (osPriority_t) osPriorityNormal,, a; C; t( L2 N% e) U
- .stack_size = 256 * 4
' }6 N9 a1 R# O, | - };% v N' G; S1 j) d8 s5 n3 r
- /* Definitions for BinarySemaphore */+ {5 }& N$ J- n* Y- `* N/ z- Y
- osSemaphoreId_t BinarySemaphoreHandle;
6 J v6 V- a. s" M; A - const osSemaphoreAttr_t BinarySemaphore_attributes = {
9 T0 A9 ^6 O! B$ O. r6 C O N - .name = "BinarySemaphore"
5 W- ?# m' H% A, G0 B& I - };# G5 X8 h$ I5 g% h
- /* Private function prototypes -----------------------------------------------*/
" v! O* f; r) U - /* USER CODE BEGIN FunctionPrototypes */
6 j( ?3 R3 n5 m# p3 I. D - void SystemClock_Config(void);
3 x# F" w6 S) L& y8 K$ R - /* USER CODE END FunctionPrototypes */& w6 L: Z% [6 z6 |' C5 s
- void MainThread_Entry(void *argument);* ^+ \ Y# k% r. r7 l7 V ~
- void MX_FREERTOS_Init(void); /* (MISRA C 2004 rule 8.1) */
t3 b- j& ~9 ]5 a - /* USER CODE BEGIN PREPOSTSLEEP */7 ]9 L6 ]' r% S
- void PreSleepProcessing(uint32_t ulExpectedIdleTime)
- ^" q& r* H! g - {
; |" |% b, R9 T5 Q1 O! \$ Y - /* This is needed to prevent TIM6 from triggering an interrupt,
* t. [/ X9 t9 Y4 G O) s% B - * which could prevent the CPU from entering STOP mode */
) R0 N z( t) f9 E- e( s# j" L7 R - HAL_SuspendTick();
/ J1 i% t; V7 k) C# i7 _) z( E - /* Start low power timer */0 \( o. v% ^' ` D2 T* Y
- HAL_LPTIM_TimeOut_Start_IT(&hlptim4, DEFAULT_TIMEOUT);2 ^) z) a8 l6 B1 C1 d4 D* i
- /* Enter STOP mode */: i$ B0 E/ J9 V0 \( _
- HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);5 }3 D1 Q& q% @
' e) m1 N) E/ s. e - void PostSleepProcessing(uint32_t ulExpectedIdleTime)! @8 J6 Q6 J6 E
- {% h. _5 z: Y8 N
- /* Restore Clock settings */4 N; `- S1 W- ^ |
- SystemClock_Config();
5 P4 O+ f! ?0 |3 p8 C - /* Resume HAL timebase */
) t. P! O/ J$ w2 h5 P - HAL_ResumeTick();! Y# J% n- @+ C4 b7 W8 m
- }8 Q1 a" B; M; }# Q& S6 |
- /* USER CODE END PREPOSTSLEEP */ F) [" Y, C6 o4 S9 T& _
- /**5 S P- [0 @' w+ u
- * @brief FreeRTOS initialization' u5 E) ]+ S( |" b7 Z. B2 |- s
- * @param None
! m: V! K' }$ T7 k8 S; Y - * @retval None
- N0 s! k$ @- [- o5 x2 a - */. K6 d9 E0 n4 a# h
- void MX_FREERTOS_Init(void) {4 z6 s& D9 P- ]
- /* USER CODE BEGIN Init */6 R7 V- {; U' m1 [6 B& `' v- K
- /* USER CODE END Init */
3 B4 }2 F C* c0 m/ A - /* USER CODE BEGIN RTOS_MUTEX */
# X- s4 r# e+ M! i0 f" E2 } - /* add mutexes, ... */
3 E$ U8 \8 i0 Z) q, N - /* USER CODE END RTOS_MUTEX */2 j& Q7 b+ b6 P: _4 ]: K5 I+ y$ ^
- /* creation of BinarySemaphore */" V& t4 K o( @
- BinarySemaphoreHandle = osSemaphoreNew(1, 1, &BinarySemaphore_attributes);% S: D4 T& o% V% D
- /* USER CODE BEGIN RTOS_SEMAPHORES */, V3 t( F& \$ o0 }
- /* add semaphores, ... */* u3 j/ j. ^; t. U) Q; X
- /* USER CODE END RTOS_SEMAPHORES */6 a& A& N0 Z; Y! ?3 ~6 v
- /* USER CODE BEGIN RTOS_TIMERS */
% m3 e' j8 G* \ y6 {' M - /* start timers, add new ones, ... */
9 a! n6 p( k2 A0 w5 {3 W - /* USER CODE END RTOS_TIMERS */
& A' t+ _2 C4 n! H0 h - /* USER CODE BEGIN RTOS_QUEUES */9 K7 D) U& p" N" O' v$ O
- /* add queues, ... */
& v1 i' y3 s( ~! d/ W- u1 E9 G& m - /* USER CODE END RTOS_QUEUES */
7 l4 k& }% A: E$ b+ @ - /* creation of MainThread */; q6 E2 g) H e9 B+ p3 j
- MainThreadHandle = osThreadNew(MainThread_Entry, NULL, &MainThread_attributes);
. Z$ A$ u, F: k: P - /* USER CODE BEGIN RTOS_THREADS */
( x9 K' a" s3 b - /* add threads, ... */
$ v+ t1 `5 U; X5 b7 R- p& P - /* USER CODE END RTOS_THREADS */
" H" z, ?1 f' T9 L( P3 X P - /* USER CODE BEGIN RTOS_EVENTS */3 i. r( S$ f# a0 d
- /* add events, ... */
3 O# e( a& ~4 L& u3 m - /* USER CODE END RTOS_EVENTS */ h3 B# N" R4 ~" u3 A$ L5 r/ g
- }% h; l1 o6 P5 L# u; `: J2 }% C
- /* USER CODE BEGIN Header_MainThread_Entry */
2 K. R) r) \' E( m' O# O6 A - /**
+ @% V$ ?, `+ | G: y/ P - * @brief Function implementing the MainThread thread./ {9 A' K( @( a7 ?9 W. G
- * @param argument: Not used
, ?1 {1 L& @, ^' l! p - * @retval None
! g' p- w; u, D5 r+ t - *// N) {! Q" r8 N# W
- /* USER CODE END Header_MainThread_Entry */ J7 V; y2 Q6 V3 B: w6 e5 J
* O; U4 j7 K; }9 f/ D1 C$ R - {
+ C0 }( j) b# T - /* USER CODE BEGIN MainThread */
0 d c$ w9 f! d - /* Infinite loop */) \$ }/ j5 \# a; g
- for(;;osSemaphoreAcquire(BinarySemaphoreHandle, osWaitForever))' O7 F: W9 L- c$ m/ o
) M5 w( j( A- Z! r: o* p - HAL_GPIO_TogglePin(LED1_GREEN_GPIO_Port, LED1_GREEN_Pin);
! _5 i7 v% v' D y, @ - }/ k: n2 O4 w8 x5 d! }9 [0 G3 P
- /* USER CODE END MainThread */
/ h2 P: I; J: j. a; k5 p- v4 r% _ - }: o* L5 p9 u! G+ h; v! F! j
- /* Private application code --------------------------------------------------*/
4 ~5 p3 i6 D1 o# B - /* USER CODE BEGIN Application */) [+ g9 c7 m! o9 n) i
- void HAL_LPTIM_CompareMatchCallback(LPTIM_HandleTypeDef *hlptim)
" U8 \0 Z9 w7 L; c7 n2 z - {% g( _% [, t3 p! r+ ?- o. G
- if(hlptim->Instance == LPTIM4)5 c! w- u5 R( I; |6 H* m8 ]
) t1 Z/ _8 Y* i' ?! [1 h - osSemaphoreRelease(BinarySemaphoreHandle);
2 ]+ J: _" }) ?7 e! @2 l - HAL_LPTIM_TimeOut_Stop_IT(&hlptim4);% d7 Z* S& A7 j. E# x x
1 M3 L, F! V" x& j* j0 n - }; j; @# Y% W9 D$ P6 ?
- /* USER CODE END Application */
复制代码 程序中首先声明了一个信号量 BinarySemaphoreHandle,作为 GPIO 的控制开关,然后在中断回调 HAL_LPTIM_CompareMatchCallback 中生成这个信号量。
; V/ p( @) Q. v0 U7 \- //信号量9 e' W3 U6 I* w. @. n/ b& j
* J b# x ]* }1 u/ s. a$ k* U - //回调函数/* Private application code --------------------------------------------------*//* USER CODE BEGIN Application */void HAL_LPTIM_CompareMatchCallback(LPTIM_HandleTypeDef *hlptim)
! X0 ^7 f+ q' V - {6 ~9 @* W9 q1 Y- W
- if(hlptim->Instance == LPTIM4)- m4 G/ W& l& ~+ g; p8 W: V$ c- x$ p
- {) T! ^# X( P! i
6 W7 i" d6 V- m5 J' z8 u - HAL_LPTIM_TimeOut_Stop_IT(&hlptim4);* F9 c1 s: u7 _7 f- H
- }& j, W/ T4 D# K
复制代码 信号生成后,等待系统自己调度,这时需要将LPTIM4中断关掉。HAL_LPTIM_TimeOut_Stop_IT(&hlptim4);
" F+ a/ @+ b; Y- /* USER CODE END Header_MainThread_Entry */void MainThread_Entry(void *argument)% J- _5 C5 H/ `$ ~
' G5 v, l5 _) m+ D \/ T7 U - /* USER CODE BEGIN MainThread */* | [2 ?! r1 \
- /* Infinite loop */. g3 ?4 {! m+ L" B4 k( n2 o
! U# }! b5 r. l! m7 J/ V - {) g0 z/ I1 T) B& w! H4 a8 d
- HAL_GPIO_TogglePin(LED2_YELLOW_GPIO_Port, LED2_YELLOW_Pin);
3 l7 I. N$ a& Y& k) S9 d( B0 G4 r" y - }
t8 }" ^5 g2 S - /* USER CODE END MainThread */; B, d! z, Q5 u- l5 A L
h! V5 k0 ~: E c9 i7 ^% f
复制代码 信号到达后翻转GPIO输出,系统运行后LED2,进入不停的闪烁。+ Y6 a4 k ^* m. u! P2 @
, O j3 ]1 @2 K/ I$ c来源:EEWORLD论坛网友bigbat 版权归原作者所有# Q& K: l; E/ |" C8 Z+ t1 k9 |' M
) ?5 |" R- I! w6 h9 }3 V# ^0 C
$ @1 t* e: t3 ]/ ~
6 G% m. F; x0 Q7 q |
