STM32CubeIDE printf浮点数,浮点数丢失数值
Elsa_Li 提问时间:2024-5-29 16:57 / 未解决
1、芯片:STM32F103C8T6 2、环境:STM32CubeIDE 3、问题:printf浮点数,浮点数数值丢失 如 float A=25.6666;float B=24.7777; 实际打印出来: 第一种情况:A=2.0000;B=0.0000; 第二种情况:A=-2.0000; B=-26815615859885194199148049996411692254958731641184786755447122887443528060147093953603748596333806855380063716372972101707507765623893139892867298012168192.000000 偶尔会出现以上情况,除此之外正常打印浮点数。 4、已开启STM32CubeIDE打印浮点数,也加了Flag。 打印整数不会出现问题 尝试double A;double B;也会出现上述问题 以下是代码
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
double Printf_T_Set,Printf_T_Act;
Printf_T_Set = T_Set;
Printf_T_Act = T_Act;
if(htim->Instance == htim2.Instance)
if(printSoftwareVersion==1)
    printSoftwareVersion=0;
    printf("Software Version: M01_40mA_V03 \r\n");
if(printEnabled==1)
// printf("T-Set:%.4f \r\n",Printf_T_Set);
// printf("T-Act:%.4f \r\n",Printf_T_Act);
    printf("T-Set:%lf \r\n",Printf_T_Set);
    printf("T-Act:%lf \r\n",Printf_T_Act);
ifdef GNUC
define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
else
define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
endif
PUTCHAR_PROTOTYPE
HAL_UART_Transmit(&huart1,(uint8_t *)&ch,1,0xFFFF);//阻塞方式打印,串口1
return ch;
赞 收藏 评论12 发布时间:2024-5-29 16:57
12个回答
xmshao 回答时间:2024-5-29 18:02:23
有个地方的配置,别忽略了。工程属性下面\Tool setting\MCU Settings,
将Use float with printf ...勾选上。
输出结果是正常的:
while (1)
   /* USER CODE END WHILE */
   /* USER CODE BEGIN 3 */
value = value +0.0000001;
printf("**value = %3.20f  ** \n\r",value);
HAL_Delay(500);
结果输出没啥问题:
**value = 12.46480359999966047724  **
**value = 12.46480369999965986949  **
**value = 12.46480379999965926174  **
**value = 12.46480389999965865400  **
**value = 12.46480399999965804625  **
**value = 12.46480409999965743850  **
**value = 12.46480419999965683076  **
**value = 12.46480429999965622301  **
**value = 12.46480439999965561526  **
**value = 12.46480449999965500751  **
xmshao 回答时间:2024-5-29 21:21:27
我刚才基于STM32芯片在STM32CUBEIDE环境下,验证了浮点的打印,没有啥问题。
double value =12.4647478;
while (1)
printf ("value = %3.20f \n\r",value);
HAL_Delay (500);
结果输出没啥问题:
李康1202 回答时间:2024-5-30 12:04:49
楼上说得对,还有就是把打印函数放到主函数试试、
Elsa_Li 回答时间:2024-5-30 16:00:57
xmshao 发表于 2024-5-29 21:21
我刚才基于STM32芯片在STM32CUBEIDE环境下,验证了浮点的打印,没有啥问题。</p>
<p>有个地方的配置,别忽略 ...
[md]1、STM32Cube已勾选打印浮点数的设置
2、代码是可以打印浮点数的,但偶尔会出现丢数据的情况,还是没有解决 3、在线debug已确认printf前,变量数值正常,printf后,实际打印与变量数值不同 image.png image.png
Elsa_Li 回答时间:2024-5-30 17:21:27
<p>有个地方的配置,别忽略 ...
Elsa_Li 回答时间:2024-5-30 17:31:54
可以看到我其他的回复吗?谢谢
xmshao 回答时间:2024-5-30 21:42:00
Elsa_Li 发表于 2024-5-30 17:21
printf打印的值与实际变量值不同
![5c955462d2cfabd391ab955e539c202b.png](data/attachment/forum/2 ...
[md]感觉你在表达printf本身没有问题,只是偶尔丢数据。
那就要检查程序逻辑了。
Elsa_Li 回答时间:2024-5-31 09:20:56
xmshao 发表于 2024-5-30 21:42
感觉你在表达printf本身没有问题,只是偶尔丢数据。</p>
<p>那就要检查程序逻辑了。
[md]我给的是实数,局部变量,固定了浮点数的值,也是有这个情况。所以我怀疑是printf的问题,我也尝试直接用TX发送,也有这个问题
芯片:STM32F103C8T6 环境:STM32CubeMX和STM32CubeIDE 库:STM32F1HAL 问题:UART1 printf打印浮点数,偶尔出现数据丢失 例子固定值读点数如 float A=25.6666;float B=24.7777; 实际打印出来: 第一种情况:A=2.0000;B=0.0000; 第二种情况:A=-2.0000; B=-26815615859885194199148049996411692254958731641184786755447122887443528060147093953603748596333806855380063716372972101707507765623893139892867298012168192.000000 偶尔会出现以上情况,除此之外正常打印浮点数。
xmshao 回答时间:2024-6-3 13:57:13
Elsa_Li 发表于 2024-5-31 09:20
我给的是实数,局部变量,固定了浮点数的值,也是有这个情况。所以我怀疑是printf的问题,我也尝试直 ...
[md]我改为定时器定时触发,在中断里做printf输出,测试几个小时一点问题都没有。
你将变量前加上volatile试试。
另外,手上有别的开发板也可以试试,或者换个串口助手看看。
Elsa_Li 回答时间:2024-6-4 10:19:15
xmshao 发表于 2024-6-3 13:57
我改为定时器定时触发,在中断里做printf输出,测试几个小时一点问题都没有。</p>
<p>![image.png](data/at ...
[md]好的,我试试,真的奇怪,我感觉不是这个问题
Glenxu 回答时间:2024-6-6 21:09:30
浮点一定会有“有小数”的限制,也就是第6位以后会有数据不准确
