TIM 单脉冲输出后的电平如何设置?
饕餮的阿周 提问时间:2026-1-8 17:45 / 未解决
这个是TIM8 ch1单脉冲输出的波形(周期为1ms,占空比为50%),可以见到,输出完毕后,引脚电平为高电平;
请问如何使输出完毕后引脚电平为低电平?困惑中,谢谢大家
核心设置代码如下:
/* TIM8 init function */
void MX_TIM8_Init(void)
  /* USER CODE BEGIN TIM8_Init 0 */
  /* USER CODE END TIM8_Init 0 */
  TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  TIM_OC_InitTypeDef sConfigOC = {0};
  TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
  /* USER CODE BEGIN TIM8_Init 1 */
  /* USER CODE END TIM8_Init 1 */
  htim8.Instance = TIM8;
  htim8.Init.Prescaler = 16-1;
  htim8.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim8.Init.Period = 9999;
  htim8.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim8.Init.RepetitionCounter = 0;
  htim8.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_Base_Init(&htim8) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim8, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_PWM_Init(&htim8) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_OnePulse_Init(&htim8, TIM_OPMODE_SINGLE) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim8, &sMasterConfig) != HAL_OK)
    Error_Handler();
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
  sConfigOC.Pulse = 4999;
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  if (HAL_TIM_PWM_ConfigChannel(&htim8, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
    Error_Handler();
  __HAL_TIM_DISABLE_OCxPRELOAD(&htim8, TIM_CHANNEL_1);
  if (HAL_TIM_PWM_ConfigChannel(&htim8, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
    Error_Handler();
  __HAL_TIM_DISABLE_OCxPRELOAD(&htim8, TIM_CHANNEL_2);
  sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
  sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
  sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  sBreakDeadTimeConfig.DeadTime = 0;
  sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  sBreakDeadTimeConfig.BreakFilter = 0;
  sBreakDeadTimeConfig.BreakAFMode = TIM_BREAK_AFMODE_INPUT;
  sBreakDeadTimeConfig.Break2State = TIM_BREAK2_DISABLE;
  sBreakDeadTimeConfig.Break2Polarity = TIM_BREAK2POLARITY_HIGH;
  sBreakDeadTimeConfig.Break2Filter = 0;
  sBreakDeadTimeConfig.Break2AFMode = TIM_BREAK_AFMODE_INPUT;
  sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
  if (HAL_TIMEx_ConfigBreakDeadTime(&htim8, &sBreakDeadTimeConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN TIM8_Init 2 */
  /* USER CODE END TIM8_Init 2 */
  HAL_TIM_MspPostInit(&htim8);
赞 收藏 评论10 发布时间:2026-1-8 17:45
10个回答
butterflyspring 回答时间:2026-1-9 10:06:16
参考手册上有这部分的详细描述
HyunYong 回答时间:2026-1-9 05:47:12
没理解错的话 图中是你要的波形 输出一次脉冲以后希望持续高电平输出
sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET; sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET; 这两行从RESET 改为SET
那么就是单脉冲输出结束后高电平了 不然改的话就会呈现输出完一次脉冲以后持续低电平
做波形的话 大部分这些简单的波形都能从cubemx上直接配置 你只需要在使用的时候初始化一次
这些都是cubemx上可以设置的 可以看看正点原子的或者是问一下AI这个芯片在cubemx中要怎么配置 会给你引导思路的 找到对应 的位置 截图翻译一下 基本配置都是直译 cubemx内容换成中文的话你就能马上找到了
饕餮的阿周 回答时间:2026-1-9 08:47:22
<br /> <br />
感谢,不好意思写错了,我是想在一个脉冲输出后引脚拉到低电平。上面的图和代码,一个脉冲输出后引脚为高电平。
HyunYong 回答时间:2026-1-9 09:17:33
<br /> <br />
我设计的时候 一般这种东西允许的话 我喜欢脉冲结束自动进入低电平以后 把引脚绑定退出来 让它变成普通IO 然后再主动拉低一次 那样就不会有意外高电平的可能
HyunYong 回答时间:2026-1-9 09:19:19
<br /> <br />
如果想要学波形的话 建议玩STM32G474系列的芯片 因为它还多一个HTIM 应该是叫这个 我叫高级定时器 这个是其他芯片没有的 这个芯片上把所有波形搞会了 其他芯片也是一样的
xmshao 回答时间:2026-1-9 09:36:04
方法不定。
这里最简单的办法就是将PWM模式改为PWM2模式,其它不动。
饕餮的阿周 回答时间:2026-1-9 10:03:14
<br /> <br />
改为PWM2模式后,互补通道在输出一个PWM周期波形后,电平也是高电平了
xmshao 回答时间:2026-1-9 10:24:40
<br /> <br />
如果使用互补通道来实现的话 就要复杂些了。此时简单地改个PWM模式的确不太好满足要求。
如果不是必须这样,最好不要使用互补通道,可以使用多个TIMER进行同步启动、同步输出,都工作在单脉冲模式。
如果非要使用互补通道的话,可能需要手动参与下,往往借助更新事件。可以基于互补输出特性来操作。
qintian0303 回答时间:2026-1-14 16:09:55
能不能设定输出固定的个数脉冲
yuliangliang 回答时间:2026-3-20 11:43:55
<br /> <br />
不借助单脉冲模式,设定好想要生成的pwm脉冲,设置每次更新事件时中断回调函数中计数,计数达到固定脉冲数或者小于固定冲数,停掉pwm脉冲;具体要看一下执行停止脉冲的时候是再生成一个还是立马停止,微调一下。
