请教STM32F334 ADC 差分应用问题
xihui8817 提问时间:2015-6-23 16:21 /
安:你好!
一、硬件连接:
1.  +3.3V 串3个10k电阻到地 取中间电阻电压(1.10V)送AD 得到码数为:2610
2.     +5V 串3个10k电阻到地 取中间电阻电压(1.66V)送AD 得到码数为:2915
3.   ADC1_IN1->PA0 接信号+
      ADC1_IN2->PA1 接信号-
二、问题:为何电压和码数无法对应呢?
三、代码:(cube生成)
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2);
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_HRTIM1|RCC_PERIPHCLK_USART1
                              |RCC_PERIPHCLK_ADC12;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
  PeriphClkInit.Adc12ClockSelection = RCC_ADC12PLLCLK_DIV1;
  PeriphClkInit.Hrtim1ClockSelection = RCC_HRTIM1CLK_PLLCLK;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
  __SYSCFG_CLK_ENABLE();
/* ADC1 init function */
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
  hadc1.Init.Resolution = ADC_RESOLUTION12b;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.EOCSelection = EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.Overrun = OVR_DATA_OVERWRITTEN;
  HAL_ADC_Init(&hadc1);
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = 1;
  sConfig.SingleDiff = ADC_DIFFERENTIAL_ENDED;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  HAL_ADC_ConfigChannel(&hadc1, &sConfig);
  HAL_ADC_Start(&hadc1);
  while (1)
    ADC_GetValue=HAL_ADC_GetValue(&hadc1);
    printf("%d \r\n", ADC_GetValue);
收藏 评论15 发布时间:2015-6-23 16:21
15个回答
黑溱郎 回答时间:2015-6-23 17:40:31
帮楼主顶一下。
废鱼 回答时间:2015-6-25 14:09:29
      ADC1_IN2->PA1 接信号-
这里说的信号+ -指的是具体哪个?还有参考电压ref是多少?
黑皮男 回答时间:2015-6-25 14:20:40
路过帮顶
XH750507 回答时间:2015-7-3 16:27:01
自己顶一下
XH750507 回答时间:2015-7-3 16:32:15
参考电压:3.3V
满码:4096
差分信号输入
1.10V送AD 得到码数为:2610
1.66V送AD 得到码数为:2915
请教码数和电压的换算关系?是不是选择了差分输入则AD自动为双极性?
废鱼 回答时间:2015-7-3 17:05:03
ADC1_IN1->PA0 接信号+
ADC1_IN2->PA1 接信号-
这里的信号+指的是哪个?信号-指的是哪个?
如果不用差分,这个时候采集到的AD值是多少?他应该是实际电压/REF*4096.
stary666 回答时间:2015-7-4 00:37:00
顶一下,,,,,,,,
XH750507 回答时间:2015-7-4 13:26:10
参考电压:3.3V
满码:4096
差分信号输入
2.20-1.10=1.10V送AD 得到码数为:2610
ADC1_IN1->PA0 接+2.20V
ADC1_IN2->PA1 接+1.10V
3.32-1.66=1.66V送AD 得到码数为:2915
ADC1_IN1->PA0 接+3.32V
ADC1_IN2->PA1 接+1.66V
请教码数和电压的换算关系?
废鱼 回答时间:2015-7-4 16:44:37
从手册看是芯片自动转换了。
In differential input mode, the analog voltage to be converted for channel “i” is the difference
between the external voltage ADC_INi (positive input) and ADC_INi+1 (negative input).
废鱼 回答时间:2015-7-4 16:55:41
对于差分AD的使用,一块探讨一下。
XH750507 回答时间:2015-7-8 08:57:59
我在使用334的差分AD的时候 转换的码数如果按照双极性来计算 电压和码数似乎是有对应关系的
欣辰天下 回答时间:2016-7-1 22:42:44
牙子男男 回答时间:2019-2-20 11:23:57
楼主~这个问题你是怎么解决的? 我现在也遇到这个情况了。看你题目上写的已解决,特来请教,望回复
牙子男男 回答时间:2019-2-20 11:55:54
您好~麻烦问一下您说的双极性指的是什么? 我也在用334,遇到楼主的问题了
12下一页
