[STM32F401-DISCO开发板]实验三、2路ADC采样+2路PWM输出实验
zhjb1 发布时间:2017-12-10 10:53
[STM32F401-DISCO开发板]实验一、STM32F401 DISCO开发板介绍,点亮LED7 Y3 Z8 q9 z" ^6 Z" m
[STM32F401-DISCO开发板]实验二、驱显黑白LCD_6903,串口调试0 n5 V. `; O* w& ]
; Y' ~: z7 d7 L5 v* N" E0 g5 A1 P0 B& p3 I6 }3 b
  Q, C9 h% s& s+ W0 ~+ F/ J( w
本实验较为简单,设置2论ADC采样和2路PWM输出,并且显示在LCD上同时从串口输出数据。8 M! g- A5 S6 J* I( H- w/ K
定义对象:
! o6 W5 c. @2 U4 D! WAnalogIn adc0(PA_4);* X+ }8 c7 ~& x" ^2 f- n' N4 z
AnalogIn adc1(PA_5);6 E: O* t! ]( c5 H2 a* H, X1 s
PwmOut pwm0(PA_10);6 _& Z! N6 M2 M5 y9 @) l
PwmOut pwm1(PA_8);
  R0 l) r) Y5 m5 J/ h- \Ticker tick;//Time Interupt Clock! r. N4 F. U1 [5 H6 J
//DigitalOut led(LED1);
* w# K2 P/ g: \& uSerial sout(PA_2,PA_3);//(USBTX, USBRX);% |6 Z9 x1 }" l3 C4 P' f0 O- F
定义显示函数:
/ K6 z4 k7 X' l& V2 Gvoid dispBase(void);
3 L% a* O8 E( H( _8 ~void dispMes(void);
6 x' s6 G3 A) ~2 r: R, S) w! ]定义变量:& R7 Q6 i: B3 E9 ?* R
//DEFINE VARIABLE
* t3 J; M% Z& ]" V- cint32_t jsq;5 s; E: L2 K* C7 P
float val0,val1,dut0=0.330f,dut1=0.450f,ddu0=0.003f,ddu1=0.002f;: F0 ^5 n* y; s: r
int pdir0=1,pdir1=1,twAddr1=0xBC,twAddr2=0xBB;0 y3 r6 f4 q4 e4 M/ b# M9 u
char twData[2]={0,0};
" u* p3 E' q0 e& `  N2 p: M/ l定义中断Tick实现程序计数器:
6 f( ~" e: A: P  @9 E* Svoid tipInt(void){jsq++;}
$ @+ Y2 c; t! H/ s3 t+ }定义GPIO[仅仅PWM周期]:' f, H5 r9 l' x2 ^( G
void ioInit(void){
( a! [2 T! U5 t* r pwm0.period(0.003f);//pwm0
: o( ^' G  W! o: M7 t pwm1.period(0.004f);//pwm13 Q9 g( A' n( Z: i8 {% X
}! M: b2 B- t2 c4 ?& G
main函数:
! L3 c& R$ ^) T0 d' g$ Mint main(){: j3 b' O0 p8 X2 N& e1 ~
ioInit();
! B* E& y$ }" E' Q lcdInit();# Q' K9 q  L6 W6 q! t. Q, F
lcdClear();
' M' Q3 y/ `- K" T; W& | dispBase();1 d1 e$ _( @0 M" c* u; ^
tick.attach(&tipInt,0.005f);
! r" U3 _  l8 ]. ~ sout.printf("TEST 2ADC 2PWM a LCD Display\n\r");0 o! L0 w- R6 v0 k  e& E7 }
while(true){6 d: y3 q7 ^- @/ c! B& _  c
  val0=adc0.read();, ]2 \' r: e" M! P% E2 g( U
  val1=adc1.read();
( ^+ w8 q# P/ v' W' A  if(dut0>0.810f){pdir0=0;};if(dut0<0.180f){pdir0=1;}
9 B& j7 u/ E; y! q+ a7 X  if(pdir0==0){dut0 -=ddu0;};if(pdir0==1){dut0 +=ddu0;}
! z  P/ q9 n% I  pwm0=dut0;3 X! p+ F; E. J% V9 ~$ S
  if(dut1>0.610f){pdir1=0;};if(dut1<0.160f){pdir1=1;}8 R  d% h; M1 |4 V& I
  if(pdir1==0){dut1 -=ddu1;};if(pdir1==1){dut1 +=ddu1;}5 ]! ?8 f6 z8 s9 L' q# e
  pwm1=dut1;
5 F" o% Q2 j6 w4 c3 O) `4 [  //i2c.read(twAddr1,twData,2);
3 \+ y% I- F0 r5 D& D8 x  if((jsq/5)%5==1){dispMes();}0 r$ C: ~" M; o! B$ d9 l
  sout.printf("ADC1=%0.4f ADC2=%0.4f PWM1=%0.3f PWM2=%0.3f ",val0,val1,dut0,dut1);
" K! |* ?% Z. }$ D0 k6 ~$ Z  sout.printf("DATA0:%d DATA1:%d \n\r",twData[0],twData[1]);+ P. b# S# h8 q: o
  //led=!led;: _; A! C0 ~: B& w5 F& j
  //wait(0.05);
: E2 O  Y' Y- s6 ~" j  j }
/ o2 k' H* b3 n6 \7 w}
% w0 l  h" A7 M" \2 a2 o, l" W显示固定字符函数:
7 j2 @& p, F& a" Y- A//Display Base Meseger) ]2 M! a* G3 q( v8 [" G, ^6 U5 t
void dispBase(void){
# s# K$ A. t  o) h: |# ~" M c2l(0,0,19);c2l(1,0,28);c2l(2,0,26);c2l(3,0,40);//JSQ:$ {" X  L1 D* u! Y+ a
c2l(0,1,10);c2l(1,1,13);c2l(2,1,0);c2l(3,1,40);//AD0:# U: p# z' s( F4 q* z' j  M( J
c2l(9,1,10);c2l(10,1,13);c2l(11,1,1);c2l(12,1,40);//AD1:
4 }- c; g) ~1 z6 B0 P5 ] c2l(0,2,25);c2l(1,2,32);c2l(2,2,0);c2l(3,2,40);//PW0:
$ _* a4 v4 a; J/ K  ^3 Q c2l(9,2,25);c2l(10,2,32);c2l(11,2,1);c2l(12,2,40);//PW1:  B* p6 D+ f; c; O& s
c2l(0,3,29);c2l(1,3,14);c2l(2,3,22);c2l(3,3,40);//TEM:
5 Q9 @! e- p2 V1 X9 g8 U c2l(9,3,17);c2l(10,3,30);c2l(11,3,22);c2l(12,3,40);//HUM:5 ?8 C% ]# ]! S+ G! Q7 ~" \. C3 i
}+ e3 J7 Q8 O2 t( }' B* c. f
显示采样和PWM输出计数器输出数据:: ^4 p) W. y- h! D1 `/ K3 w; p
//Display Messeg$ R( V. H! E. ^- c
void dispMes(void){
, X; U4 g) K( G9 \* F2 _ c2l(4,0,(jsq/1000000)%10);c2l(5,0,(jsq/100000)%10);c2l(6,0,(jsq/10000)%10);c2l(7,0,(jsq/1000)%10);//JSQ:
8 i9 ^3 }/ ^; i c2l(8,0,(jsq/100)%10);c2l(9,0,(jsq/10)%10);c2l(10,0,(jsq)%10);//JSQ:& x2 J1 G! s0 n$ L# K( F
c2l(4,1,int(val0*10)%10);c2l(5,1,int(val0*100)%10);c2l(6,1,int(val0*1000)%10);c2l(7,1,int(val0*10000)%10);//ad0% ?6 n7 O) C! v: v2 N, Z
c2l(13,1,int(val1*10)%10);c2l(14,1,int(val1*100)%10);c2l(15,1,int(val1*1000)%10);c2l(16,1,int(val1*10000)%10);//ad04 b& P6 V0 Q, N% [) n1 {2 }  m
c2l(4,2,int(dut0*10)%10);c2l(5,2,int(dut0*100)%10);c2l(6,2,int(dut0*1000)%10);
5 g' t! Z$ G8 k" B0 \ c2l(13,2,int(dut1*10)%10);c2l(14,2,int(dut1*100)%10);c2l(15,2,int(dut1*1000)%10);+ J% p: E) T* C- _/ S, A: z0 t
c2l(4,3,(twData[0]/100)%10);c2l(5,3,(twData[0]/10)%10);c2l(6,3,(twData[0])%10);. Q. {" U* T. R* I: y& }) U; M3 P1 h
c2l(13,3,(twData[1]/100)%10);c2l(14,3,(twData[1]/10)%10);c2l(15,3,(twData[1])%10);/ b6 Y& |6 _( u1 E4 O( M- Q5 o
}3 o, k8 y: ~$ C: L* J% g
编译后下载运行结果见照片和截图。照片31为硬件连接;照片32为LCD显示结果;照片33为PWM控制2个LED轮流渐亮暗;截图34为牟尼出口输出的ADC和PWM数据。8 T5 K8 k$ m' ~% Z
31
31
32
32
33
33
34
34
赞 收藏 评论4 发布时间:2017-12-10 10:53
4个回答
anywill 回答时间:2017-12-10 13:30:10
继续点赞
浪花雷雨 回答时间:2017-12-11 09:03:58
赞,很不错
wolfgang 回答时间:2017-12-11 21:09:39
很不错~~
stm32f107 回答时间:2018-7-5 09:55:13
不错
