P-NUCLEO-IHM002 开发套件,利用ST Motor Control workbench生成工程.....
xsax12zuwnsn 提问时间:2019-1-19 16:04 /
利用ST Motor Control workbench生成工程编译时无法完成编译,好多函数没有函数体,只有声明,哪位大神知道是什么原因啊,
是没有包含电机库吗,怎么处理啊
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_OTF_ResetPLL (referred from mc_config.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_ForceConvergency1 (referred from mc_config.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_ForceConvergency2 (referred from mc_config.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_IsVarianceTight (referred from mc_config.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_Clear (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_Exec (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_FirstAccelerationStageReached (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_Init (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_CalcAvrgElSpeedDpp (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_CalcAvrgMecSpeed01Hz (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_CalcElAngle (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_Clear (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_Init (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_IsObserverConverged (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_ResetPLL (referred from mc_tasks.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_GetNumberOfPhases (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_GetPhaseDurationms (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_GetPhaseFinalMecSpeed01Hz (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_GetPhaseFinalTorque (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_SetPhaseDurationms (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_SetPhaseFinalMecSpeed01Hz (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol RUC_SetPhaseFinalTorque (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_GetPLLGains (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_GetEstimatedBemf (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_GetEstimatedBemfLevel (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_GetEstimatedCurrent (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_GetObservedBemfLevel (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_GetObserverGains (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_PLL_SetObserverGains (referred from user_interface.o).
Motor_CTL\Motor_CTL.axf: Error: L6218E: Undefined symbol STO_SetPLLGains (referred from user_interface.o).
Not enough information to list image symbols.
Finished: 1 information, 0 warning and 30 error messages.
"Motor_CTL\Motor_CTL.axf" - 30 Error(s), 0 Warning(s).
赞 收藏 评论16 发布时间:2019-1-19 16:04
16个回答
mmuuss586 回答时间:2019-1-22 15:20:47
xsax12zuwnsn 发表于 2019-1-22 14:36
我试过了,还是这样,未定义,关键就这么一个文件下的函数未定义,你生成的keil文件编译成功的吗? ...
有一台电脑不行(换过很多版本,该试试的都试了,原厂那边回复可能是电脑系统问题),另外几台笔记本电脑都可以,我们6,7个同事在用
xsax12zuwnsn 回答时间:2019-1-22 16:18:28
mmuuss586 发表于 2019-1-22 15:20
有一台电脑不行(换过很多版本,该试试的都试了,原厂那边回复可能是电脑系统问题),另外几台笔记本电脑 ...
我换了好几台都那样,你用的是几点几的ST Motor Control workbench
xsax12zuwnsn 回答时间:2019-1-22 16:09:42
能发我个你们生成的程序看看嘛,我看看跟我生成的程序差在哪
子曰好人 回答时间:2019-1-19 19:27:48
重新全部编译一次吧,.axf文件是编译后生成的文件,先将这个文件删除再编译,看看编译器如何报错
STMCU + 2
xsax12zuwnsn 回答时间:2019-1-21 09:12:43
子曰好人 发表于 2019-1-19 19:27
重新全部编译一次吧,.axf文件是编译后生成的文件,先将这个文件删除再编译,看看编译器如何报错 ...
编译错误,好像都没这个文件
mmuuss586 回答时间:2019-1-21 09:24:39
看看.c程序里是不是空的;是空的就是没安装成功
参与人数 1蝴蝶豆 +1 收起 理由
STMCU + 1
xsax12zuwnsn 回答时间:2019-1-21 10:24:53
不是空的,是未定义
xsax12zuwnsn 回答时间:2019-1-21 12:55:41
找不到相应的函数
mmuuss586 回答时间:2019-1-21 15:08:25
那好像是没安装成功
mmuuss586 回答时间:2019-1-21 15:11:45
你换电脑试下看看;
xsax12zuwnsn 回答时间:2019-1-22 14:36:30
mmuuss586 发表于 2019-1-21 15:11
你换电脑试下看看;
xsax12zuwnsn 回答时间:2019-1-22 16:09:23
mmuuss586 回答时间:2019-1-23 09:47:55
自己看我发的帖子,谢谢;
mmuuss586 回答时间:2019-1-23 09:48:15
自己看我发的帖子,谢谢;
12下一页
