STM32MP135D的TIM2使用ETR作为外部时钟时,无法使用PE15作为输入
如何利用TIM1触发HRTIM TIMA生成频率为20Hz的100ns脉冲波?
STM32G473RC timer8的CCDS bit, Capture/Compare DMA selection.
FW_H7 V1.12.1-HAL库DMA双缓冲配置
STM32G431 数据手册上有个图有点不理解
STM32G473RC多个定时器同步的问题
STM32G474VET6如何配置HRTIM的中心对齐模式
stm32H755BIT6 TIM1中断问题
stm32h725
非对称PWM的问题
Low-speed external clock generated from a crystal/ceramic resonator
The low-speed external (LSE) clock can be supplied with a 32.768 kHz crystal/ceramic resonator oscillator. All the information given in this paragraph are based on characterization results obtained with typical external components specified in Table 29. In the application, the resonator and the load capacitors have to be placed as close as possible to the oscillator pins in order to minimize output distortion and startup stabilization time. Refer to the crystal resonator manufacturer for more details on the resonator characteristics (frequency, package, accuracy).
晶体/陶瓷谐振器产生的低速外部时钟
低速外部(LSE)时钟可配备32.768 kHz晶体/陶瓷谐振器振荡器。本段中给出的所有信息均基于表29中规定的典型外部元件的特性化结果。在应用中,谐振器和负载电容器必须尽可能靠近振荡器引脚,以最小化输出失真和启动稳定时间。有关谐振器特性(频率、封装、精度)的更多详情,请咨询晶体谐振器制造商。
手册上好像有这么说,你好 ,可以给个咨询的QQ吗,谢谢
stm32L476开发板
看过了,说是从ETR或者TI引脚对应引进来,看了感觉好像又不太行,寻求大佬帮助
好的 时钟树我试过可以接外部的32K,我试试用LPTIM产生下方波,谢谢
