利用CubeMX 6.3.0 生成AD读取程序无法取出寄存器值,一直为零 应为IO不够用用的串口下载程序 ADC_HandleTypeDef hadc; DMA_HandleTypeDef hdma_adc; /* ADC init function */ void MX_ADC_Init(void) { ADC_ChannelConfTypeDef sConfig = {0}; /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion) */ hadc.Instance = ADC1; hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1; hadc.Init.Resolution = ADC_RESOLUTION_12B; hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_BACKWARD; hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc.Init.LowPowerAutoWait = ENABLE; hadc.Init.LowPowerAutoPowerOff = DISABLE; hadc.Init.ContinuousConvMode = ENABLE; hadc.Init.DiscontinuousConvMode = DISABLE; hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc.Init.DMAContinuousRequests = ENABLE; hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED; if (HAL_ADC_Init(&hadc) != HAL_OK) { Error_Handler(); } /** Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_0; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; sConfig.SamplingTime = ADC_SAMPLETIME_71CYCLES_5; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { Error_Handler(); } /** Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_1; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { Error_Handler(); } /** Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_2; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN ADC_Init 2 */ // ADC1->CFGR1 &= (uint32_t)~ADC_CFGR1_DMACFG; // ADC1->CFGR1 |= (uint32_t)ADC_CFGR1_DMACFG; /* USER CODE END ADC_Init 2 */ } void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(adcHandle->Instance==ADC1) { /* USER CODE BEGIN ADC1_MspInit 0 */ /* USER CODE END ADC1_MspInit 0 */ /* ADC1 clock enable */ __HAL_RCC_ADC1_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); /**ADC GPIO Configuration PA0 ------> ADC_IN0 PA1 ------> ADC_IN1 PA2 ------> ADC_IN2 */ GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2; GPIO_InitStruct.Mode = GPIO_MODE_ANALOG; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* ADC1 DMA Init */ /* ADC Init */ hdma_adc.Instance = DMA1_Channel1; hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE; hdma_adc.Init.MemInc = DMA_MINC_ENABLE; hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD; hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_WORD; hdma_adc.Init.Mode = DMA_CIRCULAR; hdma_adc.Init.Priority = DMA_PRIORITY_LOW; if (HAL_DMA_Init(&hdma_adc) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc); } } void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle) { if(adcHandle->Instance==ADC1) { /* USER CODE BEGIN ADC1_MspDeInit 0 */ /* USER CODE END ADC1_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_ADC1_CLK_DISABLE(); /**ADC GPIO Configuration PA0 ------> ADC_IN0 PA1 ------> ADC_IN1 PA2 ------> ADC_IN2 */ HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2); /* ADC1 DMA DeInit */ HAL_DMA_DeInit(adcHandle->DMA_Handle); /* USER CODE BEGIN ADC1_MspDeInit 1 */ /* USER CODE END ADC1_MspDeInit 1 */ } } 还有初始化 HAL_ADCEx_Calibration_Start(&hadc); HAL_Delay(100); HAL_ADC_Start_DMA(&hadc, ADC_Value, 150); 处理函数 void read_V(void) { for(i=0,ad1=0,ad2=0,ad3=0; i<150;) { ad1 += ADC_Value[i++]; ad2 += ADC_Value[i++]; ad3 += ADC_Value[i++]; } ad1 /= 50; ad2 /= 50; ad3 /= 50; ChongDDY= ad1+ad2+ad3; } |
请问我的CubeMX为什么初始界面没有ai选项,进去之后也没有addnetwork?
你最期待工具带来哪些便利?
关于手动移植RTOS的问题,在基于HAL生成的工程上。xPortSysTickHandler()会影响外部晶振的时钟初始化,进入硬件故障处理函数,HSI没问题
请教各位大佬为啥我的stm32cubemax没有登陆myst的界面
stm32cubemxd的myst账号登录不上,但网页上可以登录
stm32 数据掉电保存问题
为何cubemx2只支持最新的c5系列
今天的主题是STM32CubeMX2
STM32CubeMX2尝鲜
【速览】CubeMX2发布了,目前支持C5系列,支持MDK6
代码比较简单,你可以参考下:
uint32_t AdcData3]={0};
HAL_ADCEx_Calibration_Start(&hadc);;
HAL_ADC_Start_DMA(&hadc, AdcData, 3);
static void MX_ADC_Init(void)
hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
hadc.Init.LowPowerAutoWait = DISABLE;
Error_Handler();
sConfig.SamplingTime = ADC_SAMPLETIME_55CYCLES_5;
Error_Handler();
Error_Handler();
Error_Handler();
另外,建议你检查下硬件,尤其电源以及VDDA脚的连接情况。
真坑 ,cubemx生成的程序有问题 换成老版本的cubemx就可以了
有时是可能有这些问题,毕竟CubeMx及库都超级庞大,一路有些问题也难免,总之,还是越来越好用。
CUBE生成代码初始化部分可能需要调整,上回我使用UART加DMA,先初始化UART再初始化DMA,这样只能接收最后一个字节,把DMA初始化放前面 ,UART初始化放后面,就正常了。AD加上DMA,我估计是一样的,你试下,先DMA初始化,后AD初始化。
