STM32驱动eMMC读写数据
0 f: b7 Y) W) X) Z2 j* E参照 JEDEC eMMC标准:JESD84-B51 (Revision of JESD84-B50.1, July 2014)* y5 }6 C# O/ @8 \
驱动芯片采用stm32h7xx芯片。通过官方HAL库中stm32h7xx_hal_mmc.h文件驱动,采用8bit数据传输模式,与SD卡驱动类似。实测写入速度6-10MB/s左右。% n3 [/ U+ y7 H6 P
8 T( j- `4 Y" \! m5 W3 h初始化代码清单:
* L; R5 ]4 f8 H. k* R
! A: e2 e0 p, t, i) T7 C0 Y7 N' W2 M- HAL_StatusTypeDef SDMMC1_MMC_Init(void)
1 {. ]3 L& j5 N/ _: S! @ - {
6 L/ m$ o3 r* v1 v - hmmc1.Instance = SDMMC1;4 `6 W i1 _5 C: J
- hmmc1.Init.ClockEdge = SDMMC_CLOCK_EDGE_RISING;/ P) O$ }' `. e! j% B
- hmmc1.Init.ClockPowerSave = SDMMC_CLOCK_POWER_SAVE_DISABLE;- z; x& B- g" L& Z0 |5 z$ h% b
- hmmc1.Init.BusWide = SDMMC_BUS_WIDE_8B;7 V/ u3 i6 D5 }% f
- hmmc1.Init.HardwareFlowControl = SDMMC_HARDWARE_FLOW_CONTROL_DISABLE;) ]. C$ \# [+ H' p1 S9 L) m! v
- hmmc1.Init.ClockDiv = 1;
! q! o; y* f3 S+ j: C - if (HAL_MMC_Init(&hmmc1) != HAL_OK)
0 t% {3 X5 Z! B& A* t - {( m$ @# Z5 d" h
- Error_Handler();7 R4 I* P' X9 u5 x6 W$ n8 c
0 Q: ]1 m4 a6 P0 [* E4 \ - return HAL_OK;
4 k" L; O' [9 x1 R2 f! C; f" V - }
, b: V1 [, S) F, l底层驱动代码清单:
- S# U6 a4 E) u4 w; Q$ j( {6 x9 g! n2 t
- void HAL_MMC_MspInit(MMC_HandleTypeDef* hmmc). X% r/ w; O9 R* d
- { A) [/ |: d2 l, E: T- T
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- q9 _$ N7 T7 }2 V9 B5 e - if(hmmc->Instance==SDMMC1)4 M& H& j+ O" l
2 d# ^/ s" X& p - /* USER CODE BEGIN SDMMC1_MspInit 0 */+ x/ S$ [; I/ `0 y8 V
- /* Peripheral clock enable */
7 M" g l. D# E0 R% t% r2 B o - __HAL_RCC_SDMMC1_CLK_ENABLE();
1 J7 O# s* t" e0 e* d - __HAL_RCC_GPIOC_CLK_ENABLE();, W7 c* L! ]9 `: K# v: S
- __HAL_RCC_GPIOD_CLK_ENABLE();2 Y. q W. @7 f$ S
- /**SDMMC1 GPIO Configuration
+ t' s9 N2 S* Q- O1 U- X - PC8 ------> SDMMC1_D0; E+ K8 U) Y) ?) v& q
- PC9 ------> SDMMC1_D1
9 m q% Q5 Y* z( i - PC10 ------> SDMMC1_D22 G7 q$ s/ _' j( v. l
- PC11 ------> SDMMC1_D3/ g# }" k6 M7 \% j
- PB8 ------> SDMMC1_D4& s# N& I' c, g: O7 W
- PB9 ------> SDMMC1_D5
3 L' t3 a( n& y8 @ - PC6 ------> SDMMC1_D6
( p' t4 I3 S' B - PC7 ------> SDMMC1_D7
& j2 M0 R2 F* n* h& d4 U0 N - PC12 ------> SDMMC1_CK6 Z6 k, r: \8 h- ?& Y
- PD2 ------> SDMMC1_CMD% f- G T& ~* f3 { M1 K7 k
2 O$ Z: G+ s. @5 r; U% K - GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_8 # V. [ [+ W6 c7 M2 D
- |GPIO_PIN_9|GPIO_PIN_6|GPIO_PIN_7;
) F4 K, y. e" J7 ?0 b- G - GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
% g8 t- E& y |% Y6 p G5 j( U - GPIO_InitStruct.Pull = GPIO_NOPULL;
* v5 |7 [* H. P9 y- w+ w - GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
/ b3 f& n1 y5 q0 g - GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1;$ J/ ]9 Z8 d# r) P1 Y; c2 p- O* \
- HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
" p0 r' P7 T0 d! J4 q# ?! ] - $ W5 K% s1 ?4 H& m/ j1 D( B( X/ l0 v
- GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9;) e, M# i8 V- @0 w
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;4 E$ |7 M- k' q, N
- GPIO_InitStruct.Pull = GPIO_NOPULL;, Z- h r; I/ N
9 R [* v3 @7 W/ _) N! l - GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1;
3 w( L2 D0 E5 Q$ D/ M - HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
{/ G6 n2 ^% l u) V/ v - 4 B" b, x$ e2 X! i: P6 u
- GPIO_InitStruct.Pin = GPIO_PIN_2;+ |! z2 b1 O/ t0 S
0 i( L) z3 i* l. b: i - GPIO_InitStruct.Pull = GPIO_NOPULL;
. n) t. J+ j: d6 l/ v5 P - GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;8 y' I7 F; c; K+ B" H* v
: T. G+ }3 V1 w+ ~5 _& ^ - HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
2 n, a6 j3 W% G - ; Y6 I7 H. Q; z3 n- H! g1 p
- HAL_NVIC_SetPriority(SDMMC1_IRQn,1,1); //配置SDMMC1中断
. P- w) B6 O! @5 ? - HAL_NVIC_EnableIRQ(SDMMC1_IRQn); //使能SDMMC1中断
- s! N4 h. O; T9 } - HAL_NVIC_SetPriority(SysTick_IRQn, 0x0E ,0);4 M/ ^. V B4 I( j
. C9 @1 p% e0 B/ \ - }
复制代码 ; K+ L' w& F3 M
在DMA模式下,从MMC卡的指定地址读取数据:% h' z' c1 e' a! u& e$ E6 B) I
" C* J' a6 m6 t; K0 M
- /**& |% y) T( S0 L: h. r
- * @brief 在DMA模式下,从MMC卡的指定地址读取数据
( Z; c+ j. R; t( H2 A& Y; r# A; z - * @param pData:指向将包含要传输的数据的缓冲区的指针
, c5 L: Z; y3 Q: l# j0 z I7 s - * @param ReadAddr:要读取数据的地址
7 c# k3 O$ b4 Z' N - * @param NumOfBlocks:要读取的MMC块数量
- n8 }. f/ T" Q2 | - * @retval eMMC状态
7 u6 |' y! t4 s) ` f - */% [6 v/ ^: D! U4 m! L; ]
- uint8_t BSP_MMC_ReadBlocks_DMA(uint8_t *pData, uint32_t ReadAddr, uint32_t NumOfBlocks): V9 N- e, P7 X( e
- {+ _' O+ T& e8 {: M1 j
- HAL_StatusTypeDef Status = HAL_OK;
/ F3 @/ r3 ~1 q$ v5 K
6 p a# T# L5 \8 `$ A- if(HAL_MMC_ReadBlocks_DMA(&hmmc1, pData, ReadAddr, NumOfBlocks) != HAL_OK)1 N1 z9 S3 f' k3 v: X
1 ?1 T* s7 H+ ?3 t* X - Status = HAL_ERROR;
- \9 j w9 \2 s9 K( N9 U - }
: n9 ~0 P/ s9 H - return Status;
+ X: t7 B8 O8 m. ^! ^ - }
7 ^* H* @0 z9 o在DMA模式下,向MMC卡的指定地址写入数据:
2 E/ h3 r4 r. h- d6 _2 ]5 f' l9 j5 P- |+ s! z; Z! z& x8 I4 i
- /** O' i& A7 Z: ?
- * @brief 在DMA模式下,向MMC卡的指定地址写入数据
- i3 [# K* G8 }5 t- B - * @param pData:指向将包含要传输的数据的缓冲区的指针
' U& q4 Y6 U6 p" D0 N/ K: V - * @param WriteAddr:要写入数据的地址
% P% f# w# [. _! Z4 E3 M# f - * @param NumOfBlocks:要写的MMC块的数量& ~* j" X# S' y8 ]! v
- * @retval MMC状态9 q) j% f# B# b3 k) t
" z0 g! F6 O+ a0 }& t9 h - uint8_t BSP_MMC_WriteBlocks_DMA(uint8_t *pData, uint32_t WriteAddr, uint32_t NumOfBlocks)
1 |( ]4 a/ Z( H+ A) f6 w# p - {
& b+ a- y# d8 k5 s; L - HAL_StatusTypeDef Status = HAL_OK;# T M6 E' r* @4 a( G4 f U. O
0 d! l: \: d2 I; z; E- /* Write block(s) in DMA transfer mode */
9 U6 H$ H6 W$ @& n - if (HAL_MMC_WriteBlocks_DMA(&hmmc1, pData, WriteAddr, NumOfBlocks) != HAL_OK)
9 j' w7 W' Y. z6 \: Q- U. P8 Q9 y - {
: b0 s* x, v2 S' X - Status = HAL_ERROR;
# Z; v3 h" Q( \1 I( G) \, ?1 F& @ - }/ _: e( B3 b0 m0 V8 B" V
- return Status; ' w* A' b$ [4 Y( O0 ?1 x
复制代码 [4 G3 [7 T6 A, n. U2 [
擦除eMMC卡数据:( u ` }; i i) P: v5 y9 J
4 b1 O6 h, _+ t: w, A3 p
* g, v; ~4 R h1 I9 V - * @brief 擦除eMMC卡数据1 n! N. [2 \1 ?' v$ m
- * @param 无
; ^6 Y& ~8 R' s h8 L- |9 ?, A# X8 V - * @retval 无4 Y* z3 b, t( o
- */, D4 s+ T* K; v) O$ E
- void MMC_EraseTest(void)" p' m( D' T; U7 @# Q
- {) L: D& q1 F( L8 l( c6 |6 B: J
- HAL_StatusTypeDef Status = HAL_OK;; k4 T. C5 ^! W) w$ K
- HAL_StatusTypeDef EraseStatus = HAL_OK;! P+ V% o0 R5 V, [
- if (Status == HAL_OK)
' @; Z0 R( S9 R3 ]* _ - {, u; {) v+ G% g8 D( b. q+ a# I( [
- Status = HAL_MMC_Erase(&hmmc1, 0x00, (BLOCK_SIZE * NUMBER_OF_BLOCKS));' a5 O- J+ _2 |5 l& K; c
- //等待擦除完成
- W' j6 m! e4 F5 ]+ N0 v, k - if(Wait_SDCARD_Ready() != HAL_OK)
8 H2 J0 k' @0 j - {
* j- H" k4 W6 |/ b" o5 Y. Q4 B - EraseStatus = HAL_ERROR;9 M& b+ J, z0 G; E5 @. d% s! \# f
- }) y+ X- X8 d' p4 {7 g, A. [
- }2 ~+ j) N7 y9 ]6 Y
- if(EraseStatus != HAL_OK)' |, C) o, h O0 ]2 \" a
" b2 C) u% {! K5 ^ - Error_Handler();
* s1 S1 \4 e9 N$ r' n( @ - }
9 Y/ E4 z1 m# x0 D- ~( ?1 Z! Z) _" J - }
复制代码 3 ]4 ]2 K. w$ Y; @8 A6 i
eMMC卡等待擦除完成函数:* T- T5 o3 p/ t! P6 c
; o9 q+ D! L# R1 i- /**
/ G8 U# g! N. L8 t& c - * @brief eMMC卡等待擦除完成函数$ x, A8 o; I" B! w/ v
- * @param 无( d1 W4 Q9 K2 y) v# A
- * @retval HAL_OK:擦除成功;HAL_ERROR:擦除失败
, V+ @! |$ K* [ - */
* S+ {; ^/ w0 }, {- B7 p$ Z - static HAL_StatusTypeDef Wait_SDCARD_Ready(void)
, T; _" J: h: {9 L" G, V; b; T - {
. {3 y. W( r, o - uint32_t loop = MMC_TIMEOUT;+ [" s9 W* K: e
8 g/ V. A, i/ d6 `+ v5 z- s1 R- /* Wait for the Erasing process is completed */
4 W& d% b C) R" w4 l/ h% p* _ - /* Verify that SD card is ready to use after the Erase */2 J, n0 s& o# q7 @4 N, S
- while(loop > 0)
: d0 q7 K+ w9 { O' O8 i0 \' @9 Q - {
8 H' K! @. y0 M7 q0 ` - loop--;( {+ q( s$ T5 d9 P Y
- if(HAL_MMC_GetCardState(&hmmc1) == HAL_MMC_CARD_TRANSFER)& ]1 v3 @; p7 g' ]8 k
- {6 D8 A, a& C9 {1 n
- return HAL_OK;
8 P9 Q& |0 }( W! _0 ^ - }6 G1 P! K! w5 u, o" M! @; s
- }# E' @% ?: Q6 Z. i! P. ]
- return HAL_ERROR;
; k! T8 f* D+ W; @, V - }
# a+ ?7 g4 ~! o! T+ ?最近移植的eMMC卡的驱动程序,分享出来希望对各位开发者有所帮助。还移植了FATFS文件系统到eMMC驱动程序中,之后整理好再分享。8 s2 x( j# [) q5 p1 M
3 \( ~. d0 R+ G) v! `
( e3 g* V! @/ k+ M( w |
