用定时器生成PWM波: N+ I8 Y6 M# O) j7 h, J: ?/ F
PWM全称是Pulse Width Modulation,通过控制高频信号的占空比,眼睛当成低通滤波器,可以控制亮暗。再循环更改pwm的阈值,就弄出了呼吸的效果。4 \3 a: I- g+ S1 D; W0 R0 T
这里采用一个比较简单的方法生成PWM波:设置定时器中断然后根据阈值判断置高和置低。
5 C+ Q! a; r; F7 P, e# Z- void TIM3_IRQHandler(void) * I) _5 D: ~" B0 d+ x! Y" w
9 B f+ ^3 K& j5 X* P% h - TIM_ClearITPendingBit(TIM3,TIM_IT_Update); 4 f* C: x+ I+ m
- if(counter==255) . S. W- ~4 e. c$ P: i- W/ {6 j
- counter = 0;2 R) z+ N; V, P, @3 a5 h
- else
6 G f( C# C; J: `3 ?( g - counter +=1;
- r- @6 S; f9 p3 Z1 E. `4 X4 X - if(mode == 0){
; e# }# ~$ s+ i$ u - if(counter < pwm) * T2 `1 b+ i5 T0 q G T
- GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1); ) w5 n+ O" }. a- E6 r5 a
- else
5 L, h2 l$ M! R/ | `# M. v0 Y - GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1);
7 g( U' Z: z' f: B - }
: b4 m+ @. d8 v# K8 o. N7 \ - if(mode == 1). T5 I& r# `. ~8 P7 Z6 m/ @4 x' z
- {" _6 ]( w- v* z3 r
- if(counter < pwm) ' {7 l/ W- ~& H& q; }4 w
- GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); 8 J" o- w( t+ j; f! [% B/ W
- else
2 W7 I, _3 V! `& D, V2 P6 x - GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); 2 f. ]3 V6 N4 w3 n. `: g; f$ J
1 I* x3 i, @, E' Q - if(mode ==2){: P! e, R( Q0 x1 F; l% V$ R
- if(counter < pwm) 4 d! A ^0 w) E
- GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0); 1 C% W8 }9 f: B3 X Z9 R
- else . k R2 }# |+ I" M3 r
- GPIO_ResetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0); ' ]- o1 r" Q: g. X
- }- Y# q8 _ ^) ]5 N1 Z
/ k' X% Q9 l) ?) Z4 L" y+ `; N0 n程序流程. }3 @2 z1 s# _; p7 A7 k
开启外设时钟(GPIO和TIM)
0 i5 h7 S/ F6 ?- H$ y. s6 n- void RCC_Configuration(void)
9 L( I; t2 {- {2 f. K6 R - {
! h: y6 V5 L" Q1 _ - RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE); + q( J B6 n. j- K e8 H! a6 ?
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4|RCC_APB1Periph_TIM3, ENABLE);
! U% j9 u% o7 O7 @4 ]5 k4 Y - }
" `; q. g# d2 k0 M0 y- h配置GPIO
, _- a: }4 G: w3 ]配置时钟, 使能中断(计数阈值,预分频,时钟分频,计数模式)
# |4 b% k5 p- `, [- void tim3() //配置TIM3为基本定时器模式 ,约10us触发一次,触发频率约100kHz2 {4 N+ }& ]7 q4 r- S. }& X3 {
) D, d# Y3 Q) H# `) n$ z2 c' C% C - TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; //定义格式为TIM_TimeBaseInitTypeDef的结构体的名字为TIM_TimeBaseStructure 7 P+ B T$ n H
- TIM_TimeBaseStructure. TIM_Period =9; //配置计数阈值为9,超过时,自动清零,并触发中断3 M. i* E# [( B. r7 @0 K+ D
- TIM_TimeBaseStructure.TIM_Prescaler =71; // 时钟预分频值,除以多少8 R( [' X W. _1 m# m& V% c
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; // 时钟分频倍数$ h/ \: h/ l( ^3 J
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; // 计数方式为向上计数8 a" `% F' E( f) o2 ~+ j4 d b, e/ i
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); // 初始化tim3
* X P! s& J2 W+ {0 [, p - TIM_ClearITPendingBit(TIM3,TIM_IT_Update); //清除TIM3溢出中断标志
: H# q1 W% ]' y: @ - TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE); // 使能TIM3的溢出更新中断
|. |9 _0 A9 X( v5 w! p8 c - TIM_Cmd(TIM3,ENABLE); // 使能TIM3
" z5 Q" q! o0 {( K; k( K - }
复制代码 # `. \% h. D& D/ p
配置中断优先级+ t; I# }% U& y/ N( W7 q
- void nvic() //配置中断优先级; O. M. I) @4 f$ H2 A% g
( F' j3 ~- E. j - NVIC_InitTypeDef NVIC_InitStructure; // // 命名一优先级变量' J' ?- Y3 G$ H8 M& |4 l8 [
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); // 将优先级分组方式配置为group1,有2个抢占(打断)优先级,8个响应优先级0 s4 t" q9 s. p* r$ ^
- NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn; //该中断为TIM4溢出更新中断
( B+ ]( L u1 I% A4 p - NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;//打断优先级为1,在该组中为较低的,0优先级最高! l& I. b1 `8 Y% X7 y
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; // 响应优先级0,打断优先级一样时,0最高% G7 q m( F8 y( F/ a" I8 D
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // 设置使能) D7 w1 U# Q3 d& H5 A7 D! ^( ~
- NVIC_Init(&NVIC_InitStructure); // 初始化
) o) H) Q" G; `+ Q9 _# M* M7 T) P8 w - NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); //要用同一个Group h# H% M. @* p( _% e. r0 N
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3 溢出更新中断
# k5 u \9 K" A$ G( I1 i - NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;// 打断优先级为1,与上一个相同,不希望中断相互打断对方9 U( @' l6 }3 a8 H% }
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; // 响应优先级1,低于上一个,当两个中断同时来时,上一个先执行2 q- @2 V# n9 C+ L9 \: Y1 c
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;$ P( f1 Z8 g; H8 L
- W1 R, y4 X( G( F/ |) f6 v" ` - }
复制代码 + F3 ^4 Z! u9 r0 i
写中断服务函数,相关实例请移步:STM32呼吸灯的PWM原理与代码实现。
3 w, l* P' C& r5 ^* y t- S- g) e4 U$ w2 `
代码实现为了方便按键检测,除了TIM3配置PWM波之外,TIM4用来检测是否有输入。由于使用开漏输出,这里使用5V电源。
) r/ u7 \. h! |1 U4 T: f- #include "stm32f10x.h"
, C9 Y6 x! C W) I# w1 ~0 _9 Z - #include "math.h"- n: g+ `) \; W4 U: [
- #include "stdio.h"
( _1 m- O; K% n2 F7 p6 H9 W
7 ^& f& W e) `0 q- u8 counter=0;
$ H6 t+ ?2 M2 M" E - int pwm=100;
, Q6 C5 S7 N G2 [* M& k5 {) o7 u3 _ - int flag=0;9 A- |9 W6 i! f6 b
- int mode =0;9 ] {$ | M* `- H( Y+ o3 m
- int velocity =0;
# w! m' O" h* W# J3 {; U: l1 a R - int turning=1;% r& j. N. ? @4 {/ s( p8 Z
- - B4 W0 {& h2 S
- void RCC_Configuration(void); //时钟初始化,开启外设时钟! |7 a; ^9 p1 S" X( q, [5 h) v4 k4 l
- void GPIO_Configuration(void); //IO口初始化,配置其功能; W+ B9 X0 k! @4 W* o- Q- R
- void tim3(void); //定时器tim4初始化配置
* C T; y( j3 F/ T - void tim4(void); //定时器tim4初始化配置 D5 T! A: e; Z* f/ b! H* k$ ?
- void nvic(void); //中断优先级等配置
- z. q& u4 \: n+ F& ~* M% j - void exti(void); //外部中断配置
* y) S P+ D% o. k! F( M% y: Q - void delay_nus(u32); //72M时钟下,约延时us* h }) V0 ?# K" x0 ~( e: U; k
- void delay_nms(u32); //72M时钟下,约延时ms
3 ^, X9 Z: ]! O - void breathing(int velocity){# N+ u E' \' u$ `. A0 ^. J; k. d
- switch(velocity){
) n, V; K8 l% f" `7 E$ B3 O - case 0:
9 z2 w8 y" Z* O& n6 a' ^ - if(flag)
. M) L9 z( S0 {/ x1 M1 R9 \) r) w - pwm +=1;7 } G) f) W( R
- if(pwm>240) flag=0;
6 k+ w3 t. O5 \% V - if(flag == 0){( d4 [" t# m5 c3 N8 l
- pwm -=1;
0 G' ^8 {( h K9 S9 G, t. j - if(pwm<10) flag=1;: b% S) P5 U% n# [% }% t9 T
& e* _& ]8 f, S - break;3 I# V8 `" _; e, t
- case 1:* R, Z/ j" x! p1 Y0 d7 c5 C
- if(flag)0 Y6 q/ }- y' w* n5 z9 R( F
- pwm +=2;1 R2 m" z* D: N* L. D, K: ?
- if(pwm>240) flag=0;* l; M m0 l, D7 R' S$ |# I" ~
- if(flag == 0){7 N( _& c9 M& ^5 E' G0 K- i
- pwm -=2;
* }( N7 c* v& ~) N5 z - if(pwm<10) flag=1;
& b ~. k2 E1 | - }
# d6 P# c; i$ J j2 {! ]. N - break;" q# H+ ?( [; n3 c8 V
- case 2:
' r0 C) g L$ f; k - if(flag)
2 F5 ?9 q1 R7 V - pwm +=3;
! N- K& n2 ]# b9 r* y# p; E" i" F - if(pwm>240) flag=0;. i& e) {8 L9 ^1 s8 H" E+ m
- if(flag == 0){: t3 u8 d- j+ J0 i
- pwm -=3;' T. X1 \! D' I; `, f) u4 Q' ^7 L
- if(pwm<10) flag=1;; G; a9 u$ {4 y; A
- }9 L2 l# ~/ A6 C9 u& x& z
- break;
' [& \! j, a: R - }* Y9 i+ J$ G* H, T
J8 \- _" P: N* X& J
" G- e& U, K& n7 t, c
y9 `! z8 T; |/ y; M S- void assert_failed(uint8_t* file, uint32_t line)1 W) p, n$ p& V1 a# s: J3 e# Z
- { h, F1 x0 V* p) n+ T" _. }" M; i
- printf("Wrong parameters value: file %s on line %d\r\n", file, line);/ {3 @9 r* ^; @( t+ i" @" z6 y/ `- H
- while(1);
4 m o9 D+ n, k. x i5 v0 l& X - }
p) x% k4 G5 ^9 g& _% ?
& J5 s4 a: a' {3 }, X' p" h: n- void TIM4_IRQHandler(void) //TIM4的溢出更新中断响应函数 ,读取按键输入值,根据输入控制pwm波占空比; g# C0 V' E4 ~% E# d- r
# R+ R( ?, o* S: {$ u* @( n - u8 key_in1=0x01,key_in2=0x01;. N$ E& h# \+ N7 b
- TIM_ClearITPendingBit(TIM4,TIM_IT_Update);// 清空TIM4溢出中断响应函数标志位
* f# N/ q* {/ g; @ - key_in1= GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12); // 读PC12的状态
) {: M) S- R0 }! R# o - key_in2= GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13);// 读PC13的状态) {5 ^ U# a- N O- X+ I0 y6 B1 h
- if(key_in1 && key_in2) turning =1;8 ^! }6 y7 R/ M) d9 M, d# s! t
- breathing(velocity);
. x* f* q p9 W7 g9 ~$ ` - if(key_in1==0 && turning){. l$ O- Q0 F% [/ }# m, d
- turning =0;: M, g7 d: r# c/ G3 [9 l' a- }
- velocity = (velocity + 1) % 3;
6 O- c" K, c+ p9 [& h z - }//调速度) E/ u k) z j- `5 U
- if(key_in2==0 && turning){
2 h$ k3 B& ?' _ - turning =0;
/ ^+ x5 q6 r# _; M8 k2 J - mode = (mode + 1) % 3;% e! }! s6 J/ _: }0 O
- }//调颜色2 ^7 A2 L+ }' o$ C- d( L
* g. E/ i; ?3 o( g2 t+ O0 k - % X; A8 A3 A5 I/ n
/ D% _/ w' G2 `- void TIM3_IRQHandler(void) // //TIM3的溢出更新中断响应函数,产生pwm波. Q7 f0 t3 V+ k! ]1 _4 c0 o; T6 B
3 n! y1 s) H9 X% z% v( ` - TIM_ClearITPendingBit(TIM3,TIM_IT_Update); // // 清空TIM3溢出中断响应函数标志位1 r. b: p1 p( B( u% y' Z. Z
- if(counter==255) //counter 从0到255累加循环计数,每进一次中断,counter加一% O* F( }8 \5 c( ]
- counter = 0;
% O3 p" d$ _0 O7 u - else
J- O S. c7 |! |2 v& h: w! j3 a - counter +=1;
+ j4 M/ W4 L8 _0 D: s4 [6 z - if(mode == 0){
- U v1 Y( h; z/ _5 j" m3 S - if(counter < pwm) //当counter值小于pwm值时,将IO口设为高;当counter值大于等于pwm时,将IO口置低 }! b+ L& Y% _: b% s
- GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1); //将PC14 PC15置为高电平
, |3 v$ j$ _ m4 U( @6 t2 V - else
# R8 V% A# j% t# R - GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1); // 将PC14 PC15置为低电平! ]5 v- }' G: o# x3 ]: w( W O7 X
4 |1 z8 t( G9 M4 s - if(mode == 1)
$ a+ U! g7 g* d! ~; ]" n - {9 u/ t* w8 q) O6 _
1 Q- W! o0 V& x3 u - GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); //将PC14 PC15置为高电平 y; @0 ~! n& R
- else# F+ v% m2 e) q
- GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); // 将PC14 PC15置为低电平0 x; i. W( }( |, ?
# q3 ^0 `7 T0 @' U2 Q - if(mode ==2){
, Z( p1 d& y: U) t - if(counter < pwm) //当counter值小于pwm值时,将IO口设为高;当counter值大于等于pwm时,将IO口置低
/ @( m9 A5 ~0 x1 h0 \ - GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0); //将PC14 PC15置为高电平
9 F% Q G1 d# b7 h) d - else! `( ~; g3 g+ \( Q! X$ J
- GPIO_ResetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0); // 将PC14 PC15置为低电平' Z1 v+ w! @& n! Q- R3 e
( @" [, i: u8 ~- m! K% @ - } / ]- v8 v7 W& ^# K7 @
# e( C/ a; r& g" V- + u& ?; c3 s6 h) d- t
- int main(void)/ T1 K9 h. B& |$ Q
- {6 i. K& M2 q9 b1 f
- RCC_Configuration(); 4 \6 y) X5 I: E3 C e
- GPIO_Configuration();
6 ^. {9 m7 M, c/ u7 v+ \/ k) Q3 o$ [ - tim4();
5 D \9 u/ T/ a, y* o - tim3();
" a' S, \. U' V7 ]- H - nvic();
3 C: |) g4 U) J) q2 `, }6 d - while(1)2 a$ P: `( E2 K
2 R* D# G; Y$ m4 L. N3 U - } ) d. B* L2 B; ^$ k* Z2 t! R
- } ; s4 p' ^4 s/ y6 h, X
6 p- |: b; E, S- void delay_nus(u32 n) //72M时钟下,约延时us
- y( P" R _# p' J% _ - {
# x# z* W- j' s) s8 H( j/ C - u8 i;
8 q% V2 [( s8 H* J c9 Y" ? - while(n--)
9 j4 L+ B, V8 j$ o- e# Z5 V - {
* g' s; W9 ?/ a3 w* \; a - i=7;
0 \' r- o# y; a6 | X - while(i--);
- V/ Y) ]4 L* F7 `& N( F9 t - }
( x' Z, E7 M" l6 R3 ]4 J - }
0 k/ r7 O3 R6 k" V- ? - 0 A4 V5 }% U& J9 a
- / @$ K9 E: ^& s% w
- void delay_nms(u32 n) //72M时钟下,约延时ms
# D7 H: T" @/ j - {
* P; Q0 t2 ^, L8 R9 W& i* w - while(n--)
7 g# G3 H9 ?6 s* d- q3 a - delay_nus(1000);
. g) H* v. s; x; L - }
: d- h8 e Y+ ~
# E! w- @, Y1 ?
3 p, u( ]+ A W" `6 y. c% h; v- void RCC_Configuration(void) //使用任何一个外设时,务必开启其相应的时钟( p& b8 C- i2 i1 j% e
- {8 [8 R) J% V3 J" d
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE); //使能APB2控制外设的时钟,包括GPIOC, 功能复用时钟AFIO等, / ~& G. B& V' C& b6 x1 F
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4|RCC_APB1Periph_TIM3, ENABLE); //使能APB1控制外设的时钟,定时器tim3、4,其他外设详见手册
: m% A2 e5 ~: Z - }5 _* ~( O9 s7 y5 x4 n4 y
- 1 M9 j6 ^2 l# ^1 G1 o
7 ]/ M2 s# r& @, M$ }- void GPIO_Configuration(void) //使用某io口输入输出时,请务必对其初始化配置& D9 x* Z5 O4 r! @- [0 p
# Y. h; j/ X" H0 R - GPIO_InitTypeDef GPIO_InitStructure; //定义格式为GPIO_InitTypeDef的结构体的名字为GPIO_InitStructure # M% f/ Q( O9 D- o2 ~% X' m
- //typedef struct { u16 GPIO_Pin; GPIOSpeed_TypeDef GPIO_Speed; GPIOMode_TypeDef GPIO_Mode; } GPIO_InitTypeDef;
8 }) v7 L) n) u% J3 | - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //配置IO口的工作模式为上拉输入(该io口内部外接电阻到电源)
, C+ r o2 J8 t0 U3 m. d - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //配置IO口最高的输出速率为50M8 p! p6 z4 x0 y+ G
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13; //配置被选中的管脚,|表示同时被选中
6 ?8 Q/ F! f" _2 t! Y/ B O - GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化GPIOC的相应IO口为上述配置,用于按键检测2 G6 u3 A) E: [. Z( q) S
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //配置IO口工作模式为 推挽输出(有较强的输出能力), F( b' p M. N' b9 Q
( W0 ]+ g& M u+ ?4 Z - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2; //配置被选的管脚,|表示同时被选中! P6 Z8 Z* {$ B) k
- GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化GPIOA的相应IO口为上述配置
, l# a7 K3 ~2 u- P$ h4 Q$ \' z - GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE); //失能STM32 JTAG烧写功能,只能用SWD模式烧写,解放出PA15和PB中部分IO口) w* j, M9 ^- R- ~6 N/ ?
- ~0 F" J% F2 E) ? - ; Q. t N4 @4 C7 N" s- o' v
1 m# \, w' H4 H9 X2 ~3 y! C# f, h- void tim4() //配置TIM4为基本定时器模式,约10ms触发一次,触发频率约100Hz0 S0 H( |& i4 d! f4 V5 S* t/ d6 }
- {0 z3 x4 W5 j* {1 A8 q& j5 N
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; //定义格式为TIM_TimeBaseInitTypeDef的结构体的名字为TIM_TimeBaseStructure 7 c2 S6 B: L! Q4 x5 p3 ~2 }( U
- TIM_TimeBaseStructure. TIM_Period =9999; // 配置计数阈值为9999,超过时,自动清零,并触发中断4 J2 Q- B. K. \4 Y$ g+ f3 c/ M7 h$ S1 P
* Z; { Y* P; b$ g; A - TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; // 时钟分频倍数. K9 P" ], X4 D! w9 b5 c! r! i
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; // 计数方式为向上计数, l% \) y, Y) M% A! Z& j. ~
- TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); // 初始化tim4
% _0 _6 w5 |2 Z+ D' W6 g6 }/ g( X7 K - TIM_ClearITPendingBit(TIM4,TIM_IT_Update); //清除TIM4溢出中断标志; Z4 s6 p, |0 ~. F1 R
- TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE); // 使能TIM4的溢出更新中断# e0 k" d* k0 N0 g
- TIM_Cmd(TIM4,ENABLE); // 使能TIM4; W5 S; G: }" D
- }4 f) G4 ~3 ^/ j2 U2 }1 S
$ G. _6 T' l. m, k- 2 \% w1 F5 v2 T9 a6 x
$ C0 C8 l g. E; P {5 d - {7 V# s$ n6 P* ]* D
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; //定义格式为TIM_TimeBaseInitTypeDef的结构体的名字为TIM_TimeBaseStructure 0 z$ j g2 r) V* {6 o
- TIM_TimeBaseStructure. TIM_Period =9; //配置计数阈值为9,超过时,自动清零,并触发中断( j; d6 F5 B) g3 k; t
6 d( S5 r6 H a( W, I" | - TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; // 时钟分频倍数
+ N5 ~/ m5 A1 G6 G; T9 w - TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; // 计数方式为向上计数. F" ^7 G% T$ S0 N8 f
& G& c# g0 w: ?5 n0 g8 ~% U - TIM_ClearITPendingBit(TIM3,TIM_IT_Update); //清除TIM3溢出中断标志2 ]* T! O6 Y: X& R' h4 y
- TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE); // 使能TIM3的溢出更新中断, u8 k) }% R$ }6 R6 }! m: a
- TIM_Cmd(TIM3,ENABLE); // 使能TIM3# G! M3 Z9 e8 ?# t
- }$ K& W5 k& M/ @5 w1 `
: b t: }4 @) K4 L, b+ k7 ^
/ Y. X9 ?' }" d" @3 B& i1 p0 _( N2 H- void nvic() //配置中断优先级
% D! D( l4 F2 Q: ~ - { # R9 R7 y0 |1 }1 l1 Q
- NVIC_InitTypeDef NVIC_InitStructure; // // 命名一优先级变量+ p( U3 F/ m5 t' \/ l: s
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); // 将优先级分组方式配置为group1,有2个抢占(打断)优先级,8个响应优先级$ h: d0 S7 o. O
7 Y! L+ T! ~2 v2 y7 s - NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;//打断优先级为1,在该组中为较低的,0优先级最高
. g/ M; h6 Q3 K. V$ ] - NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; // 响应优先级0,打断优先级一样时,0最高
1 D8 b6 L! q0 @) q: j/ v9 J j - NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // 设置使能9 Y. R7 A, r: f9 n) a
0 a) w! `0 ^5 a( Y* l% E1 k - NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); //要用同一个Group; o) \/ o. o1 B8 e
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3 溢出更新中断" \* s) M: P- k7 S$ e+ A, K5 u6 Y: |
, e& t- s( w+ C - NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; // 响应优先级1,低于上一个,当两个中断同时来时,上一个先执行! w$ P8 E r" ^! X1 X
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;7 H8 q/ W. T, y
- NVIC_Init(&NVIC_InitStructure);3 X* x! o. t j% n1 h
# a$ i7 T K# F
6 y$ p9 S* O" {2 m5 L6 w/ ? |
