【经验分享】STM32使用HAL库IO模拟SPI驱动SD卡
STMCU小助手 发布时间:2022-4-11 10:16
  1. #include "mmc_sd.h"
    / D8 Z  b9 H- u# z
  2. #include "delay.h"
    " r  w6 U* b1 r8 H
  3. ; O% \. X2 a) U* `4 B  H
  4. uint8_t SD_Type = 0; //SD卡的类型
    % J. d. w' z: e! ?
  5. ' ]1 t8 v" Z8 t3 L7 Q9 ?7 F+ N
  6. /// 移植修改区函数 //) ?3 X  c9 J7 k
  7. 2 z( H& e5 q5 H5 K% L
  8. /**& ^) H" ~/ f! ~6 j" m) y
  9. * SD卡SPI接口读写一个字节
    5 o' _( `  {  ~
  10. * @param  TxData 待写入的字节. l! d+ D/ G+ N8 h8 v9 [
  11. * @return        来自SPI的接收
    6 E( b0 P6 H  Z, W. H
  12. */
    3 M$ W: R2 L+ ^% i! e; c
  13. uint8_t SD_SPI_ReadWriteByte(uint8_t TxData)
    : L4 Z1 L+ \4 l( }  `8 T  j8 q
  14. {- n6 w6 C- l4 T" l5 u7 p- x
  15.     int i = 0;6 r/ h9 j$ o* F( ~) g7 i9 o
  16.     uint8_t RxData = 0;
    $ k& s2 Q/ T# l, m5 S6 g- }
  17.     HAL_GPIO_WritePin(SPI_CLK_GPIO_Port, SPI_CLK_Pin, GPIO_PIN_RESET);2 \- O8 R9 M" k5 f' ]3 a
  18.     for(i = 7; i >= 0; i--)
    5 J( p/ f: G; F0 }; |5 e2 @
  19.     {0 R. M$ s& ^4 h
  20.         HAL_GPIO_WritePin(SPI_CLK_GPIO_Port, SPI_CLK_Pin, GPIO_PIN_RESET);
    1 G# P! C' A8 C- {* L
  21.         if(TxData & (1 << i))4 I0 A3 S# Q; J
  22.         {
    / `: \) ?% Q3 `  E* @. {9 N
  23.             HAL_GPIO_WritePin(SPI_MOSI_GPIO_Port, SPI_MOSI_Pin, GPIO_PIN_SET);
    / c; _2 \* w2 U7 X
  24.         }* V; p0 z. r9 v5 k* q- h0 h8 l
  25.         else3 s( C$ `: g5 i" Z* ]
  26.         {
    4 U$ u) ]6 t5 a: l7 k- g: `  f
  27.             HAL_GPIO_WritePin(SPI_MOSI_GPIO_Port, SPI_MOSI_Pin, GPIO_PIN_RESET);
    . f% E. v! e$ `7 Z% {
  28.         }2 A+ m7 q+ a5 y3 K7 r$ T2 U$ G' _
  29.         delay_us(1);0 m0 g9 @* [$ o/ T( s1 R6 Q
  30.         HAL_GPIO_WritePin(SPI_CLK_GPIO_Port, SPI_CLK_Pin, GPIO_PIN_SET);
    : e& d0 \( u6 G4 F" n& W6 q
  31.         RxData <<= 1;
    0 t: k, P* g( ~" x; e2 T; D' A! N
  32.         RxData |= HAL_GPIO_ReadPin(SPI_MISO_GPIO_Port, SPI_MISO_Pin);
    9 ^; }( D3 v1 f: b
  33.         delay_us(1);; ]  v6 p; p* H2 J
  34.     }! f0 [( l& y4 N! w& f3 P3 I0 T
  35.     HAL_GPIO_WritePin(SPI_CLK_GPIO_Port, SPI_CLK_Pin, GPIO_PIN_RESET);' N8 F2 d2 R. s+ B1 A9 L1 \
  36.     return RxData;& }4 Q3 f+ k: _! H
  37. }' G% j) M! h$ j
  38. 9 Q  U0 _) [/ E* n
  39. /// SPI硬件层初始化. G7 p8 Y. C: [( Z8 w  E
  40. void SD_SPI_Init(void)+ @9 v% O# h2 E" f( Y& d; F' i) |
  41. {, A# U! h3 a4 ]( ^3 K/ d
  42.     HAL_GPIO_WritePin(SPI_CLK_GPIO_Port, SPI_CLK_Pin, GPIO_PIN_RESET);    /* 时钟空闲为低电平 */4 i: a8 X6 U  Y6 B" O1 E* \
  43.     SD_SPI_ReadWriteByte(0xFF);
    ! f9 \6 k0 A2 p2 S; ^
  44.     SD_CS_H();
    4 ]  b# Z: b4 N' T; H' j  [: f
  45. }& S! f: C. e! M5 |
  46. , k& o# [) w. Q& G& q  B  `
  47.   SD SPI 驱动代码  /
    " U& t& K7 Y' R. O0 h0 z0 P
  48. - `6 h- C6 o% Y- L% r, [, V! k
  49. //取消选择,释放SPI总线
    . E  k' {1 T; p4 d- _
  50. void SD_DisSelect(void)9 P8 s1 y! o2 H  [; V$ i( S
  51. {
    9 a! S+ C  {% y
  52.     SD_CS_H();) I& z( R5 j: @# \' J
  53.     SD_SPI_ReadWriteByte(0xff);//提供额外的8个时钟
      X5 Y* Y/ C6 j  V5 W
  54. }% g/ n( e" `5 z5 s5 _
  55. 4 K1 v. p6 Q2 m: r% ?
  56. /**. H4 \! }1 s# M
  57. * 选中SD卡并等待卡准备好8 B( A; E; ]$ X4 i# o
  58. * @return  0:成功  1:失败/ s8 m  ~3 ~4 C) w$ ?
  59. */7 h5 g- Y: D* e7 Z* ^* _& q
  60. uint8_t SD_Select(void)( F6 m( q+ _. f3 \8 j
  61. {3 V* I5 G  b  A/ m, J+ }9 {
  62.     SD_CS_L();/ m: K$ j. B3 m/ n
  63.     if (SD_WaitReady() == 0)return 0; //等待成功
    7 |  i% `* z- n3 O9 y: J7 V6 Z
  64.     SD_DisSelect();
    ! F8 R& w4 r3 p9 f  o
  65.     return 1;//等待失败
    / _* G$ ~# @& @: T/ b
  66. }
    - q0 t( z9 t  N9 F- ^0 @0 }
  67. : n' M# L; |5 v9 @# i
  68. /**. G5 Z8 g/ P, }7 Z- W) \
  69. * 等待SD卡准备好
    9 y, p% z: z$ B# l( B' B3 U
  70. * @return  0:成功  other:失败
    / J- o" Z) @& }1 f( b
  71. */
    6 d4 d, R8 z- a; `" s
  72. uint8_t SD_WaitReady(void)
      y: u& v+ s0 D2 f9 d
  73. {
    3 T7 S! V+ L- m
  74.     uint32_t t = 0;. Q( M/ @; Q- {' q! n, n+ a
  75.     do% `- _2 X6 w* \1 n- M
  76.     {4 ~- R5 I+ x4 w4 U) s
  77.         if (SD_SPI_ReadWriteByte(0XFF) == 0XFF)return 0; //OK
    7 `" e- B& @, R3 x
  78.         t++;
    / L* y$ c$ j! |; r+ x* n- v
  79.     }
    & \& f" o; l. N9 R2 }0 n
  80.     while (t < 0XFFFFFF); //等待; M, U+ R1 a; r
  81.     return 1;
      T% }" O$ u* u% J" m
  82. }
    9 L0 c& y4 y: \
  83. + u: X; l; z+ n  i
  84. /**
    0 e; o% M; W% b1 G
  85. * 等待SD卡回应* D5 i; e( V2 Q# [
  86. * @param  Response 要得到的回应值: j% ]0 [- Y( v$ a: p8 r
  87. * @return          0:成功  other:失败
    ' a& h5 [3 N- ~! _) P& H
  88. */, J) Z. C0 b' f. s" e, z8 N
  89. uint8_t SD_GetResponse(uint8_t Response)
    / j& V, {% z0 @* J3 }
  90. {
    + K9 }7 }, e# U  P: T! F
  91.     uint16_t Count = 0xFFF; //等待次数
    & Q. Q. E8 N( l: Z% H
  92.     while ((SD_SPI_ReadWriteByte(0XFF) != Response) && Count)Count--; //等待得到准确的回应
    9 \$ l: ]/ o0 _4 j" h
  93.     if (Count == 0)return MSD_RESPONSE_FAILURE; //得到回应失败  N6 _) P( Q0 g; @! l
  94.     else return MSD_RESPONSE_NO_ERROR;//正确回应( |+ _8 F! Y, x+ w
  95. }  t, H7 K% U8 ^3 ~3 y
  96. 1 q: z0 O+ h7 B( D
  97. /**; o, y6 Z9 Y3 U  q9 }5 b
  98. * 接收来自SD卡的一包数据
    8 X! G8 m! K- E! K* P$ y
  99. * @param  buf 存放接收的数据: \% H+ [3 u3 k! I
  100. * @param  len 接收的数据长度, ^5 d; O( q6 U( `
  101. * @return     0:成功  other:失败
    9 v, @. q( u4 K2 u9 x/ Y0 }
  102. */; ~, m- g) V' L( Y. V
  103. uint8_t SD_RecvData(uint8_t*buf, uint16_t len). ~, e+ K9 c2 L% `8 f
  104. {
    - ]4 o6 w+ x3 R% v. u! U
  105.     if (SD_GetResponse(0xFE))return 1; //等待SD卡发回数据起始令牌0xFE
    : d! M; v! G9 ^8 D. t
  106.     while (len--) //开始接收数据  k! X0 `% \6 N4 O$ i
  107.     {
    ) Q  F* V6 n$ t+ A$ V
  108.         *buf = SD_SPI_ReadWriteByte(0xFF);* X5 H1 c" I4 y5 I
  109.         buf++;$ i& l( A* \) z- L4 r( }$ r6 O
  110.     }- d- y6 m1 o3 i+ C- y# W; Z/ d" d
  111.     //下面是2个伪CRC(dummy CRC)
    " [  S' J9 k7 b( \) n
  112.     SD_SPI_ReadWriteByte(0xFF);& r- S* o. }4 h3 ?9 Q& Y$ {8 ]
  113.     SD_SPI_ReadWriteByte(0xFF);$ u4 ]+ ?( D* b& u6 i. o" G
  114.     return 0;//读取成功. q1 U* c* E. |0 ?% c4 |5 m) a
  115. }8 u8 F) {& I. S. G  G" M
  116. //向sd卡写入一个数据包的内容 512字节
    5 t5 k( p4 u) c3 I5 @+ G% ]
  117. //buf:数据缓存区; H2 i  ?: |# u. }' }9 ]
  118. //cmd:指令! t" r8 I2 o; {0 W1 A
  119. //返回值:0,成功;其他,失败;3 ]7 O; _5 H' p$ k( M& E7 L
  120. ) F( p) O4 L7 z$ S
  121. /**" z. X) G6 Z1 d# N6 C  M4 ]
  122. * 向SD卡写入一扇区数据$ S, `3 s- y1 j2 c- u4 z  S
  123. * @param  buf 待写入的数据,size=5123 }( O5 `$ f6 x7 N- M' D+ K2 t
  124. * @param  cmd 指令
    8 {# M& ~7 q8 W
  125. * @return     0:成功  other:失败
    7 P+ O) [! I5 M6 z2 j# W+ P
  126. */% f7 E1 x4 W- v/ O, X1 B9 ~9 k  k
  127. uint8_t SD_SendBlock(uint8_t*buf, uint8_t cmd)
    4 \8 U- c. f, U, e4 q
  128. {7 f9 ]: S5 B: b: G
  129.     uint16_t t;
    ) b9 x! Y' t6 h! k, ^; q  @. t' m
  130.     if (SD_WaitReady())return 1; //等待准备失效8 M% c& h. B3 H+ c3 C0 s% Q
  131.     SD_SPI_ReadWriteByte(cmd);8 }, H! n5 u. a2 Z
  132.     if (cmd != 0XFD) //不是结束指令, o4 w" J, _- A
  133.     {7 V4 A3 s+ ]8 v' w9 ?- ~5 R
  134.         for (t = 0; t < 512; t++)SD_SPI_ReadWriteByte(buf[t]); //提高速度,减少函数传参时间
    & k/ c& C6 R/ n+ [
  135.         SD_SPI_ReadWriteByte(0xFF);//忽略crc" }, O: C6 a1 b- z( u  p
  136.         SD_SPI_ReadWriteByte(0xFF);
    0 q: E) D( p3 y& [* P
  137.         t = SD_SPI_ReadWriteByte(0xFF); //接收响应
    ) L4 q9 W. G" \, m: e
  138.         if ((t & 0x1F) != 0x05)return 2; //响应错误; y1 D, J$ [. i
  139.     }- X7 z( C$ U3 s
  140.     return 0;//写入成功. l2 u( X% b7 R+ @+ K
  141. }9 s% l8 f' P+ U9 t
  142. 5 p6 A" K- ]: k7 R/ q/ {
  143. /**! i: Z+ j+ J( Z3 ?
  144. * 向SD卡发送命令
    8 }8 z; @4 p9 U
  145. * @param  cmd 待发送的命令
    & J$ w" K3 Y0 G! G: T* F1 {
  146. * @param  arg 参数* l5 E9 y4 k( e6 f
  147. * @param  crc crc校验值
    / ]$ g: Q6 z6 L
  148. * @return     SD卡返回的响应值3 ^/ D, k8 F+ N# y8 r
  149. */5 h4 L5 Y- V( X& L9 G' j5 \8 N/ I
  150. uint8_t SD_SendCmd(uint8_t cmd, uint32_t arg, uint8_t crc)
    4 G9 v6 p+ P/ {4 ?% l4 ]# ?' j1 [
  151. {
    . z+ A% E$ ]! S1 ?6 v! ]
  152.     uint8_t r1;
    $ z  D0 h$ u% G/ f
  153.     uint8_t Retry = 0;/ l' B' O4 r  z) J
  154.     SD_DisSelect();//取消上次片选" A& O5 _8 \) y- o' f. S
  155.     if (SD_Select())return 0XFF; //片选失效# h. p" u8 C+ H2 D
  156.     //发送& Z! H# s, W$ O$ p
  157.     SD_SPI_ReadWriteByte(cmd | 0x40);//分别写入命令
    & i/ A7 ~' F4 L, V8 F# n1 P
  158.     SD_SPI_ReadWriteByte(arg >> 24);0 r; H: f- {  O3 }8 C
  159.     SD_SPI_ReadWriteByte(arg >> 16);7 C! s* H" f- B  R1 C5 f
  160.     SD_SPI_ReadWriteByte(arg >> 8);
    ' c8 B5 k4 q- @8 s7 I  ~1 M% l- e2 i
  161.     SD_SPI_ReadWriteByte(arg);8 Q# u% ~$ U' a' z
  162.     SD_SPI_ReadWriteByte(crc);: ~+ `6 j/ H9 D7 P/ R; P  k
  163.     if (cmd == CMD12)SD_SPI_ReadWriteByte(0xff); //Skip a stuff byte when stop reading% x: V; s- J" o9 x
  164.     //等待响应,或超时退出# S1 \' W$ O6 ]5 a* i
  165.     Retry = 0X1F;* g, l# Y, _# m) r9 p
  166.     do" h* z) z* b+ g) U+ H
  167.     {
    - x+ A# b3 X' H& M* Y0 k. f2 Q
  168.         r1 = SD_SPI_ReadWriteByte(0xFF);8 J5 w$ s0 A  y  L
  169.     }" R; e( _: k" E
  170.     while ((r1 & 0X80) && Retry--);( a) g1 o& c: c. M* T: N) P
  171.     //返回状态值
    0 B* x, F- P. T$ }# `! T. }5 p
  172.     return r1;& }9 W3 {7 Z9 {6 v0 [- D: ^
  173. }: q7 ^1 @. O+ a' T+ o
  174. 3 e9 _/ f& q# K2 F
  175. /**
    , Y" z9 t+ l1 C% P, d8 e
  176. * 查询SD卡的CID信息,包括制造商信息" V- N2 v" Z% b" S
  177. * @param  cid_data 存放CID数据,至少16字节
    & E# `# b+ Y4 p$ y- U: R' {
  178. * @return          0:成功  1:失败* w+ q* x7 w# b7 a- Z
  179. */% q7 M+ |4 M3 C% T. B& p' X5 P
  180. uint8_t SD_GetCID(uint8_t *cid_data)
    " ]! b5 H: m& ~; f* [
  181. {/ @) b( _3 @8 g
  182.     uint8_t r1;
    7 ^/ B0 e/ V/ ?+ [/ o- w8 e7 H" w& y$ ]
  183.     //发CMD10命令,读CID: S& b) P( `: G
  184.     r1 = SD_SendCmd(CMD10, 0, 0x01);; T* i, n, s8 g8 x( f+ h% x
  185.     if (r1 == 0x00)5 }& a, Z( [! H' X. P" g" {7 f
  186.     {
    " Z; l4 @$ C& e% O$ c+ {
  187.         r1 = SD_RecvData(cid_data, 16); //接收16个字节的数据+ I0 H( _; ~- |7 ~: U7 t& }/ Y- F
  188.     }2 c# ]/ s: F5 J2 z; R& J4 A; [
  189.     SD_DisSelect();//取消片选8 \1 v* {7 V, B, k: F( r
  190.     if (r1)return 1;
      x% j% u* _! W: J3 {
  191.     else return 0;
    & Q0 C  G0 N5 F4 R" z9 ?6 P' x5 M
  192. }
    4 W  S, K3 D( A4 d3 B* h$ E' R
  193. , L% C7 k0 r% v5 `& |  g, w
  194. /**; w9 A$ `/ {& o
  195. * 查询SD卡CID信息,包括制造商信息/ _1 n$ N9 ^9 u' @) |6 _9 Q
  196. * @param  csd_data 存放CID信息,至少16字节
    / m" d7 E( f0 h* H$ q* v
  197. * @return          0:成功  1:失败
    , N  r# M( b; T4 `( p& w
  198. */1 V" h" |8 p" T4 u& d
  199. uint8_t SD_GetCSD(uint8_t *csd_data)7 U/ l! Y: l( x$ Z
  200. {
    ( O% u# x3 T: B
  201.     uint8_t r1;& F3 a- Q0 U. e1 y: N8 K3 ^
  202.     r1 = SD_SendCmd(CMD9, 0, 0x01); //发CMD9命令,读CSD. |' d* U  \* J5 h4 X
  203.     if (r1 == 0)9 {% y2 w) P6 \& V! t' L" F% O7 G6 P1 V
  204.     {
    3 N: n' E4 P- }5 Z2 m
  205.         r1 = SD_RecvData(csd_data, 16); //接收16个字节的数据
    ) ^. i3 Z# H3 m
  206.     }
    0 N" Z* w3 \, ^5 T" Y; {" O& a
  207.     SD_DisSelect();//取消片选# n9 s4 }" L3 x- Y" p& q
  208.     if (r1)return 1;
    ' l) Q, Z) E# P* w$ x
  209.     else return 0;/ f/ o% A( l5 N, T- T0 S0 @: T
  210. }
    . H7 J* b  R) P$ E, c0 }) N
  211. /**
    ! {  \% U: [# i( U
  212. * 获取SD卡扇区数
    9 ^) H* ?* U4 F9 k; g
  213. * @return  0:获取出错  other:SD卡扇区数
    1 C: {, M) A$ e- }
  214. */
    9 o7 O  h! Q  Y/ s5 R( n: {
  215. uint32_t SD_GetSectorCount(void)
    0 g! q# W; F/ y" K3 k5 {
  216. {. e3 R; p, F( V2 r1 G" Q4 Z0 @
  217.     uint8_t csd[16];
    ) o4 u/ C& b6 n
  218.     uint32_t Capacity;
    - h1 E) }/ Y4 e5 b! U6 y
  219.     uint8_t n;
    6 S4 _; U' d6 j7 y4 E% k
  220.     uint16_t csize;
    7 Q* x/ @( K0 c% S+ y0 d
  221.     //取CSD信息,如果期间出错,返回0
    ' ?& R% @9 z5 J9 ^. r
  222.     if (SD_GetCSD(csd) != 0) return 0;+ C* ~& _- [# d. D% ]+ w" a
  223.     //如果为SDHC卡,按照下面方式计算
    % l" M; a! x, p: z
  224.     if ((csd[0] & 0xC0) == 0x40)         //V2.00的卡
    ; C- w! T5 E) v& ]# U$ B2 j* A
  225.     {7 [+ ?% s; r$ O5 A9 }$ L7 _) k3 C
  226.         csize = csd[9] + ((uint16_t)csd[8] << 8) + 1;
    , |+ U8 q6 L/ S, \
  227.         Capacity = (uint32_t)csize << 10;//得到扇区数4 Y: k; P1 S! P6 R& J( V5 v) N. S
  228.     }" x$ e- t3 R( J% B2 r" @0 h
  229.     else //V1.XX的卡; `" x. P7 P! e. q* h
  230.     {
    7 w/ O! h7 ]' g' U  s) h; ^
  231.         n = (csd[5] & 15) + ((csd[10] & 128) >> 7) + ((csd[9] & 3) << 1) + 2;. l. E# S' }3 h& r
  232.         csize = (csd[8] >> 6) + ((uint16_t)csd[7] << 2) + ((uint16_t)(csd[6] & 3) << 10) + 1;
    : Z7 V/ Q4 `( v; C# k
  233.         Capacity = (uint32_t)csize << (n - 9); //得到扇区数( Q# l) ~* u0 i! v3 s
  234.     }$ M3 y3 b4 b# m* S4 X
  235.     return Capacity;1 _, `" K- x1 ^8 m* S! [7 _
  236. }
    : b6 Z& T8 i* W7 b
  237.   e# o% _. l  U; V0 i& S# \3 m
  238. /// SD卡进入闲置状态
    & F+ }2 l3 p' ~" @. u' h
  239. uint8_t SD_Idle_Sta(void)
    7 l5 q5 f$ d0 G- N1 u3 T) p
  240. {
    9 l" S- @4 J2 Z+ _
  241.     uint16_t i;, T9 s% K+ u+ U2 }
  242.     uint8_t retry;; d7 E$ f1 D: B# i: L( @* y
  243.     for (i = 0; i < 0xf00; i++); //纯延时,等待SD卡上电完成+ c: `% Z- ]9 Z( W# J! z
  244.     //先产生>74个脉冲,让SD卡自己初始化完成
    6 C1 I' B: P: @
  245.     for (i = 0; i < 10; i++)SD_SPI_ReadWriteByte(0xFF);
    1 g$ C7 r. c7 Y, ]- \
  246.     //-----------------SD卡复位到idle开始-----------------+ p" D1 O" w# K( ]
  247.     //循环连续发送CMD0,直到SD卡返回0x01,进入IDLE状态
    4 ^; E. C- A; Q9 k8 A
  248.     //超时则直接退出$ p! T9 h; Q1 @. K0 k# h! r* g
  249.     retry = 0;" ?- n# E& W* ?, a$ R3 \  x
  250.     do
    % \. G: Y9 Q$ e2 E8 b
  251.     {2 s/ E* Z- ^( k3 U! {, D
  252.         //发送CMD0,让SD卡进入IDLE状态
    + S0 s) X8 B) i1 }) s8 j4 `
  253.         i = SD_SendCmd(CMD0, 0, 0x95);0 y1 I7 k# O3 {7 H% [
  254.         retry++;
    0 X3 h* C7 r- o" f2 Z3 `" F# e; e
  255.     }
    + H5 B4 O1 ]# d
  256.     while ((i != 0x01) && (retry < 200));% X! @% X5 y# |0 E1 k
  257.     //跳出循环后,检查原因:初始化成功?or 重试超时?
    8 r3 H: d$ i5 o8 J) `0 c
  258.     if (retry == 200)return 1; //失败# t# K- E- Z4 c3 g; e
  259.     return 0;//成功
    ; A) l2 K. p' W3 {- o
  260. }
    2 h- u. r% \- b3 U5 b  T: x* k
  261. /// 初始化SD卡
    8 c& W& R6 D/ F* K7 \2 y) `" K) }0 W
  262. uint8_t SD_Initialize(void)
    $ I0 i$ s9 l4 m1 M5 u
  263. {! L- _6 U7 n& q, |2 ]+ \; d  S2 L
  264.     uint8_t r1;      // 存放SD卡的返回值- @3 D* y4 F6 e: s
  265.     uint16_t retry;  // 用来进行超时计数
    4 d% X/ U' l0 ^8 C* z; o+ K
  266.     uint8_t buf[4];
    9 l# f( m$ G: D; B
  267.     uint16_t i;
    ) ~" M1 `" Y$ W/ n5 J3 O
  268. , C9 w2 d2 H4 {$ n3 p
  269.     SD_SPI_Init();                //初始化IO
    ' m6 ]+ ]" U" k/ j4 U( w3 a1 q
  270.     for (i = 0; i < 10; i++)SD_SPI_ReadWriteByte(0XFF); //发送最少74个脉冲) x' @: G7 p( s8 i3 W) Q& W
  271.     retry = 20;
    & L# Z- f# l. F, J& S" g" s4 E- [
  272.     do
    % K. E+ N. P% p
  273.     {
    - t# D. ^2 ~# s% w  g) X
  274.         r1 = SD_SendCmd(CMD0, 0, 0x95); //进入IDLE状态& c$ B( F/ y' x* j  y# T) {. e
  275.     }4 }; ^& _4 N: c* X& a2 r
  276.     while ((r1 != 0X01) && retry--);. e/ v9 y6 S4 z3 a; d8 k
  277.     SD_Type = 0; //默认无卡
    ; N( G3 \% N" x, S6 Z
  278.     if (r1 == 0X01)" Z. Z' C  y  M( n6 F
  279.     {  Z8 b+ G7 \( X0 Q
  280.         if (SD_SendCmd(CMD8, 0x1AA, 0x87) == 1) //SD V2.0
    0 `+ d" ?1 c, ?- F% i! f+ V
  281.         {
    $ C3 Q) S9 D% @) L7 I$ y
  282.             for (i = 0; i < 4; i++)buf = SD_SPI_ReadWriteByte(0XFF);        //Get trailing return value of R7 resp
    $ Z2 |: F: }( y+ t
  283.             if (buf[2] == 0X01 && buf[3] == 0XAA) //卡是否支持2.7~3.6V$ a. k; _, t0 j
  284.             {, y& w  i% y4 x
  285.                 retry = 0XFFFE;' T$ S. [9 F* n7 Q5 l
  286.                 do% p8 Z: F+ f6 I8 G1 e/ @
  287.                 {
    4 Q- S6 _) |* c2 D* e
  288.                     SD_SendCmd(CMD55, 0, 0X01);        //发送CMD55
    * E; R: s4 E" x7 ?3 ~+ y
  289.                     r1 = SD_SendCmd(CMD41, 0x40000000, 0X01); //发送CMD41) f7 J7 L& p" D
  290.                 }
    : ^9 B) B2 D8 a( Y
  291.                 while (r1 && retry--);
    + m4 z1 U, Y4 _4 Z- ]4 N! N- j
  292.                 if (retry && SD_SendCmd(CMD58, 0, 0X01) == 0) //鉴别SD2.0卡版本开始
    5 D3 _8 S2 ]# T+ Q' _6 W/ Q7 h
  293.                 {
    % ]* |8 a; X4 [1 I
  294.                     for (i = 0; i < 4; i++)buf = SD_SPI_ReadWriteByte(0XFF); //得到OCR值+ G. p* p4 x8 G3 X  L
  295.                     if (buf[0] & 0x40)SD_Type = SD_TYPE_V2HC; //检查CCS
      `. z; q$ t8 p9 T# E
  296.                     else SD_Type = SD_TYPE_V2;
    1 }1 Z0 M" K- F6 ]7 G2 G
  297.                 }
    8 N: g, ]" T5 P+ m
  298.             }+ B6 i2 b( @# i& v' A4 }; L  {/ n
  299.         }& N# o, ~; i8 p6 D, f
  300.         else //SD V1.x/ MMC        V35 V4 Z! E% q' _/ `( h) t8 \- G
  301.         {
    5 Q. @3 n# ?7 w9 o9 _* s
  302.             SD_SendCmd(CMD55, 0, 0X01);                //发送CMD55
    0 ~$ l7 @+ d6 a4 `; O' C
  303.             r1 = SD_SendCmd(CMD41, 0, 0X01);        //发送CMD41
    # L- O$ i2 V1 H# d7 A- l$ e* Y6 Z
  304.             if (r1 <= 1)
    2 S- u# _2 W3 h, ~% U
  305.             {% D( f0 I+ P, P! F- V
  306.                 SD_Type = SD_TYPE_V1;; k" p) F- ^$ q1 F$ l: s# U$ u
  307.                 retry = 0XFFFE;- K# ~& R) L4 g* v- ^* H
  308.                 do //等待退出IDLE模式. ]% s$ G+ F* `  E* y" O8 N: f
  309.                 {
    1 K1 R$ y/ v! t, Q
  310.                     SD_SendCmd(CMD55, 0, 0X01);        //发送CMD55
    & f2 L, x) k) p6 g9 b, A
  311.                     r1 = SD_SendCmd(CMD41, 0, 0X01); //发送CMD411 Y, e* f8 ?7 h" ~, D" e& S; J
  312.                 }: w% z5 B4 n3 |  ^, K
  313.                 while (r1 && retry--);
    0 k& s$ P0 J8 T, K& A( K
  314.             }
    , H' ]3 V3 E$ @/ P
  315.             else: l% j% _. M2 O) n$ ?
  316.             {% `; w( {# u7 l  i" x
  317.                 SD_Type = SD_TYPE_MMC; //MMC V3
    / n& B7 q/ q1 ]8 R* y# r
  318.                 retry = 0XFFFE;
    + F6 o7 o6 C+ l3 v( O
  319.                 do //等待退出IDLE模式
    , W% H  d( m$ p7 P
  320.                 {
    . S! |% L- X/ }( y# o- q) ?
  321.                     r1 = SD_SendCmd(CMD1, 0, 0X01); //发送CMD1
    $ I: g$ S6 o- `3 c* w
  322.                 }
    6 p4 s- Q: ]$ H
  323.                 while (r1 && retry--);9 P+ H# x- u0 l. y7 A; l/ G  g3 E" j
  324.             }
    ; K( i, F5 W0 i+ r
  325.             if (retry == 0 || SD_SendCmd(CMD16, 512, 0X01) != 0)SD_Type = SD_TYPE_ERR; //错误的卡
    - H% r* ^! l% \1 _) `
  326.         }% m& Q! b% b0 b/ E1 S1 h
  327.     }- @  K% D( C) P  Z5 A, Y: a- V. t
  328.     SD_DisSelect();//取消片选
    ; q) R5 j; g2 a. a0 D
  329.     if (SD_Type)return 0;
    1 j: V" a5 [8 @- w* |  \7 V
  330.     else if (r1)return r1;- I& u& |9 _+ C( A1 {4 h' l
  331.     return 0xaa;//其他错误  l2 G3 W! [0 H: z) w  @# T
  332. }9 \7 Z+ z* K( h3 @- y
  333. 3 _1 K) B, ~* c
  334. /**
    2 M7 m6 h# W, ]$ i' c& p5 B1 k
  335. * 读取SD卡一个扇区
    * x' n9 a. h3 [6 k$ t' c; b$ \9 P8 @  v
  336. * @param  buf    存放读取的数据3 W! t2 Z- s5 e8 ~% u
  337. * @param  sector 扇区编号
    8 V5 a1 S6 ]1 f
  338. * @param  cnt    要读取的扇区个数
    ) V" s! K) n# x6 {: x$ f
  339. * @return        0:成功  other:失败/ o& a; ^9 j- t7 t( v9 _# ]0 L
  340. */
    - m, R. Y4 s& d. I
  341. uint8_t SD_ReadDisk(uint8_t*buf, uint32_t sector, uint8_t cnt)
    9 X" j4 o: L' h/ m5 u
  342. {
    5 w) o6 E$ X; {( }% q$ s4 Q* E
  343.     uint8_t r1;
    & z  g" C2 F3 o& H
  344.     if (SD_Type != SD_TYPE_V2HC)sector <<= 9; //转换为字节地址
    , {3 b; }4 r8 {; G0 M" Q: C
  345.     if (cnt == 1)" L' Y6 X) `/ v7 P
  346.     {7 m2 e: q9 l: Z: ?0 h+ O, K& L
  347.         r1 = SD_SendCmd(CMD17, sector, 0X01); //读命令4 p. J& J5 f9 C) Q* N; X5 q1 U
  348.         if (r1 == 0) //指令发送成功: f8 f) W. v1 d8 |: [# d
  349.         {
    + N. n# x! y4 r* v. b
  350.             r1 = SD_RecvData(buf, 512); //接收512个字节
      L# x- \+ ]+ n* }4 u7 o% {# Y
  351.         }
    2 h/ ^  ^6 R* v4 Z- V4 q+ b$ S
  352.     }
    $ p  Q' S, z/ k4 c. A* @/ E
  353.     else
    & ~& a4 G  x0 d% l% p. W
  354.     {
    5 `# [3 }5 ]. B2 d' `9 w8 N' d7 t
  355.         r1 = SD_SendCmd(CMD18, sector, 0X01); //连续读命令
      y3 v5 a$ D8 @" D5 F9 N/ \" X6 S
  356.         do" z/ M8 B( R/ N; U2 y, K
  357.         {8 z! k) k5 o0 K9 D  v: x0 [
  358.             r1 = SD_RecvData(buf, 512); //接收512个字节
    ( C% A. t2 L/ G6 L& _
  359.             buf += 512;
    + D+ h4 z- N5 T
  360.         }- ?/ `5 u( {5 G
  361.         while (--cnt && r1 == 0);, ^" S. }9 {/ G. m6 G- A' p
  362.         SD_SendCmd(CMD12, 0, 0X01);        //发送停止命令
    8 `( c- T" C8 l0 n- X# {  l& Z! j
  363.     }5 [0 z# [6 r4 Z! H+ U
  364.     SD_DisSelect();//取消片选' P1 A4 n- G" i! |
  365.     return r1;//9 d/ l+ v: j4 |" y
  366. }
      {3 `0 v! w8 x
  367. % i) F* w7 x9 N) X
  368. /**4 v0 V( n. |( v- L! p5 E
  369. * SD卡写一个扇区的数据9 K+ L( e! h2 e
  370. * @param  buf    存放待写入的数据( s2 U2 {/ N  Z7 B6 G; t9 F
  371. * @param  sector 扇区编号
    9 b; X7 j+ T6 e6 }5 \) R! _5 |
  372. * @param  cnt    要写入的扇区个数
    ! }2 `# c4 N2 d& {8 m( b* {
  373. * @return        0:成功  other:失败8 q+ V% \, s6 [8 b1 I1 Y
  374. */9 s9 x" Q5 W* w5 P7 D
  375. uint8_t SD_WriteDisk(uint8_t*buf, uint32_t sector, uint8_t cnt)0 l) k0 }3 Y! o# N
  376. {
    3 T% J" }, f1 Z" j. B
  377.     uint8_t r1;3 M) E$ }8 \* \5 Q% g1 c/ y3 S7 O
  378.     if (SD_Type != SD_TYPE_V2HC)sector *= 512; //转换为字节地址
    / q2 B5 E$ ~' S. h# a4 F1 x9 _, _
  379.     if (cnt == 1): m4 u( A. ?+ W( l" C
  380.     {
    * T. B# _1 E8 f/ D9 t0 R
  381.         r1 = SD_SendCmd(CMD24, sector, 0X01); //读命令# y- z( t7 u) c5 h' I% \* x3 s
  382.         if (r1 == 0) //指令发送成功; m7 n: I8 p) ?* H. ^
  383.         {
    7 y4 W! _- @2 ]* Z- D
  384.             r1 = SD_SendBlock(buf, 0xFE); //写512个字节
    3 Q7 u2 ?$ u! Z/ b6 T
  385.         }
    " C+ S( N7 y3 ^6 J- A
  386.     }
    ( a3 E, _4 X$ y& Q2 q
  387.     else* {) |3 k' M/ M+ j# w" G# D
  388.     {; `1 B' {% {6 H. Y& y* u, [$ n$ j: N
  389.         if (SD_Type != SD_TYPE_MMC); p# ^# t& z0 V/ W
  390.         {
    # m5 O' u8 d" V, J& V: }# C3 ]" ^
  391.             SD_SendCmd(CMD55, 0, 0X01);
    8 z8 t- [; M! I
  392.             SD_SendCmd(CMD23, cnt, 0X01); //发送指令. u  g! o1 F5 r7 k- }/ \/ N" z
  393.         }" C- B$ K% F4 K% W& h$ W, Y: e6 C
  394.         r1 = SD_SendCmd(CMD25, sector, 0X01); //连续读命令
    ! c; ^( w8 |; _6 C: H5 y
  395.         if (r1 == 0)0 B. M$ x+ Y: B/ P9 q; d3 @. w
  396.         {8 L3 e$ L: Q- D- G! s
  397.             do
    5 S2 ^. U& a. m) ~6 h
  398.             {5 ^9 @! ^3 ?! e' u; x! K0 [
  399.                 r1 = SD_SendBlock(buf, 0xFC); //接收512个字节
    : _9 y! ^; z1 l! h1 Q" _
  400.                 buf += 512;
    ! b  K$ E6 U8 M" u3 C& L1 Q
  401.             }: x( P6 ]' B! I
  402.             while (--cnt && r1 == 0);# }% ~* c' s& l, d, I: C. e
  403.             r1 = SD_SendBlock(0, 0xFD); //接收512个字节
    + H3 M# p; w4 `% V) f
  404.         }
    5 ~/ ~& V0 e) f" o7 m) C( i
  405.     }
    & a: ?2 A: u1 e) W8 \
  406.     SD_DisSelect();//取消片选+ T8 q/ J2 G+ N* h! U) l, k. a. |
  407.     return r1;//
    3 x2 w/ ?. f, g# f1 r/ i, i3 b
  408. }
  1. #ifndef _MMC_SD_H_6 E  H3 T. U9 G/ T+ r
  2. #define _MMC_SD_H_
      u& K4 b. k0 f7 d4 C  `
  3. - g0 F/ a; B5 M8 e4 p" P5 O
  4. #include "main.h"# e" V% ?  r! _) ^( C  X: y
  5. ) S) k2 N* f, r# [% E/ P4 r
  6. // SD卡扇区大小" t8 u# A, q# o! R' V* q
  7. #define SD_SECTOR_SIZE  512U
    ! F8 l) x; x% ?& S! e
  8. ! c3 O1 x. x' c2 i3 p! W, l
  9. // SD卡类型定义8 W( s2 d" U# K
  10. #define SD_TYPE_ERR     0X00
    ) F7 o+ m1 u2 x: y) Y
  11. #define SD_TYPE_MMC     0X01
    . f7 U' Q. h" t4 q
  12. #define SD_TYPE_V1      0X02
    . _6 z4 S2 a+ x4 G* C% }
  13. #define SD_TYPE_V2      0X04
    . d# D$ x  V9 E* j( F
  14. #define SD_TYPE_V2HC    0X06
    - o. B; [. u5 V$ {* j" U$ l
  15.   j2 g. b3 f4 z: l) T
  16. // SD卡指令表
    " a4 K  m  n5 ]( W
  17. #define CMD0    0       //卡复位
    8 m+ X4 r' h1 ~+ `; V" m
  18. #define CMD1    15 j: \, c3 l4 L* ]8 i5 H; ]; {( X
  19. #define CMD8    8       //命令8 ,SEND_IF_COND
    * ~" R+ U5 u  F0 v
  20. #define CMD9    9       //命令9 ,读CSD数据0 h: `4 n: v7 k4 H$ q
  21. #define CMD10   10      //命令10,读CID数据" Z+ I% w$ y" V  u
  22. #define CMD12   12      //命令12,停止数据传输
    6 k9 X% R3 E/ V5 y$ I. r
  23. #define CMD16   16      //命令16,设置SectorSize 应返回0x00/ v  ?2 z8 i& i6 M+ I- ]
  24. #define CMD17   17      //命令17,读sector
    1 b" ?$ A6 T; C: u# w
  25. #define CMD18   18      //命令18,读Multi sector
    % Z' \5 d" o5 k( e/ D
  26. #define CMD23   23      //命令23,设置多sector写入前预先擦除N个block; b# l; q8 ~$ t* ]: q- P. l
  27. #define CMD24   24      //命令24,写sector" O" E- g) e" f0 k! K7 T/ z) `; ]9 F: k
  28. #define CMD25   25      //命令25,写Multi sector
    * }; n9 K& y& V/ y+ ^+ X
  29. #define CMD41   41      //命令41,应返回0x004 w2 y& k7 r1 h8 g
  30. #define CMD55   55      //命令55,应返回0x01
    . E7 m7 H2 Z6 i( n
  31. #define CMD58   58      //命令58,读OCR信息
    . f) \% F  Y3 ]$ ]) [3 e
  32. #define CMD59   59      //命令59,使能/禁止CRC,应返回0x00
    6 K1 h& J# p' \) U" h& x; J
  33. - P4 c9 k; C% O6 N
  34. //数据写入回应字意义
    / [- {) I. z9 ?5 m3 p, q: K1 r# g. L# i
  35. #define MSD_DATA_OK                0x05, E8 Q4 a+ E. @/ S
  36. #define MSD_DATA_CRC_ERROR         0x0B
    6 I) f& d. ?. O( c
  37. #define MSD_DATA_WRITE_ERROR       0x0D
    ; c1 q$ ]. I) S5 h
  38. #define MSD_DATA_OTHER_ERROR       0xFF7 X4 V/ g+ j  T" H6 o
  39. # ?+ y1 M' O. ~( g5 ]
  40. //SD卡回应标记字
    9 i5 y5 y- I0 K+ }& T
  41. #define MSD_RESPONSE_NO_ERROR      0x00
    # j# Q! T6 P+ X7 K5 a
  42. #define MSD_IN_IDLE_STATE          0x01
    ; ]- R6 D0 ]# o% K, g( ?+ k
  43. #define MSD_ERASE_RESET            0x02- X4 w" E% Q! ?8 O8 X
  44. #define MSD_ILLEGAL_COMMAND        0x04" w. M; J  A  _. C2 D
  45. #define MSD_COM_CRC_ERROR          0x08
      B0 V1 B7 i5 p+ b
  46. #define MSD_ERASE_SEQUENCE_ERROR   0x10
    : j8 C9 @8 m% B
  47. #define MSD_ADDRESS_ERROR          0x20% B5 j" B2 Z) v" @
  48. #define MSD_PARAMETER_ERROR        0x40
    4 G  E" T$ L; @, \9 Z7 N  x
  49. #define MSD_RESPONSE_FAILURE       0xFF! g  \& U1 b9 e- U
  50. 5 u7 f2 A: v' a
  51. // SD卡片选引脚控制,使用STM32CUBEMX配置SD卡片选引脚为输出模式并设置为高电平$ o9 b$ Z2 W8 a: S+ a, t# P0 V
  52. #define SD_CS_H()                HAL_GPIO_WritePin(SD_CS_GPIO_Port, SD_CS_Pin, GPIO_PIN_SET)
    4 O4 A' w) }/ q( s. i# Q( ~5 A
  53. #define SD_CS_L()                HAL_GPIO_WritePin(SD_CS_GPIO_Port, SD_CS_Pin, GPIO_PIN_RESET)
    0 H7 W- l% T6 k* e" [
  54. & V5 \6 I' r5 j; u, J1 p
  55. extern uint8_t  SD_Type;                        //SD卡的类型
    ; m4 f8 Q( }: i7 {4 c
  56. ) h2 e7 ?- Z' Q, Z: w! K; \
  57. //函数申明区/ |  L% x4 x5 i; r
  58. uint8_t SD_WaitReady(void);                                                        //等待SD卡准备
    , f3 T# ?( }4 V' W; L
  59. uint8_t SD_GetResponse(uint8_t Response);                                        //获得相应/ [- j' q3 `/ {
  60. uint8_t SD_Initialize(void);                                                        //初始化1 e) h0 ?% g  P$ t5 K
  61. uint8_t SD_ReadDisk(uint8_t*buf,uint32_t sector,uint8_t cnt);                //读块
    ( a6 O; F  X6 T/ Z) {! B% Y: n
  62. uint8_t SD_WriteDisk(uint8_t*buf,uint32_t sector,uint8_t cnt);                //写块4 a5 [6 u3 o, ~3 \5 X8 r2 c( h
  63. uint32_t SD_GetSectorCount(void);                                           //读扇区数
    * t1 x; G+ H( a2 U/ t6 X5 f
  64. uint8_t SD_GetCID(uint8_t *cid_data);                     //读SD卡CID
    ' z1 p( g8 Q* n
  65. uint8_t SD_GetCSD(uint8_t *csd_data);                     //读SD卡CSD
    " N' ]9 x! v: t7 J) F& F
  66. $ i% y, g( M0 N$ Q* @3 q6 w
  67. #endif# v: W$ s1 i: T- `/ z$ j
  68. 0 E+ N: ^' m6 o: L9 H# L9 D  V
  69.   x) Q& C6 K$ ]4 t
8 S$ y$ y: f  N. p
赞 收藏 评论0 发布时间:2022-4-11 10:16
