一、原理图
# N% ^) k, V9 R$ k) e7 I% I6 [' E+ P. D6 v
) K: ~2 R2 t$ r0 _6 J. `( |7 O7 S% X4 U9 ^6 Y
芯片引脚连接6 n% X* ^4 Q$ z; c& U- s1 M) q' _
" J! z2 N: V" i' O" f, D
+ K( U* h6 X4 h) O1 y' s
二、驱动程序
1 J1 f2 m5 w8 n: T: ^spi.c9 d. z# O+ O( n% _: j ~1 d
0 ]4 ^' d7 M/ i0 w
- #include "spi.h"$ z1 ~& D" k0 a& u4 J0 a7 \
- ! ?8 R7 g9 j! S, i' f8 ^
- void SPI1_Init(void)
2 Z, l9 d0 d8 l# z. w8 p, I7 T) P - {6 D6 Q' t8 e' n: @) x
- GPIO_InitTypeDef GPIO_InitStructure;
0 A& D( Y; H0 h. d" S! ? - SPI_InitTypeDef SPI_InitStructure;6 C7 Y+ [' \- H" @
E* Q. `% C F" Z* c' n4 a- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );//PORTA时钟使能
2 N, s' ]5 m; m% e: ] - RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1, ENABLE );//SPI1时钟使能 4 A/ h9 k/ ? n8 e
- " T9 S% N! K! b
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
3 Y% w% B6 [* z$ l - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; % m! M' Y, a: _$ m# `) I
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;. c5 X, a3 H, }" o9 B7 q3 M
- GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA$ Q+ p; Y% @. Y5 B. K" n* w
. \ D+ ]" `; f2 y0 l3 {, {1 Y. x1 R7 G- GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_7); //PB13/14/15上拉
3 R3 [: e. [/ l& X9 [0 \ - ) x/ y8 E, W3 l$ b% Q
- SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工- Q% @. U4 H9 Q0 A' ~3 B6 H
- SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI& v9 H$ y3 q7 }' b: ^# }0 Y& c
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构
" [+ @4 ` d$ Y" M: u2 u - SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平# T! o) G% y5 o( _/ Y7 H- [
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样/ d% `# i, t W( v6 S4 ?* E
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
: P, Y- {. w2 q$ J: G. j - SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为256
- I) q+ c: c+ l+ g/ e - SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始8 A1 b' [6 W* a0 |- @: h
- SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式, d0 g$ v+ U! k' S/ f3 A3 |
- SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
, N) S4 l1 s- M6 u/ N - ; j- a- S) T4 j% n9 |( i
- SPI_Cmd(SPI1, ENABLE); //使能SPI外设
) m- y1 R4 ]+ I& \5 h* R - ) Q% P( C$ d( ] P5 q! y! Q* |
- SPI1_ReadWriteByte(0xff);//启动传输
; j3 r" C, s8 b - 2 O, m# ?7 m- B4 G J2 f$ w: H
8 m: K; G: f( Q6 L& C- } " e! I- ~% q$ c0 o, H& Y5 p& W
- //SPI 速度设置函数9 f" S, T% E: D$ h! r2 M7 P$ r
- //SpeedSet:( Y' S' S7 n7 z5 x0 `* w) _& V. D
- //SPI_BaudRatePrescaler_2 2分频
1 U& F6 v# I! w - //SPI_BaudRatePrescaler_8 8分频
, l2 ]1 c6 x7 m) F/ C1 K5 K: W - //SPI_BaudRatePrescaler_16 16分频
) Q. C: E) t% P; q2 B2 f) E6 { - //SPI_BaudRatePrescaler_256 256分频
5 x. r! f% w& l5 q0 d( n) ]7 B- Q5 B - , j9 w! B, ] Q) Q2 a; o. ^
- void SPI1_SetSpeed(u8 SPI_BaudRatePrescaler)% L6 F# G5 O: I# m8 x
- {: S! X) A, ?+ k* o
- assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler));
( ]4 G% O8 o9 t% m, x% a0 ]" _& x - SPI1->CR1&=0XFFC7;' e/ z8 ]) z9 g
- SPI1->CR1|=SPI_BaudRatePrescaler; //设置SPI1速度
. C. f z" Y0 P! @- M9 ?9 b - SPI_Cmd(SPI1,ENABLE); ! Z" K" T/ q! W/ D& Y0 e( F
- * a$ H+ v9 {1 K: G$ s& V8 e+ P
- } ( x" @1 S! S5 e8 T& K
% s7 K4 K- h2 Y; s" m4 M3 }- //SPIx 读写一个字节+ f" _) G8 g# k, [" G K3 A( E
- //TxData:要写入的字节+ \) e3 C% D& Y
- //返回值:读取到的字节
& ^$ k9 W4 [. z, P0 ?$ P3 @- l - u8 SPI1_ReadWriteByte(u8 TxData)
0 E4 B/ ?, D2 ?' d - {
2 a5 S' H8 P' a- [3 s3 E - u8 retry=0;
) i r8 t* G8 ]+ q% ~' Y - while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
: a3 V+ \- o5 L0 H3 U - {
* F, a' s' W i* w& m, M, ] - retry++;
5 ^8 J$ h& F& Y+ u - if(retry>200)return 0;, [/ i/ W. o- k1 V8 u
- } * b# `7 }. W! Y% \( R' Z3 X
- SPI_I2S_SendData(SPI1, TxData); //通过外设SPIx发送一个数据* r a( H; P! P8 I. h, C) ?! g, b$ g
- retry=0;
7 ~+ e/ N3 Q# v" Z - + O! L! Z8 R: K/ R# j9 S
- while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位; S- S. R \6 o% x) R4 p
3 P: _' e# Q! G* F4 L) Z$ o+ n& y - retry++;7 {) k! ], l) n5 Z" t. _& Y4 f9 c
- _7 D& F7 s5 e' u% W9 W, |: ?1 S - } - v1 c6 P5 v! M) N- n7 _# C
- return SPI_I2S_ReceiveData(SPI1); //返回通过SPIx最近接收的数据
# Q4 m; r/ Z0 q+ X4 H - }
复制代码 ) K$ W5 L; y! T& _; s# u; D
oled.c
- x# s9 K. ~6 Q6 c0 J/ ^- l; T9 U
+ M# j; c$ e- B# J- #include "oled.h"2 p0 O9 u& R7 ~
- #include "stdlib.h"
! F) i) q8 a" e - #include "oledfont.h" - i p& O1 k% H+ t& N# W
- #include "delay.h"; I9 Z# X' Y3 g! i( O& Y6 u
- #include "stdio.h"
* p, Q4 m* f1 j8 n - #include "spi.h"0 R% u- L) U6 \- H: x; ]; N
- //OLED的显存+ x) |3 l2 S) a7 O, t2 S$ b
- //存放格式如下.
, u; y R0 E6 B/ F# Z - //[0]0 1 2 3 ... 127 3 E7 y/ w' _( g i7 V9 E
- //[1]0 1 2 3 ... 127
0 F. @2 Y8 I" \" {4 F9 x6 z# ~ - //[2]0 1 2 3 ... 127
9 t1 d/ m/ F3 h - //[3]0 1 2 3 ... 127
( E5 v% U' k* \8 Z - //[4]0 1 2 3 ... 127 , M: k4 V* k3 c! Q- W7 Z& ]" }
- //[5]0 1 2 3 ... 127
% g) Q, `" s8 u: [5 }9 ]- V' S! h - //[6]0 1 2 3 ... 127 " u5 I7 o) l- Z
- //[7]0 1 2 3 ... 127
# b3 A N6 `8 ]) r6 i - 1 t, e+ z* p$ a) @" W( b8 q P
- //向SSD1106写入一个字节。8 y8 S2 t1 `9 L
- //dat:要写入的数据/命令
. v4 f$ {: v9 E - //cmd:数据/命令标志 0,表示命令;1,表示数据;
4 h3 F9 m4 V( s1 S8 t( o) {( u - void OLED_WR_Byte(u8 dat,u8 cmd)* H* k- R% c q& T
3 @+ a3 H* R7 V$ f - if(cmd)
7 l2 o) k) P) o3 B( J) n( a* z - OLED_DC_Set();6 L2 v1 e1 w) G6 ^
- else
* @, [/ L: J& \9 B- L* W - OLED_DC_Clr();
1 G+ y$ K- D# \7 L( ]2 H - OLED_CS_Clr();. T- e4 f: o* B% {7 s. K+ h8 j
- SPI1_ReadWriteByte(dat); 0 E8 |0 Y; j2 ^) t' x
- OLED_CS_Set();. D% j6 b0 k1 |. \( L; {
- OLED_DC_Set();
3 e8 N8 k: n3 ?' ] - }
9 a }; n3 H3 ~- o! ^+ {
) e$ X ]6 F( E8 G2 k/ ]8 u) `( M- void OLED_Set_Pos(unsigned char x, unsigned char y) 4 [) T% R+ t* U# J$ h+ s
- { 4 x# i; H# k r: |2 S( ?3 F
- OLED_WR_Byte(0xb0+y,OLED_CMD);
+ R c% ]( [9 C( w7 n1 C# B - OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);5 k2 v7 H% ]1 B9 K, ]
- OLED_WR_Byte((x&0x0f)|0x01,OLED_CMD); $ g$ X. C# |" I# z
+ p# {& s: P! s - //开启OLED显示 : w5 Q& a$ ?, q5 ]1 {( t6 v7 Y
- void OLED_Display_On(void)
[8 |9 f* S; c! B P' T3 J( R - {
8 K& ^* u+ C/ j1 L2 K1 v' N$ g - OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
# T2 y9 B- \3 H7 P5 v7 b1 a \" v# Y - OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
7 n+ z% }5 Q# j4 y! d" _ - OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON3 K* p b: z. { g) e" Y: t; z& e
7 Q4 A' A, q5 m+ V8 O1 o - //关闭OLED显示 ' g$ z9 G/ _# h) b' {
- void OLED_Display_Off(void)) k8 r# f F; N8 S6 @6 D* F
- {8 b) L% l$ }% S0 u. u
- OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令8 L9 [+ P9 _% \. v
- OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
& [' k j) i9 C% D - OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
- U) Z0 f( L5 j7 f% o - } - r* y: G' @2 Y: y5 X3 m4 M$ @
- //清屏函数,清完屏,整个屏幕是黑色的!和没点亮一样!!! ( ?% w( _" b' g; T
- void OLED_Clear(void) ( A, ?( ?. S1 X8 E
- { $ a0 _5 h- L/ K+ h N9 |# A
- u8 i,n; ) L1 f7 P; o* ~5 x6 g" q
- for(i=0;i<8;i++)
: {' p% o' X# W K* s2 D - {
/ [9 K, P6 [ D8 C( \ - OLED_WR_Byte (0xb0+i,OLED_CMD); //设置页地址(0~7)
' g7 [! ~& q4 r2 a# J - OLED_WR_Byte (0x00,OLED_CMD); //设置显示位置—列低地址! j7 p( O' Z& L/ d# l0 c1 A' w
- OLED_WR_Byte (0x10,OLED_CMD); //设置显示位置—列高地址
8 k" u5 R. i' z- H1 c - for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
5 G/ D4 F9 V! C3 ~( P, b& { - } //更新显示
$ ~' k) A$ m) C% Q k0 B% Z# A0 y - }# L& d* i6 y; V3 t& A, Q& ]0 i& F
- & p3 y' K2 R/ @4 H/ J* a4 I7 }
! t, ]7 M. n8 ^8 _6 P- //在指定位置显示一个字符,包括部分字符
2 ^+ h3 v/ P. T4 U0 h7 R5 @ - //x:0~127
+ Z, E( c3 q8 x" d. `8 n1 p - //y:0~63
$ j, X! H6 R6 ? h - //mode:0,反白显示;1,正常显示
. \ h) \& i. ^0 e a - //size:选择字体 16/12
: u1 d7 [' v4 O) l6 |: ~ - void OLED_ShowChar(u8 x,u8 y,u8 chr)
( b d9 `+ H" P; p - { / P) _' c6 P' C2 h
- unsigned char c=0,i=0;
6 M7 Z: `7 y# T; d5 I9 ]* { - c=chr-' ';//得到偏移后的值
& X' D! u5 E# m; y7 a - if(x>Max_Column-1){x=0;y=y+2;}
5 Z( G1 K" x0 g4 c2 b% @ - if(SIZE ==16)
, V; _$ f5 |+ N/ i7 v8 C - {- P0 k/ Z( k1 W+ [7 @
- OLED_Set_Pos(x,y);
# t& A# ~! v+ X9 S0 }( ? - for(i=0;i<8;i++)
, I$ W! K$ j7 x4 u5 d, D& U - OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
2 `& ~$ k5 q M* l S - OLED_Set_Pos(x,y+1);- b! [6 E- A2 w( ?5 c- Z
- for(i=0;i<8;i++)
6 I* _4 I3 }8 ^1 A - OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);$ r, B( | i+ m1 U2 S
- }" {. ]6 z6 l* S) J4 f
- }+ b% O( S) ^) i/ @2 ?: G
- //m^n函数% X# q1 T6 }& F. X9 z/ ]6 T4 @
- u32 oled_pow(u8 m,u8 n)
! W5 N' \& w- e$ T, f - {
2 c/ w( S0 V; q - u32 result=1; 5 r4 Q: l9 d% P( @# {% h
- while(n--)result*=m; 9 F+ f8 B# B; z0 f
- return result;
" U9 k3 W Y y - }
c+ |. c H( o. h: h+ `) Y m - //显示2个数字
+ p+ ^: I1 v' B+ E/ {& P/ q4 I) ] - //x,y :起点坐标 2 u. ]9 E1 e8 G# W
- //len :数字的位数
" n0 T7 F9 R' i; h - //size:字体大小
- t& H2 M Y; V5 ?3 G O - //mode:模式 0,填充模式;1,叠加模式
: S* p$ `: ?6 E) h - //num:数值(0~4294967295); $ W) [+ H( V! d
- void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size)9 r3 z7 R; C. V- h( J
7 r$ k) u. S1 B( z& p; Y8 O - u8 t,temp;5 \: H6 u8 `2 y- o/ X4 m5 s Z
- u8 enshow=0; 6 D% k2 M; I2 @
- for(t=0;t<len;t++)
$ L% v1 p, |( k- j6 d- G, H! ^ - {
9 r9 S& p3 A9 |8 G$ c9 [ - temp=(num/oled_pow(10,len-t-1))%10;& w5 ?4 z- x3 L4 x' e& }9 w/ P
- if(enshow==0&&t<(len-1))
( Y9 p0 e2 ~' A6 K: N0 j% d - {7 K8 t7 p! O+ Z: M/ |
- if(temp==0)
) `7 e+ u' d6 [( S/ l - {0 Y) C* I. l3 e; a
- OLED_ShowChar(x+(size/2)*t,y,' ');
( \& f: S+ j( j( j9 n% x - continue;: }+ h' n# E) A( J/ x# `
- }else enshow=1; 3 l7 u2 Y& P8 r# {; G
- $ e& f/ a( J4 t7 Y4 n3 `' u
, Q& r" P! ^$ d' }4 M: ? - OLED_ShowChar(x+(size/2)*t,y,temp+'0'); , {. w" _. I" |+ ~- J( J& j% T
$ ^$ P1 h8 d9 A$ A7 m - }
" x3 L; J" }7 d, |7 E( F8 H - //显示一个字符号串
& j4 t- C: c* C' {# t' J - void OLED_ShowString(u8 x,u8 y,u8 *chr)
6 X# J5 g5 Y! y& m - {
2 q+ X4 J; M% N6 ] - unsigned char j=0;" j2 E# W( b( `: W* E
- while (chr[j]!='\0')8 @/ O ~3 L# E* M' t# @' X1 }
% K, ?' D4 u0 I. a! I# N& @4 l7 ~ - OLED_ShowChar(x,y,chr[j]);
7 b& k! J. F8 z4 w5 k - x+=8;
9 s- u, c: t1 V& [ - if(x>120) ^! k- |1 w" z' d) i
- {1 D! m$ L* R+ t6 m+ ?+ j; |& z
- x=0;: o) }% \/ e$ a; d! M; N: v2 e$ R
- y+=2;
; F! }4 u$ S D+ s* I3 J; s - }
! D9 q5 H M. z& b# U; j - j++;: j: d6 r$ h, m; E% o4 S
- }# Z) F5 v2 m- K( Q8 p; B
* g+ j' Z, G. C6 R - /***********功能描述:显示显示BMP图片128×64起始点坐标(x,y),x的范围0~127,y为页的范围0~7*****************// }4 \; t- k% I! d
- void oled_draw_picture(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[]) B+ G4 I: V# E7 [
- {) a2 W. G- f* } x2 G& |" `- Q0 M
- unsigned int j=0;
, J( m6 w% S' V' O4 T - unsigned char x,y;3 Z0 O5 I$ ~2 T! H& ^ Q! I7 }
; l- x0 x: F0 u- if(y1%8==0) y=y1/8; # S& f, @+ I0 E5 H
- else y=y1/8+1;
/ r9 O' i: I' l- i- [ - for(y=y0;y<y1;y++)
" d- I; T2 C7 L0 L - {
# {0 d2 I8 T* V% W: v5 n& ~0 m7 z - OLED_Set_Pos(x0,y);) J$ i; \ _" y5 ^: j0 w: Z; X
- for(x=x0;x<x1;x++)3 Z) k2 o" s0 q) C4 G* n& a
- { 8 F! w/ u$ g* x' n
- OLED_WR_Byte(BMP[j++],OLED_DATA);
5 R, R' c' }# f8 k% k4 ^# I - }
3 @6 L9 `1 h$ `9 D* y - }
5 K9 K# i/ y5 d3 o: e: p6 W, U - }
; J }% N! [3 d6 P. ?. |" p - void oled_gpio_init()
. D: m( \ N- u# y - {. `& j5 d/ b2 o5 \( Q
& ^# @. @8 }6 ]* x. H' }
1 E- ]9 A0 O2 D5 U0 `% r5 p- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);
3 Z4 M/ f2 `0 V2 x0 e c
+ ]. X+ J6 n- q% h! J9 o8 v- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE); 6 P+ p/ ?0 F m5 N
' L* B' \6 T8 [ - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_6|GPIO_Pin_8;
- _$ a! m: h* [' h& z, [& n. h/ ] - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
( m8 Q8 T) y0 a8 G2 P- I - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
+ K; w3 k: _) M! t; E/ m8 r - GPIO_Init(GPIOA, &GPIO_InitStructure);
3 c# P) w1 L3 Q+ T+ f6 q - GPIO_SetBits(GPIOA,GPIO_Pin_4|GPIO_Pin_6|GPIO_Pin_8);6 q: N* x( w; q
- . q4 c; B, f" n0 H( j K
- 4 W- \7 H/ e2 X4 \/ {' X
' a$ Z( I) P* b8 ~* k, D/ o( K
( }) S, {' _ O5 O% e0 ^- - s9 l+ c$ ?( i
- 8 X2 I! o$ i: `8 F" [" s
- //初始化SSD1306 ' a, A2 L0 @2 E" S y+ a
- void oled_init(void)& ]4 N9 K F& J2 i
- { 5 e P& a2 s$ R. s1 }
- oled_gpio_init();6 v/ D; p. T" d4 Y. Y
- SPI1_Init();/ v5 O" Y! S, p- h! Y# G
5 G) ^$ w9 S1 r8 ^# `" g- // OLED_RST_Set();//复位使用系统复位,所有此处不需要再复位
8 j" g% f* J7 d' P& _ - // delay_ms(5);, e% P r- j( y; W( m+ C
- // OLED_RST_Clr();: S4 l+ Q2 L3 Q- S
- // delay_ms(5);' v; j n9 d$ F* |' d$ u
- // OLED_RST_Set(); . L. {8 k4 p$ N' L; m
- - Z& k1 l4 {' B: V; V, p
- OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel0 |3 o; D6 q" W0 |! T
- OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
/ P d7 U" _% n" \5 Z - OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
( w# u) I' H1 w. v - OLED_WR_Byte(0x40,OLED_CMD);//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
- ^- B, D1 w1 U8 N" B - OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register& e8 Z$ U, J2 L: ~
- OLED_WR_Byte(0xCF,OLED_CMD); // Set SEG Output Current Brightness
6 w2 H9 i, f X2 j - OLED_WR_Byte(0xA0,OLED_CMD);//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常" n4 F- @( l1 B$ r8 I/ f \
- OLED_WR_Byte(0xC0,OLED_CMD);//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
1 e+ H; ^8 E' y' n( p- F+ S - OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display
$ k3 e# A, u3 L - OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
$ f8 U$ z: W6 `4 O6 R' E - OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty5 l/ F" t$ V3 p0 z" O! r
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)7 `) Z, P$ c# q, ~
- OLED_WR_Byte(0x00,OLED_CMD);//-not offset( e$ n8 @( ~7 e* f0 j+ j: g9 Z i
- OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency' S# o7 K$ N# U) c: G
- OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec6 V: W( {$ s/ ~+ Q1 q; Z
- OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period9 T! p- t! L9 B' N
- OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock" ^8 O, ^/ R; C
- OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration& M( H+ C0 f" W( @/ U( C
- OLED_WR_Byte(0x12,OLED_CMD);
! O4 x% o8 G) A6 D, V9 I2 E - OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh
8 d7 D) s4 Z0 p6 P+ ^$ B/ u - OLED_WR_Byte(0x40,OLED_CMD);//Set VCOM Deselect Level
0 s2 Z7 w" V% o; m$ ?! J - OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
6 n% l$ y6 ]4 c Z- G; m - OLED_WR_Byte(0x02,OLED_CMD);//, w# D) m/ F1 c9 ~: K+ t8 b
- OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable% n: |9 p. M& `6 ^# Y9 _
- OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable
# e2 c6 u2 ^3 d5 {' ^+ N - OLED_WR_Byte(0xA4,OLED_CMD);// Disable Entire Display On (0xa4/0xa5)% s' }' i% w+ `5 t, D7 C- Q
- OLED_WR_Byte(0xA6,OLED_CMD);// Disable Inverse Display On (0xa6/a7)
) ?* k: T& g/ u( b5 v% N% y - OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel$ i9 E% Y2 m6 S
- ! j3 S+ d6 W; T! ~4 \3 Q
- OLED_WR_Byte(0xAF,OLED_CMD); /*display ON*/ 2 J! p5 P* t+ j
- OLED_Clear();, X0 C3 K T: ^) B
- OLED_Set_Pos(0,0);
, d/ b( a5 O Y M! ] - SPI1_SetSpeed(SPI_BaudRatePrescaler_2);1 V& @3 ?1 K3 S5 h
复制代码 ; b$ ~( ^- X" A! a# |
main.c, U( k0 Z% r8 H% o+ U, H. Q$ a
6 k# {+ L( Y% q: X8 }- #include "sys.h"' J9 `/ P9 O/ Q: | ^) r' G n
$ |1 i9 D; z R9 D3 H+ Y! {# w" [, ] - #include "usart.h"3 U8 x9 ^( ]7 W( }( H( m$ k
- #include "oled.h"
- ~. D) D: [6 F0 a$ i9 o4 ?) T - #include "tm1804.h"4 W8 G# H3 Q. ? _8 \9 A" D- v' l
- int main(void)
3 a2 X( o+ i0 G, J5 J' Y$ Q - { : ^+ I& t0 w# [: T2 B
- delay_init(); //延时函数初始化
4 N# N9 A, l% K - oled_init();4 @% V, k) }+ W
- tm1804_init();
f; K! G, D; E. E* X, [ - OLED_ShowString(0,0,"xupengxisxveryx1");3 E5 n6 u. I2 s3 M& \' P2 T8 W8 {
- OLED_ShowString(0,2,"xupeng is very");
3 s; v) }8 ~' }/ G/ {$ n - OLED_ShowString(0,4,"xupeng is very");
6 U. Q' M- u! s) s9 B; R- ^9 ?- z - OLED_ShowString(0,6,"xupeng is very");
3 \& s1 |6 \: S* e8 J+ c9 Q -
& R: S% ]9 C1 G8 j - while(1)4 g$ a% m; |" c- R
I* D% O0 N, [/ U3 D - set_tm1804_data(0xcc,0x00);
9 ]2 S; [$ G7 z0 y+ S - delay_ms(1000);
, _6 T6 s3 V4 j8 H8 U' r - set_tm1804_data(0x00,0x00);
* b# R0 ~1 k, e- r( s - delay_ms(1000);
" R6 Q$ r$ Z `$ ]) V4 ] - }7 f. E( j/ ^- U9 d5 m! [" k% G
0 ~% }. ^6 l! y& ]# g
! x/ \! n/ E. V4 P( a5 U/ [* l) f. n6 o1 i
/ K# K7 c! A6 M$ F F4 I) O- \
( |. E# V) n. m; { |
