【经验分享】STM32 GPIO相关函数和类型
STMCU小助手 发布时间:2022-6-11 21:38
01. GPIO固件库概述
) v5 u9 t, V. `9 x% h1 estm32f4xx_gpio.h GPIO相关函数和类型的声明7 |9 o1 @0 i+ n8 V2 U9 }; u
& v# x5 p  B' ]$ Q/ D. Hstm32f4xx_gpio.c GPIO相关函数具体实现。# H2 i: f+ r, t- P# x" G
+ ?4 G2 j8 T2 X: M) T02. GPIO相关类型
0 n; C; D) H" w0 W/ ~, e3 KGPIO相关的类型几乎都在stm32f4xx_gpio.h文件中。* X5 N: x$ P. ?. p, z
1 u6 n1 D. L4 Z2 VGPIO的模式
! Y+ ^# y# b/ H: {4 \1 R) J8 d! S1 S1 M
  1. /** ( o& u0 a5 v0 m3 {" W4 {
  2.   * @brief  GPIO Configuration Mode enumeration
    : C% B* m+ S# u1 }$ M
  3.   */   ' \9 x% u% S$ O7 u! H
  4. typedef enum
    - [% B. l, |. K3 u
  5. {
    ( Q/ U& I6 C* v, ^7 v
  6.   GPIO_Mode_IN   = 0x00, /*!< GPIO Input Mode *// x) Z% G( u( }% w  N% t9 v. Y1 T
  7.   GPIO_Mode_OUT  = 0x01, /*!< GPIO Output Mode */8 V# _7 Q: `+ c9 W' X) c: W* ~
  8.   GPIO_Mode_AF   = 0x02, /*!< GPIO Alternate function Mode */3 ^! |$ s! z' W, h6 ~. C
  9.   GPIO_Mode_AN   = 0x03  /*!< GPIO Analog Mode */
    / ?; h( _5 ]# F2 N  M, K
  10. }GPIOMode_TypeDef;
    $ D* n5 X  ?' V/ i# _; L
  11. #define IS_GPIO_MODE(MODE) (((MODE) == GPIO_Mode_IN)  || ((MODE) == GPIO_Mode_OUT) || \
    ! D8 w* P6 h# I, ?6 i- P3 v/ m
  12.                             ((MODE) == GPIO_Mode_AF)|| ((MODE) == GPIO_Mode_AN))
) r9 [9 e- t) W: S9 CGPIO输出类型
/ z! ]1 j, G$ b2 B& l2 B
- Z* H- q, O# H9 a* M
  1. /** ( f1 M" k9 H, F, U0 o" f2 K# L
  2.   * @brief  GPIO Output type enumeration ) C/ _1 l7 [5 ^- k, R
  3.   */
    + W. h5 n7 Y: u
  4. typedef enum
    - ~# L9 ]# v3 l- l9 j" X- [- P; w
  5. {
    * ~' e& s- ~3 F1 `0 v
  6.   GPIO_OType_PP = 0x00,
    - D- m2 `3 m$ P$ c1 a4 ?' n
  7.   GPIO_OType_OD = 0x01( V( n4 ^8 I7 S7 H( [& z8 f) a
  8. }GPIOOType_TypeDef;
    6 m1 |/ E3 {% R  G
  9. #define IS_GPIO_OTYPE(OTYPE) (((OTYPE) == GPIO_OType_PP) || ((OTYPE) == GPIO_OType_OD))
* x0 Y! ?$ e3 K/ R! r3 sGPIO输出速度
, i. U1 w/ x% \) y5 `# v/ e7 g' o4 i9 c1 ?6 r9 x4 `
  1. /** # X6 L. o9 r; E6 x
  2.   * @brief  GPIO Output Maximum frequency enumeration
    ' y$ l, r  f; u5 X2 O' O0 x
  3.   */  ' O" ?3 Y& q2 K" {1 ]% Y' E
  4. typedef enum
    ' u7 Y! R( q* m9 S2 U7 ^
  5. { 2 P  O1 M* O6 c% u! n5 ?; D
  6.   GPIO_Low_Speed     = 0x00, /*!< Low speed    */
    2 u" e0 V) v( ?: H' B+ {* V
  7.   GPIO_Medium_Speed  = 0x01, /*!< Medium speed */
    5 y0 K# F0 m% W! B- _: S7 m3 H
  8.   GPIO_Fast_Speed    = 0x02, /*!< Fast speed   */' T2 X; f* i1 f
  9.   GPIO_High_Speed    = 0x03  /*!< High speed   */0 A; y: r" l. @3 p& A
  10. }GPIOSpeed_TypeDef;
    ( P" ~" [5 ^3 `2 M7 d: ~, E# ^) R8 L
  11. & N; C$ [; F. O) U: d/ ~8 i
  12. /* Add legacy definition */
    5 y: L* Z$ f  Z) ?/ a
  13. #define  GPIO_Speed_2MHz    GPIO_Low_Speed
    + E6 d1 _) _  M, c) V  u! j4 Z# p- D" ?1 R
  14. #define  GPIO_Speed_25MHz   GPIO_Medium_Speed 7 n4 I, b, J& p; i" o5 ^0 x. f. F
  15. #define  GPIO_Speed_50MHz   GPIO_Fast_Speed ; B7 j: b- }4 M! ?! e7 }! i' ~
  16. #define  GPIO_Speed_100MHz  GPIO_High_Speed
    + K  ~6 ?* G& `' ]
  17. : R6 ?" ^; i5 q0 h1 K5 i- p
  18. #define IS_GPIO_SPEED(SPEED) (((SPEED) == GPIO_Low_Speed) || ((SPEED) == GPIO_Medium_Speed) || \
    ; O7 b3 h* l# V% x" l% q
  19.                               ((SPEED) == GPIO_Fast_Speed)||  ((SPEED) == GPIO_High_Speed))
# i" M6 t9 i8 ?3 y5 o( z8 \8 lGPIO上下拉
: P4 ?% {! F0 e" d/ Q
" s7 S( w2 T  H% E( O2 X
  1. /**
    8 p  l* y! d. {  a) f9 I! {: m/ f/ w
  2.   * @brief  GPIO Configuration PullUp PullDown enumeration & D2 k+ ?' Q7 E/ M% n
  3.   */ + `* k6 S3 |% p6 H* l
  4. typedef enum
    / W/ ^$ V- x8 Q( I7 i% u/ [: ?  R
  5. {
    : M, Y4 Z; h7 U2 S
  6.   GPIO_PuPd_NOPULL = 0x00,
      p. U0 x! b9 l" i
  7.   GPIO_PuPd_UP     = 0x01,
    7 N$ c" O/ W2 o, z
  8.   GPIO_PuPd_DOWN   = 0x02/ g3 K) n( Z1 P" n% _! n
  9. }GPIOPuPd_TypeDef;
    9 Y7 Z/ ^8 V2 a$ y, x3 c
  10. #define IS_GPIO_PUPD(PUPD) (((PUPD) == GPIO_PuPd_NOPULL) || ((PUPD) == GPIO_PuPd_UP) || \, T) g. N! d( W4 Z5 S% f4 Q
  11.                             ((PUPD) == GPIO_PuPd_DOWN))/ o' J' @; I/ _& t" q% W& X
* B" I) R+ k" E0 e# |: _
GPIO置位和复位
# ?- ^" s) n% A# G, r9 P: h% q" T: v6 D
4 o' I" b. M  y( n8 J) c
  1. /** 8 F2 c. d9 D% c
  2.   * @brief  GPIO Bit SET and Bit RESET enumeration 6 k. E0 _( e( W6 m* u  A# D
  3.   */
    ; [0 R3 n# q0 K
  4. typedef enum
    " C& v# }8 V9 A
  5. {
    0 E3 l8 |- ?, H# R0 V3 h
  6.   Bit_RESET = 0,
    / z% b; A+ `8 r4 i
  7.   Bit_SET
    . M3 i% d/ c3 V4 `
  8. }BitAction;! ^1 M- x5 c  V- R) T' u
  9. #define IS_GPIO_BIT_ACTION(ACTION) (((ACTION) == Bit_RESET) || ((ACTION) == Bit_SET))
! y- e* j! k2 @# T/ nGPIO初始化结构体类型声明7 j. G4 b; v& R8 b" A  G" Q
* m: H' M6 n6 x" f/ `- @4 E/ r
  1. /**
    ! j6 \) [" C  k9 e
  2.   * @brief   GPIO Init structure definition  6 V, @. ~/ r6 [- J
  3.   */
    + E& l* a0 F/ h. s* ]
  4. typedef struct, x* R6 G: g7 C' g
  5. {
    3 w$ m) e1 n8 S* G  {0 ?
  6.   uint32_t GPIO_Pin;              /*!< Specifies the GPIO pins to be configured.
    ; ?. D, X, B, S0 g* p9 L& {+ Z
  7.                                        This parameter can be any value of @ref GPIO_pins_define */$ X8 a8 m  N: a" b: t
  8. , T/ I. {( [) a) \; M$ `
  9.   GPIOMode_TypeDef GPIO_Mode;     /*!< Specifies the operating mode for the selected pins.
    ) u. \* J3 z# v- |$ m( b
  10.                                        This parameter can be a value of @ref GPIOMode_TypeDef */
    $ \& S- ?& l" X9 z
  11.   S& V; q3 b1 V; R# c; {7 l4 D
  12.   GPIOSpeed_TypeDef GPIO_Speed;   /*!< Specifies the speed for the selected pins./ Q1 |% @' d/ k1 p4 g  ^9 z
  13.                                        This parameter can be a value of @ref GPIOSpeed_TypeDef */
    8 V3 o$ l$ b% S
  14. * Y& J. z0 Y+ _& s
  15.   GPIOOType_TypeDef GPIO_OType;   /*!< Specifies the operating output type for the selected pins.
    * u& y7 G+ d& J
  16.                                        This parameter can be a value of @ref GPIOOType_TypeDef */' v7 N# P- B# j8 Z/ ^, G" D
  17. 1 `8 S, Q' p7 Z+ q
  18.   GPIOPuPd_TypeDef GPIO_PuPd;     /*!< Specifies the operating Pull-up/Pull down for the selected pins.
    * L) I# i% l/ L  F' J/ z- s! x
  19.                                        This parameter can be a value of @ref GPIOPuPd_TypeDef */
    ( ]! \) S% n. s5 V* D0 H
  20. }GPIO_InitTypeDef;
+ X( {2 s" O9 N2 Q  A4 ~6 t03. GPIO相关宏
6 m3 _4 N( h# z; c3 Y' U0 H判断是否为合法的GPIO外设3 v8 X4 `+ T" i. I
7 E" o7 m! `3 m, v7 _  ~- O: S
  1. #define IS_GPIO_ALL_PERIPH(PERIPH) (((PERIPH) == GPIOA) || \: r4 r# z0 o$ r/ O9 k/ u
  2.                                     ((PERIPH) == GPIOB) || \
    0 x/ Q2 O: K7 m2 W1 `, Q4 W' G. a
  3.                                     ((PERIPH) == GPIOC) || \
    # V5 [4 B8 g& p9 y
  4.                                     ((PERIPH) == GPIOD) || \, e) t7 V3 k  W4 i5 g" c4 |- _
  5.                                     ((PERIPH) == GPIOE) || \) @/ K. k, u9 D& |- S
  6.                                     ((PERIPH) == GPIOF) || \
    0 P" j% h2 A9 E$ K( S6 e! x) X
  7.                                     ((PERIPH) == GPIOG) || \7 {' M$ j/ R; H. J& z: }1 ~
  8.                                     ((PERIPH) == GPIOH) || \" A( O" j: A" c% i, c
  9.                                     ((PERIPH) == GPIOI) || \
    % m* X3 |5 _( C+ Z
  10.                                     ((PERIPH) == GPIOJ) || \
      |+ S3 T4 k+ r1 H0 P/ X' f7 \
  11.                                     ((PERIPH) == GPIOK))
5 t! `0 B# j) V) p2 @8 K
GPIO合法的引脚
* G. h. \" W) \( R
8 t, P- O4 @$ g3 }. ~' a
  1. /** @defgroup GPIO_pins_define 8 p' [" ?/ `- q4 s1 g* R, G0 e5 |0 Q
  2.   * @{3 ~4 z5 [% [$ j: x; L4 B: I
  3.   */
    ) Y+ J9 M' p! R0 F0 _
  4. #define GPIO_Pin_0                 ((uint16_t)0x0001)  /* Pin 0 selected */1 h0 U# V: l  e; z% X5 @3 q$ k5 ^9 d
  5. #define GPIO_Pin_1                 ((uint16_t)0x0002)  /* Pin 1 selected */2 q: K: s$ j2 z
  6. #define GPIO_Pin_2                 ((uint16_t)0x0004)  /* Pin 2 selected */4 \* _& ^; {) q+ Y- D% I. C
  7. #define GPIO_Pin_3                 ((uint16_t)0x0008)  /* Pin 3 selected */
    & ]+ d5 E7 A' k
  8. #define GPIO_Pin_4                 ((uint16_t)0x0010)  /* Pin 4 selected */# k  w" m' d; L* q# R# C
  9. #define GPIO_Pin_5                 ((uint16_t)0x0020)  /* Pin 5 selected */
    ! _4 l1 s5 A: p
  10. #define GPIO_Pin_6                 ((uint16_t)0x0040)  /* Pin 6 selected */
    - k, t( B/ K4 Z! q
  11. #define GPIO_Pin_7                 ((uint16_t)0x0080)  /* Pin 7 selected */( q4 p$ a8 O: Y% J( H' v5 s3 E# v
  12. #define GPIO_Pin_8                 ((uint16_t)0x0100)  /* Pin 8 selected */
    . j/ t. j4 `9 u: f
  13. #define GPIO_Pin_9                 ((uint16_t)0x0200)  /* Pin 9 selected */; F9 Y# B/ ~0 f+ Q1 x% P
  14. #define GPIO_Pin_10                ((uint16_t)0x0400)  /* Pin 10 selected */8 [0 q" X, J9 U+ s: F( C
  15. #define GPIO_Pin_11                ((uint16_t)0x0800)  /* Pin 11 selected */  h: m; G9 I& M( H5 A; h3 L
  16. #define GPIO_Pin_12                ((uint16_t)0x1000)  /* Pin 12 selected */
    ( f, x; e" F+ [
  17. #define GPIO_Pin_13                ((uint16_t)0x2000)  /* Pin 13 selected */6 }/ O0 r  g' R4 z% y, Z) @
  18. #define GPIO_Pin_14                ((uint16_t)0x4000)  /* Pin 14 selected */. ]% Y, _3 J9 i0 q' q% F
  19. #define GPIO_Pin_15                ((uint16_t)0x8000)  /* Pin 15 selected */
    " I. @# i6 s  ^
  20. #define GPIO_Pin_All               ((uint16_t)0xFFFF)  /* All pins selected */
    " M3 M9 M! ~$ F8 U' ~  P% O
  21. ) d% F" v/ c% x! U
  22. #define GPIO_PIN_MASK              ((uint32_t)0x0000FFFF) /* PIN mask for assert test */) s9 M0 x' V/ P- u2 f# Z, Y, @
  23. #define IS_GPIO_PIN(PIN)           (((PIN) & GPIO_PIN_MASK ) != (uint32_t)0x00)2 y/ M6 `# {4 y
  24. #define IS_GET_GPIO_PIN(PIN) (((PIN) == GPIO_Pin_0) || \& A% d, G) ~! w7 e
  25.                               ((PIN) == GPIO_Pin_1) || \1 x! h! Y4 h" @2 p( }. p8 i! [
  26.                               ((PIN) == GPIO_Pin_2) || \. w; p; [' R0 t
  27.                               ((PIN) == GPIO_Pin_3) || \
    - `3 E; d" n$ D  K
  28.                               ((PIN) == GPIO_Pin_4) || \
    + ~5 r4 J' I( {: A6 }1 F
  29.                               ((PIN) == GPIO_Pin_5) || \
    ' F/ `' }+ d$ Y/ A5 z
  30.                               ((PIN) == GPIO_Pin_6) || \
    / c5 U2 g- j8 S  C
  31.                               ((PIN) == GPIO_Pin_7) || \0 i8 @7 L7 n6 O( b# h
  32.                               ((PIN) == GPIO_Pin_8) || \
    - e5 e3 i& e3 G+ ?' z6 m) q
  33.                               ((PIN) == GPIO_Pin_9) || \
    2 K" a) u  f7 Q1 u& K! \/ Q
  34.                               ((PIN) == GPIO_Pin_10) || \
    ; e" B' z+ l9 K" b+ E
  35.                               ((PIN) == GPIO_Pin_11) || \3 A8 C5 p. t7 }  F( R4 Y
  36.                               ((PIN) == GPIO_Pin_12) || \
    $ R! Y3 k7 P9 W6 U1 ]/ E5 g
  37.                               ((PIN) == GPIO_Pin_13) || \
      X* i- Z2 k! d( ^' I
  38.                               ((PIN) == GPIO_Pin_14) || \
    1 k* c1 _/ c+ ~4 O$ z( S5 ^- J
  39.                               ((PIN) == GPIO_Pin_15))
* d/ b0 t. b, h) T# b: h0 D
GPIO合法的引脚源) I  A9 v: t: B# w/ ~
- U1 [: F3 t! W  `
& Z! z/ i% p" p7 {6 S5 h7 G
  1. /** @defgroup GPIO_Pin_sources
    5 _+ {  S  M1 F0 W, H, X4 T' z
  2.   * @{
    # s. W- x1 K( D1 a: p* o
  3.   */
    2 u% |- g# L4 e: Q  X
  4. #define GPIO_PinSource0            ((uint8_t)0x00)! {8 N+ Z3 {8 n0 W6 ?9 E
  5. #define GPIO_PinSource1            ((uint8_t)0x01)
    & y+ n$ A/ t4 h) X
  6. #define GPIO_PinSource2            ((uint8_t)0x02)7 R/ r8 ~' P- X. X/ J
  7. #define GPIO_PinSource3            ((uint8_t)0x03)5 U  O8 s* [  O* N  a, C
  8. #define GPIO_PinSource4            ((uint8_t)0x04)$ V. b$ H8 _- s4 q$ L7 ]3 O; H( n
  9. #define GPIO_PinSource5            ((uint8_t)0x05)% p& |5 A' C6 X9 g! X* _0 E" c
  10. #define GPIO_PinSource6            ((uint8_t)0x06)
    7 u) |' J: l1 ?, k# u, c# L6 A
  11. #define GPIO_PinSource7            ((uint8_t)0x07)
    8 q. p; q8 K' h
  12. #define GPIO_PinSource8            ((uint8_t)0x08)
    ' @; I) [- g1 h+ v+ H, ]6 S  v0 D
  13. #define GPIO_PinSource9            ((uint8_t)0x09)
    * Y$ N0 x, ?4 ^
  14. #define GPIO_PinSource10           ((uint8_t)0x0A)
    $ d+ U* w/ O, Z" K# _1 F
  15. #define GPIO_PinSource11           ((uint8_t)0x0B)
    $ o) ?! d4 i6 i  e6 b, H! f
  16. #define GPIO_PinSource12           ((uint8_t)0x0C)
    / U8 B- W+ [( w# z' V$ Z  e# z; ]3 t- p
  17. #define GPIO_PinSource13           ((uint8_t)0x0D)
    5 Q* R/ A: E- ]: N6 T! L7 Y( ^1 p. s
  18. #define GPIO_PinSource14           ((uint8_t)0x0E)
    ( U1 @" p" }6 j9 g' D
  19. #define GPIO_PinSource15           ((uint8_t)0x0F)
    ' |/ i7 P. p0 Z
  20. 5 I; k$ f6 w- u3 A
  21. #define IS_GPIO_PIN_SOURCE(PINSOURCE) (((PINSOURCE) == GPIO_PinSource0) || \
    7 L+ k" C1 w$ p( x
  22.                                        ((PINSOURCE) == GPIO_PinSource1) || \  f. H( O% V. ^
  23.                                        ((PINSOURCE) == GPIO_PinSource2) || \
    5 D- M5 j, S1 f( C2 F
  24.                                        ((PINSOURCE) == GPIO_PinSource3) || \
    0 a  Y, ]/ O& F! I+ F1 \  ?) H8 o
  25.                                        ((PINSOURCE) == GPIO_PinSource4) || \
    & r; G. \$ h: s7 {
  26.                                        ((PINSOURCE) == GPIO_PinSource5) || \! y1 s1 S/ Y  Z( d
  27.                                        ((PINSOURCE) == GPIO_PinSource6) || \8 L3 }! a7 C8 c+ E
  28.                                        ((PINSOURCE) == GPIO_PinSource7) || \* Y% [1 J4 ?& U
  29.                                        ((PINSOURCE) == GPIO_PinSource8) || \- S0 w+ ?- w1 U* _! v
  30.                                        ((PINSOURCE) == GPIO_PinSource9) || \) k. C6 J- ?) {
  31.                                        ((PINSOURCE) == GPIO_PinSource10) || \/ L6 H: e" k" N  n' H, |
  32.                                        ((PINSOURCE) == GPIO_PinSource11) || \# Q0 P- M3 I  \  G# o  q
  33.                                        ((PINSOURCE) == GPIO_PinSource12) || \
    2 S/ @: E  L3 L, X
  34.                                        ((PINSOURCE) == GPIO_PinSource13) || \
    ( Z! ?: d9 e* [6 @6 x" u: j% x" p1 Q
  35.                                        ((PINSOURCE) == GPIO_PinSource14) || \
    7 C' r5 s0 f( k
  36.                                        ((PINSOURCE) == GPIO_PinSource15))
- o; {  P! C  R; l
04. GPIO相关函数) n! c# t% t* ~6 N* @& z* I
  1. /*  Function used to set the GPIO configuration to the default reset state ****/# [. Y0 s+ S, A6 P- q$ l
  2. //配置GPIO为默认状态- j- I9 r- @+ t* C! b5 @" I
  3. void GPIO_DeInit(GPIO_TypeDef* GPIOx);+ t  B1 S% c9 o, M7 ^' j+ a5 J
  4. * j+ ~8 ?3 v% p0 A9 t
  5. /* Initialization and Configuration functions *********************************/2 X& G0 I) O% w* J" W
  6. //GPIO初始化2 q  I4 V  j' t* g* V  `
  7. void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct);9 P* m, f* o" Y# @3 O! [+ L+ X* N0 O
  8. //GPIO结构体初始化- I% _3 R* V5 M( G
  9. void GPIO_StructInit(GPIO_InitTypeDef* GPIO_InitStruct);
    2 o/ S9 |  R4 P! X2 x, Q: D
  10. //GPIO锁配置/ x& i# ^8 }( a6 y% A3 m- R: F
  11. void GPIO_PinLockConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);: ]$ n+ h0 z% R0 u0 _
  12.   V& P/ D" s9 E9 ?7 ~3 g
  13. /* GPIO Read and Write functions **********************************************/; `: v7 A: S( r
  14. //GPIO读写函数" ]+ k* m+ u/ a& E' W
  15. uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);+ {! m3 W4 v2 u/ y
  16. uint16_t GPIO_ReadInputData(GPIO_TypeDef* GPIOx);
    ( t: R* d# Q7 ]0 v0 C
  17. uint8_t GPIO_ReadOutputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);
    % [3 L" i+ q% i  H, m( ]$ R) v
  18. uint16_t GPIO_ReadOutputData(GPIO_TypeDef* GPIOx);) |  J& h) s# U# P% p' C, b$ w. W
  19. void GPIO_SetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);9 D. R  t3 {' w$ T- M
  20. void GPIO_ResetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);3 k1 n& K2 |. H  T! a5 P, ]
  21. void GPIO_WriteBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, BitAction BitVal);
    ! t* p. L( S$ Z( H* y
  22. void GPIO_Write(GPIO_TypeDef* GPIOx, uint16_t PortVal);
    . E. _' T: F" I' b5 I3 s" A
  23. void GPIO_ToggleBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);, a8 _9 P+ n0 }4 s" ~
  24. ! ~' s: ~- @# t* K! K: M7 m
  25. /* GPIO Alternate functions configuration function ****************************/
      M5 r$ M( j2 u5 x
  26. void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF);
7 E! P% r  c0 l5 e5 ~- _! Q
05. GPIO其它相关
  y( y4 _0 u% z+ Istm32f4xx.h文件中' ]4 t' a5 W2 S4 t
7 ?* K+ E! Y4 V7 {$ Q通用GPIO结构体封装
5 r# h& w# N$ I1 a; C
) Z3 }2 b9 W% O, O: u" Y( X! }
  1. typedef struct5 Z+ l5 a' D3 Z$ w
  2. {
    - E  \% |: y  S% a5 Q- e7 x) S; {# m+ h
  3.   __IO uint32_t MODER;    /*!< GPIO port mode register,               Address offset: 0x00      */
    / E) X1 S; e! F
  4.   __IO uint32_t OTYPER;   /*!< GPIO port output type register,        Address offset: 0x04      */5 ]7 R- U; s0 r: p& L
  5.   __IO uint32_t OSPEEDR;  /*!< GPIO port output speed register,       Address offset: 0x08      */
    7 E5 C/ h/ w. R2 B- v6 y
  6.   __IO uint32_t PUPDR;    /*!< GPIO port pull-up/pull-down register,  Address offset: 0x0C      */4 t8 P& i; |; p. P8 U
  7.   __IO uint32_t IDR;      /*!< GPIO port input data register,         Address offset: 0x10      */
    5 g. [- A6 D) ~: c5 T+ t3 l
  8.   __IO uint32_t ODR;      /*!< GPIO port output data register,        Address offset: 0x14      */3 e, y9 E/ r0 P( a
  9.   __IO uint16_t BSRRL;    /*!< GPIO port bit set/reset low register,  Address offset: 0x18      */
    % o. J6 g& T. s, O7 B9 m
  10.   __IO uint16_t BSRRH;    /*!< GPIO port bit set/reset high register, Address offset: 0x1A      */
    , N8 W0 t4 P+ w- }( M! |
  11.   __IO uint32_t LCKR;     /*!< GPIO port configuration lock register, Address offset: 0x1C      */
    # A, p, k; o2 i
  12.   __IO uint32_t AFR[2];   /*!< GPIO alternate function registers,     Address offset: 0x20-0x24 */
    3 ~$ m1 P; J1 h$ Y% F- y$ E
  13. } GPIO_TypeDef;
$ F7 J' u9 g7 F% [' H3 D3 C
GPIO基地址6 K3 r1 z4 E; e4 x3 \
+ t- F# E; z1 p* k$ C$ [
  1. /*!< AHB1 peripherals */+ f! _- j" ^0 R: `9 ?+ r9 k
  2. #define GPIOA_BASE            (AHB1PERIPH_BASE + 0x0000)$ y. k/ N: u& I9 o/ F: H
  3. #define GPIOB_BASE            (AHB1PERIPH_BASE + 0x0400)
    * v/ x& K3 T# b! J2 O
  4. #define GPIOC_BASE            (AHB1PERIPH_BASE + 0x0800)
    7 h6 W* ?! u9 J2 }, Z$ S* P( R& L6 W
  5. #define GPIOD_BASE            (AHB1PERIPH_BASE + 0x0C00)& U3 e9 H0 g# [% K+ g
  6. #define GPIOE_BASE            (AHB1PERIPH_BASE + 0x1000)$ B8 |; F* h% ?+ g1 J# C
  7. #define GPIOF_BASE            (AHB1PERIPH_BASE + 0x1400)
    ) [( w0 d. K. E% p. u  Z8 o
  8. #define GPIOG_BASE            (AHB1PERIPH_BASE + 0x1800); D6 N; A8 [/ j: N+ [% ~+ c
  9. #define GPIOH_BASE            (AHB1PERIPH_BASE + 0x1C00)% {5 R$ q  R$ m, T) S3 D" J& B9 R# l( ]
  10. #define GPIOI_BASE            (AHB1PERIPH_BASE + 0x2000)/ ?- W" z" G* K8 z$ Q  C
  11. #define GPIOJ_BASE            (AHB1PERIPH_BASE + 0x2400)5 Q' n5 r& P$ u. Z0 u
  12. #define GPIOK_BASE            (AHB1PERIPH_BASE + 0x2800)
2 n2 f: A% t2 @! G# T
GPIO起始地址
4 q  t! L) ?6 T% ]; F; k$ g
5 u  Y& z+ I+ D9 U& Y1 k) F
  1. #define GPIOA               ((GPIO_TypeDef *) GPIOA_BASE); k! I; W: q. k9 g2 Q$ j
  2. #define GPIOB               ((GPIO_TypeDef *) GPIOB_BASE)# p. Z% J$ L/ z0 [4 D
  3. #define GPIOC               ((GPIO_TypeDef *) GPIOC_BASE)
    9 Y% M: r! P7 t2 U; T7 I: c
  4. #define GPIOD               ((GPIO_TypeDef *) GPIOD_BASE)
    6 z7 V& r1 u4 V3 J
  5. #define GPIOE               ((GPIO_TypeDef *) GPIOE_BASE)
    8 I/ X4 _0 x4 i% E; ?
  6. #define GPIOF               ((GPIO_TypeDef *) GPIOF_BASE)8 J3 h! f+ E& f/ h) m: J. m
  7. #define GPIOG               ((GPIO_TypeDef *) GPIOG_BASE)
    ; _" d, x" m. r$ k2 f
  8. #define GPIOH               ((GPIO_TypeDef *) GPIOH_BASE)
    , f. n! Y; k$ g7 t, ?% {
  9. #define GPIOI               ((GPIO_TypeDef *) GPIOI_BASE)
    6 d! g; v2 w8 _( B* U' B
  10. #define GPIOJ               ((GPIO_TypeDef *) GPIOJ_BASE)
    0 w: s* B' z/ m+ y
  11. #define GPIOK               ((GPIO_TypeDef *) GPIOK_BASE)
' I: f/ f- N4 Q+ H- n5 p
GPIO寄存器相关位2 }( U$ s8 F  S# r5 M( i& O
: ?4 F2 E5 \( L5 A
  1. /******************************************************************************/# n. ?, y! |1 h$ C
  2. /*        */# J4 {  [3 A9 D7 V  m
  3. /*                            General Purpose I/O                             */' [# o9 z9 j7 e: [7 G! n+ F' @9 L
  4. /*        */
    9 ^6 u, L% n+ W7 E
  5. /******************************************************************************/
    ; U- ^) X/ X4 C/ k* \
  6. /******************  Bits definition for GPIO_MODER register  *****************/
    6 w; b) W( y6 V! a
  7. #define GPIO_MODER_MODER0                    ((uint32_t)0x00000003), J  Q! q  X$ h/ \, z% \
  8. #define GPIO_MODER_MODER0_0                  ((uint32_t)0x00000001); {9 v+ \1 C4 H$ P0 ^
  9. #define GPIO_MODER_MODER0_1                  ((uint32_t)0x00000002)
    6 i* G7 m4 r( p2 a% g2 q5 P3 M* T
  10. 4 }4 Z+ L; `4 a
  11. #define GPIO_MODER_MODER1                    ((uint32_t)0x0000000C)2 f; j( I" m6 K- n, R0 b- y
  12. #define GPIO_MODER_MODER1_0                  ((uint32_t)0x00000004)
    0 X/ A5 m# B2 z
  13. #define GPIO_MODER_MODER1_1                  ((uint32_t)0x00000008)8 Q' k2 I3 j6 H4 K0 `$ i
  14. # E3 U, @. w5 h+ r3 M/ q) y1 P, F
  15. #define GPIO_MODER_MODER2                    ((uint32_t)0x00000030)
    ! i& R+ i6 d4 _! p' B
  16. #define GPIO_MODER_MODER2_0                  ((uint32_t)0x00000010)
    ( M, H9 h/ y! \9 }6 J* Z5 W
  17. #define GPIO_MODER_MODER2_1                  ((uint32_t)0x00000020): E8 _$ b  O/ R6 o
  18. ; K) T& ^6 i4 f2 Z& G
  19. #define GPIO_MODER_MODER3                    ((uint32_t)0x000000C0)
    ( k$ A- |9 q, n2 ~! C
  20. #define GPIO_MODER_MODER3_0                  ((uint32_t)0x00000040)0 Q' h8 @6 F- ]8 [, ?5 Q- q, L
  21. #define GPIO_MODER_MODER3_1                  ((uint32_t)0x00000080)! _) u' \1 B3 \2 B
  22. 5 C: m; `! Y8 y+ J' J8 e1 m
  23. #define GPIO_MODER_MODER4                    ((uint32_t)0x00000300)8 \7 A7 y, O4 J/ M8 B
  24. #define GPIO_MODER_MODER4_0                  ((uint32_t)0x00000100)- M4 u$ P, J9 w0 O
  25. #define GPIO_MODER_MODER4_1                  ((uint32_t)0x00000200)( m- |* |" Y2 U! S
  26. " N4 H  V1 {9 d9 ]% w( x
  27. #define GPIO_MODER_MODER5                    ((uint32_t)0x00000C00)  Z9 P& C/ n1 \, M
  28. #define GPIO_MODER_MODER5_0                  ((uint32_t)0x00000400)
    5 i; N$ b2 X, f$ e  |: v! a
  29. #define GPIO_MODER_MODER5_1                  ((uint32_t)0x00000800)
    3 b- K: c; W, ^# B' O/ s
  30. & f! c3 l' d, P; Y
  31. #define GPIO_MODER_MODER6                    ((uint32_t)0x00003000)
    ; [3 b. D$ N/ Y1 \3 T( \: R% s; V
  32. #define GPIO_MODER_MODER6_0                  ((uint32_t)0x00001000)# U4 U( X2 e0 m0 U3 A1 k8 H- L  Y
  33. #define GPIO_MODER_MODER6_1                  ((uint32_t)0x00002000)
    # r! L" O" h- G2 `4 G
  34. - b- r, f  o  g: o
  35. #define GPIO_MODER_MODER7                    ((uint32_t)0x0000C000)
    0 o+ b! G4 h2 N7 _- C* x" i
  36. #define GPIO_MODER_MODER7_0                  ((uint32_t)0x00004000)
    8 u3 u) g9 W- x( m1 J
  37. #define GPIO_MODER_MODER7_1                  ((uint32_t)0x00008000)
    ) t3 z- [0 h  p$ t! `2 y3 [
  38. 6 H; g& H8 U4 d5 y
  39. #define GPIO_MODER_MODER8                    ((uint32_t)0x00030000)
    7 W( R0 t* @+ b! e! C5 C, X1 Z8 P
  40. #define GPIO_MODER_MODER8_0                  ((uint32_t)0x00010000)" |4 F0 h; O7 E2 c7 t9 D
  41. #define GPIO_MODER_MODER8_1                  ((uint32_t)0x00020000)
    : M: T. [' f2 _6 ^1 ^5 f
  42. ; N  [# c: \% O: G1 ~" w# [
  43. #define GPIO_MODER_MODER9                    ((uint32_t)0x000C0000)/ G/ j! `" q0 y- a4 I# s1 e
  44. #define GPIO_MODER_MODER9_0                  ((uint32_t)0x00040000)
    . v2 B) F/ g% g  s  m) [
  45. #define GPIO_MODER_MODER9_1                  ((uint32_t)0x00080000)" Q4 ^3 ~+ e; p) C( y
  46. 9 d. P, @2 [, o( b& |' h$ y
  47. #define GPIO_MODER_MODER10                   ((uint32_t)0x00300000): K4 A( n; B3 l* R
  48. #define GPIO_MODER_MODER10_0                 ((uint32_t)0x00100000)
    - ^; Q- F/ d# k+ y/ ~9 n- p1 @
  49. #define GPIO_MODER_MODER10_1                 ((uint32_t)0x00200000)
    - H1 O  k  F& C+ e
  50.   j% u1 o1 @2 ?3 V: y7 L, p" O9 y
  51. #define GPIO_MODER_MODER11                   ((uint32_t)0x00C00000)
    7 m# @; M1 y( L! Y# T/ f6 R$ D5 V
  52. #define GPIO_MODER_MODER11_0                 ((uint32_t)0x00400000)- B7 M! T; a+ e8 O
  53. #define GPIO_MODER_MODER11_1                 ((uint32_t)0x00800000)9 M4 @8 p, _# s# ~  c* k
  54. 9 \9 h9 s: d6 m6 {. p# h. X
  55. #define GPIO_MODER_MODER12                   ((uint32_t)0x03000000)2 o; G0 I4 `# g& M4 l
  56. #define GPIO_MODER_MODER12_0                 ((uint32_t)0x01000000); s* m6 F$ e2 i# R$ F0 c9 {$ `: t
  57. #define GPIO_MODER_MODER12_1                 ((uint32_t)0x02000000)
    ) C# v  N" U) x. r/ _
  58. - z  {: I, D! v: D& Q) N
  59. #define GPIO_MODER_MODER13                   ((uint32_t)0x0C000000)- f8 b- H) u+ l/ F2 \& D$ M
  60. #define GPIO_MODER_MODER13_0                 ((uint32_t)0x04000000)
    ! g4 `2 `& S. b
  61. #define GPIO_MODER_MODER13_1                 ((uint32_t)0x08000000)
    ( K% h: F, w! ]+ v6 B
  62. * m" h$ B" m( ?& V/ E
  63. #define GPIO_MODER_MODER14                   ((uint32_t)0x30000000)
    ; r- ^# S7 [  ~1 x7 a
  64. #define GPIO_MODER_MODER14_0                 ((uint32_t)0x10000000): j( k7 q. c9 u! W; L
  65. #define GPIO_MODER_MODER14_1                 ((uint32_t)0x20000000)
    + e6 r: J1 k  E* Q: m/ b
  66. 1 r1 k" v) x" d* m$ U% D' {1 U. {
  67. #define GPIO_MODER_MODER15                   ((uint32_t)0xC0000000)  Y; x( y% W. a8 U3 U
  68. #define GPIO_MODER_MODER15_0                 ((uint32_t)0x40000000)
    $ j6 t4 d9 ?; u% K% j9 f
  69. #define GPIO_MODER_MODER15_1                 ((uint32_t)0x80000000)
    : o6 z- Z0 _7 u3 N7 y& V4 n
  70. * N' E" _. c, X, j8 h" O6 U4 U. K
  71. /******************  Bits definition for GPIO_OTYPER register  ****************/+ u. {, F4 b4 j1 Z5 t& Q' ^
  72. #define GPIO_OTYPER_OT_0                     ((uint32_t)0x00000001)) x, Z: {5 Y+ A% J9 N
  73. #define GPIO_OTYPER_OT_1                     ((uint32_t)0x00000002)
    & Y1 Y6 _8 g' B9 g8 f
  74. #define GPIO_OTYPER_OT_2                     ((uint32_t)0x00000004)- E+ z7 g2 @' X4 T; l
  75. #define GPIO_OTYPER_OT_3                     ((uint32_t)0x00000008)
    4 H, j3 p4 N3 K& p) [
  76. #define GPIO_OTYPER_OT_4                     ((uint32_t)0x00000010)$ s3 d  d4 ]1 C0 p; z% O0 M6 d
  77. #define GPIO_OTYPER_OT_5                     ((uint32_t)0x00000020)& x1 P7 o( t$ R  @- O& u2 \2 _
  78. #define GPIO_OTYPER_OT_6                     ((uint32_t)0x00000040), _# y: s# ^* C  q5 I* `6 t
  79. #define GPIO_OTYPER_OT_7                     ((uint32_t)0x00000080)
    % ?4 J. r- X: s
  80. #define GPIO_OTYPER_OT_8                     ((uint32_t)0x00000100)& i- ]: U% S( @+ @* |& C
  81. #define GPIO_OTYPER_OT_9                     ((uint32_t)0x00000200); U6 w; ~5 h& f. m) f7 b0 L$ M# E
  82. #define GPIO_OTYPER_OT_10                    ((uint32_t)0x00000400)
    ' |* ]4 f+ w& ]
  83. #define GPIO_OTYPER_OT_11                    ((uint32_t)0x00000800)
    6 P# ~4 c6 |% O7 R' `
  84. #define GPIO_OTYPER_OT_12                    ((uint32_t)0x00001000)" m7 h. y8 s) F$ Z$ c, e: z
  85. #define GPIO_OTYPER_OT_13                    ((uint32_t)0x00002000)/ V' e4 u  o% n
  86. #define GPIO_OTYPER_OT_14                    ((uint32_t)0x00004000)
    : C" Z, o) w; }/ [! u3 a6 O
  87. #define GPIO_OTYPER_OT_15                    ((uint32_t)0x00008000)! o) \$ c' w0 A
  88. % |3 G! N2 }/ C4 `' m
  89. /******************  Bits definition for GPIO_OSPEEDR register  ***************/; c6 I: P* g% w4 d/ J
  90. #define GPIO_OSPEEDER_OSPEEDR0               ((uint32_t)0x00000003)0 r9 b( E$ e1 |5 ]% Z' H1 \
  91. #define GPIO_OSPEEDER_OSPEEDR0_0             ((uint32_t)0x00000001)
    % Z5 S) }$ l/ Y# D; A
  92. #define GPIO_OSPEEDER_OSPEEDR0_1             ((uint32_t)0x00000002)
    4 W* N0 W' e; R0 q5 e
  93. 9 [8 R9 R) }) Z1 k0 z4 A; ^, G
  94. #define GPIO_OSPEEDER_OSPEEDR1               ((uint32_t)0x0000000C)
    ! d, n' q3 Y5 O8 ~* [2 {8 z* R9 `
  95. #define GPIO_OSPEEDER_OSPEEDR1_0             ((uint32_t)0x00000004)
    3 y  \; A7 K1 R' p: x
  96. #define GPIO_OSPEEDER_OSPEEDR1_1             ((uint32_t)0x00000008): I7 Y" v* n* Y. c/ M
  97. 4 C; h# K3 F* c' @$ x1 X2 n6 I' i
  98. #define GPIO_OSPEEDER_OSPEEDR2               ((uint32_t)0x00000030)7 B, A% X& y3 d' B" F5 V# w
  99. #define GPIO_OSPEEDER_OSPEEDR2_0             ((uint32_t)0x00000010)
    - z0 n1 d. j3 l- k
  100. #define GPIO_OSPEEDER_OSPEEDR2_1             ((uint32_t)0x00000020)- E7 l  Y# t$ p7 L
  101. 3 ], s3 M. Z: J' X
  102. #define GPIO_OSPEEDER_OSPEEDR3               ((uint32_t)0x000000C0)& `( v5 k8 e: [9 a4 J, c
  103. #define GPIO_OSPEEDER_OSPEEDR3_0             ((uint32_t)0x00000040)2 T9 N# S0 m4 x9 p- \8 l6 w7 C
  104. #define GPIO_OSPEEDER_OSPEEDR3_1             ((uint32_t)0x00000080)
    ) ~. X) F% u3 P6 S  J# I3 |
  105. ; T4 S; o* V  i2 \* @; D
  106. #define GPIO_OSPEEDER_OSPEEDR4               ((uint32_t)0x00000300)( X5 K/ r2 u( q: X  f6 [- q
  107. #define GPIO_OSPEEDER_OSPEEDR4_0             ((uint32_t)0x00000100)+ r) @' Y! G1 G2 @  y$ D4 O" A
  108. #define GPIO_OSPEEDER_OSPEEDR4_1             ((uint32_t)0x00000200)
    ) X4 R% h1 A! y) ]0 d0 b9 u- P
  109. 6 W8 ^3 w3 K5 L0 V
  110. #define GPIO_OSPEEDER_OSPEEDR5               ((uint32_t)0x00000C00)" e, `9 a# j1 `
  111. #define GPIO_OSPEEDER_OSPEEDR5_0             ((uint32_t)0x00000400)
      V  X! a8 l7 }8 F7 t  {4 z
  112. #define GPIO_OSPEEDER_OSPEEDR5_1             ((uint32_t)0x00000800)
    & u7 b' i% c" f( y2 [
  113. $ \2 y' ^6 q( e$ D
  114. #define GPIO_OSPEEDER_OSPEEDR6               ((uint32_t)0x00003000)5 {! m2 O7 l: \% B
  115. #define GPIO_OSPEEDER_OSPEEDR6_0             ((uint32_t)0x00001000)
    ! I$ p$ F  B  a/ p& j/ S0 e6 _# M
  116. #define GPIO_OSPEEDER_OSPEEDR6_1             ((uint32_t)0x00002000)8 p) ^% A, I" `2 c: G/ J
  117. / o4 S/ D- E8 H$ a7 v4 u( g* q$ D
  118. #define GPIO_OSPEEDER_OSPEEDR7               ((uint32_t)0x0000C000)
    / d0 f, o  w, b" \$ s# r
  119. #define GPIO_OSPEEDER_OSPEEDR7_0             ((uint32_t)0x00004000)- g% L8 Y9 T; ^$ V4 o- I
  120. #define GPIO_OSPEEDER_OSPEEDR7_1             ((uint32_t)0x00008000)
    % t5 e! N7 L6 K( q8 g+ K$ A
  121. 8 g8 n# H! h5 ?* W
  122. #define GPIO_OSPEEDER_OSPEEDR8               ((uint32_t)0x00030000); `8 J0 a- f" G2 D- w. I
  123. #define GPIO_OSPEEDER_OSPEEDR8_0             ((uint32_t)0x00010000)
    : s$ M* z  E8 b$ O( o
  124. #define GPIO_OSPEEDER_OSPEEDR8_1             ((uint32_t)0x00020000)% D3 Y4 P3 U; O* P- c. q2 T5 d
  125. ) k' w6 m2 V$ y  ^+ w. }) u) r
  126. #define GPIO_OSPEEDER_OSPEEDR9               ((uint32_t)0x000C0000)% Q7 O) G/ K: D6 j9 \  {
  127. #define GPIO_OSPEEDER_OSPEEDR9_0             ((uint32_t)0x00040000)
    % b' R* e% K; s! z. J
  128. #define GPIO_OSPEEDER_OSPEEDR9_1             ((uint32_t)0x00080000)
    * o$ l6 I/ l5 z! B) x
  129. ( T7 O# p9 o* s8 m6 d( D0 M
  130. #define GPIO_OSPEEDER_OSPEEDR10              ((uint32_t)0x00300000)
    ; M* U. v- j5 r$ K- w) c( x) r
  131. #define GPIO_OSPEEDER_OSPEEDR10_0            ((uint32_t)0x00100000)' F' v% I4 V  f
  132. #define GPIO_OSPEEDER_OSPEEDR10_1            ((uint32_t)0x00200000)) j6 N/ E6 S. ?) L% t+ l
  133. . ]# o: b6 }& i- X7 ~
  134. #define GPIO_OSPEEDER_OSPEEDR11              ((uint32_t)0x00C00000)6 }3 n7 b, Y& w/ l6 s; w! [" l
  135. #define GPIO_OSPEEDER_OSPEEDR11_0            ((uint32_t)0x00400000)
    * w& b  Y8 D$ W" A' T0 L
  136. #define GPIO_OSPEEDER_OSPEEDR11_1            ((uint32_t)0x00800000)
    3 ^4 ]; U. |8 m8 a
  137. + g1 i: s8 i/ R1 p6 y
  138. #define GPIO_OSPEEDER_OSPEEDR12              ((uint32_t)0x03000000), n9 d' d& K; t2 M1 r' {
  139. #define GPIO_OSPEEDER_OSPEEDR12_0            ((uint32_t)0x01000000)/ ~( \  u7 Q; T. A! z! I
  140. #define GPIO_OSPEEDER_OSPEEDR12_1            ((uint32_t)0x02000000)
    * {. |# i9 _& i+ J8 w! g: u: n
  141.   b4 H. {  J( ^( ?" H& Q0 e! O% |2 Z
  142. #define GPIO_OSPEEDER_OSPEEDR13              ((uint32_t)0x0C000000)
    + }7 ^/ J" O& g( l- m" @
  143. #define GPIO_OSPEEDER_OSPEEDR13_0            ((uint32_t)0x04000000)2 B4 l& ^/ `: e" F2 R+ \" S
  144. #define GPIO_OSPEEDER_OSPEEDR13_1            ((uint32_t)0x08000000)
    0 j! E& j) P& u; y! F+ [9 X+ I
  145. 2 G) ~" J, U6 |
  146. #define GPIO_OSPEEDER_OSPEEDR14              ((uint32_t)0x30000000)
    1 m* D1 l, L$ f5 V7 Q
  147. #define GPIO_OSPEEDER_OSPEEDR14_0            ((uint32_t)0x10000000)
    6 V4 r% F# l; X! ~" J
  148. #define GPIO_OSPEEDER_OSPEEDR14_1            ((uint32_t)0x20000000)
    ; e! N$ e& b7 N3 e: C3 S2 i
  149.   R* c+ b( g8 C. P8 r
  150. #define GPIO_OSPEEDER_OSPEEDR15              ((uint32_t)0xC0000000)" G7 |+ z( I8 D3 I! R6 f
  151. #define GPIO_OSPEEDER_OSPEEDR15_0            ((uint32_t)0x40000000)
    ; D" k- V7 k1 s* H
  152. #define GPIO_OSPEEDER_OSPEEDR15_1            ((uint32_t)0x80000000)3 [. [* v* L- e/ B2 i. a5 t
  153. & Q( x3 \) J( E6 Q8 P( h! V
  154. /******************  Bits definition for GPIO_PUPDR register  *****************/
    * K2 C5 N# g2 Y' u
  155. #define GPIO_PUPDR_PUPDR0                    ((uint32_t)0x00000003)0 i7 ?$ H  y/ L1 j$ [
  156. #define GPIO_PUPDR_PUPDR0_0                  ((uint32_t)0x00000001)
    + L4 S+ v* S0 r( C7 E( C+ @! v9 q
  157. #define GPIO_PUPDR_PUPDR0_1                  ((uint32_t)0x00000002), L- a% y! L0 B% g
  158. 1 v  D: o" G$ ~' z& b2 s$ c+ T( Z; q
  159. #define GPIO_PUPDR_PUPDR1                    ((uint32_t)0x0000000C)2 Y7 q% w# A- K9 W: x
  160. #define GPIO_PUPDR_PUPDR1_0                  ((uint32_t)0x00000004)
    " G) b6 f  m9 o3 J% F+ l
  161. #define GPIO_PUPDR_PUPDR1_1                  ((uint32_t)0x00000008)" U! L6 D7 ^- u. A- B: q7 m
  162. / [  ^% m: y! s* }9 s
  163. #define GPIO_PUPDR_PUPDR2                    ((uint32_t)0x00000030)
    6 S9 Z0 q4 n; ^) }- F! V# b
  164. #define GPIO_PUPDR_PUPDR2_0                  ((uint32_t)0x00000010)
    % W0 P% N& n$ o" D
  165. #define GPIO_PUPDR_PUPDR2_1                  ((uint32_t)0x00000020)
    , q- t) u$ l! l% i( I  S
  166. 8 f3 ~1 s% |5 e, O* @( ?1 C
  167. #define GPIO_PUPDR_PUPDR3                    ((uint32_t)0x000000C0)
    9 g, T& z# q) D% w) _
  168. #define GPIO_PUPDR_PUPDR3_0                  ((uint32_t)0x00000040)
    ) Y* s$ v% N3 u" U1 l$ U* I
  169. #define GPIO_PUPDR_PUPDR3_1                  ((uint32_t)0x00000080)% a7 q) O  K& S
  170. - q. v& m* }: @: F5 G- T" _$ S  G9 E
  171. #define GPIO_PUPDR_PUPDR4                    ((uint32_t)0x00000300)
    : a3 ?& a6 f# h, G
  172. #define GPIO_PUPDR_PUPDR4_0                  ((uint32_t)0x00000100)/ d3 R+ \0 ^$ R, i5 x: Y% x
  173. #define GPIO_PUPDR_PUPDR4_1                  ((uint32_t)0x00000200)5 w2 p) P, i) L5 A+ r0 C
  174. 0 L9 n* A; I2 r  W, k
  175. #define GPIO_PUPDR_PUPDR5                    ((uint32_t)0x00000C00)) }! ?3 W( i7 x9 S8 |& z
  176. #define GPIO_PUPDR_PUPDR5_0                  ((uint32_t)0x00000400)
    1 N* ]- t( ~  y6 s3 x: ?, i% Z
  177. #define GPIO_PUPDR_PUPDR5_1                  ((uint32_t)0x00000800)  a) {7 o4 @" a* V. q. H! x# S
  178. ' @, O: {7 r2 _' j9 K/ W5 M
  179. #define GPIO_PUPDR_PUPDR6                    ((uint32_t)0x00003000)
    $ _2 n2 ^( G3 k7 y6 X$ C  m9 D! U
  180. #define GPIO_PUPDR_PUPDR6_0                  ((uint32_t)0x00001000)
    0 M) N9 t+ ^" M4 ~/ x7 q
  181. #define GPIO_PUPDR_PUPDR6_1                  ((uint32_t)0x00002000)6 _, V! p5 @! k4 _
  182. * B. }- b  F( e; N) [+ J
  183. #define GPIO_PUPDR_PUPDR7                    ((uint32_t)0x0000C000)3 z+ n; W! y' ^4 P7 ]) B
  184. #define GPIO_PUPDR_PUPDR7_0                  ((uint32_t)0x00004000)
    3 z9 \' {! j. d% c
  185. #define GPIO_PUPDR_PUPDR7_1                  ((uint32_t)0x00008000)
    ' f8 {- N' M  W
  186. 0 d$ U+ s+ D# R' m) r1 O8 ]9 k. A
  187. #define GPIO_PUPDR_PUPDR8                    ((uint32_t)0x00030000); z3 X: F4 i  u5 N# \- Y- m
  188. #define GPIO_PUPDR_PUPDR8_0                  ((uint32_t)0x00010000)" `' ?8 F2 H; p8 X# \' d& @
  189. #define GPIO_PUPDR_PUPDR8_1                  ((uint32_t)0x00020000)" g" r+ U5 h; {( {3 \) y8 w9 C
  190. 6 J3 F0 U5 q+ _3 q+ j
  191. #define GPIO_PUPDR_PUPDR9                    ((uint32_t)0x000C0000)7 W  z. h. ^, q& N1 v
  192. #define GPIO_PUPDR_PUPDR9_0                  ((uint32_t)0x00040000)1 [9 z' W9 q& _! ]
  193. #define GPIO_PUPDR_PUPDR9_1                  ((uint32_t)0x00080000)2 F6 }$ m* _& A0 A1 c" G
  194. / v5 M# O1 [' I3 Z9 C& e' f* m
  195. #define GPIO_PUPDR_PUPDR10                   ((uint32_t)0x00300000)
    4 z  [. [+ j: q( F! U" B  W( R  q( }6 k
  196. #define GPIO_PUPDR_PUPDR10_0                 ((uint32_t)0x00100000)# Z5 B* E; X/ ~5 g- u
  197. #define GPIO_PUPDR_PUPDR10_1                 ((uint32_t)0x00200000)
    # W2 i# Z! F# {# L) D& {
  198. / ?4 |+ K0 q) t. U# c" T6 D
  199. #define GPIO_PUPDR_PUPDR11                   ((uint32_t)0x00C00000)" g7 H! T- E0 \! L# _4 u
  200. #define GPIO_PUPDR_PUPDR11_0                 ((uint32_t)0x00400000)0 U; u# z0 H4 P  u% I' P* |
  201. #define GPIO_PUPDR_PUPDR11_1                 ((uint32_t)0x00800000)
    ) r- S( v4 k3 e
  202.   M: W0 d- ^  X- G" J! h' s2 N. v/ E
  203. #define GPIO_PUPDR_PUPDR12                   ((uint32_t)0x03000000)0 x: y: D, y, U7 y; \
  204. #define GPIO_PUPDR_PUPDR12_0                 ((uint32_t)0x01000000)
    2 j0 f8 z  W2 l4 T# D
  205. #define GPIO_PUPDR_PUPDR12_1                 ((uint32_t)0x02000000)
    8 V/ k" F: k: v- I( M, P8 `1 j
  206. 6 ]$ _  b5 t- J) y' f9 b* \; Q0 g3 c
  207. #define GPIO_PUPDR_PUPDR13                   ((uint32_t)0x0C000000)
    2 ?6 X' L& U1 i
  208. #define GPIO_PUPDR_PUPDR13_0                 ((uint32_t)0x04000000)7 G* j1 R2 z, r; O& o- g
  209. #define GPIO_PUPDR_PUPDR13_1                 ((uint32_t)0x08000000)
    8 F2 m$ t" L8 t
  210. 2 P' B; ^+ i) t3 o) S8 L' T
  211. #define GPIO_PUPDR_PUPDR14                   ((uint32_t)0x30000000)( C& O, C1 D3 j4 d
  212. #define GPIO_PUPDR_PUPDR14_0                 ((uint32_t)0x10000000)# d9 r4 W- A4 }& g) h- ~/ [/ [
  213. #define GPIO_PUPDR_PUPDR14_1                 ((uint32_t)0x20000000). J/ n; U+ o. Y
  214. " r2 d* S6 V6 q# q1 F
  215. #define GPIO_PUPDR_PUPDR15                   ((uint32_t)0xC0000000)
    0 f$ o6 d! P& D6 K* E3 @; d  a
  216. #define GPIO_PUPDR_PUPDR15_0                 ((uint32_t)0x40000000)
    : l- @0 `% R8 ^& J7 b  ^# m. m2 }
  217. #define GPIO_PUPDR_PUPDR15_1                 ((uint32_t)0x80000000)
    * C9 c5 ~' z/ t- \( h0 {
  218. ! a# j% r9 @" {0 w8 U
  219. /******************  Bits definition for GPIO_IDR register  *******************/
    ' ]0 f3 c7 Y& d$ p1 ^) ~/ Q
  220. #define GPIO_IDR_IDR_0                       ((uint32_t)0x00000001)
    9 U: _6 U. Z4 m4 b3 l7 G0 z
  221. #define GPIO_IDR_IDR_1                       ((uint32_t)0x00000002), m* z9 e+ g1 w. N& U) C9 D
  222. #define GPIO_IDR_IDR_2                       ((uint32_t)0x00000004), d8 C% F4 S9 Q) d& _0 o3 E, S# {
  223. #define GPIO_IDR_IDR_3                       ((uint32_t)0x00000008)
    5 i' O. h3 K" \& n) s
  224. #define GPIO_IDR_IDR_4                       ((uint32_t)0x00000010)& i0 w& J6 p: z
  225. #define GPIO_IDR_IDR_5                       ((uint32_t)0x00000020)$ E! {4 D8 N  o( W5 r0 U
  226. #define GPIO_IDR_IDR_6                       ((uint32_t)0x00000040)
    ( L$ ~5 ~. h: ]' N
  227. #define GPIO_IDR_IDR_7                       ((uint32_t)0x00000080)
    8 B! ~) [/ U4 D9 U
  228. #define GPIO_IDR_IDR_8                       ((uint32_t)0x00000100)
    0 ~4 v* i/ ~2 \( {3 r5 J
  229. #define GPIO_IDR_IDR_9                       ((uint32_t)0x00000200)
    ; X& y8 n0 ^8 t" X" K# v' W
  230. #define GPIO_IDR_IDR_10                      ((uint32_t)0x00000400)* b0 H: y4 _, e
  231. #define GPIO_IDR_IDR_11                      ((uint32_t)0x00000800)/ F" i+ e7 D$ S
  232. #define GPIO_IDR_IDR_12                      ((uint32_t)0x00001000)
    # L) Z- t' V& F  l
  233. #define GPIO_IDR_IDR_13                      ((uint32_t)0x00002000)& [8 O; P4 W" f/ G2 `1 w
  234. #define GPIO_IDR_IDR_14                      ((uint32_t)0x00004000)
    4 E5 |, T# U, e, ^
  235. #define GPIO_IDR_IDR_15                      ((uint32_t)0x00008000)/ \. ?, E0 {& t0 x
  236. /* Old GPIO_IDR register bits definition, maintained for legacy purpose */
    : F$ D9 ~8 t" V' d- B' d
  237. #define GPIO_OTYPER_IDR_0                    GPIO_IDR_IDR_05 ~3 }6 h" F3 S# [5 i, J
  238. #define GPIO_OTYPER_IDR_1                    GPIO_IDR_IDR_1$ t+ o# z. I6 T6 u2 y+ |8 R: j
  239. #define GPIO_OTYPER_IDR_2                    GPIO_IDR_IDR_2
    , p' w* }8 M! j! B; |$ m- j5 Y; F3 L
  240. #define GPIO_OTYPER_IDR_3                    GPIO_IDR_IDR_3
    ( A  d) Q) }) J8 W
  241. #define GPIO_OTYPER_IDR_4                    GPIO_IDR_IDR_4
    9 h5 _7 b4 ~& }; }! ^! B+ a+ E
  242. #define GPIO_OTYPER_IDR_5                    GPIO_IDR_IDR_5
    4 s- T$ k) N0 \3 T: P
  243. #define GPIO_OTYPER_IDR_6                    GPIO_IDR_IDR_6
    3 i0 x9 I$ @* n! Q+ W9 o/ q+ t3 y  m5 l
  244. #define GPIO_OTYPER_IDR_7                    GPIO_IDR_IDR_75 u! s9 N6 H3 V8 @- V' r7 l
  245. #define GPIO_OTYPER_IDR_8                    GPIO_IDR_IDR_8
    5 W& w4 `) A0 @8 @6 g# x/ F9 D
  246. #define GPIO_OTYPER_IDR_9                    GPIO_IDR_IDR_91 ]) \8 P7 o: m( h0 T: @5 t, O
  247. #define GPIO_OTYPER_IDR_10                   GPIO_IDR_IDR_10
    % z- Q% v: i9 e9 o/ J" f
  248. #define GPIO_OTYPER_IDR_11                   GPIO_IDR_IDR_110 H1 o4 k! w$ Z
  249. #define GPIO_OTYPER_IDR_12                   GPIO_IDR_IDR_12
    & z6 c" |, w" r& x. l- h
  250. #define GPIO_OTYPER_IDR_13                   GPIO_IDR_IDR_13# f$ ]3 a! Q# Z3 c; N  N4 V
  251. #define GPIO_OTYPER_IDR_14                   GPIO_IDR_IDR_14
    " }7 o1 F- T3 `  R+ f5 H5 h8 D
  252. #define GPIO_OTYPER_IDR_15                   GPIO_IDR_IDR_15
    / n- E  \8 }- L$ A" \
  253. 4 t) `+ }7 |' ~( ^0 w& k/ ~/ O% j4 u+ a  F
  254. /******************  Bits definition for GPIO_ODR register  *******************/
    . `% _; M+ ?$ E* w/ Q" V4 i
  255. #define GPIO_ODR_ODR_0                       ((uint32_t)0x00000001)! a; l/ C5 B' y: }. ?: d2 b& D2 x
  256. #define GPIO_ODR_ODR_1                       ((uint32_t)0x00000002)
      I5 u# \4 r+ L  [! U$ Y7 `  r
  257. #define GPIO_ODR_ODR_2                       ((uint32_t)0x00000004)
    & j' j# F% f8 t3 o# N/ T
  258. #define GPIO_ODR_ODR_3                       ((uint32_t)0x00000008)
    9 h/ W5 J, s8 n+ P, M% B6 q# ?  ^
  259. #define GPIO_ODR_ODR_4                       ((uint32_t)0x00000010)
      X& d, a/ L* i7 c
  260. #define GPIO_ODR_ODR_5                       ((uint32_t)0x00000020)- [0 S. f% l7 C5 k" k
  261. #define GPIO_ODR_ODR_6                       ((uint32_t)0x00000040)5 ?2 @7 q) m0 c4 Q
  262. #define GPIO_ODR_ODR_7                       ((uint32_t)0x00000080), k; E0 q1 M! d4 Q( F+ M! y
  263. #define GPIO_ODR_ODR_8                       ((uint32_t)0x00000100)
    5 G) `0 x  C8 M  J8 H& v) @7 V& {
  264. #define GPIO_ODR_ODR_9                       ((uint32_t)0x00000200)
    3 H; @% }3 ]/ @/ q* ]& w0 c5 ?4 N3 f
  265. #define GPIO_ODR_ODR_10                      ((uint32_t)0x00000400)
    9 w* r1 Z9 P- D6 A3 R: e- f5 H
  266. #define GPIO_ODR_ODR_11                      ((uint32_t)0x00000800)
    # H! i0 X/ |/ E" e, Q$ L  ?5 F+ e8 j
  267. #define GPIO_ODR_ODR_12                      ((uint32_t)0x00001000)
    ' ^. c, t5 [. l
  268. #define GPIO_ODR_ODR_13                      ((uint32_t)0x00002000)9 ?7 w( ]3 G  \+ W) o, x: x' m
  269. #define GPIO_ODR_ODR_14                      ((uint32_t)0x00004000)
    & l6 c7 ]- _7 R# o" f/ ?6 f- }
  270. #define GPIO_ODR_ODR_15                      ((uint32_t)0x00008000)5 O! a* |0 N* Z# [( N3 t+ ~
  271. /* Old GPIO_ODR register bits definition, maintained for legacy purpose */
    7 g! [3 R/ q; l* g/ O+ H( [
  272. #define GPIO_OTYPER_ODR_0                    GPIO_ODR_ODR_01 z% }( @% Y% A( I! ]! _* b; L
  273. #define GPIO_OTYPER_ODR_1                    GPIO_ODR_ODR_1, i$ Z1 K  x* W+ I5 z! r6 x, C# L
  274. #define GPIO_OTYPER_ODR_2                    GPIO_ODR_ODR_2
    7 C4 P! e6 _% ~' z$ n% ]9 ~1 Q- q
  275. #define GPIO_OTYPER_ODR_3                    GPIO_ODR_ODR_36 Q& V  M. E5 V/ _) |
  276. #define GPIO_OTYPER_ODR_4                    GPIO_ODR_ODR_4
    $ y' N9 ^# f: U: p1 w: _
  277. #define GPIO_OTYPER_ODR_5                    GPIO_ODR_ODR_5" O) M8 c$ H2 @. E
  278. #define GPIO_OTYPER_ODR_6                    GPIO_ODR_ODR_61 }4 z( ]- L' ]/ C7 Z' N2 u" ?& l
  279. #define GPIO_OTYPER_ODR_7                    GPIO_ODR_ODR_7
    / F1 _- }! X& Q9 @
  280. #define GPIO_OTYPER_ODR_8                    GPIO_ODR_ODR_8
    % t8 }( P1 @% c$ g9 K4 c
  281. #define GPIO_OTYPER_ODR_9                    GPIO_ODR_ODR_9
    0 D9 x" `1 Q5 G+ E) @5 ]0 R
  282. #define GPIO_OTYPER_ODR_10                   GPIO_ODR_ODR_100 z# c9 V3 V. p) D8 I) i- J
  283. #define GPIO_OTYPER_ODR_11                   GPIO_ODR_ODR_11
      s* S/ i2 b9 Q/ r+ F" |) ~& [
  284. #define GPIO_OTYPER_ODR_12                   GPIO_ODR_ODR_12
    + U$ S# y5 X  d" ^
  285. #define GPIO_OTYPER_ODR_13                   GPIO_ODR_ODR_13
    + p8 Q& Z1 R) J$ K1 u
  286. #define GPIO_OTYPER_ODR_14                   GPIO_ODR_ODR_14) J, |6 i  S+ L/ F, V6 I6 Y
  287. #define GPIO_OTYPER_ODR_15                   GPIO_ODR_ODR_15
    9 K* b: v( p. ]$ L( m
  288. % |% f- S* _* ?. y* v3 |% e( d5 u
  289. /******************  Bits definition for GPIO_BSRR register  ******************/
    ( t/ U( g4 D+ s; r4 q% m8 O2 B
  290. #define GPIO_BSRR_BS_0                       ((uint32_t)0x00000001)% U7 c8 a/ @! B/ J: |2 u% }
  291. #define GPIO_BSRR_BS_1                       ((uint32_t)0x00000002)
    9 M) z8 X- x3 }, p: q
  292. #define GPIO_BSRR_BS_2                       ((uint32_t)0x00000004)
    5 e. U5 R: y3 l( U) w
  293. #define GPIO_BSRR_BS_3                       ((uint32_t)0x00000008)
    - p2 A. j* [) T2 g7 q
  294. #define GPIO_BSRR_BS_4                       ((uint32_t)0x00000010)
    + A8 I5 `5 v* |- O
  295. #define GPIO_BSRR_BS_5                       ((uint32_t)0x00000020)& B0 t$ ~7 z4 H1 b- R( K# b+ t, h2 R: m% m
  296. #define GPIO_BSRR_BS_6                       ((uint32_t)0x00000040)
    + F& r" t! M( p5 C8 ^
  297. #define GPIO_BSRR_BS_7                       ((uint32_t)0x00000080)" T8 T. L5 }! s" c
  298. #define GPIO_BSRR_BS_8                       ((uint32_t)0x00000100)* o' _5 s' V$ `3 k4 v! o
  299. #define GPIO_BSRR_BS_9                       ((uint32_t)0x00000200)
    4 i; Q% i. w+ v1 |" [
  300. #define GPIO_BSRR_BS_10                      ((uint32_t)0x00000400)9 Q- F3 H( m$ q, C! T& x7 U
  301. #define GPIO_BSRR_BS_11                      ((uint32_t)0x00000800)
    8 x4 R8 P" x( @
  302. #define GPIO_BSRR_BS_12                      ((uint32_t)0x00001000)' O; H9 ~/ Y% x1 D! l7 m5 m% u
  303. #define GPIO_BSRR_BS_13                      ((uint32_t)0x00002000)) d( ~1 j/ _; y+ ]5 V
  304. #define GPIO_BSRR_BS_14                      ((uint32_t)0x00004000)! \" E, x5 ^# k6 l! M4 O5 Y' B9 k
  305. #define GPIO_BSRR_BS_15                      ((uint32_t)0x00008000)
    4 N1 L3 Z$ q0 b/ S$ n' `9 R- T
  306. #define GPIO_BSRR_BR_0                       ((uint32_t)0x00010000)
    4 |0 J$ @. ^4 ^+ R4 x
  307. #define GPIO_BSRR_BR_1                       ((uint32_t)0x00020000)9 [1 `9 O) E* A$ j- Y0 F; N
  308. #define GPIO_BSRR_BR_2                       ((uint32_t)0x00040000)' @+ V3 m1 }" m" B
  309. #define GPIO_BSRR_BR_3                       ((uint32_t)0x00080000)2 J+ @. J2 T  ^, @
  310. #define GPIO_BSRR_BR_4                       ((uint32_t)0x00100000)
      X. T" I# M6 l% m) G4 G
  311. #define GPIO_BSRR_BR_5                       ((uint32_t)0x00200000)
    4 v8 A+ r8 y; |
  312. #define GPIO_BSRR_BR_6                       ((uint32_t)0x00400000)
    7 P% N5 c) c5 h/ q. T2 s0 s6 ^
  313. #define GPIO_BSRR_BR_7                       ((uint32_t)0x00800000): A6 h  w% w: T. T2 q: N
  314. #define GPIO_BSRR_BR_8                       ((uint32_t)0x01000000)
      A( u% t7 r) ?, }- P
  315. #define GPIO_BSRR_BR_9                       ((uint32_t)0x02000000)
    . J8 ]; {6 D# Y9 K& F& }$ l' m% a
  316. #define GPIO_BSRR_BR_10                      ((uint32_t)0x04000000)5 v8 @/ E& A" b' n- ?6 H
  317. #define GPIO_BSRR_BR_11                      ((uint32_t)0x08000000)
      i5 t# L8 G3 F1 P
  318. #define GPIO_BSRR_BR_12                      ((uint32_t)0x10000000)* V$ K9 Q  p9 K" j& c, n9 j
  319. #define GPIO_BSRR_BR_13                      ((uint32_t)0x20000000): T- z% s% T! F7 W. ~" Y
  320. #define GPIO_BSRR_BR_14                      ((uint32_t)0x40000000)2 }! I2 `( K7 {; Y: h  K
  321. #define GPIO_BSRR_BR_15                      ((uint32_t)0x80000000)
6 E1 Y3 q) V# S9 AGPIO全部挂载AHB1总线上3 T& z: J: _2 L# y7 Z) L. W' F7 U
% Z: a! G5 D9 S7 ?6 G
  1. /********************  Bit definition for RCC_AHB1ENR register  ***************/2 G3 h) G8 [! ]$ F
  2. #define  RCC_AHB1ENR_GPIOAEN                 ((uint32_t)0x00000001)( _! B' H2 Z! x9 p
  3. #define  RCC_AHB1ENR_GPIOBEN                 ((uint32_t)0x00000002)# {3 {  J1 u( ~. `) O
  4. #define  RCC_AHB1ENR_GPIOCEN                 ((uint32_t)0x00000004)  e% C( H" @( Q: Q3 }
  5. #define  RCC_AHB1ENR_GPIODEN                 ((uint32_t)0x00000008)
    0 G; v+ k* _( r! P( s, A1 j
  6. #define  RCC_AHB1ENR_GPIOEEN                 ((uint32_t)0x00000010)
    ; u9 \: s7 L8 A. c5 k% }" S
  7. #define  RCC_AHB1ENR_GPIOFEN                 ((uint32_t)0x00000020)  K# L/ `, Z2 l1 o- }5 S* H8 F; y
  8. #define  RCC_AHB1ENR_GPIOGEN                 ((uint32_t)0x00000040)/ O8 D" b, t' w  f% P8 i
  9. #define  RCC_AHB1ENR_GPIOHEN                 ((uint32_t)0x00000080)
    & V5 d( Z8 ^3 w: N" S' R- E  G" Q
  10. #define  RCC_AHB1ENR_GPIOIEN                 ((uint32_t)0x00000100)
    + h1 q% D" L/ [$ Z4 L8 F
  11. #define  RCC_AHB1ENR_GPIOJEN                 ((uint32_t)0x00000200)  e8 F" E  C( C# x5 o
  12. #define  RCC_AHB1ENR_GPIOKEN                 ((uint32_t)0x00000400)
5 r! U" s( T1 t) x
; o2 G% `  Z; u3 b/ U% u8 E
6 Q) t+ ]9 x# W, l" M
赞 收藏 评论0 发布时间:2022-6-11 21:38
