STM32F1系列之在gcc环境下编写uart串口打印程序
STMCU小助手 发布时间:2022-8-27 13:40
一、构建程序目录
% w+ p. A5 P* A! n1 {- h3 O新建src文件夹,用来存放c源代码! W8 z6 B, \! W- f( X2 ?
新建inc文件夹,用来存放头文件
+ M$ h, v/ C" e  ^# b新建build文件夹,用来存放编译输出文件
: V' M; _8 i4 A( v% y
8 q1 ~1 O$ I3 g* X二、编写源文件& X6 e4 u( @( `2 b5 e) }* S! r
在src文件夹下新建uart.c文件如下所示
1 z2 \$ L$ V2 T2 u/ U" L" m+ z) Z8 w2 S0 W) |- D2 H& R6 @7 {
  1. #include "uart.h"/ M+ l& k. @5 K! k& }- u; n, e
  2. " N5 e- l: k; u, c$ F) s  c
  3. typedef unsigned int uint32_t;- j2 m/ q, q0 Q0 h% R# r+ M/ t
  4. typedef struct
    1 E* V1 y) x& M/ v
  5. {6 D8 y0 l! b+ R3 Q9 d
  6.   volatile uint32_t SR;    /*!< USART Status register, Address offset: 0x00 */
    & h" G% d  ]6 ~" ?) q$ ]& t
  7.   volatile uint32_t DR;    /*!< USART Data register,   Address offset: 0x04 */( z: U0 ?- l$ D/ y
  8.   volatile uint32_t BRR;   /*!< USART Baud rate register, Address offset: 0x08 */. {+ y$ F) s# E& J' M/ J" ]
  9.   volatile uint32_t CR1;   /*!< USART Control register 1, Address offset: 0x0C */' ~7 L$ c" ~* W7 }
  10.   volatile uint32_t CR2;   /*!< USART Control register 2, Address offset: 0x10 */$ t1 J4 i5 k2 {+ h9 ~
  11.   volatile uint32_t CR3;   /*!< USART Control register 3, Address offset: 0x14 */
    ! E/ x2 ]% ~1 A1 W
  12.   volatile uint32_t GTPR;  /*!< USART Guard time and prescaler register, Address offset: 0x18 */* S/ X- H  f% T% C# w, o
  13. } USART_TypeDef;( z3 B: \$ M  D& |
  14. ' u" V2 a( P' P& K& \
  15.   U% v, C* p1 C( B/ }
  16. void uart_init(void)  x- \, p; y" y
  17. {
    : E& P/ a* U+ \3 K
  18.         USART_TypeDef *usart1 = (USART_TypeDef *)0x40013800;
    ' N2 |+ x: F, c0 e( v2 Y. L6 s7 {  p
  19.         volatile unsigned int *pReg;9 X1 F/ [& y6 a# y
  20.         /* 使能GPIOA/USART1模块 */
    7 o5 ^  C) f. n2 R8 e3 W: M
  21.         /* RCC_APB2ENR */
    " R2 d6 R  @* O3 J5 I- E/ m  c% w
  22.         pReg = (volatile unsigned int *)(0x40021000 + 0x18);. I' c7 M: L# s4 X" _
  23.         *pReg |= (1<<2) | (1<<14);+ U; l) K( S3 T/ m# B9 c9 O
  24.
    ! N6 I4 f6 A3 M2 l: ~( O
  25.         /* 配置引脚功能: PA9(USART1_TX), PA10(USART1_RX)
    ) w/ M$ b3 _" y4 C
  26.          * GPIOA_CRH = 0x40010800 + 0x04
    + z+ I/ s5 f9 I% X" P% K
  27.          */' y6 M7 G' z% u2 L/ ^) }
  28.         pReg = (volatile unsigned int *)(0x40010800 + 0x04);) X1 {) `' T* ~
  29.
    " R6 q. B/ ?, ~% _
  30.         /* PA9(USART1_TX) */7 R, U% `0 d5 {8 x( [
  31.         *pReg &= ~((3<<4) | (3<<6));
    4 o. M. R9 Y5 x6 i- t2 V1 V0 P
  32.         *pReg |= (1<<4) | (2<<6);  /* Output mode, max speed 10 MHz; Alternate function output Push-pull */
      F/ }% ~8 w$ @6 h
  33. , S$ c0 g) @( T
  34.         /* PA10(USART1_RX) */: V3 x# K& x, g8 U) H
  35.         *pReg &= ~((3<<8) | (3<<10));) `- s% s1 W, B+ X, b
  36.         *pReg |= (0<<8) | (1<<10);  /* Input mode (reset state); Floating input (reset state) */& S' H" F: E0 A/ F" [% C8 \1 B" c
  37.
    # _7 G/ q# C* r) f/ g) [7 j
  38.         /* 设置波特率
    / ?4 x0 V( a0 S6 T  A6 }
  39.          * 115200 = 8000000/16/USARTDIV
    4 K8 @) L' V" [. H
  40.          * USARTDIV = 4.34
    . W+ {' o: _3 _7 }: W- E
  41.          * DIV_Mantissa = 4
    6 C7 q/ A: a1 ^& u1 Y9 h3 ^
  42.          * DIV_Fraction / 16 = 0.34: Z+ v2 q2 {: p; i" ?/ e; k: V
  43.          * DIV_Fraction = 16*0.34 = 58 }2 S8 r& t+ M! ]9 r4 A3 I
  44.          * 真实波特率:
    ) ?  y7 E$ Q1 g7 U; Z5 x
  45.          * DIV_Fraction / 16 = 5/16=0.31252 ]: l/ l, _5 D. D5 i/ n
  46.          * USARTDIV = DIV_Mantissa + DIV_Fraction / 16 = 4.3125
    ! d$ V2 Y, U: v' F
  47.          * baudrate = 8000000/16/4.3125 = 115942
    # R' n7 U1 h- ?+ j+ X* ^5 A
  48.           */9 M6 l+ Q- R( \4 i. y  c5 ?. U
  49. #define DIV_Mantissa 4' \: O. s- t+ i* v# B
  50. #define DIV_Fraction 5! d4 E. H: O0 X# `
  51.         usart1->BRR = (DIV_Mantissa<<4) | (DIV_Fraction);; j2 \' y+ f* |% I. Z
  52.         $ j) x( r; l# p
  53.         /* 设置数据格式: 8n1 */
    ; y" ^4 B$ X$ M7 m; h
  54.         usart1->CR1 = (1<<13) | (0<<12) | (0<<10) | (1<<3) | (1<<2);        $ J% F+ K7 s- [4 h& ~5 N5 E  n
  55.         usart1->CR2 &= ~(3<<12);$ \* ]" W' N# ~5 h
  56.         + G. \5 \# v4 u1 L
  57.         /* 使能USART1 */
    1 p4 c9 |2 b" q, p' e
  58. }# P* H: y6 V& X9 Z- u. L
  59.
    * y6 g3 I( y2 m: ~0 i& X; e3 V; a
  60. int getchar(void)
    4 M- K! [; `& t6 b# q  y4 ?% B
  61. {
    - t/ m+ `8 x' v, B: b" i% {6 E/ s
  62.         USART_TypeDef *usart1 = (USART_TypeDef *)0x40013800;+ s) [' M' x  s1 C  z( q' D+ Y( E
  63.         while ((usart1->SR & (1<<5)) == 0);
    8 _2 F3 W& @0 E" {
  64.         return usart1->DR;' q0 A& v& k- ^* {. e( z  y6 }
  65. }
    ( J% u  x& p' ~
  66. 1 R* a6 i# W& P; \; y8 m, ]) A! F
  67. int putchar(char c)# g  [2 A0 }$ d7 T9 [3 a  d( C) [
  68. {
    ) O  G- M- P. A! p% I- I
  69.         USART_TypeDef *usart1 = (USART_TypeDef *)0x40013800;9 H' e( \: [# Y  D! q* x4 q# P
  70.         while ((usart1->SR & (1<<7)) == 0);
    * \7 d( t, S9 S; I( n8 ~
  71.         usart1->DR = c;
    + `2 U: V8 ^! v
  72.         ' c! N- ~- b0 C8 ]. N* y
  73.         return c;
    * `+ Y( G8 B6 \3 B; S5 h
  74. }
7 M0 }6 [9 O/ h% q: }( d; W- C" t% L5 a在inc文件夹下新建uart.h内容如下
, R0 x5 _& w( N9 @; j
+ i& ~4 @- @4 M" K, s
  1. #ifndef _UART_H9 L( k  w5 g' K
  2. #define _UART_H
    * i- ~  O* _6 L4 p8 G0 @6 Z
  3. 5 |7 @% Z" D1 z5 Q" {% f0 q
  4. void uart_init(void);! O! w  C/ @, ^+ ]3 j
  5. int getchar(void);! A. p5 m- `. v) f6 o2 a( |( R
  6. int        putchar(char c);
    ! D9 ~: {( y" k% |# \5 ~
  7. , q4 @% x- Y' G$ }% F* F$ |" s
  8. #endif
; ]7 m8 p2 H* e8 f# K- m( O
在src文件夹下新建led.c文件如下所示6 S1 w0 Z4 J! t$ v9 S  n' p5 z8 w- l
: H; G9 F9 j4 S$ u  u1 i! n: g" A
  1. 在这里插入代码片#include "led.h"3 S. w; z" J: a% U5 U) u9 w) e; X7 _
  2. 9 D* P; E5 o* E5 F
  3. int delay(int ndelay)* k) ?: j; J+ \4 U! P
  4. {% h* @- O. O  T4 V- d4 y1 q) e
  5.         volatile int n = ndelay;  t+ Y" j3 x$ @  W/ l" U
  6.         while(n--);
    ! Y& O" G& e( n; W" S1 t: {8 M  j
  7. ! ~: |, w- R7 H& u& v
  8.         return 0;8 u# ~7 z# }7 q3 m# Z$ F
  9. }( m+ D, G- W5 U; Q; C. V0 H6 h
  10. 7 K) c, Z5 X8 B" f  N6 X% G
  11. void led_init(void): R9 A: f& ~* |  M! |0 m6 @8 g
  12. {
    ( p: Y! R$ {3 C5 o
  13.         unsigned int *pReg;
    8 ]8 ]0 G7 E, W; O8 V; ~
  14.
    + g9 W" p- [8 r' z2 x& j
  15.         /* 1、使能GPIOB */
    . m4 w! F" G+ h$ W4 G8 q! h
  16.         pReg = (unsigned int *)(0x40021000 + 0x18);
    ; h$ n; o" }' Z) X8 {' v1 [
  17.         *pReg |= (1<<3);
    / e- }4 r  {& X4 q2 ^
  18.
    # G8 c# Q; k$ h+ X3 v
  19.         /* 2、设置GPIOB5为输出引脚 */; H6 r/ e6 p( B$ u4 H! H
  20.         pReg = (unsigned int *)(0x40010C00 + 0x00);! j, E" H' ~0 `( S' e+ a
  21.         *pReg |= (1<<20);
    5 a6 X) }7 M8 q: t2 ], c+ q6 L8 c; u
  22. 9 W& l/ R9 n; l: L8 {6 O: Z) d
  23.         pReg = (unsigned int *)(0x40010C00 + 0x0C);
    3 z3 G# ^3 u3 b, B. w
  24.     *pReg &= ~(1<<5);
    : J6 z  f2 {- [# F
  25. }( J, U; p0 C% p/ q
  26. & }5 r" d* c3 d
  27. void led_on(void)8 h2 M+ l+ N! S/ ]
  28. {
    % \' ?" ^$ Q6 }3 X# n
  29.         unsigned int *pReg = (unsigned int *)(0x40010C00 + 0x0C);
    / b1 V. i5 Q  |" M
  30.                         1 u1 v' e' b* z7 J: t0 d2 [
  31.         /* 设置GPIOB5输出0 */$ N/ ]0 a' k+ L$ ~5 U2 I
  32.         *pReg &= ~(1<<5);3 Z8 o' _, Z3 |$ r- H$ a( G' x! X
  33. }
    $ \" _& L2 _  z+ K* m9 q& ~
  34. # Z6 _2 `7 g& k" t9 D
  35. void led_off(void)0 E* z/ [) q% P2 v
  36. {- L1 m8 p9 j/ e8 y
  37.         unsigned int *pReg = (unsigned int *)(0x40010C00 + 0x0C);
    8 y/ K3 N# }( M9 x% c; E
  38.
    ; |; ]1 W+ H! N4 O2 X6 p+ W( a+ }/ |3 i
  39.         /* 设置GPIOB5输出1 */
    . v: s: p. I8 {) s" t/ u1 n5 _; g
  40.         *pReg |= (1<<5);6 S% s$ g9 h! c
  41. }
3 W; u. ?3 K. \2 T在inc文件夹下新建led.h内容如下
3 I! \! O4 F: M
. I; L! x1 ?! h
  1. #ifndef __LED_H% u. z# w  {& h2 g$ v  @. V7 q
  2. #define __LED_H% |+ K- K3 @6 V- T' e# n) o
  3. ' s3 V& q' k) O- Y$ K8 B; Y" E
  4. int delay(int ndelay);
    4 j. Y! r' F: K, ]% Y
  5. void led_init(void);0 F3 c% r- F& k  P; y; }
  6. void led_on(void);: v8 x8 |8 Z% `4 p' {& I* P4 x; ^- Z
  7. void led_off(void);
    $ y2 f; L" E0 ?# {' k* a
  8. % y, U/ ~" V$ G+ w* @
  9. #endif
& M4 P' E- v- @, k0 ~三、修改主函数: n& Z0 Y+ G7 ^% B/ |2 o
将了原来的led.c修改为main.c如下所示" s4 \5 M4 U0 @7 H  I& V
" P. [' A2 f2 Z* `3 n1 j6 M/ Z
  1. #include "uart.h"6 g; k  A: @5 J) l' e* M
  2. #include "led.h"
    % o/ T/ [7 V; y" S: m+ q  W2 t. Q
  3. + p  A1 e# g* l/ t2 ]4 n
  4. int main(void); P% ]) S# \( p! }5 C+ G
  5. {) p& O2 e2 y% ~% j! }
  6.     uart_init();2 I( _6 g1 I9 x" ?
  7.     led_init();
    2 n6 A7 `/ K& d  w3 I
  8.     putchar('s');
    4 w+ Z) ?5 ^. f- T
  9.     putchar('t');
    $ |0 C$ k3 a! w
  10.     putchar('m');- P# [: F2 |3 g0 v# @# ~
  11.     putchar('3');1 [2 F; |$ d" _' U$ C$ y
  12.     putchar('2');; L2 m$ M* _7 a' o
  13.     putchar('f');" b' q2 F) I- q3 `
  14.     putchar('1');
    2 c7 c" S4 G( c7 g' F
  15.         putchar('0');
    , C6 R& W8 e( B' K
  16.         putchar('3');) V( m* p/ o# Q
  17.     putchar('\r');
    ) d2 S  R0 A4 T$ O" p9 n
  18.     putchar('\n');
    - y. G( `0 K7 R/ X4 c
  19. * J5 q. p; u: k% f* W
  20.     while(1)- D9 z$ Q2 W5 d" n7 `% P: g5 Y7 r) ^
  21.     {
    ) `. d- D0 g$ J+ h3 T5 e
  22.         led_on();  i. i! z. i3 v5 e. _7 M7 {0 }
  23.         delay(1000000);4 O8 r6 z. a9 K5 {
  24.         led_off();
    ' T/ P3 b. o) B4 ~" S8 N. w
  25.         delay(1000000);. f1 C  s2 b* k5 N+ Z' V& |
  26.     }
    2 `5 R: B+ j0 T- t6 J
  27. }
    2 I1 G; Q/ \) d2 u; k% E
( U7 G! |% I+ N四、编写汇编程序* W( a6 z0 Y( T
汇编程序也做相应修改- U: D# u4 Y! i2 p% z) U. b
$ f+ \( E  o0 S; V
  1. : X2 t8 w- T, r# z" M
  2.   .syntax unified                   /* 指明当前汇编文件的指令是ARM和THUMB通用格式 */  ~) Y# q4 K- X6 h- ]- S, z
  3.   .cpu cortex-m3                    /* 指明cpu核为cortex-m3 */, d3 q9 F. ]+ a/ `8 h
  4.   .fpu softvfp                      /* 软浮点 */
    4 d& ]) R0 c$ v4 u/ U2 G* j
  5.   .thumb                            /* thumb指令 */
      J' X) I1 V# T
  6. 7 D; Z: r$ a* K5 u& ^, y
  7. .global  _start                     /* .global表示Reset_Handler是一个全局符号 */
    5 {& {5 X& P0 N1 o) `  _
  8. : R1 \  D* R3 P" E
  9. .word 0x00000000                    /* 当前地址写入一个字(32bit)数据,值为0x00000000,实际上应为栈顶地址 */9 b1 j8 H0 ~2 N3 H
  10. .word _start+1                      /* 当前地址写入一个字(32bit)数据, 值为_reset标号代表的地址+1,即程序入口地址*/
    3 @, R* X8 }+ }5 f
  11. 6 V2 N! ?1 ~- e; R6 q
  12. _start:                             /* 标签_start,汇编程序的默认入口是_start */
    ( S: w3 T2 T7 _5 }  M+ q2 r& \
  13.     /* 1、设置栈 */
    + z  ]2 g% Z( z% w2 o* `
  14.     LDR SP, =(0x20000000+0x400)6 U" Z0 Y; f7 k2 b' p# ?! z
  15.     /* 2、跳转到led函数 */; a0 O" p1 t5 s$ F. A0 F
  16.     BL led0 ~! \2 h9 |6 b$ f
  17.     /* 3、原地循环 */& J% r  }! D) B$ i( `/ ?
  18.     B .
( L: ^0 R1 r2 W6 h# E1 l2 v五、编写Makefile
# ^" Q7 c. r) w7 y1 N编写Makefile如下所示,注意OBJECTS为我们所要链接的所有文件,链接时默认是按照其排列顺序来连接的,所以我们要将start.o文件放在最前面,如下所示;另外vpath用来指定该依赖文件的查找路径,还有关于-fno-builtin参数,表示不使用C语言的内建函数,因为我们编写的putchar()函数是C语言的内建函数,使用了-fno-builtin参数我们的函数名就可以和内建函数同名了。& y4 C2 W( P9 t$ L6 q# {4 |, a% ]
; q8 S( v2 u! n( O
  1. TARGET = uart
    / L2 U5 C  s/ ]7 w. Q! q" |9 I
  2. 4 Y, u. n- l" z( d' ?" \/ g
  3. C_SOURCES =  src/main.c \
    # i& G4 W$ O' n. _  t5 F
  4. src/uart.c \
    7 Q$ [0 W8 R# ?
  5. src/led.c
    + X3 t/ S4 z  N
  6. ' V- N' i7 q  G. F9 l
  7. C_INCLUDES = -Iinc& `& t. g1 u3 ^8 x- h
  8. 9 h* I& |. H, w
  9. ASM_SOURCES = start.s. M) H; {! @! Y; `( B+ z
  10. ' S! E9 m' H9 n7 {- I' O+ Q2 l! z
  11. CPU = -mcpu=cortex-m3$ Z: v0 u1 e6 Z* a5 D
  12. MCU = $(CPU) -mthumb
    5 L6 P0 Y- }. r* _' B1 u- b
  13. " j9 R* j3 |& _$ k" A0 E4 W
  14. CFLAGS = -c -g $(MCU) -Wall $(C_INCLUDES) -fno-builtin
    / \- J5 k/ q  Z2 @7 ~& z
  15. % D7 v5 N% `, s* S- S9 p* y3 b0 I% h
  16. PREFIX = arm-none-eabi-7 f3 |% b9 o5 i1 c/ S: c$ s2 O* u- k
  17. CC = $(PREFIX)gcc
    4 A) Z/ [# W5 v) Y8 a, x' Z( @
  18. AS = $(PREFIX)gcc -x assembler-with-cpp
    * i/ p' ?( j9 P4 c  p: H  y5 X% e
  19. LD=$(PREFIX)ld: N7 y" m' F7 H& o
  20. CP = $(PREFIX)objcopy$ R% e) m" Q) G
  21. SZ = $(PREFIX)size4 c( _$ X! U: f! s9 ?( ?
  22. OBJDUMP=$(PREFIX)objdump
    : X  L7 g" a- h5 `
  23. HEX = $(CP) -O ihex! \, @$ f( z, m* F$ X1 X
  24. BIN = $(CP) -O binary -S
    . v8 t6 D. p9 b) |$ }
  25. " N+ l  {- `, u8 a- W5 z  E5 s
  26. BUILD_DIR = build
    $ ]/ \! M, _' g% y2 ?$ |2 \2 d9 t4 j
  27. 9 h: g6 m1 X/ G0 s+ L, E( {
  28. OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
    ! S# c2 o% `6 J9 l2 X8 H
  29. vpath %.s $(sort $(dir $(ASM_SOURCES))). H" n9 b1 j: F1 ~
  30. OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
    4 V2 Y, V- H0 z$ A2 D* ^# V* v
  31. vpath %.c $(sort $(dir $(C_SOURCES))), {1 v6 q- G" T, p* m% H; \
  32. # {: ?# e% `4 E" ?8 Q
  33. 7 }9 V& \! O/ T. A8 a0 q/ n. p
  34. all : $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
    8 r1 l3 G3 }$ r* G! Y
  35.         $(SZ) [        DISCUZ_CODE_6        ]lt;3 Q& c7 B& o1 [! ^6 B% s. h2 N8 y
  36. . f& g8 u3 o* G! k3 y( r. Q8 ~3 b
  37. $(BUILD_DIR)/%.o: %.c | $(BUILD_DIR)9 |5 U+ L. e% s  S" ^6 ~2 M" ^
  38.         $(CC) $(CFLAGS)  [        DISCUZ_CODE_6        ]lt; -o $@ -MMD -MP -MF"$(@:%.o=%.d)"
    ) r& \8 s2 q1 d2 M, _0 K% m
  39. & m2 J" ~9 S1 P# W/ P7 g9 z' n
  40. $(BUILD_DIR)/%.o: %.s | $(BUILD_DIR)
    0 B5 r! E+ f5 p: y" R
  41.         $(AS) $(CFLAGS)  [        DISCUZ_CODE_6        ]lt; -o $@
    ) c. l5 }. U. z8 a  u
  42. 5 V* R) O  `8 E* e0 K+ j2 n+ {
  43. $(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) | $(BUILD_DIR)
    . e* r( s; r" J
  44.         $(LD) -g $(OBJECTS) -Ttext 0X8000000 -o $@
    % t7 K5 g, ], [$ f. a
  45. ( L( c5 O: h# W7 u+ j# T  d( M' v
  46. $(BUILD_DIR)/%.hex: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
    6 j& X# r0 ~+ k* S3 A6 e
  47.         $(HEX) [        DISCUZ_CODE_6        ]lt; $@
    . g0 C6 P; o( H- }# ^
  48.
    - {, G9 Q; O  d
  49. $(BUILD_DIR)/%.bin: $(BUILD_DIR)/%.elf | $(BUILD_DIR); ^2 j! h; h6 _4 d
  50.         $(BIN) [        DISCUZ_CODE_6        ]lt; $@
    # P3 x1 J" t% h7 }7 \
  51. * Q7 l0 A5 \! u; J9 N) i) p
  52. $(BUILD_DIR)/.dis: %.elf7 f$ N- g9 z5 w9 C  S9 Q2 O
  53.         $(OBJDUMP) -D -m cortex-m3 [        DISCUZ_CODE_6        ]lt; > $@1 @$ `) b4 b3 m9 t4 y( ]
  54. 9 Y3 M! U5 ], |, ?: }9 Q- V
  55. $(BUILD_DIR):) _6 g' Q. P# {) d  b2 J# Q/ n' c
  56.         mkdir $@; w7 Z  [( E- Z* g3 h/ K6 }. N6 f
  57. " A7 D3 C  p& U
  58. -include $(wildcard $(BUILD_DIR)/*.d)
    4 z# k) Z8 U4 j. ?( T+ D
  59. ; C5 g$ w. Z& \* e5 x% q1 \! X
  60. clean:5 }9 m. s/ x+ L1 B
  61.         rm -rf $(BUILD_DIR)
$ {- e, @5 w3 `: f1 X: }0 l2 p
然后make命令执行编译
" `# c1 P; n3 i$ }: V 20210124163201400.png
0 S8 U  _1 J( j: L3 ]! ^1 h" e$ `; I1 t8 M( h5 @6 I
然后烧录运行可以看到其打印的信息' H- E/ v+ c. s8 c5 M, M2 J
" E8 x% B' s1 i0 E' v& G3 H! D
1 w+ O$ ?9 G5 Y0 I1 K; ^
* ^! X8 b- S$ ~+ g' e0 M六、优化" {& `9 R  E' }5 _# k( j
接下来我们在uart.c中添加如下两个函数用来打印字符串和16进制数
$ N' D3 w. j! Z/ w$ T+ }. j  k3 o; s: N
  1. int putstring(const char *s)
    9 q7 g- `1 `" N
  2. {3 X* s5 E% x3 _- A
  3.         while (*s): w7 Z  a, h+ n3 Z
  4.         {5 @' b$ s8 B/ q  P- K) M) @, ~/ F
  5.                 putchar(*s);
    $ I; ]! B- X: P+ Y/ L
  6.                 s++;: v) [) K7 w$ w; D. n1 G' P0 V
  7.         }
    % V6 ^2 x% W+ j( |7 b. D
  8.         return 0;
    6 \% G4 y) n) X" b: K# M4 L" Q
  9. }# _5 n- y" z8 W
  10. ! T" U8 d: K: G. e- ^+ {/ i
  11. void puthex(unsigned int val)
    6 q* v) p5 f& s  N! n
  12. {$ a7 d* ]  R% B: `
  13.         /* 0x76543210 */# z" n; p2 ~9 y
  14.         int i, j;2 x' F: l* y8 F. B! |$ G
  15. 6 x- F# B7 {; L* [5 H* ?
  16.         //puts("0x");4 p$ f( N. Y. g6 Q2 H# p) u
  17.         putchar('0');! k8 F4 X% n6 R2 E
  18.         putchar('x');
    ' t3 m" c* A- v0 g$ @! J
  19.         for (i = 7; i >= 0; i--)4 R3 C1 m, e7 R  Y
  20.         {
    . b; |6 x/ M! i, u0 A6 y
  21.                 j = (val >> (i*4)) & 0xf;
    # G# Z( v+ x0 r6 K
  22.                 if ((j >= 0) && (j <= 9)): @) N3 Z3 L" A9 F
  23.                         putchar('0' + j);
    3 n  j( ?6 K8 x0 r8 l$ \
  24.                 else
    # ~) _7 O4 G1 m# |5 `" \
  25.                         putchar('A' + j - 0xA);
    5 i  ]  A% E# f, a
  26.         }        ' r* H2 ^: u# ?  e4 w* A0 a
  27. }
. l7 ^5 y4 \+ }$ L( Y. F修改main函数如下所示" k& }7 e( n. p* r
- z1 I% }5 D+ v
' e5 F; k* A: o# [" b编译烧录运行可以看到其串口打印如下& t+ G6 s5 B5 [. O; q# ^/ W0 t2 }
2 R% K4 D9 z  N
( r" p& c- K9 i2 H! X1 j& J  s' J: ]' o; s0 j) u4 L3 C
赞 收藏 评论0 发布时间:2022-8-27 13:40
