//串口的初始化 void MX_USART1_UART_Init(void) { /* USER CODE BEGIN USART1_Init 0 */ /* USER CODE END USART1_Init 0 */ LL_USART_InitTypeDef USART_InitStruct = {0}; LL_GPIO_InitTypeDef GPIO_InitStruct = {0}; LL_RCC_SetUSARTClockSource(LL_RCC_USART16_CLKSOURCE_PCLK2); /* Peripheral clock enable */ LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_DMA1); LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_USART1); LL_AHB4_GRP1_EnableClock(LL_AHB4_GRP1_PERIPH_GPIOA); /**USART1 GPIO Configuration PA9 ------> USART1_TX PA10 ------> USART1_RX */ GPIO_InitStruct.Pin = LL_GPIO_PIN_9|LL_GPIO_PIN_10; GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE; GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL; GPIO_InitStruct.Pull = LL_GPIO_PULL_NO; GPIO_InitStruct.Alternate = LL_GPIO_AF_7; LL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* USART1 DMA Init */ /* USART1_RX Init */ LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_0); LL_DMA_SetPeriphAddress(DMA1, LL_DMA_STREAM_0, LL_USART_DMA_GetRegAddr(USART1, LL_USART_DMA_REG_DATA_RECEIVE)); LL_DMA_SetMemoryAddress(DMA1, LL_DMA_STREAM_0, buffer); LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_0, 256); LL_DMA_SetPeriphRequest(DMA1, LL_DMA_STREAM_0, LL_DMAMUX1_REQ_USART1_RX); LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_STREAM_0, LL_DMA_DIRECTION_PERIPH_TO_MEMORY); LL_DMA_SetStreamPriorityLevel(DMA1, LL_DMA_STREAM_0, LL_DMA_PRIORITY_LOW); LL_DMA_SetMode(DMA1, LL_DMA_STREAM_0, LL_DMA_MODE_NORMAL); LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_STREAM_0, LL_DMA_PERIPH_NOINCREMENT); LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_STREAM_0, LL_DMA_MEMORY_INCREMENT); LL_DMA_SetPeriphSize(DMA1, LL_DMA_STREAM_0, LL_DMA_PDATAALIGN_BYTE); LL_DMA_SetMemorySize(DMA1, LL_DMA_STREAM_0, LL_DMA_MDATAALIGN_BYTE); LL_DMA_DisableFifoMode(DMA1, LL_DMA_STREAM_0); LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_0); /* USART1 interrupt Init */ NVIC_SetPriority(USART1_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0)); NVIC_EnableIRQ(USART1_IRQn); /* USER CODE BEGIN USART1_Init 1 */ /* USER CODE END USART1_Init 1 */ USART_InitStruct.PrescalerValue = LL_USART_PRESCALER_DIV1; USART_InitStruct.BaudRate = 115200; USART_InitStruct.DataWidth = LL_USART_DATAWIDTH_8B; USART_InitStruct.StopBits = LL_USART_STOPBITS_1; USART_InitStruct.Parity = LL_USART_PARITY_NONE; USART_InitStruct.TransferDirection = LL_USART_DIRECTION_TX_RX; USART_InitStruct.HardwareFlowControl = LL_USART_HWCONTROL_NONE; USART_InitStruct.OverSampling = LL_USART_OVERSAMPLING_16; LL_USART_Init(USART1, &USART_InitStruct); LL_USART_SetTXFIFOThreshold(USART1, LL_USART_FIFOTHRESHOLD_1_8); LL_USART_SetRXFIFOThreshold(USART1, LL_USART_FIFOTHRESHOLD_1_8); LL_USART_DisableFIFO(USART1); LL_USART_ConfigAsyncMode(USART1); /* USER CODE BEGIN WKUPType USART1 */ LL_USART_ClearFlag_IDLE(USART1); LL_USART_EnableIT_RXNE_RXFNE(USART1); LL_USART_EnableIT_IDLE(USART1); LL_USART_EnableDMAReq_RX(USART1); /* USER CODE END WKUPType USART1 */ LL_USART_Enable(USART1); /* Polling USART1 initialisation */ while((!(LL_USART_IsActiveFlag_TEACK(USART1))) || (!(LL_USART_IsActiveFlag_REACK(USART1)))) { } /* USER CODE BEGIN USART1_Init 2 */ /* USER CODE END USART1_Init 2 */ } tips:buffer运行在0x24000000后, 也没有开启cache,我之前在f103上有做过,按照芯片大概流程初始化后buffer一直为空。但是用HAL库的话可以正常接收数据,求大佬指导下! |
STM32H747XIH6 CM7正常运行 CM4不能正运行
【经验分享】STM32H7 DMA+UART不定长接收实战:解决缓存溢出与数据错位问题
STM32H725的LSE不起振
STM32H747XI CM7正常运行 CM4不运行
stm32h7s78-dk烧录
STM32Programmer能识别芯片,Keil无法识别
STM32H7进入BOOTLoader模式
stm32H743使用CubeMxAi导入模型文件,需要将测试数据进行识别,不知道如何传入参数
STM32H725VGT3内存不足问题
STM32H7A3 怎样配置MDMA的硬件触发MDMA_REQUEST_DMA1_Stream0_TC将数据再次转运
你先用CubeMx配置完成后,生成基于LL库的初始化代码。然后像下面一样组织用户代码,实现UART的
DMA收发是没有问题的,注意代码顺序。我使用H7芯片做了测试,可以正常运行。
/* Enable DMA RX Interrupt */ LL_USART_EnableDMAReq_RX(USART1);
/* Enable DMA TX Interrupt */
LL_USART_EnableDMAReq_TX(USART1);
LL_DMA_ConfigAddresses(DMA1, LL_DMA_STREAM_0,
LL_USART_DMA_GetRegAddr(USART1, LL_USART_DMA_REG_DATA_RECEIVE),
(uint32_t)RxBuffer, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_0, Length_RX);
LL_DMA_ConfigAddresses(DMA1, LL_DMA_STREAM_1,
(uint32_t)TxBuffer,
LL_USART_DMA_GetRegAddr(USART1, LL_USART_DMA_REG_DATA_TRANSMIT),
LL_DMA_DIRECTION_MEMORY_TO_PERIPH);
LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_1, Length_TX);
/* Enable DMA Channel Rx */
/* Enable DMA Channel Tx */
LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_1);
至于,空闲中断是另外回事。开启了空闲中断,UART接收发生空闲时自然会进入中断。
