stm32l151c8t6 spi2从机无法进入接收中断
有腹肌的wyj 提问时间:2023-2-20 22:01 / 未解决
工程师们好,最近我在调试l151的spi2时,发现其无法工作
spi2的初始化代码如下:
  1. void SPI2_GPIO_INIT(void)
  2. {
  3.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  4.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  5.
  6.         GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12|GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  7.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
  8.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  9.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  10.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  11.
  12.         NVIC_InitStructure.NVIC_IRQChannel=SPI2_IRQn;
  13.         NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
  14.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;
  15.         NVIC_InitStructure.NVIC_IRQChannelSubPriority=2;
  16.     NVIC_Init(&NVIC_InitStructure);
  17.
  18.
  19.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//
  20.         SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;//设置为SPI的从机模式
  21.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;//SPI数据大小:发送8位帧数据结构
  22.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;//空闲状态时SCK的状态为低电平
  23.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;//时钟相位,1表示在SCK的奇数沿边采样,2表示偶数沿边采样
  24.         SPI_InitStructure.SPI_NSS = SPI_NSS_Hard; //NSS由硬件片选
  25.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;//时钟的预分频值(0~256) 不影响传输速率
  26.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //MSB高位在前
  27.         SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC较验和的多项式
  28.
  29.         SPI_Init(SPI2,&SPI_InitStructure); //初始化SPI2的配置项
  30.         SPI_I2S_ITConfig(SPI2,SPI_I2S_IT_RXNE,ENABLE);//开启中断
  31.         SPI_Cmd(SPI2,ENABLE); //使能SPI2
  32. }
读/写函数如下:
  1. uint8_t SPI2_ReadByte(uint8_t TxData)
  2. {
  3.          uint8_t count;
  4.
  5.          while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位
  6.         {
  7.                 count++;
  8.                 if(count>200)
  9.                 return 0;        //如果200个计数还没完成发送,就返回0跳出这个函数
  10.         }
  11.
  12.         return SPI_I2S_ReceiveData(SPI2); //返回接收的数据
  13.
  14. }
  15. void SPI2_WriteByte(uint8_t TxData)
  16. {
  17.         uint8_t count;
  18.
  19.         while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
  20.         {
  21.                 count++;
  22.                 if(count>200)
  23.                 return;
  24.   }
  25.
  26.          SPI_I2S_SendData(SPI2, TxData);
  27.
  28.
  29. }
中断函数如下:
  1. void SPI2_IRQHandler(void)
  2. {
  3.    if(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_RXNE)==SET)
  4.            {
  5.                    test=SPI2_ReadByte(0x00);
  6. //                   test = SPI2_ReadWriteByte(0xaa);
  7.            }
  8. }
在debug模式中发现程序一直未能进入中断。利用示波器测试主机输出波形正常,主机也可以利用相同的spi接口成功与其他设备通讯。
烦请工程师们帮我看看那有问题,谢谢!
收藏 评论2 发布时间:2023-2-20 22:01
butterflyspring 回答时间:2023-2-21 10:14:20
硬件方面可以检查一下引脚连接,确认是否是对应的SPI2引脚。 软件方面官方库中有例程,可以对比一下。
xmshao 回答时间:2023-2-21 10:26:13
我刚才查看了STM32L151C8T6,它的确有SPI2。你既然能正常接收了,按理如果使能了接收事件中断应该可以进入中断的。
请你借助调试工具确认下相关SPI中断的使能情况,中断服务程序跟启动文件里定义的相匹配。
我看你的代码好像是基于早期标准库组织的,代码方面也可以参考相关例程。
还有,测试时将IDE的外设寄存器观察窗口先关闭掉.
尽可能使用CubeMx做配置并组织代码,这样效率更高。
这些问题一般都不难,往往需要我们的信心和耐心。
关于意法半导体
招聘信息
