STM32H7的FDCAN
Xa__ 提问时间:2026-3-5 09:07 / 未解决
采用STM32H7的FDCAN上的FIFO0中断接收数据,使用KEIL单步运行能出来结果,但是整个运行的话就会跳转到HardFault_Handler()
void MX_FDCAN1_Init(void)
  /* USER CODE BEGIN FDCAN1_Init 0 */
  /* USER CODE END FDCAN1_Init 0 */
  /* USER CODE BEGIN FDCAN1_Init 1 */
  /* USER CODE END FDCAN1_Init 1 */
  hfdcan1.Instance = FDCAN1;
  hfdcan1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
  hfdcan1.Init.Mode = FDCAN_MODE_NORMAL;
  hfdcan1.Init.AutoRetransmission = DISABLE;
  hfdcan1.Init.TransmitPause = DISABLE;
  hfdcan1.Init.ProtocolException = DISABLE;
  hfdcan1.Init.NominalPrescaler = 3;
  hfdcan1.Init.NominalSyncJumpWidth = 8;
  hfdcan1.Init.NominalTimeSeg1 = 21;
  hfdcan1.Init.NominalTimeSeg2 = 8;
  hfdcan1.Init.DataPrescaler = 2;
  hfdcan1.Init.DataSyncJumpWidth = 8;
  hfdcan1.Init.DataTimeSeg1 = 32;
  hfdcan1.Init.DataTimeSeg2 = 12;
  hfdcan1.Init.MessageRAMOffset = 0;
  hfdcan1.Init.StdFiltersNbr = 1;
  hfdcan1.Init.ExtFiltersNbr = 0;
  hfdcan1.Init.RxFifo0ElmtsNbr = 8;
  hfdcan1.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
  hfdcan1.Init.RxFifo1ElmtsNbr = 0;
  hfdcan1.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
  hfdcan1.Init.RxBuffersNbr = 0;
  hfdcan1.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
  hfdcan1.Init.TxEventsNbr = 0;
  hfdcan1.Init.TxBuffersNbr = 0;
  hfdcan1.Init.TxFifoQueueElmtsNbr = 3;
  hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
  hfdcan1.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
  if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN FDCAN1_Init 2 */
    FDCAN_FilterTypeDef sFilterConfig;
    sFilterConfig.IdType = FDCAN_STANDARD_ID;
    sFilterConfig.FilterIndex = 0;
    sFilterConfig.FilterType = FDCAN_FILTER_MASK;
    sFilterConfig.FilterConfig = FDCAN_FILTER_TO_RXFIFO0;
    sFilterConfig.FilterID1 = 0X007;
    sFilterConfig.FilterID2 = 0X7FF;
    sFilterConfig.RxBufferIndex = 0;
    if(HAL_FDCAN_ConfigFilter(&hfdcan1,&sFilterConfig) != HAL_OK)
        Error_Handler();
    HAL_FDCAN_ConfigGlobalFilter(&hfdcan1,FDCAN_REJECT,FDCAN_REJECT,FDCAN_FILTER_REMOTE,FDCAN_FILTER_REMOTE);
    //HAL_FDCAN_ConfigFifoWatermark
    //Enable FIFO0 new  message interrupt
    HAL_FDCAN_Start(&hfdcan1);
    HAL_FDCAN_ActivateNotification(&hfdcan1, FDCAN_IT_RX_FIFO0_NEW_MESSAGE, 0);
  /* USER CODE END FDCAN1_Init 2 */
//void HAL_FDCAN_RxFifo0Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo0ITs)
//  if (hfdcan == &hfdcan1 &&(RxFifo0ITs & FDCAN_IT_RX_FIFO0_NEW_MESSAGE) != RESET) // 判断是hfdcan1的中断
//      while(HAL_FDCAN_GetRxFifoFillLevel(&hfdcan1, FDCAN_RX_FIFO0) > 0)
//          if(cache_idx < CAN_RECEIVE_DATA)
//              volatile uint8_t *frame_data = &RxData[cache_idx * 8];
//              if(HAL_FDCAN_GetRxMessage(&hfdcan1, FDCAN_RX_FIFO0, &RxHeader,(uint8_t *) frame_data) == HAL_OK)
//                  cache_idx++;
////        uint32_t tx_timeout = 1000;
////        while(HAL_FDCAN_GetTxFifoFreeLevel(&hfdcan1) == 0 && tx_timeout --);
//      can_receive_ok_flag = 1;
//  HAL_FDCAN_ActivateNotification(hfdcan,FDCAN_IT_RX_FIFO0_NEW_MESSAGE,0);
// FDCAN1 接收回调函数
    if (hfdcan->Instance == FDCAN1)
            if((RxFifo0ITs & FDCAN_IT_RX_FIFO0_NEW_MESSAGE)!= RESET)
        // 从接收 FIFO 中读取数据
        if(HAL_FDCAN_GetRxMessage(hfdcan, FDCAN_RX_FIFO0, &RxHeader, (uint8_t *)frame_data) == HAL_OK)
            cache_idx++;
                // 设置接收标志
        // 重启接收 FIFO
        HAL_FDCAN_ActivateNotification(hfdcan, FDCAN_IT_RX_FIFO0_NEW_MESSAGE, 0);
        //HAL_FDCAN_ActivateNotification(hfdcan,FDCAN_IT_RX_FIFO0_NEW_MESSAGE,0);
帮忙看一下哪里有问题
赞 收藏 评论2 发布时间:2026-3-5 09:07
Xa__ 最优答案 回答时间:2026-3-5 14:54:53
已解决
摩洛哥的制砖匠人 回答时间:2026-3-5 13:02:01
这种一般都属于底层配置的问题,用示例代码跑下
