基于STM32 PWM频率与占空比计算经验分享
攻城狮Melo 发布时间:2023-4-16 21:32
频率:      Fpwm = 72M / ((arr+1)*(psc+1))(单位:Hz)
  T8 E' j0 F( s3 }, Y. j0 D占空比:  duty circle = TIM3->CCR1 / arr(单位:%)
" F" y& {: Q0 P) B, I2 h8 w3 `8 z* V5 k7 S' W: w$ J
  1. void TIM3_PWM_Init(u32 arr,u16 psc)
    4 D6 {& K4 h! c/ s; L
  2. {  8 j$ U( M( A# C5 e8 Y
  3.         GPIO_InitTypeDef GPIO_InitStructure;
    & t* e) n% j/ J/ ?$ ?3 E" u0 X
  4.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;! ?, }- d6 p4 _# w/ ?  h9 c: H
  5.         TIM_OCInitTypeDef  TIM_OCInitStructure;$ B) L$ _9 I" Q* t/ S# C( I( ?! l
  6.
    - {9 y: P  T4 ^8 D1 z
  7. # ^1 b1 v. ~3 p: e, n) `$ h2 I
  8.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);        //使能定时器3时钟
    - d+ w8 n, B" ^% |( {5 L% a
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB  | RCC_APB2Periph_AFIO, ENABLE);  //使能GPIO外设和AFIO复用功能模块时钟3 Z0 T8 m* W3 a
  10.
    : O$ A+ K8 z) f' m1 Q9 O5 e1 M9 X
  11.         GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE); //Timer3部分重映射  TIM3_CH2->PB5
    5 i6 @( M% w) x8 f0 [# H) r
  12. 4 l2 A, F$ W, @$ D' `. B* U% X
  13.    //设置该引脚为复用输出功能,输出TIM3 CH2的PWM脉冲波形        GPIOB.5
    ! v. S' _- `2 |
  14.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //TIM_CH23 W' a% s3 O, K
  15.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //复用推挽输出: _* o2 H1 V. h( P
  16.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    0 u. i0 R* d; s: e8 c* A
  17.         GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIO
    $ `/ L6 G8 c5 |8 }8 N) Y
  18. ; `- A# @* H: c: l
  19.    //初始化TIM3
    2 c, C( u. \& ?8 o9 R+ e% |
  20.         TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
    * G$ I8 a$ M" R# T
  21.         TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值
    ( O. g- y7 u7 V: L) x- d4 U( \( {
  22.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
    ; h9 t) F4 M$ o1 H2 G
  23.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
    # ]/ B7 o. D0 l9 X, j/ o) t
  24.         TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
    9 a) R" G. o7 Q5 f) Z) p$ Q
  25.         & N. m& B; g1 M6 M1 Y( |( g) e  q
  26.         //初始化TIM3 Channel2 PWM模式
    * w5 S' k- x% p9 w
  27.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2! m4 |+ F- h  R
  28.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
    5 [0 N7 k+ Q$ _$ `
  29.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高& I' p1 O. M, I9 D
  30.         TIM_OC2Init(TIM3, &TIM_OCInitStructure);  //根据T指定的参数初始化外设TIM3 OC2, R3 M6 O/ w! O8 \7 g' i
  31. # [6 x2 ?6 w# e6 Y' \2 b
  32.         TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);  //使能TIM3在CCR2上的预装载寄存器5 U2 t: T! o7 K0 @' y* T
  33. ( W+ b' ]1 |+ N# j  M
  34.         TIM_Cmd(TIM3, ENABLE);  //使能TIM3- \7 L1 N2 a8 r2 w
  35.
    7 s, S, z; c. |) y
  36. }
. ?) f  e  g! w( `————————————————
- v6 D" k4 w! A7 A( j版权声明:Bourne76
  J5 R. {6 B2 O6 c4 I如有侵权请联系删除( g: W0 f4 B* l* a0 s+ L9 y, c7 x* w) Q$ o
. k+ \& h7 e$ ?6 G3 @4 m
/ x% V0 D& @) @- _5 L+ z! ?3 ~, Z
赞 收藏 评论0 发布时间:2023-4-16 21:32
