PWM的测试选择了 FreeRTOS_Mutex 例程,主要是因为 PWM 的输出需要更加严格的同步和控制。低功耗模式不适合该应用。PWM的输出设置需要理清程序的同步逻辑。程序首先定义了两个线程Thread1和Thread2,一个Mutex锁信号MutexHandle,通过这个信号进行 UART 资源的保护运行。
1 F6 N& d6 l4 {- j5 K4 m
% o& o ~5 Q V& q3 f
) u7 ~$ U% G. i- osThreadId_t Thread1Handle;
+ D7 P5 k% }& m% i8 j - const osThreadAttr_t Thread1_attributes = {( |5 N' x- f& }8 H
- .name = "Thread1",
) Q0 h+ L9 V5 w, f8 M; |4 s - .priority = (osPriority_t) osPriorityNormal,. G5 C$ C, {: P
- .stack_size = 256 * 4
, }, t; d" ^7 }* q# _+ l3 K - };
, Q$ W8 K+ }2 d% R9 v - /* Definitions for Thread2 */! G& Q. r( k" A1 {# I% G! C
- osThreadId_t Thread2Handle;
+ r0 P2 r+ g; P. W9 ]" ^7 e) r0 X6 y - const osThreadAttr_t Thread2_attributes = {
. _5 Y7 s1 `! I9 U0 ~% v1 I2 ~ - .name = "Thread2",
% s' v- ]& u, s% w - .priority = (osPriority_t) osPriorityNormal,
4 _% O/ _& Y A5 c; F9 [* ^3 e - .stack_size = 256 * 4
( A( C2 j1 @, G- | - };7 g* @& D2 E( U: l
- /* Definitions for Mutex */
5 d. ?. z+ U( m - osMutexId_t MutexHandle;
8 n4 W4 [1 a% T4 T j - const osMutexAttr_t Mutex_attributes = {. P! b2 T# G' J' P8 x
- .name = "Mutex"" E1 s/ I3 Y$ z# X
复制代码 首先两个线程在运行前半段使用信号锁进行共用资源 uart 的运行,后面进行运行。9 G0 W2 J+ v5 {- j
5 S. I. _6 u+ e. p$ R9 B- k% `" B5 E- O" Q* F. q
- , M u0 G/ \, }8 q( {
- /* USER CODE BEGIN Header_Thread1_Entry */( e2 T: d( s) N6 n, \
1 X N' M$ P/ R6 O8 J0 K - * @brief Function implementing the Thread1 thread.1 @# a M6 z3 k2 a5 A8 ]
- * @param argument: Not used7 g0 \; |/ b2 ] \
- * @retval None
; {2 o5 {) P5 g. T) g - */9 m6 J1 {1 l& R( z: F
- /* USER CODE END Header_Thread1_Entry */
# c6 K+ Y+ X: x6 t3 k, H - void Thread1_Entry(void *argument)
0 C/ d+ }& V2 j9 Q4 B! Q - {
; z: `. {8 z* O8 O - /* USER CODE BEGIN Thread1 */
: V2 r- T8 ~9 L W; K/ ~& R7 r - uint16_t i;1 d9 t1 _: S. M8 X; ]
- /* Infinite loop */
2 P8 Z6 S6 R9 Y3 N! V - for(i = 0; i < 10; ++i)* `) ?1 Z$ h; S% d
- {# D; ~' x2 W( e" e f$ Y- H3 D
- #if EXAMPLE_USES_MUTEX
/ R6 c! ?1 P" R& c& y! U* D - osMutexAcquire(MutexHandle, osWaitForever);( _6 `5 k( M) P1 B- H
- printf ("Thread1: Mutex Acquired!\n");, U* B6 B3 W1 ^! r( g! B
- #endif
& k: V* n' T' I. P8 x x9 r5 f - " @0 p/ a/ I& r5 g: j- W
- printf("Thread1 : This is message number %u\n", i+1);
) V: f, t# d4 [ O3 | -
) ]) C+ ^+ B; N+ x6 [ - #if EXAMPLE_USES_MUTEX
- a' V: _% ~' ^- s - printf ("Thread1: Mutex Released!\n");, V9 q5 L$ ]* y+ v# ~
- osMutexRelease(MutexHandle);2 l' ~$ o" M" ? }8 V
- #endif$ \1 } W4 {5 h# j5 x+ a% K
- HAL_GPIO_TogglePin(LED1_GREEN_GPIO_Port, LED1_GREEN_Pin);7 f9 l8 y: X I
- osDelay(200);
H; ?+ O7 M! ]% Q4 y. D - }' u, q. E/ A# l, R6 k
- L E& t+ z1 W# T6 y( U0 `$ R6 W - while(1)
' I4 ^$ s# g7 I! q2 A: T1 ?1 \ - {
! {3 A$ J/ [" c/ { - HAL_GPIO_TogglePin(LED1_GREEN_GPIO_Port, LED1_GREEN_Pin);
* a5 J$ S* V" h; w+ w - osDelay(1000);
6 x& r% f7 e& O- o% \ - }
2 g' V. {3 D# a1 I: C - /* USER CODE END Thread1 */
5 D( u; R* V# L O- x% v# i - }
. ^( D* D, y+ X6 T; M6 x% t: {* ? - 7 l8 V) b1 t5 l) a1 k$ g6 `
- /* USER CODE BEGIN Header_Thread2_Entry */
: A a# a7 U8 w - /**
- O0 j, ~! ]. L9 Z - * @brief Function implementing the Thread2 thread.: |6 T: d3 a4 L9 x, e
- * @param argument: Not used. W9 n( Q& \5 P
- * @retval None
1 f# H2 P) u* y# v- ?) v# \2 n. y- C - */
/ m9 o+ h7 y/ D- z- m: C1 s( G3 N - /* USER CODE END Header_Thread2_Entry */4 S1 m3 X$ K% p( I. Z" ]
- void Thread2_Entry(void *argument)
5 ?- d6 G& z% C; Y: e) B% a; A5 r - {+ y9 {) r7 E. _% H% K& G
- /* USER CODE BEGIN Thread2 */1 P" B' p3 N) z4 L# C6 w2 F
- uint16_t i;
: d3 b) Y& r% i( ?4 S& _8 l -
) [' \( \$ K! ]2 x" R - /* Infinite loop */
5 Z9 S# H3 z, V# j7 n: P9 g# ` - for(i = 0; i < 10; ++i)7 Q( `, `% ?6 d' F8 O
L3 e5 A+ p1 S/ d. t( X( K - #if EXAMPLE_USES_MUTEX- [, r" [/ Y& n4 Y9 ?
- osMutexAcquire(MutexHandle, osWaitForever);9 p/ d/ l' J! M! w
- printf ("Thread2: Mutex Acquired!\n");* f* ^! }! I8 A6 I
- #endif
+ X0 M& A5 f* _4 A -
# l" H+ k! Z1 D& g# j9 ~ - printf("Thread2 : This is message number %u\n", i+1);1 X9 s$ Z. s9 Z% ^( l
- #if EXAMPLE_USES_MUTEX- x# A: ~0 a$ d; S, l5 V
- printf ("Thread2: Mutex Released!\n");
$ p/ P, |9 `. N$ a - osMutexRelease(MutexHandle);
$ ?4 ^9 k& n2 ?4 [+ c0 I4 t5 J - #endif
6 `: ]& z6 `1 p9 L, v s5 D4 O: m - HAL_GPIO_TogglePin(LED2_YELLOW_GPIO_Port, LED2_YELLOW_Pin);
% T' r, w* J4 F3 C7 e: Q - osDelay(200);
- G" y4 X, K0 J+ n& d - }" j% S' Y# v9 b. O9 S
- 2 _" [0 C; q q1 `8 Z
- while(1)
( s& Q& y+ K' @6 u \0 F0 _ - {
/ w/ ?9 F9 h" T8 [* t* l& h - HAL_GPIO_TogglePin(LED2_YELLOW_GPIO_Port, LED2_YELLOW_Pin);7 O8 p% a- I' v/ y. v
- osDelay(1000);2 V6 h4 \# o& w) J8 X# E5 w, F7 h
# {& N7 j, T9 k! L2 z/ S G - /* USER CODE END Thread2 */
1 V6 A1 c2 q+ f - }; n/ \$ C3 X1 W+ f/ q
- # V3 n0 _5 A5 _& ~/ p) ~
- /* Private application code --------------------------------------------------*//* USER CODE BEGIN Application */3 N) T3 K. a2 N( O
- /* USER CODE END Application */
复制代码 $ X6 I5 a6 Z# q! ~0 b6 A. F6 I* x. N
6 s9 W. r) |- E" d0 z9 @% i
进程先获取信号锁,在进行打印输出,输出完成后再解锁,这样可以保证三段打印都是同一个线程的输出。可以看出每次的输出都是一个线程的信息。下面进行PWM的改造测试PWM的设置如图,使用LED1作为PWM的输出,所以设置PB0作为TIM3的CH3通道,PWM输出,脉宽比为50%,所以计数为2048,PLUSE VALUE=1024。设置好以后将程序进行改造,另起一个项目通过CUBE生成初始化代码,然后改造项目。- ! x! S( [3 A0 C( ~# B; q7 d; C
- /* USER CODE BEGIN Header_Thread1_Entry */( W2 I0 y, K; |) E7 Q& O0 T
& ~" \+ X% r) N - * @brief Function implementing the Thread1 thread.
2 F; F% ]8 X* M% X% x% z6 I+ w - * @param argument: Not used
6 W' F7 A" Z3 {. ^( t" l - * @retval None9 q' _3 K, T) T
- Q1 p& ]0 t0 m% k, Z - /* USER CODE END Header_Thread1_Entry */
7 Y- n. `# o4 ?& a" v - void Thread1_Entry(void *argument)0 W2 S/ p, P! J( K2 E! n5 t
- {; ^( Z+ q. p0 F" \. ~7 Q- l2 U
2 R$ F0 E8 G" }9 T& N0 {1 T - osMutexAcquire(MutexHandle, osWaitForever);$ p/ R+ `1 b# U( D
" C& u" \7 j P7 v2 c, J- X - printf("Thread1 : PWM starter\n ");
6 V8 x& J/ _& l1 r8 @& M% t7 D - printf ("Thread1: Mutex Released!\n");
! m# V! t. R- k& N3 I - osMutexRelease(MutexHandle);
+ {3 U) G7 J: X, G5 Z6 Z - HAL_TIM_PWM_Start(&htim3,TIM_CHANNEL_3);8 P8 u4 ^8 X3 @" U1 B; U6 J
- while(1)* @- w l5 d) B6 O( B( X8 l' N
: r& S4 ^4 l& R# w+ C6 n! _1 Q - osDelay(1);" q( F( ]& [9 |0 Q; S, }% K: n. T/ j
- }( A# l) `4 _# ]) t1 r% Z& K, i
- /* USER CODE END Thread1 */ @) Z3 A" K `& |% V% @0 F
复制代码 项目启动后。可以看到LED1开始开始工作。
~8 q' Z' t6 C( q/ L) e# ~# B6 G
4 y% T4 S; u2 G. b1 T来源:EEWORLD论坛网友 bigbat 版权归原作者所有' \8 t. Q" N) a
2 h$ T3 F1 G: E' V' i& G+ ^7 A$ b- D/ C+ @6 J( Z' D
