/* TIM1 init function */ void MX_TIM1_Init(uint32_t arr,uint32_t psc) { /* USER CODE BEGIN TIM1_Init 0 */ /* USER CODE END TIM1_Init 0 */ TIM_ClockConfigTypeDef sClockSourceConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; TIM_OC_InitTypeDef sConfigOC = {0}; TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0}; /* USER CODE BEGIN TIM1_Init 1 */ /* USER CODE END TIM1_Init 1 */ htim1.Instance = TIM1; htim1.Init.Prescaler = psc; htim1.Init.CounterMode = TIM_COUNTERMODE_UP; htim1.Init.Period = arr; htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim1.Init.RepetitionCounter = 0; htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; if (HAL_TIM_Base_Init(&htim1) != HAL_OK) { Error_Handler(); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK) { Error_Handler(); } if (HAL_TIM_PWM_Init(&htim1) != HAL_OK) { Error_Handler(); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK) { Error_Handler(); } sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = (arr * 3)/4; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; //sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET; sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_SET; if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_4) != HAL_OK) { Error_Handler(); } sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE; sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE; sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF; sBreakDeadTimeConfig.DeadTime = 0; sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE; sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH; sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE; if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN TIM1_Init 2 */ /* USER CODE END TIM1_Init 2 */ HAL_TIM_MspPostInit(&htim1); } main函数里while按计数设置tim1_ch4的占空比; while (1) { /* USER CODE END WHILE */ HAL_Delay(500); __HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_4,plus_cnt); //drv8424_step(200,half_T); /* USER CODE BEGIN 3 */ } |
串口空闲+DMA接收GPS信号,空闲中断触发时间不对。
STM32407 使用串口闲时中断+DMA方式接收最大接收字节是多少
stm32编码器模式计数问题
外部按键硬件级防抖功能
串口DMA + 空闲中断收发 ?
STM32L433 单片机在串口配置为IRDA模式后,IRDA是否可以在STOP Mode1下唤醒
两个TIM调用HAL_TIM_PeriodElapsedCallback发生冲突
为何Tim2自动装载定时的首次中断时间总是设定时间的2倍?
STM32H5的I3C模块,target rx和tx时,硬件都存在bug
上电RC,电阻1M 电容0.1uf,导致uart失效
建议参考一下库里面的例程。
