STM32 H7B0VBT6同时使用A和B闹钟,操作备份寄存器导致闹钟无法唤醒
Despais 提问时间:2024-7-16 12:32 / 未解决
/* USER CODE BEGIN Header */
  * @file    rtc.c
  * @brief   This file provides code for the configuration
  *          of the RTC instances.
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "rtc.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
RTC_HandleTypeDef hrtc;
/* RTC init function */
void MX_RTC_Init(void)
  /* USER CODE BEGIN RTC_Init 0 */
  /* USER CODE END RTC_Init 0 */
  RTC_TimeTypeDef sTime = {0};
  RTC_DateTypeDef sDate = {0};
  RTC_AlarmTypeDef sAlarm = {0};
    uint32_t Backup_register;
  /* USER CODE BEGIN RTC_Init 1 */
  /* USER CODE END RTC_Init 1 */
  /** Initialize RTC Only
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN Check_RTC_BKUP */
//  Backup_register = power_bkp_read(0);
//  if (Backup_register == 0x5050) {
//              /* USER CODE END Check_RTC_BKUP */
//              /** Initialize RTC and set the Time and Date
//              sTime.Hours = 0;
//              sTime.Minutes = 0;
//              sTime.Seconds = 0;
//              sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
//              sTime.StoreOperation = RTC_STOREOPERATION_RESET;
//              if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BIN) != HAL_OK)
//                  Error_Handler();
//              sDate.WeekDay = RTC_WEEKDAY_FRIDAY;
//              sDate.Month = RTC_MONTH_JULY;
//              sDate.Date = 18;
//              sDate.Year = 23;
//              if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BIN) != HAL_OK)
//                  Error_Handler();
//              /** Enable the Alarm A
//              sAlarm.AlarmTime.Hours = 0;
//              sAlarm.AlarmTime.Minutes = 0;
//              sAlarm.AlarmTime.Seconds = 15;
//              sAlarm.AlarmTime.SubSeconds = 0;
//              sAlarm.AlarmTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
//              sAlarm.AlarmTime.StoreOperation = RTC_STOREOPERATION_RESET;
//              sAlarm.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY|RTC_ALARMMASK_HOURS
//        |RTC_ALARMMASK_MINUTES;
//              sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_ALL;
//              sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE;
//              sAlarm.AlarmDateWeekDay = 1;
//              sAlarm.Alarm = RTC_ALARM_A;
//              if (HAL_RTC_SetAlarm_IT(&hrtc, &sAlarm, RTC_FORMAT_BIN) != HAL_OK)
//                  Error_Handler();
//              /** Enable the Alarm B
//              sAlarm.AlarmTime.Seconds = 30;
//              sAlarm.Alarm = RTC_ALARM_B;
//                  Error_Handler();
//              /* USER CODE BEGIN RTC_Init 2 */
//              power_bkp_write(0, 0x5051);
  /* USER CODE END RTC_Init 2 */
void HAL_RTC_MspInit(RTC_HandleTypeDef* rtcHandle)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  if(rtcHandle->Instance==RTC)
  /* USER CODE BEGIN RTC_MspInit 0 */
  /* USER CODE END RTC_MspInit 0 */
  /** Initializes the peripherals clock
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
    PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
      Error_Handler();
    /* RTC clock enable */
    __HAL_RCC_RTC_ENABLE();
    /* RTC interrupt Init */
        HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_2);
    HAL_NVIC_SetPriority(RTC_Alarm_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(RTC_Alarm_IRQn);
  /* USER CODE BEGIN RTC_MspInit 1 */
  /* USER CODE END RTC_MspInit 1 */
void HAL_RTC_MspDeInit(RTC_HandleTypeDef* rtcHandle)
  /* USER CODE BEGIN RTC_MspDeInit 0 */
  /* USER CODE END RTC_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_RTC_DISABLE();
    /* RTC interrupt Deinit */
    HAL_NVIC_DisableIRQ(RTC_Alarm_IRQn);
  /* USER CODE BEGIN RTC_MspDeInit 1 */
  /* USER CODE END RTC_MspDeInit 1 */
/* USER CODE BEGIN 1 */
uint8_t set_system_time(uint8_t hours, uint8_t minutes, uint8_t seconds) {
        sTime.Hours = hours;
        sTime.Minutes = minutes;
        sTime.Seconds = seconds;
                return 1;
                Error_Handler();
        } else {
                return 0;
uint8_t set_system_date(uint8_t year, uint8_t month, uint8_t date, uint8_t weekDay) {
        sDate.WeekDay = weekDay;
        sDate.Month = month;
        sDate.Date = date;
        sDate.Year = year;
                return 1;
                Error_Handler();
        } else {
                return 0;
uint8_t set_alarm_A(uint8_t hours, uint8_t minutes, uint8_t seconds, uint8_t weekDay) {
        sAlarm.AlarmTime.Hours = hours;
        sAlarm.AlarmTime.Minutes = minutes;
        sAlarm.AlarmTime.Seconds = seconds;
//    Backup_register = hours;
//    Backup_register <<= 8;
//    Backup_register |= minutes;
//    Backup_register |= seconds;
//    power_bkp_write(0, Backup_register);       /* 0 address write  */
//      sAlarm.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY;
        sAlarm.AlarmDateWeekDay = weekDay;
                return 1;
                Error_Handler();
        } else {
                return 0;
uint8_t set_alarm_B(uint8_t hours, uint8_t minutes, uint8_t seconds, uint8_t weekDay) {
                return 1;
                Error_Handler();
        } else {
                return 0;
uint8_t get_alarm_time(uint8_t *hours, uint8_t *minutes, uint8_t *seconds) {
        RTC_TimeTypeDef rtc_t = {0};
        if (HAL_RTC_GetTime(&hrtc, &rtc_t, RTC_FORMAT_BIN) == HAL_OK) {
                *hours = rtc_t.Hours;
                *minutes = rtc_t.Minutes;
                *seconds = rtc_t.Seconds;
                return 1;
        } else {
                return 0;
uint8_t get_alarm_date(uint8_t *year, uint8_t *month, uint8_t *date, uint8_t *weekDay) {
        RTC_DateTypeDef rtc_d = {0};
        if (HAL_RTC_GetDate(&hrtc, &rtc_d, RTC_FORMAT_BIN) == HAL_OK) {
                *year = rtc_d.Year;
                *month = rtc_d.Month;
                *date = rtc_d.Date;
                *weekDay = rtc_d.WeekDay;
                return 1;
        } else {
                return 0;
void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *rtc_handle_A) {
        char infoA[]="Alarm A(xx:xx:%02d) trigger: \r\n";
        char sendBuff[128] = {0};
        get_alarm_time(&rtc_t.Hours, &rtc_t.Minutes, &rtc_t.Seconds);
        sprintf(sendBuff, infoA, rtc_t.Seconds);
        printf("\r\n ---------- A alarm ----------\r\n");
    printf("%s", sendBuff);
        printf(" ---------- A alarm ----------\r\n\r\n");
        led_switch = ALARM_A;
void HAL_RTCEx_AlarmBEventCallback(RTC_HandleTypeDef *rtc_handle_B) {
    char infoB[]="Alarm B(xx:xx:%02d) trigger: \r\n";
        sprintf(sendBuff, infoB, rtc_t.Seconds);
        printf("\r\n ---------- B alarm ----------\r\n");
        printf(" ---------- B alarm ----------\r\n\r\n");
        led_switch = ALARM_B;
/* USER CODE END 1 */
收藏 评论1 发布时间:2024-7-16 12:32
xmshao 回答时间:2024-7-16 16:08:35
一点点提醒供参考:
对RTC寄存器和backup 寄存器写操作时都需要取消写保护,完成相应操作之后再开启写保护。
你操作这两部分时注意这个问题,不要弄混乱了。
建议对这两块分开配置或编程,不要穿插在一起。
