本帖最后由 yon-gjun 于 2015-8-14 07:48 编辑 ' N4 }2 g( I1 G/ @/ k+ y
+ N* S9 N" F* P* s
https://pan.baidu.com/s/1hq92Zwo ) v: \2 H1 ?8 j" h
Microcontroller Development Kit - Version 5.16- [ARM Compiler]" D/ w9 P; M6 n' e
- This MDK release contains ARM Compiler 5.06 (build 20) which includes support for STM32L4xx based devices. All compiler related files located in ..\ARM\ARMCC\directory. Details can be found in the Compiler specific Release Notes.9 v( D0 R9 D; B
- [uVision]
6 y8 d+ U0 m* ?, u4 S" Y8 P$ z- This MDK release contains µVision V5.16.0.
- Improved: Project build now takes advantage of systems that have multiple processors or multiple-core processors. Additional build processes are created to utilize the available processors and therefore drastically reduce the overall built time. µVision can process these builds simultaneously, and therefore overall build time is reduced.
- Added: With the menu Edit – Configuration - Right Margin a line boarder can be configured which is show as vertical line or coloured background.
- Added: compiler toolchain documentation is now also accessible in PDF format from the Books Window. e7 m d3 g T- z7 y3 m/ R
- [Software Packs included], L( o: m# ]6 \4 H
- Keil - MDK-ARM Professional Middleware 6.5.0
" a; e9 q; H9 _/ T; LThe Keil::MDK-Middleware 6.5.0 Software Pack contains several enhancements and corrections. Improved are the Graphic Library, File System, and USB Host. - ARM - CMSIS 4.3.0
+ T0 i# s$ B$ |% x JThe ARM::CMSIS 4.3.0 Software Pack adds a CMSIS-Driver for Serial Audio Interface (SAI) and improves CMSIS-RTOS RTX with Stack Watermark and IRQ timing statistics. Included are also several other enhancements such as cache control functions for Cortex-M7. - Keil - ARM Compiler Extensions 1.0.0) h: L/ t, t+ J5 b$ |5 |
The Keil::ARM_Compiler 1.0.0 Software Pack contains the new Software Component Compiler that expands MicroLib with assert and enables I/O re-targeting via File System, UART, ITM debug channel, or user-defined functions.. O9 E$ B* K" E; u* g: n
- [Target debugging]; \0 G& Y6 c" x8 t/ {6 X/ j% k
- Updated: Segger J-Link driver for ARM devices to version 4.98e.
- Updated: the STMicroelectronics ST-LINKIII-KEIL_SWO.dll to version 2.0.17.7 A" B/ ?# }$ ?! M: z+ K
- [Supported Operating Systems]' b8 X; A5 o2 g; Y6 y& R0 C; [
7 O: z# M c# U! i, n
/ C( C1 Q# @8 C$ w+ @$ O: ]. q |
