使用STM32CUBE生成STM32L073的工程,如何实现us级延时?
烟花绽放 提问时间:2016-5-10 10:30 /
HAL库里面有ms级的延时__weak void HAL_Delay(__IO uint32_t Delay)
  uint32_t tickstart = 0;
  tickstart = HAL_GetTick();
  while((HAL_GetTick() - tickstart) < Delay)
但是如何实现us级的延时呢?
昨天尝试着修改了
__weak HAL_StatusTypeDef HAL_Delay_us(uint32_t TickPriority)
  /*Configure the SysTick to have interrupt in 1ms time basis*/
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  /*Configure the SysTick IRQ priority */
  HAL_NVIC_SetPriority(SysTick_IRQn, TickPriority ,0);
   /* Return function status */
  return HAL_OK;
没有实现要求,而且还出现了其他问题,程序不运行,所以想请教一下大家,如何在HAL库中实现us延时?
目前在做DHT11的程序
赞 收藏 评论23 发布时间:2016-5-10 10:30
23个回答
jtc_88 回答时间:2016-5-12 08:22:20
我使用的STM32F030R8 的程序 别的改一下 DS18B20试过没问题 可以达到效果,这个程序我后来移植了好几个项目,成熟度还是可以的,STM32的定时器多可以这么使用。
微秒级延时用函数
void Delay_us(uint16_t nus)
        __HAL_TIM_SetCounter(&htim17, 0);//htim17 可以更改为任何一个 定时器
        __HAL_TIM_ENABLE(&htim17);
        while(__HAL_TIM_GetCounter(&htim17) < (48 * nus));//48是系统时钟频率 更换不同的 系列单片机 只修改 48这个数据
         /* Disable the Peripheral */
        __HAL_TIM_DISABLE(&htim17);
《tim.c》
  * File Name          : TIM.c
  * Description        : This file provides code for the configuration
  *                      of the TIM instances.
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "tim.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
TIM_HandleTypeDef htim14;
TIM_HandleTypeDef htim16;
TIM_HandleTypeDef htim17;
/* TIM14 init function */
void MX_TIM14_Init(void)
  htim14.Instance = TIM14;
  htim14.Init.Prescaler = 0;
  htim14.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim14.Init.Period = 65535;
  htim14.Init.ClockDivision = TIM_CLOCKDIVISION_DIV2;
  HAL_TIM_Base_Init(&htim14);
/* TIM16 init function */
void MX_TIM16_Init(void)
  htim16.Instance = TIM16;
  htim16.Init.Prescaler = TIM16_PSC;
  htim16.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim16.Init.Period = 65535;
  htim16.Init.ClockDivision = TIM_CLOCKDIVISION_DIV2;
  htim16.Init.RepetitionCounter = 0;
  HAL_TIM_Base_Init(&htim16);
/* TIM17 init function */
void MX_TIM17_Init(void)
  htim17.Instance = TIM17;
  htim17.Init.Prescaler = 0;
  htim17.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim17.Init.Period = 65535;
  htim17.Init.ClockDivision = TIM_CLOCKDIVISION_DIV2;
  htim17.Init.RepetitionCounter = 0;
  HAL_TIM_Base_Init(&htim17);
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
  if(htim_base->Instance==TIM14)
  /* USER CODE BEGIN TIM14_MspInit 0 */
  /* USER CODE END TIM14_MspInit 0 */
    /* Peripheral clock enable */
    __TIM14_CLK_ENABLE();
  /* USER CODE BEGIN TIM14_MspInit 1 */
  /* USER CODE END TIM14_MspInit 1 */
  else if(htim_base->Instance==TIM16)
  /* USER CODE BEGIN TIM16_MspInit 0 */
  /* USER CODE END TIM16_MspInit 0 */
    __TIM16_CLK_ENABLE();
  /* USER CODE BEGIN TIM16_MspInit 1 */
  /* USER CODE END TIM16_MspInit 1 */
  else if(htim_base->Instance==TIM17)
  /* USER CODE BEGIN TIM17_MspInit 0 */
  /* USER CODE END TIM17_MspInit 0 */
    __TIM17_CLK_ENABLE();
  /* USER CODE BEGIN TIM17_MspInit 1 */
  /* USER CODE END TIM17_MspInit 1 */
void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base)
  /* USER CODE BEGIN TIM14_MspDeInit 0 */
  /* USER CODE END TIM14_MspDeInit 0 */
    /* Peripheral clock disable */
    __TIM14_CLK_DISABLE();
  /* USER CODE BEGIN TIM14_MspDeInit 1 */
  /* USER CODE END TIM14_MspDeInit 1 */
  /* USER CODE BEGIN TIM16_MspDeInit 0 */
  /* USER CODE END TIM16_MspDeInit 0 */
    __TIM16_CLK_DISABLE();
  /* USER CODE BEGIN TIM16_MspDeInit 1 */
  /* USER CODE END TIM16_MspDeInit 1 */
  /* USER CODE BEGIN TIM17_MspDeInit 0 */
  /* USER CODE END TIM17_MspDeInit 0 */
    __TIM17_CLK_DISABLE();
  /* USER CODE BEGIN TIM17_MspDeInit 1 */
  /* USER CODE END TIM17_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
烟花绽放 回答时间:2018-9-28 13:54:04
xxl131 发表于 2018-9-27 19:41
请问发的贴子在哪里,没找到
void delay_us(uint32_t value)
        uint32_t i;
        i = value * 8;
        while(i--);
这是我用到L0上的延时,
delay_us(30);             //主机拉高20~40us
这是我之前计算出来的,基本上是1us左右,不过没有严格测试,但是驱动DHT11足够了,详细的话可以看我另一个帖子,https://www.stmcu.org.cn/module/forum/thread-606093-1-1.html
涛哥2035 回答时间:2016-5-10 10:48:11
这个函数是设置重载寄存器值得,为1ms,如果想设置1us要改为HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000000);
因为STM32F073最大32M时钟,函数调用等等操作有可能超过32个时钟,所以用中断函数实现1us延时是有难度的。根据需要可以试试10us或者更大时间的延时
烟花绽放 回答时间:2016-5-10 10:56:46
修改成这个样子,昨天试过了,程序下载下去之后直接不运行了,不晓得什么原因
风子 回答时间:2016-5-10 12:09:03
函数库里写明了HAL_Delay会用于HAL库本身配置过程中的很多地方,不能随便改,,可以用另外一个定时器实现
中山无雪 回答时间:2016-5-10 12:41:29
还是使用定时器实现吧,那样更好操作些
烟花绽放 回答时间:2016-5-10 12:42:17
中山无雪 发表于 2016-5-10 12:41
还是使用定时器实现吧,那样更好操作些
好的,,我去试一下
烟花绽放 回答时间:2016-5-10 12:42:33
风子 发表于 2016-5-10 12:09
函数库里写明了HAL_Delay会用于HAL库本身配置过程中的很多地方,不能随便改,,可以用另外一个定时器实现 ...
嗯嗯嗯,我去试一下
huaiqiao 回答时间:2016-5-10 13:09:08
HAL_Delay 这个函数里面有说明的,它就是毫秒级的延时呀。
ifif 回答时间:2016-5-10 14:49:17
用systick写个定时,可以到1us,挺准的
烟花绽放 回答时间:2016-5-10 16:33:21
试了,,但是也是不行,今天晚上回去写个像用51时的延时函数,不行的话就开个定时器
assssdz 回答时间:2016-5-12 00:22:33
我去试一下
烟花绽放 回答时间:2016-5-12 09:17:01
jtc_88 发表于 2016-5-12 08:22
我使用的STM32F030R8 的程序 别的改一下 DS18B20试过没问题 可以达到效果,这个程序我后来移植了好几个项目 ...
感谢哦,,我研究一下,还真没有用过HAL库的定时器呢,,之前都是在用标准库的
烟花绽放 回答时间:2016-5-12 11:12:11
你好,能不能麻烦你发一下完整的工程,这段代码不是太明白,。适应STM32CUBE生产的定时器工程也在看,但是和你发的这段代码不太相同
david2016 回答时间:2016-5-12 17:37:43
是不是写IIC的那个孩子?  nop啊
12下一页
