关于STM32L011D4求助
丹心汗青 提问时间:2016-9-8 09:50 /
#include "usart.h"
extern void Error_Handler(void);
UART_HandleTypeDef huart2;
UART_HandleTypeDef husart_debug;
UART_HandleTypeDef UartHandle;
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(huart->Instance==USART2)
  /* USER CODE BEGIN USART2_MspInit 0 */
  /* USER CODE END USART2_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_USART2_CLK_ENABLE();
    /**USART2 GPIO Configuration
    PA0-CK_IN     ------> USART2_RX
    PA9     ------> USART2_TX
    GPIO_InitStruct.Pin = GPIO_PIN_0;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF0_USART2;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_9;
  /* USER CODE BEGIN USART2_MspInit 1 */
  /* USER CODE END USART2_MspInit 1 */
void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
  /* USER CODE BEGIN USART2_MspDeInit 0 */
  /* USER CODE END USART2_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_USART2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_9);
void MX_USART2_UART_Init(void)
        __HAL_RCC_GPIOA_CLK_ENABLE();
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  //huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  //HAL_UART_Init(&huart2);
         if (HAL_UART_Init(&UartHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
  * º¯Êý¹¦ÄÜ: ÖØ¶¨Ïòc¿âº¯Êýprintfµ½DEBUG_USARTx
  * ÊäÈë²ÎÊý: ÎÞ
  * ·µ »Ø Öµ: ÎÞ
  * ˵    Ã÷£ºÎÞ
int fputc(int ch, FILE *f)
  HAL_UART_Transmit(&husart_debug, (uint8_t *)&ch, 1, 0xffff);
  return ch;
  * º¯Êý¹¦ÄÜ: ÖØ¶¨Ïòc¿âº¯Êýgetchar,scanfµ½DEBUG_USARTx
  * ÊäÈë²ÎÊý: ÎÞ
  * ·µ »Ø Öµ: ÎÞ
  * ˵    Ã÷£ºÎÞ
int fgetc(FILE * f)
  uint8_t ch = 0;
  HAL_UART_Receive(&husart_debug,&ch, 1, 0xffff);
  return ch;
int main(void)
                        /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
                        HAL_Init();
                        /* Configure the system clock */
                        SystemClock_Config();
                        /* Initialize all configured peripherals */
                        //MX_GPIO_Init();
                        //MX_ADC_Init();
            MX_USART2_UART_Init();
            while (1)
                        //        I2C_Write(0x0000,1);
                     printf("s");
                                HAL_Delay(500);
型号是STM32L011什么波形都没有,哪位大神帮忙看下谢谢!
赞 收藏 1 评论8 发布时间:2016-9-8 09:50
8个回答
无薪税绵 回答时间:2016-9-11 08:48:17
只看到开启了串口功能,楼主想要什么波形呢。
ljman1101 回答时间:2016-9-11 11:16:53
楼主想要串口波形还是I2C的波形呢?,能否描述清楚
丹心汗青 回答时间:2016-9-11 14:05:59
有通信,串口线就会产生方波不是?
豆泥丸 回答时间:2016-9-11 15:41:56
程序中哪有向串口缓冲发数据的,不发数据哪来波形
Stm32McuLover 回答时间:2016-9-11 18:01:49
看看我发的帖子,里面用到了串口,PWM
feixiang20 回答时间:2016-9-11 23:14:29
串口产生方波
anywill 回答时间:2016-10-23 17:48:49
代码太长,看不出哪里关键
samhong 回答时间:2016-12-1 11:44:07
有通信,串口线的波没测过,没在意过是什么波形。直接看16进制。
